  2. @Andre Ruiz I might already have those patches in my build. Try the x96q images here. Also, you should change the log level to 7 in armbianEnv.txt. https://github.com/NickAlilovic/build/releases/tag/20250306
  3. This is a wild trip. I reinstalled various versions of Armbian on the sd card, but it would not want to boot at all. I could get it installed on a USB, and boot, but then my sdcard wouldn't be accessible at the same time. I installed Opi and reflashed mtdblock0 with the latest U-Boot SPL 2025.04 (Apr 02 2024 - 10:58:58 +0000) Then I installed Armbian Bookworm 25.8.1 (6.1 kernel) on the sdcard, and it finally booted. I think I will hang out on this version for a while. Thanks again for jumping in.
  5. Hello. How can I install armbian to internal MMC storage instead of SD card? Do you have guide somewhere?
  6. Recommended. It looks like its not that far away. With rebase you will see the diff and if this is all you need to apply.
  7. Hello fellow Linux gurus, Seeking for some assistance on this. I have NIC1 on 192.168.100.1/24 network with gateway set as 192.168.100.254 < this cant be changed. with a few PC’s connected to this. And NIC2 on 10.10.10.1/24 with a few devices on this. I want to be able to ping from PC1 connected to NIC1 on 192.168.100.100/24 to devices connected to NIC2 on 10.10.10.100/24 Could someone advise on the route settings I need to configure to make this work please ?
  8. I was able to find a UART module to read out the boot. See the file attached of the full log I was able to capture. It seems to fail on this part: Starting kernel ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. done. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=0a0755af-1936-4167-9d26-9ca9a87a9103 does not exist. Dropping to a shell! U-Boot SPL 2025.10-rc3-armbian-2025.txt
  9. Modified based on nanopi-r76s.dts, both wireless and Bluetooth networks are working properly. There is no 3.5 interface fiber optic interface audio in DTS, and the standard infrared remote control cannot be used 4k hardware acceleration mpv kodi is normal Compile-configuration.zip
  10. Hi @Kelvie Wong I have a similar problem with rk3568 on 6.12.45 with HDMI: it works on some displays and not on others. Can you share how you solved the problem?
  11. @Rodrigo Campos@Nick A This guy seems to have created a u-boot that can get 4gb ram for M98-8K. https://github.com/nitrolack/M98-8K-Linux/blob/main/U-Boot Screen 20-03-2024
  12. For anyone interested in solving this temporarily, doing the following steps worked for me: sudo systemctl edit systemd-networkd ### Editing /etc/systemd/system/systemd-networkd.service.d/override.conf ### Anything between here and the comment below will become the new contents of the file [Service] ExecStartPre=/bin/sleep 5 ### Lines below this comment will be discarded sudo systemctl daemon-reexec sudo reboot
  13. Guys, please do keep us all updated on the rk3528. I was just about to buy a job lot of boards for a grid computing project when I found it's not supported yet. I found that my old TV rk32xx box was well supported, so am prepared to wait.
  14. @snow try the transpeed image https://github.com/NickAlilovic/build/releases/tag/20250306
  15. Yesterday
  16. Thanks for the reply. In the end I soved it by following also a few steps from over here. I don't know exactly what did the trick, but actually I assume it was pure coincidence: my ethernet device is actually called en0, not eth0. During my first run through this tutorial I wasn't aware of that. I think I simply forgot to change this bit in my recent try and luckily got it working that way. About the systemd-cryptsetup: I don't know if I understand correctly, but doesn't this do some of the steps automatically which we set up manually? If so, maybe it should be adopted to this tutorial in the future …
  17. There are three ways to do this. The first simplest is to assemble a binary debian package using the Armbiyan assembly system and then convert it to a rpm package directly in a running OpenSuse OS. The second way is more complicated but it is more correct. You can take patches directly from the build system and apply them to OpenSuse kernel sources in the sequence in which the build system does this while running. Next, build the kernel package using rpmbuild. The third way is the same as the second but use OBS. This will allow you to have your own repository of signed packages and install them using zypper. You can find like-minded people anywhere on our planet, including this place. Hope this helps you.
  18. Yes, cpufrequtils has been removed upstream. It's not anymore in Debian stable. https://packages.debian.org/search?searchon=names&keywords=cpufrequtils
  19. Hey, I think I'm impacted by the same issue. I've replaced the original fan of the HC4 with a Noctua NF-A4x10 5V PWM earlier this year. It was working as expected, but since couple weeks the fan is at 100% speed continuously, which is loud. It sounds like it's a software upgrade that broke the PWM control, but no idea which one. I've done part of the same testing you mentioned but didn't managed to find a fix neither. I'm probably even more beginner than you, so I don't think I can help much unfortunately. How can we get more eyes on this issue? Did you post on Odroid Forum?
  20. OK, so I installed the latest Debian/Trixie + Cinnamon + vendor kernel available and audio is working. The name of the cards and mixers are different though: speaker-test worked both by specifying the mixer (... -D plughw:CARD=rockchiphdmi0,DEV=0) or through PulseAudio's ALSA emulation after setting the default sink to the rockchiphdmi0 card. The list of audio cards is different in the vendor kernel than what's available OOB with the edge kernel, so I'm not sure if the configuration is comparable. But the audio port/cable combo seems to be fine so there's that..
  21. @Ducdanh Nguyen, can you contact seller of your tv box and ask if they can provide firmware (or "firmware update") for it?
  22. Last week
  23. https://fi.mirror.armbian.de/apt/pool/noble-utils/b/base-files/ They are in. Perhaps need some time for repo to get in sync.
  24. Addressing the need for reliable hardware testing for RISC-V adoption, the RISE Project and Collabora added two RISC-V boards to Collabora's LAVA testing lab. View the full article
  25. Building a rolling release is more than just showing that in the MOTD. If you do "sudo apt upgrade" in an OS image you just built, you probably will have zero or one packages to upgrade. If you start with an image built a long time ago, or with packages defined a long time ago, then "sudo apt upgrade" would take a long time.
  26. I have the same debian as you: 5.1.4-xxx-v4l2request, installed over Debian Bookworm, with Linux 6.15 (OS built by myself). When I tried the ffmpeg-7.x.x-v4l2request for Trixie, I could not get hardware acceleration.
