Gullik Posted September 22, 2024 Posted September 22, 2024 All images have build dates 1 month back. Several images seem to be based on "vendor kernel". What is happening? G 0 Quote
Werner Posted September 23, 2024 Posted September 23, 2024 https://docs.armbian.com/Release_Changelog/ 0 Quote
Igor Posted September 23, 2024 Posted September 23, 2024 8 hours ago, Gullik said: based on "vendor kernel" Those have best HW support and here we can provide video acceleration support. That's why. Mainline based images are also available, but with limited functionality. Which is always the case. 0 Quote
Gullik Posted October 9, 2024 Author Posted October 9, 2024 So, only "rolling releases" with 6.1.75 kernel gets any updates since 24-aug-2024........ Anyway, MT7961 started working yesterday... Hopefully it will be possible to change to Swedish keyboard soon.... Gullik 0 Quote
Solution Gullik Posted January 9 Author Solution Posted January 9 Fantastic, I just booted Armbian with a 6.12 kernel, and for the first time since august I have a desktop system on my OPI 5's. And of course armbian-config work. It was right before my OPI5's went to recycling...... Happy Gullik 2 Quote
Gullik Posted January 13 Author Posted January 13 And, there is some progress, but Armbian with 6.12 kernel is barely useable. Observations: It is not possible to set up and configure without a serial port. The initial system config does not display over hdmi. It is not possible to answer "YES" to the connect wifi question, so no ssh login. So, no terminal and no network, but kernel runs. No video is present on HDMI for some minutes after powering up. TV displays "no hdmi input" until suddenly the desktop pops up. When configuring over serial line, the desktop comes on on subsequent boots. I guess there should be some "picture" there... Nvme install via armbian-install is broken. Using it to set up and update MTD , and subsequent DDing the image to nvme works. Firefox will not run, probably due to some "apparmor" issue, that unfortunately I do not know anything about. Root is NOT allowed to run firefox. Trying to run it from the gui causes "firefox is already running, please stop it and try again" No matching proc found with ps. No weird lock files..... But wifi when enabled (via serial) works OK, and can subsequently be modified from the GU. and speed is *Good*. So, now we are perhaps getting forward.... Gullik 0 Quote
Werner Posted January 14 Posted January 14 7 hours ago, Gullik said: No video is present on HDMI for some minutes after powering up. expected. HDMI implementation is not yet complete. 6.13.y will bring a few enhancements in that matter. 7 hours ago, Gullik said: Nvme install via armbian-install is broken. have you explicitly apt update;apt upgrade before? There were issues in the past but have been fixed iirc. 0 Quote
Gullik Posted January 14 Author Posted January 14 Yes Werner, I always synch the distribution after install, apt update / upgrade. As for "black screen / no hdmi" I noticed a complaint in the logs of graphics missing, I guess that is what is displayed during boot. To me this is OK, I miss the old boot message displays of ancient Linuxes, where you could actually always see where it failed / succeeded. Now we are forced to watch a spinning dot on an otherwise static screen waiting for something more interesting to happen...... -- Ignorance is a good substitute for security 🙂, if it was hard to write it should be hard to read.... Gullik 0 Quote
eselarm Posted January 14 Posted January 14 1 hour ago, Gullik said: To me this is OK, I miss the old boot message displays of ancient Linuxes, where you could actually always see where it failed / succeeded. ARM devices do not have something like decades old character buffer 80x25 we know from PC BIOS. It is full graphics and serial console. I lost count on how often I told people to get a USB serial console cable. Especially people used to their iPad WindowsPC Smartphone Tablet RPi seem to be totally unaware that a 2 US dollar cable and setting 'verbosity=7' and removing 'quiet' opens a whole new old world of what the computer board is doing after power on. Some SBCs are even prepared for it; My NanoPi-R6C has an extra USB-C connector for serial console, so just need a USB-C cable to connect to other computer. Better than old 80x25, it allows yo to scroll back and easy copy-paste of text. That is good for fora and getting help. 0 Quote
Werner Posted January 14 Posted January 14 3 hours ago, Gullik said: Now we are forced to watch a spinning dot Um no? disable boot logo in /boot/armbianEnv.txt 0 Quote
ArmBoy1988 Posted January 14 Posted January 14 I just tried this image a few days ago: Armbian_24.11.2_Orangepi5_noble_vendor_6.1.75_gnome-kisak_desktop.img It seemed to be working fine. I think it did take a while showing video on the monitor/TV I was using. I was asked about WiFi, locales, etc and then after apt update and apt upgrade still working fine. A short while later, maybe a few days, tried the new NVME drive I had purchased. It showed up in lsblk and then went about move image and updating MTD. Went fine and booted up fine. I'm able to either boot from SD card or remove it and boot from NVME. I was using an older Jammy image and I noticed with the new Noble image it booted much faster. One interesting thing I noted is that if the screensaver is activated and the screen blanks out, it becomes unresponsive. Pressed keys, mouse buttons but the screen didn't reactivate. Went to reboot, saw that only the red LED was on and no flashing green LED. I pressed button to reboot and then the screen woke up, back to where I left off. I thought that was odd and not typical. If I press a key before it goes into this mode, the screen does wake up. Don't know how else to explain it. Anyway, the screen works fine through HDMI and the NVME works fine too. Armbian-install worked fine to move and boot from NVME as well. 0 Quote
Gullik Posted January 16 Author Posted January 16 eselarm: Thanks for enlightening me about changes in video hardware, did not think of that. other: It seems to be running, but refuses to display (screensaver??) I rebooted twice, both times I had video barely to log in, then screensaver kicked in after only 30 seconds, and after that system is zombie. If I touch keyboard, the TV "no hdmi video" goes away, but screen is black, if I leave it the "no hdmi video" comes back on TV. But I'll try an update/upgrade/reboot seq. Gullik 0 Quote
Gullik Posted January 31 Author Posted January 31 Hmm, What happens after I log in to the desktop? Todays update behaves as before, but I noticed that HDMI video is stable *until* I log in. It seems that going from the login page to the "desktop" turns video off. To me it seems the video subsystem is functional, but that *something* *else* happens when the display changes from the login page to the "desktop". Any hints of what I should look at to help resolve this.........since I have a few of these....and could spend some hours looking into detail... Gullik 0 Quote
royk Posted February 3 Posted February 3 (edited) @Gullik To me it sounds like a problem with Mesa. This happens with an x86 box that I have after a kernel update or something with a self compiled Mesa, then in the folder /usr/lib64 the files libGL.so.1, libGLESv2.so.2 and libEGL.so.1 will be relinked to the original files (with a higher version number). In that case relinking them solves the issue. Enter "ls -ltr" in the lib64 folder to see the newest files under Edited February 3 by royk 0 Quote
Gullik Posted February 8 Author Posted February 8 Interesting, I have two opi5. One would display the login screen, and after login turn black, and after 5 seconds turn the cursor off. Available via ssh. The other would actually display the desktop, and terminal windows could be created. Firefox would NOT work, due to its inability to find a display. After this morning update, both fail to generate video / hdmi. Both accessible by ssh. Both were configured with the released 6.12 kit and updated daily. Gullik 0 Quote
Gullik Posted February 9 Author Posted February 9 Now we are seeing progress.... I built a new armbian, kernel is 6.13-2 edge, Things that don't work yet: No text on HDMI at upstart, initial config must be done via serial Thus, nothing on TV until suddenly a Desktop login page. No "settings", so no way to set audio Apt upgrade complains but that may be unaccessable servers.... Installing on nvme results in "Kernel booting" and then nothing Left USB port does not seem to work, maybe dtb trouble... Regards, Gullik 0 Quote
Werner Posted February 9 Posted February 9 That's what you get with bleeding edge. Use vendor if you need stuff working. Here is great overview of what is working in mainline: https://gitlab.collabora.com/hardware-enablement/rockchip-3588/notes-for-rockchip-3588/-/blob/main/mainline-status.md 1 Quote
Gullik Posted February 10 Author Posted February 10 Hi Werner. Yes, bleeding edge brings lots of unexpected results... However, this is why we use open source, and I like watching progress.... Some times a bug report eliminates a stupid problem, like not being able to *build* Armbian.... And old bugs resurface.... And as already pointed out *many* times vendor kernel is vintage..... Gullik 0 Quote
