IgorS Posted April 20, 2017 Posted April 20, 2017 (edited) I have seen many tutorials about connecting real time clock hardware on Orange Pi and Raspberry Pi. What i didn't like was removing of fake-hwclock service, because I want that RTC works when it is connected, and fake-hwclock when RTC is not connected. Therefore, I changed /sbin/fake-hwclock script to work in this way. So, here is how to do this, tested on OrangePi+2E, Armbian Ubuntu legacy kernel: Purchase cheap DS3231 module on eBay (cca. $1) like this one: http://www.ebay.com/itm/DS3231-AT24C32-IIC-Modul-High-Precision-Real-Time-Clock-Module-Arduino-New-/292041844936?hash=item43ff0ce8c8:g:d80AAOSwdGFYtsFP Put battery in module. Shutdown and powerof OPi and connect module: Orange (i2c0 bus) RTC module (DS3231 RTC + 24C32 eeprom) 1 3.3V 2 VCC 3 PA12 (TWI0_SDA/DI_RX/PA_EINT12) 3 SDA 5 PA11 (TWI0_SCK/DI_TX/PA_EINT11) 4 SCL 9 GND 1 GND Power up OPi Install i2c-tools. sudo apt install i2c-tools Type command: i2cdetect -y 0 You should see: 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- This means that module is connected properly and that we have DS3231 on address 0x68 and eeprom 24C32 on address 0x57. Type: sudo echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device i2cdetect -y 0 You should see: 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- This means that system is now using our RTC. Also, now should exist new device /dev/rtc1 Be sure that your system time is right, and type: sudo hwclock -w -f /dev/rtc1 Now our RTC must have right time. Check with: sudo hwclock -r -f /dev/rtc1 If everithing was ok, copy /sbin/fake-hwclock to bacup (just in case) sudo cp ~/programming/sh/fake_hwclock/sbin/fake-hwclock /sbin/fake-hwclock Edit /sbin/fake-hwclock and place this code in it: Spoiler !/bin/sh # # script: /sbin/fake-hwclock # Changed by I.S. to use RTC if it is connected # # # Trivial script to load/save current contents of the kernel clock # from/to a file. Helpful as a *bootstrap* clock on machines where # there isn't a useful RTC driver (e.g. on development boards). Using # NTP is still recommended on these machines to get to real time sync # once more of the system is up and running. # # Copyright 2012 Steve McIntyre <93sam@debian.org> # # License: GPLv2, see COPYING # Config variables # RTC is attached on bus... i2c_bus=0 eeprom_address="57" rtc_address="68" # Orange PI +2e have RTC, so our device will be: rtc_device="rtc1" # fake-hwclock is using cron.hourly to periodically save system clock cronfile="/etc/cron.hourly/fake-hwclock" # If you want to periodically synchronize rtc with system time, change this to true update_rtc_periodically=false # End of config variables # I don't know are all needed programs in PATH, # therefore I'll declare all mine echo="/bin/echo" i2cdetect="/usr/sbin/i2cdetect" grep="/bin/grep" awk="/usr/bin/awk" ln="/bin/ln" hwclock="/sbin/hwclock" readlink="/bin/readlink" progs="$echo $i2cdetect $grep $awk $ln $hwclock $readlink" check_external_progs(){ not_found="" prog="" for prog in ${progs} do if [ ! -e "$prog" ]; then not_found=$prog" "$not_found echo "Required program not found: $prog" fi done if [ "$not_found"x = ""x ] ; then progs_ok=true else progs_ok=false fi unset not_found unset prog } recreate_cronjob() { if [ ! -e "$1" ]; then cat << 'EOF' > "$1" #!/bin/sh # # Simple cron script - save the current clock periodically in case of # a power failure or other crash if (command -v fake-hwclock >/dev/null 2>&1) ; then fake-hwclock save fi EOF fi } is_rtc_connected(){ check_external_progs if $progs_ok; then list=$($i2cdetect -y "$i2c_bus") rtc=$(echo "$list" | $grep "60:" | $awk '{print $10}') eeprom=$(echo "$list" | $grep "50:" | $awk '{print $9}') if [ "$eeprom" -eq "$eeprom_address" ]; then case $rtc in "UU") t="/dev/$rtc_device" r=$($readlink -f /dev/rtc) if [ "$r"="$t" ]; then $echo "true" else $ln -sf /dev/$rtc_device /dev/rtc >/dev/null 2>&1 if [ "$r"="$t" ]; then $echo "true" else $echo "false" fi fi;; $rtc_address) $echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device sleep 5 $ln -sf /dev/$rtc_device /dev/rtc >/dev/null 2>&1 t="/dev/$rtc_device" r=$($readlink -f /dev/rtc) if [ "$r"="$t" ]; then $echo "true" else $echo "false" fi;; *) $echo "false";; esac else $echo "false" fi else $echo "false" fi } # Is RTC installed? rtc_installed=$(is_rtc_connected) if $rtc_installed; then # We dont need periodically saving rm -f "$cronfile" >/dev/null 2>&1 else # Restore periodically saving recreate_cronjob "$cronfile" fi if [ "$FILE"x = ""x ] ; then FILE=/etc/fake-hwclock.data fi COMMAND=$1 if [ "$COMMAND"x = ""x ] ; then COMMAND="save" fi FORCE=false if [ "$2"x = "force"x ] ; then FORCE=true fi case $COMMAND in save) if $rtc_installed; then #$echo "RTC save" $hwclock -w if $update_rtc_periodically; then $echo "cronjob restore" recreate_cronjob "$cronfile" fi else if [ -e $FILE ] ; then SAVED="$(cat $FILE)" SAVED_SEC=$(date -u -d "$SAVED" '+%s') NOW_SEC=$(date -u '+%s') if $FORCE || [ $NOW_SEC -ge $SAVED_SEC ] ; then date -u '+%Y-%m-%d %H:%M:%S' > $FILE else echo "Current system time: $(date -u '+%Y-%m-%d %H:%M:%S')" echo "fake-hwclock saved clock information is in the future: $SAVED" echo "To force the saved system clock backwards anyway, use \"force\"" fi else date -u '+%Y-%m-%d %H:%M:%S' > $FILE fi fi ;; load) if $rtc_installed; then #$echo "RTC load" $hwclock -s else if [ -e $FILE ] ; then SAVED="$(cat $FILE)" SAVED_SEC=$(date -u -d "$SAVED" '+%s') NOW_SEC=$(date -u '+%s') if $FORCE || [ $NOW_SEC -le $SAVED_SEC ] ; then date -u -s "$SAVED" else echo "Current system time: $(date -u '+%Y-%m-%d %H:%M:%S')" echo "fake-hwclock saved clock information is in the past: $SAVED" echo "To set system time to this saved clock anyway, use \"force\"" fi else echo "Unable to read saved clock information: $FILE does not exist" fi fi ;; *) echo $0: Unknown command $COMMAND exit 1 ;; esac Reboot. Now you should have right system time backed up by RTC. Edited February 22, 2018 by Tido added Spoiler 4
IgorS Posted April 20, 2017 Author Posted April 20, 2017 I did mistake in step about making backup of /sbin/fake-hwclock, right command is here: sudo cp /sbin/fake-hwclock /sbin/fake-hwclock.original
IgorS Posted April 24, 2017 Author Posted April 24, 2017 New version of fake-hwclock script, some mistakes corrected: Spoiler #!/bin/sh # # script: /sbin/fake-hwclock # Changed by I.S. to use RTC if it is connected # # # Trivial script to load/save current contents of the kernel clock # from/to a file. Helpful as a *bootstrap* clock on machines where # there isn't a useful RTC driver (e.g. on development boards). Using # NTP is still recommended on these machines to get to real time sync # once more of the system is up and running. # # Copyright 2012 Steve McIntyre <93sam@debian.org> # # License: GPLv2, see COPYING # Config variables # RTC is attached on bus... i2c_bus=0 eeprom_address="57" rtc_address="68" # Orange PI +2e have RTC, so our device will be: rtc_device="rtc1" # fake-hwclock is using cron.hourly to periodically save system clock cronfile="/etc/cron.hourly/fake-hwclock" # If you want to periodically synchronize rtc with system time, change this to true update_rtc_periodically=false # End of config variables i2c=false # I don't know are all needed programs in PATH, # therefore I'll declare all mine echo="/bin/echo" i2cdetect="/usr/sbin/i2cdetect" grep="/bin/grep" awk="/usr/bin/awk" ln="/bin/ln" hwclock="/sbin/hwclock" readlink="/bin/readlink" progs="$echo $i2cdetect $grep $awk $ln $hwclock $readlink" check_external_progs(){ not_found="" prog="" for prog in ${progs} do if [ ! -e "$prog" ]; then not_found=$prog" "$not_found echo "Required program not found: $prog" fi done if [ "$not_found"x = ""x ] ; then progs_ok=true else progs_ok=false fi unset not_found unset prog } recreate_cronjob() { if [ ! -e "$1" ]; then cat << 'EOF' > "$1" #!/bin/sh # # Simple cron script - save the current clock periodically in case of # a power failure or other crash if (command -v fake-hwclock >/dev/null 2>&1) ; then fake-hwclock save fi EOF fi } is_rtc_connected(){ check_external_progs if $progs_ok; then # if $i2c; then list=$($i2cdetect -y "$i2c_bus") rtc=$(echo "$list" | $grep "60:" | $awk '{print $10}') eeprom=$(echo "$list" | $grep "50:" | $awk '{print $9}') #rtc=68 if [ "$eeprom" -eq "$eeprom_address" ]; then case $rtc in "UU") t="/dev/$rtc_device" r=$($readlink -f /dev/rtc) if [ "$r" = "$t" ]; then $echo "true" else $ln -sf /dev/$rtc_device /dev/rtc >/dev/null 2>&1 r=$($readlink -f /dev/rtc) if [ "$r" = "$t" ]; then $echo "true" else $echo "false" fi fi;; $rtc_address) $echo ds1307 0x$rtc_address > /sys/class/i2c-adapter/i2c-$i2c_bus/new_device sleep 5 $ln -sf /dev/$rtc_device /dev/rtc >/dev/null 2>&1 t="/dev/$rtc_device" r=$($readlink -f /dev/rtc) if [ "$r" = "$t" ]; then $echo "true" else $echo "false" fi;; *) $echo "false";; esac else $echo "false" fi else $echo "false" fi # else $echo "false" fi } #i2c=true #is_rtc_connected #exit if [ "$FILE"x = ""x ] ; then FILE=/etc/fake-hwclock.data fi COMMAND=$1 if [ "$COMMAND"x = ""x ] ; then COMMAND="save" fi FORCE=false if [ "$2"x = "force"x ] ; then FORCE=true fi # Wait for i2c $i2cdetect -y "$i2c_bus" >/dev/null 2>&1 r=$? if [ "$COMMAND" = "load" ] || [ "$r" -eq 0 ]; then c=20 r=1 until [ "$r" -eq 0 ] || [ "$c" -eq 0 ] do $i2cdetect -y "$i2c_bus" >/dev/null 2>&1 r=$? c=$(($c - 1)) if [ "$r" -eq 0 ]; then i2c=true else sleep 1 fi done fi # Is RTC installed? rtc_installed=$(is_rtc_connected) if $rtc_installed; then # We dont need periodically saving rm -f "$cronfile" >/dev/null 2>&1 else # Restore periodically saving recreate_cronjob "$cronfile" fi case $COMMAND in save) if $rtc_installed; then #$echo "RTC save" $hwclock -w if $update_rtc_periodically; then $echo "cronjob restore" recreate_cronjob "$cronfile" fi else if [ -e $FILE ] ; then SAVED="$(cat $FILE)" SAVED_SEC=$(date -u -d "$SAVED" '+%s') NOW_SEC=$(date -u '+%s') if $FORCE || [ $NOW_SEC -ge $SAVED_SEC ] ; then date -u '+%Y-%m-%d %H:%M:%S' > $FILE else echo "Current system time: $(date -u '+%Y-%m-%d %H:%M:%S')" echo "fake-hwclock saved clock information is in the future: $SAVED" echo "To force the saved system clock backwards anyway, use \"force\"" fi else date -u '+%Y-%m-%d %H:%M:%S' > $FILE fi fi ;; load) if $rtc_installed; then #$echo "RTC load" $hwclock -s else if [ -e $FILE ] ; then SAVED="$(cat $FILE)" SAVED_SEC=$(date -u -d "$SAVED" '+%s') NOW_SEC=$(date -u '+%s') if $FORCE || [ $NOW_SEC -le $SAVED_SEC ] ; then date -u -s "$SAVED" else echo "Current system time: $(date -u '+%Y-%m-%d %H:%M:%S')" echo "fake-hwclock saved clock information is in the past: $SAVED" echo "To set system time to this saved clock anyway, use \"force\"" fi else echo "Unable to read saved clock information: $FILE does not exist" fi fi ;; check) if $rtc_installed; then echo "RTC installed" else echo "RTC not installed" fi ;; *) echo $0: Unknown command $COMMAND exit 1 ;; esac
Gab Posted February 21, 2018 Posted February 21, 2018 Thank you IGOR! I would like to work RTC with software I2C. What do you think, is this possiblity?
Larry Bank Posted February 22, 2018 Posted February 22, 2018 6 hours ago, Gab said: Thank you IGOR! I would like to work RTC with software I2C. What do you think, is this possiblity? Do you mean directly read/write the current time to the RTC registers? Take a look at my C code: https://github.com/bitbank2/rtc_eeprom
guidol Posted March 23, 2018 Posted March 23, 2018 Today I connected a I2C RTC to my NanoPi Neo Core2, worked without a problem....but if anyone is getting the same RTC (ZS-042) and using a CR2032 battery - please remove the smd resistor in the upper right corner, because this board does charge the battery, because there should normally be a LIR2032 rechargeable battery. see https://www.youtube.com/watch?v=ND2shVqV9s4 at 02:00 and I2C instructions athttps://www.raspberrypi-spy.co.uk/2015/05/adding-a-ds3231-real-time-clock-to-the-raspberry-pi/
MarshallMCH Posted March 24, 2018 Posted March 24, 2018 Hi all, I'm looking to connect a DS3231 battery-backed RTC to my OPI PC Plus, and I want to confirm I'm connecting it properly. Here's an image of a Raspberry Pi with the module I'm using (I'm assuming the GPIO is the same config as my OPI). Is this correct? I'm not seeing the eeprom at address 57 when using i2cdetect.
martinayotte Posted March 24, 2018 Posted March 24, 2018 Yes, since the DS3231 is using I2C bus and that both RPi and OPi are using the same pins for I2C/GND/3.3V, you're are safe to use this small module. About EEPROM, that is normal you can't find it with i2cdetect since the EEPROM isn't present on your module, it is a searate chip also attached on I2C bus, on previous picture, it is the 24C32.
Larry Bank Posted March 24, 2018 Posted March 24, 2018 33 minutes ago, MarshallMCH said: Hi all, I'm looking to connect a DS3231 battery-backed RTC to my OPI PC Plus, and I want to confirm I'm connecting it properly. Here's an image of a Raspberry Pi with the module I'm using (I'm assuming the GPIO is the same config as my OPI). Is this correct? I'm not seeing the eeprom at address 57 when using i2cdetect. Yes, those little modules are great; they don't contain any EEPROM, that's why the address isn't visible. Just note the direction of the header on your OrangePi PC Plus. I couldn't find the info for your board, but for my Orange Pi Lite, the header is "backwards"
guidol Posted March 24, 2018 Posted March 24, 2018 3 minutes ago, martinayotte said: Yes, since the DS3231 is using I2C bus and that both RPi and OPi are using the same pins for I2C/GND/3.3V, you're are safe to use this small module. About EEPROM, that is normal you can't find it with i2cdetect since the EEPROM isn't present on your module, it is a searate chip also attached on I2C bus, on previous picture, it is the 24C32. My module seems to have a eeprom (68 = UU after I2C init): root@nanopi-core2:~# i2cdetect -y 0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- NanoPi, OrangePi and RPi does have the same signals: (1) 3.3V (3) I2C SDA (5) I2C SCK (7) not used on RTC Module (9) GND
guidol Posted March 24, 2018 Posted March 24, 2018 2 minutes ago, Larry Bank said: Yes, those little modules are great; they don't contain any EEPROM, that's why the address isn't visible. but I dont like the soldered battery therefore I used the external module after disabling the charging circuit now with CR2032 Battery on the back. I did like the documentation athttps://www.raspberrypi-spy.co.uk/2015/05/adding-a-ds3231-real-time-clock-to-the-raspberry-pi/ but it was for the RPi which has at that pins I2C-1 and the OPi and NanoPi has at this Pins I2C-0 connected... So I used such commands: i2c DS3231N Clock: apt install i2c-tools armbian-config: activate I2C-0 i2cdetect -y 0 (modprobe) rtc-ds1307 ==> /etc/modules in /etc/rc.local: echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device hwclock -s Once correct you can write the system date and time to the RTC module using : sudo hwclock -w You should be able to read the date and time back from the RTC using : sudo date; hwclock -r compare hwclock sudo hwclock -c NeoCore2 Mini Shield: Number# Name Number# Name 1 SYS_3.3V 2 VDD_5V 3 I2C0_SDA / GPIOA12 4 VDD_5V 5 I2C0_SCL / GPIOA11 6 GND https://www.raspberrypi-spy.co.uk/2015/05/adding-a-ds3231-real-time-clock-to-the-raspberry-pi/ https://manpages.debian.org/stretch/manpages-de/hwclock.8.de.html https://www.youtube.com/watch?v=ND2shVqV9s4 echo "Updating time via ntp from ptbtime3.pt.de" ntpdate -q ptbtime3.ptb.de echo "writing actual time to hwclock..." hwclock -w echo "reading actual time from hwclock..." date; hwclock -r
Larry Bank Posted March 25, 2018 Posted March 25, 2018 (edited) Spoiler 17 hours ago, guidol said: but I dont like the soldered battery therefore I used the external module after disabling the charging circuit now with CR2032 Battery on the back. I did like the documentation athttps://www.raspberrypi-spy.co.uk/2015/05/adding-a-ds3231-real-time-clock-to-the-raspberry-pi/ but it was for the RPi which has at that pins I2C-1 and the OPi and NanoPi has at this Pins I2C-0 connected... So I used such commands: i2c DS3231N Clock: apt install i2c-tools armbian-config: activate I2C-0 i2cdetect -y 0 (modprobe) rtc-ds1307 ==> /etc/modules in /etc/rc.local: echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device hwclock -s Once correct you can write the system date and time to the RTC module using : sudo hwclock -w You should be able to read the date and time back from the RTC using : sudo date; hwclock -r compare hwclock sudo hwclock -c NeoCore2 Mini Shield: Number# Name Number# Name 1 SYS_3.3V 2 VDD_5V 3 I2C0_SDA / GPIOA12 4 VDD_5V 5 I2C0_SCL / GPIOA11 6 GND https://www.raspberrypi-spy.co.uk/2015/05/adding-a-ds3231-real-time-clock-to-the-raspberry-pi/ https://manpages.debian.org/stretch/manpages-de/hwclock.8.de.html https://www.youtube.com/watch?v=ND2shVqV9s4 echo "Updating time via ntp from ptbtime3.pt.de" ntpdate -q ptbtime3.ptb.de echo "writing actual time to hwclock..." hwclock -w echo "reading actual time from hwclock..." date; hwclock -r It's not a battery soldered on to that small module, it's a tiny supercapacitor Edited March 25, 2018 by Tido Added spoiler 1
nepo Posted April 8, 2018 Posted April 8, 2018 Hi Igor Thank you for this tutorial - and it works Spoiler orangepi@orangepiplus2e:~$ sudo i2cdetect -y 0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- orangepi@orangepiplus2e:~$ timedatectl Local time: So 2018-04-08 18:03:35 CEST Universal time: So 2018-04-08 16:03:35 UTC RTC time: So 2018-04-08 16:03:34 Time zone: Europe/Berlin (CEST, +0200) Network time on: yes NTP synchronized: yes RTC in local TZ: no orangepi@orangepiplus2e:~$ sudo hwclock -w [sudo] password for orangepi: orangepi@orangepiplus2e:~$ timedatectl Local time: So 2018-04-08 18:04:04 CEST Universal time: So 2018-04-08 16:04:04 UTC RTC time: So 2018-04-08 16:04:03 Time zone: Europe/Berlin (CEST, +0200) Network time on: yes NTP synchronized: yes RTC in local TZ: no I want to use rtcwake, but Quote sudo rtcwake -n -m off -t $(date -d '20180408 18:45' +%s) rtcwake: wakeup from "off" using /dev/rtc0 at Mon Jun 9 01:11:54 1930 logical: lrwxrwxrwx 1 root root 9 Feb 11 2016 rtc -> /dev/rtc1 crw------- 1 root root 254, 0 Feb 11 2016 rtc0 crw------- 1 root root 254, 1 Feb 11 2016 rtc1 but sudo rtcwake -n -d /dev/rtc1 -m off -t $(date -d '20180408 18:45' +%s) rtcwake: cannot open /sys/class/rtc/rtc1/device/power/wakeup: No such file or directory rtcwake: /dev/rtc1 not enabled for wakeup events What must I do to use rtcwake ? Bye nepo!
IgorS Posted April 11, 2018 Author Posted April 11, 2018 Update: Newer kernels have module rtc_ds3232 and using this module you will be able to read temperature from DS3231 sensor board via hwmon. example: rtctemp=$(cat /sys/class/i2c-adapter/i2c-0/0-0068/hwmon/hwmon0/temp1_input) rtctemp=$(bc -l <<< "$rtctemp / 1000") echo "RTC temp = $rtctemp" Attached is changed fake-hwclock which tryes to load rtc_ds3232 module if ds3231attached variable = yes, and falls back to rtc_ds1307 module on older kernels. fake-hwclock.tar.gz
IgorS Posted April 11, 2018 Author Posted April 11, 2018 9 minutes ago, IgorS said: Update: Newer kernels have module rtc_ds3232 and using this module you will be able to read temperature from DS3231 sensor board via hwmon. example: rtctemp=$(cat /sys/class/i2c-adapter/i2c-0/0-0068/hwmon/hwmon0/temp1_input) rtctemp=$(bc -l <<< "$rtctemp / 1000") echo "RTC temp = $rtctemp" Attached is changed fake-hwclock which tryes to load rtc_ds3232 module if ds3231attached variable = yes, and falls back to rtc_ds1307 module on older kernels. fake-hwclock.tar.gz Tested on OPi+2E, OPi One, OPi Zero with mainline kernel 4.14.18-sunxi.
IgorS Posted April 11, 2018 Author Posted April 11, 2018 15 minutes ago, IgorS said: Tested on OPi+2E, OPi One, OPi Zero with mainline kernel 4.14.18-sunxi. Tested also on Raspberry Pi 3b, kernel 4.14.33
Owayll1982 Posted April 12, 2018 Posted April 12, 2018 On 4/11/2018 at 1:31 PM, IgorS said: Tested on OPi+2E, OPi One, OPi Zero with mainline kernel 4.14.18-sunxi. https://suppsforlife.to/category/peptides/ so it works on kernel 4.14.18? thanks! IgorS, what's the latest kerne version it worked? thanks!
IgorS Posted April 12, 2018 Author Posted April 12, 2018 It should work on every kernel after 4.9.xxx which have rtc_ds3232 kernel module included.
nepo Posted April 15, 2018 Posted April 15, 2018 hi I have tested and read a lot of tutorials, but nothing works - I can't used rtcwake for wakeevents! Quote e.g. orangepi@orangepiplus2e:~$ sudo rtcwake -m off -d /dev/rtc1 -s 300 [sudo] password for orangepi: rtcwake: assuming RTC uses UTC ... rtcwake: cannot open /sys/class/rtc/rtc1/device/power/wakeup: No such file or directory rtcwake: /dev/rtc1 not enabled for wakeup events but the rtc-modul ds3231 works Spoiler orangepi@orangepiplus2e:~$ sudo i2cdetect -y 0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- orangepi@orangepiplus2e:~$ dmesg |grep rtc [ 3.786757] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0 [ 3.786763] sun6i-rtc 1f00000.rtc: RTC enabled [ 8.372324] [drm] Cannot find any crtc or sizes [ 9.440407] [drm] Cannot find any crtc or sizes [ 14.920990] rtc-ds1307 0-0068: registered as rtc1 orangepi@orangepiplus2e:~$ sudo hwclock -D -r -f /dev/rtc1 hwclock from util-linux 2.29.2 Using the /dev interface to the clock. Assuming hardware clock is kept in UTC time. Waiting for clock tick.../dev/rtc1 does not have interrupt functions. Waiting in loop for time from /dev/rtc1 to change ...got clock tick Time read from Hardware Clock: 2018/04/15 13:58:56 Hw clock time : 2018/04/15 13:58:56 = 1523800736 seconds since 1969 Time since last adjustment is 1523800736 seconds Calculated Hardware Clock drift is 0.000000 seconds 2018-04-15 15:58:55.297307+0200 armbianmonitor -u Can I use my Orange Pi +2e with DS3231 to wake up ? Anybody has success ? And why I have not a /proc/driver/rtc ? Quote cat /proc/driver/rtc cat: /proc/driver/rtc: No such file or directory With my Raspberry 3 and rtc-ds3231 it exist. Bye nepo!
IgorS Posted April 17, 2018 Author Posted April 17, 2018 On 4/15/2018 at 4:26 PM, nepo said: hi I have tested and read a lot of tutorials, but nothing works - I can't used rtcwake for wakeevents! but the rtc-modul ds3231 works Reveal hidden contents orangepi@orangepiplus2e:~$ sudo i2cdetect -y 0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- orangepi@orangepiplus2e:~$ dmesg |grep rtc [ 3.786757] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0 [ 3.786763] sun6i-rtc 1f00000.rtc: RTC enabled [ 8.372324] [drm] Cannot find any crtc or sizes [ 9.440407] [drm] Cannot find any crtc or sizes [ 14.920990] rtc-ds1307 0-0068: registered as rtc1 orangepi@orangepiplus2e:~$ sudo hwclock -D -r -f /dev/rtc1 hwclock from util-linux 2.29.2 Using the /dev interface to the clock. Assuming hardware clock is kept in UTC time. Waiting for clock tick.../dev/rtc1 does not have interrupt functions. Waiting in loop for time from /dev/rtc1 to change ...got clock tick Time read from Hardware Clock: 2018/04/15 13:58:56 Hw clock time : 2018/04/15 13:58:56 = 1523800736 seconds since 1969 Time since last adjustment is 1523800736 seconds Calculated Hardware Clock drift is 0.000000 seconds 2018-04-15 15:58:55.297307+0200 armbianmonitor -u Can I use my Orange Pi +2e with DS3231 to wake up ? Anybody has success ? And why I have not a /proc/driver/rtc ? With my Raspberry 3 and rtc-ds3231 it exist. Bye nepo! As far as I know there is no way to wake Orange Pi +2e with DS3231 widouth additional circuitry.
IgorS Posted April 17, 2018 Author Posted April 17, 2018 /proc/driver/rtc ... the system clock RTC may expose itself https://www.kernel.org/doc/Documentation/rtc.txt Obviously kernel dependent Rasperry3b: igor@pi-ubuntu:~$ uname -a Linux pi-ubuntu 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l armv7l armv7l GNU/Linux igor@pi-ubuntu:~$ ls /proc/driver/rtc /proc/driver/rtc igor@pi-ubuntu:~$ cat /proc/driver/rtc rtc_time : 17:23:12 rtc_date : 2018-04-17 alrm_time : 06:17:00 alrm_date : 2018-04-18 alarm_IRQ : no alrm_pending : no update IRQ enabled : no periodic IRQ enabled : no periodic IRQ frequency : 1 max user IRQ frequency : 64 24hr : yes igor@pi-ubuntu:~$ sudo hwclock [sudo] password for igor: Uto 17 Tra 2018 19:23:48 .676962 seconds OrangePi +2e, legacy kernel: igor@orangepiplus2e:~$ uname -a Linux orangepiplus2e 3.4.113-sun8i #18 SMP PREEMPT Wed Jan 24 22:10:49 CET 2018 armv7l armv7l armv7l GNU/Linux igor@orangepiplus2e:~$ ls /proc/driver/rtc /proc/driver/rtc igor@orangepiplus2e:~$ cat /proc/driver/rtc rtc_time : 06:05:49 rtc_date : 1970-01-09 alrm_time : 11:53:47 alrm_date : 1970-01-08 alarm_IRQ : no alrm_pending : no update IRQ enabled : no periodic IRQ enabled : no periodic IRQ frequency : 1 max user IRQ frequency : 64 24hr : yes igor@orangepiplus2e:~$ sudo hwclock [sudo] password for igor: Tue 17 Apr 2018 07:20:29 PM CEST .904616 seconds igor@orangepiplus2e:~$ OrangePi +2e, mainline kernel: igor@websrv:~$ uname -a Linux websrv 4.14.18-sunxi #24 SMP Fri Feb 9 16:24:32 CET 2018 armv7l armv7l armv7l GNU/Linux igor@websrv:~$ ls /proc/driver/rtc ls: cannot access '/proc/driver/rtc': No such file or directory igor@websrv:~$ sudo hwclock [sudo] password for igor: Tue 17 Apr 2018 07:39:22 PM CEST .052402 seconds
pzw Posted April 22, 2018 Posted April 22, 2018 Thanks for the script... I had to adapt it a little, since the script assumes there is a module installed with EEPROM... My question is why...? I have a module without EEPROM ( https://www.aliexpress.com/item/New-I2C-RTC-DS1307-High-Precision-RTC-Module-Real-Time-Clock-Module-for-Raspberry-Pi/32610072259.html ) and had to change line 95 into " if [ TRUE ]; then " , since the original line doesn't work for boards without EEPROM. (It tries to evaluate "--" as a number...) Maybe you want to adapt the script in such a way that it is not depending on the presence of the EEPROM... :-)
Bingo Posted May 4, 2018 Posted May 4, 2018 Fought this for a while ..... Had weird outputs on a i2cdetect -y 0 , and a DS3231 w. eeprom Using This kernel : uname -a Linux opio2 4.14.18-sunxi #24 SMP Fri Feb 9 16:24:32 CET 2018 armv7l GNU/Linux I had to add/activate i2c0 and/or i2c1 via overlays. In /boot/armbianEnv.txt Add the below i2c0 (and i2c1 if needed) to the overlays line (or create the line if needed). overlays= ....... i2c0 i2c1 /Bingo
t-minik Posted August 10, 2018 Posted August 10, 2018 Hi i'm trying to include a ds3231 rtc module but i'm facing an issue with Opi+2E nightly 5.54 and 4.17.11 kernel I2c-0 and I2c-1 activated through armbian-config : check i2c-tools installed : check module correctly wired i2cdetect -y 0 show me the 0x68 for DS3231 and 0x57 for EEprom but adding new_device returns : root@orangepiplus2e:~# echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-0/new_device echo: command not found close failed in file object destructor: sys.excepthook is missing lost sys.stderr I seen that link https://www.kernel.org/doc/Documentation/rtc.txt pointing on "tools/testing/selftests/timers/rtctest.c" but googling said nothing to me, i'm not skilled to do something. does anyone has a clue please ?
martinayotte Posted August 10, 2018 Posted August 10, 2018 The error you got is a bit strange, it is usually not "command not found" but "permission denied". You can try to do "echo 'ds1307 0x68' | sudo tee /sys/class/i2c-adapter/i2c-0/new_device" Alternatively, you can use your RTC with python script using some python libraries ...
t-minik Posted August 10, 2018 Posted August 10, 2018 Thanks martinayotte. The strange thing is echo works well in some case, eg : echo 1234 > test.txt Works perfectly... I understood rtc was entirely rewritten in last kernel release. I'll try your advice tomorrow thanks a lot.
nurdle Posted June 14, 2019 Posted June 14, 2019 Hi could someone publish a modified version IgorS's custom script (the 3rd version above) for ds3231 RTC's that don't have EEPROMs? I tried to do it myself, but my programming skills just aren't up to it. Any help much appreciated. (Here's the script to save having to download and extract the .tar.gz above.) Spoiler #!/bin/sh # # script: /sbin/fake-hwclock # Changed by I.S. to use RTC if it is connected # modified to take advantage of module ds3232 on newer kernels. # if ds3231 attached, change ds3231attached to yes, else to no # if ds3231 attached and module rtc_ds3232 available on your kernel, # you will be able to read temperature from rtc module via hwmon # # Trivial script to load/save current contents of the kernel clock # from/to a file. Helpful as a *bootstrap* clock on machines where # there isn't a useful RTC driver (e.g. on development boards). Using # NTP is still recommended on these machines to get to real time sync # once more of the system is up and running. # # Copyright 2012 Steve McIntyre <93sam@debian.org> # # License: GPLv2, see COPYING # Config variables # RTC is attached on bus... i2c_bus=0 eeprom_address="57" rtc_address="68" ds3231attached=yes # Orange PI +2e have RTC, so our device will be: rtc_device="rtc1" # fake-hwclock is using cron.hourly to periodically save system clock cronfile="/etc/cron.hourly/fake-hwclock" # If you want to periodically synchronize rtc with system time, change this to true update_rtc_periodically=false # End of config variables i2c=false if [ "$ds3231attached" = "yes" ]; then modprobe rtc_ds3232 > /dev/null 2>&1 module=$? if [ "$module" != "0" ]; then ds3231attached=no fi fi # I don't know are all needed programs in PATH, # therefore I'll declare all mine echo="/bin/echo" i2cdetect="/usr/sbin/i2cdetect" grep="/bin/grep" awk="/usr/bin/awk" ln="/bin/ln" hwclock="/sbin/hwclock" readlink="/bin/readlink" progs="$echo $i2cdetect $grep $awk $ln $hwclock $readlink" check_external_progs(){ not_found="" prog="" for prog in ${progs} do if [ ! -e "$prog" ]; then not_found=$prog" "$not_found echo "Required program not found: $prog" fi done if [ "$not_found"x = ""x ] ; then progs_ok=true else progs_ok=false fi unset not_found unset prog } recreate_cronjob() { if [ ! -e "$1" ]; then cat << 'EOF' > "$1" #!/bin/sh # # Simple cron script - save the current clock periodically in case of # a power failure or other crash if (command -v fake-hwclock >/dev/null 2>&1) ; then fake-hwclock save fi EOF fi } is_rtc_connected(){ check_external_progs if $progs_ok; then # if $i2c; then list=$($i2cdetect -y "$i2c_bus") rtc=$(echo "$list" | $grep "60:" | $awk '{print $10}') eeprom=$(echo "$list" | $grep "50:" | $awk '{print $9}') #rtc=68 if [ "$eeprom" -eq "$eeprom_address" ]; then case $rtc in "UU") t="/dev/$rtc_device" r=$($readlink -f /dev/rtc) if [ "$r" = "$t" ]; then $echo "true" else $ln -sf /dev/$rtc_device /dev/rtc >/dev/null 2>&1 r=$($readlink -f /dev/rtc) if [ "$r" = "$t" ]; then $echo "true" else $echo "false" fi fi;; $rtc_address) if [ "$ds3231attached" = "yes" ]; then $echo ds3232 0x$rtc_address > /sys/class/i2c-adapter/i2c-$i2c_bus/new_device else $echo ds1307 0x$rtc_address > /sys/class/i2c-adapter/i2c-$i2c_bus/new_device fi sleep 5 $ln -sf /dev/$rtc_device /dev/rtc >/dev/null 2>&1 t="/dev/$rtc_device" r=$($readlink -f /dev/rtc) if [ "$r" = "$t" ]; then $echo "true" else $echo "false" fi;; *) $echo "false";; esac else $echo "false" fi else $echo "false" fi # else $echo "false" fi } #i2c=true #is_rtc_connected #exit if [ "$FILE"x = ""x ] ; then FILE=/etc/fake-hwclock.data fi COMMAND=$1 if [ "$COMMAND"x = ""x ] ; then COMMAND="save" fi FORCE=false if [ "$2"x = "force"x ] ; then FORCE=true fi # Wait for i2c $i2cdetect -y "$i2c_bus" >/dev/null 2>&1 r=$? if [ "$COMMAND" = "load" ] || [ "$r" -eq 0 ]; then c=20 r=1 until [ "$r" -eq 0 ] || [ "$c" -eq 0 ] do $i2cdetect -y "$i2c_bus" >/dev/null 2>&1 r=$? c=$(($c - 1)) if [ "$r" -eq 0 ]; then i2c=true else sleep 1 fi done fi # Is RTC installed? rtc_installed=$(is_rtc_connected) if $rtc_installed; then # We dont need periodically saving rm -f "$cronfile" >/dev/null 2>&1 else # Restore periodically saving recreate_cronjob "$cronfile" fi case $COMMAND in save) if $rtc_installed; then #$echo "RTC save" $hwclock -w if $update_rtc_periodically; then $echo "cronjob restore" recreate_cronjob "$cronfile" fi else if [ -e $FILE ] ; then SAVED="$(cat $FILE)" SAVED_SEC=$(date -u -d "$SAVED" '+%s') NOW_SEC=$(date -u '+%s') if $FORCE || [ $NOW_SEC -ge $SAVED_SEC ] ; then date -u '+%Y-%m-%d %H:%M:%S' > $FILE else echo "Current system time: $(date -u '+%Y-%m-%d %H:%M:%S')" echo "fake-hwclock saved clock information is in the future: $SAVED" echo "To force the saved system clock backwards anyway, use \"force\"" fi else date -u '+%Y-%m-%d %H:%M:%S' > $FILE fi fi ;; load) if $rtc_installed; then #$echo "RTC load" $hwclock -s else if [ -e $FILE ] ; then SAVED="$(cat $FILE)" SAVED_SEC=$(date -u -d "$SAVED" '+%s') NOW_SEC=$(date -u '+%s') if $FORCE || [ $NOW_SEC -le $SAVED_SEC ] ; then date -u -s "$SAVED" else echo "Current system time: $(date -u '+%Y-%m-%d %H:%M:%S')" echo "fake-hwclock saved clock information is in the past: $SAVED" echo "To set system time to this saved clock anyway, use \"force\"" fi else echo "Unable to read saved clock information: $FILE does not exist" fi fi ;; check) if $rtc_installed; then echo "RTC installed" else echo "RTC not installed" fi ;; *) echo $0: Unknown command $COMMAND exit 1 ;; esac
martinayotte Posted June 14, 2019 Posted June 14, 2019 2 hours ago, nurdle said: for ds3231 RTC's that don't have EEPROMs? Even if EEPROM isn't present on your module, it doesn't matter, the script doesn't use the EEPROM, so it should be usable as is ...
nurdle Posted June 14, 2019 Posted June 14, 2019 I was going by pzw's comment above and the fact there are a couple of references to eeprom in the script like: eeprom_address="57" eeprom=$(echo "$list" | $grep "50:" | $awk '{print $9}') if [ "$eeprom" -eq "$eeprom_address" ]; then
martinayotte Posted June 14, 2019 Posted June 14, 2019 22 minutes ago, nurdle said: I was going by pzw's comment above Right, but he said that he overcome the issue by changing line 95 to " if [ TRUE ]; then " ... Did you tried that ?
