Not an Armbian kernel. You should ask at the place where you go the image with this kernel from.
If the armbian-install way does not work, you can also write the image directly to the ssd, either with a different computer or, since you were already successfully booting from usb, download the image again and dd it to the ssd. No need to do partitioning beforehand, just write to the raw device since the image already contains the partition table iirc.
This will cause update-grub to add the following a devicetree line to all menu entries. This example is based on Debian Trixie's grub-efi. This example will expect dtb directories (or links) to be in the /boot directory, using the convention that I've seen Armbian use. Here is an example of a /boot directory listing for (pure) Debian Trixie with two kernels: -rw-r--r-- 1 root root 336036 Aug 27 04:10 config-6.12.43+deb13-arm64 -rw-r--r-- 1 root root 343394 Sep 6 12:48 config-6.16.3+deb13-arm64 lrwxrwxrwx 1 root root 42 Sep 20 16:17 dtb -> ../usr/lib/linux-image-6.16.3+deb13-arm64/ lrwxrwxrwx 1 root root 43 Sep 20 16:17 dtb-6.12.43+deb13-arm64 -> ../usr/lib/linux-image-6.12.43+deb13-arm64/ lrwxrwxrwx 1 root root 42 Sep 20 16:18 dtb-6.16.3+deb13-arm64 -> ../usr/lib/linux-image-6.16.3+deb13-arm64/ drwxr-xr-x 3 root root 4096 Sep 20 15:13 efi drwxr-xr-x 5 root root 4096 Sep 20 16:26 grub lrwxrwxrwx 1 root root 29 Sep 15 21:30 initrd.img -> initrd.img-6.16.3+deb13-arm64 -rw------- 1 root root 42521317 Sep 20 16:26 initrd.img-6.12.43+deb13-arm64 -rw------- 1 root root 43760872 Sep 20 16:25 initrd.img-6.16.3+deb13-arm64 lrwxrwxrwx 1 root root 30 Sep 15 20:38 initrd.img.old -> initrd.img-6.12.43+deb13-arm64 -rw-r--r-- 1 root root 83 Aug 27 04:10 System.map-6.12.43+deb13-arm64 -rw-r--r-- 1 root root 92 Sep 6 12:48 System.map-6.16.3+deb13-arm64 lrwxrwxrwx 1 root root 26 Sep 15 21:30 vmlinuz -> vmlinuz-6.16.3+deb13-arm64 -rw-r--r-- 1 root root 37449664 Aug 27 04:10 vmlinuz-6.12.43+deb13-arm64 -rw-r--r-- 1 root root 41507328 Sep 6 12:48 vmlinuz-6.16.3+deb13-arm64 lrwxrwxrwx 1 root root 27 Sep 15 20:38 vmlinuz.old -> vmlinuz-6.12.43+deb13-arm64 Note: The relative pathways of the dtb links above assume that the /boot directory is part of the main OS partition, not on its own boot partition. Otherwise you'd need to copy those directories to /boot/ as Armbian does. For The Current Partition's OS Entries (each devicetree will be specific to the respective kernel) 1. Open the file with a text/source editor (using sudo): /etc/grub.d/10_linux 2. Find every line that looks something like this (currently on my system, there is only one, and it's line 189) linux ${rel_dirname}/${basename} root=${linux_root_device_thisversion} ro ${args} 3. Just above it, add your own system's version of this line: devicetree ${rel_dirname}/dtb-${version}/[VENDOR SUB-DIRECTORY]/[SBC PRODUCT].dtb Specific Example: OrangePI-5-Plus devicetree ${rel_dirname}/dtb-${version}/rockchip/rk3588-orangepi-5-plus.dtb Specific Example from the resulting grub.cfg, of the current trixie-backport kernel, again on the OrangePI-5-Plus: devicetree /boot/dtb-6.16.3+deb13-arm64/rockchip/rk3588-orangepi-5-plus.dtb For Other Partitions' OS Entries, via os-prober (I'm unfamiliar with the variables in this so each devicetree will be the same generic path, regardless of kernel) 1. Open the file with a text/source editor (using sudo): /etc/grub.d/30_os-prober 2. Find every line that looks something like this (currently on my system, there are two, lines 277 and 297) linux ${LKERNEL} ${LPARAMS} 3. Just above it, add your own system's version of this line: devicetree /boot/dtb/[VENDOR SUB-DIRECTORY]/[SBC PRODUCT].dtb Specific Example: OrangePI-5-Plus devicetree /boot/dtb/rockchip/rk3588-orangepi-5-plus.dtb Then run update-grub, and take a look at the resulting /boot/grub/grub.cfg
Hello, Armbian 25.8.1 on Helios64 BookWorm with Linux 6.12.42-current-rockchip64. I have my system booting from SD with OMV7 installed and several docker containers running. Everything is OK. Now I want to boot from emmc. Used armbian-install selecting option boot from emmc - system on emmc. Formatting and copying goes Ok, but when I reboot from emmc (extracting th SD card), OMV7 presents the web frontend, but can't log in. journalctl reports errors accessing the drives, and looking on /etc/fstab, there's only the / partition mounted. Inserting and mounting the SD card in /mnt/sdcard I can see that in /mnt/sdcard/etc/fstab there's a lot of drives ready to be mounted : eclapton@helios64:~$ cat /mnt/sdcard/etc/fstab UUID=a398270d-9378-4f2c-bedd-590b08234484 / ext4 noatime,nodiratime,defaults,commit=120,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 # >>> [openmediavault] /dev/disk/by-uuid/60c885fa-6af1-462c-bfa6-dc7fe706262f /srv/dev-disk-by-uuid-60c885fa-6af1-462c-bfa6-dc7fe706262f ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/a79a14c0-3cf4-4fb9-a6c6-838571351371 /srv/dev-disk-by-uuid-a79a14c0-3cf4-4fb9-a6c6-838571351371 ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/7b71362f-4bb4-48b6-8867-37faaedef2eb /srv/dev-disk-by-uuid-7b71362f-4bb4-48b6-8867-37faaedef2eb ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/1f1ea692-d1bb-4539-a578-0647ef752770 /srv/dev-disk-by-uuid-1f1ea692-d1bb-4539-a578-0647ef752770 ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/fac27973-2eba-43b4-acd3-2c3c2b10a5d7 /srv/dev-disk-by-uuid-fac27973-2eba-43b4-acd3-2c3c2b10a5d7 ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 # <<< [openmediavault] So, I thought the actual fstab was going to be copied over, unless it has to be recreated each boot by OMV. Also, I tried to copy /srv/salt and /srv/pillar from the old system on the SD card to the new one on the emmc, as instructed un Kobol's webpage, and it helps making openmediavault-issue start, but the webpage doesn't still work. sudo systemctl status shows nginx is not able to start : eclapton@helios64:~$ sudo systemctl status nginx × nginx.service - A high performance web server and a reverse proxy server Loaded: loaded (/lib/systemd/system/nginx.service; enabled; preset: enabled) Active: failed (Result: exit-code) since Mon 2025-09-22 23:07:25 CEST; 57s ago Docs: man:nginx(8) Process: 40902 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE) CPU: 82ms sep 22 23:07:25 helios64 systemd[1]: Starting nginx.service - A high performance web server and a reverse proxy server... sep 22 23:07:25 helios64 nginx[40902]: 2025/09/22 23:07:25 [emerg] 40902#40902: open() "/var/log/nginx/error.log" failed (2: No such file or > sep 22 23:07:25 helios64 nginx[40902]: nginx: configuration file /etc/nginx/nginx.conf test failed sep 22 23:07:25 helios64 systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE sep 22 23:07:25 helios64 systemd[1]: nginx.service: Failed with result 'exit-code'. sep 22 23:07:25 helios64 systemd[1]: Failed to start nginx.service - A high performance web server and a reverse proxy server. I suspect there's somewhere I have to change /dev/mmcblk1p1 for /dev/mmcblk0p1... but where? What am I missing? Thanks for your help.
PR: included fd6551 https://github.com/armbian/build/pull/8666 -
nice work @Eks Ma thanks for sharing!
Open the box, read the silkscreen on the board, run rk322x-config and configure according to silkscreen name. Probably you have a r29/h20 board
h96-m9s-rk3576_defconfig rk3576-h96-m9s.dts rk3576-h96-m9s1.dts rc.local h96-m9.config rk3576-h96-m9s.dts h96-m9.tvb Compile-configuration.zip -
thank you so much for the link, after trying some of the older tinkerboard .deb archives from there I was able to install one that didn't have the two missing deps eventually and, lo and behold, I could even feel the accelerated desktop from the login window, even before confirming it with the much snappier webgl aquarium test, that jumped from about one fps to almost 60 there are still some kinks, like h264ify being installed but not doing squat (youtube is still av1 and hangs the whole system), but I'll take what I got for now as for the SOC being 2017....I'm fully aware that like everything Asus makes, it becomes e-waste after 2 years, I could probably try to flip this board online for $1 and no one would buy it, but I still believe it should be enough for me to stream video from my NAS on my secondary TV using 5-15W, kind of like those crappy Android sticks that plug into HDMI and an extra USB port I have yet to decide if my next SBC should be a rk3588 board or just bite the bullet and get some N100 SBC that's probably cheaper (I live in Europe, Orange Pi 5 probably goes for more than a used PS5 with all the taxes), can run anything and won't be forever stuck on whatever this year's trending distro is
Hi ! @jpm how exactly did you solve 2) Fixed cedar_ve compilation issues / kernel name ? I'm gettinf the same "modprobe: ERROR: could not insert 'cedar_ve': Exec format error" T.
A crash in the Linux kernel's module loader is not really ZFS's fault, though, right? There's nothing about `resolve_symbol` that's part of ZFS.
Would you mind sending this as pull request? https://github.com/armbian/build/pulls
You need to install rkdeveloptool on your PC. Connect the board to your PC using a USB-C to USB-A cable. Before powering the board, press and hold the mask button, then plug in the power cable. Once this is done, your PC should detect the device, and you can verify it with: rkdeveloptool ld You can follow this guide: https://docs.armbian.com/User-Guide_Getting-Started/#rockchip
moved Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
Failed to boot after trying to manually upgrade kernel
The Tall Man replied to lovenemesis's topic in Raspberry Pi
I don't see anything above about your boot-loader being updated. i.e. u-boot or grub. If you're using u-boot, was your uInitrd in your /boot directory updated? The initrd-image needs to be converted to its u-boot format of uinitrd. Instructions for how to do that are located at the bottom of your boot.cmd file (using the mkimage command from the u-boot-tools package). Though that may be a generic example that you'll have to update for your system. Also if you have an armbianEnv.txt (or an equivalent) in your /boot directory, be sure it's up to date for your current kernel's devicetree file location and name. If that doesn't solve it read on.... I keep seeing everywhere that kernel 6.12 is broken. Not sure if that applies to all systems. I use the edge kernel (6.16) in my OrangePI-5-Plus. I've found that to work much better than Vendor (6.1). To chroot in from an another identical system. This works on Debian Trixie. I'm not sure about other OS's. Note: I don't know much about this, I recently found this from searching and used it myself. I found it works great to install new packages and also to run update-initramfs. mount -t proc proc /mnt/proc mount -t sysfs sysfs /mnt/sys mount -t devtmpfs devtmpfs /mnt/dev mount --bind /dev/pts /mnt/dev/pts # If you need for the chrooted system to be able to access the internet, the link at its: (/etc/resolv.conf) must be valid, so add this as well: mount --bind /run/systemd /mnt/run/systemd Then chroot in (I'm not sure if the /bin/bash) is necessary - or if you're using something else than bash, put that there instead?) chroot /mnt /bin/bash [Do what you need to do in there] i.e. install a different kernel, and be sure update-initramfs has been run or run it yourself, and the u-boot (or grub) is updated. Whenever you're installing a new kernel, it's a good idea to leave the old one there. Once you get it working, it might then be a good idea to remove any non-functioning kernels (like that 6.12), and leave any functioning kernels in. Then to back get out of chroot and return undo the above mounts: # Exit chroot exit # This line is only necessary if you mounted it to use the internet while chrooted: umount /mnt/run/systemd # Unmount the rest umount /mnt/dev/pts umount /mnt/dev umount /mnt/sys umount /mnt/proc umount /mnt -
Thanks for this info, just wanted to share that the image for the "Linux v6.1 vendor IOT image for the 5 "Max" model" you linked to also worked for me on my Orange Pi 5 Ultra with no modifications needed. I haven't tested wifi or any use cases besides some simmple stuff over ssh so far, I did get a warning on first boot that it's a developer version of Armbian and shouldn't be used for production, but I suppose that's the case for all "community" builds? I also found this gist with steps to build Armbian from scratch for the 5 Ultra, but I haven't tried this yet. In case anyone else is looking for related info this PR also is also relevant: https://github.com/armbian/build/pull/8252 I still regret not buying a better supported board like the 5 Max board instead but hopefully better support will come for the 5 Ultra with time.
Thank you, it looks like my Nvme was bad. It works now!
I switch to vendor kernel 6.1.115 - its work
Hi All Well I am getting nowhere fast. When plugging the board into a Rpi Zero 2w , i2cdetect -l shows i2c-1 and i2c-2 i2cdetect -y 1 shows 00x48 i2cdetect -y 2 shows oox49 (my second board) and a few others like 3a,50,59 Re-wrote the image on the Opi Zero 2w to Debian as I was getting tired of the booting problems with ArmBian. Followed the manual on ALL the instructions. i2cdetect -l shows i2c-0 i2c-1 ,i2c-2 and i2c-3 i2cdetect -y 0 does not show any adapters connected i2cdetect -y 1 shows UU on 36 i2cdetect -y 2 shows 30 and 50 i2cdetect -y 3 does not show any adapters VERY SLOWLY. Orangepi-config /system/Hardware has been tried with just i2c-0 ticked or all three ticked. Tried ticking phi2c-0 to 3 but that made no difference, still no 00x48 visible anywhere. I have tried about 6 different OS Images, all to no avail. Even tried the Rpi image shown on the Opi site. So, I have to conclude (unless someone corrects me) that it is the board that is the problem or some firmware on the board. Not sure if I should learn how to upgrade the firmware. Regards
@Igor When I first start it up, I get an error! Even if I install the packages manually, the GNOMRlE interface does not switch to Portuguese! That's strange!
I recently had to modify a device tree file for a different reason. I showed what I did (and how I did it) here: https://forum.armbian.com/topic/52118-hdmi-audio-and-analog-audio-do-not-work-on-opi5plus/?do=findComment&comment=224923 To summarize, I used the device-tree-compiler package (command line: dtc) to convert the device tree binary (.dtb) file to a device tree source (.dts) file. Then I edited the .dts file, then converted it back. The process won't show you all the variable names, but the resulting .dts is readable enough to likely see what and where you need to change... and even moreso if you have the original (pre-compiled) .dts file to compare it with. If you need to match variable names with specific numbers, they will likely be #defined in the #includes at the top of the original .dts file.
Orange Pi 5 6.12 images in website do not work
Werner replied to Fabricio Martínez Tamayo's topic in Orange Pi 5
Yes, current broke at some point. More up to date packages should be available via apt. In general the support for rk3588 in 6.12 (current as of today) is barely there but there won't be updates regarding that matter, bug fixes only due to its LTS nature. Better use vendor or edge. -
Great, svvolf! This fix boot problem on OPI Zero v1 (Armbian v25.8.1, Linux 6.12.43-current-sunxi) 😁 Thank you!
- 23 replies
- Orange Pi Zero
- Orange Pi Zero 2
(and 1 more)
Tagged with:
