martinayotte Posted October 24, 2019 Share Posted October 24, 2019 8 minutes ago, balbes150 said: Have you tried to write to eMMC bootloader from SD card (u-boot.bin.sd.bin)? I've just did it, but same issue ... 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted October 27, 2019 Share Posted October 27, 2019 Can you check the installation in eMMC on K2 ? After recording the Armbian image for the TV box (add u-boot to SD card and DTB settings), you need to download and copy these two files to the /root directory on the SD card. After starting the system from SD card to K2, you need to run the script s905_install.sh from the user "root". The script should install the system on eMMC and create a new u-boot (special version for eMMC). I have on S905 this works (I installed in eMMC the latest armbian image with kernel 5.3.0). Before starting the system SD card and run install on K2, to avoid side effects, you need to completely clean the eMMC. If the u-boot installation does not work from the script, you can re-write the file (uboot_s905_emmc_1m. img) to eMMC after the script runs s905_install.sh two commands dd if=uboot_s905_emmc_1m.img of=/dev/mmcblkX conv=fsync bs=1 count=442 dd if=uboot_s905_emmc_1m.img of=/dev/mmcblkX conv=fsync bs=512 skip=1 seek=1 https://yadi.sk/d/3RhEo60liJuTDw For a quick check, you can immediately write uboot_s905_emmc_1m.img to eMMC with a single DD command and check the overall launch of the u-boot itself with eMMC. After writing u-boot to eMMC, there should be a partition table (two partitions) on eMMC. 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted October 27, 2019 Share Posted October 27, 2019 2 hours ago, balbes150 said: For a quick check, you can immediately write uboot_s905_emmc_1m.img to eMMC That is what I will do, because I've already working Armbian installed on the eMMC into a single partition, so I don't wish to erase it for now. EDIT: It is a good step in the good direction, this U-Boot is now loaded from eMMC (wihout SD inserted) ! However, this U-Boot is far from the one from Armbian, it doesn't provide "ls", I had to do "ext4ls" instead, but this is not a big deal... But it is also a bit buggy with sub-directories, since doing "ext4ls mmc 0 /boot" don't show any files, while doing "ext4ls mmc 0 /bin" is showing the files located in /boot ... reset resetting ... GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; no sdio debug board detected TE: 41139 BL2 Built : 12:06:06, Jun 13 2016. gxb g176ecdb - laiyin.mo@droid12-sz set vcck to 1100 mv set vddee to 1000 mv Board ID = 8 CPU clk: 1536MHz DDR chl: Rank0+1 same @ 792MHz DDR0: 2048MB(auto)-2T-11 DataBus test pass! AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c000, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010000, des: 0x01000000, size: 0x0000d460 Sending bl30......................................................OK. Run bl30... Load bl31 from eMMC, src: 0x00020000, des: 0x1010[000, size: 0x00013140 Image: gxb_v1.1.3134-b387442 2016-06-16 14:48:44 yun.cai@droid06] OPS=0x13 ed 29 ad 5 1b 99 fa c9 82 86 5d Load bl33 from eMMC, src: 0x00034000, des: 0x01000000, size: 0x0006af00 4b [0.133626 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):c813a61 NOTICE: BL3-1: Built : 14:47:05, Jun 16 2016 INFO: BL3-1: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader ERROR: Error initializing runtime service opteed_fast INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01-00018-g6c5824b-dirty (Oct 12 2017 - 18:36:33) DRAM: 2 GiB Relocation Offset is: 76f3b000 register usb cfg[1][0] = 0000000077f96ac0 register usb cfg[0][1] = 0000000077f96ae0 register usb cfg[2][0] = 0000000077f96b00 vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters vpu: clk_level = 7 vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: SDIO Port C: 0, SDIO Port B: 1 emmc/sd response timeout, cmd8, status=0x3ff2800 emmc/sd response timeout, cmd55, status=0x3ff2800 [mmc_startup] mmc refix success [mmc_init] mmc init success In: serial Out: serial Err: serial reboot_mode=watchdog_reboot hpd_state=0 cvbs performance type = 4, table = 0 Net: Meson_Ethernet ** File not found nanopi-k2.dtb ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC [OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [OSD]check dts: FDT_ERR_BADMAGIC, load default fb_addr parameters [OSD]fb_addr for logo: 0x3d800000 [CANVAS]addr=0x3d800000 width=5760, height=2160 ** File not found logo.bmp ** There is no valid bmp file at the given address Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 Device: SDIO Port C Manufacturer ID: 15 OEM: 100 Name: AJTD4 Tran Speed: 52000000 Rd Block Len: 512 MMC version 4.0 High Capacity: Yes Capacity: 14.6 GiB mmc clock: 40000000 Bus Width: 8-bit DDR ** Unrecognized filesystem type ** (Re)start USB... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c0000020 USB (1) use clock source: XTAL input, div: 1 USB (1) base addr: 0xc9100000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found reading s905_autoscript ** Unable to read file s905_autoscript ** ** Bad device usb 1 ** ** Bad device usb 2 ** ** Bad device usb 3 ** emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 emmc/sd response timeout, cmd1, status=0x1ff2800 ** Bad device mmc 1 ** ## Error: "storeboot" not defined nanopi-k2# nanopi-k2#printenv baudrate=115200 bloader=ext4load mmc 0:1 bootcmd=run start_autoscript; run storeboot bootdelay=3 consoleargs=console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 cvbs_drv=0 cvbsmode=576cvbs display_bpp=24 display_color_bg=0 display_color_fg=0xffff display_color_index=24 display_height=576 display_layer=osd0 display_width=720 droidargs=androidboot.console=ttyS0 androidboot.hardware=nanopi-k2 dtb_mem_addr=0x1000000 dtb_name=nanopi-k2.dtb ethact=Meson_Ethernet ethaddr=00:16:0F:A0:10:22 fb_addr=0x3d800000 fb_height=1080 fb_width=1920 fdt_high=0x20000000 firstboot=1 gatewayip=192.168.102.1 hdmimode=1080p60hz hostname=nanopi-k2-u1 init_bootargs=setenv bootargs ${consoleargs} ${droidargs} hdmimode=${hdmimode} hdmitx=cecf logo=osd1,loaded,${fb_addr},${hdmimode} initrd=${initrd_start},${initrd_size} init_display=osd open; osd clear; ${bloader} 0x20000000 logo.bmp; bmp display 0x20000000 initrd_high=0x40000000 initrd_name=ramdisk.img initrd_size=0x200000 initrd_start=0x39000000 ipaddr=192.168.102.39 loadaddr=0x1080000 loadbootimg=${bloader} 0x20000000 boot.img loaddtb=${bloader} ${dtb_mem_addr} ${dtb_name}; fdt addr ${dtb_mem_addr} loadinitrd=${bloader} ${initrd_start} ${initrd_name}; setenv initrd_size 0x${filesize} loadkernel=${bloader} ${loadaddr} Image netmask=255.255.255.0 outputmode=576cvbs preboot=run loaddtb; run init_display reboot_mode=watchdog_reboot serial#=fe2017a905b20003 serverip=192.168.102.30 start_autoscript=if mmcinfo; then run start_mmc_autoscript; fi; if usb start; then run start_usb_autoscript; fi; run start_emmc_autoscript start_emmc_autoscript=if fatload mmc 1 1020000 emmc_autoscript; then autoscr 1020000; fi; start_mmc_autoscript=if fatload mmc 0 1020000 s905_autoscript; then autoscr 1020000; fi; start_usb_autoscript=for usbdev in 0 1 2 3; do if fatload usb ${usbdev} 1020000 s905_autoscript; then autoscr 1020000; fi; done stderr=serial stdin=serial stdout=serial upgrade_step=2 Environment size: 2051/65532 bytes nanopi-k2#ext4ls mmc 0 <DIR> 4096 . <DIR> 4096 .. <DIR> 4096 bin <DIR> 0 boot <DIR> 4096 dev <DIR> 0 etc <DIR> 4096 home <DIR> 0 lib <DIR> 4096 lost+found <DIR> 4096 media <DIR> 4096 mnt <DIR> 0 opt <DIR> 0 proc <DIR> 4096 root <DIR> 0 run <DIR> 4096 sbin <DIR> 4096 selinux <DIR> 4096 srv <DIR> 0 sys <DIR> 4096 tmp <DIR> 0 usr <DIR> 0 var nanopi-k2# nanopi-k2#ext4ls mmc 0 /boot nanopi-k2#ext4ls mmc 0 /bin Unknown command 'ext4ls' - try 'help' nanopi-k2#ext4ls mmc 0 /bin <DIR> 0 . <DIR> 4096 .. <SYM> 0 Image <SYM> 0 dtb <SYM> 0 uInitrd <SYM> 0 zImage 0 .next 0 System.map-5.3.3-meson64 0 armbian_first_run.txt.template 0 boot-desktop.png 0 boot.bmp 0 boot.cmd 0 boot.scr 0 config-5.3.3-meson64 0 initrd.img-5.3.3-meson64 0 uImage 0 uInitrd-5.3.3-meson64 0 vmlinuz-5.3.3-meson64 0 armbianEnv.txt~ 0 armbianEnv.txt 0 armbianEnv.txt-ORIG <SYM> 0 dtb.old <DIR> 0 dtb-5.3.7-meson64 nanopi-k2# I will now try to see if placing files in root will help, and try to adjust boot.scr to use ext4load instead of load like in Armbian U-Boot ... EDIT2: Strangely, the bug about sub-directory with boot/bin confusing doesn't exist if done one the SDCard inserted : ext4ls mmc 1 /boot <DIR> 4096 . <DIR> 4096 .. <SYM> 21 Image <SYM> 17 dtb <SYM> 21 uInitrd <SYM> 21 zImage <DIR> 4096 dtb-5.3.3-meson64 38518 boot.bmp 0 .next 1536 armbian_first_run.txt.template 3414756 System.map-5.3.3-meson64 269 armbianEnv.txt 171264 config-5.3.3-meson64 4882 boot-desktop.png 2993 boot.cmd 3065 boot.scr 16296008 uImage 4737692 initrd.img-5.3.3-meson64 254 armbianEnv.txt~ 4737756 uInitrd-5.3.3-meson64 16295944 vmlinuz-5.3.3-meson64 203 armbianEnv.txt-ORIG nanopi-k2#ext4ls mmc 0 /boot nanopi-k2#ext4ls mmc 0 /bin <DIR> 0 . <DIR> 4096 .. <SYM> 0 Image <SYM> 0 dtb <SYM> 0 uInitrd <SYM> 0 zImage 0 .next 0 System.map-5.3.3-meson64 0 armbian_first_run.txt.template 0 boot-desktop.png 0 boot.bmp 0 boot.cmd 0 boot.scr 0 config-5.3.3-meson64 0 initrd.img-5.3.3-meson64 0 uImage 0 uInitrd-5.3.3-meson64 0 vmlinuz-5.3.3-meson64 0 armbianEnv.txt~ 0 armbianEnv.txt 0 armbianEnv.txt-ORIG <SYM> 0 dtb.old <DIR> 0 dtb-5.3.7-meson64 EDIT3: filesystem functions are really buggy ... Now, from SDCard, I can do "ext4ls mmc 1 /boot/dtb/amlogic" but can't do "ext4ls mmc 1 /boot/dtb/amlogic/meson-gxbb-nanopi-k2.dtb", so I presume I won't be able to do "ext4load" ... nanopi-k2#ext4ls mmc 1 /boot/dtb/amlogic <DIR> 4096 . <DIR> 4096 .. 63276 meson-g12a-sei510.dtb 48318 meson-axg-s400.dtb 62359 meson-g12a-x96-max.dtb 60202 meson-g12a-u200.dtb 35233 meson-gxbb-nexbox-a95x.dtb 62457 meson-g12b-odroid-n2.dtb 37443 meson-gxbb-nanopi-k2.dtb 34637 meson-gxbb-vega-s95-meta.dtb 36104 meson-gxbb-odroidc2.dtb 36662 meson-gxbb-p200.dtb 35613 meson-gxbb-p201.dtb 34641 meson-gxbb-vega-s95-telos.dtb 34637 meson-gxbb-vega-s95-pro.dtb 35699 meson-gxbb-wetek-play2.dtb 35302 meson-gxbb-wetek-hub.dtb 34876 meson-gxl-s905x-hwacom-amazetv.dtb 35895 meson-gxl-s805x-libretech-ac.dtb 35482 meson-gxl-s805x-p241.dtb 37343 meson-gxl-s905d-p230.dtb 36313 meson-gxl-s905d-p231.dtb 37485 meson-gxl-s905d-phicomm-n1.dtb 36179 meson-gxl-s905w-p281.dtb 36151 meson-gxl-s905w-tx3-mini.dtb <DIR> 4096 overlay 38279 meson-gxl-s905x-khadas-vim.dtb 37146 meson-gxl-s905x-libretech-cc.dtb 35905 meson-gxl-s905x-nexbox-a95x.dtb 36322 meson-gxl-s905x-p212.dtb 40066 meson-gxm-khadas-vim2.dtb 36581 meson-gxm-nexbox-a1.dtb 38350 meson-gxm-q200.dtb 37515 meson-gxm-q201.dtb 36396 meson-gxm-rbox-pro.dtb 37578 meson-gxm-vega-s96.dtb nanopi-k2#ext4ls mmc 1 /boot/dtb/amlogic/meson-gxbb-nanopi-k2.dtb ** Can not find directory. ** 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted October 28, 2019 Share Posted October 28, 2019 11 hours ago, martinayotte said: filesystem functions are really buggy ... Now, from SDCard, I can do "ext4ls mmc 1 /boot/dtb/amlogic" but can't do "ext4ls mmc 1 /boot/dtb/amlogic/meson-gxbb-nanopi-k2.dtb", so I presume I won't be able to do "ext4load" ... I check the work, only together with the script s905_install. After using it, the system normally starts automatically from eMMC. Important. The eMMC device number changes when the SD card is connected. With SD card, the eMMC number will be mmcblk1. Without SD card number mmcblk0. This should be considered when creating a startup script from eMMC. Also in this u-boot "built" MBR partition table with two partitions, the first FAT and the second EXT4. 0 Quote Link to comment Share on other sites More sharing options...
Muadiv Posted April 2, 2021 Share Posted April 2, 2021 (edited) Hi everyone, I'm kind new on linux, but I have some idea. I was running before another linux distribution and ethernet was working. Today I changed the SD because last one was not working fine, and I decided to installed the new armbian images. Wifi worked perfect, but I can't get eth0 working. When I try to activate it from ntmui, is showing this: Some info here: nanopik2:~:% sudo ethtool eth0 Settings for eth0: Cannot get device settings: Device or resource busy Cannot get wake-on-lan settings: Device or resource busy Cannot get message level: Device or resource busy Cannot get link status: Device or resource busy No data available nanopik2:~:% dmesg | grep eth [ 0.000000] psci: probing for conduit method from DT. [ 2.372867] meson8b-dwmac c9410000.ethernet: IRQ eth_wake_irq not found [ 2.372879] meson8b-dwmac c9410000.ethernet: IRQ eth_lpi not found [ 2.372999] meson8b-dwmac c9410000.ethernet: PTP uses main clock [ 2.373799] meson8b-dwmac c9410000.ethernet: User ID: 0x11, Synopsys ID: 0x37 [ 2.373814] meson8b-dwmac c9410000.ethernet: DWMAC1000 [ 2.373819] meson8b-dwmac c9410000.ethernet: DMA HW capability register supported [ 2.373823] meson8b-dwmac c9410000.ethernet: RX Checksum Offload Engine supported [ 2.373828] meson8b-dwmac c9410000.ethernet: COE Type 2 [ 2.373832] meson8b-dwmac c9410000.ethernet: TX Checksum insertion supported [ 2.373835] meson8b-dwmac c9410000.ethernet: Wake-Up On Lan supported [ 2.373924] meson8b-dwmac c9410000.ethernet: Normal descriptors [ 2.373928] meson8b-dwmac c9410000.ethernet: Ring mode enabled [ 2.373933] meson8b-dwmac c9410000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 2.373943] meson8b-dwmac c9410000.ethernet: device MAC address ca:6e:40:ff:62:6b [ 14.681861] meson8b-dwmac c9410000.ethernet eth0: no phy at addr -1 [ 14.682506] meson8b-dwmac c9410000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) nanopik2:~:% cat /proc/device-tree/model FriendlyARM NanoPi K2% nanopik2:~:% uname -a Linux nanopik2 5.10.21-meson64 #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux Thanks in advance. Edited April 3, 2021 by Muadiv 0 Quote Link to comment Share on other sites More sharing options...
RussianNeuroMancer Posted April 15, 2021 Share Posted April 15, 2021 On 4/3/2021 at 5:49 AM, Muadiv said: Thanks in advance. Try to detach and then attach Ethernet cable, and see if it helps. In my case - it does. 0 Quote Link to comment Share on other sites More sharing options...
Muadiv. Posted April 16, 2022 Share Posted April 16, 2022 On 4/15/2021 at 4:27 PM, RussianNeuroMancer said: Try to detach and then attach Ethernet cable, and see if it helps. In my case - it does. Tried hundred times... didn't work ... any amother idea ? 0 Quote Link to comment Share on other sites More sharing options...
RussianNeuroMancer Posted June 7, 2022 Share Posted June 7, 2022 16.04.2022 в 02:22, Muadiv. сказал: Tried hundred times... didn't work ... any amother idea ? Yes, another workaround is in this post. Here is working link to the package for K2. After installing the package you will need to install these old uboot via armbian-config. 0 Quote Link to comment Share on other sites More sharing options...
MOEX Posted August 29, 2023 Share Posted August 29, 2023 I tried the latest version of the firmware and Armbian_21.02.3_Nanopik2-s905_buster_current_5.10.21.img.xz None of them enable K2 to run eth0 to connect to the local network. I'm in the same situation as Muadiv above. Is there any solutions? Much appreciated! 0 Quote Link to comment Share on other sites More sharing options...
Julza Posted May 7 Share Posted May 7 Hi I know this is an old thread. A few years ago i bought two NanoPi K2's I used these as kodi boxes for a while, but eventually stopped using them when i got an nvidia shield and other android tv boxes Recently i have wanted to put these back to use, specifically to run Armbian and do a source install of Retropie (which works suprisingly well) with only two caveats 1: The Video resolution seems to be locked to lower resolutions (1024x768 and i think 800x600) 2: The onboard HDMI Audio does not seem to work these issues are both apparent with the latest "automated" builds available on the Armbian website I was just wondering which build was the last "non automated" build where HDMI Audio and Video resolutions (say, 1920x1080) are supported Alternatively, are there any patches that can be applied to make the HDMI Audio work or to hard code a custom resolution? I seem to be finding conflicting info online, and this board does not appear to be very popular which is a bit sad, because it actually seems like a well featured board. If only the manufacturer supported it better. 0 Quote Link to comment Share on other sites More sharing options...
