vinser Posted July 31, 2020 Posted July 31, 2020 Few simple steps to install docker and docker compose on clean Armbian_20.05.4_Odroidxu4_focal_current_5.4.41 ODROID-HC1 Thanks to official docs https://docs.docker.com/engine/install/ubuntu/ curl -fsSL https://download.docker.com/linux/ubuntu/gpg | apt-key add - # Verify that you now have the key with the fingerprint 9DC8 5822 9FC7 DD38 854A E2D8 8D81 803C 0EBF CD88 - you may skip this apt-key fingerprint 0EBFCD88 # add-apt-repository "deb [arch=armhf] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable" add-apt-repository "deb [arch=armhf] https://download.docker.com/linux/ubuntu bionic stable" # there is no repository for focal :( apt-get update apt-get install docker-ce docker-ce-cli containerd.io docker run --rm hello-world # test - you may skip docker --version apt install python3-pip apt install python3-dev apt install libffi-dev apt install libssl-dev pip3 install docker-compose docker-compose --version That's all, enjoy Sorry for necroposting 0 Quote
gounthar Posted November 5, 2020 Posted November 5, 2020 As the documentation is now marked as obsolete, what is the correct way to install Docker on a recent Armbian Buster? ___ ____ _ _ _ / _ \ _ __ __ _ _ __ __ _ ___| _ \(_) | || | | | | | '__/ _` | '_ \ / _` |/ _ \ |_) | | | || |_ | |_| | | | (_| | | | | (_| | __/ __/| | |__ _| \___/|_| \__,_|_| |_|\__, |\___|_| |_| |_| |___/ Welcome to Armbian 20.08.17 Buster with Linux 5.8.17-rockchip64 I think at one time, it was available in armbian-config, but I may be wrong.. And I'm trying that on an unsupported board (OrangePi4). Here is what I have done: sudo apt-get remove docker docker-engine docker.io containerd runc sudo apt-get install apt-transport-https ca-certificates curl gnupg-agent software-properties-common curl -fsSL https://download.docker.com/linux/debian/gpg | sudo apt-key add - sudo apt-key fingerprint 0EBFCD88 sudo add-apt-repository "deb [arch=arm64] https://download.docker.com/linux/debian $(lsb_release -cs) stable" sudo apt update sudo apt-get install docker-ce docker-ce-cli containerd.io sudo docker run hello-world Thanks. 0 Quote
Werner Posted November 6, 2020 Posted November 6, 2020 I think I marked that point as outdated as it has not been revisited for a long time but also have no experience with docker whatsoever to change it. So of anyone wants to change that please go ahead:https://github.com/armbian/documentation/edit/master/docs/User-Guide_Advanced-Features.md 1 Quote
lanefu Posted November 9, 2020 Posted November 9, 2020 the distro natively packaged versions are new enough for my use these days.. I just do apt install docker.io 1 Quote
gounthar Posted November 10, 2020 Posted November 10, 2020 Thanks for the tip. I will try it on another machine with a fresh install, as I get : apt install docker.io Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: docker.io : Depends: runc (>= 1.0.0~rc6~) E: Unable to correct problems, you have held broken packages. 0 Quote
ajkelsey Posted October 10, 2022 Posted October 10, 2022 Hi. I am attempting to install docker and I've hit a snag in the installation. I followed the instructions here: https://docs.docker.com/engine/install/ubuntu/ For some reason the docker service did not start. Here is the error from installation and the systemctl status: Setting up docker-ce (5:20.10.18~3-0~ubuntu-jammy) ... Job for docker.service failed because the control process exited with error code. See "systemctl status docker.service" and "journalctl -xeu docker.service" for details. invoke-rc.d: initscript docker, action "start" failed. ● docker.service - Docker Application Container Engine Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled) Active: activating (auto-restart) (Result: exit-code) since Mon 2022-10-10 19:40:40 EDT; 39ms ago TriggeredBy: ● docker.socket Docs: https://docs.docker.com Process: 15936 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE) Main PID: 15936 (code=exited, status=1/FAILURE) CPU: 367ms dpkg: error processing package docker-ce (--configure): installed docker-ce package post-installation script subprocess returned error exit status 1 Processing triggers for man-db (2.10.2-1) ... Errors were encountered while processing: docker-ce E: Sub-process /usr/bin/dpkg returned an error code (1) admin@lepotato:~$ sudo systemctl status docker.service × docker.service - Docker Application Container Engine Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Mon 2022-10-10 19:40:49 EDT; 2min 0s ago TriggeredBy: × docker.socket Docs: https://docs.docker.com Process: 16057 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE) Main PID: 16057 (code=exited, status=1/FAILURE) CPU: 473ms Oct 10 19:40:49 lepotato systemd[1]: docker.service: Scheduled restart job, restart counter is at 3. Oct 10 19:40:49 lepotato systemd[1]: Stopped Docker Application Container Engine. Oct 10 19:40:49 lepotato systemd[1]: docker.service: Start request repeated too quickly. Oct 10 19:40:49 lepotato systemd[1]: docker.service: Failed with result 'exit-code'. Oct 10 19:40:49 lepotato systemd[1]: Failed to start Docker Application Container Engine. 1 Quote
gounthar Posted October 11, 2022 Posted October 11, 2022 I'm afraid the official documentation for Armbian is there: https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-run-docker 0 Quote
Alligator427 Posted July 10, 2023 Posted July 10, 2023 I have the same issue than ajkelsey with installation of Docker on an Orange Pi zero2 under Armbian_23.02.3_Orangepizero2_bullseye_legacy_4.9.318. I tried the two methods described in the official documentation (https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-run-docker), but the docker service refuses to load. Is there anything I'm missing? I was planning to try it on a fresh Armbian installation. I did not try to install Docker on Jammy and Bookworm because wifi does not work properly with these systems (available at https://www.armbian.com/orange-pi-zero-2/) 0 Quote
Werner Posted July 10, 2023 Posted July 10, 2023 On 7/10/2023 at 2:43 PM, Alligator427 said: Is there anything I'm missing? Expand Docker needs some kernel stuff that has been introduced after 4.9.y was released. So the only way is to run a more recent kernel which probably does not support all hw features the board has to offer. 1 Quote
Alligator427 Posted July 10, 2023 Posted July 10, 2023 (edited) Thanks, Werner! The official Armbian documentation states that the version should be 20.08.17 or newer, with Kernel 3.10 or higher. I thought I was in the clear with Armbian_23.02.3_Orangepizero2_bullseye_legacy_4.9.318. https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-run-docker Perhaps this requirement applies to an older version of Docker. I'm considering trying a 1-2-year-old version of Docker to see if it works. Not sure if it makes sense. I've attempted to install three different versions of Bullseye (edge and current) with a kernel >4.9 (5.15.x or 6.2), but none of them boot up on the Orange Pi Zero 2. Unfortunately, The only versions that boot up have kernel 4.9. https://www.armbian.com/orange-pi-zero-2/ Edited July 11, 2023 by Alligator427 0 Quote
Werner Posted July 11, 2023 Posted July 11, 2023 docs are most likely behind due to lack of maintenance (feel free to contribute!). Docker wants cgroupsv2 which have been introduced in kernel 4.15.y 4.9.y is vendor kernel which might work better but is outdated and unmaintained:https://docs.armbian.com/User-Guide_FAQ/#why-does-hardware-feature-xy-work-in-old-kernel-but-not-in-more-recent-one 0 Quote
ALIGMSTEN Posted July 11, 2023 Posted July 11, 2023 The only solution for legacy images is to downgrade to cgroups v1 with kernel parameter You add this in armbianEnv.txt extraargs=systemd.unified_cgroup_hierarchy=0 To use cgroup v2, you need to have kernel 4.15 or later https://github.com/opencontainers/runc/blob/v1.0.0-rc95/docs/cgroup-v2.md#host-requirements. Other requirements you might need to set iptables debian os The docker installer uses iptables for nat. Unfortunately Debian uses nftables. You can convert the entries over to nftables or just setup Debian to use the legacy iptables. sudo update-alternatives --set iptables /usr/sbin/iptables-legacy sudo update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy As for non booting zero2 images please check latest, builds are working fine for me at this point, although I will check, (limited time atm, also 'not sure about mirrors synching'). 2 Quote
Alligator427 Posted July 12, 2023 Posted July 12, 2023 (edited) Wow! Thanks ALIGMSTEN! This solve the issue completely. The last docker version is now working on Armbian bullseye kernel 4.9 on Orange pi zero2. Thanks for your help and for what you are doing! Here is the detailed procedure for the people that may experience the same issue. -Fresh install of Armbian_23.02.3_Orangepizero2_bullseye_legacy_4.9.318.img.xz http://xogium.performanceservers.nl/archive/orangepizero2/archive/Armbian_23.02.3_Orangepizero2_bullseye_legacy_4.9.318.img.xz sudo apt-get update sudo apt-get upgrade -add the following to /boot/armbianEnv.txt extraargs=systemd.unified_cgroup_hierarchy=0 -return to prompt sudo update-alternatives --set iptables /usr/sbin/iptables-legacy sudo update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy -reboot -install docker according to https://docs.docker.com/engine/install/debian/ (below) sudo apt-get update sudo apt-get install ca-certificates curl gnupg sudo install -m 0755 -d /etc/apt/keyrings curl -fsSL https://download.docker.com/linux/debian/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg sudo chmod a+r /etc/apt/keyrings/docker.gpg -Then echo \ "deb [arch="$(dpkg --print-architecture)" signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/debian \ "$(. /etc/os-release && echo "$VERSION_CODENAME")" stable" | \ sudo tee /etc/apt/sources.list.d/docker.list > /dev/null sudo apt-get update sudo apt-get install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin sudo reboot -Test docker with sudo docker run hello-world Edited July 13, 2023 by Alligator427 2 Quote
PeterRies Posted July 24, 2024 Posted July 24, 2024 Hi there, I revived my BananaPi M1 (ARM7 32bit) last week. I installed a fresh armbian and just docker like this: sudo apt-get update sudo apt-get install ca-certificates curl sudo install -m 0755 -d /etc/apt/keyrings sudo curl -fsSL https://download.docker.com/linux/debian/gpg -o /etc/apt/keyrings/docker.asc sudo chmod a+r /etc/apt/keyrings/docker.asc echo "deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.asc] https://download.docker.com/linux/debian \ $(. /etc/os-release && echo "$VERSION_CODENAME") stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null sudo apt-get update sudo apt-get install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin sudo gpasswd -a $USER docker newgrp docker docker run hello-world The "Hello world" worked. But when I tried to run anything useful things failed. Seafile installed okay, but calling the UI timed out. Paperless-ngx complained that paperless-webserver cannot find route to redis. Stuff like this. I just want to use the machine in my internal Network at home. To investigate further I installed a simple httpd docker to see if I can reach that one. No luck. Neither from another machine in my LAN, nor via lynx on BananaPi calling localhost. The request goes out as the port seems to be open, but it never reaches the daemon inside the container or cannot respond. Same commands on my "production box" (a HP t630 with debian bookworm) work fine. So my conclusion is that it must be something in the OS. I compared iptables on BananaPi and t630 and checked the output of 'sudo /usr/sbin/sysctl -a | grep forwarding | grep ipv4' - they are the same. I'm a little bit clueless where to check, what commands to use as I'm quite new to docker. Do you have any suggestions? Thanks, Peter. 2 Quote
Igor Posted July 24, 2024 Posted July 24, 2024 On 7/24/2024 at 7:01 AM, PeterRies said: The "Hello world" worked. Expand This means Docker works. On 7/24/2024 at 7:01 AM, PeterRies said: To investigate further I installed a simple httpd docker to see if I can reach that one. No luck. Neither from another machine in my LAN, nor via lynx on BananaPi calling localhost. Expand Minimal Armbian images comes with very minimal systemd-networking since several weeks. This brought much smaller OS images, but could cause this kind of troubles. On 7/24/2024 at 7:01 AM, PeterRies said: Do you have any suggestions? Expand Try to do some research into this direction. 0 Quote
Igor Posted July 24, 2024 Posted July 24, 2024 "systemd-network doesn’t quite play well with docker." Perhaps this https://blog.kylemanna.com/linux/docker-systemd-network-surprise/ is the problem. 0 Quote
dziekon Posted July 24, 2024 Posted July 24, 2024 For anyone struggling with Docker connectivity issues on latest Arbian minimal images, I've found solution (although, can't say if it's a good or bad solution, I'm not a sysops wizard or whatever) which does seem to work fine for my use case. Tested on "Armbian_community 24.8.0-trunk.399 Bookworm with Linux 6.6.36-current-sunxi64" By following this stackoverflow answer (https://stackoverflow.com/a/76440642/951007), I've modified netplan's default configuration file (currently "/etc/netplan/10-dhcp-all-interfaces.yaml" file) from: (...) all-eth-interfaces: match: name: '*' (...) to (...) all-eth-interfaces: match: name: 'en*' (...) and restarted the entire SBC. With this change applied, docker network adapters changed their SETUP from "configuring" to "unmanaged", as it apparently should be in the first place (although please do note that other adapters have been changed as well, so proceed with caution): $ sudo networkctl list IDX LINK TYPE OPERATIONAL SETUP 1 lo loopback carrier unmanaged 2 end0 ether routable configured 3 wlan0 wlan off unmanaged 4 docker0 bridge no-carrier unmanaged 5 br-xxxxxxxxxxxx bridge no-carrier unmanaged 6 br-xxxxxxxxxxxy bridge no-carrier unmanaged After that, Docker was able to communicate with the outside world: $ docker run busybox ping -c 1 1.1.1.1 PING 1.1.1.1 (1.1.1.1): 56 data bytes 64 bytes from 1.1.1.1: seq=0 ttl=57 time=4.741 ms (...) and was able to communicate with other docker-based services in the same network - in my case, a Spoolman instance was not able to communicate with Postgresql instance started using one docker compose file. --- Again, please do note that I'm no expert in this regard, so if you decide to follow this solution, I would recommend verifying whether other services (that require connectivity in any way) still work as expected. 1 Quote
Werner Posted July 25, 2024 Posted July 25, 2024 On 7/24/2024 at 10:01 PM, dziekon said: minimal Expand On 7/24/2024 at 10:01 PM, dziekon said: netplan Expand I wonder how this works out since AFAIK there is no netplan installed on minimal images. 0 Quote
Igor Posted July 25, 2024 Posted July 25, 2024 On 7/25/2024 at 3:56 AM, Werner said: I wonder how this works out since AFAIK there is no netplan installed on minimal images. Expand It is, since moving network bits into extensions. Here it is installed: https://github.com/armbian/build/blob/main/extensions/network/net-systemd-networkd.sh#L11 1 Quote
PeterRies Posted July 27, 2024 Posted July 27, 2024 Thanks Igor for the explanation and dziekon for the 2 bytes change that did the job!! Excellent description. 😀 0 Quote
TRS-80 Posted July 27, 2024 Posted July 27, 2024 I am going to go back to basics, so apologies if this is too obvious. Are you guys opening ports between the container and the host? I am still learning Docker myself, but isn't the default to limit containers to their own little Docker network, where they can only reach each other? For example, when I started running Home Assistant as a Docker container, I had to allow `--net=host` option (well, the equivalent in my `docker-compose` file, but you get the idea). 0 Quote
