On the OrangePI-5-Plus, using an edge kernel, I've found that the desktop environment's GPU rendering works very smoothly on Wayland, in KDE 6 on Debian Trixie. It renders much more smoothly than gnome with Wayland. But I've encountered a major rendering bug. It only appears in Trixie KDE Plasma 6 with Wayland rendering. It does not appear when using x11 or when using either rendering in gnome. Nor does it appear at all in Bookworm. I have tried all kinds of things to "fix" these to no avail, including installing more wayland and mesa packages, then upgrading them to stable backports and then even to unstable testing (forky) versions. I've also tried the Debian unstable edge kernel from testing (6.16.3) as well as the Armbian stable edge kernel (6.16.4) with the same results. I installed Debian Trixie using the Debian .iso installer (w/ EFI boot), then upgraded to their edge/testing kernel (6.16.3) from their testing/forky repository. The bug showed up in pure Debian without a drop of Armbian. Then I installed the Armbian stable edge kernel (6.16.4) to replace the Debian edge/testing kernel in that installation. The bug remained. The rendering bug also showed up in the release version of Armbian Trixie 25.8.1 using the Armbian edge kernel. Wayland Render Bug Appearance #1 The major place this bug shows up is in the task switcher (using ALT-TAB). The window labels, instead of rendering as textual fonts, they render as blocks (see Screenshot #1). I tried several things with the fonts, from changing their style and size, turning on/off anti-aliasing, to changing the desktop themes, and so on. I also tried using different "task switchers" from the list. All I got were the same blocks -they just appeared in different sizes and positions with no other changes. So I'm reasonably sure the rendering issue has nothing to do with fonts, desktop themes, Plasma settings, etc. Wayland Render Bug Appearance #2 Using the command-line utility: glmark2, there's an x11 version and a Wayland version. Normally the only visual difference between them is that the Wayland version has no window borders around it. But with this bug, the Wayland version renders significantly smaller on the screen, and at a significant performance reduction. I've included two screenshots (#2 and #3) to demonstrate, both render at 800x600, but clearly appear as different sizes on the screen. The Wayland one is rendering it incorrectly. Conclusion I already know it isn't an Armbian issue. I don't believe it's a kernel issue either. I'm reasonably sure it has nothing to do with fonts, themes, or Plasma settings. In my internet searches, I have found no other reports of this specific rendering bug that I think are relevant to whatever is happening now. But did find some vague statements about there still being some "issues" with rendering in the upgrade from KDE 5 (using QT5 libraries) to KDE 6 (using QT6 libraries). I also read that KDE Plasma 6 has a someone unique interface or relationship with Wayland and uses its own protocols. I think this explains why the bug doesn't show up in gnome, and also helps to isolate, to a degree, where the bug actually is. Screenshot #1: [ALT-TAB] task-switcher Screenshot #2: glmark Screenshot #3: glmark-wayland
Hi there, To make it more clear: On PC1: [As administrator] Add a route/hop via 'rocky linux' for packets destined for 10.10.10.0/24 https://www.howtogeek.com/22/adding-a-tcpip-route-to-the-windows-routing-table/ route ADD 10.10.10.0 MASK 255.255.255.0 192.168.100.101 On 'rocky linux' Raspberry Pi: Enable IPv4 forwarding: sudo sysctl -w net.ipv4.ip_forward=1 Add masquerading for NIC2 (10.10.10.1): sudo iptables -t nat -A POSTROUTING -j MASQUERADE -o enp4s0 Or use the firewall-cmd thing, which you posted: sudo firewall-cmd --zone=public --add-masquerade Then try to ping 'device 1' from PC1 once more. The traceroute should show nexthop to be 'rocky linux' for any IP address in the range 10.10.10.0/24 if you configured the route/hop on PC1 correctly. Groetjes,
@Nick A I fixed the wifi issue after warm reboot for x98h with this patch:
Hi everyone, I need to enable the csi camera and i2c port on my zero3 development board. When I click on the management overlay, an error occurs. Is there any solution?
Dear Armbians, I'm thrilled to announce the launch of this digest for our amazing community. For newcomers, Armbian is a lightweight Linux distribution that breathes life into ARM-based single-board computers, transforming tiny, affordable boards into powerful servers, workstations, and IoT devices. This newsletter is our way of keeping you in the loop, sharing the latest releases, celebrating community contributions, and diving into the technical insights that power your projects. Whether you're a tech enthusiast or just getting started with your first Orange Pi, there's something here for you. Thanks for being part of this incredible journey! Igor Armbian project manager View the full article
1
ZeroPi booting with 25.5.0-trunk.256, but not newer images
Werner replied to TimoA's topic in Allwinner sunxi
moved -
Hi all, I’m running Armbian 24.5 (Ubuntu Jammy CLI) on an Orange Pi 3 LTS with kernel 6.6.y, trying to use a CH341A Mini Programmer to flash an SPI EEPROM chip. But I’m stuck, the programmer isn’t detecting the chip at all. Connected the module to the chip using the correct pins (CS, MOSI, MISO, CLK). Powered the chip at 3.3V to match Armbian’s logic level. Used flashrom on Armbian (via terminal) to detect the chip, but it returns “no device” or similar errors. Tried different USB ports, different cables , same result. Do I need to match some specific SPI mode or speed for Armbian or for specific EEPROMs? Is there an issue with voltage levels or pull-up / pull-down resistors that often catches beginners? Any recommended OS commands/logs to check so I can see what’s going wrong (e.g. permissions, USB detection, lsusb output)? Thanks in advance for your help!
tag adjusted
Can't say I know much about X11, but after playing around with the Cinnamon version I did get a desktop by: created file:/etc/X11/xorg.conf Section "Device" Identifier "Device0" Driver "fbdev" Option "Device" "/dev/dri/card0" EndSection So I figure something in the configuration or driver related ?. And that goes for all Debian flavors I tested. All gave the same error.
Currently yes. A replacement for this package / service needs to be found and implement - in case you want to get involved. This isn't completely true. Armbian still does utilize CPUMIN/CPUMAX from /etc/default/cpufrequtils if present to set corresponding frequencies via the Armbian script armbian-hardware-optimization (packages/bsp/common/usr/lib/armbian/armbian-hardware-optimization). This script I believe runs at every system startup. So even without the cpufrequitls package installed, there is still some functionality in this area. Functionally that no one has likely touched or looked at in years.
``` root@opi5 /etc/apt/sources.list.d# apt-get update Hit:1 http://deb.debian.org/debian trixie-backports InRelease Hit:2 http://deb.debian.org/debian trixie InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 http://security.debian.org trixie-security InRelease Hit:5 https://github.armbian.com/configng stable InRelease Hit:6 http://mirror.vinehost.net/armbian/apt trixie InRelease Reading package lists... Done W: https://github.armbian.com/configng/dists/stable/InRelease: Policy will reject signature within a year, see --audit for details N: Missing Signed-By in the sources.list(5) entry for 'http://deb.debian.org/debian' ``` ``` root@opi5 /etc/apt/sources.list.d# apt-get update --audit Hit:1 http://deb.debian.org/debian trixie-backports InRelease Hit:2 http://deb.debian.org/debian trixie InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 http://security.debian.org trixie-security InRelease Hit:5 https://github.armbian.com/configng stable InRelease Hit:6 http://mirror.vinehost.net/armbian/apt trixie InRelease Reading package lists... Done W: https://github.armbian.com/configng/dists/stable/InRelease: Policy will reject signature within a year, see --audit for details A: https://github.armbian.com/configng/dists/stable/InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on DF00FAF1C577104B50BF1D0093D6889F9F0E78D5 is not bound: No binding signature at time 2025-09-08T18:12:20Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. N: Missing Signed-By in the sources.list(5) entry for 'http://deb.debian.org/debian' ``` **/etc/apt/sources.list.d/armbian-config.sources** ``` Types: deb URIs: https://github.armbian.com/configng Suites: stable Components: main Signed-By: /usr/share/keyrings/armbian.gpg ``` **/etc/apt/sources.list.d/armbian.sources** ``` Types: deb URIs: http://apt.armbian.com/ Suites: trixie Components: main trixie-utils trixie-desktop Signed-By: /etc/apt/trusted.gpg.d/armbian.gpg ``` **/etc/apt/sources.list.d/debian-backports.sources** ``` # Modernized from /etc/apt/sources.list Types: deb URIs: http://deb.debian.org/debian/ Suites: trixie-backports Components: main contrib non-free non-free-firmware Signed-By: ``` **/etc/apt/sources.list.d/debian.sources** ``` # Modernized from /etc/apt/sources.list Types: deb URIs: http://deb.debian.org/debian/ Suites: trixie Components: main contrib non-free non-free-firmware Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg # Modernized from /etc/apt/sources.list Types: deb URIs: http://deb.debian.org/debian/ Suites: trixie-updates Components: main contrib non-free non-free-firmware Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg # Modernized from /etc/apt/sources.list Types: deb URIs: http://security.debian.org/ Suites: trixie-security Components: main contrib non-free non-free-firmware Signed-By: /usr/share/keyrings/debian-archive-keyring.gpg ``` How to fix it?
The file exists in the sd card, as expected. root@x96q-lpddr3-v1-3:~# ls -l /boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb -rw-r--r-- 1 root root 37577 Apr 2 19:41 /boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb It also exists inside the installed eMMC filesystem (after installing -- without rebooting -- I mounted the /dev/mmcblk2 device and the file is there, in the correct place). root@x96q-lpddr3-v1-3:~# mount /dev/mmcblk2p1 /srv/ root@x96q-lpddr3-v1-3:~# ls -l /srv/boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb -rw-r--r-- 1 root root 37577 Sep 10 21:16 /srv/boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb Before rebooting, I re-ran armbian-install and used option 6 to re-write boot on eMMC just in case. Then rebooted. Then it worked!! It is booting from eMMC normally now.... Boot log from successful boot: U-Boot SPL 2025.01-armbian-2025.01-S6d41-P7151-H8869-V98f7-Bb703-R448a-dirty (Apr 02 2025 - 21:19:05 -04 00) DRAM:testing 32-bit width, rank = 2 read calibration failed! testing 32-bit width, rank = 1 DRAM:Store cfg DRAM:1st writing pattern DRAM:detecting column address bits detected 10 columns DRAM:restore cfg DRAM:reconfigure for all active rows DRAM:store cfg DRAM:2nd writing pattern DRAM:detecting row address bits detected 15 rows DRAM:restoring cfg DRAM:end of auto detect dram size MBUS port 0 cfg0 0100000d cfg1 00640080 MBUS port 1 cfg0 06000009 cfg1 01000578 MBUS port 2 cfg0 0200000d cfg1 00600100 MBUS port 3 cfg0 01000009 cfg1 00500064 MBUS port 4 cfg0 20000209 cfg1 1388157c MBUS port 5 cfg0 00640209 cfg1 00200040 MBUS port 6 cfg0 00640209 cfg1 00200040 MBUS port 8 cfg0 01000009 cfg1 00400080 MBUS port 11 cfg0 01000009 cfg1 00640080 MBUS port 14 cfg0 04000009 cfg1 00400100 MBUS port 16 cfg0 2000060d cfg1 09600af0 MBUS port 21 cfg0 0800060d cfg1 02000300 MBUS port 22 cfg0 01000009 cfg1 00640080 MBUS port 25 cfg0 0064000f cfg1 00200040 MBUS port 26 cfg0 20000209 cfg1 1388157c MBUS port 37 cfg0 01000009 cfg1 00400080 MBUS port 38 cfg0 00640209 cfg1 00200040 MBUS port 39 cfg0 20000209 cfg1 1388157c MBUS port 40 cfg0 00640209 cfg1 00200040 1024 MiB Trying to boot from MMC2 NOTICE: BL31: v2.10.14(debug):armbian NOTICE: BL31: Built : 18:07:43, Apr 2 2025 NOTICE: BL31: Detected Allwinner H616 SoC (1823) NOTICE: BL31: Found U-Boot DTB at 0x4a0b2520, model: hechuang,x96-q LPDDR3 v1.3 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller INFO: PMIC: Probing AXP305 on RSB ERROR: RSB: set run-time address: 0x10003 INFO: Could not init RSB: -65539 INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for erratum 855873 was applied INFO: BL31: cortex_a53: CPU workaround for erratum 1530924 was applied INFO: PSCI: Suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 INFO: Changed devicetree. ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2025.01-armbian-2025.01-S6d41-P7151-H8869-V98f7-Bb703-R448a-dirty (Apr 02 2025 - 21:19:05 -0400) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: hechuang,x96-q LPDDR3 v1.3 DRAM: 1 GiB Core: 59 devices, 20 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4021000: 3, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 No USB device found Net: apply fix for AC300 ephy bb version bug ... using AC300 emac1 ephy default config ... eth0: ethernet@5030000 starting USB... No USB controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 4641 bytes read in 1 ms (4.4 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 252 bytes read in 0 ms Load fdt: /boot/dtb/allwinner/sun50i-h313-x96-q-lpddr3.dtb Card did not respond to voltage select! : -110 ** Bad device specification mmc 0 ** 37577 bytes read in 3 ms (11.9 MiB/s) Working FDT set to 4fa00000 Failed to load '/boot/dtb/allwinner/overlay/sun50i-h616-fixup.scr' 15483712 bytes read in 492 ms (30 MiB/s) 42621440 bytes read in 1351 ms (30.1 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=0x42b50000 ## Loading init Ramdisk from Legacy Image at 4ff00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 15483648 Bytes = 14.8 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Working FDT set to 4fa00000 Loading Ramdisk to 4913b000, end 49fff300 ... OK Loading Device Tree to 00000000490c9000, end 000000004913afff ... OK Working FDT set to 490c9000 Starting kernel ...
I looked at this for an hour and unfortunately can't figure it out. It seems that Olimex didn't 'fork' from Armbian, instead did something else to make their clone of your code.
Hi, I'm still having this issue after installing qemu-emulators-full and qemu-user-static on the host (arch) does anyone have any idea or workaround ?
I'm thinking of getting https://www.beagleboard.org/boards/beagley-ai I see there is this page for it https://www.armbian.com/beagley-ai/ I also see references to it in the code: https://github.com/search?q=org%3Aarmbian+beagley&type=code Are there any pre-built images available for it? Or would I have to build one?
my uboot was armbian 2025.1, so I have no idea why it wasn't working with even Armbian mainline trixie.
The easiest route is to simply flash it to a microsd card and boot from it. Once booted issue "armbian-install" to move the OS and boot loader to eMMC. eMMC should be accessible directly if tools like rkdeveltool or whatever that is called is used. Never used that personally, seems tricky to use. Prefer first path.
I was able to find a UART module to read out the boot. See the file attached of the full log I was able to capture. It seems to fail on this part: Starting kernel ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. done. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=0a0755af-1936-4167-9d26-9ca9a87a9103 does not exist. Dropping to a shell! U-Boot SPL 2025.10-rc3-armbian-2025.txt
Modified based on nanopi-r76s.dts, both wireless and Bluetooth networks are working properly. There is no 3.5 interface fiber optic interface audio in DTS, and the standard infrared remote control cannot be used 4k hardware acceleration mpv kodi is normal Compile-configuration.zip -
Terrific! You're welcome!
For anyone interested in solving this temporarily, doing the following steps worked for me: sudo systemctl edit systemd-networkd ### Editing /etc/systemd/system/systemd-networkd.service.d/override.conf ### Anything between here and the comment below will become the new contents of the file [Service] ExecStartPre=/bin/sleep 5 ### Lines below this comment will be discarded sudo systemctl daemon-reexec sudo reboot
