TonyMac32 Posted June 30, 2017 Share Posted June 30, 2017 4 hours ago, zador.blood.stained said: I believe SPI NOR kernel drivers should be smart enough to handle chip specific quirks. Also it's possible to activate SPIdev instead of MTD NOR and poke the flash with "flashrom" This wouldn't be a chip-specific quirk, this would be back at the SPI driver itself, and would cause problems with any device attached to a given transmission line. I didn't give a clean enough break between the topics, the SPI mode used, I agree, the driver should handle, but I always like to double check. As for a needed sample delay due to routing capacitance, there is no automatic software solution that can talk to that, essentially the data received is just wrong/arbitrary, it would be a physical layer issue with the trace lengths/long parallel runs/coupling to other traces/etc. @Xalius, can you grab a shot of a single transaction (16 bits?) and grab the rise/fall time of the Clock, MOSI and MISO lines? Very nice scope by the way, I'm afraid I only have things that shiny at work. ;-) We use LeCroy WaveRunners and, when budget matters, PicoScopes. I was thinking about snagging a Picoscope for myself, as I currently just have to "trust the magic" on high speed signals. Also check to see if you have flux built up around the IC terminals. Link to comment Share on other sites More sharing options...
zador.blood.stained Posted July 1, 2017 Share Posted July 1, 2017 11 hours ago, TonyMac32 said: This wouldn't be a chip-specific quirk, this would be back at the SPI driver itself, and would cause problems with any device attached to a given transmission line. I didn't give a clean enough break between the topics, the SPI mode used, I agree, the driver should handle, but I always like to double check. As for a needed sample delay due to routing capacitance, there is no automatic software solution that can talk to that, essentially the data received is just wrong/arbitrary, it would be a physical layer issue with the trace lengths/long parallel runs/coupling to other traces/etc. Yeah, I must've been thinking about something else, sorry. Link to comment Share on other sites More sharing options...
Kwiboo Posted July 1, 2017 Share Posted July 1, 2017 On 2017-06-26 at 5:26 PM, Xalius said: The first step would be to see if ATF built from source works in contrats to the binary we have now, or wait for the SPL to arrive and do all at once... Replacing the prebuilt rk3328_bl31_v1.34.bin with a custom built bl31.elf from latest upstream ATF source seems to work, and my device have survived past the old ~15-20 minute lockup limit. The generated bl31.bin ends up being 4GiB for some reason, using the bl31.elf instead of bl31.bin as input to the trust_merger tool seems to work. This was tested on a RK3328 tv box as my ROCK64 shipment seems to have been lost in transit :/ Link to comment Share on other sites More sharing options...
Xalius Posted July 1, 2017 Author Share Posted July 1, 2017 Good to hear that ATF built from source works. Did Tl send your Rock64 via EMS? Link to comment Share on other sites More sharing options...
Kwiboo Posted July 1, 2017 Share Posted July 1, 2017 1 hour ago, Xalius said: Did Tl send you Rock64 via EMS? I think so, out of the three shipments to LibreELEC developers one made it to its destination in France last week, the second got returned by customs and my never seems to have reached Sweden at all. But I have been told that new shipments will be made next week Link to comment Share on other sites More sharing options...
Xalius Posted July 1, 2017 Author Share Posted July 1, 2017 Just now, Kwiboo said: I think so, out of the three shipments to LibreELEC developers one made it to France last week, the second got returned by customs and my never seems to have reached Sweden at all. But I have been told that new shipments will be made next week Yeah EMS is pretty hit and miss, I use them a lot when ordering stuff from AliExpress too, but it always takes 2-3weeks to Germany. They seem to have a hub in France/Paris airport and tracking always shows France as destination. Then they hand over to DHL which does the customs handling here in Germany and the delivery to my door... Link to comment Share on other sites More sharing options...
Xalius Posted July 1, 2017 Author Share Posted July 1, 2017 I did a quick test with a JMS567 and a Samsung 830 256GB SSD running iozone: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 random random kB reclen write rewrite read reread read write 102400 4 12489 13460 18838 19102 11612 13282 102400 16 40500 50855 59763 61081 36515 50299 102400 512 221087 247712 226089 236863 162081 237059 102400 1024 246648 263610 265424 276265 216642 265984 102400 16384 295448 290687 259715 344931 338378 290055 iozone -e -I -a -s 400M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 409600 4 11139 13589 20752 24122 11615 13388 409600 16 49159 51439 61127 61224 36620 50698 409600 512 230122 246652 238314 239178 161978 246797 409600 1024 264338 276146 270927 276500 217073 277141 409600 16384 304103 305119 326587 344885 339426 300827 For comparison on my Thinkpad W520 (i7@3.3Ghz) with linux-deepblack 4.11.5-200.fc25.x86_64 random random KB reclen write rewrite read reread read write 102400 4 21423 24115 28178 27733 14561 25215 102400 16 68165 74053 86389 102411 48260 73375 102400 512 138509 146013 239740 251701 176170 154234 102400 1024 169942 171816 248133 270721 213992 141895 102400 16384 179981 173118 278754 298413 302857 169050 409600 4 21378 24261 28156 27951 14726 24664 409600 16 66187 74002 97317 101167 48185 73957 409600 512 145606 145452 253851 254371 168460 147119 409600 1024 156023 154241 282162 282168 217111 156996 409600 16384 172345 180110 299627 303149 297998 171165 Edit: accidentaly swapped the results while pasting, fixed now... Link to comment Share on other sites More sharing options...
Xalius Posted July 1, 2017 Author Share Posted July 1, 2017 Back to the SPI flash, I increased some debug levels in my kernel and now I got some new info, it seems that at some point the SPI DMA transfers begin to fail and then the kernel crashes.... http://pastebin.ubuntu.com/24997024/ Is it possible to disable SPI DMA transfers for testing purposes? Link to comment Share on other sites More sharing options...
zador.blood.stained Posted July 1, 2017 Share Posted July 1, 2017 6 minutes ago, Xalius said: Is it possible to disable SPI DMA transfers for testing purposes? I remember reading about issues with UART DMA on the Tinkerboard, so maybe Rockchip DMA in general is partially broken? According to Rockchip SPI DT bindings DMA properties are optional so you can try removing them, but whether it will work without DMA depends on the driver. 1 Link to comment Share on other sites More sharing options...
Xalius Posted July 1, 2017 Author Share Posted July 1, 2017 @zador.blood.stained, thanks, I think this is at least a workaround, since I have no longer garbage on the flash and the kernel doesnt seem to crash anymore: root@rock64:/home/rock64# ubiformat /dev/mtd0 ubiformat: mtd0 (nor), size 16777216 bytes (16.0 MiB), 4096 eraseblocks of 4096 bytes (4.0 KiB), min. I/O size 1 bytes libscan: scanning eraseblock 4095 -- 100 % complete ubiformat: 132 eraseblocks have valid erase counter, mean value is 0 ubiformat: 3526 eraseblocks are supposedly empty ubiformat: 4 corrupted erase counters ubiformat: warning!: 434 of 4096 eraseblocks contain non-UBI data ubiformat: continue? (y/N) y ubiformat: warning!: only 132 of 4096 eraseblocks have valid erase counter ubiformat: erase counter 0 will be used for all eraseblocks ubiformat: note, arbitrary erase counter value may be specified using -e option ubiformat: continue? (y/N) y ubiformat: use erase counter 0 for all eraseblocks ubiformat: formatting eraseblock 4095 -- 100 % complete root@rock64:/home/rock64# sudo ubiattach -m0 [ 653.955360] ubi0: attaching mtd0 [ 656.405192] ubi0: scanning is finished [ 656.445646] ubi0: attached mtd0 (name "spi32766.0", size 16 MiB) [ 656.446297] ubi0: PEB size: 4096 bytes (4 KiB), LEB size: 3968 bytes [ 656.447003] ubi0: min./max. I/O unit sizes: 1/256, sub-page size 1 [ 656.447686] ubi0: VID header offset: 64 (aligned 64), data offset: 128 [ 656.448371] ubi0: good PEBs: 4096, bad PEBs: 0, corrupted PEBs: 0 [ 656.449029] ubi0: user volume: 0, internal volumes: 1, max. volumes count: 23 [ 656.449799] ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 89590605 [ 656.450755] ubi0: available PEBs: 4092, total reserved PEBs: 4, PEBs reserved for bad PEB handling: 0 [ 656.451754] ubi0: background thread "ubi_bgt0d" started, PID 704 UBI device number 0, total 4096 LEBs (16252928 bytes, 15.5 MiB), available 4092 LEBs (16237056 bytes, 15.5 MiB), LEB size 3968 bytes (3.9 KiB) root@rock64:/home/rock64# Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 1, 2017 Share Posted July 1, 2017 Yes, I just had to disable DMA on the uart for the Tinker Board, it was locking up the kernel. Link to comment Share on other sites More sharing options...
Xalius Posted July 1, 2017 Author Share Posted July 1, 2017 Just moving my stuff over to eMMC now, then I'm going to try and boot something from this SPI flash... I think I'll write Kever from RK a mail and ask about what's up with DMA transfers... Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 1, 2017 Share Posted July 1, 2017 Do you have a document for the format of the SPI to boot? Or is it the same as eMMC? Link to comment Share on other sites More sharing options...
Xalius Posted July 1, 2017 Author Share Posted July 1, 2017 @TonyMac32 I have to find out, but iirc it is the same. I did some more test and basic writing/reading with mtd-utils seems to work now, just read back a block after power cycling: root@rock64:/home/rock64# nanddump -l500 -f test.bin /dev/mtd0 ECC failed: 0 ECC corrected: 0 Number of bad blocks: 0 Number of bbt blocks: 0 Block size 4096, page size 1, OOB size 0 Dumping data starting at 0x00000000 and ending at 0x000001f4... root@rock64:/home/rock64# cat test.bin Hello World! I am a SPI Flash! This is a test! root@rock64:/home/rock64# Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 1, 2017 Share Posted July 1, 2017 I have some SPI flashes in the mail for a tinker board experiment. ;-) Link to comment Share on other sites More sharing options...
martinayotte Posted July 1, 2017 Share Posted July 1, 2017 W25Q128 are now cheaper than 1 year ago ... 1 Link to comment Share on other sites More sharing options...
Xalius Posted July 1, 2017 Author Share Posted July 1, 2017 I just flashed the first 16MB from my sdcard on the SPI flash and well, it boots :-) DDR version 1.06 20170424 In SRX LPDDR3 786MHz Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB ddrconfig:7 OUT Boot1 Release Time: 2017-05-18, version: 2.43 ChipType = 0x11, 187 emmc reinit emmc reinit SdmmcInit=2 20 SdmmcInit=0 2 powerOn 702746 Usb re Boot. 6702743 Usb re Boot. 12702748 Usb re Boot. 18702750 SoftReset SoftReset, 19367264 us Miniloader seems to run SPI at 12Mhz, but I guess now the boot image needs tweaking since I dont see any u-boot... 1 Link to comment Share on other sites More sharing options...
Xalius Posted July 2, 2017 Author Share Posted July 2, 2017 Fire219 just got his board and ran a GbE test using ayufan's latest image (only tx-offloading enabled by default) with performance governor. Rock64 (client) --> Thinkcentre (server) [ 4] local 192.168.0.120 port 49148 connected to 192.168.0.85 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 104 MBytes 868 Mbits/sec 0 2.39 MBytes [ 4] 1.00-2.00 sec 108 MBytes 904 Mbits/sec 0 2.39 MBytes [ 4] 2.00-3.00 sec 108 MBytes 902 Mbits/sec 0 2.67 MBytes [ 4] 3.00-4.00 sec 108 MBytes 902 Mbits/sec 0 2.67 MBytes [ 4] 4.00-5.00 sec 105 MBytes 880 Mbits/sec 0 3.63 MBytes [ 4] 5.00-6.00 sec 110 MBytes 921 Mbits/sec 0 3.63 MBytes [ 4] 6.00-7.00 sec 105 MBytes 883 Mbits/sec 0 3.63 MBytes [ 4] 7.00-8.00 sec 110 MBytes 923 Mbits/sec 0 3.63 MBytes [ 4] 8.00-9.00 sec 106 MBytes 891 Mbits/sec 0 5.45 MBytes [ 4] 9.00-10.00 sec 106 MBytes 891 Mbits/sec 0 5.45 MBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 1.04 GBytes 896 Mbits/sec 0 sender [ 4] 0.00-10.00 sec 1.04 GBytes 894 Mbits/sec receiver iperf Done. Thinkcentre (client) --> Rock64 (server) [ 4] local 192.168.0.85 port 54468 connected to 192.168.0.120 port 5201 [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 111 MBytes 931 Mbits/sec 0 450 KBytes [ 4] 1.00-2.00 sec 112 MBytes 941 Mbits/sec 0 474 KBytes [ 4] 2.00-3.00 sec 112 MBytes 937 Mbits/sec 0 474 KBytes [ 4] 3.00-4.00 sec 111 MBytes 929 Mbits/sec 0 474 KBytes [ 4] 4.00-5.00 sec 112 MBytes 940 Mbits/sec 0 474 KBytes [ 4] 5.00-6.00 sec 111 MBytes 933 Mbits/sec 0 474 KBytes [ 4] 6.00-7.00 sec 112 MBytes 938 Mbits/sec 0 474 KBytes [ 4] 7.00-8.00 sec 112 MBytes 942 Mbits/sec 0 474 KBytes [ 4] 8.00-9.00 sec 112 MBytes 936 Mbits/sec 0 474 KBytes [ 4] 9.00-10.00 sec 112 MBytes 936 Mbits/sec 0 474 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 1.09 GBytes 936 Mbits/sec 0 sender [ 4] 0.00-10.00 sec 1.09 GBytes 934 Mbits/sec receiver iperf Done. Link to comment Share on other sites More sharing options...
Xalius Posted July 3, 2017 Author Share Posted July 3, 2017 I am currently trying to patch some holes in the Rock64 dts. There seem to be some regulator properties missing and some GPIOs for card detect... I got this in the beginning: http://pastebin.ubuntu.com/25013127/ I got rid of the "rk808 1-0018: Looking up vccX-supply property in node ..." by defining the regulator inputs in the dts, and adding a fixed 5V regulator for DC input: https://github.com/ayufan-rock64/linux-kernel/pull/3/files But I have a problem now that the regulator driver can not connect the new inputs or rather created the symlinks in syfs (symptom?) [ 2.087955] rk808 1-0018: Pmic Chip id: 0x8050 [ 2.096971] rk808 1-0018: source: on=0x40, off=0x00 [ 2.108733] rk808 1-0018: Looking up vcc1-supply from device tree [ 2.108849] DCDC_REG1: supplied by vcc_sys [ 2.116743] vcc_sys: could not add device link regulator.4 err -2 [ 2.118643] vdd_logic: 712 <--> 1450 mV at 1100 mV [ 2.118947] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [ 2.118981] vcc_sd: unable to resolve supply [ 2.119009] rk808 1-0018: Looking up vcc2-supply from device tree [ 2.119100] DCDC_REG2: supplied by vcc_sys [ 2.126809] vcc_sys: could not add device link regulator.5 err -2 [ 2.128223] vdd_arm: 712 <--> 1450 mV at 1000 mV [ 2.128528] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [ 2.128559] vcc_sd: unable to resolve supply [ 2.128586] rk808 1-0018: Looking up vcc3-supply from device tree [ 2.128674] DCDC_REG3: supplied by vcc_sys [ 2.136256] vcc_sys: could not add device link regulator.6 err -2 [ 2.137517] vcc_ddr: at 5000 mV [ 2.137767] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [ 2.137797] vcc_sd: unable to resolve supply [ 2.137825] rk808 1-0018: Looking up vcc4-supply from device tree [ 2.137907] DCDC_REG4: supplied by vcc_sys [ 2.145348] vcc_sys: could not add device link regulator.7 err -2 [ 2.146250] vcc_io: 3300 mV [ 2.146552] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [ 2.146583] vcc_sd: supplied by vcc_io [ 2.154221] rk808 1-0018: Looking up vcc5-supply from device tree [ 2.154254] LDO_REG1: supplied by vcc_io [ 2.161514] vcc_io: could not add device link regulator.8 err -2 [ 2.163889] vdd_18: 1800 mV [ 2.164188] rk808 1-0018: Looking up vcc5-supply from device tree [ 2.164220] LDO_REG2: supplied by vcc_io [ 2.171394] vcc_io: could not add device link regulator.9 err -2 [ 2.173749] vcc_18emmc: 1800 mV [ 2.174041] rk808 1-0018: Looking up vcc6-supply from device tree [ 2.174072] LDO_REG3: supplied by vcc_io [ 2.181197] vcc_io: could not add device link regulator.10 err -2 [ 2.183588] vdd_10: 1000 mV Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 4, 2017 Share Posted July 4, 2017 Look at rockchip patchwork area, they are adding the RK805, which I believe is the pmic involved here? They are very similar, but not quite the same. https://patchwork.kernel.org/project/linux-rockchip/list/?q=rk805 1 Link to comment Share on other sites More sharing options...
infinity Posted July 4, 2017 Share Posted July 4, 2017 Hi there, since the pre-order is open now, I'm wondering whether somebody has already had a look at the power consumption? I'm asking because I cannot decide between 2GB and 4GB version, since I don't know how significant the increase of power consumption might be to the 4GB version. My intention is to use the board as a seafile 24/7 miniserver with an SSD. Currently a BananaPi does this task. Any thoughts about this would be very appreciated Link to comment Share on other sites More sharing options...
tkaiser Posted July 4, 2017 Share Posted July 4, 2017 1 hour ago, infinity said: somebody has already had a look at the power consumption? Not really since I lack USB-to-3.5/1.35mm cables to do some precise measurements. But since we're talking about LPDDR3 here I wouldn't be concerned about the size of memory unless there's something f*cked up with entering low power states (driver issues). That's why I did no tests yet since I lack the cable and since I don't trust in software being 'stable' yet. Most probably for your use case being able to choose an appropriate PSU (5V/1.5A) would save more on consumption than RAM size. 1 Link to comment Share on other sites More sharing options...
infinity Posted July 4, 2017 Share Posted July 4, 2017 @tkaiser Thanks for these suggestions! So the 3A psu and an additional usb2barrel adaptor would be a good choice. EDIT I'm just concerned a bit about the quality of the usb2barrel adaptor cable that pine64 sells. In terms of awg standard. I'd perhaps need somewhen to extend it to 2m, which most probably wouldn't work then. Link to comment Share on other sites More sharing options...
tkaiser Posted July 4, 2017 Share Posted July 4, 2017 25 minutes ago, infinity said: So the 3A psu and an additional usb2barrel adaptor would be a good choice Hmm... I think there's a misunderstanding. I was only talking about my usual consumption measurements using another SBC (Banana Pro) and it's power management IC to measure its own consumption and the one of a connected other SBC (web search for 'measuring psu site:armbian.com' should give the idea). For this and only for this I would need such an USB to barrel cable, for all other use cases I would strongly recommend their 3A PSU with fixed cable. Your server setup with just a single SSD might be reliably powered with only 1A (so add some peak consumption and you're at 1.5A) so if you ensure that you avoid under-voltage then you should be fine with a 1.5A PSU too. A 3A PSU is not that efficient with loads that are below 50% or even 30% of the maximum ratings so if you're after power savings you might benefit from a 'smaller' PSU. But that was only to illustrate that if you care about consumption it's most probably better to look at PSU 'size' than DRAM size 1 Link to comment Share on other sites More sharing options...
hojnikb Posted July 4, 2017 Share Posted July 4, 2017 Pretty good price for the base model; too bad shipping costs are absurd. Link to comment Share on other sites More sharing options...
infinity Posted July 4, 2017 Share Posted July 4, 2017 @tkaiser Yep I understood it the way you meant it I was just too lazy to explain that I would buy the 3A for high power and also the usb2barrel adaptor that pine64 offers for being able to use any usb phone charger at home. This way i could also connect any 1A to 2A phone charger that I have at home. Thank you very much! Link to comment Share on other sites More sharing options...
Xalius Posted July 4, 2017 Author Share Posted July 4, 2017 9 hours ago, TonyMac32 said: Look at rockchip patchwork area, they are adding the RK805, which I believe is the pmic involved here? They are very similar, but not quite the same. https://patchwork.kernel.org/project/linux-rockchip/list/?q=rk805 Many thanks for spotting that! I think here mainline is even ahead of BSP for once, lol. I will see if I can backport the RK805 support patch for the RK808 driver, since I think atm we are just using RK808 as is with BSP... compared to A64's AXP803 this PMIC is very straightforward, the missing dts entries are more or less only cosmetics, but I like my boot logs clean :-) Link to comment Share on other sites More sharing options...
Xalius Posted July 5, 2017 Author Share Posted July 5, 2017 Some more iozone results for my JMS567 and a Samsung 830 256GB SSD running iozone, using large size of 12GB shows some significantly different results to the values above with 100M, 400M. random random kB reclen write rewrite read reread read write 12288000 4 17768 22328 26129 25677 13302 21361 12288000 16 61171 75520 79985 79982 43520 73117 12288000 512 157411 241636 297964 297923 186737 107077 12288000 1024 179415 259620 308459 320070 239986 166616 12288000 16384 195302 232991 335103 352457 345601 153506 It would be interesting to see some low level statistics on the USB/UAS transfers... Link to comment Share on other sites More sharing options...
infinity Posted July 5, 2017 Share Posted July 5, 2017 Seeing these USB benchmarks: Is anything known about USB3-Hub support? Since the board has only one USB3 port, It'd be interesting to know what happens if you add an USB3 Hub to connect more than one device. Also wondering what would happen with UAS support if such a hub-setup is possible. Link to comment Share on other sites More sharing options...
Xalius Posted July 6, 2017 Author Share Posted July 6, 2017 That is an interesting question, I have one USB3 hub at home, maybe I'll get a second JMS bridge and find out... 1 Link to comment Share on other sites More sharing options...
