Skip to content
View in the app
Armbian Community Forums
State of support for Raspberry Pi 5
Featured Replies
I recently got a Raspberry Pi 5 and installed Armbian on it. Most things work fine, aside for some weird output issues in htop and nano.
I noticed, when I go to the Raspberry Pi page on Armbian, the url refers to the Pi 4b, not the 5. I also found some articles online linking to a specific Pi 5b page (which I thought was weird since that model doesn't exist), but it just redirects to the 4b page.
Then, I went searching in the archive and found that, at some point, there were specific 5b images available (https://armbian.hosthatch.com/archive/rpi5b/archive).
Which of these should I use? Is the 4b image okay to use on a Pi 5? Or do you not support the Pi 5 at all?
Sorry if this has been answered before, it is kind of impossible to search this forum for similar questions with the super aggressive rate limiting.
When support for Raspberry Pis has been added there was no model 5 yet. With the intention to only support the flagship the board configuration was added as rpi4b.conf. Since then support was extended across all models from 3 and up. However renaming a board config file is an issue. I already had the idea to address that but gave up on it: https://github.com/armbian/build/pull/7881
tl;dr: rpi4b image will work on all models from 3 to 5. https://www.armbian.com/rpi4b/
Thank you Werner, I propose to put this statement red boxed on top of this rpi landing page. Too many rpi5 help seekers get puzzled, they should be informed, to find more stuff in forum discussions.
Greetings
@Werner, @Igor: Is the Raspberry Pi 500 supported by Armbian? It’s the successor to the RPi 400, for which support is mentioned. Internally, it looks similar to the RPi 5, except that it seems to lack wifi.
Edited by MMGen
You can check the .DTB files on the bootfs (FAT32) 1st partition. AFAIK the Pi500 uses a D0 variant of the SoC and that needs a separate/dedicated .dts (when downstream kernel what Armbian also uses).
When upstream kernel, make sure you have the very latest, as even in 6.18.0-rc? (or 6.19.0-rc? dont remember) I saw some fix w.r.t. naming w.r.t. that D0 variant. And also should pair with proper and/or new enough bootloader (the code in EEPROM). Still upstream kernel might lack a lot of functionality, but at least RP1 should work so RJ45 should work.
Rpi support for whatever of their devices is mainly on the level of RaspberryPi OS. We use their kernels sources as base, add some additional things and release timing is different - not much difference. If they added new device, it should just work.
If anyone wants to improve support or fix WiFi -> https://github.com/armbian/build/pulls
Hello! I have a follow-up question about installing Armbian on a Raspberry Pi 5, and hopefully this is a good place for it. Perhaps this belongs here instead:
I just installed the Armbian/Gnome version for Raspberry Pi "4b", as mentioned above, for my Raspberry Pi 5. The OS booted fine and is running. However, I'm trying to install some additional software (specifically this: https://github.com/sunfounder/pipower5/tree/main) and I'm getting errors related to installing the right version of `linux-headers`, the output of `uname`, and possibly the `bcm2711` vs. `bcm2712` CPU.
The original error was:
Error: E: Unable to locate package linux-headers-6.18.9-current-bcm2711
E: Couldn't find any package by glob 'linux-headers-6.18.9-current-bcm2711'
E: Couldn't find any package by regex 'linux-headers-6.18.9-current-bcm2711'
When I searched for the available packages, I found the following "closest" options:
linux-headers-current-bcm2711/noble 26.2.1 arm64 [upgradable from: 26.2.1]
  Armbian Linux current headers 6.18.10-current-bcm2711
linux-headers-current-bcm2712/noble 24.11.1 arm64
  Armbian Linux current headers 6.6.63-current-bcm2712
At this point, I realized that the installation scripts were pulling the kernel version from the output of `uname`:
denbro@rpi5b:~$ uname -r
denbro@rpi5b:~$ uname -a
Linux rpi5b 6.18.9-current-bcm2711 #1 SMP PREEMPT Mon Feb  9 10:54:02 UTC 2026 aarch64 aarch64 aarch64 GNU/Linux
My two main questions are:
 1. Why is the proper linux header not available? My understanding is that, in principle, `linux-headers-$(uname -r)` should always be available.
2. Should I be concerned that my linux kernel thinks it is using the bcm2711 CPU? That's the Pi 4 CPU, but my raspberry pi 5 has a bcm2712. Should I install the version of armbian for the Pi 500?
Two additional notes - 1. The Sunfounder software I mentioned above installed without issue on the same device running Raspberry Pi OS Trixie. 2. I originally tried to flash an SD card with Armbian using Raspberry Pi Imager, and it wouldn't boot; the device turned on, and printed a bunch of startup output, and then shut off. After confirming that the SD card worked, I switched to using Armbian Imager to flash the SD card and that led to my current state.
denbro@rpi5b:~$ neofetch
        #####           denbro@rpi5b
       ##O#O##          OS: Armbian 26.2.1 noble aarch64
       #######          Host: Raspberry Pi 5 Model B Rev 1.1
     ###########        Kernel: 6.18.9-current-bcm2711
    #############       Uptime: 1 hour, 25 mins
   ###############      Packages: 1200 (dpkg)
   ################     Shell: bash 5.2.21
  #################     Resolution: 1280x800
#####################   Terminal: /dev/pts/1
#####################   CPU: (4) @ 2.400GHz
  #################     Memory: 691MiB / 3983MiB
Let me know if there's any other information I can provide, and thanks in advance for any guidance!
I just checked at my ROCK5B running Armbian userspace:
# sudo apt update
# sudo apt list -a linux-headers-*current-bcm2711
linux-headers-current-bcm2711/trixie 26.2.1 arm64
linux-headers-current-bcm2711/trixie 25.11.2 arm64
linux-headers-current-bcm2711/trixie 25.8.2 arm64
linux-headers-current-bcm2711/trixie 25.8.1 arm64
linux-headers-current-bcm2711/trixie 25.5.1 arm64
linux-headers-current-bcm2711/trixie 25.2.3 arm64
linux-headers-current-bcm2711/trixie 25.2.2 arm64
linux-headers-current-bcm2711/trixie 24.11.1 arm64
linux-headers-current-bcm2711/trixie 24.8.2 arm64
linux-headers-current-bcm2711/trixie 24.5.1 arm64
linux-headers-current-bcm2711/trixie 24.2.1 arm64
So you can install them with:
# sudo apt install  linux-headers-*current-bcm2711
You will get the latest if you do not select explicit version 6.18.9, I got 6.18.10 as that seems to be the latest now.
Armbian also has edge and legacy, but for normal release all 64-bit Raspberry Pis is named 'current-bcm2711', which should be the equivalent of 'rpi-v8', which is the normal 4k pages downstream kernel in Raspberry Pi OS 64-bit. It might be you originally had the dedicated rpi5b installation, so you simply had not gotten the headers maybe.
Armbian has no 16k pages kernel, if you want that, you need to build yourself, but note that this comes with quite some of issues, many people are not aware and cannot fix issues due to that. See 2+ years of trouble w.r.t. that on RPL forums.
I do not use Ubuntu based Armbian, but Debian based, but should not matter for that kernel packages as those are Armbian on top of either distro.
Edited by eselarm
Thank you! I ended up getting this working.
For one, an update and reboot did get me the 6.18.10 kernel. Then, in the installation scripts for drivers, I just had to specify the package name for the headers explicitly, e.g. replacing:
apt-get install linux-headers-$(uname -r) -y
with
apt-get install linux-headers-current-bcm2711 -y
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
