Posted (edited)
Here will be published all the tweaks for the Youyeetoo YY3568 board to enter the mainline with armbian.
Images
Kernel Vendor 6.1:
https://github.com/armbian/linux-rockchip/commit/27a98750790114235c72e8420d45f44eff210461
Overlays:
https://github.com/armbian/linux-rockchip/commit/18f066190842fc6bd509662a2d19588eb9f04612
Kernel Vendor 5.1:
https://github.com/armbian/linux-rockchip/commit/b5964f997e2267802db0a965e66ec299b8a1f437
Edited by Hqnicolas
Posted (edited)
TESTING
none of the images I created worked,
despite seeing the status post
https://github.com/armbian/linux-rockchip/releases/tag/v24.8.0-trunk.147
 it seems there was a cut in the manufacturer's information and the project didn't move forward
https://github.com/armbian/linux-rockchip/pull/99
I will do all the steps from scratch
cat dmesg
Quote
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 6.14.0-rc4-edge-rockchip64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Sun Feb 23 20:32:57 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Youyeetoo YY3568
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: Reserved memory: No reserved-memory node in the DT
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000001ffffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x1ff753640-0x1ff755dff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000]   node   0: [mem 0x00000001f0000000-0x00000001ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] cma: Reserved 256 MiB at 0x00000000e0000000 on node -1
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 34 pages/cpu s98840 r8192 d32232 u139264
[    0.000000] pcpu-alloc: s98840 r8192 d32232 u139264 alloc=34*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: root=UUID=de2a5213-e4a0-4e17-8a41-545c79873d46 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=41a72af7-ee03-854a-8ec3-780abdbcac11 usb-storage.quirks= cma=256M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=ddr-v1.21-2d653b3476,bl31-v1.44,uboot-rmbian-201-03/03/2025
[    0.000000] Unknown kernel command line parameters "splash ubootpart=41a72af7-ee03-854a-8ec3-780abdbcac11 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    0.000000] printk: log buffer data + meta data: 262144 + 917504 = 1179648 bytes
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1048064
[    0.000000] Policy zone: Normal
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 320 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: MBI range [296:319]
[    0.000000] GICv3: Using MBI frame 0x00000000fd410000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001303] Console: colour dummy device 80x25
[    0.001326] printk: legacy console [tty1] enabled
[    0.001522] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001548] pid_max: default: 32768 minimum: 301
[    0.001657] LSM: initializing lsm=capability,yama,apparmor
[    0.001748] Yama: becoming mindful.
[    0.002091] AppArmor: AppArmor initialized
[    0.002253] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002291] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.035886] rcu: Hierarchical SRCU implementation.
[    0.035909] rcu:     Max phase no-delay instances is 1000.
[    0.036426] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.037625] EFI services will not be available.
[    0.039937] smp: Bringing up secondary CPUs ...
[    0.052125] Detected VIPT I-cache on CPU1
[    0.052228] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.052288] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.060343] Detected VIPT I-cache on CPU2
[    0.060438] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.060489] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.068205] Detected VIPT I-cache on CPU3
[    0.068299] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.068350] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.068536] smp: Brought up 1 node, 4 CPUs
[    0.068564] SMP: Total of 4 processors activated.
[    0.068573] CPU: All CPU(s) started at EL2
[    0.068582] CPU features: detected: 32-bit EL0 Support
[    0.068589] CPU features: detected: 32-bit EL1 Support
[    0.068600] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.068609] CPU features: detected: Common not Private translations
[    0.068617] CPU features: detected: CRC32 instructions
[    0.068633] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.068642] CPU features: detected: LSE atomic instructions
[    0.068651] CPU features: detected: Privileged Access Never
[    0.068658] CPU features: detected: RAS Extension Support
[    0.068670] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.068757] alternatives: applying system-wide alternatives
[    0.073662] Memory: 3714900K/4192256K available (16576K kernel code, 2906K rwdata, 11224K rodata, 5312K init, 785K bss, 210980K reserved, 262144K cma-reserved)
[    0.075527] devtmpfs: initialized
[    0.098887] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.098944] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.107497] 23504 pages in range for non-PLT usage
[    0.107524] 515024 pages in range for PLT usage
[    0.107891] pinctrl core: initialized pinctrl subsystem
[    0.108843] DMI not present or invalid.
[    0.113431] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.115674] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.116915] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.118088] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.118185] audit: initializing netlink subsys (disabled)
[    0.118539] audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1
[    0.121651] thermal_sys: Registered thermal governor 'fair_share'
[    0.121669] thermal_sys: Registered thermal governor 'bang_bang'
[    0.121679] thermal_sys: Registered thermal governor 'step_wise'
[    0.121687] thermal_sys: Registered thermal governor 'user_space'
[    0.121817] cpuidle: using governor menu
[    0.122311] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.122544] ASID allocator initialised with 65536 entries
[    0.122926] Serial: AMBA PL011 UART driver
[    0.143586] /pcie@fe260000: Fixed dependency cycle(s) with /pcie@fe260000/legacy-interrupt-controller
[    0.163152] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.164093] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.164697] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.165129] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.165563] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.166024] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.166458] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.166875] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.167304] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.167698] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.171601] /pcie@fe270000: Fixed dependency cycle(s) with /pcie@fe270000/legacy-interrupt-controller
[    0.172611] /pcie@fe280000: Fixed dependency cycle(s) with /pcie@fe280000/legacy-interrupt-controller
[    0.180358] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.180382] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.180394] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.180402] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.180412] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.180420] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.180429] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.180436] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.182711] cryptd: max_cpu_qlen set to 1000
[    0.250273] raid6: neonx8   gen()  1409 MB/s
[    0.318488] raid6: neonx4   gen()  1438 MB/s
[    0.386708] raid6: neonx2   gen()  1323 MB/s
[    0.454913] raid6: neonx1   gen()  1074 MB/s
[    0.523150] raid6: int64x8  gen()   910 MB/s
[    0.591350] raid6: int64x4  gen()  1051 MB/s
[    0.659572] raid6: int64x2  gen()   937 MB/s
[    0.727789] raid6: int64x1  gen()   689 MB/s
[    0.727802] raid6: using algorithm neonx4 gen() 1438 MB/s
[    0.795960] raid6: .... xor() 1102 MB/s, rmw enabled
[    0.795973] raid6: using neon recovery algorithm
[    0.797381] iommu: Default domain type: Translated
[    0.797401] iommu: DMA domain TLB invalidation policy: strict mode
[    0.798494] SCSI subsystem initialized
[    0.798880] libata version 3.00 loaded.
[    0.799213] usbcore: registered new interface driver usbfs
[    0.799267] usbcore: registered new interface driver hub
[    0.799333] usbcore: registered new device driver usb
[    0.800043] pps_core: LinuxPPS API ver. 1 registered
[    0.800055] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.800092] PTP clock support registered
[    0.800154] EDAC MC: Ver: 3.0.0
[    0.800731] scmi_core: SCMI protocol bus registered
[    0.802471] NetLabel: Initializing
[    0.802490] NetLabel:  domain hash size = 128
[    0.802499] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.802603] NetLabel:  unlabeled traffic allowed by default
[    0.802902] vgaarb: loaded
[    0.803735] clocksource: Switched to clocksource arch_sys_counter
[    0.804536] VFS: Disk quotas dquot_6.6.0
[    0.804607] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.805494] AppArmor: AppArmor Filesystem Enabled
[    0.821070] NET: Registered PF_INET protocol family
[    0.821449] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.894225] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.894471] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.894597] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.895189] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.896176] TCP: Hash tables configured (established 32768 bind 32768)
[    0.896426] UDP hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.896618] UDP-Lite hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.897027] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.897079] NET: Registered PF_XDP protocol family
[    0.897105] PCI: CLS 0 bytes, default 64
[    0.897573] Trying to unpack rootfs image as initramfs...
[    0.904809] kvm [1]: nv: 566 coarse grained trap handlers
[    0.905489] kvm [1]: IPA Size Limit: 40 bits
[    0.905541] kvm [1]: GICv3: no GICV resource entry
[    0.905552] kvm [1]: disabling GICv2 emulation
[    0.905599] kvm [1]: GIC system register CPU interface enabled
[    0.905644] kvm [1]: vgic interrupt IRQ9
[    0.905706] kvm [1]: VHE mode initialized successfully
[    0.908801] Initialise system trusted keyrings
[    0.908894] Key type blacklist registered
[    0.909281] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    0.909362] zbud: loaded
[    0.910207] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.910930] fuse: init (API version 7.42)
[    0.913576] integrity: Platform Keyring initialized
[    0.986759] xor: measuring software checksum speed
[    0.988735]    8regs           :  1684 MB/sec
[    0.990833]    32regs          :  1576 MB/sec
[    0.992766]    arm64_neon      :  1707 MB/sec
[    0.992781] xor: using function: arm64_neon (1707 MB/sec)
[    0.992802] Key type asymmetric registered
[    0.992812] Asymmetric key parser 'x509' registered
[    0.992993] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.993365] io scheduler mq-deadline registered
[    0.993381] io scheduler kyber registered
[    0.993453] io scheduler bfq registered
[    2.496436] Freeing initrd memory: 26360K
[    2.499366] ledtrig-cpu: registered to indicate activity on CPUs
[    2.510538] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.510569] dma-pl330 fe530000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.514067] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.514094] dma-pl330 fe550000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.517572] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.523234] printk: legacy console [ttyS2] disabled
[    2.523780] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 25, base_baud = 1500000) is a 16550A
[    2.524060] printk: legacy console [ttyS2] enabled
[    2.525942] Serial: AMBA driver
[    2.538697] loop: module loaded
[    2.540746] Key type psk registered
[    2.546658] thunder_xcv, ver 1.0
[    2.546720] thunder_bgx, ver 1.0
[    2.546765] nicpf, ver 1.0
[    2.550827] usbcore: registered new interface driver usb-storage
[    2.553549] mousedev: PS/2 mouse device common for all mice
[    2.554250] i2c_dev: i2c /dev entries driver
[    2.556987] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    2.564338] sdhci: Secure Digital Host Controller Interface driver
[    2.564361] sdhci: Copyright(c) Pierre Ossman
[    2.564412] Synopsys Designware Multimedia Card Interface Driver
[    2.565464] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.568098] arm-scmi arm-scmi.0.auto: Using scmi_smc_transport
[    2.568124] arm-scmi arm-scmi.0.auto: SCMI max-rx-timeout: 30ms / max-msg-size: 104bytes / max-msg: 20
[    2.568342] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16
[    2.568746] arm-scmi arm-scmi.0.auto: SCMI Notifications - Core Enabled.
[    2.568822] arm-scmi arm-scmi.0.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    2.570833] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    2.571199] hid: raw HID events driver (C) Jiri Kosina
[    2.571328] usbcore: registered new interface driver usbhid
[    2.571341] usbhid: USB HID core driver
[    2.573093] rockchip-dfi fe230000.dfi: dfi initialized, dram type: 0x7, channels: 1
[    2.575141] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available
[    2.577037] NET: Registered PF_INET6 protocol family
[    2.619073] Segment Routing with IPv6
[    2.619188] In-situ OAM (IOAM) with IPv6
[    2.619334] NET: Registered PF_PACKET protocol family
[    2.619612] 8021q: 802.1Q VLAN Support v1.8
[    2.619799] Key type dns_resolver registered
[    2.633085] registered taskstats version 1
[    2.633600] Loading compiled-in X.509 certificates
[    2.652841] zswap: loaded using pool zstd/z3fold
[    2.653268] Demotion targets for Node 0: null
[    2.653509] Key type .fscrypt registered
[    2.653524] Key type fscrypt-provisioning registered
[    2.657066] Btrfs loaded, zoned=yes, fsverity=yes
[    2.657341] Key type encrypted registered
[    2.657365] AppArmor: AppArmor sha256 policy hashing enabled
[    2.705057] rockchip-dw-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[    2.705126] rockchip-dw-pcie 3c0000000.pcie:       IO 0x00f4100000..0x00f41fffff -> 0x00f4100000
[    2.705162] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x00f4200000..0x00f5ffffff -> 0x00f4200000
[    2.705187] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x0300000000..0x033fffffff -> 0x0040000000
[    2.705394] rockchip-dw-pcie 3c0000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G
[    2.808338] rockchip-dw-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00
[    2.808373] pci_bus 0000:00: root bus resource [bus 00-0f]
[    2.808393] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff])
[    2.808409] pci_bus 0000:00: root bus resource [mem 0xf4200000-0xf5ffffff]
[    2.808425] pci_bus 0000:00: root bus resource [mem 0x300000000-0x33fffffff] (bus address [0x40000000-0x7fffffff])
[    2.808480] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400 PCIe Root Port
[    2.808520] pci 0000:00:00.0: ROM [mem 0x00000000-0x0000ffff pref]
[    2.808538] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.808557] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    2.808573] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    2.808594] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    2.808689] pci 0000:00:00.0: supports D1 D2
[    2.808704] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.817565] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[    2.817925] pci 0000:00:00.0: ROM [mem 0xf4200000-0xf420ffff pref]: assigned
[    2.817955] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.817981] pci_bus 0000:00: resource 4 [io  0x0000-0xfffff]
[    2.817996] pci_bus 0000:00: resource 5 [mem 0xf4200000-0xf5ffffff]
[    2.818010] pci_bus 0000:00: resource 6 [mem 0x300000000-0x33fffffff]
[    2.821017] pcieport 0000:00:00.0: PME: Signaling with IRQ 37
[    2.821550] pcieport 0000:00:00.0: AER: enabled with IRQ 37
[    2.822726] ahci-dwc fc400000.sata: supply ahci not found, using dummy regulator
[    2.822938] ahci-dwc fc400000.sata: supply phy not found, using dummy regulator
[    2.823115] ahci-dwc fc400000.sata: supply target not found, using dummy regulator
[    2.823223] ahci-dwc fc400000.sata: PMPn is limited up to 5 ports
[    2.823366] ahci-dwc fc400000.sata: forcing port_map 0x0 -> 0x1
[    2.823431] ahci-dwc fc400000.sata: AHCI vers 0001.0300, 32 command slots, 6 Gbps, platform mode
[    2.823451] ahci-dwc fc400000.sata: 1/1 ports implemented (port mask 0x1)
[    2.823467] ahci-dwc fc400000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[    2.823504] ahci-dwc fc400000.sata: port 0 is not capable of FBS
[    2.825266] scsi host0: ahci-dwc
[    2.825714] ata1: SATA max UDMA/133 mmio [mem 0xfc400000-0xfc400fff] port 0x100 irq 38 lpm-pol 0
[    2.933776] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    2.933870] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    2.933889] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    2.933960] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[    2.934666] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    2.948705] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    2.956428] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[    2.956478] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 1
[    2.956676] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010
[    2.956754] xhci-hcd xhci-hcd.7.auto: irq 67, io mem 0xfcc00000
[    2.956992] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[    2.957021] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 2
[    2.957045] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed
[    2.957371] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.957393] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.957407] usb usb1: Product: xHCI Host Controller
[    2.957421] usb usb1: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.957433] usb usb1: SerialNumber: xhci-hcd.7.auto
[    2.958244] hub 1-0:1.0: USB hub found
[    2.958316] hub 1-0:1.0: 1 port detected
[    2.958957] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.959196] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[    2.959219] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.959234] usb usb2: Product: xHCI Host Controller
[    2.959246] usb usb2: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.959258] usb usb2: SerialNumber: xhci-hcd.7.auto
[    2.960019] hub 2-0:1.0: USB hub found
[    2.960090] hub 2-0:1.0: 1 port detected
[    2.963267] WCN: marlin_init entry!
[    2.963988] of_cfs_init
[    2.964049] of_cfs_init: OK
[    2.964317] ehci-platform fd800000.usb: EHCI Host Controller
[    2.964352] ohci-platform fd840000.usb: Generic Platform OHCI controller
[    2.964362] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 3
[    2.964397] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 4
[    2.964560] ehci-platform fd800000.usb: irq 69, io mem 0xfd800000
[    2.964593] ohci-platform fd840000.usb: irq 71, io mem 0xfd840000
[    2.964754] ehci-platform fd880000.usb: EHCI Host Controller
[    2.964796] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[    2.964796] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 5
[    2.964837] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 6
[    2.964958] ehci-platform fd880000.usb: irq 70, io mem 0xfd880000
[    2.964984] ohci-platform fd8c0000.usb: irq 72, io mem 0xfd8c0000
[    2.967376] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    2.975889] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[    2.976412] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.976443] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.976458] usb usb3: Product: EHCI Host Controller
[    2.976469] usb usb3: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ehci_hcd
[    2.976481] usb usb3: SerialNumber: fd800000.usb
[    2.977577] hub 3-0:1.0: USB hub found
[    2.977661] hub 3-0:1.0: 1 port detected
[    2.991813] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[    2.992273] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.992302] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.992317] usb usb5: Product: EHCI Host Controller
[    2.992329] usb usb5: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ehci_hcd
[    2.992341] usb usb5: SerialNumber: fd880000.usb
[    2.993264] hub 5-0:1.0: USB hub found
[    2.993356] hub 5-0:1.0: 1 port detected
[    3.024227] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[    3.024262] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.024276] usb usb6: Product: Generic Platform OHCI controller
[    3.024288] usb usb6: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ohci_hcd
[    3.024301] usb usb6: SerialNumber: fd8c0000.usb
[    3.025243] hub 6-0:1.0: USB hub found
[    3.025333] hub 6-0:1.0: 1 port detected
[    3.026256] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[    3.026288] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.026303] usb usb4: Product: Generic Platform OHCI controller
[    3.026315] usb usb4: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ohci_hcd
[    3.026327] usb usb4: SerialNumber: fd840000.usb
[    3.027188] hub 4-0:1.0: USB hub found
[    3.027276] hub 4-0:1.0: 1 port detected
[    3.038455] mmc0: new HS200 MMC card at address 0001
[    3.039867] mmcblk0: mmc0:0001 DV4032 29.1 GiB
[    3.046945] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    3.046973] GPT:10625023 != 61071359
[    3.046987] GPT:Alternate GPT header not at the end of the disk.
[    3.046994] GPT:10625023 != 61071359
[    3.047002] GPT: Use GNU Parted to correct GPT errors.
[    3.047042]  mmcblk0: p1 p2
[    3.048386] mmcblk0boot0: mmc0:0001 DV4032 4.00 MiB
[    3.051028] mmcblk0boot1: mmc0:0001 DV4032 4.00 MiB
[    3.053353] mmcblk0rpmb: mmc0:0001 DV4032 16.0 MiB, chardev (243:0)
[    3.057043] clk: Disabling unused clocks
[    3.059228] PM: genpd: Disabling unused power domains
[    3.134709] ata1: SATA link down (SStatus 0 SControl 300)
[    3.138033] Freeing unused kernel memory: 5312K
[    3.138282] Run /init as init process
[    3.138296]   with arguments:
[    3.138307]     /init
[    3.138316]     splash
[    3.138325]   with environment:
[    3.138333]     HOME=/
[    3.138342]     TERM=linux
[    3.138351]     ubootpart=41a72af7-ee03-854a-8ec3-780abdbcac11
[    3.138360]     cgroup_enable=memory
[    3.138368]     cgroup_memory=1
[    3.223845] usb 3-1: new high-speed USB device number 2 using ehci-platform
[    3.379165] usb 3-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[    3.379201] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.379216] usb 3-1: Product: USB2.0 Hub
[    3.380461] hub 3-1:1.0: USB hub found
[    3.380969] hub 3-1:1.0: 4 ports detected
[    3.870119] rk808-rtc rk808-rtc.4.auto: registered as rtc0
[    3.874113] rk808-rtc rk808-rtc.4.auto: setting system clock to 2017-08-05T09:03:38 UTC (1501923818)
[    3.911973] panfrost fde60000.gpu: clock rate = 594000000
[    3.912044] panfrost fde60000.gpu: bus_clock rate = 500000000
[    3.921437] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    3.921474] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    3.921490] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    3.921507] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    3.948618] spi-nor spi4.0: supply vcc not found, using dummy regulator
[    3.948628] [drm] Initialized panfrost 1.3.0 for fde60000.gpu on minor 0
[    3.949572] spi-nor spi4.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.955184] random: crng init done
[    4.020964] phy phy-fe8c0000.phy.6: lane number 0, val 1
[    4.020998] phy phy-fe8c0000.phy.6: lane number 1, val 2
[    4.021010] phy phy-fe8c0000.phy.6: bifurcation enabled
[    4.021528] phy phy-fe8c0000.phy.6: rockchip_p3phy_rk3568_init: lock failed 0x6890000, check input refclk and power supply
[    4.021552] phy phy-fe8c0000.phy.6: phy init failed --> -110
[    4.022252] rockchip-dw-pcie 3c0800000.pcie: probe with driver rockchip-dw-pcie failed with error -110
[    4.024936] phy phy-fe8c0000.phy.6: lane number 0, val 1
[    4.024970] phy phy-fe8c0000.phy.6: lane number 1, val 2
[    4.024983] phy phy-fe8c0000.phy.6: bifurcation enabled
[    4.025502] phy phy-fe8c0000.phy.6: rockchip_p3phy_rk3568_init: lock failed 0x6890000, check input refclk and power supply
[    4.025527] phy phy-fe8c0000.phy.6: phy init failed --> -110
[    4.025586] rockchip-dw-pcie 3c0400000.pcie: probe with driver rockchip-dw-pcie failed with error -110
[    5.841347] EXT4-fs (mmcblk0p2): mounted filesystem de2a5213-e4a0-4e17-8a41-545c79873d46 ro with writeback data mode. Quota mode: none.
[    6.317227] systemd[1]: System time before build time, advancing clock.
[    6.329831] systemd[1]: Inserted module 'autofs4'
[    6.368100] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    6.369246] systemd[1]: Detected architecture arm64.
[    6.371213] systemd[1]: Hostname set to <yy3568>.
[    6.373329] systemd[1]: Initializing machine ID from random generator.
[    6.373622] systemd[1]: Installed transient /etc/machine-id file.
[    6.531343] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[    6.613040] block mmcblk0: the capability attribute has been deprecated.
[    6.825919] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[    7.213576] systemd[1]: Queued start job for default target Graphical Interface.
[    7.259435] systemd[1]: Created slice Slice /system/modprobe.
[    7.262737] systemd[1]: Created slice Slice /system/serial-getty.
[    7.265655] systemd[1]: Created slice Slice /system/systemd-fsck.
[    7.267710] systemd[1]: Created slice User and Session Slice.
[    7.268505] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.269978] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.270744] systemd[1]: Reached target User and Group Name Lookups.
[    7.271119] systemd[1]: Reached target Slice Units.
[    7.271404] systemd[1]: Reached target Swaps.
[    7.271651] systemd[1]: Reached target System Time Set.
[    7.272155] systemd[1]: Reached target Local Verity Protected Volumes.
[    7.296939] systemd[1]: Listening on RPCbind Server Activation Socket.
[    7.298266] systemd[1]: Listening on Syslog Socket.
[    7.299328] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.300064] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.301676] systemd[1]: Listening on Journal Audit Socket.
[    7.302703] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.304018] systemd[1]: Listening on Journal Socket.
[    7.310073] systemd[1]: Listening on udev Control Socket.
[    7.311185] systemd[1]: Listening on udev Kernel Socket.
[    7.317646] systemd[1]: Mounting Huge Pages File System...
[    7.324601] systemd[1]: Mounting POSIX Message Queue File System...
[    7.332040] systemd[1]: Mounting Kernel Debug File System...
[    7.339032] systemd[1]: Mounting Kernel Trace File System...
[    7.340513] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    7.348547] systemd[1]: Starting Restore / save the current clock...
[    7.356637] systemd[1]: Starting Set the console keyboard layout...
[    7.365046] systemd[1]: Starting Create List of Static Device Nodes...
[    7.373662] systemd[1]: Starting Load Kernel Module configfs...
[    7.382276] systemd[1]: Starting Load Kernel Module drm...
[    7.391227] systemd[1]: Starting Load Kernel Module efi_pstore...
[    7.399687] systemd[1]: Starting Load Kernel Module fuse...
[    7.401291] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.415272] systemd[1]: Starting Load Kernel Modules...
[    7.424180] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.432904] systemd[1]: Starting Coldplug All udev Devices...
[    7.447045] systemd[1]: Mounted Huge Pages File System.
[    7.449586] systemd[1]: Mounted POSIX Message Queue File System.
[    7.451908] systemd[1]: Mounted Kernel Debug File System.
[    7.454169] systemd[1]: Mounted Kernel Trace File System.
[    7.458998] systemd[1]: Finished Restore / save the current clock.
[    7.463939] systemd[1]: Finished Create List of Static Device Nodes.
[    7.466692] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    7.469769] systemd[1]: Finished Load Kernel Module configfs.
[    7.473457] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    7.480004] systemd[1]: Finished Load Kernel Module drm.
[    7.482458] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    7.485719] systemd[1]: Finished Load Kernel Module efi_pstore.
[    7.492398] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    7.494535] systemd[1]: Finished Load Kernel Module fuse.
[    7.497679] EXT4-fs (mmcblk0p2): re-mounted de2a5213-e4a0-4e17-8a41-545c79873d46 r/w. Quota mode: none.
[    7.498837] systemd[1]: Finished Load Kernel Modules.
[    7.511839] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.540417] systemd[1]: Mounting FUSE Control File System...
[    7.547304] systemd[1]: Mounting Kernel Configuration File System...
[    7.548309] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    7.556383] systemd[1]: Starting Load/Save Random Seed...
[    7.569406] systemd[1]: Starting Apply Kernel Variables...
[    7.588631] systemd[1]: Starting Create System Users...
[    7.610730] systemd[1]: Mounted FUSE Control File System.
[    7.613031] systemd[1]: Mounted Kernel Configuration File System.
[    7.623458] systemd[1]: Finished Load/Save Random Seed.
[    7.625464] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[    7.655225] systemd[1]: Finished Create System Users.
[    7.683615] systemd[1]: Finished Apply Kernel Variables.
[    7.692411] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.753849] systemd[1]: Finished Set the console keyboard layout.
[    7.757876] systemd[1]: Finished Create Static Device Nodes in /dev.
[    7.759112] systemd[1]: Reached target Preparation for Local File Systems.
[    7.796270] systemd[1]: Mounting /tmp...
[    7.807909] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    7.814108] systemd[1]: Mounted /tmp.
[    8.097802] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    8.129870] systemd[1]: Finished Coldplug All udev Devices.
[    8.172364] systemd[1]: Starting Show Plymouth Boot Screen...
[    8.231995] systemd[1]: Started Show Plymouth Boot Screen.
[    8.233129] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[    8.234308] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[    8.234639] systemd[1]: Reached target Local Encrypted Volumes.
[    8.606928] mc: Linux media interface: v0.10
[    8.688457] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey.3.auto/input/input0
[    8.739993] videodev: Linux video capture interface: v2.00
[    8.764699] rk2-crypto fe380000.crypto: will run requests pump with realtime priority
[    8.764785] rk2-crypto fe380000.crypto: Registers crypto algos
[    8.764792] rk2-crypto fe380000.crypto: Register ecb(aes) as ecb-aes-rk2
[    8.764845] rk2-crypto fe380000.crypto: Register cbc(aes) as cbc-aes-rk2
[    8.764860] rk2-crypto fe380000.crypto: Register xts(aes) as xts-aes-rk2
[    8.764874] rk2-crypto fe380000.crypto: Register md5 as rk2-md5 3
[    8.764889] rk2-crypto fe380000.crypto: Register sha1 as rk2-sha1 4
[    8.764905] rk2-crypto fe380000.crypto: Register sha256 as rk2-sha256 5
[    8.764919] rk2-crypto fe380000.crypto: Register sha384 as rk2-sha384 6
[    8.764932] rk2-crypto fe380000.crypto: Register sha512 as rk2-sha512 7
[    8.764945] rk2-crypto fe380000.crypto: Register sm3 as rk2-sm3 8
[    8.829499] rockchip-rga fdeb0000.rga: HW Version: 0x03.02
[    8.830002] rockchip_vdec2: module is from the staging directory, the quality is unknown, you have been warned.
[    8.850073] systemd[1]: Found device /dev/disk/by-uuid/3EBA-7644.
[    8.865368] rockchip-rga fdeb0000.rga: Registered rockchip-rga as /dev/video0
[    8.876982] systemd[1]: Starting File System Check on /dev/disk/by-uuid/3EBA-7644...
[    8.903175] hantro-vpu fdea0000.video-codec: Adding to iommu group 0
[    8.904321] hantro-vpu fdea0000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2
[    8.905473] hantro-vpu fdee0000.video-codec: Adding to iommu group 1
[    8.907885] hantro-vpu fdee0000.video-codec: registered rockchip,rk3568-vepu-enc as /dev/video3
[    8.916668] systemd[1]: Found device /dev/ttyS2.
[    8.948546] systemd[1]: Started File System Check Daemon to report status.
[    8.982837] systemd[1]: Finished File System Check on /dev/disk/by-uuid/3EBA-7644.
[    8.988625] systemd[1]: Mounting /boot...
[    9.030354] systemd[1]: Mounted /boot.
[    9.031205] systemd[1]: Reached target Local File Systems.
[    9.049439] systemd[1]: Starting Armbian ZRAM config...
[    9.055279] systemd[1]: Starting Set console font and keymap...
[    9.064534] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.065579] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[    9.072269] systemd[1]: Starting Set Up Additional Binary Formats...
[    9.072580] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    9.082948] systemd[1]: Starting Commit a transient machine-id on disk...
[    9.085620] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.086521] systemd[1]: Received SIGRTMIN+20 from PID 175 (plymouthd).
[    9.098605] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 326 (systemd-binfmt)
[    9.108171] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[    9.136056] systemd[1]: etc-machine\x2did.mount: Deactivated successfully.
[    9.139106] systemd[1]: Finished Commit a transient machine-id on disk.
[    9.140132] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[    9.150078] systemd[1]: Finished Set Up Additional Binary Formats.
[    9.268366] zram: Added device: zram0
[    9.268892] zram: Added device: zram1
[    9.272574] zram: Added device: zram2
[    9.335217] zram0: detected capacity change from 0 to 4012952
[    9.353350] Adding 2006472k swap on /dev/zram0.  Priority:5 extents:1 across:2006472k SS
[    9.391417] zram1: detected capacity change from 0 to 102400
[    9.421596] systemd[1]: Finished Armbian ZRAM config.
[    9.444580] systemd[1]: Starting Armbian memory supported logging...
[    9.493608] EXT4-fs (zram1): mounted filesystem ef0c2a86-bb36-4b01-8cee-d5ff3a7a96ad r/w without journal. Quota mode: none.
[    9.955138] systemd[1]: Finished Armbian memory supported logging.
[    9.976514] systemd[1]: Starting Journal Service...
[   10.125420] systemd[1]: Started Journal Service.
[   10.175941] systemd-journald[435]: Received client request to flush runtime journal.
[   10.325494] RPC: Registered named UNIX socket transport module.
[   10.325509] RPC: Registered udp transport module.
[   10.325513] RPC: Registered tcp transport module.
[   10.325517] RPC: Registered tcp-with-tls transport module.
[   10.325520] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   11.348922] EXT4-fs (mmcblk0p2): resizing filesystem from 1258491 to 7487488 blocks
[   11.536331] EXT4-fs (mmcblk0p2): resized filesystem to 7487488
[   33.768240] vdd_npu: disabling
[   33.769497] vdda0v9_image: disabling
[   33.771188] vcca1v8_image: disabling
[   53.431847] usb 3-1.1: new full-speed USB device number 3 using ehci-platform
[   53.530354] usb 3-1.1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   53.530412] usb 3-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   53.530441] usb 3-1.1: Product: USB2.0 HUB
[   53.532313] hub 3-1.1:1.0: USB hub found
[   53.532752] hub 3-1.1:1.0: 4 ports detected
[   74.691339] usb 3-1.1: USB disconnect, device number 3
[   74.767910] usb 3-1.2: new full-speed USB device number 4 using ehci-platform
[   74.866461] usb 3-1.2: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   74.866518] usb 3-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   74.866549] usb 3-1.2: Product: USB2.0 HUB
[   74.868281] hub 3-1.2:1.0: USB hub found
[   74.868626] hub 3-1.2:1.0: 4 ports detected
[  118.679009] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[  118.690355] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  118.690850] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Edited by Hqnicolas
Posted (edited)
Mainline Kernel 6.14 :thumbup:
PR: https://github.com/armbian/build/pull/7908
cat dmesg
Quote
[    0.000000] NODE_DATA(0) allocated [mem 0x1ff751a40-0x1ff7541ff]
[    0.000000] Kernel command line: root=UUID=94ea9275-a0cd-4974-b523-8269456a7d02 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=5e425cc6-0a96-1149-b209-be03a1570889 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cma=256M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=ddr-v1.21-2d653b3476,bl31-v1.44,uboot-rmbian-201-03/04/2025
[    0.000000] Unknown kernel command line parameters "splash ubootpart=5e425cc6-0a96-1149-b209-be03a1570889 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    0.001341] Console: colour dummy device 80x25
[    0.001365] printk: legacy console [tty1] enabled
[    0.001564] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001589] pid_max: default: 32768 minimum: 301
[    0.001701] LSM: initializing lsm=capability,yama,apparmor
[    0.001793] Yama: becoming mindful.
[    0.002140] AppArmor: AppArmor initialized
[    0.002301] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002340] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.031827] rcu: Hierarchical SRCU implementation.
[    0.031850] rcu:     Max phase no-delay instances is 1000.
[    0.032370] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.033586] EFI services will not be available.
[    0.035872] smp: Bringing up secondary CPUs ...
[    0.048063] Detected VIPT I-cache on CPU1
[    0.048166] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.048228] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.056285] Detected VIPT I-cache on CPU2
[    0.056382] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.056433] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.068161] Detected VIPT I-cache on CPU3
[    0.068257] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.068308] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.068492] smp: Brought up 1 node, 4 CPUs
[    0.068520] SMP: Total of 4 processors activated.
[    0.068528] CPU: All CPU(s) started at EL2
[    0.068537] CPU features: detected: 32-bit EL0 Support
[    0.068545] CPU features: detected: 32-bit EL1 Support
[    0.068555] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.068566] CPU features: detected: Common not Private translations
[    0.068574] CPU features: detected: CRC32 instructions
[    0.068590] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.068598] CPU features: detected: LSE atomic instructions
[    0.068606] CPU features: detected: Privileged Access Never
[    0.068614] CPU features: detected: RAS Extension Support
[    0.068626] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.068711] alternatives: applying system-wide alternatives
[    0.073669] Memory: 3714892K/4192256K available (16576K kernel code, 2906K rwdata, 11224K rodata, 5312K init, 785K bss, 210988K reserved, 262144K cma-reserved)
[    0.075567] devtmpfs: initialized
[    0.099152] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.099209] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.107832] 23504 pages in range for non-PLT usage
[    0.107860] 515024 pages in range for PLT usage
[    0.108315] pinctrl core: initialized pinctrl subsystem
[    0.109173] DMI not present or invalid.
[    0.113372] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.115662] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.116900] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.118078] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.118182] audit: initializing netlink subsys (disabled)
[    0.118541] audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1
[    0.121697] thermal_sys: Registered thermal governor 'fair_share'
[    0.121716] thermal_sys: Registered thermal governor 'bang_bang'
[    0.121726] thermal_sys: Registered thermal governor 'step_wise'
[    0.121734] thermal_sys: Registered thermal governor 'user_space'
[    0.121861] cpuidle: using governor menu
[    0.122360] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.122600] ASID allocator initialised with 65536 entries
[    0.122976] Serial: AMBA PL011 UART driver
[    0.140512] /vop@fe040000: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    0.140626] /hdmi@fe0a0000: Fixed dependency cycle(s) with /vop@fe040000
[    0.146258] /pcie@fe260000: Fixed dependency cycle(s) with /pcie@fe260000/legacy-interrupt-controller
[    0.166209] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.167112] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.167729] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.168156] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.168711] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.169113] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.169664] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.170108] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.170560] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.170971] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.175046] /pcie@fe280000: Fixed dependency cycle(s) with /pcie@fe280000/legacy-interrupt-controller
[    0.176987] /hdmi@fe0a0000: Fixed dependency cycle(s) with /hdmi-con
[    0.177096] /hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    0.183438] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.183462] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.183474] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.183482] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.183492] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.183500] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.183509] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.183516] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.185576] cryptd: max_cpu_qlen set to 1000
[    0.254305] raid6: neonx8   gen()  1408 MB/s
[    0.322527] raid6: neonx4   gen()  1437 MB/s
[    0.390738] raid6: neonx2   gen()  1322 MB/s
[    0.458974] raid6: neonx1   gen()  1074 MB/s
[    0.527171] raid6: int64x8  gen()   910 MB/s
[    0.595418] raid6: int64x4  gen()  1051 MB/s
[    0.663654] raid6: int64x2  gen()   939 MB/s
[    0.731847] raid6: int64x1  gen()   671 MB/s
[    0.731862] raid6: using algorithm neonx4 gen() 1437 MB/s
[    0.800013] raid6: .... xor() 1103 MB/s, rmw enabled
[    0.800027] raid6: using neon recovery algorithm
[    0.801570] iommu: Default domain type: Translated
[    0.801590] iommu: DMA domain TLB invalidation policy: strict mode
[    0.802682] SCSI subsystem initialized
[    0.803036] libata version 3.00 loaded.
[    0.803375] usbcore: registered new interface driver usbfs
[    0.803429] usbcore: registered new interface driver hub
[    0.803495] usbcore: registered new device driver usb
[    0.804278] pps_core: LinuxPPS API ver. 1 registered
[    0.804292] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.804330] PTP clock support registered
[    0.804395] EDAC MC: Ver: 3.0.0
[    0.804950] scmi_core: SCMI protocol bus registered
[    0.806691] NetLabel: Initializing
[    0.806707] NetLabel:  domain hash size = 128
[    0.806717] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.806819] NetLabel:  unlabeled traffic allowed by default
[    0.807132] vgaarb: loaded
[    0.807967] clocksource: Switched to clocksource arch_sys_counter
[    0.808858] VFS: Disk quotas dquot_6.6.0
[    0.808926] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.809806] AppArmor: AppArmor Filesystem Enabled
[    0.825866] NET: Registered PF_INET protocol family
[    0.826225] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.899303] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.899536] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.899664] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.900299] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.901226] TCP: Hash tables configured (established 32768 bind 32768)
[    0.901470] UDP hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.901670] UDP-Lite hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.902096] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.902150] NET: Registered PF_XDP protocol family
[    0.902176] PCI: CLS 0 bytes, default 64
[    0.902606] Trying to unpack rootfs image as initramfs...
[    0.908065] kvm [1]: nv: 566 coarse grained trap handlers
[    0.908754] kvm [1]: IPA Size Limit: 40 bits
[    0.908802] kvm [1]: GICv3: no GICV resource entry
[    0.908814] kvm [1]: disabling GICv2 emulation
[    0.908860] kvm [1]: GIC system register CPU interface enabled
[    0.908902] kvm [1]: vgic interrupt IRQ9
[    0.908962] kvm [1]: VHE mode initialized successfully
[    0.914681] Initialise system trusted keyrings
[    0.914769] Key type blacklist registered
[    0.915179] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    0.915257] zbud: loaded
[    0.916195] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.916929] fuse: init (API version 7.42)
[    0.919570] integrity: Platform Keyring initialized
[    0.992525] xor: measuring software checksum speed
[    0.994459]    8regs           :  1718 MB/sec
[    0.996599]    32regs          :  1547 MB/sec
[    0.998518]    arm64_neon      :  1726 MB/sec
[    0.998528] xor: using function: arm64_neon (1726 MB/sec)
[    0.998549] Key type asymmetric registered
[    0.998559] Asymmetric key parser 'x509' registered
[    0.998742] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.999209] io scheduler mq-deadline registered
[    0.999225] io scheduler kyber registered
[    0.999302] io scheduler bfq registered
[    2.503085] Freeing initrd memory: 26360K
[    2.515507] ledtrig-cpu: registered to indicate activity on CPUs
[    2.524738] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.524769] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.528071] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.528100] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.531307] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.536971] printk: legacy console [ttyS2] disabled
[    2.537495] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 25, base_baud = 1500000) is a 16550A
[    2.537773] printk: legacy console [ttyS2] enabled
[    2.539686] Serial: AMBA driver
[    2.553098] loop: module loaded
[    2.555126] Key type psk registered
[    2.561289] thunder_xcv, ver 1.0
[    2.561352] thunder_bgx, ver 1.0
[    2.561407] nicpf, ver 1.0
[    2.565675] usbcore: registered new interface driver usb-storage
[    2.568451] mousedev: PS/2 mouse device common for all mice
[    2.569156] i2c_dev: i2c /dev entries driver
[    2.571795] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    2.579441] sdhci: Secure Digital Host Controller Interface driver
[    2.579464] sdhci: Copyright(c) Pierre Ossman
[    2.579521] Synopsys Designware Multimedia Card Interface Driver
[    2.580777] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.581959] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[    2.582048] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[    2.582067] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[    2.582142] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo
[    2.582415] dwmmc_rockchip fe000000.mmc: Got CD GPIO
[    2.583615] arm-scmi arm-scmi.0.auto: Using scmi_smc_transport
[    2.583636] arm-scmi arm-scmi.0.auto: SCMI max-rx-timeout: 30ms / max-msg-size: 104bytes / max-msg: 20
[    2.583847] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16
[    2.584325] arm-scmi arm-scmi.0.auto: SCMI Notifications - Core Enabled.
[    2.584404] arm-scmi arm-scmi.0.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    2.586951] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    2.587329] hid: raw HID events driver (C) Jiri Kosina
[    2.587468] usbcore: registered new interface driver usbhid
[    2.587481] usbhid: USB HID core driver
[    2.589275] rockchip-dfi fe230000.dfi: dfi initialized, dram type: 0x7, channels: 1
[    2.591400] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available
[    2.593374] NET: Registered PF_INET6 protocol family
[    2.595294] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    2.635629] Segment Routing with IPv6
[    2.635747] In-situ OAM (IOAM) with IPv6
[    2.635893] NET: Registered PF_PACKET protocol family
[    2.636214] 8021q: 802.1Q VLAN Support v1.8
[    2.636325] Key type dns_resolver registered
[    2.649683] registered taskstats version 1
[    2.650181] Loading compiled-in X.509 certificates
[    2.652062] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[    2.669772] zswap: loaded using pool zstd/z3fold
[    2.670215] Demotion targets for Node 0: null
[    2.670450] Key type .fscrypt registered
[    2.670465] Key type fscrypt-provisioning registered
[    2.674157] Btrfs loaded, zoned=yes, fsverity=yes
[    2.674458] Key type encrypted registered
[    2.674482] AppArmor: AppArmor sha256 policy hashing enabled
[    2.828080] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    2.828169] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    2.828188] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    2.828258] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[    2.829001] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    2.839604] rockchip-dw-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[    2.839677] rockchip-dw-pcie 3c0000000.pcie:       IO 0x00f4100000..0x00f41fffff -> 0x00f4100000
[    2.839722] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x00f4200000..0x00f5ffffff -> 0x00f4200000
[    2.839748] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x0300000000..0x033fffffff -> 0x0040000000
[    2.840036] rockchip-dw-pcie 3c0000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G
[    2.844146] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    2.864634] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    2.932827] mmc0: new HS200 MMC card at address 0001
[    2.933948] mmcblk0: mmc0:0001 DV4032 29.1 GiB
[    2.939302]  mmcblk0: p1 p2
[    2.940516] mmcblk0boot0: mmc0:0001 DV4032 4.00 MiB
[    2.942837] mmcblk0boot1: mmc0:0001 DV4032 4.00 MiB
[    2.944748] rockchip-dw-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00
[    2.944786] pci_bus 0000:00: root bus resource [bus 00-0f]
[    2.944807] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff])
[    2.944822] pci_bus 0000:00: root bus resource [mem 0xf4200000-0xf5ffffff]
[    2.944838] pci_bus 0000:00: root bus resource [mem 0x300000000-0x33fffffff] (bus address [0x40000000-0x7fffffff])
[    2.944893] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400 PCIe Root Port
[    2.944933] pci 0000:00:00.0: ROM [mem 0x00000000-0x0000ffff pref]
[    2.944950] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.944968] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    2.944983] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    2.945003] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    2.945097] pci 0000:00:00.0: supports D1 D2
[    2.945112] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.945231] mmcblk0rpmb: mmc0:0001 DV4032 16.0 MiB, chardev (243:0)
[    2.954249] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[    2.954631] pci 0000:00:00.0: ROM [mem 0xf4200000-0xf420ffff pref]: assigned
[    2.954660] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.954687] pci_bus 0000:00: resource 4 [io  0x0000-0xfffff]
[    2.954702] pci_bus 0000:00: resource 5 [mem 0xf4200000-0xf5ffffff]
[    2.954716] pci_bus 0000:00: resource 6 [mem 0x300000000-0x33fffffff]
[    2.957759] pcieport 0000:00:00.0: PME: Signaling with IRQ 69
[    2.958315] pcieport 0000:00:00.0: AER: enabled with IRQ 69
[    2.968326] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
[    2.969815] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
[    2.969842] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
[    2.969868] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[    2.969904] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 1
[    2.970097] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010
[    2.970175] xhci-hcd xhci-hcd.7.auto: irq 70, io mem 0xfcc00000
[    2.970416] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[    2.970445] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 2
[    2.970470] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed
[    2.970834] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.970857] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.970870] usb usb1: Product: xHCI Host Controller
[    2.970885] usb usb1: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.970897] usb usb1: SerialNumber: xhci-hcd.7.auto
[    2.971762] hub 1-0:1.0: USB hub found
[    2.971830] hub 1-0:1.0: 1 port detected
[    2.972517] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.972765] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[    2.972786] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.972801] usb usb2: Product: xHCI Host Controller
[    2.972813] usb usb2: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.972825] usb usb2: SerialNumber: xhci-hcd.7.auto
[    2.973532] hub 2-0:1.0: USB hub found
[    2.973596] hub 2-0:1.0: 1 port detected
[    2.978794] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    2.978841] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 3
[    2.979059] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010
[    2.979146] xhci-hcd xhci-hcd.8.auto: irq 71, io mem 0xfd000000
[    2.979396] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    2.979425] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4
[    2.979448] xhci-hcd xhci-hcd.8.auto: Host supports USB 3.0 SuperSpeed
[    2.979770] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.979791] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.979807] usb usb3: Product: xHCI Host Controller
[    2.979819] usb usb3: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.979831] usb usb3: SerialNumber: xhci-hcd.8.auto
[    2.980658] hub 3-0:1.0: USB hub found
[    2.980738] hub 3-0:1.0: 1 port detected
[    2.981346] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.981591] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[    2.981612] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.981627] usb usb4: Product: xHCI Host Controller
[    2.981639] usb usb4: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.981652] usb usb4: SerialNumber: xhci-hcd.8.auto
[    2.982358] hub 4-0:1.0: USB hub found
[    2.982425] hub 4-0:1.0: 1 port detected
[    2.985390] WCN: marlin_init entry!
[    2.986029] of_cfs_init
[    2.986090] of_cfs_init: OK
[    2.986810] ehci-platform fd800000.usb: EHCI Host Controller
[    2.986856] ohci-platform fd840000.usb: Generic Platform OHCI controller
[    2.986865] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 5
[    2.986896] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 6
[    2.987086] ehci-platform fd800000.usb: irq 72, io mem 0xfd800000
[    2.987132] ohci-platform fd840000.usb: irq 74, io mem 0xfd840000
[    2.987210] ehci-platform fd880000.usb: EHCI Host Controller
[    2.987255] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[    2.987258] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 7
[    2.987298] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 8
[    2.987471] ehci-platform fd880000.usb: irq 73, io mem 0xfd880000
[    2.987504] ohci-platform fd8c0000.usb: irq 75, io mem 0xfd8c0000
[    2.996076] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[    2.996552] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.996583] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.996597] usb usb5: Product: EHCI Host Controller
[    2.996610] usb usb5: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ehci_hcd
[    2.996621] usb usb5: SerialNumber: fd800000.usb
[    2.997545] hub 5-0:1.0: USB hub found
[    2.997628] hub 5-0:1.0: 1 port detected
[    3.008045] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[    3.008505] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    3.008536] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.008550] usb usb7: Product: EHCI Host Controller
[    3.008562] usb usb7: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ehci_hcd
[    3.008574] usb usb7: SerialNumber: fd880000.usb
[    3.009506] hub 7-0:1.0: USB hub found
[    3.009588] hub 7-0:1.0: 1 port detected
[    3.044452] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[    3.044488] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.044503] usb usb6: Product: Generic Platform OHCI controller
[    3.044516] usb usb6: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ohci_hcd
[    3.044528] usb usb6: SerialNumber: fd840000.usb
[    3.045522] hub 6-0:1.0: USB hub found
[    3.045635] hub 6-0:1.0: 1 port detected
[    3.046605] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[    3.046641] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.046655] usb usb8: Product: Generic Platform OHCI controller
[    3.046668] usb usb8: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ohci_hcd
[    3.046679] usb usb8: SerialNumber: fd8c0000.usb
[    3.047706] hub 8-0:1.0: USB hub found
[    3.047796] hub 8-0:1.0: 1 port detected
[    3.082885] clk: Disabling unused clocks
[    3.085096] PM: genpd: Disabling unused power domains
[    3.089964] Freeing unused kernel memory: 5312K
[    3.090509] Run /init as init process
[    3.090523]   with arguments:
[    3.090533]     /init
[    3.090542]     splash
[    3.090553]   with environment:
[    3.090561]     HOME=/
[    3.090571]     TERM=linux
[    3.090579]     ubootpart=5e425cc6-0a96-1149-b209-be03a1570889
[    3.090588]     cgroup_enable=memory
[    3.090597]     cgroup_memory=1
[    3.244040] usb 5-1: new high-speed USB device number 2 using ehci-platform
[    3.391180] usb 5-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[    3.391216] usb 5-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.391231] usb 5-1: Product: USB2.0 Hub
[    3.395341] hub 5-1:1.0: USB hub found
[    3.400037] hub 5-1:1.0: 4 ports detected
[    3.872770] rockchip-vop2 fe040000.vop: Adding to iommu group 0
[    3.889293] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm])
[    3.895586] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    3.897286] rk808-rtc rk808-rtc.4.auto: registered as rtc0
[    3.898279] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.899125] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[    3.900561] rk808-rtc rk808-rtc.4.auto: setting system clock to 2017-08-05T09:00:08 UTC (1501923608)
[    3.901377] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0
[    3.951591] panfrost fde60000.gpu: clock rate = 594000000
[    3.951650] panfrost fde60000.gpu: bus_clock rate = 500000000
[    3.972247] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    3.972290] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    3.972306] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    3.972324] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    3.986079] [drm] Initialized panfrost 1.3.0 for fde60000.gpu on minor 1
[    3.990289] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    3.990324] rk_gmac-dwmac fe010000.ethernet: IRQ sfty not found
[    3.990645] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    3.990925] rk_gmac-dwmac fe010000.ethernet: clock input or output? (output).
[    3.990948] rk_gmac-dwmac fe010000.ethernet: Can not read property: tx_delay.
[    3.990960] rk_gmac-dwmac fe010000.ethernet: set tx_delay to 0x30
[    3.990975] rk_gmac-dwmac fe010000.ethernet: Can not read property: rx_delay.
[    3.990985] rk_gmac-dwmac fe010000.ethernet: set rx_delay to 0x10
[    3.991007] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    3.996236] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    3.997368] random: crng init done
[    4.000972] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    4.001015] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[    4.001042] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    4.001055] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    4.001066] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    4.001076] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    4.001374] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    4.001512] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.001531] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    4.001545] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    4.001558] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    4.068985] phy phy-fe8c0000.phy.6: lane number 0, val 1
[    4.069018] phy phy-fe8c0000.phy.6: lane number 1, val 2
[    4.069032] phy phy-fe8c0000.phy.6: bifurcation enabled
[    4.069550] phy phy-fe8c0000.phy.6: rockchip_p3phy_rk3568_init: lock failed 0x6890000, check input refclk and power supply
[    4.069572] phy phy-fe8c0000.phy.6: phy init failed --> -110
[    4.069722] rockchip-dw-pcie 3c0800000.pcie: probe with driver rockchip-dw-pcie failed with error -110
[    4.158740] rk_gmac-dwmac fe2a0000.ethernet: IRQ eth_lpi not found
[    4.158776] rk_gmac-dwmac fe2a0000.ethernet: IRQ sfty not found
[    4.160360] rk_gmac-dwmac fe2a0000.ethernet: supply phy not found, using dummy regulator
[    4.161247] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (output).
[    4.161272] rk_gmac-dwmac fe2a0000.ethernet: Can not read property: tx_delay.
[    4.161280] rk_gmac-dwmac fe2a0000.ethernet: set tx_delay to 0x30
[    4.161292] rk_gmac-dwmac fe2a0000.ethernet: Can not read property: rx_delay.
[    4.161299] rk_gmac-dwmac fe2a0000.ethernet: set rx_delay to 0x10
[    4.161321] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[    4.166409] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[    4.166917] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    4.166945] rk_gmac-dwmac fe2a0000.ethernet:     DWMAC4/5
[    4.166957] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[    4.166965] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[    4.166973] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[    4.166979] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[    4.167229] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[    4.167242] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.167254] rk_gmac-dwmac fe2a0000.ethernet: Enabled RFS Flow TC (entries=10)
[    4.167263] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[    4.167271] rk_gmac-dwmac fe2a0000.ethernet: Using 32/32 bits DMA host/device width
[    4.394779] Console: switching to colour frame buffer device 240x67
[    4.497462] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    6.122887] EXT4-fs (mmcblk0p2): mounted filesystem 94ea9275-a0cd-4974-b523-8269456a7d02 ro with writeback data mode. Quota mode: none.
[    6.601959] systemd[1]: System time before build time, advancing clock.
[    6.614440] systemd[1]: Inserted module 'autofs4'
[    6.652511] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    6.653670] systemd[1]: Detected architecture arm64.
[    6.656225] systemd[1]: Hostname set to <yy3568>.
[    6.798144] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[    6.882068] block mmcblk0: the capability attribute has been deprecated.
[    7.086269] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[    7.479445] systemd[1]: Queued start job for default target Graphical Interface.
[    7.516102] systemd[1]: Created slice Slice /system/modprobe.
[    7.519292] systemd[1]: Created slice Slice /system/serial-getty.
[    7.522085] systemd[1]: Created slice Slice /system/systemd-fsck.
[    7.524298] systemd[1]: Created slice User and Session Slice.
[    7.525036] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.526429] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.527158] systemd[1]: Reached target User and Group Name Lookups.
[    7.527515] systemd[1]: Reached target Slice Units.
[    7.527787] systemd[1]: Reached target Swaps.
[    7.528082] systemd[1]: Reached target System Time Set.
[    7.528523] systemd[1]: Reached target Local Verity Protected Volumes.
[    7.556504] systemd[1]: Listening on RPCbind Server Activation Socket.
[    7.557813] systemd[1]: Listening on Syslog Socket.
[    7.558820] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.559479] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.561152] systemd[1]: Listening on Journal Audit Socket.
[    7.562201] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.563389] systemd[1]: Listening on Journal Socket.
[    7.569136] systemd[1]: Listening on udev Control Socket.
[    7.570292] systemd[1]: Listening on udev Kernel Socket.
[    7.576678] systemd[1]: Mounting Huge Pages File System...
[    7.583721] systemd[1]: Mounting POSIX Message Queue File System...
[    7.591006] systemd[1]: Mounting Kernel Debug File System...
[    7.598147] systemd[1]: Mounting Kernel Trace File System...
[    7.599433] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    7.607539] systemd[1]: Starting Restore / save the current clock...
[    7.614977] systemd[1]: Starting Set the console keyboard layout...
[    7.623286] systemd[1]: Starting Create List of Static Device Nodes...
[    7.632114] systemd[1]: Starting Load Kernel Module configfs...
[    7.642255] systemd[1]: Starting Load Kernel Module drm...
[    7.652233] systemd[1]: Starting Load Kernel Module efi_pstore...
[    7.660816] systemd[1]: Starting Load Kernel Module fuse...
[    7.662253] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.680145] systemd[1]: Starting Load Kernel Modules...
[    7.688200] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.697748] systemd[1]: Starting Coldplug All udev Devices...
[    7.715837] systemd[1]: Mounted Huge Pages File System.
[    7.718912] systemd[1]: Mounted POSIX Message Queue File System.
[    7.721879] systemd[1]: Mounted Kernel Debug File System.
[    7.725117] systemd[1]: Mounted Kernel Trace File System.
[    7.731943] systemd[1]: Finished Restore / save the current clock.
[    7.737641] systemd[1]: Finished Create List of Static Device Nodes.
[    7.740230] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    7.743768] systemd[1]: Finished Load Kernel Module configfs.
[    7.746699] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    7.749293] systemd[1]: Finished Load Kernel Module drm.
[    7.751816] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    7.755217] systemd[1]: Finished Load Kernel Module efi_pstore.
[    7.758200] EXT4-fs (mmcblk0p2): re-mounted 94ea9275-a0cd-4974-b523-8269456a7d02 r/w. Quota mode: none.
[    7.758326] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    7.760645] systemd[1]: Finished Load Kernel Module fuse.
[    7.769465] systemd[1]: Finished Load Kernel Modules.
[    7.773278] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.808579] systemd[1]: Mounting FUSE Control File System...
[    7.816616] systemd[1]: Mounting Kernel Configuration File System...
[    7.817654] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    7.824909] systemd[1]: Starting Load/Save Random Seed...
[    7.833622] systemd[1]: Starting Apply Kernel Variables...
[    7.842671] systemd[1]: Starting Create System Users...
[    7.862287] systemd[1]: Mounted FUSE Control File System.
[    7.867440] systemd[1]: Mounted Kernel Configuration File System.
[    7.912475] systemd[1]: Finished Load/Save Random Seed.
[    7.914631] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[    7.918213] systemd[1]: Finished Create System Users.
[    7.952967] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.963879] systemd[1]: Finished Apply Kernel Variables.
[    8.012967] systemd[1]: Finished Create Static Device Nodes in /dev.
[    8.038624] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    8.042826] systemd[1]: Finished Set the console keyboard layout.
[    8.044248] systemd[1]: Reached target Preparation for Local File Systems.
[    8.051668] systemd[1]: Mounting /tmp...
[    8.067002] systemd[1]: Mounted /tmp.
[    8.328925] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    8.464794] systemd[1]: Finished Coldplug All udev Devices.
[    8.489040] systemd[1]: Starting Show Plymouth Boot Screen...
[    8.555337] systemd[1]: Started Show Plymouth Boot Screen.
[    8.559804] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[    8.561216] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[    8.561631] systemd[1]: Reached target Local Encrypted Volumes.
[    8.910780] mc: Linux media interface: v0.10
[    9.010305] videodev: Linux video capture interface: v2.00
[    9.038717] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey.3.auto/input/input0
[    9.116877] rockchip_vdec2: module is from the staging directory, the quality is unknown, you have been warned.
[    9.120091] rk2-crypto fe380000.crypto: will run requests pump with realtime priority
[    9.120171] rk2-crypto fe380000.crypto: Registers crypto algos
[    9.120179] rk2-crypto fe380000.crypto: Register ecb(aes) as ecb-aes-rk2
[    9.120232] rk2-crypto fe380000.crypto: Register cbc(aes) as cbc-aes-rk2
[    9.120248] rk2-crypto fe380000.crypto: Register xts(aes) as xts-aes-rk2
[    9.120261] rk2-crypto fe380000.crypto: Register md5 as rk2-md5 3
[    9.120276] rk2-crypto fe380000.crypto: Register sha1 as rk2-sha1 4
[    9.120291] rk2-crypto fe380000.crypto: Register sha256 as rk2-sha256 5
[    9.120306] rk2-crypto fe380000.crypto: Register sha384 as rk2-sha384 6
[    9.120319] rk2-crypto fe380000.crypto: Register sha512 as rk2-sha512 7
[    9.120333] rk2-crypto fe380000.crypto: Register sm3 as rk2-sm3 8
[    9.122514] rockchip-rga fdeb0000.rga: HW Version: 0x03.02
[    9.165687] rockchip-rga fdeb0000.rga: Registered rockchip-rga as /dev/video0
[    9.188101] hantro-vpu fdea0000.video-codec: Adding to iommu group 1
[    9.216117] systemd[1]: Found device /dev/disk/by-uuid/4271-D3A2.
[    9.232905] hantro-vpu fdea0000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2
[    9.236847] hantro-vpu fdee0000.video-codec: Adding to iommu group 2
[    9.256727] OF: /rk809-sound/simple-audio-card,codec: could not get #sound-dai-cells for /i2c@fdd40000/pmic@20
[    9.256765] asoc-simple-card rk809-sound: error -EINVAL: parse error
[    9.256775] asoc-simple-card rk809-sound: probe with driver asoc-simple-card failed with error -22
[    9.256848] systemd[1]: Starting File System Check on /dev/disk/by-uuid/4271-D3A2...
[    9.262745] systemd[1]: Found device /dev/ttyS2.
[    9.264444] hantro-vpu fdee0000.video-codec: registered rockchip,rk3568-vepu-enc as /dev/video3
[    9.286846] systemd[1]: Started File System Check Daemon to report status.
[    9.359011] systemd[1]: Finished File System Check on /dev/disk/by-uuid/4271-D3A2.
[    9.381420] systemd[1]: Mounting /boot...
[    9.415422] systemd[1]: Mounted /boot.
[    9.416898] systemd[1]: Reached target Local File Systems.
[    9.421770] systemd[1]: Starting Armbian ZRAM config...
[    9.428901] systemd[1]: Starting Set console font and keymap...
[    9.439940] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.442453] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[    9.454891] systemd[1]: Starting Set Up Additional Binary Formats...
[    9.455248] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    9.455526] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.462000] systemd[1]: Finished Set console font and keymap.
[    9.466643] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.468923] systemd[1]: Received SIGRTMIN+20 from PID 181 (plymouthd).
[    9.479836] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 337 (systemd-binfmt)
[    9.485212] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[    9.514830] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[    9.526889] systemd[1]: Finished Set Up Additional Binary Formats.
[    9.659684] zram: Added device: zram0
[    9.660618] zram: Added device: zram1
[    9.663734] zram: Added device: zram2
[    9.728528] zram0: detected capacity change from 0 to 4012944
[    9.746979] Adding 2006468k swap on /dev/zram0.  Priority:5 extents:1 across:2006468k SS
[    9.790109] zram1: detected capacity change from 0 to 102400
[    9.826419] systemd[1]: Finished Armbian ZRAM config.
[    9.865763] systemd[1]: Starting Armbian memory supported logging...
[    9.926542] EXT4-fs (zram1): mounted filesystem 3ccbfa22-0697-469d-86f0-199ab9e91036 r/w without journal. Quota mode: none.
[   10.412107] systemd[1]: Finished Armbian memory supported logging.
[   10.438010] systemd[1]: Starting Journal Service...
[   10.608629] systemd[1]: Started Journal Service.
[   10.662120] systemd-journald[466]: Received client request to flush runtime journal.
[   10.785735] RPC: Registered named UNIX socket transport module.
[   10.785760] RPC: Registered udp transport module.
[   10.785765] RPC: Registered tcp transport module.
[   10.785768] RPC: Registered tcp-with-tls transport module.
[   10.785772] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   12.840069] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   12.928586] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   12.940124] dwmac4: Master AXI performs any burst length
[   12.940159] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   12.940187] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   12.940556] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   12.940964] rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rgmii link mode
[   13.001059] rk_gmac-dwmac fe2a0000.ethernet eth1: Register MEM_TYPE_PAGE_POOL RxQ-0
[   13.088098] rk_gmac-dwmac fe2a0000.ethernet eth1: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   13.101133] dwmac4: Master AXI performs any burst length
[   13.101172] rk_gmac-dwmac fe2a0000.ethernet eth1: No Safety Features support found
[   13.101210] rk_gmac-dwmac fe2a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[   13.106147] rk_gmac-dwmac fe2a0000.ethernet eth1: registered PTP clock
[   13.107519] rk_gmac-dwmac fe2a0000.ethernet eth1: configuring for phy/rgmii link mode
[   17.070468] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   19.432764] platform hdmi-sound: deferred probe pending: asoc-simple-card: parse error
[   23.788138] usb 3-1: new full-speed USB device number 2 using xhci-hcd
[   23.932924] usb 3-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   23.932946] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   23.932953] usb 3-1: Product: USB2.0 HUB
[   24.100129] hub 3-1:1.0: USB hub found
[   24.100267] hub 3-1:1.0: 4 ports detected
[   24.480042] usb 3-1.1: new low-speed USB device number 3 using xhci-hcd
[   24.579770] usb 3-1.1: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[   24.579792] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   24.579798] usb 3-1.1: Product: Lenovo Traditional USB Keyboard
[   24.579804] usb 3-1.1: Manufacturer: Lenovo
[   24.745674] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/fd000000.usb/xhci-hcd.8.auto/usb3/3-1/3-1.1/3-1.1:1.0/0003:17EF:6099.0001/input/input1
[   24.856489] hid-generic 0003:17EF:6099.0001: input,hidraw0: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.8.auto-1.1/input0
[   24.928048] usb 3-1.2: new low-speed USB device number 4 using xhci-hcd
[   25.023913] usb 3-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[   25.023936] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   25.023943] usb 3-1.2: Product: Lenovo USB Optical Mouse
[   25.023995] usb 3-1.2: Manufacturer: PixArt
[   25.254467] input: PixArt Lenovo USB Optical Mouse as /devices/platform/fd000000.usb/xhci-hcd.8.auto/usb3/3-1/3-1.2/3-1.2:1.0/0003:17EF:608D.0002/input/input2
[   25.256550] hid-generic 0003:17EF:608D.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.8.auto-1.2/input0
[   29.293424] usb 3-1.4: new full-speed USB device number 5 using xhci-hcd
[   29.386437] usb 3-1.4: not running at top speed; connect to a high speed hub
[   29.389647] usb 3-1.4: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.00
[   29.389697] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   29.389726] usb 3-1.4: Product: DataTraveler 3.0
[   29.389749] usb 3-1.4: Manufacturer: Kingston
[   29.389771] usb 3-1.4: SerialNumber: 60A44C3FAC2DBDA0A98A2DE8
[   29.392638] usb-storage 3-1.4:1.0: USB Mass Storage device detected
[   29.398455] scsi host0: usb-storage 3-1.4:1.0
[   29.446242] usbcore: registered new interface driver uas
[   30.411461] scsi 0:0:0:0: Direct-Access     Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[   30.572143] sd 0:0:0:0: [sda] 15360000 512-byte logical blocks: (7.86 GB/7.32 GiB)
[   30.574628] sd 0:0:0:0: [sda] Write Protect is off
[   30.574644] sd 0:0:0:0: [sda] Mode Sense: 2b 80 00 08
[   30.576603] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   30.647165]  sda: sda1 sda2
[   30.647606] sd 0:0:0:0: [sda] Attached SCSI removable disk
[   30.654983] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   33.770013] vdd_npu: disabling
[   35.663374] ntfs3: Enabled Linux POSIX ACLs support
[   35.663396] ntfs3: Read-only LZX/Xpress compression included
[   35.685675] ntfs3(sda1): It is recommened to use chkdsk.
[   35.694214] FAT-fs (sda2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   49.444758] ntfs3(sda1): volume is dirty and "force" flag is not set!
Edited by Hqnicolas
Posted (edited)
Download RKDevTool and also download this small file wipe_part. We will be using that shortly.
Download the Clear_EMMC_YY3568
Unzip RKDevTool and run RKDevTool.exe
Set the Config for RKDevTool "RkDevToolConfig.cfg" that was inside " Clear_EMMC_YY3568"
Flash the U-boot, parameter.txt and MiniloaderAll from "Clear_EMMC_YY3568"
Your Board will restart.
Destroy All the partitions overrided by file wipe_part.
Flash this MiniLoaderAll.bin
it now boots from SD-Card
Edited by Hqnicolas
Posted (edited)
On 2/13/2025 at 9:44 PM, Hqnicolas said:
none of the images I created worked,
despite seeing the status post
https://github.com/armbian/linux-rockchip/releases/tag/v24.8.0-trunk.147
 it seems there was a cut in the manufacturer's information and the project didn't move forward
https://github.com/armbian/linux-rockchip/pull/99
Since the Vendor Kernel don't work, I'm doing It from scratch:
https://github.com/armbian/linux-rockchip/pull/341
so far?
dmsg:
Quote
[   10.521638] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[   10.521682] Linux version 6.1.99-vendor-rk35xx (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Mar  6 03:10:34 UTC 2025
[   10.528880] Machine model: Youyeetoo YY3568
[   10.529129] efi: UEFI not found.
[   10.529402] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB
[   10.529430] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB
[   10.529574] Reserved memory: created CMA memory pool at 0x00000000d0000000, size 512 MiB
[   10.529584] OF: reserved mem: initialized node rknpu, compatible id shared-dma-pool
[   10.654275] Zone ranges:
[   10.654290]   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[   10.654307]   DMA32    empty
[   10.654314]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[   10.654324] Movable zone start for each node
[   10.654328] Early memory node ranges
[   10.654331]   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[   10.654344]   node   0: [mem 0x00000001f0000000-0x00000001ffffffff]
[   10.654354] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[   10.684458] On node 0, zone DMA: 512 pages in unavailable ranges
[   10.686593] cma: Reserved 256 MiB at 0x00000000c0000000
[   10.686739] psci: probing for conduit method from DT.
[   10.686754] psci: PSCIv1.1 detected in firmware.
[   10.686764] psci: Using standard PSCI v0.2 function IDs
[   10.686772] psci: MIGRATE_INFO_TYPE not supported.
[   10.686788] psci: SMC Calling Convention v1.2
[   10.687258] percpu: Embedded 30 pages/cpu s82728 r8192 d31960 u122880
[   10.687310] pcpu-alloc: s82728 r8192 d31960 u122880 alloc=30*4096
[   10.687327] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[   10.687465] Detected VIPT I-cache on CPU0
[   10.687546] CPU features: detected: GIC system register CPU interface
[   10.687553] CPU features: detected: Virtualization Host Extensions
[   10.687575] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[   10.687582] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[   10.687590] alternatives: applying boot alternatives
[   10.688373] Built 1 zonelists, mobility grouping on.  Total pages: 1031688
[   10.688396] Kernel command line: root=UUID=eaf13fe3-9baf-4448-9822-797e05b82fee rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=56a0f540-524e-4f8b-8bb2-dadfd100fc0c usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cma=256M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=ddr-v1.21-2d653b3476,bl31-v1.44,uboot-rmbian-201-03/06/2025
[   10.689360] Unknown kernel command line parameters "splash ubootpart=56a0f540-524e-4f8b-8bb2-dadfd100fc0c cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[   10.690700] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[   10.691364] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[   10.691379] mem auto-init: stack:off, heap alloc:off, heap free:off
[   10.691389] software IO TLB: area num 4.
[   10.733828] software IO TLB: mapped [mem 0x00000000bc000000-0x00000000c0000000] (64MB)
[   10.797191] Memory: 3193812K/4192256K available (18944K kernel code, 3960K rwdata, 16056K rodata, 8320K init, 703K bss, 212012K reserved, 786432K cma-reserved)
[   10.797437] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[   10.797502] ftrace: allocating 71631 entries in 280 pages
[   10.990625] ftrace: allocated 280 pages with 3 groups
[   10.990861] trace event string verifier disabled
[   10.991210] rcu: Hierarchical RCU implementation.
[   10.991218] rcu:     RCU event tracing is enabled.
[   10.991222] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[   10.991232]     Rude variant of Tasks RCU enabled.
[   10.991236]     Tracing variant of Tasks RCU enabled.
[   10.991240] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[   10.991247] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[   11.020872] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[   11.023926] GICv3: GIC: Using split EOI/Deactivate mode
[   11.023941] GICv3: 320 SPIs implemented
[   11.023949] GICv3: 0 Extended SPIs implemented
[   11.024007] Root IRQ handler: gic_handle_irq
[   11.024031] GICv3: GICv3 features: 16 PPIs
[   11.024077] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[   11.024872] ITS [mem 0xfd440000-0xfd45ffff]
[   11.024984] ITS@0x00000000fd440000: allocated 8192 Devices @3410000 (indirect, esz 8, psz 64K, shr 0)
[   11.025048] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @3420000 (flat, esz 2, psz 64K, shr 0)
[   11.025070] ITS: using cache flushing for cmd queue
[   11.025649] GICv3: using LPI property table @0x0000000003430000
[   11.025819] GIC: using cache flushing for LPI property table
[   11.025828] GICv3: CPU0: using allocated LPI pending table @0x0000000003440000
[   11.025941] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[   11.077071] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[   11.077103] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[   11.077119] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[   11.079143] Console: colour dummy device 80x25
[   11.079230] printk: console [tty1] enabled
[   11.079292] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[   11.079313] pid_max: default: 32768 minimum: 301
[   11.079441] LSM: Security Framework initializing
[   11.079595] AppArmor: AppArmor initialized
[   11.079811] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[   11.079850] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[   11.081431] cacheinfo: Unable to detect cache hierarchy for CPU 0
[   11.083137] cblist_init_generic: Setting adjustable number of callback queues.
[   11.083152] cblist_init_generic: Setting shift to 2 and lim to 1.
[   11.083371] cblist_init_generic: Setting adjustable number of callback queues.
[   11.083384] cblist_init_generic: Setting shift to 2 and lim to 1.
[   11.083826] rcu: Hierarchical SRCU implementation.
[   11.083837] rcu:     Max phase no-delay instances is 1000.
[   11.086047] Platform MSI: interrupt-controller@fd440000 domain created
[   11.086813] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[   11.087375] EFI services will not be available.
[   11.088109] smp: Bringing up secondary CPUs ...
[   11.089377] Detected VIPT I-cache on CPU1
[   11.089501] cacheinfo: Unable to detect cache hierarchy for CPU 1
[   11.089522] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[   11.089554] GICv3: CPU1: using allocated LPI pending table @0x0000000003450000
[   11.089623] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[   11.091148] Detected VIPT I-cache on CPU2
[   11.091262] cacheinfo: Unable to detect cache hierarchy for CPU 2
[   11.091283] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[   11.091311] GICv3: CPU2: using allocated LPI pending table @0x0000000003460000
[   11.091370] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[   11.092727] Detected VIPT I-cache on CPU3
[   11.092841] cacheinfo: Unable to detect cache hierarchy for CPU 3
[   11.092861] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[   11.092889] GICv3: CPU3: using allocated LPI pending table @0x0000000003470000
[   11.092943] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[   11.093137] smp: Brought up 1 node, 4 CPUs
[   11.093168] SMP: Total of 4 processors activated.
[   11.093179] CPU features: detected: 32-bit EL0 Support
[   11.093186] CPU features: detected: 32-bit EL1 Support
[   11.093196] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[   11.093205] CPU features: detected: Common not Private translations
[   11.093212] CPU features: detected: CRC32 instructions
[   11.093223] CPU features: detected: RCpc load-acquire (LDAPR)
[   11.093231] CPU features: detected: LSE atomic instructions
[   11.093238] CPU features: detected: Privileged Access Never
[   11.093244] CPU features: detected: RAS Extension Support
[   11.093254] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[   11.093390] CPU: All CPU(s) started at EL2
[   11.093440] alternatives: applying system-wide alternatives
[   11.099392] devtmpfs: initialized
[   11.143045] Registered cp15_barrier emulation handler
[   11.143079] Registered setend emulation handler
[   11.143394] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[   11.143431] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[   11.167572] pinctrl core: initialized pinctrl subsystem
[   11.168193] regulator-dummy: no parameters, enabled
[   11.168736] DMI not present or invalid.
[   11.169757] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[   11.172291] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[   11.172814] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[   11.173177] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[   11.173266] audit: initializing netlink subsys (disabled)
[   11.173595] audit: type=2000 audit(0.093:1): state=initialized audit_enabled=0 res=1
[   11.178400] Registered FIQ tty driver
[   11.179189] thermal_sys: Registered thermal governor 'fair_share'
[   11.179203] thermal_sys: Registered thermal governor 'step_wise'
[   11.179212] thermal_sys: Registered thermal governor 'user_space'
[   11.179220] thermal_sys: Registered thermal governor 'power_allocator'
[   11.179354] cpuidle: using governor menu
[   11.180312] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   11.180595] ASID allocator initialised with 65536 entries
[   11.185107] ramoops: dmesg-0    0x20000@0x0000000000110000
[   11.185164] ramoops: console    0x80000@0x0000000000130000
[   11.185205] ramoops: pmsg    0x50000@0x00000000001b0000
[   11.185486] printk: console [ramoops-1] enabled
[   11.185500] pstore: Registered ramoops as persistent store backend
[   11.185509] ramoops: using 0xf0000@0x110000, ecc: 0
[   11.216635] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[   11.216780] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000
[   11.252063] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[   11.253187] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[   11.254196] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[   11.255108] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[   11.255992] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[   11.256252] rockchip-pinctrl pinctrl: probed pinctrl
[   11.268479] KASLR disabled due to lack of seed
[   11.293348] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[   11.293373] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[   11.293387] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[   11.293396] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[   11.293406] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[   11.293415] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[   11.293426] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[   11.293434] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[   11.350055] raid6: neonx8   gen()  1371 MB/s
[   11.406967] raid6: neonx4   gen()  1413 MB/s
[   11.463857] raid6: neonx2   gen()  1288 MB/s
[   11.520763] raid6: neonx1   gen()  1052 MB/s
[   11.577700] raid6: int64x8  gen()   349 MB/s
[   11.634549] raid6: int64x4  gen()   440 MB/s
[   11.691450] raid6: int64x2  gen()   912 MB/s
[   11.748422] raid6: int64x1  gen()   634 MB/s
[   11.748438] raid6: using algorithm neonx4 gen() 1413 MB/s
[   11.805208] raid6: .... xor() 1069 MB/s, rmw enabled
[   11.805223] raid6: using neon recovery algorithm
[   11.807374] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found
[   11.807406] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found
[   11.807429] fiq_debugger_probe: could not install nmi irq handler
[   11.807855] printk: console [ttyFIQ0] enabled
[   11.808221] Registered fiq debugger ttyFIQ0
[   11.809104] vcc5v0_sys: 5000 mV, enabled
[   11.809426] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[   11.809682] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[   11.809711] vcc3v3_sys: supplied by vcc5v0_sys
[   11.809730] vcc5v0_sys: could not add device link regulator.2: -ENOENT
[   11.809805] vcc3v3_sys: 3300 mV, enabled
[   11.810113] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[   11.810609] vcc5v0_host: no parameters, enabled
[   11.810891] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[   11.811317] vcc5v0_otg: no parameters, enabled
[   11.811626] reg-fixed-voltage vcc5v0-otg-regulator: vcc5v0_otg supplying 0uV
[   11.812205] vcc3v3_minipcie: no parameters, enabled
[   11.812479] reg-fixed-voltage vcc3v3-minipcie: vcc3v3_minipcie supplying 0uV
[   11.812911] vcc3v3_minipcie_to_5g_or_wifi: no parameters, enabled
[   11.813220] reg-fixed-voltage vcc3v3-minipcie-to-5g-or-wifi: vcc3v3_minipcie_to_5g_or_wifi supplying 0uV
[   11.813607] vcc3v3_pci_30x1: no parameters, enabled
[   11.813914] reg-fixed-voltage vcc3v3-pci-30x1: vcc3v3_pci_30x1 supplying 0uV
[   11.814516] gpio-regulator pcie30-3v3: No 'states' property found
[   11.814533] gpio-regulator: probe of pcie30-3v3 failed with error -22
[   11.815210] iommu: Default domain type: Translated
[   11.815227] iommu: DMA domain TLB invalidation policy: strict mode
[   11.815899] SCSI subsystem initialized
[   11.815975] libata version 3.00 loaded.
[   11.816294] usbcore: registered new interface driver usbfs
[   11.816378] usbcore: registered new interface driver hub
[   11.816448] usbcore: registered new device driver usb
[   11.816711] mc: Linux media interface: v0.10
[   11.816805] videodev: Linux video capture interface: v2.00
[   11.817033] pps_core: LinuxPPS API ver. 1 registered
[   11.817048] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[   11.817082] PTP clock support registered
[   11.818059] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[   11.818282] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[   11.818364] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[   11.820142] Advanced Linux Sound Architecture Driver Initialized.
[   11.821221] Bluetooth: Core ver 2.22
[   11.821290] NET: Registered PF_BLUETOOTH protocol family
[   11.821304] Bluetooth: HCI device and connection manager initialized
[   11.821324] Bluetooth: HCI socket layer initialized
[   11.821339] Bluetooth: L2CAP socket layer initialized
[   11.821370] Bluetooth: SCO socket layer initialized
[   11.821502] NetLabel: Initializing
[   11.821512] NetLabel:  domain hash size = 128
[   11.821523] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[   11.821640] NetLabel:  unlabeled traffic allowed by default
[   11.822286] vgaarb: loaded
[   11.827980] clocksource: Switched to clocksource arch_sys_counter
[   11.828880] VFS: Disk quotas dquot_6.6.0
[   11.828969] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   11.829894] AppArmor: AppArmor Filesystem Enabled
[   11.849815] NET: Registered PF_INET protocol family
[   11.850202] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[   11.855496] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[   11.855575] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[   11.855697] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[   11.855982] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[   11.856940] TCP: Hash tables configured (established 32768 bind 32768)
[   11.857303] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[   11.857461] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   11.857557] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   11.857909] NET: Registered PF_UNIX/PF_LOCAL protocol family
[   11.858826] RPC: Registered named UNIX socket transport module.
[   11.858845] RPC: Registered udp transport module.
[   11.858855] RPC: Registered tcp transport module.
[   11.858864] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   11.860548] PCI: CLS 0 bytes, default 64
[   11.861629] Trying to unpack rootfs image as initramfs...
[   11.885452] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[   11.887054] kvm [1]: IPA Size Limit: 40 bits
[   11.887103] kvm [1]: GICv3: no GICV resource entry
[   11.887115] kvm [1]: disabling GICv2 emulation
[   11.887125] kvm [1]: GIC system register CPU interface enabled
[   11.894783] kvm [1]: vgic interrupt IRQ9
[   11.904064] kvm [1]: VHE mode initialized successfully
[   12.595051] Initialise system trusted keyrings
[   12.595519] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[   12.604856] zbud: loaded
[   12.608404] NFS: Registering the id_resolver key type
[   12.608480] Key type id_resolver registered
[   12.608492] Key type id_legacy registered
[   12.608641] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[   12.608658] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[   12.663981] NET: Registered PF_ALG protocol family
[   12.664024] xor: measuring software checksum speed
[   12.670390]    8regs           :  1565 MB/sec
[   12.675603]    32regs          :  1911 MB/sec
[   12.681715]    arm64_neon      :  1624 MB/sec
[   12.681738] xor: using function: 32regs (1911 MB/sec)
[   12.681775] Key type asymmetric registered
[   12.681788] Asymmetric key parser 'x509' registered
[   12.681925] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
[   12.682339] io scheduler mq-deadline registered
[   12.682358] io scheduler kyber registered
[   12.689888] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[   12.689939] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.0: -ENOENT
[   12.690310] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[   12.690334] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply property in node /usb2-phy@fe8a0000/otg-port failed
[   12.690496] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[   12.693532] phy phy-fe8b0000.usb2-phy.2: Looking up phy-supply from device tree
[   12.693584] vcc5v0_host: could not add device link phy-fe8b0000.usb2-phy.2: -ENOENT
[   12.693901] phy phy-fe8b0000.usb2-phy.3: Looking up phy-supply from device tree
[   12.693933] vcc5v0_host: could not add device link phy-fe8b0000.usb2-phy.3: -ENOENT
[   12.694214] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply from device tree
[   12.694237] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply property in node /usb2-phy@fe8b0000/otg-port failed
[   12.699238] phy phy-fe830000.phy.4: Looking up phy-supply from device tree
[   12.699274] phy phy-fe830000.phy.4: Looking up phy-supply property in node /phy@fe830000 failed
[   12.700064] phy phy-fe840000.phy.5: Looking up phy-supply from device tree
[   12.700089] phy phy-fe840000.phy.5: Looking up phy-supply property in node /phy@fe840000 failed
[   12.701141] phy phy-fe820000.phy.6: Looking up phy-supply from device tree
[   12.701169] phy phy-fe820000.phy.6: Looking up phy-supply property in node /phy@fe820000 failed
[   12.707495] iep: Module initialized.
[   12.707640] mpp_service mpp-srv: 53c0acb01bce author: Tao Huang 2024-12-09 video: rockchip: mpp: Fix typos in Rockchip copyright notices
[   12.707661] mpp_service mpp-srv: probe start
[   12.715650] mpp_service mpp-srv: probe success
[   12.724671] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[   12.724708] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[   12.728744] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[   12.728779] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[   12.729501] rockchip-pvtm fde00000.pvtm: failed to retrieve pvtm_tz
[   12.729578] rockchip-pvtm fde00000.pvtm: pvtm@0 probed
[   12.729804] rockchip-pvtm fde80000.pvtm: failed to retrieve pvtm_tz
[   12.729894] rockchip-pvtm fde80000.pvtm: pvtm@1 probed
[   12.730071] rockchip-pvtm fde90000.pvtm: failed to retrieve pvtm_tz
[   12.730141] rockchip-pvtm fde90000.pvtm: pvtm@2 probed
[   12.731740] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[   12.733338] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[   12.733840] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[   12.735468] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 32, base_baud = 1500000) is a 16550A
[   12.737214] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 33, base_baud = 1500000) is a 16550A
[   12.738783] fe6d0000.serial: ttyS9 at MMIO 0xfe6d0000 (irq = 34, base_baud = 1500000) is a 16550A
[   12.743121] led_vk2c21_init
[   12.743343] random: crng init done
[   12.744162] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply from device tree
[   12.744200] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply property in node /power-management@fdd90000/power-controller failed
[   12.746311] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply from device tree
[   12.746356] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply property in node /power-management@fdd90000/power-controller failed
[   12.747392] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply from device tree
[   12.747431] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply property in node /power-management@fdd90000/power-controller failed
[   12.750804] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply from device tree
[   12.750850] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[   12.752029] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply from device tree
[   12.752073] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[   12.753134] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply from device tree
[   12.753174] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply property in node /power-management@fdd90000/power-controller failed
[   12.756699] rockchip-vop2 fe040000.vop: Adding to iommu group 8
[   12.773494] [drm] all windows should be assigned, full plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], current plane mask: [0x0
[   12.773525] [drm] use default plane mask
[   12.773599] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], primary plane phy id: Smart0[4]
[   12.773643] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: [0x0], primary plane phy id: INVALID[-1]
[   12.773672] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: [0x0], primary plane phy id: INVALID[-1]
[   12.774208] [drm] failed to init overlay plane Cluster0-win1
[   12.774316] [drm] failed to init overlay plane Cluster1-win1
[   12.774539] rockchip-vop2 fe040000.vop: bin=0
[   12.774705] rockchip-vop2 fe040000.vop: Failed to get leakage
[   12.774794] rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[   12.774832] rockchip-vop2 fe040000.vop: Looking up vop-supply property in node /vop@fe040000 failed
[   12.774878] rockchip-vop2 fe040000.vop: Failed to get reg
[   12.774958] rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[   12.774997] rockchip-vop2 fe040000.vop: Looking up vop-supply property in node /vop@fe040000 failed
[   12.775028] rockchip-vop2 fe040000.vop: error -ENODEV: _opp_set_regulators: no regulator (vop) found
[   12.775087] rockchip-vop2 fe040000.vop: failed to set opp config
[   12.775103] rockchip-vop2 fe040000.vop: failed to init opp info
[   12.775117] rockchip-vop2 fe040000.vop: Unsupported VOP aclk dvfs
[   12.775138] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff8000093de7c0)
[   12.775350] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply from device tree
[   12.775377] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply property in node /hdmi@fe0a0000 failed
[   12.775411] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply from device tree
[   12.775432] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply property in node /hdmi@fe0a0000 failed
[   12.775710] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[   12.776867] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[   12.777231] dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found
[   12.777939] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000093f7058)
[   12.779868] [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0
[   12.779945] rockchip-drm display-subsystem: failed to parse loader memory
[   12.857605] Freeing initrd memory: 16108K
[   12.966845] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 3840x2160p60, type: 11(if:HDMI0, flag:0x0) for vp0 dclk: 594000000
[   12.967267] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 594000000, get 594000000
[   13.200739] Console: switching to colour frame buffer device 480x135
[   13.282346] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[   13.282864] rockchip-drm display-subsystem: [drm] run display error_event monitor
[   13.286451] Registered IR keymap rc-cec
[   13.286669] rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0
[   13.286965] input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0
[   13.287506] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input1
[   13.289242] cacheinfo: Unable to detect cache hierarchy for CPU 0
[   13.290856] brd: module loaded
[   13.300306] loop: module loaded
[   13.301065] rbd: loaded (major 254)
[   13.301717] lkdtm: No crash points registered, enable through debugfs
[   13.313037] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[   13.313389] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[   13.313421] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[   13.313466] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[   13.313706] rk_gmac-dwmac fe010000.ethernet: clock input or output? (output).
[   13.313727] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[   13.313743] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26).
[   13.313779] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[   13.314114] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[   13.314512] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[   13.314539] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[   13.314555] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[   13.314567] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[   13.314579] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[   13.314591] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[   13.314744] rk_gmac-dwmac fe010000.ethernet: TSO supported
[   13.314761] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   13.314777] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[   13.314808] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[   13.314823] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[   13.471034] rk_gmac-dwmac fe2a0000.ethernet: IRQ eth_lpi not found
[   13.471875] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply from device tree
[   13.471912] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply property in node /ethernet@fe2a0000 failed
[   13.471955] rk_gmac-dwmac fe2a0000.ethernet: supply phy not found, using dummy regulator
[   13.472203] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (output).
[   13.472225] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3c).
[   13.472241] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2f).
[   13.472279] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[   13.472624] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[   13.473009] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[   13.473036] rk_gmac-dwmac fe2a0000.ethernet:     DWMAC4/5
[   13.473053] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[   13.473066] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[   13.473078] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[   13.473089] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[   13.473194] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[   13.473210] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   13.473226] rk_gmac-dwmac fe2a0000.ethernet: Enabled RFS Flow TC (entries=10)
[   13.473241] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[   13.473255] rk_gmac-dwmac fe2a0000.ethernet: Using 32/32 bits DMA host/device width
[   13.617581] phy_rtl8211f_led_fixup in
[   13.617756] phy_rtl8211f_led_fixup in  val=0x0a42
[   13.624413] usbcore: registered new interface driver rndis_wlan
[   13.624524] usbcore: registered new interface driver asix
[   13.624595] usbcore: registered new interface driver cdc_ether
[   13.624737] usbcore: registered new interface driver rndis_host
[   13.624862] usbcore: registered new interface driver cdc_ncm
[   13.625248] VFIO - User Level meta-driver version: 0.3
[   13.633896] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pipe-supply from device tree
[   13.633943] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pipe-supply property in node /power-management@fdd90000/power-controller failed
[   13.643739] phy phy-fe8b0000.usb2-phy.3: illegal mode
[   13.644867] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[   13.644933] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[   13.645135] xhci-hcd xhci-hcd.4.auto: USB3 root hub has no ports
[   13.645156] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002010010
[   13.645249] xhci-hcd xhci-hcd.4.auto: irq 51, io mem 0xfd000000
[   13.645860] ehci-platform fd800000.usb: EHCI Host Controller
[   13.645890] phy phy-fe8b0000.usb2-phy.3: illegal mode
[   13.645896] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[   13.645917] ohci-platform fd840000.usb: Generic Platform OHCI controller
[   13.645921] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.645939] usb usb1: Product: xHCI Host Controller
[   13.645948] ehci-platform fd880000.usb: EHCI Host Controller
[   13.645952] usb usb1: Manufacturer: Linux 6.1.99-vendor-rk35xx xhci-hcd
[   13.645963] usb usb1: SerialNumber: xhci-hcd.4.auto
[   13.646293] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[   13.646841] hub 1-0:1.0: USB hub found
[   13.646924] hub 1-0:1.0: 1 port detected
[   13.647627] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 2
[   13.647664] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[   13.647710] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 4
[   13.647793] usbcore: registered new interface driver cdc_acm
[   13.647811] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   13.647886] ehci-platform fd800000.usb: irq 52, io mem 0xfd800000
[   13.647922] ohci-platform fd840000.usb: irq 54, io mem 0xfd840000
[   13.647947] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 5
[   13.648014] ehci-platform fd880000.usb: irq 53, io mem 0xfd880000
[   13.648199] ohci-platform fd8c0000.usb: irq 55, io mem 0xfd8c0000
[   13.648363] usbcore: registered new interface driver uas
[   13.648508] usbcore: registered new interface driver usb-storage
[   13.649419] mousedev: PS/2 mouse device common for all mice
[   13.650017] [GTP-INF][goodix_i2c_init:1931] Goodix driver init
[   13.650081] [GTP-INF][goodix_fwu_module_init:1588] goodix_fwupdate_module_ini IN
[   13.650096] [GTP-INF][goodix_register_ext_module:161] goodix_register_ext_module IN
[   13.650127] [GTP-INF][goodix_register_ext_module:166] goodix_register_ext_module OUT
[   13.650161] [GTP-INF][__do_register_ext_module:67] __do_register_ext_module IN
[   13.651178] .. rk pwm remotectl v2.0 init
[   13.651707] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input2
[   13.652391] remotectl-pwm fe6e0030.pwm: Controller support pwrkey capture
[   13.653196] i2c_dev: i2c /dev entries driver
[   13.656461] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[   13.656506] fan53555-regulator 0-001c: Looking up vin-supply from device tree
[   13.656854] vdd_cpu: supplied by vcc5v0_sys
[   13.656875] vcc5v0_sys: could not add device link regulator.8: -ENOENT
[   13.657436] vdd_cpu: override max_uV, 1390000 -> 1387500
[   13.658034] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[   13.658776] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[   13.658801] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.658816] usb usb2: Product: EHCI Host Controller
[   13.658829] usb usb2: Manufacturer: Linux 6.1.99-vendor-rk35xx ehci_hcd
[   13.658841] usb usb2: SerialNumber: fd800000.usb
[   13.659730] hub 2-0:1.0: USB hub found
[   13.659815] hub 2-0:1.0: 1 port detected
[   13.659908] vdd_cpu: 712 <--> 1387 mV at 900 mV, enabled
[   13.661863] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_rst
[   13.661908] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_pwrdn
[   13.661942] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_slp
[   13.663794] rk808 0-0020: chip id: 0x8090
[   13.663864] rk808 0-0020: No cache defaults, reading back from HW
[   13.671370] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[   13.672134] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[   13.672159] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.672175] usb usb4: Product: EHCI Host Controller
[   13.672188] usb usb4: Manufacturer: Linux 6.1.99-vendor-rk35xx ehci_hcd
[   13.672201] usb usb4: SerialNumber: fd880000.usb
[   13.673075] hub 4-0:1.0: USB hub found
[   13.673201] hub 4-0:1.0: 1 port detected
[   13.687692] rk808 0-0020: source: on=0x10, off=0x00
[   13.687725] rk808 0-0020: support dcdc3 fb mode:-22, 1
[   13.687743] rk808 0-0020: support pmic reset mode:0,0
[   13.690920] rk808 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx
[   13.697442] rk808-regulator rk808-regulator: there is no dvs0 gpio
[   13.697501] rk808-regulator rk808-regulator: there is no dvs1 gpio
[   13.697598] rk808 0-0020: Looking up vcc1-supply from device tree
[   13.698020] vdd_logic: supplied by vcc3v3_sys
[   13.698046] vcc3v3_sys: could not add device link regulator.9: -ENOENT
[   13.698926] vdd_logic: 500 <--> 1350 mV at 900 mV, enabled
[   13.699427] rk808 0-0020: Looking up vcc2-supply from device tree
[   13.699458] vdd_gpu: supplied by vcc3v3_sys
[   13.699476] vcc3v3_sys: could not add device link regulator.10: -ENOENT
[   13.700299] vdd_gpu: 500 <--> 1350 mV at 900 mV, enabled
[   13.700784] rk808 0-0020: Looking up vcc3-supply from device tree
[   13.700813] vcc_ddr: supplied by vcc3v3_sys
[   13.700831] vcc3v3_sys: could not add device link regulator.11: -ENOENT
[   13.701354] vcc_ddr: at 500 mV, enabled
[   13.701801] rk808 0-0020: Looking up vcc4-supply from device tree
[   13.701830] vdd_npu: supplied by vcc3v3_sys
[   13.701847] vcc3v3_sys: could not add device link regulator.12: -ENOENT
[   13.702318] vdd_npu: 500 <--> 1350 mV at 900 mV, enabled
[   13.702785] rk808 0-0020: Looking up vcc9-supply from device tree
[   13.702814] vcc_1v8: supplied by vcc3v3_sys
[   13.702832] vcc3v3_sys: could not add device link regulator.13: -ENOENT
[   13.703653] vcc_1v8: 1800 mV, enabled
[   13.704061] rk808 0-0020: Looking up vcc5-supply from device tree
[   13.704090] vdda0v9_image: supplied by vcc3v3_sys
[   13.704108] vcc3v3_sys: could not add device link regulator.14: -ENOENT
[   13.705112] vdda0v9_image: 900 mV, enabled
[   13.705503] rk808 0-0020: Looking up vcc5-supply from device tree
[   13.705531] vdda_0v9: supplied by vcc3v3_sys
[   13.705549] vcc3v3_sys: could not add device link regulator.15: -ENOENT
[   13.705783] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[   13.705809] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.705825] usb usb3: Product: Generic Platform OHCI controller
[   13.705838] usb usb3: Manufacturer: Linux 6.1.99-vendor-rk35xx ohci_hcd
[   13.705851] usb usb3: SerialNumber: fd840000.usb
[   13.706709] hub 3-0:1.0: USB hub found
[   13.706800] hub 3-0:1.0: 1 port detected
[   13.706942] vdda_0v9: 900 mV, enabled
[   13.707385] rk808 0-0020: Looking up vcc5-supply from device tree
[   13.707415] vdda0v9_pmu: supplied by vcc3v3_sys
[   13.707441] vcc3v3_sys: could not add device link regulator.16: -ENOENT
[   13.708451] vdda0v9_pmu: 900 mV, enabled
[   13.708903] rk808 0-0020: Looking up vcc6-supply from device tree
[   13.708933] vccio_acodec: supplied by vcc3v3_sys
[   13.708952] vcc3v3_sys: could not add device link regulator.17: -ENOENT
[   13.709014] vccio_acodec: Bringing 3300000uV into 3000000-3000000uV
[   13.709082] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[   13.709108] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.709124] usb usb5: Product: Generic Platform OHCI controller
[   13.709137] usb usb5: Manufacturer: Linux 6.1.99-vendor-rk35xx ohci_hcd
[   13.709150] usb usb5: SerialNumber: fd8c0000.usb
[   13.709977] hub 5-0:1.0: USB hub found
[   13.710060] hub 5-0:1.0: 1 port detected
[   13.710334] vccio_acodec: 3000 mV, enabled
[   13.710805] rk808 0-0020: Looking up vcc6-supply from device tree
[   13.710836] vccio_sd: supplied by vcc3v3_sys
[   13.710854] vcc3v3_sys: could not add device link regulator.18: -ENOENT
[   13.712250] vccio_sd: 1800 <--> 3300 mV at 3300 mV, enabled
[   13.712677] rk808 0-0020: Looking up vcc6-supply from device tree
[   13.712706] vcc3v3_pmu: supplied by vcc3v3_sys
[   13.712725] vcc3v3_sys: could not add device link regulator.19: -ENOENT
[   13.713707] vcc3v3_pmu: 3300 mV, enabled
[   13.714166] rk808 0-0020: Looking up vcc7-supply from device tree
[   13.714194] vcca_1v8: supplied by vcc3v3_sys
[   13.714212] vcc3v3_sys: could not add device link regulator.20: -ENOENT
[   13.715575] vcca_1v8: 1800 mV, enabled
[   13.716027] rk808 0-0020: Looking up vcc7-supply from device tree
[   13.716057] vcca1v8_pmu: supplied by vcc3v3_sys
[   13.716075] vcc3v3_sys: could not add device link regulator.21: -ENOENT
[   13.717060] vcca1v8_pmu: 1800 mV, enabled
[   13.717531] rk808 0-0020: Looking up vcc7-supply from device tree
[   13.717560] vcca1v8_image: supplied by vcc3v3_sys
[   13.717580] vcc3v3_sys: could not add device link regulator.22: -ENOENT
[   13.718617] vcca1v8_image: 1800 mV, enabled
[   13.719093] rk808 0-0020: Looking up vcc9-supply from device tree
[   13.719124] vcc_3v3: supplied by vcc3v3_sys
[   13.719142] vcc3v3_sys: could not add device link regulator.23: -ENOENT
[   13.719965] vcc_3v3: at 3300 mV, enabled
[   13.720350] rk808 0-0020: Looking up vcc8-supply from device tree
[   13.720378] vcc3v3_sd: supplied by vcc3v3_sys
[   13.720397] vcc3v3_sys: could not add device link regulator.24: -ENOENT
[   13.721228] vcc3v3_sd: at 3300 mV, enabled
[   13.721643] rk817-battery: Failed to locate of_node [id: -1]
[   13.721884] rk817-battery rk817-battery: Failed to find matching dt id
[   13.722067] rk817-charger: Failed to locate of_node [id: -1]
[   13.722244] rk817-charger rk817-charger: Failed to find matching dt id
[   13.729007] rk808-rtc rk808-rtc: registered as rtc0
[   13.730807] rk808-rtc rk808-rtc: setting system clock to 2025-03-06T15:22:44 UTC (1741274564)
[   13.737455] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
[   13.737846] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[   13.739290] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[   13.739337] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 6
[   13.739527] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002010010
[   13.739620] xhci-hcd xhci-hcd.6.auto: irq 87, io mem 0xfcc00000
[   13.739907] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[   13.739938] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 7
[   13.739966] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[   13.740484] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[   13.740507] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.740524] usb usb6: Product: xHCI Host Controller
[   13.740537] usb usb6: Manufacturer: Linux 6.1.99-vendor-rk35xx xhci-hcd
[   13.740550] usb usb6: SerialNumber: xhci-hcd.6.auto
[   13.742530] hub 6-0:1.0: USB hub found
[   13.742618] hub 6-0:1.0: 1 port detected
[   13.743369] usb usb7: We don't know the algorithms for LPM for this host, disabling LPM.
[   13.743675] usb usb7: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[   13.743698] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.743713] usb usb7: Product: xHCI Host Controller
[   13.743726] usb usb7: Manufacturer: Linux 6.1.99-vendor-rk35xx xhci-hcd
[   13.743738] usb usb7: SerialNumber: xhci-hcd.6.auto
[   13.745380] hub 7-0:1.0: USB hub found
[   13.745472] hub 7-0:1.0: 1 port detected
[   13.746859] rkisp_hw fdff0000.rkisp: Adding to iommu group 7
[   13.747232] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[   13.747281] rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff]
[   13.747334] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[   13.747841] rkisp_hw fdff0000.rkisp: no find phandle sram
[   13.751097] usbcore: registered new interface driver uvcvideo
[   13.754701] cpu cpu0: Failed to get specification_serial_number
[   13.754763] cpu cpu0: Failed to get leakage
[   13.754803] cpu cpu0: Looking up cpu-supply from device tree
[   13.755877] cpu cpu0: soc version=0, speed=0
[   13.755990] cpu cpu0: Looking up cpu-supply from device tree
[   13.758929] cpu cpu0: avs=0
[   13.759234] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[   13.762856] cpu cpu0: EM: OPP:600000 is inefficient
[   13.763202] cpu cpu0: EM: created perf domain
[   13.766291] sdhci: Secure Digital Host Controller Interface driver
[   13.766316] sdhci: Copyright(c) Pierre Ossman
[   13.766325] Synopsys Designware Multimedia Card Interface Driver
[   13.768059] sdhci-pltfm: SDHCI platform and OF driver helper
[   13.768865] dwmmc_rockchip fe2b0000.mmc: No normal pinctrl state
[   13.768890] dwmmc_rockchip fe2b0000.mmc: No idle pinctrl state
[   13.769075] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   13.769095] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   13.769440] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[   13.769505] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[   13.769527] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[   13.769616] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 92,32 bit host data width,256 deep fifo
[   13.769791] dwmmc_rockchip fe2b0000.mmc: Looking up vmmc-supply from device tree
[   13.769799] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   13.769843] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   13.769864] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   13.769931] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   13.770075] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   13.770129] dwmmc_rockchip fe2b0000.mmc: Looking up vqmmc-supply from device tree
[   13.770305] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   13.770317] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   13.770473] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[   13.770917] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply from device tree
[   13.770935] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply property in node /mmc@fe310000 failed
[   13.770975] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply from device tree
[   13.770983] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply property in node /mmc@fe310000 failed
[   13.771817] ledtrig-cpu: registered to indicate activity on CPUs
[   13.771869] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[   13.771954] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[   13.772828] cryptodev: driver 1.12 loaded.
[   13.772880] hid: raw HID events driver (C) Jiri Kosina
[   13.773101] usbcore: registered new interface driver usbhid
[   13.773109] usbhid: USB HID core driver
[   13.773383] rockchip,bus bus-npu: Looking up bus-supply from device tree
[   13.773560] rockchip,bus bus-npu: bin=0
[   13.773582] rockchip,bus bus-npu: Failed to get leakage
[   13.773597] rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[   13.774364] rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[   13.777950] rockchip,bus bus-npu: avs=0
[   13.781463] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[   13.782452] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[   13.783444] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42600
[   13.783455] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42602
[   13.783460] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42605
[   13.783464] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42622
[   13.784762] usbcore: registered new interface driver snd-usb-audio
[   13.787150] [Awinic] aw87xxx_pa_init:driver version: v2.2.0
[   13.799122] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[   13.855639] Initializing XFRM netlink socket
[   13.855887] NET: Registered PF_PACKET protocol family
[   13.856273] [BT_RFKILL]: Enter rfkill_rk_init
[   13.856282] [WLAN_RFKILL]: Enter rfkill_wlan_init
[   13.856909] Key type dns_resolver registered
[   13.856946] Key type ceph registered
[   13.857398] libceph: loaded (mon/osd proto 15/24)
[   13.859521] registered taskstats version 1
[   13.859564] Loading compiled-in X.509 certificates
[   13.863774] zswap: loaded using pool zstd/zbud
[   13.864447] Key type .fscrypt registered
[   13.864457] Key type fscrypt-provisioning registered
[   13.865514] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[   13.865942] pstore: Using crash dump compression: deflate
[   13.866272] AppArmor: AppArmor sha1 policy hashing enabled
[   13.876018] rga2 fdeb0000.rk_rga: probe successfully, irq = 99, hw_version:3.2.63318
[   13.876413] rga: IOMMU binding successfully, default mapping core[0x4]
[   13.876738] rga: Module initialized. v1.3.7
[   13.894302] mmc0: Host Software Queue enabled
[   13.894345] mmc0: new HS200 MMC card at address 0001
[   13.897395] mmcblk0: mmc0:0001 DV4032 29.1 GiB
[   13.898066] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[   13.906619]  mmcblk0: p1
[   13.908163] usb 2-1: new high-speed USB device number 2 using ehci-platform
[   13.910194] mmcblk0boot0: mmc0:0001 DV4032 4.00 MiB
[   13.916448] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[   13.916473] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply property in node /syscon@fdc20000/io-domains failed
[   13.916521] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[   13.916842] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc_3v3
[   13.916876] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[   13.917106] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3000000 uV) supplied by vccio_acodec
[   13.917133] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[   13.917149] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply property in node /syscon@fdc20000/io-domains failed
[   13.917214] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[   13.917424] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[   13.917442] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[   13.917610] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[   13.917626] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[   13.917722] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[   13.917735] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[   13.917819] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[   13.917836] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[   13.917951] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[   13.919083] mpp_rkvenc fdf40000.rkvenc: Adding to iommu group 5
[   13.919294] mmcblk0boot1: mmc0:0001 DV4032 4.00 MiB
[   13.919380] mpp_rkvenc fdf40000.rkvenc: probing start
[   13.920041] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[   13.920481] mpp_rkvenc fdf40000.rkvenc: bin=0
[   13.920532] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[   13.920564] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[   13.920604] vdd_logic: could not add device link fdf40000.rkvenc: -EEXIST
[   13.920743] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[   13.920775] debugfs: Directory 'fdf40000.rkvenc-venc' with parent 'vdd_logic' already present!
[   13.920798] vdd_logic: Failed to create debugfs directory
[   13.921185] mpp_rkvenc fdf40000.rkvenc: avs=0
[   13.921625] mpp_rkvenc fdf40000.rkvenc: using default check_rate_volt
[   13.921661] mpp_rkvenc fdf40000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[   13.922779] mpp_rkvenc fdf40000.rkvenc: probing finish
[   13.923737] mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 1
[   13.924208] mpp_vdpu2 fdea0400.vdpu: probe device
[   13.924876] mpp_vdpu2 fdea0400.vdpu: probing finish
[   13.925324] mpp_vepu2 fdee0000.vepu: Adding to iommu group 3
[   13.925504] mpp_vepu2 fdee0000.vepu: probing start
[   13.925681] mmcblk0rpmb: mmc0:0001 DV4032 16.0 MiB, chardev (234:0)
[   13.925814] mpp_vepu2 fdee0000.vepu: probing finish
[   13.926151] mpp-iep2 fdef0000.iep: Adding to iommu group 4
[   13.926304] mpp-iep2 fdef0000.iep: probe device
[   13.926554] mpp-iep2 fdef0000.iep: probing finish
[   13.926853] mpp_jpgdec fded0000.jpegd: Adding to iommu group 2
[   13.927028] mpp_jpgdec fded0000.jpegd: probe device
[   13.927293] mpp_jpgdec fded0000.jpegd: probing finish
[   13.927637] mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 6
[   13.927822] mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[   13.928178] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[   13.928188] rkvdec2_init:1198: No niu aclk reset resource define
[   13.928196] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[   13.928201] rkvdec2_init:1201: No niu hclk reset resource define
[   13.928223] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[   13.928438] mpp_rkvdec2 fdf80200.rkvdec: bin=0
[   13.928463] mpp_rkvdec2 fdf80200.rkvdec: Failed to get leakage
[   13.928479] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[   13.928498] vdd_logic: could not add device link fdf80200.rkvdec: -EEXIST
[   13.928560] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[   13.928578] debugfs: Directory 'fdf80200.rkvdec-vdec' with parent 'vdd_logic' already present!
[   13.928588] vdd_logic: Failed to create debugfs directory
[   13.928785] mpp_rkvdec2 fdf80200.rkvdec: avs=0
[   13.928955] mpp_rkvdec2 fdf80200.rkvdec: using default check_rate_volt
[   13.928973] mpp_rkvdec2 fdf80200.rkvdec: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[   13.929136] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[   13.929144] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[   13.929150] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[   13.929156] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[   13.929163] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[   13.929226] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[   13.929294] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[   13.929300] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[   13.930221] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply from device tree
[   13.930256] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fdd90000/power-controller failed
[   13.930387] mali fde60000.gpu: Kernel DDK version g25p0-00eac0
[   13.930403] mali fde60000.gpu: error -ENXIO: IRQ JOB not found
[   13.930537] mali fde60000.gpu: error -ENXIO: IRQ MMU not found
[   13.930621] mali fde60000.gpu: error -ENXIO: IRQ GPU not found
[   13.930691] mali fde60000.gpu: Insufficient register space, will override to the required size
[   13.930705] mali fde60000.gpu: Register window unavailable
[   13.930711] mali fde60000.gpu: Failed to map registers
[   13.930716] mali fde60000.gpu: Register map failed error = -5
[   13.930722] mali fde60000.gpu: Device initialization failed
[   13.930776] mali: probe of fde60000.gpu failed with error -5
[   13.930817] rockchip-dmc dmc: Failed to get specification_serial_number
[   13.930853] rockchip-dmc dmc: Failed to get leakage
[   13.930875] rockchip-dmc dmc: Looking up center-supply from device tree
[   13.931220] rockchip-dmc dmc: soc version=0, speed=0
[   13.931274] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   13.931283] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   13.931347] rockchip-dmc dmc: Looking up center-supply from device tree
[   13.931417] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   13.931449] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   13.931459] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   13.931495] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   13.931568] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   13.931632] rockchip-dmc dmc: avs=0
[   13.931651] rockchip-dmc dmc: current ATF version 0x102
[   13.931738] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   13.931749] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   13.932273] rockchip-dmc dmc: normal_rate = 780000000
[   13.932288] rockchip-dmc dmc: reboot_rate = 1560000000
[   13.932299] rockchip-dmc dmc: suspend_rate = 324000000
[   13.932306] rockchip-dmc dmc: video_4k_rate = 780000000
[   13.932312] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[   13.932320] rockchip-dmc dmc: boost_rate = 1560000000
[   13.932327] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1560000000
[   13.932333] rockchip-dmc dmc: performance_rate = 1560000000
[   13.932377] rockchip-dmc dmc: failed to get vop pn to msch rl
[   13.932622] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[   13.971461] vendor storage:20190527 ret = 0
[   13.978917] WCN: marlin_init entry!
[   13.979131] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   13.979153] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   13.979333] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   13.979398] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   13.979418] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   13.979482] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   13.979656] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   13.979956] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   13.979981] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   13.980742] RKNPU fde40000.npu: Adding to iommu group 0
[   13.981532] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[   13.981639] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[   13.981902] RKNPU fde40000.npu: Looking up mem-supply from device tree
[   13.981925] RKNPU fde40000.npu: Looking up mem-supply property in node /npu@fde40000 failed
[   13.982005] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[   13.982068] RKNPU fde40000.npu: error -ENXIO: IRQ npu_irq not found
[   13.982885] [drm] Initialized rknpu 0.9.8 20240828 for fde40000.npu on minor 1
[   13.983604] RKNPU fde40000.npu: Failed to get specification_serial_number
[   13.983650] RKNPU fde40000.npu: Failed to get leakage
[   13.983685] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[   13.983736] vdd_npu: could not add device link fde40000.npu: -EEXIST
[   13.983797] RKNPU fde40000.npu: soc version=0, speed=0
[   13.983897] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[   13.983943] debugfs: Directory 'fde40000.npu-rknpu' with parent 'vdd_npu' already present!
[   13.983963] vdd_npu: Failed to create debugfs directory
[   13.985589] RKNPU fde40000.npu: avs=0
[   13.986025] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=800000000 h_limit=0 h_table=0
[   13.989924] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   13.991193] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   13.991214] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   13.991373] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   13.991412] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   13.991425] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   13.991465] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   13.991577] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   13.991772] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   13.991787] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.006457] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.007174] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   14.007269] clk: Disabling unused clocks
[   14.008093] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[   14.008856] rockchip-suspend not set sleep-mode-config for mem-lite
[   14.008863] rockchip-suspend not set wakeup-config for mem-lite
[   14.008870] rockchip-suspend not set sleep-mode-config for mem-ultra
[   14.008874] rockchip-suspend not set wakeup-config for mem-ultra
[   14.009935] ALSA device list:
[   14.009950]   #0: rockchip,hdmi
[   14.010765] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.010781] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.010902] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.010925] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.010934] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.010973] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.011065] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.011215] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.011225] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.018605] Freeing unused kernel memory: 8320K
[   14.018909] Run /init as init process
[   14.018918]   with arguments:
[   14.018925]     /init
[   14.018929]     splash
[   14.018934]   with environment:
[   14.018938]     HOME=/
[   14.018942]     TERM=linux
[   14.018946]     ubootpart=56a0f540-524e-4f8b-8bb2-dadfd100fc0c
[   14.018951]     cgroup_enable=memory
[   14.018956]     cgroup_memory=1
[   14.039440] usb 1-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   14.039470] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   14.039479] usb 1-1: Product: USB2.0 HUB
[   14.060080] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[   14.060110] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   14.060120] usb 2-1: Product: USB2.0 Hub
[   14.061123] hub 2-1:1.0: USB hub found
[   14.061802] hub 2-1:1.0: 4 ports detected
[   14.067005] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.067030] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.067178] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.067219] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.067233] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.067286] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.067472] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.067680] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.067698] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.286072] hub 1-1:1.0: USB hub found
[   14.286264] hub 1-1:1.0: 4 ports detected
[   14.289191] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.289210] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.289341] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.289372] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.289383] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.289421] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.289554] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.289708] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.289720] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.671430] usb 1-1.2: new low-speed USB device number 3 using xhci-hcd
[   14.749308] input: adc-keys as /devices/platform/adc-keys/input/input3
[   14.753291] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.753310] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.753456] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.753490] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.753501] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.753543] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.753668] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.753840] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.753855] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.765654] usb 1-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[   14.765677] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   14.765684] usb 1-1.2: Product: Lenovo USB Optical Mouse
[   14.765690] usb 1-1.2: Manufacturer: PixArt
[   14.830084] rk_gmac-dwmac fe010000.ethernet end1: renamed from eth0
[   14.859326] rk_gmac-dwmac fe2a0000.ethernet end0: renamed from eth1
[   14.865583] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[   14.867223] rockchip-cpuinfo cpuinfo: SoC        : 35683000
[   14.867246] rockchip-cpuinfo cpuinfo: Serial        : c744c33f00e28e4f
[   14.868802] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.868823] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.869071] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.869118] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.869129] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.869175] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.869306] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.869486] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.869503] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.953581] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbhost/fd000000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:608D.0001/input/input4
[   14.954193] hid-generic 0003:17EF:608D.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.4.auto-1.2/input0
[   14.956527] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.956549] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.956743] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.956789] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.956801] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.956846] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.956975] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.957200] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.957221] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   15.034792] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd
[   15.136543] usb 1-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[   15.136573] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   15.136589] usb 1-1.3: Product: Lenovo Traditional USB Keyboard
[   15.136602] usb 1-1.3: Manufacturer: Lenovo
[   15.344943] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbhost/fd000000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:17EF:6099.0002/input/input5
[   15.402971] hid-generic 0003:17EF:6099.0002: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.4.auto-1.3/input0
[   15.409022] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   15.409077] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   15.409338] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   15.409437] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   15.409475] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   15.409579] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   15.410461] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   15.411042] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   15.411094] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   16.582322] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
[   16.949545] NET: Registered PF_INET6 protocol family
[   16.950690] Segment Routing with IPv6
[   16.950722] In-situ OAM (IOAM) with IPv6
[   16.973857] systemd[1]: systemd 255.4-1ubuntu8.5 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   16.973899] systemd[1]: Detected architecture arm64.
[   16.977225] systemd[1]: Hostname set to <yy3568>.
[   17.578784] systemd[1]: Queued start job for default target graphical.target.
[   17.654020] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[   17.658662] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[   17.660135] systemd[1]: Created slice user.slice - User and Session Slice.
[   17.660649] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[   17.661729] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[   17.661968] systemd[1]: Expecting device dev-ttyFIQ0.device - /dev/ttyFIQ0...
[   17.662177] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[   17.662395] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[   17.662597] systemd[1]: Reached target slices.target - Slice Units.
[   17.662747] systemd[1]: Reached target swap.target - Swaps.
[   17.662891] systemd[1]: Reached target time-set.target - System Time Set.
[   17.663102] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[   17.682628] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
[   17.683849] systemd[1]: Listening on syslog.socket - Syslog Socket.
[   17.684859] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[   17.685503] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[   17.686549] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   17.687681] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[   17.688124] systemd[1]: systemd-pcrextend.socket - TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   17.691239] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[   17.692518] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   17.697540] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   17.701367] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   17.705740] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   17.711065] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   17.712184] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[   17.724937] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[   17.742856] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[   17.748064] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[   17.749925] (-hwclock)[326]: fake-hwclock-load.service: Referenced but unset environment variable evaluates to an empty string: FORCE
[   17.753444] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   17.760429] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[   17.774666] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   17.787012] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   17.810050] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[   17.818352] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[   17.820820] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[   17.822199] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[   17.830682] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[   17.831485] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   17.838101] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[   17.838859] systemd[1]: systemd-tpm2-setup-early.service - TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   17.855881] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   17.857427] fuse: init (API version 7.37)
[   17.865119] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   17.870226] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   17.872784] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   17.874297] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   17.876571] systemd[1]: fake-hwclock-load.service: Deactivated successfully.
[   17.877490] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
[   17.880084] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[   17.883062] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   17.883953] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[   17.886578] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   17.889092] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[   17.891277] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   17.892414] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[   17.894397] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   17.896116] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   17.898528] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   17.899363] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[   17.901243] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
[   17.901982] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   17.903042] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[   17.916067] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[   17.922500] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[   17.923214] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   17.950101] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[   17.954510] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[   17.957940] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[   17.959971] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[   17.971111] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   17.972370] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   17.977417] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[   17.982555] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[   17.982824] systemd[1]: systemd-tpm2-setup.service - TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   17.986156] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[   18.008600] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   18.039843] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully.
[   18.041663] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[   18.046427] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[   18.049460] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
[   18.050787] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[   18.059096] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[   18.132458] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
[   18.133419] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
[   18.158633] systemd[1]: Mounting tmp.mount - /tmp...
[   18.164395] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
[   18.168562] systemd[1]: Mounted tmp.mount - /tmp.
[   18.169181] systemd[1]: Reached target local-fs.target - Local File Systems.
[   18.174191] systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management (Varlink).
[   18.179186] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
[   18.183782] systemd[1]: Starting console-setup.service - Set console font and keymap...
[   18.184298] systemd[1]: ldconfig.service - Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
[   18.199144] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
[   18.209232] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
[   18.209625] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   18.252792] systemd[1]: Finished console-setup.service - Set console font and keymap.
[   18.262787] systemd[1]: Received SIGRTMIN+20 from PID 252 (plymouthd).
[   18.266707] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
[   18.278730] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 369 (systemd-binfmt)
[   18.283369] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
[   18.360266] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
[   18.366092] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
[   18.413192] zram: Added device: zram0
[   18.413753] zram: Added device: zram1
[   18.414437] zram: Added device: zram2
[   18.435759] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
[   18.507338] zram0: detected capacity change from 0 to 4004672
[   18.539024] Adding 2002332k swap on /dev/zram0.  Priority:5 extents:1 across:2002332k SSFS
[   18.695275] zram1: detected capacity change from 0 to 102400
[   18.738134] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
[   18.765666] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
[   18.798643] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
[   18.828619] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
[   18.851907] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
[   18.928967] systemd[1]: Found device dev-ttyFIQ0.device - /dev/ttyFIQ0.
[   18.932997] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
[   18.935136] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
[   18.935860] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
[   18.936686] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[   19.470677] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
[   19.495900] panfrost fde60000.gpu: clock rate = 594000000
[   19.495944] panfrost fde60000.gpu: bus_clock rate = 500000000
[   19.496030] panfrost fde60000.gpu: Looking up mali-supply from device tree
[   19.509117] systemd[1]: Starting systemd-journald.service - Journal Service...
[   19.545044] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[   19.545070] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[   19.545078] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[   19.545087] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[   19.569193] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 2
[   19.572834] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   19.572856] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   19.572977] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   19.573016] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   19.573027] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   19.573069] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   19.573207] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   19.573378] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   19.573392] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   19.577223] systemd-journald[515]: Collecting audit messages is disabled.
[   19.751454] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input6
[   19.769917] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   19.769935] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   19.770350] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   19.770396] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   19.770407] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   19.770452] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   19.804661] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   19.832119] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   19.832149] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   19.874476] CAN device driver interface
[   20.075710] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   20.091372] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   20.091395] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   20.091521] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   20.091560] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   20.091571] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   20.091613] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   20.102815] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   20.113269] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   20.113301] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   20.173891] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   20.286240] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
[   20.315410] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[   20.315915] systemd[1]: ldconfig.service - Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
[   20.321842] (-hwclock)[544]: fake-hwclock-load.service: Referenced but unset environment variable evaluates to an empty string: FORCE
[   20.325595] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[   20.336958] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   20.350605] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[   20.351197] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   20.351554] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   20.351639] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   20.352003] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[   20.352136] systemd[1]: systemd-tpm2-setup-early.service - TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   20.352207] systemd[1]: systemd-tpm2-setup.service - TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   20.353962] systemd[1]: fake-hwclock-load.service: Deactivated successfully.
[   20.361698] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
[   20.373222] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   20.374006] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[   20.383129] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   20.420284] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   20.421082] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   20.423087] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   20.423848] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[   20.425119] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   20.425309] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   20.485733] systemd[1]: Started systemd-journald.service - Journal Service.
[   20.535917] systemd-journald[515]: Received client request to flush runtime journal.
[   20.851616] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   21.194438] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   22.532196] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   22.651042] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   25.134386] rk_gmac-dwmac fe2a0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   25.135368] phy_rtl8211f_led_fixup in
[   25.135538] phy_rtl8211f_led_fixup in  val=0x0000
[   25.136029] phy_rtl8211f_led_fixup in
[   25.136160] phy_rtl8211f_led_fixup in  val=0x0000
[   25.194828] rk_gmac-dwmac fe2a0000.ethernet end0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   25.195399] dwmac4: Master AXI performs any burst length
[   25.195426] rk_gmac-dwmac fe2a0000.ethernet end0: No Safety Features support found
[   25.195456] rk_gmac-dwmac fe2a0000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported
[   25.195893] rk_gmac-dwmac fe2a0000.ethernet end0: registered PTP clock
[   25.196354] rk_gmac-dwmac fe2a0000.ethernet end0: configuring for phy/rgmii link mode
[   25.237573] rk_gmac-dwmac fe010000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0
[   25.238428] phy_rtl8211f_led_fixup in
[   25.238586] phy_rtl8211f_led_fixup in  val=0x0a42
[   25.239068] phy_rtl8211f_led_fixup in
[   25.239198] phy_rtl8211f_led_fixup in  val=0x0000
[   25.328200] rk_gmac-dwmac fe010000.ethernet end1: PHY [stmmac-1:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   25.328769] dwmac4: Master AXI performs any burst length
[   25.328804] rk_gmac-dwmac fe010000.ethernet end1: No Safety Features support found
[   25.328831] rk_gmac-dwmac fe010000.ethernet end1: IEEE 1588-2008 Advanced Timestamp supported
[   25.329206] rk_gmac-dwmac fe010000.ethernet end1: registered PTP clock
[   25.329681] rk_gmac-dwmac fe010000.ethernet end1: configuring for phy/rgmii link mode
[   25.575141] usb 1-1: USB disconnect, device number 2
[   25.575168] usb 1-1.2: USB disconnect, device number 3
[   25.794397] usb 1-1.3: USB disconnect, device number 4
[   28.167818] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   28.167838] Bluetooth: BNEP filters: protocol multicast
[   28.167856] Bluetooth: BNEP socket layer initialized
[   28.838085] usb 6-1: new full-speed USB device number 2 using xhci-hcd
[   28.979129] usb 6-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   28.979153] usb 6-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   28.979161] usb 6-1: Product: USB2.0 HUB
[   29.204292] hub 6-1:1.0: USB hub found
[   29.204437] hub 6-1:1.0: 4 ports detected
[   29.207177] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   29.207200] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   29.209264] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   29.209324] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   29.209335] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   29.209388] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   29.209541] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   29.209732] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   29.209747] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   29.588054] usb 6-1.2: new low-speed USB device number 3 using xhci-hcd
[   29.685462] usb 6-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[   29.685488] usb 6-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   29.685495] usb 6-1.2: Product: Lenovo USB Optical Mouse
[   29.685501] usb 6-1.2: Manufacturer: PixArt
[   29.869377] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbdrd/fcc00000.usb/xhci-hcd.6.auto/usb6/6-1/6-1.2/6-1.2:1.0/0003:17EF:608D.0003/input/input7
[   29.870369] hid-generic 0003:17EF:608D.0003: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.6.auto-1.2/input0
[   29.872866] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   29.872889] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   29.873583] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   29.873645] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   29.873654] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   29.873706] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   29.873923] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   29.877213] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   29.877248] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   29.941507] usb 6-1.3: new low-speed USB device number 4 using xhci-hcd
[   30.043302] usb 6-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[   30.043332] usb 6-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   30.043339] usb 6-1.3: Product: Lenovo Traditional USB Keyboard
[   30.043351] usb 6-1.3: Manufacturer: Lenovo
[   30.125901] platform mtd_vendor_storage: deferred probe pending
[   30.126870] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   30.126894] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   30.127171] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   30.127234] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   30.127245] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   30.127296] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   30.127490] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   30.127857] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   30.127882] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   30.257307] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbdrd/fcc00000.usb/xhci-hcd.6.auto/usb6/6-1/6-1.3/6-1.3:1.0/0003:17EF:6099.0004/input/input8
[   30.313061] hid-generic 0003:17EF:6099.0004: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.6.auto-1.3/input0
[   30.315490] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   30.315515] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   30.318203] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   30.318260] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   30.318273] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   30.318325] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   30.318498] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   30.318720] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   30.318740] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   32.116825] xhci-hcd xhci-hcd.6.auto: remove, state 4
[   32.116864] usb usb7: USB disconnect, device number 1
[   32.117655] xhci-hcd xhci-hcd.6.auto: USB bus 7 deregistered
[   32.117694] xhci-hcd xhci-hcd.6.auto: remove, state 1
[   32.117714] usb usb6: USB disconnect, device number 1
[   32.117724] usb 6-1: USB disconnect, device number 2
[   32.117731] usb 6-1.2: USB disconnect, device number 3
[   32.297812] usb 6-1.3: USB disconnect, device number 4
[   32.718819] xhci-hcd xhci-hcd.6.auto: USB bus 6 deregistered
[   37.095851] rfkill: input handler disabled
[   39.724707] [GTP-ERR][__do_register_ext_module:79] Module [goodix-fwu] timeout
[   49.311565] usb 2-1.1: new full-speed USB device number 3 using ehci-platform
[   49.411520] usb 2-1.1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   49.411587] usb 2-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   49.411619] usb 2-1.1: Product: USB2.0 HUB
[   49.413826] hub 2-1.1:1.0: USB hub found
[   49.414144] hub 2-1.1:1.0: 4 ports detected
[   49.422797] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   49.422852] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   49.423151] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   49.423273] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   49.423312] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   49.423423] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   49.423878] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   49.424448] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   49.424499] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   55.664861] usb 1-1: new full-speed USB device number 5 using xhci-hcd
[   55.810301] usb 1-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   55.810371] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   55.810403] usb 1-1: Product: USB2.0 HUB
[   55.949571] hub 1-1:1.0: USB hub found
[   55.949853] hub 1-1:1.0: 4 ports detected
[   55.957730] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   55.957790] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   55.958335] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   55.958479] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   55.958521] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   55.958638] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   55.959201] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   55.959821] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   55.959876] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   56.334716] usb 1-1.2: new low-speed USB device number 6 using xhci-hcd
[   56.432123] usb 1-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[   56.432146] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   56.432153] usb 1-1.2: Product: Lenovo USB Optical Mouse
[   56.432159] usb 1-1.2: Manufacturer: PixArt
[   56.610045] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbhost/fd000000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:608D.0005/input/input9
[   56.610516] hid-generic 0003:17EF:608D.0005: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.4.auto-1.2/input0
[   56.612566] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   56.612586] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   56.612805] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   56.612850] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   56.612860] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   56.612898] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   56.613075] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   56.613473] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   56.613498] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   56.684694] usb 1-1.3: new low-speed USB device number 7 using xhci-hcd
[   56.786085] usb 1-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[   56.786107] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   56.786114] usb 1-1.3: Product: Lenovo Traditional USB Keyboard
[   56.786120] usb 1-1.3: Manufacturer: Lenovo
[   56.997587] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbhost/fd000000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:17EF:6099.0006/input/input10
[   57.052094] hid-generic 0003:17EF:6099.0006: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.4.auto-1.3/input0
[   57.054060] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   57.054079] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   57.054229] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   57.054265] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   57.054275] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   57.054317] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   57.054933] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   57.055785] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   57.055816] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   72.595941] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
Edited by Hqnicolas
Posted (edited)
Build Images:
Armbian-unofficial_25.05.0-trunk
Yy3568 noble vendor 6.1.99 Minimal
Yy3568 noble vendor 6.1.99 gnome Desktop
Yy3568 noble current 6.12.17 minimal
Yy3568 noble current 6.12.17 gnome Desktop
Joshua Riek Images
https://github.com/hqnicolas/debug-rockchip/actions/runs/13767536453
ubuntu 22.04 kernel 5.1 Vendor
Server
https://github.com/hqnicolas/debug-rockchip/actions/runs/13767536453/artifacts/2724348355
Desktop
https://github.com/hqnicolas/debug-rockchip/actions/runs/13767536453/artifacts/2724403700
ubuntu 24.04 kernel 6.1 Vendor
Desktop
https://github.com/hqnicolas/debug-rockchip/actions/runs/13767536453/artifacts/2724523437
Server
https://github.com/hqnicolas/debug-rockchip/actions/runs/13767536453/artifacts/2724483900
Edited by Hqnicolas
Hello Hqnicolas,
thank you very much for the effort you made with the yy3568.
I have a nvme SSD connected to .m2 and this works with the youyeetoo kernel "Linux yy3568 4.19.232 #8 SMP Wed Aug 7 10:48:37 CEST 2024 aarch64 GNU/Linux".
I tried your Armbian plus the attached patch but the SSD doesn't work. See attached screenlog.0
[    2.512779] pci 0000:00:00.0: ROM [mem 0xf4200000-0xf420ffff pref]: assigned
[    2.512806] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.512830] pci_bus 0000:00: resource 4 [io  0x0000-0xfffff]
[    2.512844] pci_bus 0000:00: resource 5 [mem 0xf4200000-0xf5ffffff]
[    2.512857] pci_bus 0000:00: resource 6 [mem 0x300000000-0x33fffffff]
[    2.516131] pcieport 0000:00:00.0: PME: Signaling with IRQ 73
[    2.516722] pcieport 0000:00:00.0: AER: enabled with IRQ 73
[    2.518475] phy phy-fe8c0000.phy.2: lane number 0, val 1
[    2.518506] phy phy-fe8c0000.phy.2: lane number 1, val 2
[    2.518519] phy phy-fe8c0000.phy.2: bifurcation enabled
[    2.519039] phy phy-fe8c0000.phy.2: rockchip_p3phy_rk3568_init: lock failed 0x6890000, check input refclk and power supply
[    2.519059] phy phy-fe8c0000.phy.2: phy init failed --> -110
[    2.519102] rockchip-dw-pcie 3c0800000.pcie: probe with driver rockchip-dw-pcie failed with error -110
[    2.520137] mmc0: new HS200 MMC card at address 0001
[    2.525326] mmcblk0: mmc0:0001 ISOCOM 57.6 GiB
[    2.529794] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
[    2.531377] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
[    2.531408] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
At least is PCI bridge found:
root@yy3568:~# lspci -v
00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3568 Remote Signal Processor (rev 01) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 73
        Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
        I/O behind bridge: [disabled] [16-bit]
        Memory behind bridge: [disabled] [32-bit]
        Prefetchable memory behind bridge: [disabled] [64-bit]
        Expansion ROM at f4200000 [virtual] [disabled] [size=64K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
        Capabilities: [70] Express Root Port (Slot-), MSI 00
        Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [148] Secondary PCI Express
        Capabilities: [160] L1 PM Substates
        Capabilities: [170] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
        Kernel driver in use: pcieport
It would be great if you find some time to find a solution.
Kind Regards,
Guenter
kernel-rockchip64-edge.patch screenlog.0
