Igor Posted July 6, 2024 Posted July 6, 2024 May 1st, 2025 AVAILABLE FOR ALL BOARDS on Debian Bookworm image via armbian-config https://docs.armbian.com/User-Guide_Armbian-Software/Media/#omv Download Armbian with OpenMediaVault (OMV) Currently (for testing) only 4 targets were build: rock5-itx, odroid m1, odroid xu4 and x86. Once its confirmed that works well, other targets will be assembled. Then boot the image, wait few minutes and login via: http://ip_address_of_armbian_running_ha U: admin P: openmediavault Test setup on Odroid M1: Spoiler Tested on: Odroid M1 Raspberry PI 4 DIY Spoiler How was this assembled? - you need a build framework which assembles Armbian (Debian variant is the only supported by OMV) https://github.com/armbian/build (can be compiled in GitHub free runners too) - OMV extension: https://github.com/armbian/os/blob/main/userpatches/extensions/omv.sh (download this extension and place it into your build directory) ./compile.sh BOARD="uefi-x86" BRANCH=current RELEASE=bookworm ENABLE_EXTENSIONS="omv" KERNEL_CONFIGURE="no" BUILD_MINIMAL="yes" 3 Quote
MacBreaker Posted July 16, 2024 Posted July 16, 2024 Hello Igor, try to build OMV for rpi4. ./compile.sh BOARD="rpi4b" BRANCH=current RELEASE=bookworm ENABLE_EXTENSIONS="omv" KERNEL_CONFIGURE="no" BUILD_MINIMAL="yes" Got these error messages: [🌿] Enabling extension [ omv ] [🔨] ERR: Extension problem -- cant find extension 'omv' anywhere - called by /home/master/build/lib/functions/general/extensions.sh [💥] Exiting with error 17 [ at /home/master/build/lib/functions/general/extensions.sh:1 enable_extension() --> lib/functions/general/extensions.sh:1 initialize_extension_manager() --> lib/functions/general/extensions.sh:135 do_main_configuration() --> lib/functions/configuration/main-config.sh:317 do_with_logging() --> lib/functions/logging/section-logging.sh:81 do_with_conditional_logging() --> lib/functions/logging/section-logging.sh:111 prep_conf_main_build_single() --> lib/functions/main/config-prepare.sh:29 cli_standard_build_run() --> lib/functions/cli/cli-build.sh:22 armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:176 main() --> compile.sh:50 ] [💥] Cleaning up [ please wait for cleanups to finish ] What I'm doing wrong? Markus 0 Quote
Werner Posted July 16, 2024 Posted July 16, 2024 omv extension isn't automatically shipped with the build framework. You can grab it here: https://github.com/armbian/os/blob/main/userpatches/extensions/omv.sh 1 Quote
MacBreaker Posted July 16, 2024 Posted July 16, 2024 Ahh, okay, i didn't know Now it's working.. 👍 Thank's Werner 1 Quote
Werner Posted July 16, 2024 Posted July 16, 2024 58 minutes ago, MacBreaker said: i didn't know Me neither 1 Quote
SteeMan Posted July 16, 2024 Posted July 16, 2024 The instructions on above (under DIY) should be clearer to explain that. When I looked at this earlier, I was guessing that is what the instructions assumed you needed to do (download that referenced file). Edited the above instructions to clarify. 2 Quote
AlexVS Posted August 26, 2024 Posted August 26, 2024 Downloaded the image Armbian_24.5.9_Rpi4b_bookworm_current_6.6.44-openhab.img, uploaded. Does not work. The page is http://192.168.1.105 not available. 0 Quote
Igor Posted August 26, 2024 Author Posted August 26, 2024 2 hours ago, AlexVS said: Downloaded the image Armbian_24.5.9_Rpi4b_bookworm_current_6.6.44-openhab.img, uploaded. Does not work. The page is http://192.168.1.105 not available. It takes some time before OpenHab initialises. How long did you wait? Can you provide some logs? 0 Quote
AlexVS Posted August 26, 2024 Posted August 26, 2024 I waited for 10 to 20 minutes. I'll try again soon. Can you tell me which logs to provide? 0 Quote
Igor Posted August 27, 2024 Author Posted August 27, 2024 @AlexVS 1. Downloaded this image: https://dl.armbian.com/rpi4b/Bookworm_current_server-openhab 2. Executed 1st login, create username (probably must have), created locales ... 3. As you can see OpenHab installation activities: 4. http://10.0.40.156:8080/ (you failed to see OpenHab manual 5. Login prompt (2-3 minutes after startup) 0 Quote
AlexVS Posted August 27, 2024 Posted August 27, 2024 It seems to me that I did not understand you. When I downloaded the image, I expected that OMV7 was preinstalled there. And after installing it, I hoped that OMV7 would be available for testing. I am sorry. Apparently this is a translation difficulty. 0 Quote
MacBreaker Posted August 27, 2024 Posted August 27, 2024 Hello @AlexVS, you wrote: Quote Downloaded the image Armbian_24.5.9_Rpi4b_bookworm_current_6.6.44-openhab.img, uploaded. That is no image with preinstalled OMV but with preinstalled openhab. There is no image for ri4 with OMV preinstalled (as far as i see..). You have to build it by yorself. See DIY on post 1. Markus 0 Quote
Igor Posted August 27, 2024 Author Posted August 27, 2024 4 hours ago, AlexVS said: It seems to me that I did not understand you. Proceed as @MacBreaker suggests. 45 minutes ago, MacBreaker said: There is no image for ri4 with OMV preinstalled (as far as i see..). You have to build it by yorself. Exactly. Added for future releases: https://github.com/armbian/os/commit/e87f4f529a8dfadeaa011decc9aa3c65d98c17a5 0 Quote
Igor Posted August 28, 2024 Author Posted August 28, 2024 @AlexVS Try this: https://dl.armbian.com/rpi4b/Bookworm_current_minimal-omv 1 Quote
AlexVS Posted August 30, 2024 Posted August 30, 2024 (edited) Thank you very much. Installed the specified image. OMV has started. Now you can test it. Edited August 30, 2024 by AlexVS 1 Quote
0jay Posted September 16, 2024 Posted September 16, 2024 This is great, thanks for this it's exactly what I wanted! Will this play nice with armbian-config eMMC install? I once tried after installing OMV on an sd card and the emmc transfer wouldn't boot (armbian-config's the only tool I've found to do an emmc install) 0 Quote
Igor Posted September 16, 2024 Author Posted September 16, 2024 2 hours ago, 0jay said: Will this play nice with armbian-config eMMC install? It should work - depends on the hardware - for the one we don't support, its unknown, for supported one we will try to fix in case of troubles. You can call armbian-install directly, so you don't install dependencies from armbian-config. There will soon be much lighter version of it, but current one is not very light. 1 Quote
0jay Posted September 19, 2024 Posted September 19, 2024 Would any of these OMV images run on a 3328 Renegade? I can run the Libre portability script so figure I just need it to boot 0 Quote
Werner Posted September 19, 2024 Posted September 19, 2024 If there is no pre-made OMV image you can create your own just like mentioned under DIY at the very first post of this topic. Also check the few posts after for copying the necessary extension if necessary. 0 Quote
0jay Posted September 19, 2024 Posted September 19, 2024 7 minutes ago, Werner said: you can create your own I intend getting to this in time (also with OpenWRT) but for the moment I'm not in a position to do it. If there's an image that'll boot on a renegade board then at least I can explore 0 Quote
0jay Posted September 19, 2024 Posted September 19, 2024 (edited) On 9/16/2024 at 9:27 PM, Igor said: It should work - depends on the hardware Armbian install unfortunately not working to transfer an OMV install on a 3328 renegade board. It boots but OMV is non functional (and seemingly irreparable) Edited September 20, 2024 by 0jay 0 Quote
Igor Posted September 20, 2024 Author Posted September 20, 2024 11 hours ago, 0jay said: Armbian install unfortunately not working to transfer an OMV install on a 3328 renegade board. Aha, you mean SD boot works, but then it fails to properly transfer it? 0 Quote
0jay Posted September 20, 2024 Posted September 20, 2024 (edited) 1 hour ago, Igor said: SD boot works, but then it fails to properly transfer it? Short summary of process to follow: I burn Armbian with Etcher, update etc and install OMV. From here I use armbian-install (or armbian-config) to transfer to the eMMC. This is the only tool I've found that makes the eMMC transfer simple (thank you!). The eMMC system boots and seems fine but OMV is not functional (though it works fine on the SD it was transferred from). As a result I always just transfer the raw Armbian install to eMMC, boot from there and install OMV direct to the eMMC but it would be very handy to be able to transfer from an SD with a working OMV install fully configured as backup. Edited September 20, 2024 by 0jay 0 Quote
0jay Posted October 9, 2024 Posted October 9, 2024 Hi Igor, any developments with these pre-rolled images? Can I request a Renegade OMV image or will I need to wait for an LTS? Thanks for your time, Oscar 0 Quote
Igor Posted October 9, 2024 Author Posted October 9, 2024 6 minutes ago, 0jay said: Can I request a Renegade OMV image or will I need to wait for an LTS? Open PR similar to this one https://github.com/armbian/os/pull/254 it's faster. I can execute build, but can't test. 1 Quote
0jay Posted October 9, 2024 Posted October 9, 2024 33 minutes ago, Igor said: I can execute build, but can't test. Done. Thanks 0 Quote
lurch Posted November 11, 2024 Posted November 11, 2024 (edited) Hello and thanks for this great work! Today I tried installing `Armbian_24.8.4_Odroidxu4_bookworm_current_6.6.54-omv_minimal.img.xz` (SHA256 confirmed/writing verified/new sd cards) on some Odroid-HC1's. Problem is/was I can't access the devices, I see them only short (reacting to pings) and then vanish again from the network. It behaved the same for 2 different devices. Then I tried the latest normal/minimal image instead: `Armbian_24.8.1_Odroidxu4_bookworm_current_6.6.47_minimal.img.xz` and things work like normal (stays in the network, can access via ssh, ...) Thought maybe the latest omv spin got some error so I tried again with the former stable (same version as minimal atm) `Armbian_24.8.1_Odroidxu4_bookworm_current_6.6.44-omv_minimal.img.xz` but again no luck and when pinging the device seems to be online only less then a minute before vanishing from the network again. Attaching a classic (spinning/mechanical!) hard disk then gave some "sound" confirmation: The disks spins up around every minute - so most likely boot looping! Can anyone confirm that one of the latest two (24.8.4 or 24.8.1) actually works on a odroid-xu4/hc without boot loop? At the moment I use the Armbian 24.8.1 minimal image mention and install OMV the hard way following this guide: https://wiki.omv-extras.org/doku.php?id=omv7:armbian_bookworm_install I successfully used Armbian 24.8.1 minimal image mention and installed OMV the hard(er) way following this guide: https://wiki.omv-extras.org/doku.php?id=omv7:armbian_bookworm_install Edited November 11, 2024 by lurch 0 Quote
Igor Posted November 11, 2024 Author Posted November 11, 2024 7 hours ago, lurch said: I successfully used Armbian 24.8.1 minimal image mention and installed OMV the hard(er) way following this guide: The problem you are experiencing is probably related to some incompatibility when assembling 32bit OMV. We can't test all assemblies manually (we have no other option) on all targets. Perhaps moving installer to run-time is better? https://docs.armbian.com/User-Guide_Armbian-Software/#adding-example We will eventually add this, but help is appreciated. 1 Quote
MrT Posted December 30, 2024 Posted December 30, 2024 Hello people. Today i found the Armbian-OS for Odroid XU4 with OMV and I wanted to test it on my installation. Sadly i does not seem to work. The machine does not seems to be connected to my home network. So i cannot reach the OMV page from the webbrowser and i cannot SSH in to it. My Odroid XU4 setup is like thus: 1 Odroid XU4Q (the fanless one) 1 Cloudshell appliance in which the XU4Q is mounted 2 old 2TB WD green drives 1 EMMC on with the armbian os on it. I also have an USB to EMMC reader/writer. So i will connect a screen and a keyboard to the XU4 and take a look inside. If i could help with log files or tests please let me know i gladly help out when possible. greetings Tom 0 Quote
