koakh Posted April 24, 2019 Posted April 24, 2019 Thanks @balbes150 Its seems a hard task! Maybe I wait for someone create a dtb for A95X Max..........or someone send me some links to start....maybe to start in first step.... 1. get the primary information to create an option for your model Thanks
talraash Posted May 3, 2019 Posted May 3, 2019 I finally “killed” my last tv box on s905x. How does s905x2 feel like in linux? According to synthetic tests, should the power of new soc be sufficient for sw video decoding up to 1080p? Does it make sense to pay a little extra and get boxes on the new soc?
MemoLee51 Posted May 5, 2019 Posted May 5, 2019 I need some help : (please forgive my english, it isn't my native language; also I'm a total newbie) I managed installing armbian 5.82 under debian, and it booted, but it won't connect to any network even known I'm plugged in Ethernet to my modem. I have a H96 Max and I choosed its dtb for the install.
amirul Posted May 5, 2019 Posted May 5, 2019 4 hours ago, MemoLee51 said: I need some help : (please forgive my english, it isn't my native language; also I'm a total newbie) I managed installing armbian 5.82 under debian, and it booted, but it won't connect to any network even known I'm plugged in Ethernet to my modem. I have a H96 Max and I choosed its dtb for the install. You could try this
MemoLee51 Posted May 5, 2019 Posted May 5, 2019 36 minutes ago, amirul said: You could try this But mines runs a s905x2 , will it work? (sorry if I'm kind of annoying but don't know much about tinkering those things)
amirul Posted May 5, 2019 Posted May 5, 2019 17 minutes ago, MemoLee51 said: But mine runs a s905x2 , will it work? (sorry if I'm kind of annoying but don't know much about tinkering those things) Sorry I read H96 Max from your post
MemoLee51 Posted May 5, 2019 Posted May 5, 2019 Actually Ijust realized I used the x96 Max dtb. If anyone could help.
balbes150 Posted May 7, 2019 Posted May 7, 2019 On 5/4/2019 at 12:55 AM, talraash said: I finally “killed” my last tv box on s905x. How does s905x2 feel like in linux? According to synthetic tests, should the power of new soc be sufficient for sw video decoding up to 1080p? Does it make sense to pay a little extra and get boxes on the new soc? I have several options for S905X2. Video in MPV up to 1080p works with SW normally. There are small artifacts in the browser at 1080p. Is no support for audio via HDMI (expected within the next month), you need to use a USB sound card. And no support built-in WiFi and BT (need to use USB). If you take, the version with 4 GB of RAM and 1000 LAN port (and I recommend proven models for which there will be support). If there is no hurry, you can wait until the fall, then go new RK, it is more interesting models. 2
Peyton Posted May 27, 2019 Posted May 27, 2019 Do you have some dtb file to boot on km9 which use S905X2 SoC or it's not possible ? I received one and it run android 9 on kernel 4. If i can bring you more infos easily i will. Thanks.
sol Posted July 21, 2019 Posted July 21, 2019 Hi people, what image I can use for this box https://www.gearbest.com/tv-box/pp_009773246649.html?wid=1433363 Thanks
theflashdesign Posted July 26, 2019 Posted July 26, 2019 (edited) YES! I have a VANKYO MatrixBox X95 Plus with 2g ram, 32g rom, PCB board is A95XY2_V1.1 and cpu s905y2 Just about the same as A95X plus with 4g of ram. USB BOOT File Armbian_5.86_Aml-s905_Ubuntu_bionic_default_5.1.0_desktop_20190514.img DTB File meson-g12a-x96-max-rmii.dtb Working on s905x2 a95x plus s905y2 In USB1 port blue 3.0 Edit uEnv.ini file with dtb_name=/dtb/dtb.img Rename meson-g12a-x96-max-rmii.dtb to dtb.img Copy to dtb folder Boot USB1 Login : root Pass : 1234 meson-g12a-x96-max-rmii.dtb Edited July 26, 2019 by theflashdesign
Haryy Posted July 28, 2019 Posted July 28, 2019 (edited) @theflashdesignI have an s905x2 ( A95X F2 4GB/64GB ) but I keep getting footer is wrong signature verification failed error 21 I have tried two different SD cards and five usb thumb drives, two different flash programs (rufus on windows and etcher on mac). Same error on every single one. Any ideas ? Edited July 28, 2019 by Haryy
sol Posted July 30, 2019 Posted July 30, 2019 @theflashdesignhello, where is this file Armbian_5.86_Aml-s905_Ubuntu_bionic_default_5.1.0_desktop_20190514.img ? so I need to burn it to usb and then replace dtb ? thanks
theflashdesign Posted July 31, 2019 Posted July 31, 2019 8 hours ago, sol said: @theflashdesignhello, where is this file Armbian_5.86_Aml-s905_Ubuntu_bionic_default_5.1.0_desktop_20190514.img ? so I need to burn it to usb and then replace dtb ? thanks I think this is the link that I used I'm not on my PC right now. Yes to USB I also flash the aml-update.zip file in Android (don't) check any boxes that say wipe then reboot unplug power hold reset at boot. It worked for my box but no wifi https://yadi.sk/d/pHxaRAs-tZiei/5.86/S9xxx/default 1
sol Posted July 31, 2019 Posted July 31, 2019 @theflashdesignalright, it boots fine Though couldn't get network running, checked /etc/network/interfaces tried dhcp and static ip but nothing worked. Even if static ip was assigned couldn't ping my other network devices. Will see more. Thanks for info anyway it's something already!
theflashdesign Posted July 31, 2019 Posted July 31, 2019 25 minutes ago, sol said: @theflashdesignalright, it boots fine Though couldn't get network running, checked /etc/network/interfaces tried dhcp and static ip but nothing worked. Even if static ip was assigned couldn't ping my other network devices. Will see more. Thanks for info anyway it's something already! NICE I've been really trying to get lakka to run on this box but it fails to boot every time
podarok Posted August 10, 2019 Posted August 10, 2019 installed today successfully on X96 Max wifi is not working. all other systems working perfect way performant replacement for the raspberry pi
qstaq Posted August 10, 2019 Posted August 10, 2019 1 hour ago, podarok said: installed today successfully on X96 Max wifi is not working. all other systems working perfect way performant replacement for the raspberry pi AP6356S WiFi chip in the 2.4/5Ghz models does work however the system looks for the firmware in the wrong place Copy the firmware from the rkwifi folder to the brcm folder and reboot, wifi should work cp -Rv /lib/firmware/rkwifi/* /lib/firmware/brcm/
podarok Posted August 10, 2019 Posted August 10, 2019 28 minutes ago, qstaq said: AP6356S WiFi chip in the 2.4/5Ghz models does work however the system looks for the firmware in the wrong place Copy the firmware from the rkwifi folder to the brcm folder and reboot, wifi should work cp -Rv /lib/firmware/rkwifi/* /lib/firmware/brcm/ doesn't work root@aml:~# uname -a Linux aml 5.2.0-rc7-aml-g12 #5.91 SMP PREEMPT Mon Jul 8 14:07:34 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux
qstaq Posted August 10, 2019 Posted August 10, 2019 20 minutes ago, podarok said: doesn't work root@aml:~# uname -a Linux aml 5.2.0-rc7-aml-g12 #5.91 SMP PREEMPT Mon Jul 8 14:07:34 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux Can you pot the output of armbianmonitor -u Check your dmesg output, there will be a firmware loading failed line
podarok Posted August 10, 2019 Posted August 10, 2019 1 minute ago, qstaq said: Can you pot the output of armbianmonitor -u Check your dmesg output, there will be a firmware loading failed line http://ix.io/1Rgz
qstaq Posted August 10, 2019 Posted August 10, 2019 You dont seem to have the bcmdhd module loaded Can you "modprobe bcmdhd" then check the output of dmesg You should see something like below or see a firmware load error [141287.185258] dhd_module_init: in Dongle Host Driver, version 1.579.77.41.9 (r) [141287.185286] ======== dhd_wlan_init_plat_data ======== [141287.185298] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [141287.185315] dhd_wlan_init_gpio: WL_REG_ON=-1, WL_HOST_WAKE=-1 [141287.185326] dhd_wlan_init_gpio: oob_irq=65, oob_irq_flags=0x414 [141287.185336] dhd_wifi_platform_load: Enter [141287.185378] Power-up adapter 'DHD generic adapter' [141287.185782] dummy_sdmmc: probe of mmc2:0001:1 failed with error -110 [141287.186059] dummy_sdmmc: probe of mmc2:0001:2 failed with error -110 [141287.186883] wifi_platform_set_power = 1 [141287.186897] ======== PULL WL_REG_ON(-1) HIGH! ======== [141287.186909] [WLAN_RFKILL]: rockchip_wifi_power: 1 [141287.186921] [WLAN_RFKILL]: wifi turn on power. -1 [141287.489181] wifi_platform_bus_enumerate device present 1 [141287.489193] ======== Card detection to detect SDIO card! ======== [141287.489200] mmc2:mmc host rescan start!
podarok Posted August 10, 2019 Posted August 10, 2019 1 minute ago, qstaq said: You dont seem to have the bcmdhd module loaded Can you "modprobe bcmdhd" then check the output of dmesg root@aml:~# modprobe bcmdhd modprobe: FATAL: Module bcmdhd not found in directory /lib/modules/5.2.0-rc7-aml-g12
qstaq Posted August 10, 2019 Posted August 10, 2019 2 minutes ago, podarok said: root@aml:~# modprobe bcmdhd modprobe: FATAL: Module bcmdhd not found in directory /lib/modules/5.2.0-rc7-aml-g12 Strange. Where did you download your armbian image from?
podarok Posted August 10, 2019 Posted August 10, 2019 1 minute ago, qstaq said: Strange. Where did you download your armbian image from? Armbian_5.91_Aml-g12_Ubuntu_disco_default_5.2.0-rc7_20190708.img.xz from yandex disk
qstaq Posted August 10, 2019 Posted August 10, 2019 Just now, podarok said: Armbian_5.91_Aml-g12_Ubuntu_disco_default_5.2.0-rc7_20190708.img.xz from yandex disk Is that the 5.91 images from balbes150 unofficial test yandisk repo? If so then yes it is missing the bcmdhd module. You will have to clone balbes s905 kernel repo from github and build the module and / or kernel
podarok Posted August 10, 2019 Posted August 10, 2019 9 minutes ago, qstaq said: Is that the 5.91 images from balbes150 unofficial test yandisk repo? If so then yes it is missing the bcmdhd module. You will have to clone balbes s905 kernel repo from github and build the module and / or kernel Is there any image with this module ?
X96Maxer Posted August 10, 2019 Posted August 10, 2019 3 hours ago, podarok said: installed today successfully on X96 Max wifi is not working. all other systems working perfect way performant replacement for the raspberry pi What Android version os your x96max? Mine is android 9 and gives me an verification error in the upgrade..... What version of armbian do you use? Thanks un advance
podarok Posted August 11, 2019 Posted August 11, 2019 12 hours ago, X96Maxer said: What Android version os your x96max? Mine is android 9 and gives me an verification error in the upgrade..... What version of armbian do you use? Thanks un advance It was version 9. I killed it accidentally I went to recovery and run TSWP from. Where I was able to flash TSWP as a recovery and then installed armbian from sdcard plus overridden eMMC with armbian So right now I have no android at all
X96Maxer Posted August 12, 2019 Posted August 12, 2019 (edited) On 8/11/2019 at 12:45 PM, podarok said: It was version 9. I killed it accidentally I went to recovery and run TSWP from. Where I was able to flash TSWP as a recovery and then installed armbian from sdcard plus overridden eMMC with armbian So right now I have no android at all Thanks I'm newbie with tvboxes and armbian. I'm booting with twrp by: 1. - trying to install the aml_autoscript.zip 2. - When x96 max reboots gives an error (verification error) 3.- update from EXT... sdcard TWRP-3.2.2.zip 4.- The TWRP starts correctly If I try with the button in "AV" then x96 max or "bootloader" from recovery menu.... the system freezes in the first logo (it appears that there is not a bootloader ¿?) and have downloaded a lot of armbians from https://yadi.sk/d/pHxaRAs-tZiei I can copy to sdcard with balena etcher but never starts.... and can't locate an option to boot from sdcard. I copied in other sdcard (fat32) the full image ( Armbian_5.91_Aml-g12_Debian_buster_default_5.2.1_20190802.img for example) and locate the restore option in twrp ..... very scared I click in "restore boot" but error message received ".... file size not match... " or something like. I don't need android in the x96max.... if armbian runs with ethernet (¿wifi runs?).. I would prefer dual boot but if no chance I can live without android. The ubuntu disco version is good for me (can I try with desktop if the process is repeatable) So, please, say to me: How do you flash twrp as a recovery? How do you intalled armbian from sdcard? How "overridden eMMC with armbian"? thanks in advance I have got It! I don't know how but playing with twrp, another versión images and diferent muktiboot zips..... It starts from sdcard the Ubuntu with and without desktop!!!!! now to try with wifi ...... Edited August 13, 2019 by X96Maxer I have got It
