Igor Posted February 3 Posted February 3 We are opening public testing for upcoming Armbian images. The goal is to verify that the right images are built and that basic functionality works before boards are moved to the main download pages. You don’t need to be a developer. Simple testing and short reports are enough. 1. Download testing images Testing images are available here: https://fi.mirror.armbian.de/incoming/igorpecovnik/ Pick the image matching your board and choose desktop if applicable. Once image is confirmed working, the board will be: Moved to the main download pages Added to Armbian Imager 2. Check that expected images exist Before testing, please verify that: Your board is listed The expected image variants exist If an image (variant) seems to be missing: Check the release target definitions: https://github.com/armbian/armbian.github.io/tree/main/release-targets If the image should exist, check build logs to see if it failed: https://github.com/armbian/os/actions/runs/21642728389 If you are unsure, report it anyway. 3. Flash and boot Flash the image using Armbian Imager: https://imager.armbian.com Boot the board and check whether it reaches: Login prompt (CLI images) Desktop (Desktop images) If the board does not boot, serial output or photos help. 4. What to test Please focus on basic functionality: Boot reliability and reboot Networking (Ethernet, Wi-Fi, Bluetooth) Display and GPU, if applicable Installer and first-boot experience Advanced features can wait. Stability comes first. 5. UEFI ARM64 images If your board might support UEFI on ARM64, please test those images on them. Working UEFI images allow us to reuse targets and reduce the number of generated images. Reference: https://github.com/armbian/armbian.github.io/blob/main/release-targets/reusable.yml 6. Community-supported boards Some boards are currently released as community-supported: https://github.com/armbian/community/releases We want to promote suitable boards to standard support which brings more image variants and much faster download. This requires: Confirmation that basic functionality works Send a PR to change status from .csc to .conf A community member willing to step up as maintainer If you rely on such a board and want it promoted, this is the time to help. 7. Reporting (here in this topic!) When reporting test results, please include: Board model Image name and variant What works and what does not Logs or serial output if available Even short reports like “Board X, image Y, boots and networking works” are useful. Thanks to everyone helping with testing. Early feedback directly improves the release quality! 2 Quote
Igor Posted February 4 Author Posted February 4 What was already tested: UEFI x86 KDE Neon, Gnome, Ubuntu minimal MusePI Pro Xfce Odroid M1 KDE Neon Odroid N2 Xfce https://paste.armbian.com/oqegebaqey Orangepi 5 Nanopi M4V2 Odroid M2 Radxa E54 Rock 5C Orangepi 3LTS Odroid C4 Bananapi Rock 3A Orangepi PC2 Nanopi K1plus Khadas Edge 2 Bananapi F3 Nanopi M6 / R6S Rock 2F / 2A / 3A Rpi (all) 0 Quote
Walter Zambotti Posted February 5 Posted February 5 (edited) I am currently on the community Odroid M2 CURRENT (6.18) (not edge 6.19) rolling release. Does this differ significantly enough from the images provided here: https://fi.mirror.armbian.de/incoming/igorpecovnik/ that I should download afresh and re-install before submitting any test results? Reporting! Where? (Every other section 1 - 7 had a necessary link) Much appreciated in advance. Willing to help or donate a M2 board if necessary. Edited February 5 by Walter Zambotti 0 Quote
Walter Zambotti Posted February 5 Posted February 5 (edited) I download Armbian_26.2.1_Odroidm2_noble_current_6.18.8_gnome_desktop.img.xz and burnt to a new SD card. Tested: Install OK Initial startup to desktop OK shutdown OK boot OK HDMI OK HDMI audio FAILED only dummy sound device Wifi via PCI M-key to E-key adapter Intel Wifi 6 AX200 OK USB-2 OK multiple devices including HUB USB-3 OK thumb drive USB-C FAILED nil buses detected or exposed I have managed to add a user device tree overlay to expose the USB-C port in non OTG mode and get some USB-C devices working. A USB-C thumb drive was consistent. But I only managed to connect my Pixel 8a successfully once at 480m speed. Edited February 5 by Walter Zambotti 0 Quote
Igor Posted February 5 Author Posted February 5 10 hours ago, Walter Zambotti said: Reporting! Where? Here, yes. Thank you! 10 hours ago, Walter Zambotti said: Does this differ significantly No, but we need to test images made for release. There is another last minute change https://github.com/armbian/build/commit/1890d7f6566a65202f73730b469d024c20f863b8 than can, in theory, make unbootable image. 8 hours ago, Walter Zambotti said: USB-C FAILED nil buses detected or exposed I have managed to add a user device tree overlay to expose the USB-C port in non OTG mode and get some USB-C devices working. A USB-C thumb drive was consistent. But I only managed to connect my Pixel 8a successfully once at 480m speed. OK. Bugs will be present and we won't be fixing them at this stage. Here - if basic things works - that image boots, have connectivity and video output ... its ready to ship. All other things can be fixed with an update. If / when they are fixed. 10 hours ago, Walter Zambotti said: or donate a M2 board if necessary. Armbian exists to save users time so you don't need to waste your private time dealing with bad software experience which would exists without our work. Sadly most people don't understand the value Armbian projecst make. Average Armbian developer have 100+ boards. We drown in issues they generate. All board manufacturer are happy to send us board for free and we decline many of their offers. I still have many unpacked boxes ... Without your help / engagement, we have no alternative but to keep images in automated untested (theoretically community maintained images) loop. Standard support costs us more then automated unchecked images. 0 Quote
JFL Posted February 5 Posted February 5 Device: Orange Pi 5 Plus Image: Armbian_26.2.1_Orangepi5-plus_noble_current_6.18.8_kde-neon_desktop.img.xz Installation on SD Card without issue. Ethernet works WiFi (RTW89_8852BE): Works Bluetooth: Available but did not test pairing with bluetooth device Chromium_v144: vpu hardware acceleration working USB-3.0 & USB-2.0 Ports working PCIE-NVMe: Accessible HDMI Display: working HDMI-Audio: working Headphone Jack-Audio: Working (After using alsamixer to increase "output1" volume") Out of the box, konsole (terminal-emulator) and dolphin (file manager) not pre-installed. 0 Quote
tparys Posted February 6 Posted February 6 (edited) I have two boards I can test. ODroid C4 and NanoPi M4v2. I'll pull down the C4 build and give it a go. I don't see a build for the M4v2? (EDIT - Doesn't look like the Github action failed) Edited February 6 by tparys 0 Quote
tparys Posted February 6 Posted February 6 Board: ODroid C4 Image: Armbian_26.2.1_Odroidc4_noble_current_6.18.8_xfce_desktop.img.xz Tested OK: - Installation to SD card - Boot to desktop, login - OpenGL / Panfrost - USB 2.0 - Ethernet Not tested: - Audio via HDMI (Though alsamixer reports there's stuff there) If anything, the serial console seems rather quiet. But attached ... minicom.cap 0 Quote
eselarm Posted February 6 Posted February 6 Armbian_26.2.1_Bananapi_trixie_current_6.12.68_minimal.img.xz (Bananapi M1) - only power, ethernet and serial console cable connected: 1st boot and user creation all fine - network up, WAN IP shown - then connecting a SATA SSD ('hotplug'), pops up in dmesg, so recognized OK 0 Quote
eselarm Posted February 6 Posted February 6 Armbian_26.2.1_Rock-3a_trixie_current_6.18.8_minimal.img.xz (ROCK3A) - system has NVME inserted and SATA M.2 E-key adaptor where HDD is connected to - SPI has Armbian legacy U-Boot, but that is skipped as SD-card with new image is inserted - further only power, ethernet and serial console cable connected: 1st boot and user creation all fine - network up, WAN IP shown - NVME is available (but OS is running from SD-card for the test) - SATA is not available as not supported mainline based kernel (and needs adding overlay manually when vendor kernel) - reboot does not reboot (but 'echo 1 > /proc/sys/kernel/sysrq ; echo b > /proc/sysrq-trigger' works) - also poweroff is only shutdown, no powerdown (and HDD keeps also spinning) 0 Quote
tparys Posted February 6 Posted February 6 (edited) Update on NanoPi M4v2 ... I pulled the most recent Armbian build, and manually ran the build for the M4v2, and it fails on kernel patch "general-gpio-driver-no-sleep". See pastebin at https://paste.armbian.com/puvorasuco for failed build. Checking upstream at https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git, it looks like branch 6.18.y already has the subject patch, and was pushed today. Since both the rockchip and rockchip64 families use mainline kernel, I just submitted a PR that kills that patch for both. See https://github.com/armbian/build/pull/9368. Edited February 6 by tparys 0 Quote
Igor Posted February 9 Author Posted February 9 On 2/6/2026 at 3:15 AM, tparys said: I don't see a build for the M4v2? Once board is tested, its moved to its final destination https://www.armbian.com/nanopi-m4-v2/ I tested it On 2/5/2026 at 6:34 PM, JFL said: Out of the box, konsole (terminal-emulator) and dolphin (file manager) not pre-installed. KDE was enabled "as is" / at last moment. I am not familiar with KDE much, so I don't know what to enable. I know that there could be issues between Neon and Ubuntu packages, so we kept this minimal. https://github.com/armbian/build/blob/main/config/desktop/noble/environments/kde-neon/config_base/packages Tested boards are moving to /dl Thank you for help. 0 Quote
robertoj Posted February 10 Posted February 10 (edited) I have an Orange Pi Zero 3, Opi z2w, Opi z LTS, and Banana Pi M2 Zero. If the OS image is not in your download page, does it mean you don't need help with these boards? I didn't have any problems with opiz3 Armbian.com or self built image ever (last time I tried was 2 months ago). The others: haven't used in 1 year. Edited February 10 by robertoj 0 Quote
SuperKali Posted February 10 Posted February 10 Boards that've tested: NanoPC T6 LTS: Kernel: Vendor (6.1) - Current (6.18) Variant: Desktop - Gnome What was tested: GPU works as expected WI-FI Card works as expected NVME, eMMC, SPI and SD Card works as expected Ethernets: 2x 2.5GbE works as expected HDMI both works as expected AUDIO: HDMI & via jack works as expected HDMI-IN video works as expected NanoPi M5: Kernel: Vendor (6.1) Variant: Desktop - Gnome What was tested: Image not boot, i have to investigate more, The previous image works without any problems. I will check soon and maybe migrate it to mainline uboot @Igor Can you do a double check if your board have the same issue? What was tested with the new build: GPU works as expected WI-FI Card works as expected NVME, SPI and SD Card works as expected UFS: I have to working on it, maybe with new mainline patches that will add the support on it Ethernets: 2x 1GbE works as expected HDMI both works as expected AUDIO: HDMI & via jack works as expected NanoPi R76S: Kernel: Vendor (6.1) Variant: Desktop - Gnome What was tested: GPU works as expected WI-FI Card works as expected eMMC and SD Card works as expected Ethernets: 2x 2.5GbE works as expected HDMI both works as expected AUDIO: HDMI works as expected 1 Quote
Igor Posted February 11 Author Posted February 11 16 hours ago, robertoj said: I have an Orange Pi Zero 3, Opi z2w, Opi z LTS, and Banana Pi M2 Zero. All are interesting. However, H3, H5 and H6 boards will receive additional fixing to DVFS during this week. After that, I will rebuild them, but those are all CSC, so there are additional tasks: 16 hours ago, robertoj said: If the OS image is not in your download page, does it mean you don't need help with these boards? We only generate and test boards with at least "standard support", where a known maintainer is around. If you (or someone else) step up as a maintainer: https://docs.armbian.com/User-Guide_Board-Support-Rules/ following by PR as such https://github.com/armbian/build/pull/8981 boards will automatically be added to automatically generated build lists https://github.armbian.com/release-targets/targets-release-standard-support.yaml and images can be (auto) generated: https://docs.armbian.com/Process_CI/#automation-for-developers-and-maintainers If you wanna cover those steps, report status at release periods, step up. 16 hours ago, robertoj said: I didn't have any problems with opiz3 In most cases, boards work but during those tests we usually always found something to fix. And boot loader compilation is checked this way - end user upgrades don't upgrade that by default so you could be running a board for years while freshly build images would have borked uboot ... 16 hours ago, robertoj said: The others: haven't used in 1 year. Perfect - new use case: Armbian QA 0 Quote
Torte Posted February 11 Posted February 11 Board: MKS-Klipad50 Images: * Armbian_26.2.1_Mksklipad50_noble_current_6.18.8_minimal.img.xz * Armbian_26.2.1_Mksklipad50_trixie_current_6.18.8_minimal.img.xz Passed tests: * gpg and sha checksum files * boot from emmc, leds, display, touch, usb, internal wifi * initial setup, uboot-console, full klipper/klipperscreen install, reboot Result: All expected images do exist, verify and work properly. 1 Quote
Walter Zambotti Posted April 2 Posted April 2 (edited) The last update installed a broken firmware package which prevents the system from rebooting and there is no heartbeat. This is the tail end of the upgrade: Preparing to unpack .../40-libnss-myhostname_255.4-1ubuntu8.14_arm64.deb ... Unpacking libnss-myhostname:arm64 (255.4-1ubuntu8.14) over (255.4-1ubuntu8.12) ... Errors were encountered while processing: /tmp/apt-dpkg-install-QRewUS/02-armbian-firmware_26.2.1_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1) Since the install is on the internal eMMc that pretty much prevents any recovery So just retested. Brand new download and reburnt image to eMMc. Booted completed install setup. Performed a sudo apt update and sudo apt upgrade and it immediately breaks and becomes non bootable. Edited April 2 by Walter Zambotti 0 Quote
Igor Posted May 24 Author Posted May 24 Armbian 26.05 Test images: https://fi.mirror.armbian.de/incoming/igorpecovnik/ Tested by me: - x86 and arm64 UEFI images - Odroid M1 - Radxa 5T https://paste.armbian.com/jizuhuweru - Inovato Quadra - RPi 400 - Musepipro - Orangepi 5 Plus (vendor BROKEN, wrong DT) - Odroid N2 https://paste.armbian.com/ipoyatajuj - Nanopi M4V2 https://paste.armbian.com/rewiqijizi - Nanopi R4S https://paste.armbian.com/sesemehohi - NanoPC T6 LTS / plus https://paste.armbian.com/cupifefofe - Nanopi R6S/C https://paste.armbian.com/igesulided .. 0 Quote
Werner Posted May 24 Posted May 24 2 hours ago, Igor said: - Orange 5 (FAILS) Tested orangepi5 current and vendor. works as expected 0 Quote
Torte Posted May 25 Posted May 25 Board: MKS-Klipad50 Images: * Armbian_26.5.1_Mksklipad50_resolute_current_6.18.33_minimal.img.xz * Armbian_26.5.1_Mksklipad50_trixie_current_6.18.33_minimal.img.xz Passed tests: * gpg and sha checksum files * boot from emmc, leds, display, touch, usb, internal wifi * initial setup, uboot-console, reboot Result: All expected images do exist, verify and work properly. Sidenote: The Klipper ecosystem does not yet run on Ubuntu-Resolute (Python-3.14 incompatibility), but that shouldn't be a stopper for the release. 1 Quote
Stephen Graf Posted May 25 Posted May 25 Board: Orangepione Testing results for the three available images. Should there be more images available? Armbian_26.5.1_Orangepione_resolute_current_6.18.33_minimal.img Tested working: Boot from SD card with uboot and then to a USB SSD. Reboot Connect via ssh iperf3 after installing iperf3 gpio after installing gpiod HDMI video HDMI audio after installing mpg123 Used usb keyboard/mouse to test HDMI. Note that resolute now uses gpiod for gpio instead of sys. Gpiod had to be installed whereas trixie minimal comes with gpiod installed. Armbian_2Armbian_26.5.1_Orangepione_trixie_current_6.18.33_minimal.img Tested working: Boot from SD card with uboot and then to a USB SSD. Reboot Connect via ssh iperf3 after installing iperf3 gpio HDMI video HDMI audio after installing mpg123 Used usb keyboard/mouse to test HDMI. Armbian_26.5.1_Orangepione_resolute_current_6.18.33_xfce_desktop.img Tested working: Boot from SD card with uboot and then to a USB SSD. Reboot On HDMI connecter screen with usb keyboard/mouse Using terminal emulatori tested perf3 and gpio HDMI audio with vlc media player. Not working: Ran chromium to get to Armbian download page but took over a minute for each page to load and then the system crashed. With only 512MB RAM this system is under powered for general purpose desktop use. ubuntu_resolute_minimal.txt debian_trixie_minimal.txt ubuntu_resolute_xfce.txt 1 Quote
Gabriel Becker Posted May 27 Posted May 27 NanoPi M5 test report for 26.5.1 vendor images Board: NanoPi M5 Boot media: SD card Kernel branch tested: vendor 6.1.115 Test scope: quick first-boot / first-login / desktop smoke test only. I mainly tested the vendor kernel images because my intended use case requires vendor kernel support, especially for NPU-related use later. 1. Image: `Armbian_26.5.1_Nanopi-m5_resolute_vendor_6.1.115_gnome_desktop.img.xz` Result: OK What worked: * Booted from SD card successfully. * Armbian initial configuration completed successfully. * After initial configuration, the GNOME desktop started normally. * I was able to enter the desktop and open a few basic applications. Notes: * I did not do a full hardware validation in this round. * I did not collect serial logs because the image reached the desktop successfully. 2. Image: `Armbian_26.5.1_Nanopi-m5_resolute_vendor_6.1.115_kde-plasma_desktop.img.xz` Result: FAILED What worked: * Booted from SD card successfully. * Armbian initial configuration started normally. What did not work: * The system got stuck at the Armbian first-login / initialization screen when it was supposed to start the desktop. * It did not proceed to a usable KDE Plasma desktop. Notes: * I only did a basic desktop startup test. * I have not collected serial logs yet, but I can retest and provide logs if needed. 3. Image: `Armbian_26.5.1_Nanopi-m5_trixie_vendor_6.1.115_minimal.img.xz` Result: CLI OK, XFCE installation failed What worked: * Booted from SD card successfully. * Armbian initial configuration completed successfully. * Login to the terminal worked normally. * Basic CLI usage appeared normal. What did not work: * I tried installing XFCE through `armbian-config`, using the XFCE mid option. * The desktop package dependencies appeared to download successfully. * After that, the screen switched to a black screen with a blinking terminal cursor in the top-left corner. * I waited for about 10 minutes, but it stayed stuck there and did not continue to a usable desktop. Notes: * The base minimal image itself seemed to work correctly from the terminal. * The issue happened during or after the XFCE installation/startup process via `armbian-config`. * I have not collected detailed logs yet, but I can retest and provide logs if needed. Summary: * `resolute_vendor_6.1.115_gnome_desktop`: boots from SD card and reaches GNOME desktop successfully. * `resolute_vendor_6.1.115_kde-plasma_desktop`: boots from SD card, but gets stuck at the Armbian first-login / initialization screen and does not reach KDE Plasma. * `trixie_vendor_6.1.115_minimal`: boots from SD card and CLI works, but installing XFCE mid through `armbian-config` gets stuck on a black screen with a blinking cursor. 1 Quote
Wolfpup Posted May 27 Posted May 27 Board: Orangepi3-lts Images: * Armbian_26.5.1_Orangepi3-lts_trixie_current_6.18.33_minimal.img.xz Passed tests: * SHA-256 passed All below testing done via wired and wireless console connection(headless) * initial setup passed * create main user passed * update/upgrade check as root passed * log in as created user pass * update/upgrade check as the created user passed Result: All tested images do exist, are verified, and work properly 1 Quote
Igor Posted May 31 Author Posted May 31 On 5/27/2026 at 5:11 AM, Gabriel Becker said: 1. Image: `Armbian_26.5.1_Nanopi-m5_resolute_vendor_6.1.115_gnome_desktop.img.xz` On 5/27/2026 at 5:11 AM, Gabriel Becker said: I did not do a full hardware validation in this round. Neither we do full hardware validation. That is only done in military grade software support and this is community open source development Thank you for your input. We don't have much time so in case we don't find a fix in <1h, broken images will be removed. Which is already a good added value. It is interesting that Gnome works and KDE don't. I did several tests on x86 platform and KDE always worked ... But I think we need to be realistic and happy if one desktop works solid. 0 Quote
schwar3kat Posted May 31 Posted May 31 radxa-e52c - tested okay please move to dl: Armbian_26.5.1_Radxa-e52c_resolute_current_6.18.33_minimal Boot from SD card TTY Terminal 1500000 baud Connect via ssh Lan ethernet iperf3 Wan ethernet iperf3 USB Reboot Shutdown Armbian_26.5.1_Radxa-e52c_resolute_vendor_6.1.115_minimal Boot from SD card TTY Terminal 1500000 baud Connect via ssh Lan ethernet iperf3 Wan ethernet iperf3 USB Reboot Shutdown Armbian_26.5.1_Radxa-e52c_trixie_vendor_6.1.115_minimal Boot from SD card TTY Terminal 1500000 baud Connect via ssh Lan ethernet iperf3 Wan ethernet iperf3 USB Reboot Shutdown 0 Quote
schwar3kat Posted May 31 Posted May 31 Radxa-e54c - tested okay please move to dl: Armbian_26.5.1_Radxa-e54c_resolute_vendor_6.1.115_gnome_desktop Boot from SD card TTY Terminal 1500000 baud Connect via ssh Lan1 ethernet iperf3 Lan2 ethernet iperf3 Lan3 ethernet iperf3 Wan ethernet iperf3 USB Reboot Shutdown HDMI video HDMI audio Armbian_26.5.1_Radxa-e54c_resolute_vendor_6.1.115_minimal Boot from SD card TTY Terminal 1500000 baud Connect via ssh Lan1 ethernet iperf3 Lan2 ethernet iperf3 Lan3 ethernet iperf3 Wan ethernet iperf3 (needs manual config) USB Reboot Shutdown Armbian_26.5.1_Radxa-e54c_trixie_vendor_6.1.115_minimal Boot from SD card TTY Terminal 1500000 baud Connect via ssh Lan1 ethernet iperf3 Lan2 ethernet iperf3 Lan3 ethernet iperf3 Wan ethernet iperf3 (needs manual config) USB Reboot Shutdown 0 Quote
schwar3kat Posted June 1 Posted June 1 Rock-5c vendor builds are good. Current is good except for audio: Armbian_26.5.1_Rock-5c_resolute_vendor_6.1.115_gnome_desktop Boot from SD card - okay Connect via ssh - okay Ethernet iperf3 - okay USB2 ports - okay USB3 ports - okay Reboot - okay Shutdown - okay HDMI video - okay HDMI audio - okay Headphone jack audio - okay Armbian_26.5.1_Rock-5c_resolute_vendor_6.1.115_minimal Boot from SD card - okay Connect via ssh - okay Ethernet iperf3 - okay USB2 ports - okay USB3 ports - okay Reboot - okay Shutdown - okay HDMI video - okay Armbian_26.5.1_Rock-5c_resolute_current_6.18.33_gnome_desktop Boot from SD card - okay Connect via ssh - okay Ethernet iperf3 - okay USB2 ports - okay USB3 ports - okay Reboot - okay Shutdown - okay HDMI video - okay HDMI audio - FAILED Headphone jack audio - FAILED Bluetooth audio - FAILED 1 Quote
Igor Posted June 3 Author Posted June 3 Tested: - Odroid C4 / HC4 - Tinkerboard - Odroid XU4 - Rockpi E 0 Quote
Scritch Posted 2 hours ago Posted 2 hours ago I hope this is the right place for such a finding. If not, please forgive me. My Orange PI Zero 3 got upgraded to Armbian 26.05 yesterday. Usbip modules are gone: Using armbian 26.05: ls -l /usr/lib/modules/$(uname -r)/kernel/drivers/usb/usbip ls: cannot access '/usr/lib/modules/6.18.33-current-sunxi64/kernel/drivers/usb/usbip': No such file or directory After downgrading using armbian config to linux-image-current-sunxi64=25.11.2 (v6.12.58) Note: Armbian 26.02 is not available via armbian-config. ls -ld /usr/lib/modules/$(uname -r)/kernel/drivers/usb/usbip drwxr-xr-x 2 root root 4096 Jun 14 00:11 /usr/lib/modules/6.12.58-current-sunxi64/kernel/drivers/usb/usbip As soon as it becomes available for the officially supported odroidc2, I will test, too. 0 Quote
