Vuckovic Milos Posted February 5, 2019 Share Posted February 5, 2019 Hello, I'm new to the Pi computers and all that, and I'm planning on doing a project, so I was wondering if the Opi One H3 would support packet injection and monitor mode on Armbian with the onboard wifi? Thanks in advance. Link to comment Share on other sites More sharing options...
0 Igor Posted February 6, 2019 Share Posted February 6, 2019 7 hours ago, Vuckovic Milos said: with the onboard wifi Onboard wifi chips are mainly on the low end which means their drivers are on the baseline functionality. I am not aware of any board that would support monitor mode. You will probably need to go with something on USB: 8811AU, 8812AU ... that will work. Link to comment Share on other sites More sharing options...
0 manuti Posted February 6, 2019 Share Posted February 6, 2019 Orange Pi One dons't have onboard Wi-Fi. Maybe you are thinking on Orange Pi Lite. Following this RPi tutorial https://null-byte.wonderhowto.com/how-to/enable-monitor-mode-packet-injection-raspberry-pi-0189378/ and using Nexmon drivers you can reach this modes but ... the RTL8189FTV chipset included in the OPi Lite is not supported. Link to comment Share on other sites More sharing options...
0 DrSchottky Posted February 6, 2019 Share Posted February 6, 2019 I suggest you to buy one of the mentioned 8812AU USB dongles or, if you want to use the embedded WiFi, a Zero Plus2 H3 w/ Nexmon. RTL8189FTV should support monitor mode (it's mostly a matter of drivers), but I never tested it so I can't guarantee. 1 Link to comment Share on other sites More sharing options...
0 Vuckovic Milos Posted February 6, 2019 Author Share Posted February 6, 2019 It said onboard network as for ethernet, not for wifi, haha i'm stupid... Will get the zero plus 2 h3 after doing some more research about monitor mode on that, thanks guys, I don't want to open another thread, so I'll ask here, does it support monitor mode (Opi zero plus2)??? Link to comment Share on other sites More sharing options...
0 Vuckovic Milos Posted February 6, 2019 Author Share Posted February 6, 2019 Hi, so I asked a question about monitor mode for a board that doesn't even have wifi onboard, what a pity... I've looked into it more, and I was wondering if these boards will support it (they have onboard wifi) Orange pi zero h2 Orange pi zero plus h5 Or do I have to opt for the more expensive Opi zero plus2? Sorry for bothering, I'm quite a noob, haha. Link to comment Share on other sites More sharing options...
0 Igor Posted February 7, 2019 Share Posted February 7, 2019 10 hours ago, Vuckovic Milos said: Orange pi zero h2 Orange pi zero plus h5 Or do I have to opt for the more expensive Opi zero plus2? 1. No monitor mode, most shitty wifi chip ever seen on those boards. Stay away. 2. Possible, but not OOB. You will need to patch/hack drivers. 3. Possible, probably not OOB. You will need to patch/hack drivers. This chip is similar that the one on RPi3 for which IIRC I saw some patches for this function. 10 hours ago, Vuckovic Milos said: I'm quite a noob In this case its highly recommended to buy 8811AU/8812AU based USB wifi, where this will work plug and play. Link to comment Share on other sites More sharing options...
0 DrSchottky Posted February 7, 2019 Share Posted February 7, 2019 10 hours ago, Vuckovic Milos said: Hi, so I asked a question about monitor mode for a board that doesn't even have wifi onboard, what a pity... I've looked into it more, and I was wondering if these boards will support it (they have onboard wifi) Orange pi zero h2 Orange pi zero plus h5 Or do I have to opt for the more expensive Opi zero plus2? Sorry for bothering, I'm quite a noob, haha. Although I suggest you to buy one of that dongles if you really want to go with Zero Plus2 be sure to buy the H3 version, since Nexmon doesn't come with aarch64 support Link to comment Share on other sites More sharing options...
0 Vuckovic Milos Posted February 7, 2019 Author Share Posted February 7, 2019 Alright, thanks, looks like I'll buy the opi one+ a usb wifi dongle, May you guys suggest me one that will work and possibly fit in the plastic casing? Also, as cheap as possible (Doesn't have to fit, but It'd be good) Link to comment Share on other sites More sharing options...
0 Igor Posted February 8, 2019 Share Posted February 8, 2019 10 hours ago, Vuckovic Milos said: Alright, thanks, looks like I'll buy the opi one+ a usb wifi dongle, May you guys suggest me one that will work and possibly fit in the plastic casing? Also, as cheap as possible (Doesn't have to fit, but It'd be good) https://www.armbian.com/orange-pi-one/ If you live in EU and Amazon.de is in your reach you only need to click to the red zone and you get best option. In case amazon.de is not the best for you, search around Aliexpress, Gearbest, ... for exact this one. Spoiler Link to comment Share on other sites More sharing options...
Question
Vuckovic Milos
Link to comment
9 answers to this question
