Posted (edited)
TESTING
none of the images I created worked,
despite seeing the status post
https://github.com/armbian/linux-rockchip/releases/tag/v24.8.0-trunk.147
 it seems there was a cut in the manufacturer's information and the project didn't move forward
https://github.com/armbian/linux-rockchip/pull/99
I will do all the steps from scratch
cat dmesg
Quote
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 6.14.0-rc4-edge-rockchip64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Sun Feb 23 20:32:57 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Youyeetoo YY3568
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: Reserved memory: No reserved-memory node in the DT
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000001ffffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x1ff753640-0x1ff755dff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000]   node   0: [mem 0x00000001f0000000-0x00000001ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] cma: Reserved 256 MiB at 0x00000000e0000000 on node -1
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 34 pages/cpu s98840 r8192 d32232 u139264
[    0.000000] pcpu-alloc: s98840 r8192 d32232 u139264 alloc=34*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: root=UUID=de2a5213-e4a0-4e17-8a41-545c79873d46 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=41a72af7-ee03-854a-8ec3-780abdbcac11 usb-storage.quirks= cma=256M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=ddr-v1.21-2d653b3476,bl31-v1.44,uboot-rmbian-201-03/03/2025
[    0.000000] Unknown kernel command line parameters "splash ubootpart=41a72af7-ee03-854a-8ec3-780abdbcac11 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    0.000000] printk: log buffer data + meta data: 262144 + 917504 = 1179648 bytes
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1048064
[    0.000000] Policy zone: Normal
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 320 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: MBI range [296:319]
[    0.000000] GICv3: Using MBI frame 0x00000000fd410000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001303] Console: colour dummy device 80x25
[    0.001326] printk: legacy console [tty1] enabled
[    0.001522] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001548] pid_max: default: 32768 minimum: 301
[    0.001657] LSM: initializing lsm=capability,yama,apparmor
[    0.001748] Yama: becoming mindful.
[    0.002091] AppArmor: AppArmor initialized
[    0.002253] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002291] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.035886] rcu: Hierarchical SRCU implementation.
[    0.035909] rcu:     Max phase no-delay instances is 1000.
[    0.036426] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.037625] EFI services will not be available.
[    0.039937] smp: Bringing up secondary CPUs ...
[    0.052125] Detected VIPT I-cache on CPU1
[    0.052228] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.052288] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.060343] Detected VIPT I-cache on CPU2
[    0.060438] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.060489] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.068205] Detected VIPT I-cache on CPU3
[    0.068299] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.068350] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.068536] smp: Brought up 1 node, 4 CPUs
[    0.068564] SMP: Total of 4 processors activated.
[    0.068573] CPU: All CPU(s) started at EL2
[    0.068582] CPU features: detected: 32-bit EL0 Support
[    0.068589] CPU features: detected: 32-bit EL1 Support
[    0.068600] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.068609] CPU features: detected: Common not Private translations
[    0.068617] CPU features: detected: CRC32 instructions
[    0.068633] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.068642] CPU features: detected: LSE atomic instructions
[    0.068651] CPU features: detected: Privileged Access Never
[    0.068658] CPU features: detected: RAS Extension Support
[    0.068670] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.068757] alternatives: applying system-wide alternatives
[    0.073662] Memory: 3714900K/4192256K available (16576K kernel code, 2906K rwdata, 11224K rodata, 5312K init, 785K bss, 210980K reserved, 262144K cma-reserved)
[    0.075527] devtmpfs: initialized
[    0.098887] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.098944] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.107497] 23504 pages in range for non-PLT usage
[    0.107524] 515024 pages in range for PLT usage
[    0.107891] pinctrl core: initialized pinctrl subsystem
[    0.108843] DMI not present or invalid.
[    0.113431] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.115674] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.116915] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.118088] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.118185] audit: initializing netlink subsys (disabled)
[    0.118539] audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1
[    0.121651] thermal_sys: Registered thermal governor 'fair_share'
[    0.121669] thermal_sys: Registered thermal governor 'bang_bang'
[    0.121679] thermal_sys: Registered thermal governor 'step_wise'
[    0.121687] thermal_sys: Registered thermal governor 'user_space'
[    0.121817] cpuidle: using governor menu
[    0.122311] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.122544] ASID allocator initialised with 65536 entries
[    0.122926] Serial: AMBA PL011 UART driver
[    0.143586] /pcie@fe260000: Fixed dependency cycle(s) with /pcie@fe260000/legacy-interrupt-controller
[    0.163152] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.164093] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.164697] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.165129] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.165563] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.166024] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.166458] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.166875] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.167304] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.167698] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.171601] /pcie@fe270000: Fixed dependency cycle(s) with /pcie@fe270000/legacy-interrupt-controller
[    0.172611] /pcie@fe280000: Fixed dependency cycle(s) with /pcie@fe280000/legacy-interrupt-controller
[    0.180358] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.180382] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.180394] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.180402] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.180412] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.180420] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.180429] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.180436] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.182711] cryptd: max_cpu_qlen set to 1000
[    0.250273] raid6: neonx8   gen()  1409 MB/s
[    0.318488] raid6: neonx4   gen()  1438 MB/s
[    0.386708] raid6: neonx2   gen()  1323 MB/s
[    0.454913] raid6: neonx1   gen()  1074 MB/s
[    0.523150] raid6: int64x8  gen()   910 MB/s
[    0.591350] raid6: int64x4  gen()  1051 MB/s
[    0.659572] raid6: int64x2  gen()   937 MB/s
[    0.727789] raid6: int64x1  gen()   689 MB/s
[    0.727802] raid6: using algorithm neonx4 gen() 1438 MB/s
[    0.795960] raid6: .... xor() 1102 MB/s, rmw enabled
[    0.795973] raid6: using neon recovery algorithm
[    0.797381] iommu: Default domain type: Translated
[    0.797401] iommu: DMA domain TLB invalidation policy: strict mode
[    0.798494] SCSI subsystem initialized
[    0.798880] libata version 3.00 loaded.
[    0.799213] usbcore: registered new interface driver usbfs
[    0.799267] usbcore: registered new interface driver hub
[    0.799333] usbcore: registered new device driver usb
[    0.800043] pps_core: LinuxPPS API ver. 1 registered
[    0.800055] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.800092] PTP clock support registered
[    0.800154] EDAC MC: Ver: 3.0.0
[    0.800731] scmi_core: SCMI protocol bus registered
[    0.802471] NetLabel: Initializing
[    0.802490] NetLabel:  domain hash size = 128
[    0.802499] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.802603] NetLabel:  unlabeled traffic allowed by default
[    0.802902] vgaarb: loaded
[    0.803735] clocksource: Switched to clocksource arch_sys_counter
[    0.804536] VFS: Disk quotas dquot_6.6.0
[    0.804607] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.805494] AppArmor: AppArmor Filesystem Enabled
[    0.821070] NET: Registered PF_INET protocol family
[    0.821449] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.894225] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.894471] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.894597] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.895189] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.896176] TCP: Hash tables configured (established 32768 bind 32768)
[    0.896426] UDP hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.896618] UDP-Lite hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.897027] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.897079] NET: Registered PF_XDP protocol family
[    0.897105] PCI: CLS 0 bytes, default 64
[    0.897573] Trying to unpack rootfs image as initramfs...
[    0.904809] kvm [1]: nv: 566 coarse grained trap handlers
[    0.905489] kvm [1]: IPA Size Limit: 40 bits
[    0.905541] kvm [1]: GICv3: no GICV resource entry
[    0.905552] kvm [1]: disabling GICv2 emulation
[    0.905599] kvm [1]: GIC system register CPU interface enabled
[    0.905644] kvm [1]: vgic interrupt IRQ9
[    0.905706] kvm [1]: VHE mode initialized successfully
[    0.908801] Initialise system trusted keyrings
[    0.908894] Key type blacklist registered
[    0.909281] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    0.909362] zbud: loaded
[    0.910207] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.910930] fuse: init (API version 7.42)
[    0.913576] integrity: Platform Keyring initialized
[    0.986759] xor: measuring software checksum speed
[    0.988735]    8regs           :  1684 MB/sec
[    0.990833]    32regs          :  1576 MB/sec
[    0.992766]    arm64_neon      :  1707 MB/sec
[    0.992781] xor: using function: arm64_neon (1707 MB/sec)
[    0.992802] Key type asymmetric registered
[    0.992812] Asymmetric key parser 'x509' registered
[    0.992993] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.993365] io scheduler mq-deadline registered
[    0.993381] io scheduler kyber registered
[    0.993453] io scheduler bfq registered
[    2.496436] Freeing initrd memory: 26360K
[    2.499366] ledtrig-cpu: registered to indicate activity on CPUs
[    2.510538] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.510569] dma-pl330 fe530000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.514067] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.514094] dma-pl330 fe550000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.517572] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.523234] printk: legacy console [ttyS2] disabled
[    2.523780] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 25, base_baud = 1500000) is a 16550A
[    2.524060] printk: legacy console [ttyS2] enabled
[    2.525942] Serial: AMBA driver
[    2.538697] loop: module loaded
[    2.540746] Key type psk registered
[    2.546658] thunder_xcv, ver 1.0
[    2.546720] thunder_bgx, ver 1.0
[    2.546765] nicpf, ver 1.0
[    2.550827] usbcore: registered new interface driver usb-storage
[    2.553549] mousedev: PS/2 mouse device common for all mice
[    2.554250] i2c_dev: i2c /dev entries driver
[    2.556987] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    2.564338] sdhci: Secure Digital Host Controller Interface driver
[    2.564361] sdhci: Copyright(c) Pierre Ossman
[    2.564412] Synopsys Designware Multimedia Card Interface Driver
[    2.565464] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.568098] arm-scmi arm-scmi.0.auto: Using scmi_smc_transport
[    2.568124] arm-scmi arm-scmi.0.auto: SCMI max-rx-timeout: 30ms / max-msg-size: 104bytes / max-msg: 20
[    2.568342] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16
[    2.568746] arm-scmi arm-scmi.0.auto: SCMI Notifications - Core Enabled.
[    2.568822] arm-scmi arm-scmi.0.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    2.570833] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    2.571199] hid: raw HID events driver (C) Jiri Kosina
[    2.571328] usbcore: registered new interface driver usbhid
[    2.571341] usbhid: USB HID core driver
[    2.573093] rockchip-dfi fe230000.dfi: dfi initialized, dram type: 0x7, channels: 1
[    2.575141] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available
[    2.577037] NET: Registered PF_INET6 protocol family
[    2.619073] Segment Routing with IPv6
[    2.619188] In-situ OAM (IOAM) with IPv6
[    2.619334] NET: Registered PF_PACKET protocol family
[    2.619612] 8021q: 802.1Q VLAN Support v1.8
[    2.619799] Key type dns_resolver registered
[    2.633085] registered taskstats version 1
[    2.633600] Loading compiled-in X.509 certificates
[    2.652841] zswap: loaded using pool zstd/z3fold
[    2.653268] Demotion targets for Node 0: null
[    2.653509] Key type .fscrypt registered
[    2.653524] Key type fscrypt-provisioning registered
[    2.657066] Btrfs loaded, zoned=yes, fsverity=yes
[    2.657341] Key type encrypted registered
[    2.657365] AppArmor: AppArmor sha256 policy hashing enabled
[    2.705057] rockchip-dw-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[    2.705126] rockchip-dw-pcie 3c0000000.pcie:       IO 0x00f4100000..0x00f41fffff -> 0x00f4100000
[    2.705162] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x00f4200000..0x00f5ffffff -> 0x00f4200000
[    2.705187] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x0300000000..0x033fffffff -> 0x0040000000
[    2.705394] rockchip-dw-pcie 3c0000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G
[    2.808338] rockchip-dw-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00
[    2.808373] pci_bus 0000:00: root bus resource [bus 00-0f]
[    2.808393] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff])
[    2.808409] pci_bus 0000:00: root bus resource [mem 0xf4200000-0xf5ffffff]
[    2.808425] pci_bus 0000:00: root bus resource [mem 0x300000000-0x33fffffff] (bus address [0x40000000-0x7fffffff])
[    2.808480] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400 PCIe Root Port
[    2.808520] pci 0000:00:00.0: ROM [mem 0x00000000-0x0000ffff pref]
[    2.808538] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.808557] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    2.808573] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    2.808594] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    2.808689] pci 0000:00:00.0: supports D1 D2
[    2.808704] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.817565] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[    2.817925] pci 0000:00:00.0: ROM [mem 0xf4200000-0xf420ffff pref]: assigned
[    2.817955] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.817981] pci_bus 0000:00: resource 4 [io  0x0000-0xfffff]
[    2.817996] pci_bus 0000:00: resource 5 [mem 0xf4200000-0xf5ffffff]
[    2.818010] pci_bus 0000:00: resource 6 [mem 0x300000000-0x33fffffff]
[    2.821017] pcieport 0000:00:00.0: PME: Signaling with IRQ 37
[    2.821550] pcieport 0000:00:00.0: AER: enabled with IRQ 37
[    2.822726] ahci-dwc fc400000.sata: supply ahci not found, using dummy regulator
[    2.822938] ahci-dwc fc400000.sata: supply phy not found, using dummy regulator
[    2.823115] ahci-dwc fc400000.sata: supply target not found, using dummy regulator
[    2.823223] ahci-dwc fc400000.sata: PMPn is limited up to 5 ports
[    2.823366] ahci-dwc fc400000.sata: forcing port_map 0x0 -> 0x1
[    2.823431] ahci-dwc fc400000.sata: AHCI vers 0001.0300, 32 command slots, 6 Gbps, platform mode
[    2.823451] ahci-dwc fc400000.sata: 1/1 ports implemented (port mask 0x1)
[    2.823467] ahci-dwc fc400000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[    2.823504] ahci-dwc fc400000.sata: port 0 is not capable of FBS
[    2.825266] scsi host0: ahci-dwc
[    2.825714] ata1: SATA max UDMA/133 mmio [mem 0xfc400000-0xfc400fff] port 0x100 irq 38 lpm-pol 0
[    2.933776] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    2.933870] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    2.933889] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    2.933960] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 64,32 bit host data width,256 deep fifo
[    2.934666] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    2.948705] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    2.956428] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[    2.956478] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 1
[    2.956676] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010
[    2.956754] xhci-hcd xhci-hcd.7.auto: irq 67, io mem 0xfcc00000
[    2.956992] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[    2.957021] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 2
[    2.957045] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed
[    2.957371] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.957393] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.957407] usb usb1: Product: xHCI Host Controller
[    2.957421] usb usb1: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.957433] usb usb1: SerialNumber: xhci-hcd.7.auto
[    2.958244] hub 1-0:1.0: USB hub found
[    2.958316] hub 1-0:1.0: 1 port detected
[    2.958957] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.959196] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[    2.959219] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.959234] usb usb2: Product: xHCI Host Controller
[    2.959246] usb usb2: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.959258] usb usb2: SerialNumber: xhci-hcd.7.auto
[    2.960019] hub 2-0:1.0: USB hub found
[    2.960090] hub 2-0:1.0: 1 port detected
[    2.963267] WCN: marlin_init entry!
[    2.963988] of_cfs_init
[    2.964049] of_cfs_init: OK
[    2.964317] ehci-platform fd800000.usb: EHCI Host Controller
[    2.964352] ohci-platform fd840000.usb: Generic Platform OHCI controller
[    2.964362] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 3
[    2.964397] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 4
[    2.964560] ehci-platform fd800000.usb: irq 69, io mem 0xfd800000
[    2.964593] ohci-platform fd840000.usb: irq 71, io mem 0xfd840000
[    2.964754] ehci-platform fd880000.usb: EHCI Host Controller
[    2.964796] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[    2.964796] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 5
[    2.964837] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 6
[    2.964958] ehci-platform fd880000.usb: irq 70, io mem 0xfd880000
[    2.964984] ohci-platform fd8c0000.usb: irq 72, io mem 0xfd8c0000
[    2.967376] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    2.975889] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[    2.976412] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.976443] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.976458] usb usb3: Product: EHCI Host Controller
[    2.976469] usb usb3: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ehci_hcd
[    2.976481] usb usb3: SerialNumber: fd800000.usb
[    2.977577] hub 3-0:1.0: USB hub found
[    2.977661] hub 3-0:1.0: 1 port detected
[    2.991813] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[    2.992273] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.992302] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.992317] usb usb5: Product: EHCI Host Controller
[    2.992329] usb usb5: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ehci_hcd
[    2.992341] usb usb5: SerialNumber: fd880000.usb
[    2.993264] hub 5-0:1.0: USB hub found
[    2.993356] hub 5-0:1.0: 1 port detected
[    3.024227] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[    3.024262] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.024276] usb usb6: Product: Generic Platform OHCI controller
[    3.024288] usb usb6: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ohci_hcd
[    3.024301] usb usb6: SerialNumber: fd8c0000.usb
[    3.025243] hub 6-0:1.0: USB hub found
[    3.025333] hub 6-0:1.0: 1 port detected
[    3.026256] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[    3.026288] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.026303] usb usb4: Product: Generic Platform OHCI controller
[    3.026315] usb usb4: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ohci_hcd
[    3.026327] usb usb4: SerialNumber: fd840000.usb
[    3.027188] hub 4-0:1.0: USB hub found
[    3.027276] hub 4-0:1.0: 1 port detected
[    3.038455] mmc0: new HS200 MMC card at address 0001
[    3.039867] mmcblk0: mmc0:0001 DV4032 29.1 GiB
[    3.046945] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    3.046973] GPT:10625023 != 61071359
[    3.046987] GPT:Alternate GPT header not at the end of the disk.
[    3.046994] GPT:10625023 != 61071359
[    3.047002] GPT: Use GNU Parted to correct GPT errors.
[    3.047042]  mmcblk0: p1 p2
[    3.048386] mmcblk0boot0: mmc0:0001 DV4032 4.00 MiB
[    3.051028] mmcblk0boot1: mmc0:0001 DV4032 4.00 MiB
[    3.053353] mmcblk0rpmb: mmc0:0001 DV4032 16.0 MiB, chardev (243:0)
[    3.057043] clk: Disabling unused clocks
[    3.059228] PM: genpd: Disabling unused power domains
[    3.134709] ata1: SATA link down (SStatus 0 SControl 300)
[    3.138033] Freeing unused kernel memory: 5312K
[    3.138282] Run /init as init process
[    3.138296]   with arguments:
[    3.138307]     /init
[    3.138316]     splash
[    3.138325]   with environment:
[    3.138333]     HOME=/
[    3.138342]     TERM=linux
[    3.138351]     ubootpart=41a72af7-ee03-854a-8ec3-780abdbcac11
[    3.138360]     cgroup_enable=memory
[    3.138368]     cgroup_memory=1
[    3.223845] usb 3-1: new high-speed USB device number 2 using ehci-platform
[    3.379165] usb 3-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[    3.379201] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.379216] usb 3-1: Product: USB2.0 Hub
[    3.380461] hub 3-1:1.0: USB hub found
[    3.380969] hub 3-1:1.0: 4 ports detected
[    3.870119] rk808-rtc rk808-rtc.4.auto: registered as rtc0
[    3.874113] rk808-rtc rk808-rtc.4.auto: setting system clock to 2017-08-05T09:03:38 UTC (1501923818)
[    3.911973] panfrost fde60000.gpu: clock rate = 594000000
[    3.912044] panfrost fde60000.gpu: bus_clock rate = 500000000
[    3.921437] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    3.921474] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    3.921490] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    3.921507] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    3.948618] spi-nor spi4.0: supply vcc not found, using dummy regulator
[    3.948628] [drm] Initialized panfrost 1.3.0 for fde60000.gpu on minor 0
[    3.949572] spi-nor spi4.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    3.955184] random: crng init done
[    4.020964] phy phy-fe8c0000.phy.6: lane number 0, val 1
[    4.020998] phy phy-fe8c0000.phy.6: lane number 1, val 2
[    4.021010] phy phy-fe8c0000.phy.6: bifurcation enabled
[    4.021528] phy phy-fe8c0000.phy.6: rockchip_p3phy_rk3568_init: lock failed 0x6890000, check input refclk and power supply
[    4.021552] phy phy-fe8c0000.phy.6: phy init failed --> -110
[    4.022252] rockchip-dw-pcie 3c0800000.pcie: probe with driver rockchip-dw-pcie failed with error -110
[    4.024936] phy phy-fe8c0000.phy.6: lane number 0, val 1
[    4.024970] phy phy-fe8c0000.phy.6: lane number 1, val 2
[    4.024983] phy phy-fe8c0000.phy.6: bifurcation enabled
[    4.025502] phy phy-fe8c0000.phy.6: rockchip_p3phy_rk3568_init: lock failed 0x6890000, check input refclk and power supply
[    4.025527] phy phy-fe8c0000.phy.6: phy init failed --> -110
[    4.025586] rockchip-dw-pcie 3c0400000.pcie: probe with driver rockchip-dw-pcie failed with error -110
[    5.841347] EXT4-fs (mmcblk0p2): mounted filesystem de2a5213-e4a0-4e17-8a41-545c79873d46 ro with writeback data mode. Quota mode: none.
[    6.317227] systemd[1]: System time before build time, advancing clock.
[    6.329831] systemd[1]: Inserted module 'autofs4'
[    6.368100] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    6.369246] systemd[1]: Detected architecture arm64.
[    6.371213] systemd[1]: Hostname set to <yy3568>.
[    6.373329] systemd[1]: Initializing machine ID from random generator.
[    6.373622] systemd[1]: Installed transient /etc/machine-id file.
[    6.531343] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[    6.613040] block mmcblk0: the capability attribute has been deprecated.
[    6.825919] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[    7.213576] systemd[1]: Queued start job for default target Graphical Interface.
[    7.259435] systemd[1]: Created slice Slice /system/modprobe.
[    7.262737] systemd[1]: Created slice Slice /system/serial-getty.
[    7.265655] systemd[1]: Created slice Slice /system/systemd-fsck.
[    7.267710] systemd[1]: Created slice User and Session Slice.
[    7.268505] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.269978] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.270744] systemd[1]: Reached target User and Group Name Lookups.
[    7.271119] systemd[1]: Reached target Slice Units.
[    7.271404] systemd[1]: Reached target Swaps.
[    7.271651] systemd[1]: Reached target System Time Set.
[    7.272155] systemd[1]: Reached target Local Verity Protected Volumes.
[    7.296939] systemd[1]: Listening on RPCbind Server Activation Socket.
[    7.298266] systemd[1]: Listening on Syslog Socket.
[    7.299328] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.300064] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.301676] systemd[1]: Listening on Journal Audit Socket.
[    7.302703] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.304018] systemd[1]: Listening on Journal Socket.
[    7.310073] systemd[1]: Listening on udev Control Socket.
[    7.311185] systemd[1]: Listening on udev Kernel Socket.
[    7.317646] systemd[1]: Mounting Huge Pages File System...
[    7.324601] systemd[1]: Mounting POSIX Message Queue File System...
[    7.332040] systemd[1]: Mounting Kernel Debug File System...
[    7.339032] systemd[1]: Mounting Kernel Trace File System...
[    7.340513] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    7.348547] systemd[1]: Starting Restore / save the current clock...
[    7.356637] systemd[1]: Starting Set the console keyboard layout...
[    7.365046] systemd[1]: Starting Create List of Static Device Nodes...
[    7.373662] systemd[1]: Starting Load Kernel Module configfs...
[    7.382276] systemd[1]: Starting Load Kernel Module drm...
[    7.391227] systemd[1]: Starting Load Kernel Module efi_pstore...
[    7.399687] systemd[1]: Starting Load Kernel Module fuse...
[    7.401291] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.415272] systemd[1]: Starting Load Kernel Modules...
[    7.424180] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.432904] systemd[1]: Starting Coldplug All udev Devices...
[    7.447045] systemd[1]: Mounted Huge Pages File System.
[    7.449586] systemd[1]: Mounted POSIX Message Queue File System.
[    7.451908] systemd[1]: Mounted Kernel Debug File System.
[    7.454169] systemd[1]: Mounted Kernel Trace File System.
[    7.458998] systemd[1]: Finished Restore / save the current clock.
[    7.463939] systemd[1]: Finished Create List of Static Device Nodes.
[    7.466692] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    7.469769] systemd[1]: Finished Load Kernel Module configfs.
[    7.473457] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    7.480004] systemd[1]: Finished Load Kernel Module drm.
[    7.482458] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    7.485719] systemd[1]: Finished Load Kernel Module efi_pstore.
[    7.492398] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    7.494535] systemd[1]: Finished Load Kernel Module fuse.
[    7.497679] EXT4-fs (mmcblk0p2): re-mounted de2a5213-e4a0-4e17-8a41-545c79873d46 r/w. Quota mode: none.
[    7.498837] systemd[1]: Finished Load Kernel Modules.
[    7.511839] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.540417] systemd[1]: Mounting FUSE Control File System...
[    7.547304] systemd[1]: Mounting Kernel Configuration File System...
[    7.548309] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    7.556383] systemd[1]: Starting Load/Save Random Seed...
[    7.569406] systemd[1]: Starting Apply Kernel Variables...
[    7.588631] systemd[1]: Starting Create System Users...
[    7.610730] systemd[1]: Mounted FUSE Control File System.
[    7.613031] systemd[1]: Mounted Kernel Configuration File System.
[    7.623458] systemd[1]: Finished Load/Save Random Seed.
[    7.625464] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[    7.655225] systemd[1]: Finished Create System Users.
[    7.683615] systemd[1]: Finished Apply Kernel Variables.
[    7.692411] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.753849] systemd[1]: Finished Set the console keyboard layout.
[    7.757876] systemd[1]: Finished Create Static Device Nodes in /dev.
[    7.759112] systemd[1]: Reached target Preparation for Local File Systems.
[    7.796270] systemd[1]: Mounting /tmp...
[    7.807909] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    7.814108] systemd[1]: Mounted /tmp.
[    8.097802] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    8.129870] systemd[1]: Finished Coldplug All udev Devices.
[    8.172364] systemd[1]: Starting Show Plymouth Boot Screen...
[    8.231995] systemd[1]: Started Show Plymouth Boot Screen.
[    8.233129] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[    8.234308] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[    8.234639] systemd[1]: Reached target Local Encrypted Volumes.
[    8.606928] mc: Linux media interface: v0.10
[    8.688457] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey.3.auto/input/input0
[    8.739993] videodev: Linux video capture interface: v2.00
[    8.764699] rk2-crypto fe380000.crypto: will run requests pump with realtime priority
[    8.764785] rk2-crypto fe380000.crypto: Registers crypto algos
[    8.764792] rk2-crypto fe380000.crypto: Register ecb(aes) as ecb-aes-rk2
[    8.764845] rk2-crypto fe380000.crypto: Register cbc(aes) as cbc-aes-rk2
[    8.764860] rk2-crypto fe380000.crypto: Register xts(aes) as xts-aes-rk2
[    8.764874] rk2-crypto fe380000.crypto: Register md5 as rk2-md5 3
[    8.764889] rk2-crypto fe380000.crypto: Register sha1 as rk2-sha1 4
[    8.764905] rk2-crypto fe380000.crypto: Register sha256 as rk2-sha256 5
[    8.764919] rk2-crypto fe380000.crypto: Register sha384 as rk2-sha384 6
[    8.764932] rk2-crypto fe380000.crypto: Register sha512 as rk2-sha512 7
[    8.764945] rk2-crypto fe380000.crypto: Register sm3 as rk2-sm3 8
[    8.829499] rockchip-rga fdeb0000.rga: HW Version: 0x03.02
[    8.830002] rockchip_vdec2: module is from the staging directory, the quality is unknown, you have been warned.
[    8.850073] systemd[1]: Found device /dev/disk/by-uuid/3EBA-7644.
[    8.865368] rockchip-rga fdeb0000.rga: Registered rockchip-rga as /dev/video0
[    8.876982] systemd[1]: Starting File System Check on /dev/disk/by-uuid/3EBA-7644...
[    8.903175] hantro-vpu fdea0000.video-codec: Adding to iommu group 0
[    8.904321] hantro-vpu fdea0000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2
[    8.905473] hantro-vpu fdee0000.video-codec: Adding to iommu group 1
[    8.907885] hantro-vpu fdee0000.video-codec: registered rockchip,rk3568-vepu-enc as /dev/video3
[    8.916668] systemd[1]: Found device /dev/ttyS2.
[    8.948546] systemd[1]: Started File System Check Daemon to report status.
[    8.982837] systemd[1]: Finished File System Check on /dev/disk/by-uuid/3EBA-7644.
[    8.988625] systemd[1]: Mounting /boot...
[    9.030354] systemd[1]: Mounted /boot.
[    9.031205] systemd[1]: Reached target Local File Systems.
[    9.049439] systemd[1]: Starting Armbian ZRAM config...
[    9.055279] systemd[1]: Starting Set console font and keymap...
[    9.064534] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.065579] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[    9.072269] systemd[1]: Starting Set Up Additional Binary Formats...
[    9.072580] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    9.082948] systemd[1]: Starting Commit a transient machine-id on disk...
[    9.085620] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.086521] systemd[1]: Received SIGRTMIN+20 from PID 175 (plymouthd).
[    9.098605] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 326 (systemd-binfmt)
[    9.108171] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[    9.136056] systemd[1]: etc-machine\x2did.mount: Deactivated successfully.
[    9.139106] systemd[1]: Finished Commit a transient machine-id on disk.
[    9.140132] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[    9.150078] systemd[1]: Finished Set Up Additional Binary Formats.
[    9.268366] zram: Added device: zram0
[    9.268892] zram: Added device: zram1
[    9.272574] zram: Added device: zram2
[    9.335217] zram0: detected capacity change from 0 to 4012952
[    9.353350] Adding 2006472k swap on /dev/zram0.  Priority:5 extents:1 across:2006472k SS
[    9.391417] zram1: detected capacity change from 0 to 102400
[    9.421596] systemd[1]: Finished Armbian ZRAM config.
[    9.444580] systemd[1]: Starting Armbian memory supported logging...
[    9.493608] EXT4-fs (zram1): mounted filesystem ef0c2a86-bb36-4b01-8cee-d5ff3a7a96ad r/w without journal. Quota mode: none.
[    9.955138] systemd[1]: Finished Armbian memory supported logging.
[    9.976514] systemd[1]: Starting Journal Service...
[   10.125420] systemd[1]: Started Journal Service.
[   10.175941] systemd-journald[435]: Received client request to flush runtime journal.
[   10.325494] RPC: Registered named UNIX socket transport module.
[   10.325509] RPC: Registered udp transport module.
[   10.325513] RPC: Registered tcp transport module.
[   10.325517] RPC: Registered tcp-with-tls transport module.
[   10.325520] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   11.348922] EXT4-fs (mmcblk0p2): resizing filesystem from 1258491 to 7487488 blocks
[   11.536331] EXT4-fs (mmcblk0p2): resized filesystem to 7487488
[   33.768240] vdd_npu: disabling
[   33.769497] vdda0v9_image: disabling
[   33.771188] vcca1v8_image: disabling
[   53.431847] usb 3-1.1: new full-speed USB device number 3 using ehci-platform
[   53.530354] usb 3-1.1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   53.530412] usb 3-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   53.530441] usb 3-1.1: Product: USB2.0 HUB
[   53.532313] hub 3-1.1:1.0: USB hub found
[   53.532752] hub 3-1.1:1.0: 4 ports detected
[   74.691339] usb 3-1.1: USB disconnect, device number 3
[   74.767910] usb 3-1.2: new full-speed USB device number 4 using ehci-platform
[   74.866461] usb 3-1.2: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   74.866518] usb 3-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   74.866549] usb 3-1.2: Product: USB2.0 HUB
[   74.868281] hub 3-1.2:1.0: USB hub found
[   74.868626] hub 3-1.2:1.0: 4 ports detected
[  118.679009] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[  118.690355] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[  118.690850] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
Edited by Hqnicolas
Posted (edited)
Mainline Kernel 6.14 :thumbup:
PR: https://github.com/armbian/build/pull/7908
cat dmesg
Quote
[    0.000000] NODE_DATA(0) allocated [mem 0x1ff751a40-0x1ff7541ff]
[    0.000000] Kernel command line: root=UUID=94ea9275-a0cd-4974-b523-8269456a7d02 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=5e425cc6-0a96-1149-b209-be03a1570889 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cma=256M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=ddr-v1.21-2d653b3476,bl31-v1.44,uboot-rmbian-201-03/04/2025
[    0.000000] Unknown kernel command line parameters "splash ubootpart=5e425cc6-0a96-1149-b209-be03a1570889 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    0.001341] Console: colour dummy device 80x25
[    0.001365] printk: legacy console [tty1] enabled
[    0.001564] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001589] pid_max: default: 32768 minimum: 301
[    0.001701] LSM: initializing lsm=capability,yama,apparmor
[    0.001793] Yama: becoming mindful.
[    0.002140] AppArmor: AppArmor initialized
[    0.002301] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002340] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.031827] rcu: Hierarchical SRCU implementation.
[    0.031850] rcu:     Max phase no-delay instances is 1000.
[    0.032370] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.033586] EFI services will not be available.
[    0.035872] smp: Bringing up secondary CPUs ...
[    0.048063] Detected VIPT I-cache on CPU1
[    0.048166] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.048228] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.056285] Detected VIPT I-cache on CPU2
[    0.056382] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.056433] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.068161] Detected VIPT I-cache on CPU3
[    0.068257] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.068308] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.068492] smp: Brought up 1 node, 4 CPUs
[    0.068520] SMP: Total of 4 processors activated.
[    0.068528] CPU: All CPU(s) started at EL2
[    0.068537] CPU features: detected: 32-bit EL0 Support
[    0.068545] CPU features: detected: 32-bit EL1 Support
[    0.068555] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.068566] CPU features: detected: Common not Private translations
[    0.068574] CPU features: detected: CRC32 instructions
[    0.068590] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.068598] CPU features: detected: LSE atomic instructions
[    0.068606] CPU features: detected: Privileged Access Never
[    0.068614] CPU features: detected: RAS Extension Support
[    0.068626] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.068711] alternatives: applying system-wide alternatives
[    0.073669] Memory: 3714892K/4192256K available (16576K kernel code, 2906K rwdata, 11224K rodata, 5312K init, 785K bss, 210988K reserved, 262144K cma-reserved)
[    0.075567] devtmpfs: initialized
[    0.099152] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.099209] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.107832] 23504 pages in range for non-PLT usage
[    0.107860] 515024 pages in range for PLT usage
[    0.108315] pinctrl core: initialized pinctrl subsystem
[    0.109173] DMI not present or invalid.
[    0.113372] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.115662] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.116900] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.118078] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.118182] audit: initializing netlink subsys (disabled)
[    0.118541] audit: type=2000 audit(0.116:1): state=initialized audit_enabled=0 res=1
[    0.121697] thermal_sys: Registered thermal governor 'fair_share'
[    0.121716] thermal_sys: Registered thermal governor 'bang_bang'
[    0.121726] thermal_sys: Registered thermal governor 'step_wise'
[    0.121734] thermal_sys: Registered thermal governor 'user_space'
[    0.121861] cpuidle: using governor menu
[    0.122360] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.122600] ASID allocator initialised with 65536 entries
[    0.122976] Serial: AMBA PL011 UART driver
[    0.140512] /vop@fe040000: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    0.140626] /hdmi@fe0a0000: Fixed dependency cycle(s) with /vop@fe040000
[    0.146258] /pcie@fe260000: Fixed dependency cycle(s) with /pcie@fe260000/legacy-interrupt-controller
[    0.166209] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.167112] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.167729] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.168156] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.168711] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.169113] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.169664] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.170108] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.170560] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    0.170971] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.175046] /pcie@fe280000: Fixed dependency cycle(s) with /pcie@fe280000/legacy-interrupt-controller
[    0.176987] /hdmi@fe0a0000: Fixed dependency cycle(s) with /hdmi-con
[    0.177096] /hdmi-con: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    0.183438] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.183462] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.183474] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.183482] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.183492] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.183500] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.183509] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.183516] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.185576] cryptd: max_cpu_qlen set to 1000
[    0.254305] raid6: neonx8   gen()  1408 MB/s
[    0.322527] raid6: neonx4   gen()  1437 MB/s
[    0.390738] raid6: neonx2   gen()  1322 MB/s
[    0.458974] raid6: neonx1   gen()  1074 MB/s
[    0.527171] raid6: int64x8  gen()   910 MB/s
[    0.595418] raid6: int64x4  gen()  1051 MB/s
[    0.663654] raid6: int64x2  gen()   939 MB/s
[    0.731847] raid6: int64x1  gen()   671 MB/s
[    0.731862] raid6: using algorithm neonx4 gen() 1437 MB/s
[    0.800013] raid6: .... xor() 1103 MB/s, rmw enabled
[    0.800027] raid6: using neon recovery algorithm
[    0.801570] iommu: Default domain type: Translated
[    0.801590] iommu: DMA domain TLB invalidation policy: strict mode
[    0.802682] SCSI subsystem initialized
[    0.803036] libata version 3.00 loaded.
[    0.803375] usbcore: registered new interface driver usbfs
[    0.803429] usbcore: registered new interface driver hub
[    0.803495] usbcore: registered new device driver usb
[    0.804278] pps_core: LinuxPPS API ver. 1 registered
[    0.804292] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.804330] PTP clock support registered
[    0.804395] EDAC MC: Ver: 3.0.0
[    0.804950] scmi_core: SCMI protocol bus registered
[    0.806691] NetLabel: Initializing
[    0.806707] NetLabel:  domain hash size = 128
[    0.806717] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.806819] NetLabel:  unlabeled traffic allowed by default
[    0.807132] vgaarb: loaded
[    0.807967] clocksource: Switched to clocksource arch_sys_counter
[    0.808858] VFS: Disk quotas dquot_6.6.0
[    0.808926] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.809806] AppArmor: AppArmor Filesystem Enabled
[    0.825866] NET: Registered PF_INET protocol family
[    0.826225] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.899303] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.899536] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.899664] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.900299] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.901226] TCP: Hash tables configured (established 32768 bind 32768)
[    0.901470] UDP hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.901670] UDP-Lite hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.902096] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.902150] NET: Registered PF_XDP protocol family
[    0.902176] PCI: CLS 0 bytes, default 64
[    0.902606] Trying to unpack rootfs image as initramfs...
[    0.908065] kvm [1]: nv: 566 coarse grained trap handlers
[    0.908754] kvm [1]: IPA Size Limit: 40 bits
[    0.908802] kvm [1]: GICv3: no GICV resource entry
[    0.908814] kvm [1]: disabling GICv2 emulation
[    0.908860] kvm [1]: GIC system register CPU interface enabled
[    0.908902] kvm [1]: vgic interrupt IRQ9
[    0.908962] kvm [1]: VHE mode initialized successfully
[    0.914681] Initialise system trusted keyrings
[    0.914769] Key type blacklist registered
[    0.915179] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    0.915257] zbud: loaded
[    0.916195] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.916929] fuse: init (API version 7.42)
[    0.919570] integrity: Platform Keyring initialized
[    0.992525] xor: measuring software checksum speed
[    0.994459]    8regs           :  1718 MB/sec
[    0.996599]    32regs          :  1547 MB/sec
[    0.998518]    arm64_neon      :  1726 MB/sec
[    0.998528] xor: using function: arm64_neon (1726 MB/sec)
[    0.998549] Key type asymmetric registered
[    0.998559] Asymmetric key parser 'x509' registered
[    0.998742] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.999209] io scheduler mq-deadline registered
[    0.999225] io scheduler kyber registered
[    0.999302] io scheduler bfq registered
[    2.503085] Freeing initrd memory: 26360K
[    2.515507] ledtrig-cpu: registered to indicate activity on CPUs
[    2.524738] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.524769] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.528071] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.528100] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    2.531307] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    2.536971] printk: legacy console [ttyS2] disabled
[    2.537495] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 25, base_baud = 1500000) is a 16550A
[    2.537773] printk: legacy console [ttyS2] enabled
[    2.539686] Serial: AMBA driver
[    2.553098] loop: module loaded
[    2.555126] Key type psk registered
[    2.561289] thunder_xcv, ver 1.0
[    2.561352] thunder_bgx, ver 1.0
[    2.561407] nicpf, ver 1.0
[    2.565675] usbcore: registered new interface driver usb-storage
[    2.568451] mousedev: PS/2 mouse device common for all mice
[    2.569156] i2c_dev: i2c /dev entries driver
[    2.571795] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    2.579441] sdhci: Secure Digital Host Controller Interface driver
[    2.579464] sdhci: Copyright(c) Pierre Ossman
[    2.579521] Synopsys Designware Multimedia Card Interface Driver
[    2.580777] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.581959] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[    2.582048] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[    2.582067] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[    2.582142] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo
[    2.582415] dwmmc_rockchip fe000000.mmc: Got CD GPIO
[    2.583615] arm-scmi arm-scmi.0.auto: Using scmi_smc_transport
[    2.583636] arm-scmi arm-scmi.0.auto: SCMI max-rx-timeout: 30ms / max-msg-size: 104bytes / max-msg: 20
[    2.583847] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16
[    2.584325] arm-scmi arm-scmi.0.auto: SCMI Notifications - Core Enabled.
[    2.584404] arm-scmi arm-scmi.0.auto: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    2.586951] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    2.587329] hid: raw HID events driver (C) Jiri Kosina
[    2.587468] usbcore: registered new interface driver usbhid
[    2.587481] usbhid: USB HID core driver
[    2.589275] rockchip-dfi fe230000.dfi: dfi initialized, dram type: 0x7, channels: 1
[    2.591400] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 (0,8000003f) counters available
[    2.593374] NET: Registered PF_INET6 protocol family
[    2.595294] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    2.635629] Segment Routing with IPv6
[    2.635747] In-situ OAM (IOAM) with IPv6
[    2.635893] NET: Registered PF_PACKET protocol family
[    2.636214] 8021q: 802.1Q VLAN Support v1.8
[    2.636325] Key type dns_resolver registered
[    2.649683] registered taskstats version 1
[    2.650181] Loading compiled-in X.509 certificates
[    2.652062] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[    2.669772] zswap: loaded using pool zstd/z3fold
[    2.670215] Demotion targets for Node 0: null
[    2.670450] Key type .fscrypt registered
[    2.670465] Key type fscrypt-provisioning registered
[    2.674157] Btrfs loaded, zoned=yes, fsverity=yes
[    2.674458] Key type encrypted registered
[    2.674482] AppArmor: AppArmor sha256 policy hashing enabled
[    2.828080] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    2.828169] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    2.828188] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    2.828258] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 63,32 bit host data width,256 deep fifo
[    2.829001] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    2.839604] rockchip-dw-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[    2.839677] rockchip-dw-pcie 3c0000000.pcie:       IO 0x00f4100000..0x00f41fffff -> 0x00f4100000
[    2.839722] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x00f4200000..0x00f5ffffff -> 0x00f4200000
[    2.839748] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x0300000000..0x033fffffff -> 0x0040000000
[    2.840036] rockchip-dw-pcie 3c0000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G
[    2.844146] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    2.864634] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    2.932827] mmc0: new HS200 MMC card at address 0001
[    2.933948] mmcblk0: mmc0:0001 DV4032 29.1 GiB
[    2.939302]  mmcblk0: p1 p2
[    2.940516] mmcblk0boot0: mmc0:0001 DV4032 4.00 MiB
[    2.942837] mmcblk0boot1: mmc0:0001 DV4032 4.00 MiB
[    2.944748] rockchip-dw-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00
[    2.944786] pci_bus 0000:00: root bus resource [bus 00-0f]
[    2.944807] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xf4100000-0xf41fffff])
[    2.944822] pci_bus 0000:00: root bus resource [mem 0xf4200000-0xf5ffffff]
[    2.944838] pci_bus 0000:00: root bus resource [mem 0x300000000-0x33fffffff] (bus address [0x40000000-0x7fffffff])
[    2.944893] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400 PCIe Root Port
[    2.944933] pci 0000:00:00.0: ROM [mem 0x00000000-0x0000ffff pref]
[    2.944950] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.944968] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    2.944983] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    2.945003] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    2.945097] pci 0000:00:00.0: supports D1 D2
[    2.945112] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.945231] mmcblk0rpmb: mmc0:0001 DV4032 16.0 MiB, chardev (243:0)
[    2.954249] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[    2.954631] pci 0000:00:00.0: ROM [mem 0xf4200000-0xf420ffff pref]: assigned
[    2.954660] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.954687] pci_bus 0000:00: resource 4 [io  0x0000-0xfffff]
[    2.954702] pci_bus 0000:00: resource 5 [mem 0xf4200000-0xf5ffffff]
[    2.954716] pci_bus 0000:00: resource 6 [mem 0x300000000-0x33fffffff]
[    2.957759] pcieport 0000:00:00.0: PME: Signaling with IRQ 69
[    2.958315] pcieport 0000:00:00.0: AER: enabled with IRQ 69
[    2.968326] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
[    2.969815] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
[    2.969842] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
[    2.969868] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[    2.969904] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 1
[    2.970097] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010
[    2.970175] xhci-hcd xhci-hcd.7.auto: irq 70, io mem 0xfcc00000
[    2.970416] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[    2.970445] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 2
[    2.970470] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed
[    2.970834] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.970857] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.970870] usb usb1: Product: xHCI Host Controller
[    2.970885] usb usb1: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.970897] usb usb1: SerialNumber: xhci-hcd.7.auto
[    2.971762] hub 1-0:1.0: USB hub found
[    2.971830] hub 1-0:1.0: 1 port detected
[    2.972517] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.972765] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[    2.972786] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.972801] usb usb2: Product: xHCI Host Controller
[    2.972813] usb usb2: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.972825] usb usb2: SerialNumber: xhci-hcd.7.auto
[    2.973532] hub 2-0:1.0: USB hub found
[    2.973596] hub 2-0:1.0: 1 port detected
[    2.978794] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    2.978841] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 3
[    2.979059] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010
[    2.979146] xhci-hcd xhci-hcd.8.auto: irq 71, io mem 0xfd000000
[    2.979396] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    2.979425] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4
[    2.979448] xhci-hcd xhci-hcd.8.auto: Host supports USB 3.0 SuperSpeed
[    2.979770] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.979791] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.979807] usb usb3: Product: xHCI Host Controller
[    2.979819] usb usb3: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.979831] usb usb3: SerialNumber: xhci-hcd.8.auto
[    2.980658] hub 3-0:1.0: USB hub found
[    2.980738] hub 3-0:1.0: 1 port detected
[    2.981346] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    2.981591] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[    2.981612] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.981627] usb usb4: Product: xHCI Host Controller
[    2.981639] usb usb4: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 xhci-hcd
[    2.981652] usb usb4: SerialNumber: xhci-hcd.8.auto
[    2.982358] hub 4-0:1.0: USB hub found
[    2.982425] hub 4-0:1.0: 1 port detected
[    2.985390] WCN: marlin_init entry!
[    2.986029] of_cfs_init
[    2.986090] of_cfs_init: OK
[    2.986810] ehci-platform fd800000.usb: EHCI Host Controller
[    2.986856] ohci-platform fd840000.usb: Generic Platform OHCI controller
[    2.986865] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 5
[    2.986896] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 6
[    2.987086] ehci-platform fd800000.usb: irq 72, io mem 0xfd800000
[    2.987132] ohci-platform fd840000.usb: irq 74, io mem 0xfd840000
[    2.987210] ehci-platform fd880000.usb: EHCI Host Controller
[    2.987255] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[    2.987258] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 7
[    2.987298] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 8
[    2.987471] ehci-platform fd880000.usb: irq 73, io mem 0xfd880000
[    2.987504] ohci-platform fd8c0000.usb: irq 75, io mem 0xfd8c0000
[    2.996076] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[    2.996552] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    2.996583] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.996597] usb usb5: Product: EHCI Host Controller
[    2.996610] usb usb5: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ehci_hcd
[    2.996621] usb usb5: SerialNumber: fd800000.usb
[    2.997545] hub 5-0:1.0: USB hub found
[    2.997628] hub 5-0:1.0: 1 port detected
[    3.008045] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[    3.008505] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[    3.008536] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.008550] usb usb7: Product: EHCI Host Controller
[    3.008562] usb usb7: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ehci_hcd
[    3.008574] usb usb7: SerialNumber: fd880000.usb
[    3.009506] hub 7-0:1.0: USB hub found
[    3.009588] hub 7-0:1.0: 1 port detected
[    3.044452] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[    3.044488] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.044503] usb usb6: Product: Generic Platform OHCI controller
[    3.044516] usb usb6: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ohci_hcd
[    3.044528] usb usb6: SerialNumber: fd840000.usb
[    3.045522] hub 6-0:1.0: USB hub found
[    3.045635] hub 6-0:1.0: 1 port detected
[    3.046605] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.14
[    3.046641] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.046655] usb usb8: Product: Generic Platform OHCI controller
[    3.046668] usb usb8: Manufacturer: Linux 6.14.0-rc4-edge-rockchip64 ohci_hcd
[    3.046679] usb usb8: SerialNumber: fd8c0000.usb
[    3.047706] hub 8-0:1.0: USB hub found
[    3.047796] hub 8-0:1.0: 1 port detected
[    3.082885] clk: Disabling unused clocks
[    3.085096] PM: genpd: Disabling unused power domains
[    3.089964] Freeing unused kernel memory: 5312K
[    3.090509] Run /init as init process
[    3.090523]   with arguments:
[    3.090533]     /init
[    3.090542]     splash
[    3.090553]   with environment:
[    3.090561]     HOME=/
[    3.090571]     TERM=linux
[    3.090579]     ubootpart=5e425cc6-0a96-1149-b209-be03a1570889
[    3.090588]     cgroup_enable=memory
[    3.090597]     cgroup_memory=1
[    3.244040] usb 5-1: new high-speed USB device number 2 using ehci-platform
[    3.391180] usb 5-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[    3.391216] usb 5-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.391231] usb 5-1: Product: USB2.0 Hub
[    3.395341] hub 5-1:1.0: USB hub found
[    3.400037] hub 5-1:1.0: 4 ports detected
[    3.872770] rockchip-vop2 fe040000.vop: Adding to iommu group 0
[    3.889293] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm])
[    3.895586] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    3.897286] rk808-rtc rk808-rtc.4.auto: registered as rtc0
[    3.898279] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    3.899125] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[    3.900561] rk808-rtc rk808-rtc.4.auto: setting system clock to 2017-08-05T09:00:08 UTC (1501923608)
[    3.901377] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0
[    3.951591] panfrost fde60000.gpu: clock rate = 594000000
[    3.951650] panfrost fde60000.gpu: bus_clock rate = 500000000
[    3.972247] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    3.972290] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    3.972306] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    3.972324] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    3.986079] [drm] Initialized panfrost 1.3.0 for fde60000.gpu on minor 1
[    3.990289] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    3.990324] rk_gmac-dwmac fe010000.ethernet: IRQ sfty not found
[    3.990645] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    3.990925] rk_gmac-dwmac fe010000.ethernet: clock input or output? (output).
[    3.990948] rk_gmac-dwmac fe010000.ethernet: Can not read property: tx_delay.
[    3.990960] rk_gmac-dwmac fe010000.ethernet: set tx_delay to 0x30
[    3.990975] rk_gmac-dwmac fe010000.ethernet: Can not read property: rx_delay.
[    3.990985] rk_gmac-dwmac fe010000.ethernet: set rx_delay to 0x10
[    3.991007] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    3.996236] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    3.997368] random: crng init done
[    4.000972] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    4.001015] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[    4.001042] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    4.001055] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    4.001066] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    4.001076] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    4.001374] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    4.001512] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.001531] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    4.001545] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    4.001558] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    4.068985] phy phy-fe8c0000.phy.6: lane number 0, val 1
[    4.069018] phy phy-fe8c0000.phy.6: lane number 1, val 2
[    4.069032] phy phy-fe8c0000.phy.6: bifurcation enabled
[    4.069550] phy phy-fe8c0000.phy.6: rockchip_p3phy_rk3568_init: lock failed 0x6890000, check input refclk and power supply
[    4.069572] phy phy-fe8c0000.phy.6: phy init failed --> -110
[    4.069722] rockchip-dw-pcie 3c0800000.pcie: probe with driver rockchip-dw-pcie failed with error -110
[    4.158740] rk_gmac-dwmac fe2a0000.ethernet: IRQ eth_lpi not found
[    4.158776] rk_gmac-dwmac fe2a0000.ethernet: IRQ sfty not found
[    4.160360] rk_gmac-dwmac fe2a0000.ethernet: supply phy not found, using dummy regulator
[    4.161247] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (output).
[    4.161272] rk_gmac-dwmac fe2a0000.ethernet: Can not read property: tx_delay.
[    4.161280] rk_gmac-dwmac fe2a0000.ethernet: set tx_delay to 0x30
[    4.161292] rk_gmac-dwmac fe2a0000.ethernet: Can not read property: rx_delay.
[    4.161299] rk_gmac-dwmac fe2a0000.ethernet: set rx_delay to 0x10
[    4.161321] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[    4.166409] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[    4.166917] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    4.166945] rk_gmac-dwmac fe2a0000.ethernet:     DWMAC4/5
[    4.166957] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[    4.166965] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[    4.166973] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[    4.166979] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[    4.167229] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[    4.167242] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.167254] rk_gmac-dwmac fe2a0000.ethernet: Enabled RFS Flow TC (entries=10)
[    4.167263] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[    4.167271] rk_gmac-dwmac fe2a0000.ethernet: Using 32/32 bits DMA host/device width
[    4.394779] Console: switching to colour frame buffer device 240x67
[    4.497462] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    6.122887] EXT4-fs (mmcblk0p2): mounted filesystem 94ea9275-a0cd-4974-b523-8269456a7d02 ro with writeback data mode. Quota mode: none.
[    6.601959] systemd[1]: System time before build time, advancing clock.
[    6.614440] systemd[1]: Inserted module 'autofs4'
[    6.652511] systemd[1]: systemd 249.11-0ubuntu3.12 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    6.653670] systemd[1]: Detected architecture arm64.
[    6.656225] systemd[1]: Hostname set to <yy3568>.
[    6.798144] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[    6.882068] block mmcblk0: the capability attribute has been deprecated.
[    7.086269] systemd[1]: Configuration file /run/systemd/system/netplan-ovs-cleanup.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[    7.479445] systemd[1]: Queued start job for default target Graphical Interface.
[    7.516102] systemd[1]: Created slice Slice /system/modprobe.
[    7.519292] systemd[1]: Created slice Slice /system/serial-getty.
[    7.522085] systemd[1]: Created slice Slice /system/systemd-fsck.
[    7.524298] systemd[1]: Created slice User and Session Slice.
[    7.525036] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.526429] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.527158] systemd[1]: Reached target User and Group Name Lookups.
[    7.527515] systemd[1]: Reached target Slice Units.
[    7.527787] systemd[1]: Reached target Swaps.
[    7.528082] systemd[1]: Reached target System Time Set.
[    7.528523] systemd[1]: Reached target Local Verity Protected Volumes.
[    7.556504] systemd[1]: Listening on RPCbind Server Activation Socket.
[    7.557813] systemd[1]: Listening on Syslog Socket.
[    7.558820] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.559479] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.561152] systemd[1]: Listening on Journal Audit Socket.
[    7.562201] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.563389] systemd[1]: Listening on Journal Socket.
[    7.569136] systemd[1]: Listening on udev Control Socket.
[    7.570292] systemd[1]: Listening on udev Kernel Socket.
[    7.576678] systemd[1]: Mounting Huge Pages File System...
[    7.583721] systemd[1]: Mounting POSIX Message Queue File System...
[    7.591006] systemd[1]: Mounting Kernel Debug File System...
[    7.598147] systemd[1]: Mounting Kernel Trace File System...
[    7.599433] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    7.607539] systemd[1]: Starting Restore / save the current clock...
[    7.614977] systemd[1]: Starting Set the console keyboard layout...
[    7.623286] systemd[1]: Starting Create List of Static Device Nodes...
[    7.632114] systemd[1]: Starting Load Kernel Module configfs...
[    7.642255] systemd[1]: Starting Load Kernel Module drm...
[    7.652233] systemd[1]: Starting Load Kernel Module efi_pstore...
[    7.660816] systemd[1]: Starting Load Kernel Module fuse...
[    7.662253] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.680145] systemd[1]: Starting Load Kernel Modules...
[    7.688200] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.697748] systemd[1]: Starting Coldplug All udev Devices...
[    7.715837] systemd[1]: Mounted Huge Pages File System.
[    7.718912] systemd[1]: Mounted POSIX Message Queue File System.
[    7.721879] systemd[1]: Mounted Kernel Debug File System.
[    7.725117] systemd[1]: Mounted Kernel Trace File System.
[    7.731943] systemd[1]: Finished Restore / save the current clock.
[    7.737641] systemd[1]: Finished Create List of Static Device Nodes.
[    7.740230] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    7.743768] systemd[1]: Finished Load Kernel Module configfs.
[    7.746699] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    7.749293] systemd[1]: Finished Load Kernel Module drm.
[    7.751816] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    7.755217] systemd[1]: Finished Load Kernel Module efi_pstore.
[    7.758200] EXT4-fs (mmcblk0p2): re-mounted 94ea9275-a0cd-4974-b523-8269456a7d02 r/w. Quota mode: none.
[    7.758326] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    7.760645] systemd[1]: Finished Load Kernel Module fuse.
[    7.769465] systemd[1]: Finished Load Kernel Modules.
[    7.773278] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.808579] systemd[1]: Mounting FUSE Control File System...
[    7.816616] systemd[1]: Mounting Kernel Configuration File System...
[    7.817654] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    7.824909] systemd[1]: Starting Load/Save Random Seed...
[    7.833622] systemd[1]: Starting Apply Kernel Variables...
[    7.842671] systemd[1]: Starting Create System Users...
[    7.862287] systemd[1]: Mounted FUSE Control File System.
[    7.867440] systemd[1]: Mounted Kernel Configuration File System.
[    7.912475] systemd[1]: Finished Load/Save Random Seed.
[    7.914631] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[    7.918213] systemd[1]: Finished Create System Users.
[    7.952967] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.963879] systemd[1]: Finished Apply Kernel Variables.
[    8.012967] systemd[1]: Finished Create Static Device Nodes in /dev.
[    8.038624] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    8.042826] systemd[1]: Finished Set the console keyboard layout.
[    8.044248] systemd[1]: Reached target Preparation for Local File Systems.
[    8.051668] systemd[1]: Mounting /tmp...
[    8.067002] systemd[1]: Mounted /tmp.
[    8.328925] systemd[1]: Started Rule-based Manager for Device Events and Files.
[    8.464794] systemd[1]: Finished Coldplug All udev Devices.
[    8.489040] systemd[1]: Starting Show Plymouth Boot Screen...
[    8.555337] systemd[1]: Started Show Plymouth Boot Screen.
[    8.559804] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[    8.561216] systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
[    8.561631] systemd[1]: Reached target Local Encrypted Volumes.
[    8.910780] mc: Linux media interface: v0.10
[    9.010305] videodev: Linux video capture interface: v2.00
[    9.038717] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey.3.auto/input/input0
[    9.116877] rockchip_vdec2: module is from the staging directory, the quality is unknown, you have been warned.
[    9.120091] rk2-crypto fe380000.crypto: will run requests pump with realtime priority
[    9.120171] rk2-crypto fe380000.crypto: Registers crypto algos
[    9.120179] rk2-crypto fe380000.crypto: Register ecb(aes) as ecb-aes-rk2
[    9.120232] rk2-crypto fe380000.crypto: Register cbc(aes) as cbc-aes-rk2
[    9.120248] rk2-crypto fe380000.crypto: Register xts(aes) as xts-aes-rk2
[    9.120261] rk2-crypto fe380000.crypto: Register md5 as rk2-md5 3
[    9.120276] rk2-crypto fe380000.crypto: Register sha1 as rk2-sha1 4
[    9.120291] rk2-crypto fe380000.crypto: Register sha256 as rk2-sha256 5
[    9.120306] rk2-crypto fe380000.crypto: Register sha384 as rk2-sha384 6
[    9.120319] rk2-crypto fe380000.crypto: Register sha512 as rk2-sha512 7
[    9.120333] rk2-crypto fe380000.crypto: Register sm3 as rk2-sm3 8
[    9.122514] rockchip-rga fdeb0000.rga: HW Version: 0x03.02
[    9.165687] rockchip-rga fdeb0000.rga: Registered rockchip-rga as /dev/video0
[    9.188101] hantro-vpu fdea0000.video-codec: Adding to iommu group 1
[    9.216117] systemd[1]: Found device /dev/disk/by-uuid/4271-D3A2.
[    9.232905] hantro-vpu fdea0000.video-codec: registered rockchip,rk3328-vpu-dec as /dev/video2
[    9.236847] hantro-vpu fdee0000.video-codec: Adding to iommu group 2
[    9.256727] OF: /rk809-sound/simple-audio-card,codec: could not get #sound-dai-cells for /i2c@fdd40000/pmic@20
[    9.256765] asoc-simple-card rk809-sound: error -EINVAL: parse error
[    9.256775] asoc-simple-card rk809-sound: probe with driver asoc-simple-card failed with error -22
[    9.256848] systemd[1]: Starting File System Check on /dev/disk/by-uuid/4271-D3A2...
[    9.262745] systemd[1]: Found device /dev/ttyS2.
[    9.264444] hantro-vpu fdee0000.video-codec: registered rockchip,rk3568-vepu-enc as /dev/video3
[    9.286846] systemd[1]: Started File System Check Daemon to report status.
[    9.359011] systemd[1]: Finished File System Check on /dev/disk/by-uuid/4271-D3A2.
[    9.381420] systemd[1]: Mounting /boot...
[    9.415422] systemd[1]: Mounted /boot.
[    9.416898] systemd[1]: Reached target Local File Systems.
[    9.421770] systemd[1]: Starting Armbian ZRAM config...
[    9.428901] systemd[1]: Starting Set console font and keymap...
[    9.439940] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.442453] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[    9.454891] systemd[1]: Starting Set Up Additional Binary Formats...
[    9.455248] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    9.455526] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.462000] systemd[1]: Finished Set console font and keymap.
[    9.466643] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.468923] systemd[1]: Received SIGRTMIN+20 from PID 181 (plymouthd).
[    9.479836] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 337 (systemd-binfmt)
[    9.485212] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[    9.514830] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[    9.526889] systemd[1]: Finished Set Up Additional Binary Formats.
[    9.659684] zram: Added device: zram0
[    9.660618] zram: Added device: zram1
[    9.663734] zram: Added device: zram2
[    9.728528] zram0: detected capacity change from 0 to 4012944
[    9.746979] Adding 2006468k swap on /dev/zram0.  Priority:5 extents:1 across:2006468k SS
[    9.790109] zram1: detected capacity change from 0 to 102400
[    9.826419] systemd[1]: Finished Armbian ZRAM config.
[    9.865763] systemd[1]: Starting Armbian memory supported logging...
[    9.926542] EXT4-fs (zram1): mounted filesystem 3ccbfa22-0697-469d-86f0-199ab9e91036 r/w without journal. Quota mode: none.
[   10.412107] systemd[1]: Finished Armbian memory supported logging.
[   10.438010] systemd[1]: Starting Journal Service...
[   10.608629] systemd[1]: Started Journal Service.
[   10.662120] systemd-journald[466]: Received client request to flush runtime journal.
[   10.785735] RPC: Registered named UNIX socket transport module.
[   10.785760] RPC: Registered udp transport module.
[   10.785765] RPC: Registered tcp transport module.
[   10.785768] RPC: Registered tcp-with-tls transport module.
[   10.785772] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   12.840069] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   12.928586] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-1:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   12.940124] dwmac4: Master AXI performs any burst length
[   12.940159] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   12.940187] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   12.940556] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   12.940964] rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rgmii link mode
[   13.001059] rk_gmac-dwmac fe2a0000.ethernet eth1: Register MEM_TYPE_PAGE_POOL RxQ-0
[   13.088098] rk_gmac-dwmac fe2a0000.ethernet eth1: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   13.101133] dwmac4: Master AXI performs any burst length
[   13.101172] rk_gmac-dwmac fe2a0000.ethernet eth1: No Safety Features support found
[   13.101210] rk_gmac-dwmac fe2a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[   13.106147] rk_gmac-dwmac fe2a0000.ethernet eth1: registered PTP clock
[   13.107519] rk_gmac-dwmac fe2a0000.ethernet eth1: configuring for phy/rgmii link mode
[   17.070468] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   19.432764] platform hdmi-sound: deferred probe pending: asoc-simple-card: parse error
[   23.788138] usb 3-1: new full-speed USB device number 2 using xhci-hcd
[   23.932924] usb 3-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   23.932946] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   23.932953] usb 3-1: Product: USB2.0 HUB
[   24.100129] hub 3-1:1.0: USB hub found
[   24.100267] hub 3-1:1.0: 4 ports detected
[   24.480042] usb 3-1.1: new low-speed USB device number 3 using xhci-hcd
[   24.579770] usb 3-1.1: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[   24.579792] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   24.579798] usb 3-1.1: Product: Lenovo Traditional USB Keyboard
[   24.579804] usb 3-1.1: Manufacturer: Lenovo
[   24.745674] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/fd000000.usb/xhci-hcd.8.auto/usb3/3-1/3-1.1/3-1.1:1.0/0003:17EF:6099.0001/input/input1
[   24.856489] hid-generic 0003:17EF:6099.0001: input,hidraw0: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.8.auto-1.1/input0
[   24.928048] usb 3-1.2: new low-speed USB device number 4 using xhci-hcd
[   25.023913] usb 3-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[   25.023936] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   25.023943] usb 3-1.2: Product: Lenovo USB Optical Mouse
[   25.023995] usb 3-1.2: Manufacturer: PixArt
[   25.254467] input: PixArt Lenovo USB Optical Mouse as /devices/platform/fd000000.usb/xhci-hcd.8.auto/usb3/3-1/3-1.2/3-1.2:1.0/0003:17EF:608D.0002/input/input2
[   25.256550] hid-generic 0003:17EF:608D.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.8.auto-1.2/input0
[   29.293424] usb 3-1.4: new full-speed USB device number 5 using xhci-hcd
[   29.386437] usb 3-1.4: not running at top speed; connect to a high speed hub
[   29.389647] usb 3-1.4: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.00
[   29.389697] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   29.389726] usb 3-1.4: Product: DataTraveler 3.0
[   29.389749] usb 3-1.4: Manufacturer: Kingston
[   29.389771] usb 3-1.4: SerialNumber: 60A44C3FAC2DBDA0A98A2DE8
[   29.392638] usb-storage 3-1.4:1.0: USB Mass Storage device detected
[   29.398455] scsi host0: usb-storage 3-1.4:1.0
[   29.446242] usbcore: registered new interface driver uas
[   30.411461] scsi 0:0:0:0: Direct-Access     Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[   30.572143] sd 0:0:0:0: [sda] 15360000 512-byte logical blocks: (7.86 GB/7.32 GiB)
[   30.574628] sd 0:0:0:0: [sda] Write Protect is off
[   30.574644] sd 0:0:0:0: [sda] Mode Sense: 2b 80 00 08
[   30.576603] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   30.647165]  sda: sda1 sda2
[   30.647606] sd 0:0:0:0: [sda] Attached SCSI removable disk
[   30.654983] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   33.770013] vdd_npu: disabling
[   35.663374] ntfs3: Enabled Linux POSIX ACLs support
[   35.663396] ntfs3: Read-only LZX/Xpress compression included
[   35.685675] ntfs3(sda1): It is recommened to use chkdsk.
[   35.694214] FAT-fs (sda2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   49.444758] ntfs3(sda1): volume is dirty and "force" flag is not set!
Edited by Hqnicolas
Posted (edited)
Download RKDevTool and also download this small file wipe_part. We will be using that shortly.
Download the Clear_EMMC_YY3568
Unzip RKDevTool and run RKDevTool.exe
Set the Config for RKDevTool "RkDevToolConfig.cfg" that was inside " Clear_EMMC_YY3568"
Flash the U-boot, parameter.txt and MiniloaderAll from "Clear_EMMC_YY3568"
Your Board will restart.
Destroy All the partitions overrided by file wipe_part.
Flash this MiniLoaderAll.bin
it now boots from SD-Card
Edited by Hqnicolas
Posted (edited)
On 2/13/2025 at 9:44 PM, Hqnicolas said:
none of the images I created worked,
despite seeing the status post
https://github.com/armbian/linux-rockchip/releases/tag/v24.8.0-trunk.147
 it seems there was a cut in the manufacturer's information and the project didn't move forward
https://github.com/armbian/linux-rockchip/pull/99
Since the Vendor Kernel don't work, I'm doing It from scratch:
https://github.com/armbian/linux-rockchip/pull/341
so far?
dmsg:
Quote
[   10.521638] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[   10.521682] Linux version 6.1.99-vendor-rk35xx (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Thu Mar  6 03:10:34 UTC 2025
[   10.528880] Machine model: Youyeetoo YY3568
[   10.529129] efi: UEFI not found.
[   10.529402] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-logo@0': base 0x0000000000000000, size 0 MiB
[   10.529430] OF: fdt: Reserved memory: failed to reserve memory for node 'drm-cubic-lut@0': base 0x0000000000000000, size 0 MiB
[   10.529574] Reserved memory: created CMA memory pool at 0x00000000d0000000, size 512 MiB
[   10.529584] OF: reserved mem: initialized node rknpu, compatible id shared-dma-pool
[   10.654275] Zone ranges:
[   10.654290]   DMA      [mem 0x0000000000200000-0x00000000ffffffff]
[   10.654307]   DMA32    empty
[   10.654314]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[   10.654324] Movable zone start for each node
[   10.654328] Early memory node ranges
[   10.654331]   node   0: [mem 0x0000000000200000-0x00000000efffffff]
[   10.654344]   node   0: [mem 0x00000001f0000000-0x00000001ffffffff]
[   10.654354] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[   10.684458] On node 0, zone DMA: 512 pages in unavailable ranges
[   10.686593] cma: Reserved 256 MiB at 0x00000000c0000000
[   10.686739] psci: probing for conduit method from DT.
[   10.686754] psci: PSCIv1.1 detected in firmware.
[   10.686764] psci: Using standard PSCI v0.2 function IDs
[   10.686772] psci: MIGRATE_INFO_TYPE not supported.
[   10.686788] psci: SMC Calling Convention v1.2
[   10.687258] percpu: Embedded 30 pages/cpu s82728 r8192 d31960 u122880
[   10.687310] pcpu-alloc: s82728 r8192 d31960 u122880 alloc=30*4096
[   10.687327] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[   10.687465] Detected VIPT I-cache on CPU0
[   10.687546] CPU features: detected: GIC system register CPU interface
[   10.687553] CPU features: detected: Virtualization Host Extensions
[   10.687575] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[   10.687582] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[   10.687590] alternatives: applying boot alternatives
[   10.688373] Built 1 zonelists, mobility grouping on.  Total pages: 1031688
[   10.688396] Kernel command line: root=UUID=eaf13fe3-9baf-4448-9822-797e05b82fee rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=56a0f540-524e-4f8b-8bb2-dadfd100fc0c usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cma=256M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory androidboot.fwver=ddr-v1.21-2d653b3476,bl31-v1.44,uboot-rmbian-201-03/06/2025
[   10.689360] Unknown kernel command line parameters "splash ubootpart=56a0f540-524e-4f8b-8bb2-dadfd100fc0c cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[   10.690700] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[   10.691364] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[   10.691379] mem auto-init: stack:off, heap alloc:off, heap free:off
[   10.691389] software IO TLB: area num 4.
[   10.733828] software IO TLB: mapped [mem 0x00000000bc000000-0x00000000c0000000] (64MB)
[   10.797191] Memory: 3193812K/4192256K available (18944K kernel code, 3960K rwdata, 16056K rodata, 8320K init, 703K bss, 212012K reserved, 786432K cma-reserved)
[   10.797437] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[   10.797502] ftrace: allocating 71631 entries in 280 pages
[   10.990625] ftrace: allocated 280 pages with 3 groups
[   10.990861] trace event string verifier disabled
[   10.991210] rcu: Hierarchical RCU implementation.
[   10.991218] rcu:     RCU event tracing is enabled.
[   10.991222] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[   10.991232]     Rude variant of Tasks RCU enabled.
[   10.991236]     Tracing variant of Tasks RCU enabled.
[   10.991240] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[   10.991247] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[   11.020872] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[   11.023926] GICv3: GIC: Using split EOI/Deactivate mode
[   11.023941] GICv3: 320 SPIs implemented
[   11.023949] GICv3: 0 Extended SPIs implemented
[   11.024007] Root IRQ handler: gic_handle_irq
[   11.024031] GICv3: GICv3 features: 16 PPIs
[   11.024077] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[   11.024872] ITS [mem 0xfd440000-0xfd45ffff]
[   11.024984] ITS@0x00000000fd440000: allocated 8192 Devices @3410000 (indirect, esz 8, psz 64K, shr 0)
[   11.025048] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @3420000 (flat, esz 2, psz 64K, shr 0)
[   11.025070] ITS: using cache flushing for cmd queue
[   11.025649] GICv3: using LPI property table @0x0000000003430000
[   11.025819] GIC: using cache flushing for LPI property table
[   11.025828] GICv3: CPU0: using allocated LPI pending table @0x0000000003440000
[   11.025941] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[   11.077071] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[   11.077103] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[   11.077119] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[   11.079143] Console: colour dummy device 80x25
[   11.079230] printk: console [tty1] enabled
[   11.079292] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[   11.079313] pid_max: default: 32768 minimum: 301
[   11.079441] LSM: Security Framework initializing
[   11.079595] AppArmor: AppArmor initialized
[   11.079811] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[   11.079850] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[   11.081431] cacheinfo: Unable to detect cache hierarchy for CPU 0
[   11.083137] cblist_init_generic: Setting adjustable number of callback queues.
[   11.083152] cblist_init_generic: Setting shift to 2 and lim to 1.
[   11.083371] cblist_init_generic: Setting adjustable number of callback queues.
[   11.083384] cblist_init_generic: Setting shift to 2 and lim to 1.
[   11.083826] rcu: Hierarchical SRCU implementation.
[   11.083837] rcu:     Max phase no-delay instances is 1000.
[   11.086047] Platform MSI: interrupt-controller@fd440000 domain created
[   11.086813] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[   11.087375] EFI services will not be available.
[   11.088109] smp: Bringing up secondary CPUs ...
[   11.089377] Detected VIPT I-cache on CPU1
[   11.089501] cacheinfo: Unable to detect cache hierarchy for CPU 1
[   11.089522] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[   11.089554] GICv3: CPU1: using allocated LPI pending table @0x0000000003450000
[   11.089623] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[   11.091148] Detected VIPT I-cache on CPU2
[   11.091262] cacheinfo: Unable to detect cache hierarchy for CPU 2
[   11.091283] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[   11.091311] GICv3: CPU2: using allocated LPI pending table @0x0000000003460000
[   11.091370] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[   11.092727] Detected VIPT I-cache on CPU3
[   11.092841] cacheinfo: Unable to detect cache hierarchy for CPU 3
[   11.092861] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[   11.092889] GICv3: CPU3: using allocated LPI pending table @0x0000000003470000
[   11.092943] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[   11.093137] smp: Brought up 1 node, 4 CPUs
[   11.093168] SMP: Total of 4 processors activated.
[   11.093179] CPU features: detected: 32-bit EL0 Support
[   11.093186] CPU features: detected: 32-bit EL1 Support
[   11.093196] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[   11.093205] CPU features: detected: Common not Private translations
[   11.093212] CPU features: detected: CRC32 instructions
[   11.093223] CPU features: detected: RCpc load-acquire (LDAPR)
[   11.093231] CPU features: detected: LSE atomic instructions
[   11.093238] CPU features: detected: Privileged Access Never
[   11.093244] CPU features: detected: RAS Extension Support
[   11.093254] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[   11.093390] CPU: All CPU(s) started at EL2
[   11.093440] alternatives: applying system-wide alternatives
[   11.099392] devtmpfs: initialized
[   11.143045] Registered cp15_barrier emulation handler
[   11.143079] Registered setend emulation handler
[   11.143394] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[   11.143431] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[   11.167572] pinctrl core: initialized pinctrl subsystem
[   11.168193] regulator-dummy: no parameters, enabled
[   11.168736] DMI not present or invalid.
[   11.169757] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[   11.172291] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[   11.172814] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[   11.173177] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[   11.173266] audit: initializing netlink subsys (disabled)
[   11.173595] audit: type=2000 audit(0.093:1): state=initialized audit_enabled=0 res=1
[   11.178400] Registered FIQ tty driver
[   11.179189] thermal_sys: Registered thermal governor 'fair_share'
[   11.179203] thermal_sys: Registered thermal governor 'step_wise'
[   11.179212] thermal_sys: Registered thermal governor 'user_space'
[   11.179220] thermal_sys: Registered thermal governor 'power_allocator'
[   11.179354] cpuidle: using governor menu
[   11.180312] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[   11.180595] ASID allocator initialised with 65536 entries
[   11.185107] ramoops: dmesg-0    0x20000@0x0000000000110000
[   11.185164] ramoops: console    0x80000@0x0000000000130000
[   11.185205] ramoops: pmsg    0x50000@0x00000000001b0000
[   11.185486] printk: console [ramoops-1] enabled
[   11.185500] pstore: Registered ramoops as persistent store backend
[   11.185509] ramoops: using 0xf0000@0x110000, ecc: 0
[   11.216635] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[   11.216780] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /vop@fe040000
[   11.252063] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[   11.253187] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[   11.254196] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[   11.255108] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[   11.255992] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[   11.256252] rockchip-pinctrl pinctrl: probed pinctrl
[   11.268479] KASLR disabled due to lack of seed
[   11.293348] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[   11.293373] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[   11.293387] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[   11.293396] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[   11.293406] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[   11.293415] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[   11.293426] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[   11.293434] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[   11.350055] raid6: neonx8   gen()  1371 MB/s
[   11.406967] raid6: neonx4   gen()  1413 MB/s
[   11.463857] raid6: neonx2   gen()  1288 MB/s
[   11.520763] raid6: neonx1   gen()  1052 MB/s
[   11.577700] raid6: int64x8  gen()   349 MB/s
[   11.634549] raid6: int64x4  gen()   440 MB/s
[   11.691450] raid6: int64x2  gen()   912 MB/s
[   11.748422] raid6: int64x1  gen()   634 MB/s
[   11.748438] raid6: using algorithm neonx4 gen() 1413 MB/s
[   11.805208] raid6: .... xor() 1069 MB/s, rmw enabled
[   11.805223] raid6: using neon recovery algorithm
[   11.807374] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ fiq not found
[   11.807406] fiq_debugger fiq_debugger.0: error -ENXIO: IRQ wakeup not found
[   11.807429] fiq_debugger_probe: could not install nmi irq handler
[   11.807855] printk: console [ttyFIQ0] enabled
[   11.808221] Registered fiq debugger ttyFIQ0
[   11.809104] vcc5v0_sys: 5000 mV, enabled
[   11.809426] reg-fixed-voltage vcc5v0-sys: vcc5v0_sys supplying 5000000uV
[   11.809682] reg-fixed-voltage vcc3v3-sys: Looking up vin-supply from device tree
[   11.809711] vcc3v3_sys: supplied by vcc5v0_sys
[   11.809730] vcc5v0_sys: could not add device link regulator.2: -ENOENT
[   11.809805] vcc3v3_sys: 3300 mV, enabled
[   11.810113] reg-fixed-voltage vcc3v3-sys: vcc3v3_sys supplying 3300000uV
[   11.810609] vcc5v0_host: no parameters, enabled
[   11.810891] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[   11.811317] vcc5v0_otg: no parameters, enabled
[   11.811626] reg-fixed-voltage vcc5v0-otg-regulator: vcc5v0_otg supplying 0uV
[   11.812205] vcc3v3_minipcie: no parameters, enabled
[   11.812479] reg-fixed-voltage vcc3v3-minipcie: vcc3v3_minipcie supplying 0uV
[   11.812911] vcc3v3_minipcie_to_5g_or_wifi: no parameters, enabled
[   11.813220] reg-fixed-voltage vcc3v3-minipcie-to-5g-or-wifi: vcc3v3_minipcie_to_5g_or_wifi supplying 0uV
[   11.813607] vcc3v3_pci_30x1: no parameters, enabled
[   11.813914] reg-fixed-voltage vcc3v3-pci-30x1: vcc3v3_pci_30x1 supplying 0uV
[   11.814516] gpio-regulator pcie30-3v3: No 'states' property found
[   11.814533] gpio-regulator: probe of pcie30-3v3 failed with error -22
[   11.815210] iommu: Default domain type: Translated
[   11.815227] iommu: DMA domain TLB invalidation policy: strict mode
[   11.815899] SCSI subsystem initialized
[   11.815975] libata version 3.00 loaded.
[   11.816294] usbcore: registered new interface driver usbfs
[   11.816378] usbcore: registered new interface driver hub
[   11.816448] usbcore: registered new device driver usb
[   11.816711] mc: Linux media interface: v0.10
[   11.816805] videodev: Linux video capture interface: v2.00
[   11.817033] pps_core: LinuxPPS API ver. 1 registered
[   11.817048] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[   11.817082] PTP clock support registered
[   11.818059] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[   11.818282] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[   11.818364] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[   11.820142] Advanced Linux Sound Architecture Driver Initialized.
[   11.821221] Bluetooth: Core ver 2.22
[   11.821290] NET: Registered PF_BLUETOOTH protocol family
[   11.821304] Bluetooth: HCI device and connection manager initialized
[   11.821324] Bluetooth: HCI socket layer initialized
[   11.821339] Bluetooth: L2CAP socket layer initialized
[   11.821370] Bluetooth: SCO socket layer initialized
[   11.821502] NetLabel: Initializing
[   11.821512] NetLabel:  domain hash size = 128
[   11.821523] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[   11.821640] NetLabel:  unlabeled traffic allowed by default
[   11.822286] vgaarb: loaded
[   11.827980] clocksource: Switched to clocksource arch_sys_counter
[   11.828880] VFS: Disk quotas dquot_6.6.0
[   11.828969] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[   11.829894] AppArmor: AppArmor Filesystem Enabled
[   11.849815] NET: Registered PF_INET protocol family
[   11.850202] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[   11.855496] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[   11.855575] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[   11.855697] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[   11.855982] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[   11.856940] TCP: Hash tables configured (established 32768 bind 32768)
[   11.857303] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[   11.857461] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   11.857557] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[   11.857909] NET: Registered PF_UNIX/PF_LOCAL protocol family
[   11.858826] RPC: Registered named UNIX socket transport module.
[   11.858845] RPC: Registered udp transport module.
[   11.858855] RPC: Registered tcp transport module.
[   11.858864] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   11.860548] PCI: CLS 0 bytes, default 64
[   11.861629] Trying to unpack rootfs image as initramfs...
[   11.885452] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[   11.887054] kvm [1]: IPA Size Limit: 40 bits
[   11.887103] kvm [1]: GICv3: no GICV resource entry
[   11.887115] kvm [1]: disabling GICv2 emulation
[   11.887125] kvm [1]: GIC system register CPU interface enabled
[   11.894783] kvm [1]: vgic interrupt IRQ9
[   11.904064] kvm [1]: VHE mode initialized successfully
[   12.595051] Initialise system trusted keyrings
[   12.595519] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[   12.604856] zbud: loaded
[   12.608404] NFS: Registering the id_resolver key type
[   12.608480] Key type id_resolver registered
[   12.608492] Key type id_legacy registered
[   12.608641] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[   12.608658] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[   12.663981] NET: Registered PF_ALG protocol family
[   12.664024] xor: measuring software checksum speed
[   12.670390]    8regs           :  1565 MB/sec
[   12.675603]    32regs          :  1911 MB/sec
[   12.681715]    arm64_neon      :  1624 MB/sec
[   12.681738] xor: using function: 32regs (1911 MB/sec)
[   12.681775] Key type asymmetric registered
[   12.681788] Asymmetric key parser 'x509' registered
[   12.681925] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 241)
[   12.682339] io scheduler mq-deadline registered
[   12.682358] io scheduler kyber registered
[   12.689888] phy phy-fe8a0000.usb2-phy.0: Looking up phy-supply from device tree
[   12.689939] vcc5v0_host: could not add device link phy-fe8a0000.usb2-phy.0: -ENOENT
[   12.690310] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply from device tree
[   12.690334] phy phy-fe8a0000.usb2-phy.1: Looking up phy-supply property in node /usb2-phy@fe8a0000/otg-port failed
[   12.690496] phy phy-fe8a0000.usb2-phy.1: Looking up vbus-supply from device tree
[   12.693532] phy phy-fe8b0000.usb2-phy.2: Looking up phy-supply from device tree
[   12.693584] vcc5v0_host: could not add device link phy-fe8b0000.usb2-phy.2: -ENOENT
[   12.693901] phy phy-fe8b0000.usb2-phy.3: Looking up phy-supply from device tree
[   12.693933] vcc5v0_host: could not add device link phy-fe8b0000.usb2-phy.3: -ENOENT
[   12.694214] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply from device tree
[   12.694237] phy phy-fe8b0000.usb2-phy.3: Looking up vbus-supply property in node /usb2-phy@fe8b0000/otg-port failed
[   12.699238] phy phy-fe830000.phy.4: Looking up phy-supply from device tree
[   12.699274] phy phy-fe830000.phy.4: Looking up phy-supply property in node /phy@fe830000 failed
[   12.700064] phy phy-fe840000.phy.5: Looking up phy-supply from device tree
[   12.700089] phy phy-fe840000.phy.5: Looking up phy-supply property in node /phy@fe840000 failed
[   12.701141] phy phy-fe820000.phy.6: Looking up phy-supply from device tree
[   12.701169] phy phy-fe820000.phy.6: Looking up phy-supply property in node /phy@fe820000 failed
[   12.707495] iep: Module initialized.
[   12.707640] mpp_service mpp-srv: 53c0acb01bce author: Tao Huang 2024-12-09 video: rockchip: mpp: Fix typos in Rockchip copyright notices
[   12.707661] mpp_service mpp-srv: probe start
[   12.715650] mpp_service mpp-srv: probe success
[   12.724671] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[   12.724708] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[   12.728744] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[   12.728779] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[   12.729501] rockchip-pvtm fde00000.pvtm: failed to retrieve pvtm_tz
[   12.729578] rockchip-pvtm fde00000.pvtm: pvtm@0 probed
[   12.729804] rockchip-pvtm fde80000.pvtm: failed to retrieve pvtm_tz
[   12.729894] rockchip-pvtm fde80000.pvtm: pvtm@1 probed
[   12.730071] rockchip-pvtm fde90000.pvtm: failed to retrieve pvtm_tz
[   12.730141] rockchip-pvtm fde90000.pvtm: pvtm@2 probed
[   12.731740] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[   12.733338] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[   12.733840] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[   12.735468] fe680000.serial: ttyS4 at MMIO 0xfe680000 (irq = 32, base_baud = 1500000) is a 16550A
[   12.737214] fe6c0000.serial: ttyS8 at MMIO 0xfe6c0000 (irq = 33, base_baud = 1500000) is a 16550A
[   12.738783] fe6d0000.serial: ttyS9 at MMIO 0xfe6d0000 (irq = 34, base_baud = 1500000) is a 16550A
[   12.743121] led_vk2c21_init
[   12.743343] random: crng init done
[   12.744162] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply from device tree
[   12.744200] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up npu-supply property in node /power-management@fdd90000/power-controller failed
[   12.746311] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply from device tree
[   12.746356] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vpu-supply property in node /power-management@fdd90000/power-controller failed
[   12.747392] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply from device tree
[   12.747431] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rga-supply property in node /power-management@fdd90000/power-controller failed
[   12.750804] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply from device tree
[   12.750850] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvenc-supply property in node /power-management@fdd90000/power-controller failed
[   12.752029] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply from device tree
[   12.752073] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up rkvdec-supply property in node /power-management@fdd90000/power-controller failed
[   12.753134] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply from device tree
[   12.753174] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up vi-supply property in node /power-management@fdd90000/power-controller failed
[   12.756699] rockchip-vop2 fe040000.vop: Adding to iommu group 8
[   12.773494] [drm] all windows should be assigned, full plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], current plane mask: [0x0
[   12.773525] [drm] use default plane mask
[   12.773599] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: Cluster0 | Cluster1 | Esmart0 | Esmart1 | Smart0 | Smart1[0x3f], primary plane phy id: Smart0[4]
[   12.773643] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: [0x0], primary plane phy id: INVALID[-1]
[   12.773672] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: [0x0], primary plane phy id: INVALID[-1]
[   12.774208] [drm] failed to init overlay plane Cluster0-win1
[   12.774316] [drm] failed to init overlay plane Cluster1-win1
[   12.774539] rockchip-vop2 fe040000.vop: bin=0
[   12.774705] rockchip-vop2 fe040000.vop: Failed to get leakage
[   12.774794] rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[   12.774832] rockchip-vop2 fe040000.vop: Looking up vop-supply property in node /vop@fe040000 failed
[   12.774878] rockchip-vop2 fe040000.vop: Failed to get reg
[   12.774958] rockchip-vop2 fe040000.vop: Looking up vop-supply from device tree
[   12.774997] rockchip-vop2 fe040000.vop: Looking up vop-supply property in node /vop@fe040000 failed
[   12.775028] rockchip-vop2 fe040000.vop: error -ENODEV: _opp_set_regulators: no regulator (vop) found
[   12.775087] rockchip-vop2 fe040000.vop: failed to set opp config
[   12.775103] rockchip-vop2 fe040000.vop: failed to init opp info
[   12.775117] rockchip-vop2 fe040000.vop: Unsupported VOP aclk dvfs
[   12.775138] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffff8000093de7c0)
[   12.775350] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply from device tree
[   12.775377] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-0v9-supply property in node /hdmi@fe0a0000 failed
[   12.775411] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply from device tree
[   12.775432] dwhdmi-rockchip fe0a0000.hdmi: Looking up avdd-1v8-supply property in node /hdmi@fe0a0000 failed
[   12.775710] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[   12.776867] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[   12.777231] dwhdmi-rockchip fe0a0000.hdmi: error -ENXIO: IRQ index 1 not found
[   12.777939] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffff8000093f7058)
[   12.779868] [drm] Initialized rockchip 4.0.0 20140818 for display-subsystem on minor 0
[   12.779945] rockchip-drm display-subsystem: failed to parse loader memory
[   12.857605] Freeing initrd memory: 16108K
[   12.966845] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 3840x2160p60, type: 11(if:HDMI0, flag:0x0) for vp0 dclk: 594000000
[   12.967267] rockchip-vop2 fe040000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 594000000, get 594000000
[   13.200739] Console: switching to colour frame buffer device 480x135
[   13.282346] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[   13.282864] rockchip-drm display-subsystem: [drm] run display error_event monitor
[   13.286451] Registered IR keymap rc-cec
[   13.286669] rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0
[   13.286965] input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0
[   13.287506] input: hdmi_cec_key as /devices/platform/fe0a0000.hdmi/dw-hdmi-cec.1.auto/input/input1
[   13.289242] cacheinfo: Unable to detect cache hierarchy for CPU 0
[   13.290856] brd: module loaded
[   13.300306] loop: module loaded
[   13.301065] rbd: loaded (major 254)
[   13.301717] lkdtm: No crash points registered, enable through debugfs
[   13.313037] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[   13.313389] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[   13.313421] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply property in node /ethernet@fe010000 failed
[   13.313466] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[   13.313706] rk_gmac-dwmac fe010000.ethernet: clock input or output? (output).
[   13.313727] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[   13.313743] rk_gmac-dwmac fe010000.ethernet: RX delay(0x26).
[   13.313779] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[   13.314114] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[   13.314512] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[   13.314539] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[   13.314555] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[   13.314567] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[   13.314579] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[   13.314591] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[   13.314744] rk_gmac-dwmac fe010000.ethernet: TSO supported
[   13.314761] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   13.314777] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[   13.314808] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[   13.314823] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[   13.471034] rk_gmac-dwmac fe2a0000.ethernet: IRQ eth_lpi not found
[   13.471875] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply from device tree
[   13.471912] rk_gmac-dwmac fe2a0000.ethernet: Looking up phy-supply property in node /ethernet@fe2a0000 failed
[   13.471955] rk_gmac-dwmac fe2a0000.ethernet: supply phy not found, using dummy regulator
[   13.472203] rk_gmac-dwmac fe2a0000.ethernet: clock input or output? (output).
[   13.472225] rk_gmac-dwmac fe2a0000.ethernet: TX delay(0x3c).
[   13.472241] rk_gmac-dwmac fe2a0000.ethernet: RX delay(0x2f).
[   13.472279] rk_gmac-dwmac fe2a0000.ethernet: integrated PHY? (no).
[   13.472624] rk_gmac-dwmac fe2a0000.ethernet: init for RGMII
[   13.473009] rk_gmac-dwmac fe2a0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[   13.473036] rk_gmac-dwmac fe2a0000.ethernet:     DWMAC4/5
[   13.473053] rk_gmac-dwmac fe2a0000.ethernet: DMA HW capability register supported
[   13.473066] rk_gmac-dwmac fe2a0000.ethernet: RX Checksum Offload Engine supported
[   13.473078] rk_gmac-dwmac fe2a0000.ethernet: TX Checksum insertion supported
[   13.473089] rk_gmac-dwmac fe2a0000.ethernet: Wake-Up On Lan supported
[   13.473194] rk_gmac-dwmac fe2a0000.ethernet: TSO supported
[   13.473210] rk_gmac-dwmac fe2a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   13.473226] rk_gmac-dwmac fe2a0000.ethernet: Enabled RFS Flow TC (entries=10)
[   13.473241] rk_gmac-dwmac fe2a0000.ethernet: TSO feature enabled
[   13.473255] rk_gmac-dwmac fe2a0000.ethernet: Using 32/32 bits DMA host/device width
[   13.617581] phy_rtl8211f_led_fixup in
[   13.617756] phy_rtl8211f_led_fixup in  val=0x0a42
[   13.624413] usbcore: registered new interface driver rndis_wlan
[   13.624524] usbcore: registered new interface driver asix
[   13.624595] usbcore: registered new interface driver cdc_ether
[   13.624737] usbcore: registered new interface driver rndis_host
[   13.624862] usbcore: registered new interface driver cdc_ncm
[   13.625248] VFIO - User Level meta-driver version: 0.3
[   13.633896] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pipe-supply from device tree
[   13.633943] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up pipe-supply property in node /power-management@fdd90000/power-controller failed
[   13.643739] phy phy-fe8b0000.usb2-phy.3: illegal mode
[   13.644867] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[   13.644933] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 1
[   13.645135] xhci-hcd xhci-hcd.4.auto: USB3 root hub has no ports
[   13.645156] xhci-hcd xhci-hcd.4.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002010010
[   13.645249] xhci-hcd xhci-hcd.4.auto: irq 51, io mem 0xfd000000
[   13.645860] ehci-platform fd800000.usb: EHCI Host Controller
[   13.645890] phy phy-fe8b0000.usb2-phy.3: illegal mode
[   13.645896] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[   13.645917] ohci-platform fd840000.usb: Generic Platform OHCI controller
[   13.645921] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.645939] usb usb1: Product: xHCI Host Controller
[   13.645948] ehci-platform fd880000.usb: EHCI Host Controller
[   13.645952] usb usb1: Manufacturer: Linux 6.1.99-vendor-rk35xx xhci-hcd
[   13.645963] usb usb1: SerialNumber: xhci-hcd.4.auto
[   13.646293] ohci-platform fd8c0000.usb: Generic Platform OHCI controller
[   13.646841] hub 1-0:1.0: USB hub found
[   13.646924] hub 1-0:1.0: 1 port detected
[   13.647627] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 2
[   13.647664] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[   13.647710] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 4
[   13.647793] usbcore: registered new interface driver cdc_acm
[   13.647811] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   13.647886] ehci-platform fd800000.usb: irq 52, io mem 0xfd800000
[   13.647922] ohci-platform fd840000.usb: irq 54, io mem 0xfd840000
[   13.647947] ohci-platform fd8c0000.usb: new USB bus registered, assigned bus number 5
[   13.648014] ehci-platform fd880000.usb: irq 53, io mem 0xfd880000
[   13.648199] ohci-platform fd8c0000.usb: irq 55, io mem 0xfd8c0000
[   13.648363] usbcore: registered new interface driver uas
[   13.648508] usbcore: registered new interface driver usb-storage
[   13.649419] mousedev: PS/2 mouse device common for all mice
[   13.650017] [GTP-INF][goodix_i2c_init:1931] Goodix driver init
[   13.650081] [GTP-INF][goodix_fwu_module_init:1588] goodix_fwupdate_module_ini IN
[   13.650096] [GTP-INF][goodix_register_ext_module:161] goodix_register_ext_module IN
[   13.650127] [GTP-INF][goodix_register_ext_module:166] goodix_register_ext_module OUT
[   13.650161] [GTP-INF][__do_register_ext_module:67] __do_register_ext_module IN
[   13.651178] .. rk pwm remotectl v2.0 init
[   13.651707] input: fe6e0030.pwm as /devices/platform/fe6e0030.pwm/input/input2
[   13.652391] remotectl-pwm fe6e0030.pwm: Controller support pwrkey capture
[   13.653196] i2c_dev: i2c /dev entries driver
[   13.656461] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[   13.656506] fan53555-regulator 0-001c: Looking up vin-supply from device tree
[   13.656854] vdd_cpu: supplied by vcc5v0_sys
[   13.656875] vcc5v0_sys: could not add device link regulator.8: -ENOENT
[   13.657436] vdd_cpu: override max_uV, 1390000 -> 1387500
[   13.658034] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[   13.658776] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[   13.658801] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.658816] usb usb2: Product: EHCI Host Controller
[   13.658829] usb usb2: Manufacturer: Linux 6.1.99-vendor-rk35xx ehci_hcd
[   13.658841] usb usb2: SerialNumber: fd800000.usb
[   13.659730] hub 2-0:1.0: USB hub found
[   13.659815] hub 2-0:1.0: 1 port detected
[   13.659908] vdd_cpu: 712 <--> 1387 mV at 900 mV, enabled
[   13.661863] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_rst
[   13.661908] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_pwrdn
[   13.661942] i2c 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx/rk817_slppin_slp
[   13.663794] rk808 0-0020: chip id: 0x8090
[   13.663864] rk808 0-0020: No cache defaults, reading back from HW
[   13.671370] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[   13.672134] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[   13.672159] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.672175] usb usb4: Product: EHCI Host Controller
[   13.672188] usb usb4: Manufacturer: Linux 6.1.99-vendor-rk35xx ehci_hcd
[   13.672201] usb usb4: SerialNumber: fd880000.usb
[   13.673075] hub 4-0:1.0: USB hub found
[   13.673201] hub 4-0:1.0: 1 port detected
[   13.687692] rk808 0-0020: source: on=0x10, off=0x00
[   13.687725] rk808 0-0020: support dcdc3 fb mode:-22, 1
[   13.687743] rk808 0-0020: support pmic reset mode:0,0
[   13.690920] rk808 0-0020: Fixed dependency cycle(s) with /i2c@fdd40000/pmic@20/pinctrl_rk8xx
[   13.697442] rk808-regulator rk808-regulator: there is no dvs0 gpio
[   13.697501] rk808-regulator rk808-regulator: there is no dvs1 gpio
[   13.697598] rk808 0-0020: Looking up vcc1-supply from device tree
[   13.698020] vdd_logic: supplied by vcc3v3_sys
[   13.698046] vcc3v3_sys: could not add device link regulator.9: -ENOENT
[   13.698926] vdd_logic: 500 <--> 1350 mV at 900 mV, enabled
[   13.699427] rk808 0-0020: Looking up vcc2-supply from device tree
[   13.699458] vdd_gpu: supplied by vcc3v3_sys
[   13.699476] vcc3v3_sys: could not add device link regulator.10: -ENOENT
[   13.700299] vdd_gpu: 500 <--> 1350 mV at 900 mV, enabled
[   13.700784] rk808 0-0020: Looking up vcc3-supply from device tree
[   13.700813] vcc_ddr: supplied by vcc3v3_sys
[   13.700831] vcc3v3_sys: could not add device link regulator.11: -ENOENT
[   13.701354] vcc_ddr: at 500 mV, enabled
[   13.701801] rk808 0-0020: Looking up vcc4-supply from device tree
[   13.701830] vdd_npu: supplied by vcc3v3_sys
[   13.701847] vcc3v3_sys: could not add device link regulator.12: -ENOENT
[   13.702318] vdd_npu: 500 <--> 1350 mV at 900 mV, enabled
[   13.702785] rk808 0-0020: Looking up vcc9-supply from device tree
[   13.702814] vcc_1v8: supplied by vcc3v3_sys
[   13.702832] vcc3v3_sys: could not add device link regulator.13: -ENOENT
[   13.703653] vcc_1v8: 1800 mV, enabled
[   13.704061] rk808 0-0020: Looking up vcc5-supply from device tree
[   13.704090] vdda0v9_image: supplied by vcc3v3_sys
[   13.704108] vcc3v3_sys: could not add device link regulator.14: -ENOENT
[   13.705112] vdda0v9_image: 900 mV, enabled
[   13.705503] rk808 0-0020: Looking up vcc5-supply from device tree
[   13.705531] vdda_0v9: supplied by vcc3v3_sys
[   13.705549] vcc3v3_sys: could not add device link regulator.15: -ENOENT
[   13.705783] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[   13.705809] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.705825] usb usb3: Product: Generic Platform OHCI controller
[   13.705838] usb usb3: Manufacturer: Linux 6.1.99-vendor-rk35xx ohci_hcd
[   13.705851] usb usb3: SerialNumber: fd840000.usb
[   13.706709] hub 3-0:1.0: USB hub found
[   13.706800] hub 3-0:1.0: 1 port detected
[   13.706942] vdda_0v9: 900 mV, enabled
[   13.707385] rk808 0-0020: Looking up vcc5-supply from device tree
[   13.707415] vdda0v9_pmu: supplied by vcc3v3_sys
[   13.707441] vcc3v3_sys: could not add device link regulator.16: -ENOENT
[   13.708451] vdda0v9_pmu: 900 mV, enabled
[   13.708903] rk808 0-0020: Looking up vcc6-supply from device tree
[   13.708933] vccio_acodec: supplied by vcc3v3_sys
[   13.708952] vcc3v3_sys: could not add device link regulator.17: -ENOENT
[   13.709014] vccio_acodec: Bringing 3300000uV into 3000000-3000000uV
[   13.709082] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[   13.709108] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.709124] usb usb5: Product: Generic Platform OHCI controller
[   13.709137] usb usb5: Manufacturer: Linux 6.1.99-vendor-rk35xx ohci_hcd
[   13.709150] usb usb5: SerialNumber: fd8c0000.usb
[   13.709977] hub 5-0:1.0: USB hub found
[   13.710060] hub 5-0:1.0: 1 port detected
[   13.710334] vccio_acodec: 3000 mV, enabled
[   13.710805] rk808 0-0020: Looking up vcc6-supply from device tree
[   13.710836] vccio_sd: supplied by vcc3v3_sys
[   13.710854] vcc3v3_sys: could not add device link regulator.18: -ENOENT
[   13.712250] vccio_sd: 1800 <--> 3300 mV at 3300 mV, enabled
[   13.712677] rk808 0-0020: Looking up vcc6-supply from device tree
[   13.712706] vcc3v3_pmu: supplied by vcc3v3_sys
[   13.712725] vcc3v3_sys: could not add device link regulator.19: -ENOENT
[   13.713707] vcc3v3_pmu: 3300 mV, enabled
[   13.714166] rk808 0-0020: Looking up vcc7-supply from device tree
[   13.714194] vcca_1v8: supplied by vcc3v3_sys
[   13.714212] vcc3v3_sys: could not add device link regulator.20: -ENOENT
[   13.715575] vcca_1v8: 1800 mV, enabled
[   13.716027] rk808 0-0020: Looking up vcc7-supply from device tree
[   13.716057] vcca1v8_pmu: supplied by vcc3v3_sys
[   13.716075] vcc3v3_sys: could not add device link regulator.21: -ENOENT
[   13.717060] vcca1v8_pmu: 1800 mV, enabled
[   13.717531] rk808 0-0020: Looking up vcc7-supply from device tree
[   13.717560] vcca1v8_image: supplied by vcc3v3_sys
[   13.717580] vcc3v3_sys: could not add device link regulator.22: -ENOENT
[   13.718617] vcca1v8_image: 1800 mV, enabled
[   13.719093] rk808 0-0020: Looking up vcc9-supply from device tree
[   13.719124] vcc_3v3: supplied by vcc3v3_sys
[   13.719142] vcc3v3_sys: could not add device link regulator.23: -ENOENT
[   13.719965] vcc_3v3: at 3300 mV, enabled
[   13.720350] rk808 0-0020: Looking up vcc8-supply from device tree
[   13.720378] vcc3v3_sd: supplied by vcc3v3_sys
[   13.720397] vcc3v3_sys: could not add device link regulator.24: -ENOENT
[   13.721228] vcc3v3_sd: at 3300 mV, enabled
[   13.721643] rk817-battery: Failed to locate of_node [id: -1]
[   13.721884] rk817-battery rk817-battery: Failed to find matching dt id
[   13.722067] rk817-charger: Failed to locate of_node [id: -1]
[   13.722244] rk817-charger rk817-charger: Failed to find matching dt id
[   13.729007] rk808-rtc rk808-rtc: registered as rtc0
[   13.730807] rk808-rtc rk808-rtc: setting system clock to 2025-03-06T15:22:44 UTC (1741274564)
[   13.737455] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
[   13.737846] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!
[   13.739290] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[   13.739337] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 6
[   13.739527] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002010010
[   13.739620] xhci-hcd xhci-hcd.6.auto: irq 87, io mem 0xfcc00000
[   13.739907] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[   13.739938] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 7
[   13.739966] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[   13.740484] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[   13.740507] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.740524] usb usb6: Product: xHCI Host Controller
[   13.740537] usb usb6: Manufacturer: Linux 6.1.99-vendor-rk35xx xhci-hcd
[   13.740550] usb usb6: SerialNumber: xhci-hcd.6.auto
[   13.742530] hub 6-0:1.0: USB hub found
[   13.742618] hub 6-0:1.0: 1 port detected
[   13.743369] usb usb7: We don't know the algorithms for LPM for this host, disabling LPM.
[   13.743675] usb usb7: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[   13.743698] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.743713] usb usb7: Product: xHCI Host Controller
[   13.743726] usb usb7: Manufacturer: Linux 6.1.99-vendor-rk35xx xhci-hcd
[   13.743738] usb usb7: SerialNumber: xhci-hcd.6.auto
[   13.745380] hub 7-0:1.0: USB hub found
[   13.745472] hub 7-0:1.0: 1 port detected
[   13.746859] rkisp_hw fdff0000.rkisp: Adding to iommu group 7
[   13.747232] rkisp_hw fdff0000.rkisp: is_thunderboot: 0
[   13.747281] rkisp_hw fdff0000.rkisp: can't request region for resource [mem 0xfdff0000-0xfdffffff]
[   13.747334] rkisp_hw fdff0000.rkisp: max input:0x0@0fps
[   13.747841] rkisp_hw fdff0000.rkisp: no find phandle sram
[   13.751097] usbcore: registered new interface driver uvcvideo
[   13.754701] cpu cpu0: Failed to get specification_serial_number
[   13.754763] cpu cpu0: Failed to get leakage
[   13.754803] cpu cpu0: Looking up cpu-supply from device tree
[   13.755877] cpu cpu0: soc version=0, speed=0
[   13.755990] cpu cpu0: Looking up cpu-supply from device tree
[   13.758929] cpu cpu0: avs=0
[   13.759234] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[   13.762856] cpu cpu0: EM: OPP:600000 is inefficient
[   13.763202] cpu cpu0: EM: created perf domain
[   13.766291] sdhci: Secure Digital Host Controller Interface driver
[   13.766316] sdhci: Copyright(c) Pierre Ossman
[   13.766325] Synopsys Designware Multimedia Card Interface Driver
[   13.768059] sdhci-pltfm: SDHCI platform and OF driver helper
[   13.768865] dwmmc_rockchip fe2b0000.mmc: No normal pinctrl state
[   13.768890] dwmmc_rockchip fe2b0000.mmc: No idle pinctrl state
[   13.769075] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   13.769095] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   13.769440] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[   13.769505] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[   13.769527] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[   13.769616] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 92,32 bit host data width,256 deep fifo
[   13.769791] dwmmc_rockchip fe2b0000.mmc: Looking up vmmc-supply from device tree
[   13.769799] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   13.769843] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   13.769864] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   13.769931] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   13.770075] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   13.770129] dwmmc_rockchip fe2b0000.mmc: Looking up vqmmc-supply from device tree
[   13.770305] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   13.770317] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   13.770473] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[   13.770917] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply from device tree
[   13.770935] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply property in node /mmc@fe310000 failed
[   13.770975] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply from device tree
[   13.770983] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply property in node /mmc@fe310000 failed
[   13.771817] ledtrig-cpu: registered to indicate activity on CPUs
[   13.771869] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[   13.771954] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[   13.772828] cryptodev: driver 1.12 loaded.
[   13.772880] hid: raw HID events driver (C) Jiri Kosina
[   13.773101] usbcore: registered new interface driver usbhid
[   13.773109] usbhid: USB HID core driver
[   13.773383] rockchip,bus bus-npu: Looking up bus-supply from device tree
[   13.773560] rockchip,bus bus-npu: bin=0
[   13.773582] rockchip,bus bus-npu: Failed to get leakage
[   13.773597] rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[   13.774364] rockchip,bus bus-npu: Looking up pvtm-supply from device tree
[   13.777950] rockchip,bus bus-npu: avs=0
[   13.781463] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[   13.782452] rockchip-saradc fe720000.saradc: Looking up vref-supply from device tree
[   13.783444] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42600
[   13.783455] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42602
[   13.783460] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42605
[   13.783464] SPI driver inv-icm42600-spi has no spi_device_id for invensense,icm42622
[   13.784762] usbcore: registered new interface driver snd-usb-audio
[   13.787150] [Awinic] aw87xxx_pa_init:driver version: v2.2.0
[   13.799122] mmc0: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[   13.855639] Initializing XFRM netlink socket
[   13.855887] NET: Registered PF_PACKET protocol family
[   13.856273] [BT_RFKILL]: Enter rfkill_rk_init
[   13.856282] [WLAN_RFKILL]: Enter rfkill_wlan_init
[   13.856909] Key type dns_resolver registered
[   13.856946] Key type ceph registered
[   13.857398] libceph: loaded (mon/osd proto 15/24)
[   13.859521] registered taskstats version 1
[   13.859564] Loading compiled-in X.509 certificates
[   13.863774] zswap: loaded using pool zstd/zbud
[   13.864447] Key type .fscrypt registered
[   13.864457] Key type fscrypt-provisioning registered
[   13.865514] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
[   13.865942] pstore: Using crash dump compression: deflate
[   13.866272] AppArmor: AppArmor sha1 policy hashing enabled
[   13.876018] rga2 fdeb0000.rk_rga: probe successfully, irq = 99, hw_version:3.2.63318
[   13.876413] rga: IOMMU binding successfully, default mapping core[0x4]
[   13.876738] rga: Module initialized. v1.3.7
[   13.894302] mmc0: Host Software Queue enabled
[   13.894345] mmc0: new HS200 MMC card at address 0001
[   13.897395] mmcblk0: mmc0:0001 DV4032 29.1 GiB
[   13.898066] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[   13.906619]  mmcblk0: p1
[   13.908163] usb 2-1: new high-speed USB device number 2 using ehci-platform
[   13.910194] mmcblk0boot0: mmc0:0001 DV4032 4.00 MiB
[   13.916448] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[   13.916473] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply property in node /syscon@fdc20000/io-domains failed
[   13.916521] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[   13.916842] rockchip-iodomain fdc20000.syscon:io-domains: pmuio2(3300000 uV) supplied by vcc_3v3
[   13.916876] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[   13.917106] rockchip-iodomain fdc20000.syscon:io-domains: vccio1(3000000 uV) supplied by vccio_acodec
[   13.917133] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[   13.917149] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply property in node /syscon@fdc20000/io-domains failed
[   13.917214] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[   13.917424] rockchip-iodomain fdc20000.syscon:io-domains: vccio3(3300000 uV) supplied by vccio_sd
[   13.917442] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[   13.917610] rockchip-iodomain fdc20000.syscon:io-domains: vccio4(1800000 uV) supplied by vcc_1v8
[   13.917626] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[   13.917722] rockchip-iodomain fdc20000.syscon:io-domains: vccio5(3300000 uV) supplied by vcc_3v3
[   13.917735] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[   13.917819] rockchip-iodomain fdc20000.syscon:io-domains: vccio6(1800000 uV) supplied by vcc_1v8
[   13.917836] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[   13.917951] rockchip-iodomain fdc20000.syscon:io-domains: vccio7(3300000 uV) supplied by vcc_3v3
[   13.919083] mpp_rkvenc fdf40000.rkvenc: Adding to iommu group 5
[   13.919294] mmcblk0boot1: mmc0:0001 DV4032 4.00 MiB
[   13.919380] mpp_rkvenc fdf40000.rkvenc: probing start
[   13.920041] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[   13.920481] mpp_rkvenc fdf40000.rkvenc: bin=0
[   13.920532] mpp_rkvenc fdf40000.rkvenc: Failed to get leakage
[   13.920564] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[   13.920604] vdd_logic: could not add device link fdf40000.rkvenc: -EEXIST
[   13.920743] mpp_rkvenc fdf40000.rkvenc: Looking up venc-supply from device tree
[   13.920775] debugfs: Directory 'fdf40000.rkvenc-venc' with parent 'vdd_logic' already present!
[   13.920798] vdd_logic: Failed to create debugfs directory
[   13.921185] mpp_rkvenc fdf40000.rkvenc: avs=0
[   13.921625] mpp_rkvenc fdf40000.rkvenc: using default check_rate_volt
[   13.921661] mpp_rkvenc fdf40000.rkvenc: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[   13.922779] mpp_rkvenc fdf40000.rkvenc: probing finish
[   13.923737] mpp_vdpu2 fdea0400.vdpu: Adding to iommu group 1
[   13.924208] mpp_vdpu2 fdea0400.vdpu: probe device
[   13.924876] mpp_vdpu2 fdea0400.vdpu: probing finish
[   13.925324] mpp_vepu2 fdee0000.vepu: Adding to iommu group 3
[   13.925504] mpp_vepu2 fdee0000.vepu: probing start
[   13.925681] mmcblk0rpmb: mmc0:0001 DV4032 16.0 MiB, chardev (234:0)
[   13.925814] mpp_vepu2 fdee0000.vepu: probing finish
[   13.926151] mpp-iep2 fdef0000.iep: Adding to iommu group 4
[   13.926304] mpp-iep2 fdef0000.iep: probe device
[   13.926554] mpp-iep2 fdef0000.iep: probing finish
[   13.926853] mpp_jpgdec fded0000.jpegd: Adding to iommu group 2
[   13.927028] mpp_jpgdec fded0000.jpegd: probe device
[   13.927293] mpp_jpgdec fded0000.jpegd: probing finish
[   13.927637] mpp_rkvdec2 fdf80200.rkvdec: Adding to iommu group 6
[   13.927822] mpp_rkvdec2 fdf80200.rkvdec: rkvdec, probing start
[   13.928178] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[   13.928188] rkvdec2_init:1198: No niu aclk reset resource define
[   13.928196] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[   13.928201] rkvdec2_init:1201: No niu hclk reset resource define
[   13.928223] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[   13.928438] mpp_rkvdec2 fdf80200.rkvdec: bin=0
[   13.928463] mpp_rkvdec2 fdf80200.rkvdec: Failed to get leakage
[   13.928479] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[   13.928498] vdd_logic: could not add device link fdf80200.rkvdec: -EEXIST
[   13.928560] mpp_rkvdec2 fdf80200.rkvdec: Looking up vdec-supply from device tree
[   13.928578] debugfs: Directory 'fdf80200.rkvdec-vdec' with parent 'vdd_logic' already present!
[   13.928588] vdd_logic: Failed to create debugfs directory
[   13.928785] mpp_rkvdec2 fdf80200.rkvdec: avs=0
[   13.928955] mpp_rkvdec2 fdf80200.rkvdec: using default check_rate_volt
[   13.928973] mpp_rkvdec2 fdf80200.rkvdec: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0 h_table=0
[   13.929136] mpp_rkvdec2 fdf80200.rkvdec: sram_start 0x00000000fdcc0000
[   13.929144] mpp_rkvdec2 fdf80200.rkvdec: rcb_iova 0x0000000010000000
[   13.929150] mpp_rkvdec2 fdf80200.rkvdec: sram_size 45056
[   13.929156] mpp_rkvdec2 fdf80200.rkvdec: rcb_size 65536
[   13.929163] mpp_rkvdec2 fdf80200.rkvdec: min_width 512
[   13.929226] mpp_rkvdec2 fdf80200.rkvdec: link mode probe finish
[   13.929294] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[   13.929300] mpp_rkvdec2 fdf80200.rkvdec: probing finish
[   13.930221] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply from device tree
[   13.930256] rockchip-pm-domain fdd90000.power-management:power-controller: Looking up gpu-supply property in node /power-management@fdd90000/power-controller failed
[   13.930387] mali fde60000.gpu: Kernel DDK version g25p0-00eac0
[   13.930403] mali fde60000.gpu: error -ENXIO: IRQ JOB not found
[   13.930537] mali fde60000.gpu: error -ENXIO: IRQ MMU not found
[   13.930621] mali fde60000.gpu: error -ENXIO: IRQ GPU not found
[   13.930691] mali fde60000.gpu: Insufficient register space, will override to the required size
[   13.930705] mali fde60000.gpu: Register window unavailable
[   13.930711] mali fde60000.gpu: Failed to map registers
[   13.930716] mali fde60000.gpu: Register map failed error = -5
[   13.930722] mali fde60000.gpu: Device initialization failed
[   13.930776] mali: probe of fde60000.gpu failed with error -5
[   13.930817] rockchip-dmc dmc: Failed to get specification_serial_number
[   13.930853] rockchip-dmc dmc: Failed to get leakage
[   13.930875] rockchip-dmc dmc: Looking up center-supply from device tree
[   13.931220] rockchip-dmc dmc: soc version=0, speed=0
[   13.931274] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   13.931283] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   13.931347] rockchip-dmc dmc: Looking up center-supply from device tree
[   13.931417] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   13.931449] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   13.931459] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   13.931495] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   13.931568] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   13.931632] rockchip-dmc dmc: avs=0
[   13.931651] rockchip-dmc dmc: current ATF version 0x102
[   13.931738] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   13.931749] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   13.932273] rockchip-dmc dmc: normal_rate = 780000000
[   13.932288] rockchip-dmc dmc: reboot_rate = 1560000000
[   13.932299] rockchip-dmc dmc: suspend_rate = 324000000
[   13.932306] rockchip-dmc dmc: video_4k_rate = 780000000
[   13.932312] rockchip-dmc dmc: video_4k_10b_rate = 780000000
[   13.932320] rockchip-dmc dmc: boost_rate = 1560000000
[   13.932327] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 1560000000
[   13.932333] rockchip-dmc dmc: performance_rate = 1560000000
[   13.932377] rockchip-dmc dmc: failed to get vop pn to msch rl
[   13.932622] rockchip-dmc dmc: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[   13.971461] vendor storage:20190527 ret = 0
[   13.978917] WCN: marlin_init entry!
[   13.979131] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   13.979153] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   13.979333] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   13.979398] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   13.979418] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   13.979482] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   13.979656] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   13.979956] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   13.979981] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   13.980742] RKNPU fde40000.npu: Adding to iommu group 0
[   13.981532] RKNPU fde40000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[   13.981639] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[   13.981902] RKNPU fde40000.npu: Looking up mem-supply from device tree
[   13.981925] RKNPU fde40000.npu: Looking up mem-supply property in node /npu@fde40000 failed
[   13.982005] RKNPU fde40000.npu: can't request region for resource [mem 0xfde40000-0xfde4ffff]
[   13.982068] RKNPU fde40000.npu: error -ENXIO: IRQ npu_irq not found
[   13.982885] [drm] Initialized rknpu 0.9.8 20240828 for fde40000.npu on minor 1
[   13.983604] RKNPU fde40000.npu: Failed to get specification_serial_number
[   13.983650] RKNPU fde40000.npu: Failed to get leakage
[   13.983685] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[   13.983736] vdd_npu: could not add device link fde40000.npu: -EEXIST
[   13.983797] RKNPU fde40000.npu: soc version=0, speed=0
[   13.983897] RKNPU fde40000.npu: Looking up rknpu-supply from device tree
[   13.983943] debugfs: Directory 'fde40000.npu-rknpu' with parent 'vdd_npu' already present!
[   13.983963] vdd_npu: Failed to create debugfs directory
[   13.985589] RKNPU fde40000.npu: avs=0
[   13.986025] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=800000000 h_limit=0 h_table=0
[   13.989924] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   13.991193] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   13.991214] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   13.991373] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   13.991412] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   13.991425] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   13.991465] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   13.991577] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   13.991772] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   13.991787] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.006457] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.007174] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   14.007269] clk: Disabling unused clocks
[   14.008093] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[   14.008856] rockchip-suspend not set sleep-mode-config for mem-lite
[   14.008863] rockchip-suspend not set wakeup-config for mem-lite
[   14.008870] rockchip-suspend not set sleep-mode-config for mem-ultra
[   14.008874] rockchip-suspend not set wakeup-config for mem-ultra
[   14.009935] ALSA device list:
[   14.009950]   #0: rockchip,hdmi
[   14.010765] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.010781] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.010902] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.010925] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.010934] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.010973] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.011065] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.011215] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.011225] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.018605] Freeing unused kernel memory: 8320K
[   14.018909] Run /init as init process
[   14.018918]   with arguments:
[   14.018925]     /init
[   14.018929]     splash
[   14.018934]   with environment:
[   14.018938]     HOME=/
[   14.018942]     TERM=linux
[   14.018946]     ubootpart=56a0f540-524e-4f8b-8bb2-dadfd100fc0c
[   14.018951]     cgroup_enable=memory
[   14.018956]     cgroup_memory=1
[   14.039440] usb 1-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   14.039470] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   14.039479] usb 1-1: Product: USB2.0 HUB
[   14.060080] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[   14.060110] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   14.060120] usb 2-1: Product: USB2.0 Hub
[   14.061123] hub 2-1:1.0: USB hub found
[   14.061802] hub 2-1:1.0: 4 ports detected
[   14.067005] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.067030] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.067178] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.067219] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.067233] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.067286] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.067472] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.067680] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.067698] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.286072] hub 1-1:1.0: USB hub found
[   14.286264] hub 1-1:1.0: 4 ports detected
[   14.289191] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.289210] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.289341] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.289372] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.289383] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.289421] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.289554] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.289708] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.289720] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.671430] usb 1-1.2: new low-speed USB device number 3 using xhci-hcd
[   14.749308] input: adc-keys as /devices/platform/adc-keys/input/input3
[   14.753291] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.753310] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.753456] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.753490] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.753501] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.753543] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.753668] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.753840] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.753855] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.765654] usb 1-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[   14.765677] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   14.765684] usb 1-1.2: Product: Lenovo USB Optical Mouse
[   14.765690] usb 1-1.2: Manufacturer: PixArt
[   14.830084] rk_gmac-dwmac fe010000.ethernet end1: renamed from eth0
[   14.859326] rk_gmac-dwmac fe2a0000.ethernet end0: renamed from eth1
[   14.865583] rockchip-thermal fe710000.tsadc: tsadc is probed successfully!
[   14.867223] rockchip-cpuinfo cpuinfo: SoC        : 35683000
[   14.867246] rockchip-cpuinfo cpuinfo: Serial        : c744c33f00e28e4f
[   14.868802] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.868823] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.869071] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.869118] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.869129] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.869175] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.869306] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.869486] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.869503] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   14.953581] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbhost/fd000000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:608D.0001/input/input4
[   14.954193] hid-generic 0003:17EF:608D.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.4.auto-1.2/input0
[   14.956527] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   14.956549] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   14.956743] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   14.956789] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   14.956801] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   14.956846] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   14.956975] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   14.957200] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   14.957221] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   15.034792] usb 1-1.3: new low-speed USB device number 4 using xhci-hcd
[   15.136543] usb 1-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[   15.136573] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   15.136589] usb 1-1.3: Product: Lenovo Traditional USB Keyboard
[   15.136602] usb 1-1.3: Manufacturer: Lenovo
[   15.344943] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbhost/fd000000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:17EF:6099.0002/input/input5
[   15.402971] hid-generic 0003:17EF:6099.0002: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.4.auto-1.3/input0
[   15.409022] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   15.409077] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   15.409338] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   15.409437] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   15.409475] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   15.409579] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   15.410461] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   15.411042] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   15.411094] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   16.582322] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Quota mode: none.
[   16.949545] NET: Registered PF_INET6 protocol family
[   16.950690] Segment Routing with IPv6
[   16.950722] In-situ OAM (IOAM) with IPv6
[   16.973857] systemd[1]: systemd 255.4-1ubuntu8.5 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   16.973899] systemd[1]: Detected architecture arm64.
[   16.977225] systemd[1]: Hostname set to <yy3568>.
[   17.578784] systemd[1]: Queued start job for default target graphical.target.
[   17.654020] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[   17.658662] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[   17.660135] systemd[1]: Created slice user.slice - User and Session Slice.
[   17.660649] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[   17.661729] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[   17.661968] systemd[1]: Expecting device dev-ttyFIQ0.device - /dev/ttyFIQ0...
[   17.662177] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[   17.662395] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[   17.662597] systemd[1]: Reached target slices.target - Slice Units.
[   17.662747] systemd[1]: Reached target swap.target - Swaps.
[   17.662891] systemd[1]: Reached target time-set.target - System Time Set.
[   17.663102] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[   17.682628] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
[   17.683849] systemd[1]: Listening on syslog.socket - Syslog Socket.
[   17.684859] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[   17.685503] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[   17.686549] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[   17.687681] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[   17.688124] systemd[1]: systemd-pcrextend.socket - TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   17.691239] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[   17.692518] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[   17.697540] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[   17.701367] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[   17.705740] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[   17.711065] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[   17.712184] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[   17.724937] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[   17.742856] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[   17.748064] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[   17.749925] (-hwclock)[326]: fake-hwclock-load.service: Referenced but unset environment variable evaluates to an empty string: FORCE
[   17.753444] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[   17.760429] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[   17.774666] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[   17.787012] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   17.810050] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[   17.818352] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[   17.820820] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[   17.822199] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[   17.830682] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[   17.831485] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   17.838101] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[   17.838859] systemd[1]: systemd-tpm2-setup-early.service - TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   17.855881] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   17.857427] fuse: init (API version 7.37)
[   17.865119] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   17.870226] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   17.872784] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   17.874297] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   17.876571] systemd[1]: fake-hwclock-load.service: Deactivated successfully.
[   17.877490] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
[   17.880084] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[   17.883062] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   17.883953] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[   17.886578] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   17.889092] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[   17.891277] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   17.892414] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[   17.894397] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   17.896116] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   17.898528] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   17.899363] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[   17.901243] EXT4-fs (mmcblk0p1): re-mounted. Quota mode: none.
[   17.901982] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   17.903042] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[   17.916067] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[   17.922500] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[   17.923214] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   17.950101] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[   17.954510] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[   17.957940] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[   17.959971] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[   17.971111] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   17.972370] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   17.977417] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[   17.982555] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[   17.982824] systemd[1]: systemd-tpm2-setup.service - TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   17.986156] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[   18.008600] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   18.039843] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully.
[   18.041663] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[   18.046427] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[   18.049460] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
[   18.050787] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[   18.059096] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[   18.132458] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
[   18.133419] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
[   18.158633] systemd[1]: Mounting tmp.mount - /tmp...
[   18.164395] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
[   18.168562] systemd[1]: Mounted tmp.mount - /tmp.
[   18.169181] systemd[1]: Reached target local-fs.target - Local File Systems.
[   18.174191] systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management (Varlink).
[   18.179186] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
[   18.183782] systemd[1]: Starting console-setup.service - Set console font and keymap...
[   18.184298] systemd[1]: ldconfig.service - Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
[   18.199144] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
[   18.209232] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
[   18.209625] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   18.252792] systemd[1]: Finished console-setup.service - Set console font and keymap.
[   18.262787] systemd[1]: Received SIGRTMIN+20 from PID 252 (plymouthd).
[   18.266707] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
[   18.278730] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 369 (systemd-binfmt)
[   18.283369] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
[   18.360266] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
[   18.366092] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
[   18.413192] zram: Added device: zram0
[   18.413753] zram: Added device: zram1
[   18.414437] zram: Added device: zram2
[   18.435759] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
[   18.507338] zram0: detected capacity change from 0 to 4004672
[   18.539024] Adding 2002332k swap on /dev/zram0.  Priority:5 extents:1 across:2002332k SSFS
[   18.695275] zram1: detected capacity change from 0 to 102400
[   18.738134] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
[   18.765666] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
[   18.798643] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
[   18.828619] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
[   18.851907] EXT4-fs (zram1): mounted filesystem without journal. Quota mode: none.
[   18.928967] systemd[1]: Found device dev-ttyFIQ0.device - /dev/ttyFIQ0.
[   18.932997] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
[   18.935136] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
[   18.935860] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
[   18.936686] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[   19.470677] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
[   19.495900] panfrost fde60000.gpu: clock rate = 594000000
[   19.495944] panfrost fde60000.gpu: bus_clock rate = 500000000
[   19.496030] panfrost fde60000.gpu: Looking up mali-supply from device tree
[   19.509117] systemd[1]: Starting systemd-journald.service - Journal Service...
[   19.545044] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[   19.545070] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[   19.545078] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[   19.545087] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[   19.569193] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 2
[   19.572834] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   19.572856] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   19.572977] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   19.573016] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   19.573027] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   19.573069] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   19.573207] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   19.573378] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   19.573392] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   19.577223] systemd-journald[515]: Collecting audit messages is disabled.
[   19.751454] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input6
[   19.769917] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   19.769935] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   19.770350] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   19.770396] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   19.770407] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   19.770452] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   19.804661] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   19.832119] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   19.832149] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   19.874476] CAN device driver interface
[   20.075710] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   20.091372] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   20.091395] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   20.091521] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   20.091560] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   20.091571] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   20.091613] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   20.102815] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   20.113269] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   20.113301] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   20.173891] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   20.286240] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
[   20.315410] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[   20.315915] systemd[1]: ldconfig.service - Rebuild Dynamic Linker Cache was skipped because no trigger condition checks were met.
[   20.321842] (-hwclock)[544]: fake-hwclock-load.service: Referenced but unset environment variable evaluates to an empty string: FORCE
[   20.325595] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[   20.336958] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   20.350605] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[   20.351197] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   20.351554] systemd[1]: systemd-machine-id-commit.service - Commit a transient machine-id on disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   20.351639] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   20.352003] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[   20.352136] systemd[1]: systemd-tpm2-setup-early.service - TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   20.352207] systemd[1]: systemd-tpm2-setup.service - TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   20.353962] systemd[1]: fake-hwclock-load.service: Deactivated successfully.
[   20.361698] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
[   20.373222] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   20.374006] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[   20.383129] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   20.420284] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   20.421082] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   20.423087] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   20.423848] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[   20.425119] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   20.425309] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[   20.485733] systemd[1]: Started systemd-journald.service - Journal Service.
[   20.535917] systemd-journald[515]: Received client request to flush runtime journal.
[   20.851616] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   21.194438] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   22.532196] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   22.651042] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
[   25.134386] rk_gmac-dwmac fe2a0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   25.135368] phy_rtl8211f_led_fixup in
[   25.135538] phy_rtl8211f_led_fixup in  val=0x0000
[   25.136029] phy_rtl8211f_led_fixup in
[   25.136160] phy_rtl8211f_led_fixup in  val=0x0000
[   25.194828] rk_gmac-dwmac fe2a0000.ethernet end0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   25.195399] dwmac4: Master AXI performs any burst length
[   25.195426] rk_gmac-dwmac fe2a0000.ethernet end0: No Safety Features support found
[   25.195456] rk_gmac-dwmac fe2a0000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported
[   25.195893] rk_gmac-dwmac fe2a0000.ethernet end0: registered PTP clock
[   25.196354] rk_gmac-dwmac fe2a0000.ethernet end0: configuring for phy/rgmii link mode
[   25.237573] rk_gmac-dwmac fe010000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0
[   25.238428] phy_rtl8211f_led_fixup in
[   25.238586] phy_rtl8211f_led_fixup in  val=0x0a42
[   25.239068] phy_rtl8211f_led_fixup in
[   25.239198] phy_rtl8211f_led_fixup in  val=0x0000
[   25.328200] rk_gmac-dwmac fe010000.ethernet end1: PHY [stmmac-1:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   25.328769] dwmac4: Master AXI performs any burst length
[   25.328804] rk_gmac-dwmac fe010000.ethernet end1: No Safety Features support found
[   25.328831] rk_gmac-dwmac fe010000.ethernet end1: IEEE 1588-2008 Advanced Timestamp supported
[   25.329206] rk_gmac-dwmac fe010000.ethernet end1: registered PTP clock
[   25.329681] rk_gmac-dwmac fe010000.ethernet end1: configuring for phy/rgmii link mode
[   25.575141] usb 1-1: USB disconnect, device number 2
[   25.575168] usb 1-1.2: USB disconnect, device number 3
[   25.794397] usb 1-1.3: USB disconnect, device number 4
[   28.167818] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   28.167838] Bluetooth: BNEP filters: protocol multicast
[   28.167856] Bluetooth: BNEP socket layer initialized
[   28.838085] usb 6-1: new full-speed USB device number 2 using xhci-hcd
[   28.979129] usb 6-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   28.979153] usb 6-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   28.979161] usb 6-1: Product: USB2.0 HUB
[   29.204292] hub 6-1:1.0: USB hub found
[   29.204437] hub 6-1:1.0: 4 ports detected
[   29.207177] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   29.207200] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   29.209264] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   29.209324] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   29.209335] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   29.209388] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   29.209541] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   29.209732] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   29.209747] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   29.588054] usb 6-1.2: new low-speed USB device number 3 using xhci-hcd
[   29.685462] usb 6-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[   29.685488] usb 6-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   29.685495] usb 6-1.2: Product: Lenovo USB Optical Mouse
[   29.685501] usb 6-1.2: Manufacturer: PixArt
[   29.869377] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbdrd/fcc00000.usb/xhci-hcd.6.auto/usb6/6-1/6-1.2/6-1.2:1.0/0003:17EF:608D.0003/input/input7
[   29.870369] hid-generic 0003:17EF:608D.0003: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.6.auto-1.2/input0
[   29.872866] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   29.872889] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   29.873583] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   29.873645] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   29.873654] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   29.873706] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   29.873923] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   29.877213] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   29.877248] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   29.941507] usb 6-1.3: new low-speed USB device number 4 using xhci-hcd
[   30.043302] usb 6-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[   30.043332] usb 6-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   30.043339] usb 6-1.3: Product: Lenovo Traditional USB Keyboard
[   30.043351] usb 6-1.3: Manufacturer: Lenovo
[   30.125901] platform mtd_vendor_storage: deferred probe pending
[   30.126870] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   30.126894] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   30.127171] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   30.127234] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   30.127245] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   30.127296] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   30.127490] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   30.127857] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   30.127882] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   30.257307] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbdrd/fcc00000.usb/xhci-hcd.6.auto/usb6/6-1/6-1.3/6-1.3:1.0/0003:17EF:6099.0004/input/input8
[   30.313061] hid-generic 0003:17EF:6099.0004: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.6.auto-1.3/input0
[   30.315490] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   30.315515] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   30.318203] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   30.318260] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   30.318273] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   30.318325] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   30.318498] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   30.318720] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   30.318740] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   32.116825] xhci-hcd xhci-hcd.6.auto: remove, state 4
[   32.116864] usb usb7: USB disconnect, device number 1
[   32.117655] xhci-hcd xhci-hcd.6.auto: USB bus 7 deregistered
[   32.117694] xhci-hcd xhci-hcd.6.auto: remove, state 1
[   32.117714] usb usb6: USB disconnect, device number 1
[   32.117724] usb 6-1: USB disconnect, device number 2
[   32.117731] usb 6-1.2: USB disconnect, device number 3
[   32.297812] usb 6-1.3: USB disconnect, device number 4
[   32.718819] xhci-hcd xhci-hcd.6.auto: USB bus 6 deregistered
[   37.095851] rfkill: input handler disabled
[   39.724707] [GTP-ERR][__do_register_ext_module:79] Module [goodix-fwu] timeout
[   49.311565] usb 2-1.1: new full-speed USB device number 3 using ehci-platform
[   49.411520] usb 2-1.1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   49.411587] usb 2-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   49.411619] usb 2-1.1: Product: USB2.0 HUB
[   49.413826] hub 2-1.1:1.0: USB hub found
[   49.414144] hub 2-1.1:1.0: 4 ports detected
[   49.422797] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   49.422852] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   49.423151] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   49.423273] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   49.423312] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   49.423423] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   49.423878] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   49.424448] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   49.424499] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   55.664861] usb 1-1: new full-speed USB device number 5 using xhci-hcd
[   55.810301] usb 1-1: New USB device found, idVendor=0a05, idProduct=7211, bcdDevice= 1.00
[   55.810371] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[   55.810403] usb 1-1: Product: USB2.0 HUB
[   55.949571] hub 1-1:1.0: USB hub found
[   55.949853] hub 1-1:1.0: 4 ports detected
[   55.957730] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   55.957790] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   55.958335] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   55.958479] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   55.958521] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   55.958638] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   55.959201] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   55.959821] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   55.959876] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   56.334716] usb 1-1.2: new low-speed USB device number 6 using xhci-hcd
[   56.432123] usb 1-1.2: New USB device found, idVendor=17ef, idProduct=608d, bcdDevice= 1.00
[   56.432146] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   56.432153] usb 1-1.2: Product: Lenovo USB Optical Mouse
[   56.432159] usb 1-1.2: Manufacturer: PixArt
[   56.610045] input: PixArt Lenovo USB Optical Mouse as /devices/platform/usbhost/fd000000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:608D.0005/input/input9
[   56.610516] hid-generic 0003:17EF:608D.0005: input,hidraw0: USB HID v1.11 Mouse [PixArt Lenovo USB Optical Mouse] on usb-xhci-hcd.4.auto-1.2/input0
[   56.612566] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   56.612586] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   56.612805] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   56.612850] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   56.612860] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   56.612898] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   56.613075] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   56.613473] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   56.613498] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   56.684694] usb 1-1.3: new low-speed USB device number 7 using xhci-hcd
[   56.786085] usb 1-1.3: New USB device found, idVendor=17ef, idProduct=6099, bcdDevice= 1.00
[   56.786107] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   56.786114] usb 1-1.3: Product: Lenovo Traditional USB Keyboard
[   56.786120] usb 1-1.3: Manufacturer: Lenovo
[   56.997587] input: Lenovo Lenovo Traditional USB Keyboard as /devices/platform/usbhost/fd000000.usb/xhci-hcd.4.auto/usb1/1-1/1-1.3/1-1.3:1.0/0003:17EF:6099.0006/input/input10
[   57.052094] hid-generic 0003:17EF:6099.0006: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Traditional USB Keyboard] on usb-xhci-hcd.4.auto-1.3/input0
[   57.054060] dwmmc_rockchip fe000000.mmc: No normal pinctrl state
[   57.054079] dwmmc_rockchip fe000000.mmc: No idle pinctrl state
[   57.054229] dwmmc_rockchip fe000000.mmc: IDMAC supports 32-bit address mode.
[   57.054265] dwmmc_rockchip fe000000.mmc: Using internal DMA controller.
[   57.054275] dwmmc_rockchip fe000000.mmc: Version ID is 270a
[   57.054317] dwmmc_rockchip fe000000.mmc: DW MMC controller at irq 93,32 bit host data width,256 deep fifo
[   57.054933] dwmmc_rockchip fe000000.mmc: Looking up vmmc-supply from device tree
[   57.055785] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply from device tree
[   57.055816] dwmmc_rockchip fe000000.mmc: Looking up vqmmc-supply property in node /mmc@fe000000 failed
[   72.595941] rockchip_canfd fe580000.can can0: rockchip_canfd_get_berr_counter RX_ERR_CNT=0x00000000, TX_ERR_CNT=0x00000000
Edited by Hqnicolas
Build Images:
Armbian-unofficial_25.05.0-trunk
Yy3568 noble vendor 6.1.99 Minimal
Yy3568 noble vendor 6.1.99 gnome Desktop
Yy3568 noble current 6.12.17 minimal
Yy3568 noble current 6.12.17 gnome Desktop
ubuntu 22.04 kernel 5.1 Vendor
Server
Desktop
ubuntu 24.04 kernel 6.1 Vendor
Desktop
Server
Hello Hqnicolas,
thank you very much for the effort you made with the yy3568.
I have a nvme SSD connected to .m2 and this works with the youyeetoo kernel "Linux yy3568 4.19.232 #8 SMP Wed Aug 7 10:48:37 CEST 2024 aarch64 GNU/Linux".
I tried your Armbian plus the attached patch but the SSD doesn't work. See attached screenlog.0
[    2.512779] pci 0000:00:00.0: ROM [mem 0xf4200000-0xf420ffff pref]: assigned
[    2.512806] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.512830] pci_bus 0000:00: resource 4 [io  0x0000-0xfffff]
[    2.512844] pci_bus 0000:00: resource 5 [mem 0xf4200000-0xf5ffffff]
[    2.512857] pci_bus 0000:00: resource 6 [mem 0x300000000-0x33fffffff]
[    2.516131] pcieport 0000:00:00.0: PME: Signaling with IRQ 73
[    2.516722] pcieport 0000:00:00.0: AER: enabled with IRQ 73
[    2.518475] phy phy-fe8c0000.phy.2: lane number 0, val 1
[    2.518506] phy phy-fe8c0000.phy.2: lane number 1, val 2
[    2.518519] phy phy-fe8c0000.phy.2: bifurcation enabled
[    2.519039] phy phy-fe8c0000.phy.2: rockchip_p3phy_rk3568_init: lock failed 0x6890000, check input refclk and power supply
[    2.519059] phy phy-fe8c0000.phy.2: phy init failed --> -110
[    2.519102] rockchip-dw-pcie 3c0800000.pcie: probe with driver rockchip-dw-pcie failed with error -110
[    2.520137] mmc0: new HS200 MMC card at address 0001
[    2.525326] mmcblk0: mmc0:0001 ISOCOM 57.6 GiB
[    2.529794] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
[    2.531377] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
[    2.531408] rockchip-usb2phy fe8a0000.usb2phy: Requested PHY is disabled
At least is PCI bridge found:
root@yy3568:~# lspci -v
00:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3568 Remote Signal Processor (rev 01) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 73
        Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
        I/O behind bridge: [disabled] [16-bit]
        Memory behind bridge: [disabled] [32-bit]
        Prefetchable memory behind bridge: [disabled] [64-bit]
        Expansion ROM at f4200000 [virtual] [disabled] [size=64K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
        Capabilities: [70] Express Root Port (Slot-), MSI 00
        Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [148] Secondary PCI Express
        Capabilities: [160] L1 PM Substates
        Capabilities: [170] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
        Kernel driver in use: pcieport
It would be great if you find some time to find a solution.
Kind Regards,
Guenter
kernel-rockchip64-edge.patch screenlog.0
Posted (edited)
No problem. Good luck with the exams.
And thank you for the interesting link. I remember there was a hype about fuzzy logic, when I was young and in college😀.
Edited by guenter
4 hours ago, fss-hacks said:
YY3568 is now one of the Armbian recognized boards
Sadly no. https://github.com/armbian/build/tree/main/config/boards
There are (too) many boards in the system, added by random people (this is build system and we accept anything that builds, but we don't maintain those boards as we can't afford associated costs / there are not enough resources), but only supported / .conf are recognized until there is someone willing to maintaining them and fits condition of "supported" board. When we find out that conditions are not met anymore, they are "un-recognized".
Support is defined under those rules: https://docs.armbian.com/User-Guide_Board-Support-Rules
On 7/7/2025 at 2:09 AM, fss-hacks said:
This SSD thing has been broken for several months. YY3568 is now one of the Armbian recognized boards. Can someone please provide a fix?
I bring the board up to use it on metal and Low level development,
I use pci-e for jtag but I never considered the possibility of using an nvme there
In my opinion, if you have a board that is running with internal emmc and sdcard you can provide an adjustment for pci-e NVME,
It is a small adjustment, related to just one functionality of the board.
I hope I'm not the only one with this board in my hands
I agree, it would be a small adjustment that is hopefully easy. I don't know how to do it myself but the inbuilt eMMC is definitely not big enough for the kind of files I want to serve from the board.
And I apologize, I didn't realize that random people can upload builds like that; I meant that it appeared to be a listed frequently updated board.
Posted (edited)
My apologies. I started working on this board again and just spent 3 wasted hours getting angry at the previous wipe eMMC instructions only to realize *I* had the wrong version of RKDevTool.
Protip - do not do any hardware development angry, hungry, in a rage, or pressed for time. Wow.
Here is the issues with your "erase eMMC" instructions (apparently partly taken from the guide to getting Linux on the T95 Plus):
-Config file was loaded, loader, parameters and uboot were written.
Board usually does not restart when this is done, restarted once out of my many attempts.
-There are no instructions about "wipe_part", what partitions to destroy, or how to do this. Using your version of RKDevTool, no partitions are loaded which then appear in the Download Image window (as I assume they are supposed to).
-Flashing the other Miniloader file is met with a Waiting for Device Success prompt, which never completes.
These instructions obviously worked the first time I did this several months ago. I don't know what at all could have changed, and I'm pretty frustrated as I'm trying to recover from another OMV system crashing and trying to recover data, so the use was/is pretty urgent, and given this forum, it could be a few days before a replay so my system is now sitting hostage to these instructions.
Edited by fss-hacks
On 11/4/2025 at 4:15 AM, dale said:
guide to compile for that chip?
You need to imagine it as a chip, the entire board; each change to the board alters the description of the "chip" you're referring to. Search for your board model on the forum. I don't own any boards using RK3399, but I believe you can find several users mentioning the board on the forum. for YY3568 board, the factory already have all information https://wiki.youyeetoo.com/en/YY3568/sdCardSystem
can you please share the config for the 3568 / or patch so I can refer to for the 3399 chip?
Thank you!
The rk3588 soc has a fixed boot order which is spi, emmc, microsd, other I think. So if there is a boot loader found on spi it will ignore other options and try to boot from that.
While Armbian uboot binaries on spi are instructed to check if there is a microsd card inserted and boot from that, vendors can (ab)use this circumstance to make it harder for other operation systems being used because tools like rkdevtool are necessary to get rid of it. If the spi is pre-flashed with crap, I guess that's why the step is necessary.
Hello,
I am facing an issue with my Youyeetoo YY3568 board.
After that, I attempted to flash my own Yocto (Radxa manifest–based) wic image for the YY3568 using RKDevTool on Windows, but the flashing did not complete successfully.
Since then, the board is always detected in Maskrom mode and never switches back to Loader mode.
What I have tried so far:
1- Flashed prebuilt Ubuntu image (YY3568_Ubuntu_EDP.img) from the official link:
https://drive.google.com/drive/folders/1D90vztL9fRfWV7laV9mdcnZ5kNpxx_tl
→ Board still shows Maskrom mode after flashing.
2- Flashed SDK-based image and loader built using the official documentation:
https://wiki.youyeetoo.com/en/YY3568/ubuntu
→ Board remains in Maskrom mode.
I have tried flashing from both Windows (RKDevTool) and Linux (rkdeveloptool), but the board is consistently detected in Maskrom mode.
Question:
How can I recover the board from Maskrom mode and bring it back into Loader mode, so that I can flash images and make the board operational again?
Any guidance would be appreciated.
Thank you.
On 1/20/2026 at 4:04 AM, M Ali said:
Question:
Thank you.
You need to clear the EMMC and flash the bootloader
an easy way to do it, just flash the android update image, it will flash the bootloader.
if you are making experiments with this board use this bootloader
Testing Kernel 7, Buiding new images inside docker on 24.04 ubuntu x86
sudo apt update
sudo apt install -y qemu-user-static binfmt-support
sudo systemctl restart systemd-binfmt
update-binfmts --display qemu-aarch64
docker run --privileged --rm tonistiigi/binfmt --install all
docker run --rm --platform linux/arm64 arm64v8/ubuntu uname -m
git clone https://github.com/armbian/build.git
cd build
newgrp docker
./compile.sh docker-shell
./compile.sh BOARD=yy3568 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_ENVIRONMENT=gnome DESKTOP_TIER=mid KERNEL_CONFIGURE=no RELEASE=resolute
