pbies Posted November 26, 2018 Posted November 26, 2018 @hipboi I already have this one. I was asking if these are 64-bit or 32-bit...
martinayotte Posted November 26, 2018 Posted November 26, 2018 37 minutes ago, pbies said: I was asking if these are 64-bit or 32-bit A simple search on google and/or wikipedia would have answered you ... https://en.wikipedia.org/wiki/Rockchip#RK3399
pbies Posted November 26, 2018 Posted November 26, 2018 @martinayotte I am not asking for CPU bitness. I am asking if these OSes images are 64-bit!
martinayotte Posted November 26, 2018 Posted November 26, 2018 2 hours ago, pbies said: I am asking if these OSes images are 64-bit! Armbian images are always native kernel along with all packages, so if CPU is 64 bits, all the OS is 64 bits ! The only thing that could be different, and this is up to the user to install it, is when people wish to run specific "armhf" application on a "aarch64" board when such application doesn't exist in 64bits, they need to install proper 32bits libraries, as mentioned in :
pbies Posted November 27, 2018 Posted November 27, 2018 @martinayotte I am not asking about Armbian. I am asking about the mentioned OSes. I have Armbian on armv7l and it is 32-bit. At least provided binaries are 32-bit. I ask about bitness of the provided OSes for Rock Pi 4. There is no Armbian for this board.
martinayotte Posted November 27, 2018 Posted November 27, 2018 33 minutes ago, pbies said: I am asking about the mentioned OSes. If you are talking about the link provided by @guidol , it is clearly mentioned "armhf", so 32 bits ...
hipboi Posted November 28, 2018 Posted November 28, 2018 7 hours ago, pbies said: @martinayotte I am not asking about Armbian. I am asking about the mentioned OSes. I have Armbian on armv7l and it is 32-bit. At least provided binaries are 32-bit. I ask about bitness of the provided OSes for Rock Pi 4. There is no Armbian for this board. The radxa people is working on Armbian support for this board. I think it will be soon to have Armbian on ROCK Pi 4. 2
martinayotte Posted November 28, 2018 Posted November 28, 2018 12 hours ago, hipboi said: The radxa people is working on Armbian support for this board Glad to hear that ... 1
NicoD Posted November 29, 2018 Posted November 29, 2018 My Rock Pi 4B arrived today. I'm impressed by it. Very well designed. Only bad point I've found until now is that the power LED is too bright. Everything I've tested until now seems to work. On-board audio is no problem and very stable voltage on the USB ports. Some things the M4 does a bit less. For who's interested here's my data until now. Debian armhf ------------ Chromium+Firefox not working. Install Vivaldi browser : wget https://downloads.vivaldi.com/stable/vivaldi-stable_1.13.1008.34-1_armhf.deb sudo apt install gdebi Open gdebi package installer, click open, go to Home folder and choose the vivaldi-stable.... Click install Youtube playback ---------------- Vivaldi : Best on 1080p 50% lost frames No zram-config/zram-tools in repo's : Manual configuration should work Temperatures ------------ No fan idle : 50°C No fan max load : 90°C throttle With fan idle : 37°C With fan max load : 76°C Power consumption ----------------- Idle with fan : 0.26A @ 9.14V = 2.3W Maxed out with fan : 1A @ 9.11V = 9.11W Very stable 5V on USB. With 1A load on USB + maxed out CPU + 5V fan it remains stable at 5V Blender BMW 1080p ----------------- armhf Debian : 1h58m04s SBC-Bench --------- No fan - small heatsink : http://ix.io/1uP8 With fan - small heatsink : http://ix.io/1uPr + Raspi compatible MIPI CSI/DSI + M.2 slot for NVME SATA + USB3 ports each have a seperate controller - Too bright power LED/Check if it can be accessed - High throttle temp 90°C - SD-card sticks out a lot Difference with Model A ----------------------- Model A : No WIFI No PoE Difference with NanoPi M4 ------------------------- RockPi 4 : Has M.2 slot USB3 ports have seperate controllers CSI/DSI are RPI compatible LPDDR4 Powered with USB Type C PD 2.0, 9V/2A, 12V/2A, 15V/2A, 20V/2A NanoPi M4 : Has a better stock heatsink(there are bigger heatsinks for the RPI4B) CSI/DSI are proprietary DDR3 Powered with 5V
NicoD Posted December 10, 2018 Posted December 10, 2018 Hi all. I've finished my review video about the RockPi 4B. Here it is. Greetings.
mboehmer Posted December 12, 2018 Author Posted December 12, 2018 Some news: https://wiki.radxa.com/Rockpi4/downloads There is a first Armbian image available. 1
pbies Posted December 18, 2018 Posted December 18, 2018 My Rock Pi 4 B 4GB just arrived. Unluckily I don't have PSU for it yet.
pbies Posted December 18, 2018 Posted December 18, 2018 cpuinfo: processor : 0 BogoMIPS : 48.00 Features : fp asimd evtstrm aes pmull sha1 sha2 crc32 CPU implementer : 0x41 CPU architecture: 8 CPU variant : 0x0 CPU part : 0xd03 CPU revision : 4 lscpu: Architecture: aarch64 Byte Order: Little Endian CPU(s): 6 On-line CPU(s) list: 0-5 Thread(s) per core: 1 Core(s) per socket: 3 Socket(s): 2 Vendor ID: ARM Model: 4 Model name: Cortex-A53 Stepping: r0p4 CPU max MHz: 1800.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 uname -a: Linux rock 4.4.154-ge0ce80a-dirty #6 SMP Fri Nov 23 16:58:02 CST 2018 aarch64 aarch64 aarch64 GNU/Linux dmesg attached. dmesg.txt
pbies Posted December 18, 2018 Posted December 18, 2018 No heatsink, no fan. $ stress-ng --cpu 1 --cpu-method matrixprod --metrics-brief -t 60 stress-ng: info: [1125] successful run completed in 60.22s (1 min, 0.22 secs) stress-ng: info: [1125] stressor bogo ops real time usr time sys time bogo ops/s bogo ops/s stress-ng: info: [1125] (secs) (secs) (secs) (real time) (usr+sys time) stress-ng: info: [1125] cpu 253 60.22 60.19 0.00 4.20 4.20 $ stress-ng --cpu 6 --cpu-method matrixprod --metrics-brief -t 60 stress-ng: info: [1147] successful run completed in 60.30s (1 min, 0.30 secs) stress-ng: info: [1147] stressor bogo ops real time usr time sys time bogo ops/s bogo ops/s stress-ng: info: [1147] (secs) (secs) (secs) (real time) (usr+sys time) stress-ng: info: [1147] cpu 793 60.20 359.21 0.08 13.17 2.21 $ sysbench --test=cpu --cpu-max-prime=20000 --num-threads=1 --max-time=60 run sysbench 1.0.11 (using system LuaJIT 2.1.0-beta3) Running the test with following options: Number of threads: 1 Initializing random number generator from current time Prime numbers limit: 20000 Initializing worker threads... Threads started! CPU speed: events per second: 701.24 General statistics: total time: 60.0014s total number of events: 42084 Latency (ms): min: 1.42 avg: 1.42 max: 6.72 95th percentile: 1.42 sum: 59964.36 Threads fairness: events (avg/stddev): 42084.0000/0.00 execution time (avg/stddev): 59.9644/0.00 $ sysbench --test=cpu --cpu-max-prime=20000 --num-threads=6 --max-time=60 run sysbench 1.0.11 (using system LuaJIT 2.1.0-beta3) Running the test with following options: Number of threads: 6 Initializing random number generator from current time Prime numbers limit: 20000 Initializing worker threads... Threads started! CPU speed: events per second: 2237.70 General statistics: total time: 60.0024s total number of events: 134280 Latency (ms): min: 1.42 avg: 2.68 max: 22.67 95th percentile: 3.62 sum: 359842.66 Threads fairness: events (avg/stddev): 22380.0000/8091.23 execution time (avg/stddev): 59.9738/0.01 $ 7z b 7-Zip [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=pl_PL.UTF-8,Utf16=on,HugeFiles=on,64 bits,6 CPUs LE) LE CPU Freq: 1064 979 894 1260 1651 1792 1792 1792 1792 RAM size: 3812 MB, # CPU hardware threads: 6 RAM usage: 1323 MB, # Benchmark threads: 6 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 4218 478 858 4104 | 92601 523 1509 7897 23: 4035 494 833 4112 | 87611 544 1394 7581 24: 3793 516 791 4079 | 84930 564 1323 7455 25: 3592 530 774 4102 | 81479 586 1237 7251 ---------------------------------- | ------------------------------ Avr: 504 814 4099 | 554 1365 7546 Tot: 529 1090 5823 7z b: 1.609 more total MIPS than RPi 3B+ with fan.
NicoD Posted December 18, 2018 Posted December 18, 2018 3 hours ago, pbies said: No heatsink, no fan. Don't use it without a heatsink/fan. The throttling isn't set right in any of the OS'es. It only throttles the big cores, and so the temperature keeps rising. Here my temps with a heatsink Debian armhf No fan idle : 50°C No fan max load : 85°C throttle keeps rising to +90°C With fan idle : 37°C With fan max load : 77°C Ubuntu arm64 No fan idle : 56°C No fan max load : 85°C throttle keeps rising to 95°C With fan idle : 38°C With fan max load : 83°C I bet without a heatsink it will rise quicker and higher. Maybe to +100°C. I told them, and they're working on it, I don't think it's fixed yet. Just wanted to let you know before you cook it. Here you see what happens. System health while running 7-zip multi core benchmark: Time big.LITTLE load %cpu %sys %usr %nice %io %irq Temp 14:38:16: 1416/1416MHz 4.78 16% 0% 15% 0% 0% 0% 86.9°C 14:38:40: 1200/1416MHz 5.34 80% 1% 79% 0% 0% 0% 89.4°C 14:39:00: 1008/1416MHz 5.70 90% 1% 88% 0% 0% 0% 90.0°C 14:39:22: 1008/1416MHz 6.01 85% 2% 83% 0% 0% 0% 90.0°C 14:39:43: 1008/1416MHz 5.66 80% 1% 79% 0% 0% 0% 89.4°C 14:40:03: 1008/1416MHz 5.83 88% 1% 87% 0% 0% 0% 91.1°C 14:40:23: 1008/1416MHz 5.72 87% 1% 86% 0% 0% 0% 91.7°C 14:40:44: 1008/1416MHz 5.54 85% 1% 83% 0% 0% 0% 90.6°C 14:41:04: 1200/1416MHz 5.45 80% 1% 78% 0% 0% 0% 90.0°C 14:41:25: 1008/1416MHz 5.74 89% 1% 88% 0% 0% 0% 92.2°C 14:41:46: 816/1416MHz 5.95 87% 1% 85% 0% 0% 0% 92.2°C 14:42:07: 1008/1416MHz 6.38 84% 1% 83% 0% 0% 0% 92.2°C System health while running cpuminer: Time big.LITTLE load %cpu %sys %usr %nice %io %irq Temp 14:42:24: 1800/1416MHz 6.02 23% 0% 22% 0% 0% 0% 91.1°C 14:42:48: 816/1416MHz 6.01 99% 0% 99% 0% 0% 0% 93.3°C 14:43:13: 816/1416MHz 6.06 100% 0% 99% 0% 0% 0% 93.9°C 14:43:38: 600/1416MHz 6.12 100% 0% 99% 0% 0% 0% 93.9°C 14:44:04: 600/1416MHz 6.21 100% 0% 99% 0% 0% 0% 93.9°C 14:44:29: 600/1416MHz 6.20 100% 0% 99% 0% 0% 0% 93.9°C 14:44:54: 600/1416MHz 6.31 100% 0% 99% 0% 0% 0% 94.4°C 14:45:18: 600/1416MHz 6.26 100% 0% 99% 0% 0% 0% 94.4°C
NicoD Posted December 18, 2018 Posted December 18, 2018 But it is an awesome board tho. I love it even more than my NanoPi M4. I'm testing images for them now, RecalBox is awesome. I made a video about it, but I've got to wait to release until they'll release the image. They seem to put a lot of energy in software. So there it beats all the others. And it's Raspberry compatible with a lot of things. So it could become a very well selled board.
pbies Posted December 18, 2018 Posted December 18, 2018 @NicoD I will need to order heatsink. For now it is just a test board. I'll try not to heat it too much.
Dante4 Posted December 22, 2018 Posted December 22, 2018 Heatsink and M.2 Expander Board are out. You can buy them here https://shop.allnetchina.cn/collections/rock-pi-4-accessories?page=2 1
pbies Posted December 22, 2018 Posted December 22, 2018 @Dante4 unfortunately there are some countries which they are not shipping to. Poland is one of them.
Dante4 Posted December 22, 2018 Posted December 22, 2018 3 hours ago, pbies said: @Dante4 unfortunately there are some countries which they are not shipping to. Poland is one of them. Well, to be precise to whole EU (UK is not part of EU for them now). For EU there are special distributors, but that such pain to deal with them (one require special account to be able to order and other cost just huge), so maybe it will be simplier (and cheapier) to use some trustworthy man-in-the-middle outside of EU.
pbies Posted December 23, 2018 Posted December 23, 2018 I bought here https://pishop.at/index.php/single-board-computer/rock-pi-4-model-b-4gb-detail with overall price (with shipment) €114.78 (504.44 PLN). I've seen the same model €105 from Spain without shipment...
SenorSmartyPants Posted February 20, 2019 Posted February 20, 2019 I just did the most recent apt upgrade/update and I noticed a change in htop. Before it would report CPU temp and core frequencies. Both of those are gone now. Does anyone know if this is a change with htop or rockpi firmware? I thought that was nice info to have in htop.
Ľubo Jurčišin Posted February 22, 2019 Posted February 22, 2019 Hi guys, I bought this sbc a few days ago and I love it! I will be a server and a controler for my hydroponic system, once :D I am using Armbian system provided by radxa, not the nightly build downloaded from armbian directly, with mainline kernel 4.4. But the gpu performance seems to be quite slow. The whole ui and web browsing has a low fps. I've triet to build panfrost driver for mali gpu but it didn't help. Do you guys use some other gpu driver or are you ok with the performance?
JMCC Posted February 22, 2019 Posted February 22, 2019 36 minutes ago, Ľubo Jurčišin said: Do you guys use some other gpu driver or are you ok with the performance? This is what we use. It is meant to be applied on an Armbian Bionic Default image:
Ľubo Jurčišin Posted February 23, 2019 Posted February 23, 2019 (edited) Thanks, I will try it. I've tried Armbian Bionic (same as Armbian Stretch) nightly builds before, but I had no Wifi and max resolution was 1920x1080 (I have 2k monitor). Plus I did not see mali0 under /dev. So I thought there's missing mali driver. I am new in linux so sorry for noob questions... EDIT: On 2/22/2019 at 11:32 PM, JMCC said: This is what we use. It is meant to be applied on an Armbian Bionic Default image: JMCC, what did you mean Armbian Bionic Default image? I've found only nightly builds working with kernel 4.2, updating kernel to 4.4 caused boot failure. On the https://dl.armbian.com/rockpi-4b/, in the "Archive" folder I found 5.75 versions of Armbian with 4.4.174 kernels, but no boot again. Just red led blinking... So I did not find a way how to get armbian bionic working with 4.4 kernel. What am I missing? Edited February 25, 2019 by Ľubo Jurčišin
atula Posted March 1, 2019 Posted March 1, 2019 rockpi 4 ARMBIAN 5.74.190202 nightly Debian GNU/Linux 9 (stretch) 4.20.0-rockchip64 could someone help me to take uart0, 1, 3. uart2 works , pin 8, 10 root@rockpi:~# ls /dev/ttyS* /dev/ttyS0 /dev/ttyS1 /dev/ttyS2 /dev/ttyS3 i dont need serial console step by step and simply
martinayotte Posted March 1, 2019 Posted March 1, 2019 8 hours ago, atula said: step by step and simply You need to install DT compiler from : http://ftp.debian.org/debian/pool/main/d/device-tree-compiler/device-tree-compiler_1.4.7-3_arm64.deb Backup /boot/dtb/rockchip/rk3399-rockpi4b.dtb into /boot/dtb/rockchip/rk3399-rockpi4b.dtb-ORIG Decompile the DTB into DTS : dtc -@ -I dtb -O dts -o rk3399-rockpi4b.dts-4.20.0 /boot/dtb/rockchip/rk3399-rockpi4b.dtb Edit the file rk3399-rockpi4b.dts-4.20.0 by changing all the serial node from "disabled" to "okay", then recompile DTB : dtc -@ -I dts -O dtb -o /boot/dtb/rockchip/rk3399-rockpi4b.dtb rk3399-rockpi4b.dts-4.20.0 1
atula Posted March 4, 2019 Posted March 4, 2019 Thank you very much for script, /dev/ttyS1 and /dev/ttyS2 also, two other not work I'm trying them again but two uarts is fine
