Great news and thank you for reporting back. Do you have any idea what they changed or where they host their sources so we can have a look? There is for example this. There is another user who reported running into problems that sounded a lot like yours. -
fixed
@Igor Armbian_25.5.1_Orangepizero3_bookworm_current_6.12.23_mi nimal.img.xz below is transcript from the 'debug uart (serial)' console, via a usb-uart dongle, it is the only way to boot up with a console , if network etc is not available. U-Boot 2024.01-armbian-2024.01-S866c-P4a40-H8869-V3d5b-Bb703-R448a (May 28 2025 - 02:53:19 +0000) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: OrangePi Zero3 DRAM: 1.5 GiB Core: 57 devices, 25 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0 Loading Environment from FAT... Unable to use mmc 0:1... .... _ _ _ /_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.5.1 for Orange Pi Zero3 running Armbian Linux 6.12.23-current-sunxi64 Packages: Debian stable (bookworm) Updates: Kernel upgrade enabled and 23 packages available for upgrade Support: DIY (community maintained) IPv4: (LAN) 192.168.xxx.xxx (WAN) xxx.xxx.xxx.xxx IPv6: fd00:aa00:1:1:xxxxx, xxxxx (WAN) xxxx Performance: Load: 18% Up time: 2 min Memory usage: 9% of 1.44G CPU temp: 50°C Usage of /: 9% of 15G Commands: Configuration : armbian-config Upgrade : armbian-upgrade Monitoring : htop root@orangepizero3:~# ping google.com PING google.com (142.250.4.138) 56(84) bytes of data. 64 bytes from sm-in-f138.1e100.net (142.250.4.138): icmp_seq=1 ttl=100 time=2.77 ms 64 bytes from sm-in-f138.1e100.net (142.250.4.138): icmp_seq=2 ttl=100 time=2.79 ms ^ ethernet works root@orangepizero3:~# ip link set wlan0 up root@orangepizero3:~# iw dev wlan0 scan BSS xxxxx freq: 24xx signal: -77 dBm ^ wifi works, at least for scanning for stations, connect and AP not yet tested ^ the above is booted up on a 'rare' 1.5GB board. I'm not too sure what is the difference between v25.5.1 vs that on the boards page? https://www.armbian.com/orange-pi-zero-3/ from those links 'current' seemed to be linked to: as of current 28 May 2025 Armbian_community_25.8.0-trunk.8_Orangepizero3_bookworm_current_6.12.23_minimal.img.xz @TRay It is a good idea to try U-Boot v2025.04 I've got a python script which can patch u-boot binary into an Armbian .img or practically any other image file (though i've only tested this in *unofficial* armbian builds) https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3/tree/main/tools https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3 i created it back then while researching solutions for the '1.5GB' problem back then. Do you have the 'bin' file for u-boot that you could share say in a zip file attached here? you can extract that 'bin' file using the 'backup' procedure documented here: https://github.com/ag88/1.5GB_Fix_for_Armbian_on_OrangePiZero3?tab=readme-ov-file#how-to-use sudo dd if=/dev/sdX of=u-boot-backup.bin bs=1024 skip=8 count=1024 But that the appropriate way would be to build the full armbian image from source including u-boot etc. Nevertheless, having the 'patched' u-boot binary would enable most here to test that by patching a distributed image file e.g. from the boards page, or from the 'test images' link as Igor has provided.
How to enable sound on a server version of Armbian
Hooutoo replied to ubhelbr's topic in Orange Pi 5 Plus
Looks like most of the mainline issues will be resolved with the release of Kernel 6.16 rc1 which will hopefully be in the nest couple of weeks. I'm running Fedora rawhide with 6.15 rc7 and the only thing I'm missing is analog sound which collabora says should be in 6.16 rc1. I have dual monitors, sound over hdmi so the last biggy for me is analog sound. The reason I'm running Fedora is theses guys are pretty guick to release the latest mainline kernel. -
Pusillus replied to Igor's topic in Software, Applications, Userspace
Thanks Igor for your work! -
looks like a really cool machine. unfortunately, no maintainer in armbian and I am not aware if any of the regular developpers has that SBC. It seems to be based on the H618 which it shares with the Orange Pi Zero3 which is reported working with the latest Armbian release. Did this board ever work with an older release? Is this a regression? I see somebody else mentioning they have issues with the board booting, , apparently due to issues with thermal management. And your crash apparently started in pstate.
The network card cannot be recognized on armsom
laibsch replied to chauncy's topic in Software, Applications, Userspace
Nice. To help other users of the forum, it would be good if you shared what fixed the issue. -
To be honest, I'm confused. You reference three different systems and it is unclear to me which one it is that FTBFS for you. Let's take a step back. Do you have the latest git tree of armbian/build? Do you have any local changes? What is the exact command you for compile.sh? I will try to reproduce the problem here.
Sparking between the wires on the poles produces high-frequency pulses of high power and transmits them through the wires to consumers of electricity. Household consumers such as a TV, vacuum cleaner, refrigerator do not have a built-in high-frequency protection filter and very often fail. As for the orange, it is not protected at all. My orange was just lying on the table and was connected by an Ethernet cable to the router. Both were not power up. Lightning struck a nearby building. The Ethernet cable caught an electromagnetic pulse. The orange burned down completely and the router has only 1 port damaged. You can draw your own conclusions.
EDID read issue on kernel 6.12 - missing 1280x800 mode (CB2)
anarsoul replied to mecho's topic in BIGTREETECH CB2
This mode needs 80MHz pixel clock which is not in the table for clk-rk3568.c driver. You need a patch similar to https://lkml.org/lkml/2025/3/18/1337 to add this rate. FWIW 1280x800@63.59Hz isn't a very common mode - Yesterday
@jwillb00In this patch. Try changing 16 to 0. In both locations. Maybe I uploaded the image with these changes. https://github.com/NickAlilovic/build/blob/v20250306/patch/u-boot/u-boot-h616/153-add-tanix_tx6s_axp313_defconfig.patch +&mdio1 { + rmii_phy: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; +}; +
paradigman replied to jock's topic in Rockchip CPU Boxes
I would like to use my device as a VPN client, i.e. connect to a remote OpenVPN server. How can I enable the Tun/Tap module on my board? -
Buying advice: H96 Max V56 or X88 Pro 20?
caminati replied to caminati's topic in Rockchip CPU Boxes
Thanks both! -
Hi We all started at some point. But overall prepare for some frustration We don't support this device. Support was added via community effort. May work, maybe not. We don't know nor do we track status of such configurations. Regarding OPi5+. It is using - in terms of ARM socs - a fairly recent SoC, the Rockchip RK3588. Mainline support is far from feature-complete. Will take a few additional years to complete. If you need an almost feature-complete kernel, you have to use vendor branch which is based on Rockchip BSP. current (Linux 6.12.y LTS at this time) has basic support for rk3588 and is good enough for general server application, though for your usecase might not be enough. This branch will receive fixes only but no new features. edge may be sufficient. When using some graphics related I suggest to use an image with mesa-vpu extension included. Also there a two ways to make use of it: - We backported the open source Panthor driver into vendor. Can be enabled via device tree overlay (check code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } armbian-config) - Using proprietary mali blobs is also possible. I think Jellyfin has a tutorial how to setup those: https://jellyfin.org/docs/general/post-install/transcoding/hardware-acceleration/rockchip/
Armbian on Box K12 Bqeel / Mini M8S pro C (S912)
lucash78 replied to RuDy_74's topic in Amlogic CPU Boxes
I've extracted dtbs from my rooted device bqeel K12, could it be useful share them? @RuDy_74 I've used "Magicsee C400 Plus" dtb (I don't remember the exact name) and I got also wifi and bluetooth working. The only issue is ethernet working at 100Mbit instead of 1Gbit -
Still the same with armbian 25.2.3 kernel: 6.12.22-current-rockchip64 #1 SMP PREEMPT Mon Apr 7 08:08:37 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux u-boot-version: # cat /dev/mtd/by-name/U-Boot | strings | grep -B1 "u-boot,version" 2025.01-armbian-2025.01-S6d41-P41ad-H4cab-V390e-Bb703-R448a u-boot,version WARNING: could not set u-boot,version %s. # iperf3 -R -c odroidm1 Connecting to host odroidm1, port 5201 Reverse mode, remote host odroidm1 is sending [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 79.2 KBytes 649 Kbits/sec [ 5] 1.00-2.00 sec 84.8 KBytes 695 Kbits/sec [ 5] 2.00-3.00 sec 206 KBytes 1.69 Mbits/sec [ 5] 3.00-4.00 sec 228 KBytes 1.87 Mbits/sec [ 5] 4.00-5.00 sec 115 KBytes 938 Kbits/sec [ 5] 5.00-6.00 sec 181 KBytes 1.48 Mbits/sec [ 5] 6.00-7.00 sec 163 KBytes 1.33 Mbits/sec ^C[ 5] 7.00-7.36 sec 9.90 KBytes 226 Kbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-7.36 sec 0.00 Bytes 0.00 bits/sec sender [ 5] 0.00-7.36 sec 1.04 MBytes 1.19 Mbits/sec receiver when changing u-boot back to older u-boot (same kernel), it works as expected # cat /dev/mtd/by-name/U-Boot | strings | grep -B1 "u-boot,version" 2023.04-00035-g7dd5eb0228 u-boot,version WARNING: could not set u-boot,version %s. # iperf3 -R -c odroidm1 Connecting to host odrdoidm1, port 5201 Reverse mode, remote host odroidm1 is sending [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 110 MBytes 921 Mbits/sec [ 5] 1.00-2.00 sec 110 MBytes 926 Mbits/sec [ 5] 2.00-3.00 sec 110 MBytes 926 Mbits/sec [ 5] 3.00-4.00 sec 110 MBytes 921 Mbits/sec [ 5] 4.00-5.00 sec 111 MBytes 929 Mbits/sec [ 5] 5.00-6.00 sec 111 MBytes 927 Mbits/sec [ 5] 6.00-7.00 sec 110 MBytes 919 Mbits/sec ^C[ 5] 7.00-7.79 sec 87.0 MBytes 925 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-7.79 sec 0.00 Bytes 0.00 bits/sec sender [ 5] 0.00-7.79 sec 858 MBytes 924 Mbits/sec receiver iperf3: interrupt - the client has terminated ethtool output: ~# ethtool end0 Settings for end0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supported pause frame use: Symmetric Receive-only Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: Symmetric Receive-only Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Link partner advertised pause frame use: No Link partner advertised auto-negotiation: Yes Link partner advertised FEC modes: Not reported Speed: 1000Mb/s Duplex: Full Auto-negotiation: on master-slave cfg: preferred slave master-slave status: slave Port: Twisted Pair PHYAD: 0 Transceiver: external MDI-X: Unknown Supports Wake-on: ug Wake-on: d Current message level: 0x0000003f (63) drv probe link timer ifdown ifup Link detected: yes
I upgraded my ROCK5B in-place from Armbian Bookworm beta to Armbian Testing/Trixie beta and it turns out that no Ambian packages are seen (so not updated). The Debian Trixie packages do upgrade, as for example I just saw while doing full-upgrade: libavif16:arm64 (1.2.1-1.2) over (1.2.1-1.1) ... I thought something with my install, but also downloaded 'Armbian_25.8.0-trunk.50_Rock-5b_trixie_vendor_6.1.115_minimal.img' yesterday and it has the same issue (quick test via systemd-nspawn container on loopdev mounted image). My goal is at least to figure out what is best bootloader and kernel for the ROCK5B. So far I simply copied/cloned Armbian Bookworm rootfs from ROCK3A+NanoPi-R6C and did some ROCK5B specific changes like U-Boot, but not much more and it actually is already good enough. But before the ROCK5B becomes a 24/7 headless workhorse with long uptime, I thought better to prepare/check for newer Linux or potential issues. I already upgraded some other devices from Bookworm->Trixie and that is quite an improvement, for example KDE 6 performs much better/nicer than KDE5 in Bookworm. It currently uses U-Boot 'edge' and 'current' kernel and very important for me, both the 'vendor' and 'mainline current/edge' overlay for SERDES multi-PHY SATA on the M.2 E-key work (and also the NVMe keeps working). I need to drill a hole in the Radxa aluminum cooling case for the SATA cable (and serial console cable), that needs some time first. I can build and install U-Boot and kernel etc manually of -course, but i wonder why Armbian packages are not visible. Is it as expected or is something wrong? I assume it is just too early yet and that it is work in progress. I think maybe policies are an issue, but don't understand what it could be. Maybe someone has a hint. root@rock-5b:~# apt policy Package files: 100 /var/lib/dpkg/status release a=now 500 http://deb.debian.org/debian trixie/non-free-firmware arm64 Packages release o=Debian,a=testing,n=trixie,l=Debian,c=non-free-firmware,b=arm64 origin deb.debian.org 500 http://deb.debian.org/debian trixie/non-free arm64 Packages release o=Debian,a=testing,n=trixie,l=Debian,c=non-free,b=arm64 origin deb.debian.org 500 http://deb.debian.org/debian trixie/contrib arm64 Packages release o=Debian,a=testing,n=trixie,l=Debian,c=contrib,b=arm64 origin deb.debian.org 500 http://deb.debian.org/debian trixie/main arm64 Packages release o=Debian,a=testing,n=trixie,l=Debian,c=main,b=arm64 origin deb.debian.org 500 https://beta.armbian.com trixie/trixie-desktop all Packages release o=Armbian,a=trixie,n=trixie,l=Armbian,c=trixie-desktop,b=all origin beta.armbian.com 500 https://beta.armbian.com trixie/trixie-desktop arm64 Packages release o=Armbian,a=trixie,n=trixie,l=Armbian,c=trixie-desktop,b=arm64 origin beta.armbian.com 500 https://beta.armbian.com trixie/trixie-utils all Packages release o=Armbian,a=trixie,n=trixie,l=Armbian,c=trixie-utils,b=all origin beta.armbian.com 500 https://beta.armbian.com trixie/trixie-utils arm64 Packages release o=Armbian,a=trixie,n=trixie,l=Armbian,c=trixie-utils,b=arm64 origin beta.armbian.com 500 https://github.armbian.com/configng stable/main arm64 Packages release o=armbian.github.io/configurator,n=stable,l=armbian.github.io/configurator,c=main,b=arm64 origin github.armbian.com Pinned packages:
I tried the image from "armbian.atomonetworks.com" and the exact same thing happens. Thanks, I'll compare the images.
The latest Linux kernel brings expanded hardware support for MediaTek and Rockchip, enhanced graphics drivers, and more. Collabora played a key role in this release, with no less than 20 authored contributors! View the full article
ZFS-DKMS doesn't work on vanilla image https://dl.armbian.com/longanpi-3h/Bookworm_current_minimal Image is freshly burnt to the SD card. root@longanpi-3h:~# apt update root@longanpi-3h:~# apt install zfs-dkms root@longanpi-3h:~# modprobe zfs modprobe: ERROR: could not insert 'zfs': Exec format error root@longanpi-3h:~# modinfo zfs | grep -v parm filename: /lib/modules/6.12.23-current-sunxi64/updates/dkms/zfs.ko version: 2.3.1-1~bpo12+1 license: CDDL license: Dual BSD/GPL license: Dual MIT/GPL author: OpenZFS description: ZFS alias: zzstd alias: zcommon alias: zunicode alias: znvpair alias: zlua alias: icp alias: zavl alias: devname:zfs alias: char-major-10-249 srcversion: 2742833EE1C14D857611F06 depends: spl name: zfs vermagic: 6.12.23-current-sunxi64 SMP mod_unload aarch64 root@longanpi-3h:~# file /lib/modules/6.12.23-current-sunxi64/updates/dkms/zfs.ko /lib/modules/6.12.23-current-sunxi64/updates/dkms/zfs.ko: ELF 64-bit LSB relocatable, ARM aarch64, version 1 (SYSV), BuildID[sha1]=f87455b001529d816f09e1498e63a902d1af9be5, not stripped root@longanpi-3h:~# uname -a Linux longanpi-3h 6.12.23-current-sunxi64 #1 SMP Thu Apr 10 12:39:41 UTC 2025 aarch64 GNU/Linux logs After doing apt upgrade, reinstalling dkms module result is the same.
Awesome work as always. Cant wait until the 25.05 upgrade is available for my Rock5b
