u-boot-rockchip-spi.bin is a firmware. Out of pure curiosity, what is the result of 'pci enum' on the firmware console?
I could not get PCIE to work properly on BSP 6.6 on the A7S, but maybe it was my mistake. For SATA over M.2 to work (in case on m.2 SATA drives), the device need to support this electrically, which I'm not sure if A7x boards do. Sent from my SM-S931B using Tapatalk
My initial testing at the Orange Pi RV2 board detected a list of errors, missing features, driver issues and instabilities: . Not able to run Py5 3D geometry on basis of Jogl, JavaFx3D and Py5 API and packages. The error relates due to missing RISC64 architecture support in the Java APIs and will require platform adjustments for additional drivers. There is yet no GPU acceleration available for this board. Issues: . Missing Wacom tablet driver support at opening of the Ubuntu GNOME environment, the Stylus pen was not detected as pointer device. . Instability at the Firefox Web browser when opening of the start screen. . Chrome browser also shows issues with Google page display. My bypass solution is to use the startpage.com as default entry portal. . Slowness and strange blockings when switching the login to GNOME on Xorg. Xorg mode on Ubuntu. It could give support to the xinput setup commands. I appreciate some guidance how to activate those missing features at the Orange Pi RV2 board. Further test reports are welcome.
I am trying to enable the VFD display to show the current time. This board came with AiP1628 chip, will be going the posts to make it working. If you got it already working then kindly share the info. 🙂
Generic aarch64 or x86 image has all needed support for most comon virtual environments. On a side we provide cloud images, optimized to run inside KVM / QEMU virtualized environment - super lean kernel. https://armbian.com/boards/uefi-arm64 https://armbian.com/boards/uefi-x86 Look for cloud kernel images. Here it can only be a problem if host (Orangepi) supports qemu or not. I don't run it here but I think it must just work. There won't be any difference compared to standard Debian / Ubuntu. Armbian is more polished in general, comes with several important improvements. Securing support for virtual targets is relatively easy compared to any custom hardware. And this was done long time ago. We use Armbian UEFI and QCOW2 virtual images to drive our infrastructur and also automated testing, but of course we target KVM / Quemu not Virtualbox. Which anyway can run normal image. Our runners and cloud services mainly run Armbian Noble cloud. Our website (dual core x86 vps): www:/boot:% du -h vmlinuz-6.18.10-cloud-x86 15M vmlinuz-6.18.10-cloud-x86 + 17M for modules (normal image has 150-200M for modules, for things you never need in virtualized environment) Yep, that's the best path for this use case.
https://blog.aurel32.net/upstream-opensbi-spacemit-k1.html will try dev version of u-boot and openbsi
Hello, I ruun an Helios4 myself, and I've been struck by the kernel image size issue some time ago. I managed to recover using an old version, but now need to upgrade... I foolishly tried an 'apt update', which obviously end up in a non booting board. I manage to get it boot with the latest version on SD, but can not manage to make it work from SPI... Could you please explain how to get the updated u-boot loaded into SPI ? No try using nand-sata-install I've made make a difference.
Good morning. git clone https://github.com/NickAlilovic/build.git --branch v20251014 ~/build/patch-u-boot/u-boot-aw/150-1dd-x96q-lpddr3-defconfig.patch "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" ~/build/patch-u-boot/u-boot-aw/secure-boot.patch ./compile.sh choice = x96q-lpddr3 2026-04-26_0851h.txt boot sequence, shutdown -r and dmesg Thanks in advance. 2026-04-26_0851h.txt
Hi, For Tanix TX68 to get all USB ports working it was enough to toggle status = "disabled" to "okay" in transpeed-8k618 DTS. (unfortunatelly i cannot spin up an external HDD by it while having soldered 2x18650 UPS, to little amps available) Getting WiFi / BT to work on the other hand is not solved. BT: - modules loaded out of the box, no errors in dmesg after changing something in DTS but hcitool dev/scan show nothing WiFi: - modprobe: ERROR: could not insert 'aic8800_fdrv': No such device - I tried modifying parts of Transpeed DTS to align with vendor Android DTS with no result Probably same issue as on T95Z Plus: I tried its image: https://github.com/LYU4662/t95zplus-h618-build same error. I diffed android DTS between T95Z & TX68 - almost identical tp95_android.dts tx68_android.dts
Dear community, I just wanted to politely and respectfully ask whether somebody from the Orange Pi 5 or Orange Pi 5 Plus maintainer group wants to maintain the Orange Pi 5 Pro as well? It's using almost the same SoC, a Rockchip RK3588S. Right now, the device is on "community" maintenance, which is a bit sad since its brother/sister boards are on "standard". This means everyone who uses it has to use rolling release instead of being on a stable version. Being relatively close to the other two RK3588-based boards, I hope this can be done? But I don't want to sound like an ass for asking. I just wanted to use the two "Pro" I've bought for projects that need reliability, and was a bit saddened to hear they're rolling release-only. Kind regards
So out of luck, I have tried multiple fixes that I can find, tested other SD cards and still ending up with the same error. Booting: mmc 0 error: no such partition grub rescue> Will try to do some more digging and keep the post updated
0KTAV1US replied to 0KTAV1US's topic in Rockchip CPU Boxes
The microphone (on Android) does not work after installing Armbian?
Igor replied to KAHrel's topic in Orange Pi 5 Plus
When SPI is erased, the board falls back to the bootloader on the SD card. If you want to run Armbian, or Linux in general, the bootloader often needs to be updated - in this case on SPI. This can be done with armbian-install. Android support is not verified and is outside the scope of Linux maintainers. It may continue to work, or it may break. -
NAS kit w/ NEO LTS: RTC not surviving reboots
Makda Mujji replied to Makda Mujji's topic in Allwinner sunxi
Starting from Trixie, some paths have changed. Here is the complete walkthrough for the process: Install necessary tools (i2c-tools and hwclock are not present by default in Armbian trixie): sudo apt install i2c-tools util-linux-extra Edit armbianEnv.txt: sudo nano /boot/armbianEnv.txt Append i2c0 to the line that says overlays=...: overlays=... i2c0 ("..." denotes some overlays already written, do not delete them). Reboot (compulsory to load i2c module): sudo reboot now Inquire availability of module rtc-ds1307 in the kernel (present in trixie): sudo modinfo rtc-ds1307 If it returns some description, the module is present. If not, then install its driver from GitHub. Open modules file: sudo nano /etc/modules Add line rtc-ds1307 in it. Save and close. Run the following command: sudo i2cdetect -y 0 It should return 68 in the grid: 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- 68 -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- Then add module to start up: sudo modprobe rtc-ds1307 sudo echo ds1307 0x68 > /sys/class/i2c-dev/i2c-0/device/new_device The DS1307 should now be available at /dev/rtc1, which you can check: sudo ls /dev/ | grep rtc Initialize rtc1 (once) sudo hwclock --rtc /dev/rtc1 --systohc Create a new file rtc_ds1307.sh: sudo nano /usr/local/bin/rtc_ds1307.sh Add following lines in it: #!/bin/bash echo "Creating entry for rtc_1307 service" | systemd-cat -p info sudo echo ds1307 0x68 > /sys/class/i2c-dev/i2c-0/device/new_device echo "Done" | systemd-cat -p info echo "Symlinking /dev/rtc1 to /dev/rtc" | systemd-cat -p info sudo ln -f -s /dev/rtc1 /dev/rtc echo "Done" echo "Syncing RTC time to system time" | systemd-cat -p info sudo hwclock --hctosys --noadjfile --utc -f /dev/rtc1 echo "Done" Save and exit. Make this file executable: sudo chmod +x /usr/local/bin/rtc_ds1307.sh Create a systemd service to run this script at startup: sudo nano /etc/systemd/system/rtc_ds1307.service Add following lines in it: [Unit] Description=Synchronize system clock to RTC Requires=systemd-modules-load.service After=systemd-modules-load.service ConditionPathExists=/sys/class/i2c-dev [Service] Type=oneshot RemainAfterExit=yes ExecStart=/usr/local/bin/rtc_ds1307.sh [Install] WantedBy=multi-user.target Save and exit. Enable the service: sudo chmod 644 /etc/systemd/system/rtc_ds1307.service sudo systemctl enable rtc_ds1307.service Reboot and check system date time by running: timedatectl -
Is there an armbian with home-assistant installed?
So I'm fairly new to Armbian (although I have already managed to successfully create a custom build with most of what I need). Sadly, I've very much hit a blocker. I really need to use linux-tools/perf on an RK3588 board with a vendor kernel (I'm using the Mali OpenCL, and the ARM packages are mostly locked) and I need to do some performance tuning. I cannot figure out how to get these tools deployed. 1. There are no linux-tools packages build -- which is fair enough, I'm probably in a minority. Some parts of the tools directories are culled during a cleaning process for the headers, I can see that 2. I am happy to copy over the kernel source and build on the device, but this is a patched vendor kernel. Can I just rsync across `cache/sources/linux-kernel-worktree`? Is that the patched kernel source tree? 3. There are some old allusions in the forums to using armbian-config to get sources -- I'm guessing that's long deprecated 4. Would it be appropriate at some point to create a .deb for the actual kernel sources, just in case -- or even, ideally, the linux-tools packages themselves? I am very happy to invest effort into helping make this happen, but I am starting from cold into this fairly complex build infrastructure, so any help or pointers I'd be extremely grateful.
How to install Armbian on an eMMC module? Simply using Armbian Imager with the image file doesn't work—the system won't boot. The official Radxa OS boots fine from the same eMMC module.
Hello everyone, I bought an H96 Max M9 TV box. I mainly use it for YouTube and watching movies, but later I wanted to use it for gaming, including emulators and modern community-made ports. This TV box, with its 8GB of RAM, has a lot of potential, but it is being wasted due to a common issue: the file manager. The problem is not the file explorer apps you install—I’ve tried them all—but the system’s storage manager (Android’s SAF), which seems to be poorly implemented or limited by the firmware. This causes issues such as: Selecting folders in PPSSPP (memory stick) Access for emulators like Dolphin Emulator Installing game ports that should run perfectly on this TV box, but cannot be installed due to bugs in the system file manager To be honest, I’m not very knowledgeable about these topics, but if anyone has experienced this or knows a possible solution and can share the information, I would really appreciate it in advance.
Hi, trying to build custom image, from your repo. Building from branch mxq-pro couldn't get to booting from emmc, but your provided firmware does fine, what am i missing there?
USB 3.0 port does not show connected device.
jarda9 jarda9 replied to jarda9 jarda9's topic in Rockchip
As a workaround I installed Armbian_community_26.2.0-trunk.732_Orangepi3b_trixie_vendor_6.1.115_minimal .img.xz and USB is OK, anyway ethernet is functional. -
sr4armbian replied to fensoft's topic in Rockchip CPU Boxes
@fensoft I am using your current image 3.0.0_r2 in H96 Max M1 with USB Hub + USB to Ethernet adapter successfully. Its really energy efficient solution which can run 24 x 7 without costing much. However I am trying to set this up on a dq08 box with 4 GB/64 GB Model. I am able to install dq08_ha_supervised_3.0.0_r2.zip without any issue. However due to recent support changes from the application, I am unable to continue further with the setup. I tried to install docker version to set this up but getting error "invalid argument: in-kernel BTF is malformed (1 line(s) omitted)". Not seeing much on this error in the interwebs but there are suggestions that this could be due to old kernels/. Is there a way we can update this kernel and OS to Armbian Trixie or will it brick the dq08? Have you got a chance to look at the updated installer image? -
same here: RADXA 4SE
How to install correct linux-headers?
Werner replied to Stanislav Chizhik's topic in Software, Applications, Userspace
Okay so then we have some issues here This is clearly wrong since these packages come from upstream Debian and cannot/will not work with Armbian kernels. This shall be reported here: https://github.com/armbian/configng/ Then you were lucky some working headers were present https://docs.armbian.com/Developer-Guide_Build-Preparation/ Or in very short: git clone the repo ./compile.sh BOARD=rockpi-4bplus BRANCH=current kernel Check output/debs for your packages Install via dpkg -i on the target board
