  1. Yesterday
  2. At Radxa's suggestion I grabbed their latest image `rock-5t_bookworm_kde_r5.output_512.img` which contains `DDR b8ce94f14b cym 25/09/26-15:48.05,fwver: v1.20` and `stress-ng` now passes without any errors.
  3. Does the box have an sd card slot and have you tried booting from that? (That is the common method). Also are you sure the box has an s905x3? Have you opened the box and inspected the chip? You might want to try all the uboot binaries just in case.
  4. Ubuntu 26.04 with or without KDE Plasma with working drivers for WiFi, GPU, Nic, Bluetooth. Enjoy! https://github.com/mack42/OrangePi5Pro Note: There are Minimal and Graphical images available. It also supports installing to the NVME.
  5. Thank you very much for your responses, it totally make sense. I will try to build it myself, tho I have never done that, and my knowledge is very limited. I'd love to help one day, but this really is beyond what I can offer, for now.
  6. Well if you want to live on the edge, then use code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } egde as branch instead of code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } current
  7. I have also encountered this using Orange pi 5 and latest Armbian updated as of today. That the "standing" USB port does not work also means that the USB-C port doesn't work -- they are electrically connected. So Mitu's question is also mine: Is this a limitation of the mainstream kernel (6.18.x) - i.e. does this work only with the vendor kernel (6.1.x)? EDIT: typo
  8. Update: sicXnull/armbian-build (H96q) + "+CONFIG_SPL_IMAGE_TYPE_SUNXI_TOC0=y" and "secure-boot.patch" solved the problem. Now, the ethernet interface is fully functional. Thank you Nick & sicXnull.
  9. Last week
  10. I downloaded the image. And yes, of course, I needed to set up the wifi connection when armbian asked me to.
  11. Has anyone found a working gpiolib implementation for Armbian on Orange Pi 5? I'm aware of wiringPi and it sort of works. However, being able to use the "real stuff" so to speak would make my life easier.
  12. Hi @falbriard, I don't know where your image is from and to what RISC-V build of Chrome browser you are referring. Anyhow, you are free to test my latest image build from current main commit 3ce7dec74. Go to https://privat-in.de/ follow Downloads and flash Armbian-unofficial_26.05.0-trunk_Orangepirv2_trixie_current_6.18.26_minimal.img from there. You will find a script in /root which installs Gnome with GPU and Chromium. Any GPU stuff is from a mirror of the Bianbu Linux (Chinese Ubuntu variant from SpacemiT). Be warned: You may get a kernel downgrade if you install current Armbian upgrades. The image comes with 6.18.26-current-spacemit (from main) but Armbian repos may deliver 6.6 until that main-current-6.18 makes it to the update repos. HTH // Sven-Ola
  13. Okay slight update, I have successfully booted https://forum.armbian.com/topic/56130-radxa-cubie-a7aa7z-allwinner-a733 linux 6.6.98-vendor-sun60iw2 kernel and debootstrapped Bookworm (Debian 12) on it using userdata as root fs. Basically I got in using: aliexpress.com/item/1005009243708714.html Micro SD Sniffer aliexpress.com/item/1005010529282186.html in 1.8v mode(important!) And fiddling with the u-boot endlessly after i first sabotaged the auto-boot process. Display is alive, usb subsystem does not work, does not probe. Wifi would be next so I can ditch the tf uart. All your bases belong to us, resistance is futile!
  14. Collabora brought Bluetooth Auracast broadcasting to MediaTek Genio 700 for Embedded World 2026. Here's the complete, fully Open Source setup featuring Debian, BlueZ, PipeWire, with all the code and configs from our live booth demo. View the full article
  15. I am not using WOL on any of my devices, I have no personal experience with the software on the Helios or any other platform.
  16. Hi @Ross Cawston I've been using your patch for a few months on Orange Pi 5 Plus/Max SBCs with Linux kernels from 6.19 to 7.0.3 and it works well encoding H.264 streams (didn't try H.265, though) Thank you for your contribution. There's still no support for `rkvenc` in edge kernels (as of 7.1rc2).
  17. This week's work centers on release pipeline modernization, desktop and userland refinements, and board and kernel platform maintenance. On the release and CI side, the build matrix gained codename parameterisation with Ubuntu 26.04 "resolute" set as default, a dedicated Bianbu target, and exposed map overrides, while standard-support targets now include UEFI desktops and a plain cloud variant. The KDE fast-HDMI matrix was switched from kde-neon to kde-plasma, mesa-vpu was dropped from auto-attached extensions, and external CI now skips slots with a warning when upstream sources break. Supporting fixes route forky/loong64 base-files lookups to the main archive and add AI cover image generation to the blog workflow. Desktop and userland changes focus on the Bianbu environment, where PVR DRI was enabled, detection corrected, menu entries added, systemd suspend re-enabled on K1, and gnome-initial-setup purged post-install. Broader fixes pass --allow-downgrades on pinned package installs, align LAN/WAN labels across IPv4 and IPv6 rows in the MOTD, harden console-width handling against invalid COLUMNS values, and correct output to /etc/armbian-image-release. Platform support sees explicit ARCH=arm64 declarations on five inheriting boards, validate-board-config now following inheritance from ${SRC}/config/boards, and targeted fixes for imx8m binman hooks and rockchip family tweaks under forky (addgroup → groupadd). Kernel and DTS work restores 6.18.y on sm8550, syncs CAINIAO CNIoT-CORE DTS from 6.18 to 6.12, disables broken drm/xe patches under uefi-loong64-7.0, and improves the SMART AM40 and Retroid Pocket board definitions. AX210 firmware lands for mainline, and Seeed Studio reComputer images join the catalogue. #Armbian #EmbeddedLinux #ARM64 #Rockchip #Ubuntu #KDE #Mainline ChangesAdd AX210 firmware for mainline kernel. by @ginkage in armbian/firmware#126Add Seeed Studio reComputer board images and vendor logo. by @baorepo in armbian/armbian.github.io#297boards: declare ARCH=arm64 explicitly on five inheriting boards. by @igorpecovnik in armbian/build#9747ci/external: skip slot with warning when upstream source breaks. by @igorpecovnik in armbian/armbian.github.io#301ci/maintenance-unit-tests: list docker state on the runner. by @igorpecovnik in armbian/configng#903desktops/bianbu: enable PVR DRI, fix detection, add menu entries. by @igorpecovnik in armbian/configng#897desktops/bianbu: purge gnome-initial-setup after install. by @igorpecovnik in armbian/configng#902desktops/bianbu: re-enable systemd suspend on K1. by @igorpecovnik in armbian/configng#900desktops: pass --allow-downgrades on pinned package install. by @igorpecovnik in armbian/configng#899DTS: Sync CAINIAO CNIoT-CORE from 6.18 to 6.12. by @retro98boy in armbian/build#9736Fix workflow bugs and add AI cover image generation. by @igorpecovnik in armbian/armbian.github.io#298fix: rename imx8m bare hook so binman pkg_resources patch can run. by @igorpecovnik in armbian/build#9752fix: rockchip family_tweaks fails on forky — addgroup → groupadd. by @igorpecovnik in armbian/build#9753fix: route forky/loong64 base-files lookups to the main archive. by @igorpecovnik in armbian/armbian.github.io#299fixing output to /etc/armbian-image-release. by @dittodhole in armbian/build#9729Handle invalid data in COLUMNS env var when determining console width. by @scollinson in armbian/build#9631kernel: add linux-initramfs-tool as dep of linux-image package. by @amazingfate in armbian/build#9731motd/20-ip-info: align (LAN)/(WAN) labels across IPv4 + IPv6 rows. by @igorpecovnik in armbian/build#9728os-info: add Ubuntu 26.04 (resolute). by @igorpecovnik in armbian/imager#134patch: disable broken drm/xe patches under uefi-loong64-7.0. by @igorpecovnik in armbian/build#9745release-targets/standard-support.manual: add UEFI desktops + plain cloud. by @igorpecovnik in armbian/armbian.github.io#304release-targets: codename parameterisation, resolute default, Bianbu target, exposed.map overrides. by @igorpecovnik in armbian/armbian.github.io#295release-targets: drop mesa-vpu from auto-attached extensions. by @igorpecovnik in armbian/armbian.github.io#302release-targets: switch fast-HDMI KDE matrix from kde-neon to kde-plasma. by @igorpecovnik in armbian/armbian.github.io#303Retroidpocket: fix current and add edge as target. by @EvilOlaf in armbian/build#9724sm8550: Restore kernel 6.18.y for current and edge branch. by @kasimling in armbian/build#9737SMART AM40 improve. by @retro98boy in armbian/build#9735userpatches: skip jammy in items-from-inventory. by @igorpecovnik in armbian/os#460validate-board-config: follow source ${SRC}/config/boards inheritance. by @igorpecovnik in armbian/build#9748View the full article
  18. This week's work centers on release pipeline modernization, desktop and userland refinements, and board and kernel platform maintenance. On the release and CI side, the build matrix gained codename parameterisation with Ubuntu 26.04 "resolute" set as default, a dedicated Bianbu target, and exposed map overrides, while standard-support targets now include UEFI desktops and a plain cloud variant. The KDE fast-HDMI matrix was switched from kde-neon to kde-plasma, mesa-vpu was dropped from auto-attached extensions, and external CI now skips slots with a warning when upstream sources break. Supporting fixes route forky/loong64 base-files lookups to the main archive and add AI cover image generation to the blog workflow. Desktop and userland changes focus on the Bianbu environment, where PVR DRI was enabled, detection corrected, menu entries added, systemd suspend re-enabled on K1, and gnome-initial-setup purged post-install. Broader fixes pass --allow-downgrades on pinned package installs, align LAN/WAN labels across IPv4 and IPv6 rows in the MOTD, harden console-width handling against invalid COLUMNS values, and correct output to /etc/armbian-image-release. Platform support sees explicit ARCH=arm64 declarations on five inheriting boards, validate-board-config now following inheritance from ${SRC}/config/boards, and targeted fixes for imx8m binman hooks and rockchip family tweaks under forky (addgroup → groupadd). Kernel and DTS work restores 6.18.y on sm8550, syncs CAINIAO CNIoT-CORE DTS from 6.18 to 6.12, disables broken drm/xe patches under uefi-loong64-7.0, and improves the SMART AM40 and Retroid Pocket board definitions. AX210 firmware lands for mainline, and Seeed Studio reComputer images join the catalogue. #Armbian #EmbeddedLinux #ARM64 #Rockchip #Ubuntu #KDE #Mainline ChangesAdd AX210 firmware for mainline kernel. by @ginkage in armbian/firmware#126Add Seeed Studio reComputer board images and vendor logo. by @baorepo in armbian/armbian.github.io#297boards: declare ARCH=arm64 explicitly on five inheriting boards. by @igorpecovnik in armbian/build#9747ci/external: skip slot with warning when upstream source breaks. by @igorpecovnik in armbian/armbian.github.io#301ci/maintenance-unit-tests: list docker state on the runner. by @igorpecovnik in armbian/configng#903desktops/bianbu: enable PVR DRI, fix detection, add menu entries. by @igorpecovnik in armbian/configng#897desktops/bianbu: purge gnome-initial-setup after install. by @igorpecovnik in armbian/configng#902desktops/bianbu: re-enable systemd suspend on K1. by @igorpecovnik in armbian/configng#900desktops: pass --allow-downgrades on pinned package install. by @igorpecovnik in armbian/configng#899DTS: Sync CAINIAO CNIoT-CORE from 6.18 to 6.12. by @retro98boy in armbian/build#9736Fix workflow bugs and add AI cover image generation. by @igorpecovnik in armbian/armbian.github.io#298fix: rename imx8m bare hook so binman pkg_resources patch can run. by @igorpecovnik in armbian/build#9752fix: rockchip family_tweaks fails on forky — addgroup → groupadd. by @igorpecovnik in armbian/build#9753fix: route forky/loong64 base-files lookups to the main archive. by @igorpecovnik in armbian/armbian.github.io#299fixing output to /etc/armbian-image-release. by @dittodhole in armbian/build#9729Handle invalid data in COLUMNS env var when determining console width. by @scollinson in armbian/build#9631kernel: add linux-initramfs-tool as dep of linux-image package. by @amazingfate in armbian/build#9731motd/20-ip-info: align (LAN)/(WAN) labels across IPv4 + IPv6 rows. by @igorpecovnik in armbian/build#9728os-info: add Ubuntu 26.04 (resolute). by @igorpecovnik in armbian/imager#134patch: disable broken drm/xe patches under uefi-loong64-7.0. by @igorpecovnik in armbian/build#9745release-targets/standard-support.manual: add UEFI desktops + plain cloud. by @igorpecovnik in armbian/armbian.github.io#304release-targets: codename parameterisation, resolute default, Bianbu target, exposed.map overrides. by @igorpecovnik in armbian/armbian.github.io#295release-targets: drop mesa-vpu from auto-attached extensions. by @igorpecovnik in armbian/armbian.github.io#302release-targets: switch fast-HDMI KDE matrix from kde-neon to kde-plasma. by @igorpecovnik in armbian/armbian.github.io#303Retroidpocket: fix current and add edge as target. by @EvilOlaf in armbian/build#9724sm8550: Restore kernel 6.18.y for current and edge branch. by @kasimling in armbian/build#9737SMART AM40 improve. by @retro98boy in armbian/build#9735userpatches: skip jammy in items-from-inventory. by @igorpecovnik in armbian/os#460validate-board-config: follow source ${SRC}/config/boards inheritance. by @igorpecovnik in armbian/build#9748View the full article
  19. You aren't telling us much, like what software you are using. I would expect you to need to give it something like smb://10.10.2.101/NAME_OF_SHARE/ or sftp://10.10.2.101:/path/to/folder You will also need to give it a username and password somehow. But first; have you checked you can reach it on the network?
  20. On my Debian13 VM that I use to build images for my boards, I have started to notice new errors that I have not seen before after this part of the logs... [🐳|🌱] After updating and cleaning image apt list cache [ 30 files ] [🐳|🌱] Image installed package hash [ ✅ base-files = 1-trixie-1armbian1-Bb095-U13.8--deb13u4-R55fa ] [🐳|🌱] Image installed package hash [ ✅ linux-image-current-rockchip64 = 6.18.26-S1fe0-Dedd0-P1f35-Cc077-H8200-HK01ba-Vc222-Bed86-R448a ] [🐳|🌱] Image installed package hash [ ✅ armbian-firmware = 1-SAa38b-B96c8-R448a ] [🐳|🌱] Image installed package hash [ ✅ armbian-bsp-cli-rockpro64-current = 1-PC1e15-V9ab0-H3400-Bd2e9-Rf36a ] [🐳|🌱] Image installed package hash [ ✅ linux-u-boot-rockpro64-current = 2025.01-S6d41-P6e2c-Hbf76-V6f3c-Be4e9-R448a ] [🐳|🌱] Image installed package hash [ ✅ linux-dtb-current-rockchip64 = 6.18.26-S1fe0-Dedd0-P1f35-Cc077-H8200-HK01ba-Vc222-Bed86-R448a ] [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/etc/resolv.conf' [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sbin/initctl' [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sbin/start-stop-daemon' [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/usr/sbin/policy-rc.d' [🐳|🌱] Removing qemu-user-static binary from chroot [ qemu-aarch64-static during image ] [🐳|🔨] removed '/armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/usr/bin/qemu-aarch64-static' [🐳|🌱] Unmounting [ /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210 ] Once the unmounting of rootfs-nouuidgen-yet begins I notice the following errors spam in the logs, 1000+ lines, and finally the target unmounts successfully and the image finishes building. The images still boot fine. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev: target is busy. [🐳|🔨] tmpfs /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev tmpfs rw,nosuid,size=65536k,mode=755,inode64 0 0 umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev/pts: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/dev: target is busy. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/proc: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/sys: not mounted umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/tmp: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/var/tmp: not mounted. umount: /armbian/.tmp/rootfs-no-uuidgen-yet-15898-49210/run/user/0: not mounted. Is there a way to adjust some kind of timeout for this to prevent the massive amount of "target is busy" outputs in the logs? Thank you for any help or insights!
  21. I don't own that box so I can only give you generic help. You really would need to hook up a usb-uart adapter to access the uboot debug output to see what is happening. The second thing I would say is that I have no idea what ophub builds do as they are not Armbian builds, ophub is a fork, they don't contribute to Armbian development nor do they participate in these forums. So per the Armbian amlogic TV box instructions, the boot environment must be a clean android boot environment. Installing or running any other distribution may cause Armbian to not boot. So I'd recommend either reinstalling a clean Android image to test from, or investigate any differences in boot scripts to see what might be going on. But again getting access to the new boot serial console would help a lot.
  22. Hi Everyone! I'm trying to install it on a TV Box with an Allwinner IK316 SOC and a NANYA 1303 eMMC, but Armbian can't find the eMMC at all... has anyone found a solution for this NAND?
  23. Has anyone installed Waydroid on Armbian 26.2.4? Are there any manual for this?
  24. Back to the "drawing board" in the search for a solution. 🤔
  25. You need to provide more informations. I wasn't able to repreoduce. I works here.
  26. What you’re seeing is open-source maintenance in practice. It’s not centrally orchestrated. We only manage to do this for some key features while DVB support is present in some kernels, but it’s not guaranteed to be consistently enabled across all targets unless someone explicitly maintains this functionality. -> https://github.com/armbian/build/pulls
