dimaxus Posted September 23, 2019 Posted September 23, 2019 Thanks to everyone. I figured it out myself. 0 Quote
dimaxus Posted September 23, 2019 Posted September 23, 2019 One more question . What version of Debian is the Armbian Buster based on? 0 Quote
jeanrhum Posted September 24, 2019 Posted September 24, 2019 12 hours ago, dimaxus said: Buster You give the answer in the question . So if you don't know, buster is the name of debian 10. 0 Quote
gounthar Posted April 14, 2020 Posted April 14, 2020 Hi, I tried today the latest image Armbian_20.02.1_Orangepi-rk3399_buster_current_5.4.20_desktop.img for the Orange Pi RK3399, and got ## Executing script at 00500000 Boot script loaded from mmc 1 102 bytes read in 17 ms (5.9 KiB/s) 34210 bytes read in 487 ms (14 MiB/s) 0722176 bytes read in 1353 ms (14.6 MiB/s) * File not found /boot/dtb/ ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 698 bytes read in 32 ms (82 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 39000000 ## Loading init Ramdisk from Legacy Image at 04000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 7134146 Bytes = 6.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... K ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... I know my board is nit-picky, and I will try another image, but does the log says anything that could be helpful? Thanks. 0 Quote
martinayotte Posted April 14, 2020 Posted April 14, 2020 11 minutes ago, gounthar said: * File not found /boot/dtb/ ** It seems to be clear that DTB is missing ... 1 Quote
gounthar Posted April 14, 2020 Posted April 14, 2020 Same with image Armbian_20.02.1_Orangepi-rk3399_buster_legacy_4.4.213 canning mmc 1:1... ound U-Boot script /boot/boot.scr 40 bytes read in 22 ms (129.9 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 102 bytes read in 17 ms (5.9 KiB/s) 674569 bytes read in 520 ms (14.1 MiB/s) 0492296 bytes read in 1338 ms (14.6 MiB/s) * File not found /boot/dtb/ ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! ile not found /boot/dtb/rockchip/overlay/rockchip-fixup.scr ** # Loading init Ramdisk from Legacy Image at 04000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 7674505 Bytes = 7.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... => 0 Quote
gounthar Posted April 14, 2020 Posted April 14, 2020 And another... Armbian_20.02.1_Orangepi-rk3399_bionic_legacy_4.4.213_desktop 940 bytes read in 22 ms (129.9 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 102 bytes read in 17 ms (5.9 KiB/s) 36013 bytes read in 583 ms (14.1 MiB/s) 0492296 bytes read in 1341 ms (14.6 MiB/s) ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! * File not found /boot/dtb/rockchip/overlay/rockchip-fixup.scr ** Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... => CTRL-A Z for help | 1500000 8N1 | I suppose that the board is the problem, and not each and every Armbian image. 0 Quote
martinayotte Posted April 14, 2020 Posted April 14, 2020 39 minutes ago, gounthar said: * File not found /boot/dtb/ ** Again, some "file not found" ... Could be that you have an incompatible U-Boot present in the eMMC which prevent reading properly the SDCard images. Make sure that you have TP50265 shorted to GND to disable the eMMC completely, and then it will boot using the U-Boot present on the SDCard. 0 Quote
gounthar Posted April 14, 2020 Posted April 14, 2020 Thanks. I think this card has the eMMC kind of broken. By jumper, do you mean the test pads shorcut, because I can't see any jumper on the board... 0 Quote
martinayotte Posted April 14, 2020 Posted April 14, 2020 Just now, gounthar said: do you mean the test pads shorcut Right ! I've corrected my reply, (jumper was in the case of RockPro64, TP50265 test point in case of OrangePi-RK3399) ... 0 Quote
gounthar Posted April 14, 2020 Posted April 14, 2020 I now can remember why I had put this board aside for a few months... Whenever I think I managed to get it to start on the SDCard, I get DDR Version 1.08 20170320 In hannel 0: DDR3, 800MHz BMB Channel 1: DDR3, 800MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB 256B stride ch 0 ddrconfig = 0x101, ddrsize = 0x20 ch 1 ddrconfig = 0x101, ddrsize = 0x20 pmoot1: 2017-04-07, version: 1.06 CPUId = 0x0 ChipType = 0x10, 1838 2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 SdmmcInit=0 0 BootCapSize=0 UserCapSize=15193MB FwPartOffset=2000 , 0 StorageInit ok = 195484 LoadTrustBL No find bl30.bin o find bl32.bin unBL31 0x40000 NOTI Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services INFO: BL31: Initializing BL32 and nothing else. Never. Ever. 0 Quote
martinayotte Posted April 14, 2020 Posted April 14, 2020 2 hours ago, gounthar said: nothing else This U-Boot seems to be pretty old ... The one I built recently is booting fine 5.6.2 from eMMC : DDR Version 1.24 20191016 In soft reset SRX Channel 0: DDR3, 800MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB Channel 1: DDR3, 800MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB 256B stride ch 0 ddrconfig = 0x101, ddrsize = 0x20 ch 1 ddrconfig = 0x101, ddrsize = 0x20 pmugrf_os_reg[2] = 0x32817281, stride = 0x9 OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 307 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 SdmmcInit=0 1 StorageInit ok = 67497 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xa5d94 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.01-armbian (Apr 06 2020 - 16:14:46 -0400) Model: Orange Pi RK3399 Board DRAM: 2 GiB PMIC: RK808 MMC: dwmmc@fe310000: 2, dwmmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial@ff1a0000 Out: serial@ff1a0000 Err: serial@ff1a0000 Model: Orange Pi RK3399 Board rockchip_dnl_key_pressed: adc_channel_single_shot fail! Net: eth0: ethernet@fe300000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 2940 bytes read in 19 ms (150.4 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 0 209 bytes read in 16 ms (12.7 KiB/s) 7746799 bytes read in 755 ms (9.8 MiB/s) 22217216 bytes read in 2122 ms (10 MiB/s) 74021 bytes read in 38 ms (1.9 MiB/s) 1266 bytes read in 33 ms (37.1 KiB/s) Applying kernel provided DT overlay rockchip-spi-spidev.dtbo 2698 bytes read in 33 ms (79.1 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 39000000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 7746735 Bytes = 7.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to 7d7be000, end 7df214af ... OK Loading Device Tree to 000000007d743000, end 000000007d7bdfff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.6.2-rockchip64 (root@giroles-hpel8300) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #trunk SMP PREEMPT Mon Apr 6 16:26:34 EDT 2020 [ 0.000000] Machine model: Orange Pi RK3399 Board ... 1 Quote
gounthar Posted April 14, 2020 Posted April 14, 2020 Would you mind sharing your image @martinayotte? 0 Quote
martinayotte Posted April 14, 2020 Posted April 14, 2020 54 minutes ago, gounthar said: Would you mind sharing your image @martinayotte? Here it is : https://mega.nz/file/fS5XhTQI#_7bZ_jw4XdqFWc_9x6wAI1s07sEnKoamqOBqhMf_hc8 1 Quote
gounthar Posted April 15, 2020 Posted April 15, 2020 Ok, the image does not change the message... I guess my RK3399 boards (1*2GB 1*4GB) can't use the TP50265 anymore... Or is it a chair-to-keyboard interface problem? 0 Quote
martinayotte Posted April 15, 2020 Posted April 15, 2020 26 minutes ago, gounthar said: can't use the TP50265 anymore Are you sure your short is correctly done ? 0 Quote
gounthar Posted April 15, 2020 Posted April 15, 2020 Almost, except if the pads are really worn out... The "almost" is because I'm still afraid of the chair-to-keyboard interface problem... 0 Quote
gounthar Posted April 15, 2020 Posted April 15, 2020 Ok, I think I managed to get the pads to work ONE time... And I managed to boot Armbian, thanks a lot for your help and patience... Now, I'm using it through one USB2UART thingie on an OrangePi Zero, but I don't have all the characters... So... Quick quick quick add Wifi via command line, and let's go to work. Thanks a ton for your help! 0 Quote
martinayotte Posted April 15, 2020 Posted April 15, 2020 3 minutes ago, gounthar said: And it never goes farther. You should change the "verbosity=1" to "verbosity=7" in /boot/armbianEnv.txt 1 Quote
gounthar Posted April 15, 2020 Posted April 15, 2020 I now have a working OrangePi RK3399, thanks a lot. I haven't seen on the download page that the wifi was non fonctional, so do we have to use a Wifi USB stick? 0 Quote
martinayotte Posted April 15, 2020 Posted April 15, 2020 22 minutes ago, gounthar said: I now have a working OrangePi RK3399, thanks a lot. After transferring Armbian from SDCard to eMMC, next time you wish to boot SDCard, it will be less painful, no more needs of TP50265 ... Simply stop U-Boot with spacebar, then you can select SD with "setenv devnum 1" followed by "run mmc_boot". 22 minutes ago, gounthar said: I haven't seen on the download page that the wifi was non fonctional, You need to switch firmware to another version : mv /lib/firmware/brcm/brcmfmac4356-sdio.bin /lib/firmware/brcm/brcmfmac4356-sdio.bin-ORIG mv /lib/firmware/brcm/brcmfmac4356-sdio.txt /lib/firmware/brcm/brcmfmac4356-sdio.txt-ORIG cp /lib/firmware/brcm/brcmfmac4356-sdio-nanopi-m4v2.bin /lib/firmware/brcm/brcmfmac4356-sdio.bin cp /lib/firmware/brcm/brcmfmac4356-sdio-nanopi-m4v2.txt /lib/firmware/brcm/brcmfmac4356-sdio.txt 1 Quote
gounthar Posted April 17, 2020 Posted April 17, 2020 Thanks @martinayotte, that made the trick. The board still has lots of connectivity problems, as I lose the Wifi connection a few tens of seconds after the boot (I am able to do a sudo apt update, and then, it's gone). 0 Quote
dimaxus Posted January 24, 2021 Posted January 24, 2021 Good day to all. In the latest builds of the system, bluetooth does not work, maybe someone knows how this is treated, help ... 0 Quote
Werner Posted January 24, 2021 Posted January 24, 2021 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
dimaxus Posted January 24, 2021 Posted January 24, 2021 6.388066] systemd[1]: /lib/systemd/system/rk3399-bluetooth.service:6: Failed to parse service type, ignoring: exec [ 6.388184] systemd[1]: /lib/systemd/system/rk3399-bluetooth.service:11: Support for option SysVStartPriority= has been removed and it is ignored lines from boot log, command armbianmonitor -u dumps log to remote server http://ix.io/2N9v - is this ok? 0 Quote
dimaxus Posted January 24, 2021 Posted January 24, 2021 and here are some more lines: [ 3.025330] of_get_named_gpiod_flags: parsed 'uart_rts_gpios' property of node '/wireless-bluetooth[0]' - status (0) [ 3.025346] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83. [ 3.025377] of_get_named_gpiod_flags: can't parse 'BT,power_gpio' property of node '/wireless-bluetooth[0]' [ 3.025427] of_get_named_gpiod_flags: parsed 'BT,reset_gpio' property of node '/wireless-bluetooth[0]' - status (0) [ 3.025441] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9. [ 3.025488] of_get_named_gpiod_flags: parsed 'BT,wake_gpio' property of node '/wireless-bluetooth[0]' - status (0) [ 3.025502] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90. [ 3.025548] of_get_named_gpiod_flags: parsed 'BT,wake_host_irq' property of node '/wireless-bluetooth[0]' - status (0) [ 3.025562] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4. [ 3.026068] [BT_RFKILL]: Request irq for bt wakeup host [ 3.026159] [BT_RFKILL]: ** disable irq can anyone know how to defeat this? 0 Quote
piter75 Posted January 24, 2021 Posted January 24, 2021 3 hours ago, dimaxus said: can anyone know how to defeat this? You can fix your current installation by running: sudo sed -i s/Type=exec/Type=simple/g /lib/systemd/system/rk3399-bluetooth.service followed by a reboot. Bluetooth in legacy Bionic images will be fixed when they are built next time. 0 Quote
dimaxus Posted January 25, 2021 Posted January 25, 2021 16 hours ago, piter75 said: You can fix your current installation by running: sudo sed -i s/Type=exec/Type=simple/g /lib/systemd/system/rk3399-bluetooth.service followed by a reboot. Bluetooth in legacy Bionic images will be fixed when they are built next time. I did, but the Bluetooth Adapters application still does not start, of course there is no way to add Bluetooth devices, what else can you try? Boot log output: 3.019909] of_get_named_gpiod_flags: parsed 'uart_rts_gpios' property of node '/wireless-bluetooth[0]' - status (0) [ 3.019927] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83. [ 3.019952] of_get_named_gpiod_flags: can't parse 'BT,power_gpio' property of node '/wireless-bluetooth[0]' [ 3.020002] of_get_named_gpiod_flags: parsed 'BT,reset_gpio' property of node '/wireless-bluetooth[0]' - status (0) [ 3.020018] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9. [ 3.020067] of_get_named_gpiod_flags: parsed 'BT,wake_gpio' property of node '/wireless-bluetooth[0]' - status (0) [ 3.020082] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90. [ 3.020131] of_get_named_gpiod_flags: parsed 'BT,wake_host_irq' property of node '/wireless-bluetooth[0]' - status (0) [ 3.020146] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4. [ 3.020702] [BT_RFKILL]: Request irq for bt wakeup host [ 3.020800] [BT_RFKILL]: ** disable irq [ 3.021030] [BT_RFKILL]: bt shut off power [ 3.043187] [BT_RFKILL]: bt_default device registered. [ 7.296310] systemd[1]: /lib/systemd/system/rk3399-bluetooth.service:11: Support for option SysVStartPriority= has been removed and it is ignored 0 Quote
piter75 Posted January 25, 2021 Posted January 25, 2021 32 minutes ago, dimaxus said: I did, but the Bluetooth Adapters application still does not start, of course there is no way to add Bluetooth devices, what else can you try? At first I (somehow...) thought you were using OrangePi 4. Now I see you have OrangePi RK3399 - the issue may stem from something else here. The board has AP6356S module but rk3399-bluetooth service is configured as it was using AP6256. Try one more substitution (and reboot): sudo sed -i s%BCM4345C5%BCM4356A2%g /lib/systemd/system/rk3399-bluetooth.service 0 Quote
