@iav Thank you for the detailed reponse. I was not blaming the overlay or your build; I know the cpu voltages don't impact on this seperate issue. I have seen this before with the 6.18 kernel on the Helios64 which is why for the moment I am sticking with the 6.12 kernel with the opp microvolt patch which seems to be stable for me at least. I assume something has changed in the underlying PCIe architecture or drivers between 25.11.2 with 6.12.58 and 26.5.0 with 6.18.30 which results in this issue on my hardware. It is interesting that the build works on your hardware though. I will investigate the PCIe issue further when time allows and raise a issue.
@ljones0 in meantime can you test edge kernel images, i'm sure those works.
code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } dpkg-reconfigure locales and change default locale Tried?
1. https://github.com/apritzel/sunxi-fw 2. "adb reboot bootloader" takes you to fastboot if android boots up, "fastboot" if you are at u-boot terminal. See help for list of u-boot commands, I do not know that much about it but you can feed the list to AI and see if something useful comes up. So to get acceleration we need to pull at least 6.12.x kernel from raxda a7a a7s a7z to get video acceleration going, maybe like https://github.com/radxa-build/radxa-a733/releases -
the issue is fixed with edge kernel, with armbian u-boot included in 26.2.1 speed is now at gigabit level # uname -r 6.19.0-edge-rockchip64 # grep -a --null-data U-Boot /dev/mtd0ro U-Boot SPL 2026.01_armbian-2026.01-S127a-Pc2e6-H706e-Vab81-B2eb2-R448a (Feb 10 2026 - 04:37:42 +0000) # iperf3 -R -c odroidm1.lan Connecting to host odroidm1.lan, port 5201 Reverse mode, remote host odroidm1.lan is sending [ 5] local 192.168.1.192 port 45834 connected to 192.168.1.195 port 5201 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 110 MBytes 919 Mbits/sec [ 5] 1.00-2.00 sec 110 MBytes 919 Mbits/sec [ 5] 2.00-3.00 sec 111 MBytes 928 Mbits/sec [ 5] 3.00-4.00 sec 110 MBytes 927 Mbits/sec [ 5] 4.00-5.00 sec 110 MBytes 922 Mbits/sec [ 5] 5.00-6.00 sec 110 MBytes 919 Mbits/sec [ 5] 6.00-7.00 sec 111 MBytes 928 Mbits/sec [ 5] 7.00-8.00 sec 110 MBytes 925 Mbits/sec [ 5] 8.00-9.00 sec 110 MBytes 925 Mbits/sec [ 5] 9.00-10.00 sec 110 MBytes 921 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 1.08 GBytes 926 Mbits/sec 110 sender [ 5] 0.00-10.00 sec 1.08 GBytes 923 Mbits/sec receiver
This device is currently an outcast here, and until someone with understanding sets out to fix at least the main problems, welcome to the official image on the 5.15 kernel.
Katsujinken replied to Katsujinken's topic in Pinebook Pro
Updating to include a few more I've successfully run... OpenMW - FOSS Engine to play Morrowind & it's KOTOR total conversion Starwind Quakespasm - FOSS engine to play Quake and it's expansions, mods & total conversions UFO: Alien Invasion - an XCom "homage" Yamagi Quake 2 - FOSS engine for Quake 2 I was able to test Quake Mods like the cyberpunk FPS prequel to a prequel to a Dreamcast mecha game "Slave Zero X: Enyo" and top down fantasy RPG "Prydon Gate". Both work great but I'll need to upgrade the eMMC before I can try larger sized conversions like Brutalist Jam III or Slayer's Testaments. - Yesterday
Hello @jock, thank you for the quick reply! Indeed, the drivers for the 8723cs have been disabled in the rockchip64 version, as confirmed by my config file: grep -i "8723" /boot/config-$(uname -r) # CONFIG_RTL8723CS is not set # CONFIG_RTW88_8723CS is not set I found 2 GitHub repos with the uncompiled drivers for the 8723cs chipset: - https://github.com/VictorIstratii151/rtl8703bs_rtl8723cs_linux_driver - https://github.com/TinkerBoard-Android/rockchip-android-external-wifi_driver/tree/android14-rockchip I tried to compile them natively on my machine but without success. They relies on Android-specific headers that are missing in Armbian. Regarding the rockchip armhf family you mentioned, do I need to completely reinstall Armbian on my board using a different image (the 32-bit armhf one)? Do I have to use the Armbian build framework to achieve this? Or is there a way/tool to cross-compile this specific module for my current 64-bit setup? Thanks again for your help!
@Delutto Thank you for your contribution! Your changes have been successfully merged to my repo https://github.com/cdhigh/armbian_sv6256p Now the driver should work with kernels from 6.0 through 7.x. -
Hello everyone. I made a direct connection between the 5V from the motherboard and the 5V from the USB ports to try and overcome the current limitation of the USB ports. However, something went wrong. I undid this direct connection, but the motherboard is still shorting the USB ports. I believe the short circuit is in that ADG3T port. Does anyone have any idea what happened? I didn't even connect anything to the USB port. Thanks.
When I ask multiple questions, it is for a reason. When you don't answer all of the questions, then I can't help you as I have to guess. So here is a guess, that you are burning the SD card on Windows. I have seen reports that on some versions of Windows, that windows will automount the FAT partition on the SD card after burning, and when it mounts it it alters it in ways that cause problems. I haven't spent any time looking into that issue, but because of what I have seen repored, I would avoid doing the burn on windows. Please try it on a linux box. As for recommended burning tool, you should follow the Armbian documentation (https://docs.armbian.com/User-Guide_Getting-Started) and use Armbian Imager.
This week's work advances on three fronts: kernel and bleedingedge alignment across Rockchip and Sunxi trees, board and platform enablement spanning RV1106 to SpacemiT, and CI hardening with self-hosted runner maintenance. On the kernel side, bleedingedge was bumped to 7.1-rc3, accompanied by cfg80211 API fixes and re-enablement of the rtl8189fs and rtl8852bs drivers for the new release. Both the rockchip64 and sunxi patch stacks for current and edge were rewritten, an upstream ptrace fix for CVE-2026-46333 was backported to linux-rockchip, and the odroidxu4-current kernel moved to 6.6.139. Platform enablement was broad. The Ayn Odin2 gained 7.0 kernel support, the Mekotronics R58X-Pro switched its vendor build to mainline U-Boot with a corrected LCD driver, and the H96 TV box advanced to U-Boot v2026.04. RV1106 transitioned from extlinux to a bootscript and gained DS1307, PCF85063, and RV8803 RTC drivers, while SpacemiT received OpenSBI, U-Boot, and BPI-F3 DTS fixups. Smaller but user-visible improvements include NanoPi M5 second USB3 port exposure via DRD0 host-mode pinning, NORCO EMB-3531 LPDDR4X variants, RK3528 USB2 PHY corrections for high-speed NCM, and UEFI x86 images enabling iwlwifi MLD and Intel SOF audio for MTL, LNL, and PTL. Infrastructure work centered on self-hosted runner reliability and supply-chain hygiene. A new runner-cleanup module provides hourly disk and memory maintenance, skips busy runners, and ships via .deb, while a maintenance watchdog was added to the SDK repository. Multiple StepSecurity hardening passes landed across build and SDK workflows, though an overly strict egress-policy was subsequently reverted after breaking builds. #Armbian #EmbeddedLinux #Rockchip #RISCV #KernelDevelopment ChangesActions: Cleanup "Release" workflow. by @vidplace7 in armbian/MorseMicro-DKMS#4Actions: Create release workflow. by @vidplace7 in armbian/MorseMicro-DKMS#3Ayn Odin2 kernel 7.0 support. by @kasimling in armbian/build#9706Build for riscv64. by @vidplace7 in armbian/MorseMicro-DKMS#5Bump actions/download-artifact from 7 to 8. by @igorpecovnik in armbian/os#464Bump versions: stable 26.5.0, nightly 26.8.0-trunk.1. by @igorpecovnik in armbian/os#461bump bleedingedge to 7.1-rc3. by @EvilOlaf in armbian/build#9806cfg80211: fix API changes for Linux 7.1. by @EvilOlaf in armbian/wifi-rtl8852bs#5change recomputer rk35xx fan speed. by @ackPeng in armbian/linux-rockchip#472ci: add maintenance watchdog + rename action.yml → build-armbian-sdk.yml. by @igorpecovnik in armbian/sdk#25ci: drop step-security/harden-runner steps (egress-policy was breaking builds). by @igorpecovnik in armbian/sdk#26desktops: ship fprintd userspace at mid tier. by @igorpecovnik in armbian/configng#918desktops: split light/dark wallpapers in gnome + bianbu postinsts. by @igorpecovnik in armbian/configng#905Disable: SpacemiT: fix RX DMA params not set when TX is running. by @pyavitz in armbian/build#9808drivers_network: bump rtl8852bs commit ref to 35d3e266 (May 17). by @igorpecovnik in armbian/build#9841drop old lcd_vk2c21 LCD driver that never worked; backport workingvinka,vk2c21 driver; fix Mekos DTs. by @rpardini in armbian/linux-rockchip#482ebyte-ecb41-pge: Add spidev overlays (RPi-compatible). by @vidplace7 in armbian/linux-rockchip#467firmware-sof-signed: move from cli/amd64 baseline to UEFI common. by @igorpecovnik in armbian/build#9857fix(deps): add Pygments to requirements.txt (rich.syntax dep). by @iav in armbian/build#9819luckfox-lyra-zero-w: Default to onboard wifi antenna, add ipex overlay. by @vidplace7 in armbian/linux-rockchip#468maintenance-watchdog: target the workflow that actually exists. by @igorpecovnik in armbian/configng#915Mekotronics R58X-Pro (vendor): use mainline u-boot for vendor; use new LCD driver. by @rpardini in armbian/build#9836module_armbian_runners: skip busy runners + ship runner-cleanup assets via .deb. by @igorpecovnik in armbian/configng#914module_qbittorrent: poll for temporary password before showing dialog. by @igorpecovnik in armbian/configng#916nanopi-m5: pin DRD0 dwc3 to host mode to expose the second USB3 port. by @SuperKali in armbian/build#9844NORCO EMB-3531: Add LPDDR4X variants support. by @retro98boy in armbian/build#9823patch/sunxi-6.12: drop two Rockchip SPI patches (not applicable to sunxi). by @igorpecovnik in armbian/build#9827postinst/gnome: enable tap-to-click + clickpad right-click out of the box. by @igorpecovnik in armbian/configng#917Potential fix for code scanning alert no. 2: Code injection. by @iav in armbian/build#9799ptrace: backport upstream fix for CVE-2026-46333 (ssh-keysign-pwn). by @SuperKali in armbian/linux-rockchip#481restore backwards compatibility. by @EvilOlaf in armbian/wifi-rtl8852bs#6rockchip rk3566: h96-TVbox: bump to uboot v2026.04. by @hqnicolas in armbian/build#9807rockchip64-6.18: rebase rk3399 dwc3 phy-reset-quirk patch for 6.18.32. by @SuperKali in armbian/build#9847rockchip64: fix RK3528 USB2 PHY regmap split for high-speed NCM. by @rubycomm in armbian/build#9785rockchip64: opt-in helios64 CPU stability overlay (current + edge). by @iav in armbian/build#9822rockchip64: rewrite patches of current and edge. by @EvilOlaf in armbian/build#9829rtl8189fs: fix compilation for 7.1 and re-enable. by @EvilOlaf in armbian/build#9813rtl8852bs: re-enable for bleedingedge. by @EvilOlaf in armbian/build#9831runner-cleanup: drop redundant age-based _diag prune. by @igorpecovnik in armbian/configng#921runner-cleanup: hourly disk + memory maintenance for self-hosted runner hosts. by @igorpecovnik in armbian/configng#913runner-cleanup: wipe _diag/pages/ alongside _work/. by @igorpecovnik in armbian/configng#919runner-cleanup: wipe ~/_diag/ on every runner each pass. by @igorpecovnik in armbian/configng#920RV1106: add support for additional RTC drivers (DS1307, PCF85063, RV8803). by @vidplace7 in armbian/build#9812RV1106: Switch u-boot from extlinux to bootscript. by @vidplace7 in armbian/build#9801SpacemiT: Fixup OpenSBI, U-Boot and BPI-F3 DTS. by @pyavitz in armbian/build#9838sunxi: rewrite kernel patches of current and edge. by @EvilOlaf in armbian/build#9828uefi-x86: enable iwlwifi MLD + Intel SOF (MTL/LNL/PTL) audio. by @igorpecovnik in armbian/build#9846Update documentation / packaging URLs. by @vidplace7 in armbian/MorseMicro-DKMS#2Update MorseMicro suite to 1.17.8. by @vidplace7 in armbian/MorseMicro-DKMS#1Update nanopi r5s udev rule tweak for persistent net interface names. by @ruabmbua in armbian/build#9811Update odroidxu4-current to 6.6.139. by @belegdol in armbian/build#9837Workaround devcontainer/ci platform issues. by @vidplace7 in armbian/MorseMicro-DKMS#6[StepSecurity] Apply security best practices. by @step-security-bot in armbian/build#9833[StepSecurity] Apply security best practices. by @step-security-bot in armbian/build#9839[StepSecurity] Apply security best practices. by @step-security-bot in armbian/sdk#24[StepSecurity] ci: Harden GitHub Actions. by @step-security-bot in armbian/build#9803[StepSecurity] ci: Harden GitHub Actions. by @step-security-bot in armbian/build#9825View the full article
I failed to flash the firmware of my TV box and it's now bricked. I need to re-flash it. Please tell me where the shorting point of this TV box is and how to flash it using the shorting point. Thank you.
I don't have a specific solution for you. I flashed my M1S just yesterday with the latest Minimal image and it worked just ootb. But what I recognized during tests of my self-compiled images was, that the M1S seems to be quite picky regarding the SD card and how it is flashed. My M1S showed a lot of different strange behaviors: very (I mean VERY!) slow boot, file system was read-only, no ethernet, kernel panics... I had to try different SD cards as well as different flashing tools to get it running. Interestingly the images that I flashed with Balena Etcher worked better than those flashed with the Armbian flasher. My No-HDMI-problem was solved by just using another cable... So maybe it is worth to try to just re-download the image and flash it with another tool to another SD card? Best whishes, Jojo
Magcubic HY300 Android 11 Projector Allwinner H713, 1GB/8GB
curse replied to curse's topic in Allwinner CPU Boxes
@well0nez keep us updated on your progress. -
Hello good people. I honestly had given up on that thing, until last weekend, where I set my mind to finally get it to work. And work, it does! eMMC works, display output works without a trouble, and only today I've seen @eloirotava's comment about the 6051. And I'm calling for help again on that one. I currently am using the kernel 7.0.8-meson64 (the current edge for the tv box) and no matter what i'm doing, there's no way for me to get the correct linux-header files, to compile and install that module. May a kind soul help me? I'll post a full documentation very soon, and will probably push my work to the armbian git, once everything is clean. Thank you very much in advance!
chapeaufer replied to chapeaufer's topic in Allwinner sunxi
Problem remains the same. i have cloned a new build repos and patch with pr-9626 and rebuild image. console output result remains: U-Boot SPL 2026.01_armbian-2026.01-S127a-Pa547-Hc6a9-V2b7c-Bd0d2-R448a (May 18 2026 - 10:12:32 +0200) DRAM: 1024 MiB Something wrong with the uboot timing of the dram etc.? i can supplied the timing and trimming of the board with the funtional debian bootloader saved to spi. Setting of voltage regulators etc. see attached file. Regards Rolf hardcopy.0 -
Been doing some RK3588 board porting and kept running into the same category of bug — dtc compiles clean, dtbs_check passes, but the board either panics on suspend or a peripheral silently fails to probe. Stuff like: Peripheral on the EE supply wired to something that only stays alive in the AO domain → suspend-resume panic Copy-pasted a GPIO bank with 32 pins, used pin 35 → kernel panic at driver probe SPI clock request exceeds PLL maximum → silent bus hang Two nodes sharing the same GIC SPI interrupt line None of these are schema violations — they require knowing the actual cross-domain constraints of the SoC, which dtc has no idea about. So I wrote a Python tool that builds an in-memory model of the power tree, clock tree, and pin assignments, then runs constraint rules against it: $ pip install soc-consistency $ socc check board.dts --soc rk3588 error[PD-001] Power domain crossing — i2c@fe2b0000 uses vcc_3v3 (EE domain) but is connected to vcc_1v8 (AO domain). Will panic on suspend. error[GP-003] GPIO index out of bounds — gpio1 pin 35 on a 32-pin bank. warn[CK-003] Clock rate mismatch — spi0 requests 50 MHz from pll_cpll (max 24 MHz). There's also a decompile command that runs dtc on a binary blob and annotates the output with peripheral names from the SoC database — useful when you're staring at a vendor DTB and have no idea which block is at which address: $ socc decompile vendor.dtb --soc rk3588 gpio0@fd8a0000 /* GPIO0 (32-pin, 3.3V) */ { cru@fd7c0000 /* CRU — Clock and Reset Unit */ { RK3588 has the most complete constraint coverage right now. The constraint format is a simple YAML file — happy to accept PRs for other SoCs. GitHub: https://github.com/gahingwoo/SoC-Consistency Docs/rules reference: in the README If you hit false positives on a real BSP DTS, open an issue — BSP files from vendors tend to have a lot of "intentional" violations that I'm still tuning the rules around.
1
@Nick A TY very much for your reply, I've managed to create my first build but I am a bit confused because it made an IMG with a FAT32 boot partition, is it right or did I miss something?
Sancho replied to Sancho's topic in Rockchip CPU Boxes
After many weeks of research, testing and debugging I managed to put together an Unofficial Armbian Linux build for LinknLink iSG Box SE. Version: v26.05 Rolling Kernel: 6.1.115-vendor-rk35xx Flashed and booting from eMMC. All hardware working and tested, including Ethernet, WiFi and Bluetooth. Source, build and flashing instructions here https://github.com/luisdosreis/linknlink-isg-box-se-armbian If anyone is interested I can share a test image ready to be flashed or you can (and should) build it yourselves. I plan to add a Home Assistant flavor to the build system in the future. -
San Dich Huu replied to hamidreza h's topic in Allwinner CPU Boxes
Yes, the device is working now. Check the forum manjaro, they put kernel from sunxi and working now. -
epost.deb replied to 0KTAV1US's topic in Rockchip CPU Boxes
@jock Is it possible to dump BOOTROM from Linux, or is it hidden/shadowed by ATF ? There is RK3399 dumper code at github, so i am wondering if the same can be done on RK3528. -
Thank you! I ended up getting this working. For one, an update and reboot did get me the 6.18.10 kernel. Then, in the installation scripts for drivers, I just had to specify the package name for the headers explicitly, e.g. replacing: apt-get install linux-headers-$(uname -r) -y with apt-get install linux-headers-current-bcm2711 -y
