lampra Posted May 2, 2016 Posted May 2, 2016 Here is a used Toshiba EXCERIA 16GB I have run izone on cubietruck with an other image (not Armbian) already on the card Photo Reveal hidden contents Reveal hidden contents random random KB reclen write rewrite read reread read write 102400 4 544 547 9676 9703 9685 311 102400 16 2289 2352 15279 14941 14258 1042 102400 512 14421 16325 19463 19520 19397 3202 102400 1024 15810 16174 20025 20146 20139 5646 102400 16384 16780 16852 20853 20929 20833 14742 mmc0:1300 info: cid: 02544d534431364789dfe2654900cb21 csd: 400e00325b59000075bf7f800a400093 scr: 02b5800332020702 date: 11/2012 name: SD16G type: SD preferred_erase_size: 4194304 fwrev: 0x9 hwrev: 0x8 oemid: 0x544d manfid: 0x000002 serial: 0xdfe26549 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block erase_size: 512 $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor performance $ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq 960000
tkaiser Posted May 3, 2016 Author Posted May 3, 2016 On 5/2/2016 at 10:05 PM, lampra said: Here is a used Toshiba EXCERIA 16GB Thx. But it would help if you could tell the exact product description (also for the Transcend tested before), maybe an picture of those two cards? IMO they're both too slow (especially writes and especially with small record sizes) but since they're both rather old the results are hard to classify or to use for buying decisions.
lampra Posted May 3, 2016 Posted May 3, 2016 On 5/3/2016 at 6:29 AM, tkaiser said: Thx. But it would help if you could tell the exact product description (also for the Transcend tested before), maybe an picture of those two cards? IMO they're both too slow (especially writes and especially with small record sizes) but since they're both rather old the results are hard to classify or to use for buying decisions. Hi, both posts updated with a photo. I bought both cards during 2015 and I now realized that they were manufactured during 2012 and 2013. When it comes to desktop use (i.e. "not headless"), Toshiba exceria is much more responsive and also much faster with software updates. If you think that these posts are "useless" even for future reference, let me know and I can delete them. 1
drose28357 Posted May 5, 2016 Posted May 5, 2016 i just installed Armbian Jessie Desktop Vanilla (Kernel 4.5.2-sunxi) on a cubietruck i moved rootfs to ssd. I use SanDisk Extrem Pro U3 64 GByte. It loads the image on USB3.0 with 75 Mbyte/sec. So it should be a speedy one ;-) here are the result /var/log/armhwinfo.log has been uploaded to http://sprunge.us/HQKV random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 10685 13846 38298 39802 22382 13571 102400 16 20769 24279 70019 71756 58212 24283 102400 512 34010 34755 150473 150265 146174 35034 102400 1024 34605 35535 154435 155517 152905 35198 102400 16384 36256 36648 176087 176085 176053 36368 and from "cat /var/log/armhwinfo.log | more" Fri Apr 29 03:16:19 CEST 2016 sun7i armv7l Cubietech Cubietruck Cubietruck Linux version 4.5.2-sunxi (root@trusty) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #11 SMP Thu Apr 28 21:53:25$ ### mmc0:aaaa info: cid: 0353445350363447802a34340700fa37 csd: 400e00325b590001dbd37f800a4040df scr: 0245840300000000 date: 10/2015 name: SP64G type: SD preferred_erase_size: 16777216 fwrev: 0x0 hwrev: 0x8 oemid: 0x5344 manfid: 0x000003 serial: 0x2a343407 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SP64G MODALIAS=mmc:block erase_size: 512
tkaiser Posted May 5, 2016 Author Posted May 5, 2016 On 5/5/2016 at 10:50 AM, drose28357 said: i moved rootfs to ssd. And tested the SSD later Please note that the Cubietruck can not exceed 23MB/s on SDIO and not 39.5MB/s on USB2.0 so you showed us how your SSD performs when using native SATA. Performance is not that impressive so maybe look through http://linux-sunxi.org/Sunxi_devices_as_NAS 1
drose28357 Posted May 6, 2016 Posted May 6, 2016 Sorry. didnt understand the test command. But it seems to create a file maybe in rootfs ( on ssd).
tkaiser Posted May 6, 2016 Author Posted May 6, 2016 On 5/6/2016 at 1:39 PM, drose28357 said: Sorry. didnt understand the test command. But it seems to create a file maybe in rootfs ( on ssd). Well, iozone uses the current working directory to test with. So in case you created an ext4 partition on your SD card that is writeable simply do a chdir before and then start the iozone call again. Regarding your Samsung SSD 840 EVO. You should be able to exceed 40MB/s sequential write speeds and get close to 200MB/s. Which cpufreq governor are you currently using (cpufreq-info should tell)?
wildcat_paris Posted May 7, 2016 Posted May 7, 2016 my turn with eMMC 32GB from hardkernel (without the SD reader) Odroid XU4 kernel 3.10.96 Reveal hidden contents kB reclen write rewrite read reread read write 102400 4 3282 3319 5651 4854 6378 5532 102400 16 10676 12738 12603 12667 10758 8813 102400 512 28941 29109 23747 24573 29744 24074 102400 1024 41504 42335 38576 45464 40423 40857 102400 16384 62566 66868 135014 126652 130134 63020 random random kB reclen write rewrite read reread read write 102400 4 3368 5216 4299 3727 3935 3286 102400 16 9371 11520 12234 9341 8828 8506 102400 512 33701 27352 24157 32883 30253 24118 102400 1024 42484 42781 42935 40733 43126 41871 102400 16384 63433 64096 144852 136006 128915 65239 MMC info: Reveal hidden contents mmc0:0001 info: cid: 4501005344573332470192b7309892d5 csd: d00f00320f5903ffffffffef8a40401f prv: 0x1 date: 09/1999 name: SDW32G type: MMC rel_sectors: 0x1 preferred_erase_size: 524288 fwrev: 0x0 hwrev: 0x0 oemid: 0x0100 enhanced_area_offset: 18446744073709551594 raw_rpmb_size_mult: 0x0 manfid: 0x000045 serial: 0x92b73098 uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=SDW32G MODALIAS=mmc:block erase_size: 524288 enhanced_area_size: 4294967274
chradev Posted May 9, 2016 Posted May 9, 2016 Hi to All, Some results from the performance tests of eMMC on A20-Olinuxinot-Lime2-eMMC can be found on the following posts: http://forum.armbian.com/index.php/topic/853-armbian-customization/page-4#entry8846 - in graphics form http://forum.armbian.com/index.php/topic/853-armbian-customization/page-4#entry8847 - data in raw format Best regardsChris 1
sooperior Posted May 14, 2016 Posted May 14, 2016 Hi, My results: http://sprunge.us/KLWN Using the image provided for this test, no modifications Hardware: Banana pi M1 Card Samsung EVO+ 32 gb U1 Quick comment: could it be possible to make a script (e.g. testsd) with the command? I think I did it the right way but there is a risk of inputting the wrong parameters Hope it helps!
tkaiser Posted May 14, 2016 Author Posted May 14, 2016 On 5/14/2016 at 9:30 AM, sooperior said: could it be possible to make a script (e.g. testsd) with the command? I think I did it the right way but there is a risk of inputting the wrong parameters Thx for the suggestion. Next time I'm rolling out such a test image I will keep that in mind. Currently you could use 'armbianmonitor -c $HOME' to do this performance test (given $HOME is located on the SD card). But since the -c switch (check) has been designed to test also the reliability of the card this check can take a long time since all available free space will be tested (by f3write/f3read). BTW: Next time we should also consider 32K test size since the many test runs showed some abnormal random write results with 16K (many many cards really suck here) and 32K is now Firefox/Midori default Sqlite page size ('browsing the web' with Firefox/Midori means constant random 32K writes and in case an SD card is used that's slow here browser processes are constantly stuck in IO) BTW: Is it just me but I'm missing your actual test results?
eternalWalker Posted May 14, 2016 Posted May 14, 2016 ... eMMC BMPi3 with sinovoip's "dietpi" Image (dietpi-preview-bpi-m3-sd-emmc.image 2016-5-14 ) root@BPiM3:~# uname -aLinux BPiM3 3.4.39-BPI-M3-Kernel #1 SMP PREEMPT Tue May 3 13:47:01 UTC 2016 armv7l GNU/Linux Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread 102400 4 3224 4963 9150 9159 8220 3634 102400 16 7474 6181 21394 21420 20109 4830 102400 512 6893 7747 55980 41569 39409 7147 102400 1024 7160 7378 41020 46033 46022 7989 102400 16384 8332 7606 61326 61396 60390 7694 ...& Flash Information: mmc1:0001 info: cid: 15010038575044335200e79f654a13ad csd: d02701320f5903fff6dbffef8e40400d rev: 7 date: 01/2000 name: 8WPD3R type: MMC preferred_erase_size: 524288 cache_ctrl: 0 cache_size: 65536 fwrev: 0x0 hwrev: 0x0 oemid: 0x0100 enhanced_area_offset: 18446744073709551594 manfid: 0x000015 serial: 0xe79f654a uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=8WPD3R MODALIAS=mmc:block erase_size: 524288 enhanced_area_size: 4294967274 root@BPiM3:~# cat /proc/sys/vm/mmap_min_addr 4096 Great from Austria @tkaiser have you the image (Semi_Armbian_5.07_M3) like minimal? Without X? Thx. (ich putze nich gerne ) Thx in advance
tkaiser Posted May 15, 2016 Author Posted May 15, 2016 On 5/14/2016 at 10:55 PM, eternalWalker said: @tkaiser have you the image (Semi_Armbian_5.07_M3) like minimal? Without X? Thx. (ich putze nich gerne ) Thx in advance Nope, but as outlined in moronic BPi forum you can combine any rootfs with SinoVoip's OS images (that's what they do all day long) so you can take any sun8i Armbian image and simply copy over the rootfs. Of course I would do it differently as outlined in H3 FAQ. Regarding your test results: It seems there's something wrong. Either with the image you used (settings matter and that's the reason I provided a dedicated Armbian test image at the top of this thread) or with the eMMC they use now. At least when I tested half a year ago sequential write speeds were 3 times higher so I think your results are somewhat questionable or would at least need further investigation.
Igor Posted June 1, 2016 Posted June 1, 2016 8G eMMC @Opi PC+ random random kB reclen write rewrite read reread read write 102400 4 6262 6629 16402 16395 13807 6452 102400 16 21461 22644 38815 38879 34878 21536 102400 512 36555 36811 65848 65820 65757 35055 102400 1024 37144 37141 70197 70151 70182 36506 102400 16384 39586 39656 78985 78983 78905 39622 102400 4 6305 6683 16485 16511 13938 6567 102400 16 21586 22801 38892 39009 35094 21554 102400 512 36563 36442 65146 65170 65086 35190 102400 1024 36874 37237 70174 70158 70121 36484 102400 16384 39602 39563 78982 78970 78993 39567 2
tkaiser Posted June 2, 2016 Author Posted June 2, 2016 Banana Pi M2+ running 3.4.112 @ 1200 MHz, 8GB eMMC: random random kB reclen write rewrite read reread read write 102400 4 5462 5780 13914 13919 11757 5667 102400 16 18099 18741 35521 35393 31657 17903 102400 32 20665 21437 45119 45499 42081 19926 102400 512 25062 24884 63142 63277 63115 24127 102400 1024 25252 25218 68877 68462 68330 24927 102400 16384 26360 26356 77756 77808 77737 26345 Orange Pi Plus 2E running 3.4.112 @ 1296 MHz, 16GB eMMC: random random kB reclen write rewrite read reread read write 102400 4 6383 6803 16713 16728 14099 6749 102400 16 22678 24012 39160 39164 35149 23221 102400 32 29243 30099 48981 49041 45747 28385 102400 512 38058 38255 63783 63322 63741 36899 102400 1024 38556 38800 69013 69222 69085 38052 102400 16384 41116 41587 78354 78300 78353 41108 Orange Pi Plus 2E running 4.6-rc1 @ 816 MHz only (no throttling yet available therefore 'play safe'), the same 16GB eMMC: random random kB reclen write rewrite read reread read write 102400 4 6501 6937 16680 16678 14042 6057 102400 16 23547 24898 41205 41240 36901 23992 102400 32 30655 31229 53485 53582 49688 29383 102400 512 40405 40571 74903 74963 74322 27747 102400 1024 40875 40914 75691 75750 75750 39958 102400 16384 40900 41017 75927 76017 76009 40880 In other words: Xunlong uses faster eMMC than 'Team BPi' and mainline kernel results look promising. It seems in our 'latest' 4.6-rc1 kernel for H3 boards we already benefit from wens' eMMC HS-DDR support. The device tree nodes for eMMC on BPi M2+ and for the eMMC equipped Oranges all look already like this: mmc2_8bit { allwinner,pins = "PC5", "PC6", "PC8", "PC9", "PC10", "PC11", "PC12", "PC13", "PC14", "PC15", "PC16"; allwinner,function = "mmc2"; allwinner,drive = <0x3>; allwinner,pull = <0x1>; linux,phandle = <0x1b>; phandle = <0x1b>; }; 1
wildcat_paris Posted June 2, 2016 Posted June 2, 2016 [Pine64] A simple SanDisk 8GB Class 10 SDHC UHS-I Class 1 random random kB reclen write rewrite read reread read write 102400 4 2010 1993 8440 8422 8422 876 102400 16 7657 7513 16585 16622 16622 47 102400 512 11608 12550 23140 23142 23108 1567 102400 1024 12146 12519 23163 23164 23166 3001 102400 16384 12079 13288 23195 23197 23194 12536 details Reveal hidden contents ubuntu@pine64:~$ cat /proc/version Linux version 3.10.101-0-pine64-longsleep (longsleep@mose2) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #39 SMP PREEMPT Sat May 7 12:39:25 CEST 2016 ubuntu@pine64:~$ iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Iozone: Performance Test of File I/O Version $Revision: 3.429 $ Compiled for 64 bit mode. Build: linux Run began: Thu Jun 2 15:40:09 2016 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random kB reclen write rewrite read reread read write 102400 4 2010 1993 8440 8422 8422 876 102400 16 7657 7513 16585 16622 16622 47 102400 512 11608 12550 23140 23142 23108 1567 102400 1024 12146 12519 23163 23164 23166 3001 102400 16384 12079 13288 23195 23197 23194 12536 mmc0:aaaa info: cid: 035344534c30384780007069ae00f38b csd: 400e00325b5900003b377f800a4040af scr: 0235800100000000 date: 03/2015 name: SL08G type: SD preferred_erase_size: 4194304 fwrev: 0x0 hwrev: 0x8 oemid: 0x5344 manfid: 0x000003 serial: 0x007069ae uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SL08G MODALIAS=mmc:block erase_size: 512 ubuntu@pine64:~$ cat /proc/sys/vm/mmap_min_addr 32768
Igor Posted June 3, 2016 Posted June 3, 2016 Samsung 128GB EVO+ @Bananapi M2+ running 3.4.112 Low performance with small files. http://sprunge.us/JhiI random random kB reclen write rewrite read reread read write 102400 4 1678 1711 3884 3861 3724 993 102400 16 2418 2826 10531 10520 9911 2087 102400 512 14170 16880 21360 21334 21319 11710 102400 1024 16402 16584 21780 21777 21765 12249 102400 16384 14908 17148 22618 22588 22584 14759 102400 4 1613 1148 3890 3883 3809 940 102400 16 4896 5697 10539 10539 9936 2818 102400 512 16313 16380 21335 21332 21332 12171 102400 1024 14629 16577 21886 21856 21845 12429 102400 16384 14910 17201 22587 22617 22604 14910 cid: 1b534d303030303010db1b022600fb73 csd: 400e00325b590003bdfd7f800a4000e5 scr: 0245800300000000 date: 11/2015 name: 00000 type: SD preferred_erase_size: 4194304 fwrev: 0x0 hwrev: 0x1 oemid: 0x534d manfid: 0x00001b serial: 0xdb1b0226 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=00000 MODALIAS=mmc:block erase_size: 512
tkaiser Posted June 15, 2016 Author Posted June 15, 2016 Interesting results from Beelink X2's internal eMMC. When I first tested I got results that look weird: Reveal hidden contents 102400 4 3588 3677 12861 12895 9533 3093 102400 16 13640 14180 28482 28303 24024 12902 102400 32 13840 14349 33000 33416 29975 13359 102400 512 23711 23808 41859 42150 41990 12637 102400 1024 4916 4741 43797 43857 43607 4610 102400 16384 4690 4685 47475 47153 47530 4614 102400 4 1934 2046 11033 10872 8618 1487 102400 16 3948 4068 26413 26461 22609 3653 102400 32 4296 4303 32090 32273 29155 4126 102400 512 4474 4781 41881 42118 41499 4367 102400 1024 4589 4767 43946 43557 43234 4522 102400 16384 4808 4875 47120 46745 46966 4897 First assumption: Overheating (Beelink X2 uses a heat pad on H3 and a large metal plate above so when the SoC shows 60°C most likely everything inside the enclosure is at 55°C). But a few tests confirmed: Nope, not temperature related but write performance drops drastically after continually writing large amounts of data (as our benchmarking does). So I tested with some time in between different runs and get somewhat decent performance numbers: for i in 4k 16k 32k 512k 1024k 16384k; do iozone -e -I -a -s 100M -r $i -i 0 -i 1 -i 2 ; sleep 300 done random random kB reclen write rewrite read reread read write 102400 4 3478 3734 13374 13292 9872 3259 102400 16 9991 10273 28856 28916 24218 9331 102400 32 13963 18092 35374 35153 31823 13414 102400 512 24717 24557 43647 43830 43396 23682 102400 1024 25057 24814 45497 45714 45499 24591 102400 16384 25597 25752 48003 48602 48390 26050 What does that mean for us: Beelink X2 as a data logger might be not the best idea but for normal use cases eMMC performance is ok. Would be great if other X2 owners would drop in their results. Both using the delayed approach as shown above as well as the usual: echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor iozone -e -I -a -s 100M -r 4k -r 16k -r 32k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
EtlARM Posted July 5, 2016 Posted July 5, 2016 End of last year I received several faked Samsung EVO 32G, therefore I bought a Samsung Pro 32G: Tested on CubieTruck, Armbian 5.11, ext4, card is used for 7 month, system is doing some minor background work. Reveal hidden contents 102400 4 1245 1925 7398 7407 7320 1655 102400 16 6232 6143 12403 12391 12315 4677 102400 512 15026 12275 17099 17070 16810 14260 102400 1024 16861 16953 17918 17926 17970 13262 102400 16384 17971 17898 19069 19093 19062 16421 102400 4 2237 2030 7413 7394 7350 1474 102400 16 6038 6645 12376 12366 12336 5146 102400 512 16292 16375 17088 17155 17070 16422 102400 1024 16529 16593 18019 17931 17931 16562 102400 16384 17500 17531 19053 19058 19059 17517 102400 4 2336 2033 7388 7404 7352 1494 102400 16 6026 6637 12408 12357 12344 5153 102400 512 16266 16369 17094 17071 17141 16410 102400 1024 16566 16647 17929 17970 17925 16656 102400 16384 17542 17564 19060 19052 19055 17610 Reveal hidden contents mmc0:0001 info: cid: 1b534d303030303010138202fc00e63f csd: 400e00325b590000ee7c7f800a4040c9 scr: 02b5800200000000 date: 06/2014 name: 00000 type: SD preferred_erase_size: 4194304 fwrev: 0x0 hwrev: 0x1 oemid: 0x534d manfid: 0x00001b serial: 0x138202fc uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=00000 MODALIAS=mmc:block erase_size: 512
tkaiser Posted July 8, 2016 Author Posted July 8, 2016 On 7/5/2016 at 7:05 PM, EtlARM said: End of last year I received several faked Samsung EVO 32G, therefore I bought a Samsung Pro 32G Well, the results aren't impressive (way slower than EVO/EVO+ and Pro we already tested) and it's somewhat useless to measure when information about the amount of background activity is not available as well as cpufreq settings. That's why I provided an own test image in the first place... to be able to compare different hardware afterwards since every test happened with identical settings. New results: neither SD card nor NAND/eMMC but an USB stick: "Samsung Memory Fit USB Flash Drive Speicherstick 128GB" bought for approx 45 bucks for a customer to double the storage capacity of his MacBook: Performance connected to the MacBook using USB 3.0 is quite ok, connected to an Orange Pi PC Plus (USB 2.0, performance cpufreq governor, ext4 without further tuning) it's not that great: random random kB reclen write rewrite read reread read write 102400 4 6719 4639 7289 7327 3325 673 102400 16 8865 10110 17630 13126 9332 1738 102400 512 15794 5296 30224 29691 20380 7460 102400 1024 17655 21927 23763 30117 29757 10017 102400 16384 29651 18520 31263 24585 31983 13342 Device info according to lsusb: Reveal hidden contents Bus 004 Device 002: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) Flash Drive Bus 004 Device 002: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) Flash Drive Couldn't open device, some information will be missing Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.10 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x090c Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) idProduct 0x1000 Flash Drive bcdDevice 11.00 iManufacturer 1 iProduct 2 iSerial 3 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 32 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 300mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 8 Mass Storage bInterfaceSubClass 6 SCSI bInterfaceProtocol 80 Bulk-Only iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x01 EP 1 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x82 EP 2 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 But since the device is really small and other USB sticks I tested recently (Kingston, Verbatim and SONY) were magnitudes slower I decided to post results here in case anyone is searching for a low power solution requiring minimum space to add 128GB to his SBC. 1
RagnerBG Posted August 11, 2016 Posted August 11, 2016 I just got this: Reveal hidden contents It's advertise as UCH-I U3, r - up to 90Mb/s, w - up to 40Mb/s. The result are a bit diferent: random random kB reclen write rewrite read reread read write 102400 4 2644 2714 8684 8683 8641 2420 102400 16 7870 8483 16670 16686 16645 6124 102400 512 19282 21706 22715 22722 22716 20974 102400 1024 22048 22177 22886 22887 22884 21872 102400 16384 22199 22247 22956 22957 22957 22235 ### mmc0:aaaa info: cid: 03534453453136478083d92bff0107b5 csd: 400e00325b59000076b27f800a404013 scr: 0235840300000000 date: 07/2016 name: SE16G type: SD preferred_erase_size: 4194304 fwrev: 0x0 hwrev: 0x8 oemid: 0x5344 manfid: 0x000003 serial: 0x83d92bff uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SE16G MODALIAS=mmc:block erase_size: 512 http://sprunge.us/VFiN This barely cover UCH-I U2 specifications, for U3 there must be at least 30Mb/s write. Can you tell me if this is some board limitation, or this sd card is not real U3?
tkaiser Posted August 11, 2016 Author Posted August 11, 2016 On 8/11/2016 at 9:30 AM, RagnerBG said: Can you tell me if this is some board limitation, or this sd card is not real U3? Board limitation. A20's SDIO implementation with mainline kernel will not exceed 23 MB/s (unfortunately true for all Allwinner based SBC currently known, maybe Olimex' upcoming A64 board will be the first exception). Random IO looks nice but compared to the best buys (currently Samsung EVO with either 32GB or 64 GB) your card is too expensive Same with Samsung Pro or Pro+ -- specs look nice since high sequential transfer rates are guaranteed. But what a surprise, we're not using digital cameras with fast host controllers but SBCs and here the host implementation limits sequential throughput anyway, random IO is way more important and the pretty cheap EVO (or EVO+) outperform all tested more expensive cards easily when it's about this
RagnerBG Posted August 11, 2016 Posted August 11, 2016 On 8/11/2016 at 10:48 AM, tkaiser said: Board limitation. A20's SDIO implementation with mainline kernel will not exceed 23 MB/s (unfortunately true for all Allwinner based SBC currently known, maybe Olimex' upcoming A64 board will be the first exception). Random IO looks nice but compared to the best buys (currently Samsung EVO with either 32GB or 64 GB) your card is too expensive That's good to know, thank you. About the price, it's cheap - 10$ from ebay, that's why i have some doubts about the origin. Unfortunately it's appears i don't have necessary hardware to test it. My 2 card readers and my phone have something like >=20Mb/s r/w limit and this test above is the best result i see so far.
tkaiser Posted August 11, 2016 Author Posted August 11, 2016 On 8/11/2016 at 5:44 PM, RagnerBG said: About the price, it's cheap - 10$ from ebay, that's why i have some doubts about the origin. Well, I bought 2 EVO 32 GB at a local store for 8€ each this week (faster card in most if not all SBCs with twice the capacity ) But back to checking cards. You should use f3 to check the whole card. Since a while Armbian supports this sort of media checking (using both f3 and iozone): cd /path/to/mountpoint armbianmonitor -c This does not work as root and it might take ages if you got a counterfeit card so better run it overnight. But it will check all available free space on the card and gives you a performance overview too.
overnight Posted October 30, 2016 Posted October 30, 2016 Sony SR-16MX2 UHS-I Class 3 16GB, 90/60MB/S r/w nominal speed. Benchmarks: Reveal hidden contents random random kB reclen write rewrite read reread read write 102400 4 1617 1834 7908 7914 7679 1274 102400 16 5968 7016 15055 15068 14863 3936 102400 512 20763 21267 22682 22683 22666 17557 102400 1024 21336 21289 22687 22686 22682 17208 102400 16384 21514 21516 22907 22907 22901 21259 random random kB reclen write rewrite read reread read write 102400 4 1690 1952 7912 7914 7696 1285 102400 16 6294 7287 15080 15084 14878 4025 102400 512 19074 21329 22663 22659 22646 17590 102400 1024 21474 21415 22750 22749 22741 17348 102400 16384 21544 21571 22940 22943 22936 21297 random random kB reclen write rewrite read reread read write 102400 4 1752 1880 7903 7903 7666 1286 102400 16 6394 7299 15087 15083 14882 3735 102400 512 19160 21389 22733 22730 22711 17642 102400 1024 21488 21434 22778 22766 22772 17048 102400 16384 21558 21564 22935 22945 22942 21283 Card info: Reveal hidden contents KERNELS:"mmc0:59b4" SUBSYSTEMS:"mmc" DRIVERS:"mmcblk" cid:"9c534f5553443030025320000d01014b" csd:"400e00325b590000787d7f800a400005" date:"01/2016" erase_size:"512" fwrev:"0x2" hwrev:"0x0" manfid:"0x00009c" name:"USD00" oemid:"0x534f" preferred_erase_size:"4194304" scr:"0235800300000000" serial:"0x5320000d" type:"SD" Tested on NanoPi Neo w/o heatsink.
Tido Posted February 10, 2017 Posted February 10, 2017 SanDisk Extreme microSDHC UHS-I 16GB - February 2015, as it has been used quite a bit, I just ran it once Lesegeschwindigkeit: bis zu 90MB/s Schreibgeschwindigkeit: bis zu 40MB/s Videogeschwindigkeit: C10, U3 Reveal hidden contents @lamobo-r1:~$ uname -a Linux lamobo-r1 4.9.6-sunxi #22 SMP Wed Feb 1 07:43:35 CET 2017 armv7l armv7l armv7l GNU/Linux @lamobo-r1:~$ iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Iozone: Performance Test of File I/O Version $Revision: 3.429 $ Compiled for 32 bit mode. Build: linux Run began: Fri Feb 10 20:12:07 2017 Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 102400 kB Record Size 4 kB Record Size 16 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size. random random bkwd record stride kB reclen write rewrite read reread read write read rewrite read 102400 4 2503 2592 8379 8372 8177 2288 102400 16 4631 4738 15818 15836 15733 4024 102400 512 18624 19743 22276 22301 22295 16012 102400 1024 20840 21011 22044 22500 22477 18762 102400 16384 20238 20983 22645 22658 22657 21026 @lamobo-r1:~$ sudo armbianmonitor -uuploaded to http://sprunge.us/SiGb
hrip6 Posted March 5, 2017 Posted March 5, 2017 This is my result: Reveal hidden contents http://sprunge.us/YgJe random random kB reclen write rewrite read reread read write 102400 4 1340 1648 5425 5423 5379 549 102400 16 4861 4007 11461 11461 11418 992 102400 512 9104 8312 17827 17781 17806 1380 102400 1024 7285 7567 18370 18439 18413 2876 102400 16384 7895 8395 19257 19292 19287 7401 Card info: Reveal hidden contents ### mmc0:aaaa info: cid: 03534453553136478020cb458600d865 csd: 400e00325b59000076b27f800a404013 scr: 0235800100000000 date: 08/2013 name: SU16G type: SD preferred_erase_size: 4194304 fwrev: 0x0 hwrev: 0x8 oemid: 0x5344 manfid: 0x000003 serial: 0x20cb4586 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SU16G MODALIAS=mmc:block erase_size: 512 armbianmonitor -u: http://sprunge.us/hUhE Too slow Micro SD Card you think :(? I'm newbie and playing with Banana Pi for a year ago but I still have some problem with it :((
lagerschaden Posted December 26, 2017 Posted December 26, 2017 a Toshiba Exceria 32GB on an OrangePi One - ARMBIAN 5.37.171221 nightly Debian GNU/Linux 8 (jessie) 3.4.113-sun8i random random kB reclen write rewrite read reread read write 102400 4 1646 1719 7660 7658 6295 167 102400 16 5743 5283 14291 14254 13093 37 102400 512 11085 10968 22590 21994 20114 1146 102400 1024 14581 14444 22596 22597 22549 2344 102400 16384 15162 13057 22762 22763 22758 12308 and the 2. run: random random kB reclen write rewrite read reread read write 102400 4 1883 1907 7834 7834 6543 184 102400 16 7406 7107 13679 14571 13393 38 102400 512 15185 15097 22614 22615 22518 1189 102400 1024 14787 17266 22630 22632 22586 2372 102400 16384 17930 15759 22750 22754 22753 10334 and the MMC-Info mmc0:1234 info: cid: 02544d5341333247252735f690011683 csd: 400e00325b590000e74f7f800a4000d5 scr: 0235840301000000 date: 06/2017 name: SA32G type: SD preferred_erase_size: 4194304 fwrev: 0x5 hwrev: 0x2 oemid: 0x544d manfid: 0x000002 serial: 0x2735f690 uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SA32G MODALIAS=mmc:block erase_size: 512
lagerschaden Posted December 27, 2017 Posted December 27, 2017 A question abaout iozone: is it possible to use another SDCard eg in an USB-reader in the USB-port ?
