martinayotte Posted December 30, 2018 Share Posted December 30, 2018 25 minutes ago, g40 said: Does the DT control which USB interface is used? Repeating the exercise above with a card plugged into USB 2 or 3 does not work. If USB1 work, but not USB2 and USB3, I don't know where is the issue since I've enabled all of them in DT. In U-Boot command prompt, what "usb info" is reporting after having done "usb reset" ? 0 Quote Link to comment Share on other sites More sharing options...
g40 Posted January 1, 2019 Share Posted January 1, 2019 Hello Martin u-boot is detecting the OHCI/EHCI controllers. But it is only finding storage attached to USB0. In this case a USB=>SD card adapter. If I swap the thumb drive into USB0 and and SD adapter into USB2 or 4, it gets correctly identified. It's slightly annoying but definitely not a show-stopper. => usb reset resetting USB... EHCI failed to shut down host controller. EHCI failed to shut down host controller. USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 USB4: USB EHCI 1.00 USB5: USB OHCI 1.0 scanning bus 0 for devices... 2 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 4 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb storage Device 0: Vendor: Mass Rev: 1.00 Prod: Storage Device Type: Removable Hard Disk Capacity: 7580.0 MB = 7.4 GB (15523840 x 512) => usb storage Device 0: Vendor: SanDisk Rev: 1.00 Prod: Cruzer Blade Type: Removable Hard Disk Capacity: 7632.0 MB = 7.4 GB (15630336 x 512) 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted January 1, 2019 Share Posted January 1, 2019 28 minutes ago, g40 said: It's slightly annoying but definitely not a show-stopper. I will investigate when I get chance, time is the missing ingredient ... 0 Quote Link to comment Share on other sites More sharing options...
g40 Posted January 1, 2019 Share Posted January 1, 2019 Yes, is it ever I am going to try and repeat this exercise for the K1+ so it can boot out of SPI flash using TFTP. Are any of the other Allwinner based boards configured to do this? Thanks again for your help here. 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted January 1, 2019 Share Posted January 1, 2019 3 hours ago, g40 said: so it can boot out of SPI flash using TFTP. I don't know if networking is enabled in most u-boot, I doubt ... 0 Quote Link to comment Share on other sites More sharing options...
g40 Posted January 14, 2019 Share Posted January 14, 2019 On 1/1/2019 at 2:18 PM, martinayotte said: I will investigate when I get chance, time is the missing ingredient ... Hi Martin I've been playing with the 2018.11 release of U-Boot. The problem with not finding USB devices on busses > 0 seems to have been fixed. Annoyingly the device tree has been completely revised so there is a deal of patching to be done. I also got u-boot network support enabled in 2018.05 with some device tree changes. I'll try and get patches out in due course. LMK if you'd like the changes. Thanks for all the help. 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted January 14, 2019 Share Posted January 14, 2019 26 minutes ago, g40 said: The problem with not finding USB devices on busses > 0 seems to have been fixed Glad to hear that (especially that time still the missing ingredient) ! @Igor ? Is there any reason why sunxi* stick with u-boot v2018.05 instead of v2018.11 ? I don't recall any ... 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted January 14, 2019 Share Posted January 14, 2019 17 minutes ago, martinayotte said: Is there any reason why sunxi* stick with u-boot v2018.05 instead of v2018.11 ? I don't recall any ... Not anymore. I wanted to keep it as long as possible, but after this https://github.com/armbian/build/pull/1216 feature was introduced, we can move on right away. 0 Quote Link to comment Share on other sites More sharing options...
martinayotte Posted January 14, 2019 Share Posted January 14, 2019 5 minutes ago, Igor said: Not anymore. Ok ! I will update config/sources/sunxi* and give it a try with few boards ... 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted March 11, 2019 Share Posted March 11, 2019 On 10/22/2018 at 12:40 AM, markbirss said: Here what I did with a recent ARMBIAN 5.64 user-built Ubuntu 18.04.1 to flash the mx25l1606e (2048 Kbytes) spi flash with u-boot-sunxi-with-spl.bin Thanks for the instruction WIth these I did flash today my 2 Opi Zero with /usr/lib/linux-u-boot-dev-orangepizero_5.77_armhf/u-boot-sunxi-with-spl.bin (which I did build with the armbian-build-system today). Now this is my first testdrive to boot armbian from a usb-port before this I did only boot from MicroSD or eMMC on ther boards. Flashing went OK, but for comparing I couldnt use mtd_debug read /dev/mtd0 0 404407 ./current.bin because this gives me a Segmentation fault ( mtd-utils 1:2.0.0-1 armhf Memory Technology Device Utilities ) So for creating the file for compare I did use the following command succesfull:dd if=/dev/mtd0 bs=1 count=404407 of=./current.bin then the compare also went OK:cmp /usr/lib/linux-u-boot-dev-orangepizero_5.77_armhf/u-boot-sunxi-with-spl.bin ./current.bin As Info: the Zero seems to need more power for the USB-Drive (16GB USB 3.0 SanDisk Ultra Fit), because with the normal USB-Power I do use the Zero does disappear from the network after some time 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted May 25, 2020 Share Posted May 25, 2020 @c.man I rechecked the instructions from markbirss he wrote at October 22, 2018 in this thread today against my OrangePi R1 and it works like a charme to boot via spi-flash (as u-boot) from USB (so your USB msata should also work): Add overlay: spi-jedec-nor to /boot/armbianEnv.txt overlays=pi-jedec-nor (or complete by an OPi R1: overlays=analog-codec spi-jedec-nor usbhost2 usbhost3 ) via armbin-config -> system -> hardware Install mtd-utils: apt install mtd-utils Verify existence of the mtd device (will only work if your board actually has a supported spi chip) mtd_debug info /dev/mtd0: mtd.type = MTD_NORFLASH mtd.flags = MTD_CAP_NORFLASH mtd.size = 16777216 (16M) mtd.erasesize = 65536 (64K) mtd.writesize = 1 mtd.oobsize = 0 regions = 0 Erase the mtd device flash_erase /dev/mtd0 0 256 --> Erasing 64 Kibyte @ ff0000 -- 100 % complete Find the local "u-boot-sunxi-with-spl.bin" and it's size in bytes (455007) find / -name u-boot-sunxi-with-spl.bin --> /usr/lib/linux-u-boot-dev-orangepi-r1_20.05.0-trunk_armhf/u-boot-sunxi-with-spl.bin ls -l /usr/lib/linux-u-boot-dev-orangepi-r1_20.05.0-trunk_armhf/u-boot-sunxi-with-spl.bin --> -rw-rw-r-- 1 root root 455007 Mai 25 14:46 /usr/lib/linux-u-boot-dev-orangepi-r1_20.05.0-trunk_armhf/u-boot-sunxi-with-spl.bin Write the local u-boot-sunxi-with-spl.bin to the mtd device nandwrite -p /dev/mtd0 /usr/lib/linux-u-boot-dev-orangepi-r1_20.05.0-trunk_armhf/u-boot-sunxi-with-spl.bin Writing data to block 0 at offset 0x0 Writing data to block 1 at offset 0x10000 Writing data to block 2 at offset 0x20000 Writing data to block 3 at offset 0x30000 Writing data to block 4 at offset 0x40000 Writing data to block 5 at offset 0x50000 Writing data to block 6 at offset 0x60000 Write the mtd device to a local file to compare with local u-boot-sunxi-with-spl.bin (using the size of bytes the u-boot file used 455007) mtd_debug read /dev/mtd0 0 455007 current.bin --> Copied 455007 bytes from address 0x00000000 in flash to current.bin Compare the current.bin with the local /usr/lib/linux-u-boot-next-orangepizero_5.64_armhf/u-boot-sunxi-with-spl.bin cmp /usr/lib/linux-u-boot-dev-orangepi-r1_20.05.0-trunk_armhf/u-boot-sunxi-with-spl.bin ./current.bin --> No Output compares OK If that is OK - then power off, remove sdcard, write normal armbian-image to usb (if usb-stick or write the image before boot with dd to your msata device). If USB-Stick insert it in USB-Port and start your device. Now you will see it boot from USB (as in these hidden Messages): Spoiler U-Boot SPL 2020.04-armbian (May 25 2020 - 14:45:50 +0300) DRAM: 256 MiB Trying to boot from sunxi SPI U-Boot 2020.04-armbian (May 25 2020 - 14:45:50 +0300) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi R1 DRAM: 256 MiB MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... MMC: no card present In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: USB EHCI 1.00 Bus usb@1c1a400: USB OHCI 1.0 Bus usb@1c1b000: USB EHCI 1.00 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c1a000 for devices... 1 USB Device(s) found scanning bus usb@1c1a400 for devices... 1 USB Device(s) found scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 2 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop MMC: no card present Device 0: Vendor: SanDisk Rev: 1.00 Prod: Ultra Fit Type: Removable Hard Disk Capacity: 14832.0 MB = 14.4 GB (30375936 x 512) ... is now current device Scanning usb 0:1... Found U-Boot script /boot/boot.scr 3789 bytes read in 8 ms (461.9 KiB/s) ## Executing script at 43100000 U-boot loaded from SPI Boot script loaded from usb 181 bytes read in 8 ms (21.5 KiB/s) 12460445 bytes read in 317 ms (37.5 MiB/s) 7446528 bytes read in 189 ms (37.6 MiB/s) Found mainline kernel configuration 30841 bytes read in 10 ms (2.9 MiB/s) 504 bytes read in 11 ms (43.9 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo 504 bytes read in 12 ms (41 KiB/s) Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo 4185 bytes read in 11 ms (371.1 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 12460381 Bytes = 11.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 EHCI failed to shut down host controller. Loading Ramdisk to 4941d000, end 49fff15d ... OK Loading Device Tree to 493ad000, end 4941cfff ... OK Starting kernel ... Uncompressing Linux... done, booting the kernel. ... [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyGS0. [ OK ] Started Serial Getty on ttyS0. [ OK ] Reached target Login Prompts. [ OK ] Reached target Multi-User System. [ OK ] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [ OK ] Finished Update UTMP about System Runlevel Changes. Armbian 20.05.0-trunk Focal ttyS0 orangepi-r1 login: 0 Quote Link to comment Share on other sites More sharing options...
hmartin Posted September 27, 2020 Share Posted September 27, 2020 Hi, sorry if this is considered a necro bump. I just received the Orange Pi Zero Plus H5, as it was seemingly out of production earlier this year. I have tried building u-boot from mainline (using v2020.07 and v2020.04) and both fail with the following error (SPI or FEL booting): U-Boot SPL 2020.04-dirty (Sep 27 2020 - 20:11:48 +0000) DRAM: 512 MiB SPL: Unsupported Boot Device! SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### Since I have read about people flashing u-boot from Armbian, I thought I would try FEL booting the u-boot included in the Armbian Focal image. Same deal: U-Boot SPL 2020.04-armbian (Sep 02 2020 - 10:37:42 +0200) DRAM: 512 MiB SPL: Unsupported Boot Device! SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### Yes, I did replace the Macronix 16MBit with Winbond 128MBit (25Q128FVSG), but I don't think this is the cause of my issues as they should both implement the same JEDEC commands. Is u-boot SPI booting on the H5 just broken in recent u-boot releases? Or am I doing something fundamentally wrong? I've spent many hours trying different u-boot configuration options (e.g. CONFIG_SPL_NOR_SUPPORT, CONFIG_SPL_SPI_SUPPORT, CONFIG_SPI_FLASH, etc), and I cannot figure out why it's broken. The dts is correct, and according to all the documentation I can find, the defconfig should be sufficient to support loading u-boot from SPI. 0 Quote Link to comment Share on other sites More sharing options...
phier Posted June 10, 2021 Share Posted June 10, 2021 hi, these is mostly about how to fully re-flash uboot; but how can one re-configure uboot ie access its env variables? 0 Quote Link to comment Share on other sites More sharing options...
fcollingwood Posted September 22, 2022 Share Posted September 22, 2022 Sorry for the necro-bump. I followed the steps posted above by @guidol, and I was able to get my Zero Plus to boot via SPI and a 32GB USB key. I have two problems though: 1. I have the expansion board on the 13 pin header giving access to two additional USB ports. However, if I plug the 32GB USB key into one of these additional ports, it won't boot. 2. I have flashed the Armbian image to a 128GB USB key, but no matter which USB port it's inserted into, it won't boot. I checked the uboot version and it seems OK, certainly later than 2018.11: root@orangepizeroplus:~/build# strings /dev/mtd0 | grep U-Boot U-Boot SPL 2021.10-armbian (Aug 30 2022 - 06:48:52 +0000) U-Boot WConfiguration to load ATF before U-Boot ** Invalid partition type "%.32s" (expect "U-Boot") scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done U-Boot.armv8 U-Boot U-Boot 2021.10-armbian (Aug 30 2022 - 06:48:52 +0000) Allwinner Technology WU-Boot (64-bit) BL31: Found U-Boot DTB at %p, model: %s Configuration to load ATF before U-Boot U-Boot (64-bit) Hopefully @martinayotte or @Igor have a solution? 0 Quote Link to comment Share on other sites More sharing options...
