monetschemist Posted August 22 Posted August 22 Greetings; I have downloaded this https://dl.armbian.com/cubox-i/Noble_current_server and verified that I got what I was supposed to (ASC, SHA). I have used a brand new usbimager to install it on various freshly formatted (brand new SD Formatter) and verified working Samsung Evo 32GB, SanDisk Extreme Plus 16GB, Extreme Plus 32GB. All the formatting, imaging and installation done on an Ubuntu 25.04 laptop. After usbimager is done, if I use the Ubuntu Disks application to look at the drive, the first partion shows as free space, which seems suspicious. When I insert the newly-set up SD cards in the Cubox-i4, I see the bootloader start and then do its handoff to the operating system... and then nothing. No more signal on the HDMI cable, nothing out on ssh, nothing. The Cubox-i4 tries to reboot every few minutes with no more successful outcome. This same Cubox-i4 runs fine with the last SD card system disk I built for it using the previous Debian server image. Does anyone have any ideas? Thanks in advance! 0 Quote
laibsch Posted August 23 Posted August 23 unfortunately, we do not have a maintainer for this board, so it gets very little testing 0 Quote
Igor Posted August 24 Posted August 24 https://paste.armbian.com/ehuwawexih v25.5.1 image (Debian Bookworm minimal) runs on my Cubox i4, but HDMI out is untested ... images were released, only because I manage to spent some time testing and as I found out that build actually works. 1 Quote
monetschemist Posted August 24 Author Posted August 24 Thanks for your replies! @Igor is that screen shot you've pastebinned from a connection to the usb TTY? I've ordered a new card reader / writer which should be here tomorrow. The only one I currently have is in my elderly System76 laptop and I'm not fully confident in its driver support (for example it doesn't eject or unmount, so my only recourse is to run sync a bunch of times and then shut the machine down). I don't think there's much point in building new cards with the Bookworm minimal version as that's what I currently have on my Cuboxes. I will report back. Thanks again! 0 Quote
Igor Posted August 24 Posted August 24 2 hours ago, monetschemist said: is that screen shot you've pastebinned from a connection to the usb TTY? Connected via SSH. DHCP client is automatically getting IP, so you should be able to find the device on network after few minutes ... in case HDMI output is really broken. I can't test that as device is stashed to some rack. 0 Quote
monetschemist Posted August 25 Author Posted August 25 @Igor thanks for the reply. In my case, I can't even ping the Cubox much less connect to it. I'm pretty sure something is failing as the device reboots itself every ~ 2 minutes; each time I see the initial boot with logo on the HDMI, then the screen goes blank, then my monitor claims that HDMI signal is lost, then nothing (including no successful pings) for a couple of minutes, then around again. I've ordered some new SD cards and a USB SD card reader writer which should arrive Wednesday. Maybe things will improve after that. If not I will try a serial connection via USB. I will report back. 0 Quote
Igor Posted August 25 Posted August 25 16 minutes ago, monetschemist said: If not I will try a serial connection via USB. That would be good. Cubox-i has standard microUSB connector for serial console, so its easy. That would give some insights on what is happening. 0 Quote
monetschemist Posted August 28 Author Posted August 28 @Igor well I'm not getting very far, unless I'm prepared to count failures... I have more of those. The SD Card reader / writer works well; I can use it to carry out various operations on my brand-new SanDisk Extreme Pro A2, including formatting from the Ubuntu Disks application, running SDCardFormatter, using usbimager to create the Armbian 25.5.1 Noble Minimal system disk, mounting, unmounting and ejecting... When I've finally got the SD card set up, here's what the Ubuntu Disk application shows. Note the first partition is 4.2MB of free space. When I put this SD card in the Cubox and boot from it, the same thing appears to happen as previously - on the HDMI-connected monitor, the Cubox bootloader runs and hands off to the boot program, after which the monitor reports no HDMI signal and the monitor goes into sleep mode. After approximately two minutes, the Cubox bootloader appears again on the monitor, hands off to the boot program, and... the same thing. Nothing seems to be active at the IP address - I can neither ping nor ssh to it. This time I have my laptop connected vi USB to the Cubox console port. Various positive messages show up in dmesg finally ending in: usb 1-6: Detected FT-X usb 1-6: FTDI USB Serial Device converter now attached to ttyUSB0 But running either screen or minicom, they return immediately, showing no sign of having established any kind of connection, no waiting for a connection, no error message, nothing. Just a reminder that this Cubox boots and runs fine on the current system SD card which is up-to-date bookworm minimal. 0 Quote
Igor Posted August 28 Posted August 28 3 hours ago, monetschemist said: When I've finally got the SD card set up, here's what the Ubuntu Disk application shows. Note the first partition is 4.2MB of free space. This looks normal. Most of those boards have bootloaders at locations prior to boot partition. 3 hours ago, monetschemist said: After approximately two minutes, the Cubox bootloader appears again on the monitor, hands off to the boot program, and... the same thing. Boot loop. This can be many things - i would guess kernel crash and watchdog issue restart. Why that happens? Hard to tell. 3 hours ago, monetschemist said: But running either screen or minicom This way? sudo screen /dev/ttyUSB0 115200 It should prompt out something. 0 Quote
monetschemist Posted Friday at 01:28 AM Author Posted Friday at 01:28 AM Good evening all and thanks @Igor for the suggestions. I managed to connect to my Cubox-i4 from my laptop via USB with sudo picocom -b 115200 -r -l /dev/ttyUSB0 and now I have lots of messages, but no success with booting the Ubuntu 24.04 Noble minimal image. In particular, there is a complaint about a CRC error. I've attached the text generated by letting the boot process run for awhile. I decided to try the Bookworm minimal image, and I'm up and running right away with that. So I guess I will stick with Bookworm for now. If anyone generates a new Ubuntu 24.04 image they would like me to try, happy to give it a go. Or of course any other suggestions! booting_ubuntu_cubox-i.txt 0 Quote
Igor Posted Saturday at 07:21 PM Posted Saturday at 07:21 PM On 10/3/2025 at 3:28 AM, monetschemist said: there is a complaint about a CRC error "*** Warning - bad CRC, using default environment" This is safe to ignore. It is strange why Ubuntu doesn't work, while Bookworm does. This could be some build infrastructure issue. On 10/3/2025 at 3:28 AM, monetschemist said: If anyone generates a new Ubuntu 24.04 image https://docs.armbian.com/Developer-Guide_Build-Preparation/ 0 Quote
monetschemist Posted 4 hours ago Author Posted 4 hours ago @igor I think what you're suggesting is that I build my own Ubuntu 24.04 image using the info on the page; am I correct? I could be talked into this but first I would have to build a 24.04 system - my three desktops and one laptop are all running 25.04, soon to move to 25.10. I could sacrifice the "old beater"... Reading these instructions, I believe that running 24.04 on an X86/64 machine I could build an ARM system; does that make sense? This comment worries me though: Quote This command will generate Ubuntu 24.04 Noble based Gnome desktop environment image for Intel based hardware (uefi-x86). Besides bare desktop, it will contain packages from browsers and desktop_tool sections and it will use unchanged kernel from current kernel branch. I'm trying to create a minimal IOT image; is that a separate pathway? Thanks in advance, and as always thanks for Armbian! 0 Quote
Werner Posted 4 hours ago Posted 4 hours ago 14 minutes ago, monetschemist said: I could be talked into this but first I would have to build a 24.04 system - my three desktops and one laptop are all running 25.04, soon to move to 25.10. I could sacrifice the "old beater"... You don't have to run on bare-metal. A proper VM will do too and is probably the better solution. 15 minutes ago, monetschemist said: Reading these instructions, I believe that running 24.04 on an X86/64 machine I could build an ARM system; does that make sense? Yes. Cross-compiling is used for everything that's not native. 15 minutes ago, monetschemist said: I'm trying to create a minimal IOT image; is that a separate pathway? You're aware that the command in the docs is just an example, right? 0 Quote
