mrstone78 Posted August 22, 2019 Posted August 22, 2019 On 8/20/2019 at 2:32 PM, martinayotte said: Do you have "CONFIG_SUN50I_ERRATUM_UNKNOWN1=y" in /boot/config-4.19.63-sunxi64 ? I followed all the threads and checked all the config settings, I have this and all the others you usually ask enabled. and for the record, it happened again this morning. 1
martinayotte Posted August 22, 2019 Posted August 22, 2019 3 hours ago, mrstone78 said: I have this and all the others you usually ask enabled. Strange ... I've a Pine64, OPiWin and OlinuxinoA64 and none of them got the issue since months ... Maybe @smaeul can give more details since he is the author of the latest patch ?
Don Park Posted August 23, 2019 Posted August 23, 2019 I got tired of trying to cleanup after the Pine A64/Armbian clock skips and shut off the board for a few months. Then I came across this linux 5.3 patch for the Allwinner clock https://github.com/torvalds/linux/commit/c950ca8c35eeb32224a63adc47e12f9e226da241 The stock 5.3-rc5 kernel built on the pine64 and installed without much trouble. Its been a day and a half under fairly heavy load (a heavy load would increase the frequency of clock skips) with no skips yet so I am cautiously optimistic. the new clock fix kernel flag is: (already set in the tarball below) CONFIG_SUN50I_ERRATUM_UNKNOWN1=y If someone wants to try this on their own board without having to complie the kernel, I tar'ed up the kernel, modules, and /boot bits. https://donp.org/linux-5.3-rc5-pinea64.tar.xz By moving the /boot symlinks, the board should boot into this kernel: lrwxrwxrwx 1 root root 11 Aug 21 2116 dtb -> dtb-5.3-rc5 lrwxrwxrwx 1 root root 17 Oct 13 2114 Image -> vmlinuz-5.3.0-rc5 lrwxrwxrwx 1 root root 17 Oct 13 2114 uInitrd -> uInitrd-5.3.0-rc5 haha you can see the timestamps of the symlinks happened after a clock skip. Don
martinayotte Posted August 24, 2019 Posted August 24, 2019 21 hours ago, Don Park said: Then I came across this linux 5.3 patch for the Allwinner clock As you can see in this commit, it was originally introduced during v5.1-rc1 in January. It is exactly the same patch that Armbian is using since months ...
Don Park Posted August 24, 2019 Posted August 24, 2019 Ah perhaps I read the bottom row wrong, where it was saying 5.3-rc5 that was the most recent tag and not the tag that contains the patch. For someone who has a pine A64 today, what armbian build should be used? The ones on https://www.armbian.com/pine64/ report kernel 4.19.
mrstone78 Posted September 1, 2019 Posted September 1, 2019 On 8/22/2019 at 2:08 PM, martinayotte said: I've a Pine64, OPiWin and OlinuxinoA64 and none of them got the issue since months ... What can I say, lucky you FTR, it just happened again. In the meantime I had updated the kernel to 5.3.0-rc3-sunxi64
OlegM Posted September 5, 2019 Posted September 5, 2019 Hi guys! Facing the same issue :) $ date Thu Oct 25 18:17:22 UTC 2114 $ uname -a Linux pine64so-node6 4.19.57-sunxi64 #5.90 SMP Fri Jul 5 18:38:49 CEST 2019 aarch64 aarch64 aarch64 GNU/Linux $ grep CONFIG_SUN50I_ERRATUM_UNKNOWN1 /boot/config-4.19.57-sunxi64 CONFIG_SUN50I_ERRATUM_UNKNOWN1=y
ams.br Posted September 5, 2019 Posted September 5, 2019 I switched to 5.3.0-rc3, but not work. After +/- 8 days. Welcome to Debian Stretch with Armbian Linux 5.3.0-rc3-sunxi64 System load: 0.82 0.73 0.70 Up time: 24855 days # date Sat Dec 16 19:19:42 -03 2209
markolonius Posted September 6, 2019 Posted September 6, 2019 12 hours ago, ams.br said: I switched to 5.3.0-rc3, but not work. After +/- 8 days. Welcome to Debian Stretch with Armbian Linux 5.3.0-rc3-sunxi64 System load: 0.82 0.73 0.70 Up time: 24855 days # date Sat Dec 16 19:19:42 -03 2209 This was same for me.
ams.br Posted September 12, 2019 Posted September 12, 2019 I compiled the kernel (branch next 4.19.y) applying a patch based in https://github.com/arctype-co/linux/commit/5fcb4e57eeaa4d670ef4acf5818c6fe16aa0d3d0 Strikes me as a more stable workaround, but I'm still evaluating. Patch: --- a/drivers/clocksource/arm_arch_timer.c +++ b/drivers/clocksource/arm_arch_timer.c @@ -328,16 +328,17 @@ * number of CPU cycles in 3 consecutive 24 MHz counter periods. */ #define __sun50i_a64_read_reg(reg) ({ \ - u64 _val; \ - int _retries = 150; \ + u64 _old, _new; \ + int _retries = 200; \ \ do { \ - _val = read_sysreg(reg); \ + _old = read_sysreg(reg); \ + _new = read_sysreg(reg); \ _retries--; \ - } while (((_val + 1) & GENMASK(9, 0)) <= 1 && _retries); \ + } while (unlikely(_old != _new) && _retries); \ \ WARN_ON_ONCE(!_retries); \ - _val; \ + _new; \ }) static u64 notrace sun50i_a64_read_cntpct_el0(void)
ams.br Posted September 25, 2019 Posted September 25, 2019 On 9/11/2019 at 9:15 PM, ams.br said: I compiled the kernel (branch next 4.19.y) applying a patch based in https://github.com/arctype-co/linux/commit/5fcb4e57eeaa4d670ef4acf5818c6fe16aa0d3d0 Strikes me as a more stable workaround, but I'm still evaluating. Patch: --- a/drivers/clocksource/arm_arch_timer.c +++ b/drivers/clocksource/arm_arch_timer.c @@ -328,16 +328,17 @@ * number of CPU cycles in 3 consecutive 24 MHz counter periods. */ #define __sun50i_a64_read_reg(reg) ({ \ - u64 _val; \ - int _retries = 150; \ + u64 _old, _new; \ + int _retries = 200; \ \ do { \ - _val = read_sysreg(reg); \ + _old = read_sysreg(reg); \ + _new = read_sysreg(reg); \ _retries--; \ - } while (((_val + 1) & GENMASK(9, 0)) <= 1 && _retries); \ + } while (unlikely(_old != _new) && _retries); \ \ WARN_ON_ONCE(!_retries); \ - _val; \ + _new; \ }) static u64 notrace sun50i_a64_read_cntpct_el0(void) After 14 days, the date remains stable. The patch apparently worked
langerma Posted September 26, 2019 Posted September 26, 2019 On 9/6/2019 at 1:57 PM, markolonius said: This was same for me. same here. nearly all my sopines in the clusterboard face this issue.
langerma Posted September 26, 2019 Posted September 26, 2019 19 hours ago, ams.br said: After 14 days, the date remains stable. The patch apparently worked how can i compile this in my kernel? or are there any packages?
linda Posted September 26, 2019 Author Posted September 26, 2019 2 hours ago, langerma said: how can i compile this in my kernel? or are there any packages? I would also be very happy if I could integrate the patch into my current image!
ams.br Posted September 27, 2019 Posted September 27, 2019 16 hours ago, langerma said: how can i compile this in my kernel? or are there any packages? at a Linux OS (Armbian recommend Ubuntu), download the latest source of armbian build git clone https://github.com/armbian/build.git copy patch file arm_arch_timer.patch to folder userpatches/kernel/sunxi-next (more details in documentation). Run the compile script ./compile.sh choose "U-boot and kernel packages", apply. choose "Do not change the kernel configuration" for a standard kernel, or "Show a kernel configuration menu before compilation" for customize your kernel (recommended for advanced users), apply choose your board choose "next" apply, and now just have a coffee and wait. After compilation deb packages generated at folder output/debs, copy the deb packages to you Armbian and run dpkg -i *.deb more details at https://docs.armbian.com/Developer-Guide_Build-Preparation/ arm_arch_timer.patch 1
markolonius Posted October 5, 2019 Posted October 5, 2019 On 10/4/2019 at 4:25 AM, langerma said: @ams.br seems like your patch works! I was able to successfully build with the patch this time as well. Been running solid since! Can we get this patch submitted into official builds?
Kalin Posted October 5, 2019 Posted October 5, 2019 On 10/4/2019 at 11:25 AM, langerma said: @ams.br seems like your patch works! 1 hour ago, markolonius said: I was able to successfully build with the patch this time as well. Been running solid since! Can we get this patch submitted into official builds? Same here, running stable for 8 days. Before the patch, usually 1 or 2 days.
langerma Posted October 16, 2019 Posted October 16, 2019 On 10/5/2019 at 8:33 PM, Kalin said: Same here, running stable for 8 days. Before the patch, usually 1 or 2 days. completely stable since 17 days!
ykanello Posted November 5, 2019 Posted November 5, 2019 Thank you ams.br for the solution. I run 7 pine64so on the clusterboard and two of the SoCs had this problem. I would get the error almost immediately under heavy cpu usage. Now my test SoC is running 20h straight at 99% cpu usage (Seti@home) and the date is still in 2019. Cool stuff. thank you once again 1
eminguez Posted November 5, 2019 Posted November 5, 2019 Is this patch going to be added in future releases? Thanks!
Igor Posted November 5, 2019 Posted November 5, 2019 2 hours ago, eminguez said: Is this patch going to be added in future releases? Thanks! Perhaps its already there? We are moving to 5.3.y (current DEV) when possible ... otherwise it goes this way too: https://www.armbian.com/get-involved/ 1
goathunter Posted November 12, 2019 Posted November 12, 2019 @ams.br Allow me to join the chorus. Thank you for posting your easy-to-follow instructions. I was able to build the current Armbian kernel with your patch and install it without any issue at all. The system has been up 1 day and 11 hours. I finally took the step of installing your patch after the system time-jumped twice over the weekend. I can't say for sure yet that it fixes the problem for me, but I can say that your directions made it a piece of cake to build and install, and so far, so good. Thanks! Updated 2019-11-18: My patched Pine has been running for 7 days and 12 hours now without issue, which is the longest it has ever run without experiencing the time jump. 1
windysea Posted November 28, 2019 Posted November 28, 2019 I haven't had much time to follow-up on this. FWIW the upstream patches should have included an improved version of the patch above already. To clarify it is not a fix but rather a loop to read the hardware timer repeatedly until there are two consecutive reads that are the same. It does add a different amount of overhead than the fix it is replacing. For instance there must always be at least two reads. I am wondering about the above solution being replaced since it is only a nine-bit mask, but it was found that this should probably be 11 bits. I forget the reason that solution was not used as-is in the upstream but I do remember there was concern two reads close enough could read the same value before the hardware timer actually changed (IE: The same bad value could be read twice consecutively) Now that we're a few versions newer than the last time I checked it probably warrants another review. FWIW I haven't seen the issue with the more recent kernels while previously I had one A64 that couldn't get through a half day.
eminguez Posted December 12, 2019 Posted December 12, 2019 I've just installed latest armbian buster today, updated, switched to the latest 5.4.2 kernel via armbian-config and installed k3s (minimal k8s distro) on it and after a few minutes, 2113! I will try the attached patch but just in case, to me it is still unresolved in 5.4.2.
martinayotte Posted December 12, 2019 Posted December 12, 2019 47 minutes ago, eminguez said: I will try the attached patch but just in case, to me it is still unresolved in 5.4.2. I've just added the patch, and will do testing when my new build is finished : https://github.com/armbian/build/commit/d688244fea291e81a42c64aaf3588ee1f83b741c 1
eminguez Posted December 13, 2019 Posted December 13, 2019 16 hours ago, martinayotte said: I've just added the patch, and will do testing when my new build is finished : https://github.com/armbian/build/commit/d688244fea291e81a42c64aaf3588ee1f83b741c Thanks!!! How can I update the kernel to the latest build? Is there a nightly builds kernel repo? Is there a way to check if the patch is there as a 'regular user'? Thanks again!
Igor Posted December 13, 2019 Posted December 13, 2019 11 minutes ago, eminguez said: Is there a nightly builds kernel repo? There are. See armbian-config and remember that those builds are not tested. 1
eminguez Posted December 13, 2019 Posted December 13, 2019 4 hours ago, Igor said: There are. See armbian-config and remember that those builds are not tested. I've updated to the latest one (19.11.3.346) and I can confirm the fix is not yet there (probably by looking at the commit time and the build time it didn't entered in the build). In order to do that, I've downloaded the sources (https://apt.armbian.com/pool/main/l/linux-source-5.4.2-dev-sunxi64/linux-source-dev-sunxi64_19.11.3.346_all.deb) and the patch doesn't seem to be there (it would be nice if the debs have a changelog or if they can be shown somewhere) I'll wait for the next build Thanks!!!
eminguez Posted December 16, 2019 Posted December 16, 2019 I've tried to build the kernel with the current sources but it seems to fail to apply the patch. From the log file: Processing file /root/build/patch/kernel/sunxi-dev/fix-a64-timejump.patch 1 out of 1 hunk FAILED -- saving rejects to file drivers/clocksource/arm_arch_timer.c.rej It is just a clean git clone from the armbian/build repository and the following build flags: /compile.sh BOARD=pine64 BRANCH=dev KERNEL_ONLY=yes KERNEL_CONFIGURE=no The rej file: # find ~/build/cache/sources -type f -iname "*arm_arch_timer.c.rej*" /root/build/cache/sources/linux-mainline/orange-pi-5.4/drivers/clocksource/arm_arch_timer.c.rej # cat /root/build/cache/sources/linux-mainline/orange-pi-5.4/drivers/clocksource/arm_arch_timer.c.rej --- drivers/clocksource/arm_arch_timer.c +++ drivers/clocksource/arm_arch_timer.c @@ -342,16 +342,17 @@ static u64 notrace arm64_858921_read_cntvct_el0(void) * number of CPU cycles in 3 consecutive 24 MHz counter periods. */ #define __sun50i_a64_read_reg(reg) ({ \ - u64 _val; \ - int _retries = 150; \ + u64 _old, _new; \ + int _retries = 200; \ \ \ do { \ - _val = read_sysreg(reg); \ + _old = read_sysreg(reg); \ + _new = read_sysreg(reg); \ _retries--; \ - } while (((_val + 1) & GENMASK(9, 0)) <= 1 && _retries); \ + } while (unlikely(_old != _new) && _retries); \ \ WARN_ON_ONCE(!_retries); \ - _val; \ + _new; \ }) static u64 notrace sun50i_a64_read_cntpct_el0(void) IDK why this file is hosted in the `orange-pi-5.4` folder. I've just in case extracted the source from the deb file and the code is not patched. Any help? Thanks!!!
