I have an OrangePI 5 Plus, which is based on the rk3588 (arm64) SoC. I've installed Debian Trixie directly from their .iso installer (using an EFI booter) and it works - although I had to upgrade the kernel to the latest backported version to get GPU and audio. But the Armbian edge kernel (Rockchip64 in my case) works even better when install that package onto the pure Debian. I looked up that Chromebook and see it's based on the rk3288C, which is apparently a 32-bit arm (armhf)? If that's the case, you can download the Debian .iso installer here: https://cdimage.debian.org/debian-cd/current/armhf/iso-dvd/ Then if Armbian has an edge kernel for the rk3288, try it out to improve upon what Debian provides. I did find this page on Debian's site, but it doesn't look like it would be much help.: https://wiki.debian.org/InstallingDebianOn/Asus/C100P There is a Debian page for a similar computer that may be more helpful if you can adapt it to yours? https://wiki.debian.org/InstallingDebianOn/Asus/C101PA Note that the above two links were probably created long before Trixie. P.S. Even better is a full linux tutorial for your specific computer. In a search engine, I looked up: installing linux on ASUS ChromeBook C100P ...and this was a result: https://archlinuxarm.org/platforms/armv7/rockchip/asus-chromebook-flip-c100p
After like a week of trying to make my tinkerboard rk3288 play videos I finally found the holy grail: https://users.armbian.com/jmcc/output/ Find the latest version and install that with all his dependencies, all the dependencies are in the debian archive: deb http://archive.debian.org/debian buster main contrib non-free deb http://archive.debian.org/debian buster-updates main contrib non-free deb http://archive.debian.org/debian buster-backports main contrib non-free deb http://archive.debian.org/debian-security buster/updates main contrib non-free deb [signed-by=/usr/share/keyrings/armbian.gpg] https://github.armbian.com/configng stable main deb http://apt.armbian.com buster main buster-utils buster-desktop I managed to play 4k hevc dolby atmos 5.1 movie streaming from my jellyfin server at my parents house using kodi-gbm and it worked flawlessly! I couldn't do the same with mpv yet. I hope this helps ppl with this ancient (2017) sbc.
Why does the system restart trigger at 3:30 every day?
Werner replied to lay's topic in Khadas EDGE2
Checked here?https://serverfault.com/questions/1042988/automatic-reboot-at-specific-time-if-automatic-upgrade-requires-reboot - Yesterday
I flashed same image to a SD card and tried to boot from it. Following is the result of `grep mmcblk1p2 /var/log/syslog` 2025-09-17T09:52:44.015489+00:00 rock-5-itx armbian-resize-filesystem[947]: ### [resize2fs] Trying to resize ext4 filesystem on /dev/mmcblk1p2: 2025-09-17T09:52:44.015493+00:00 rock-5-itx armbian-resize-filesystem[947]: Running 'resize2fs /dev/mmcblk1p2' now... 2025-09-17T09:52:44.015508+00:00 rock-5-itx armbian-resize-filesystem[947]: Filesystem at /dev/mmcblk1p2 is mounted on /; on-line resizing required 2025-09-17T09:52:44.021891+00:00 rock-5-itx kernel: EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Quota mode: none. 2025-09-17T09:52:44.021891+00:00 rock-5-itx kernel: EXT4-fs (mmcblk1p2): unmounting filesystem. 2025-09-17T09:52:44.021893+00:00 rock-5-itx kernel: EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Quota mode: none. I will try booting from a different medium and running `fsck mmcblk1p2` too.
read first How to build my own image or kernel?
pberki replied to Igor's topic in Advanced users - Development
Hi, In the documentation (https://docs.armbian.com/Developer-Guide_User-Configurations/#user-provided-kernel-config) it says: "User provided kernel config: If the file userpatches/linux-$LINUXFAMILY-$BRANCH.config exists, it will be used instead of the default one from config." Is there a way to define only the desired changes to the kernel parameters? -
@SteeMan That is actually a good question, to which I do not have the answer. Here's a picture of the chip itself: I have not been able to find any information on that particular chip, so it may as well be nand...
Orange Pi H3 soc images doesn't have lpae enabled in kernel
laibsch replied to sea's topic in Allwinner sunxi
this can easily be answered with a quick web search or AI request for "disadvantage of LPAE on armhf". As expected, one of the drawbacks is increased use of memory when the benefit of larger addressable memory applies only to few installations and in a limited way. - Last week
Certainly worth a look. It is also probably worth comparing the Armbian commit from when I last had it working until now, but it will need to be when I have a bit more time, and me remembering just when I first started seeing these issues.
Hi pcduino2user, glad you are finding it useful. Maybe CMA Buffer size needs to be lowered during the kernel, which actually appears to get ignore anyway once the board has fully booted and replaced with 96mb based on the reserve memory node within the A10 DTSI. This is definitely needed if trying to run a desktop although I wouldn't recommend running a desktop on the Pcduino2. There are still some minor issues that I would like to address in future but I don't have as much time as I used to. For example the pcduino2 is actually booting from the Pcduino1 DTS although this problem is more cosmetic than functional. Both the Pcduino1 and Pcduino2 share the same uboot defconfig file but the Pcduino2 has a USB2 VBUS pin defined within its DTS and physically connected on the PCB. This is normally pulled high by a resistor so does not cause any problems with USB power being enabled. The build framework allows us to configure the kernel but there must be a way to customize uboot more dynamically as well? Now certain Armbian board configuration files appear to contain configuration data for adjusting the dram speed as can be found in the cubieboard.csc so I wonder if a similar setup in the pcduino2 configuration file to override the default device tree property to use sun4i-a10-pcduino2.dts instead of sun4i-pcduino.dts. Given the closeness of hardware it does not seem worth creating a separate defconfig file. Ryzer
Hi @Nick A, the armbian in afiftyp board just see 2GB to, at least it was this way in 2024 when he sent me his boot log. My board is very similar to afiftyp board, except of a number near the QC sticker, that looks like a version number. afiftyp number is 2336 and the mine is 2333. The amout of memory chips is identical to (8 chips), but tha labels is a litle different, but I cant found the label meaning. I use your image since very old one, so I don't think it is about u-boot update, but I could try an older one. About Secure Boot, A patch that you give me solved it and it isn't a problem any more (thanks again for it). @afiftyp, if I'm wrong and you already solve your rom amount in armbian, please let us know and if you could, explain us what you did to solve it, thanks.
Something like git clone https://github.com/armbian/build.git -b main cd build git remote add -f imx8mp-build https://github.com/OLIMEX/imx8mp-build.git git remote update git fetch origin git fetch imx8mp-build git checkout main git rebase imx8mp-build/bookworm # fix conflict vi VERSION git add VERSION git rebase --continue # fix conflict vi .github/dependabot.yml git add .github/dependabot.yml git rebase --continue git log
@Dann https://dl.armbian.com/rock-5b-plus/Noble_vendor_gnome verifies fine for me. Try https://netcup-03.armbian.com/dl/rock-5b-plus/archive/Armbian_25.5.1_Rock-5b-plus_noble_vendor_6.1.115_gnome_desktop.img.xz and https://netcup-03.armbian.com/dl/rock-5b-plus/archive/Armbian_25.5.1_Rock-5b-plus_noble_vendor_6.1.115_gnome_desktop.img.xz.sha
AFBC support has been merged to PanVK and will be available in the Mesa 25.3 release! This new enablement reduces memory bandwidth and boosts performance. View the full article
How to install armbian to Amlogic S805 android box
Vittorio Saldo replied to remolaan's topic in Amlogic CPU Boxes
@remolaan "...Hey i have a SDMC DV8040 stb ,SoC-Amlogic S805X,CPU-Quad-core 1.2 GHz,GPU-ARM Mali-450,RAM-1GB,Storage-8GB it currently runs custom made android 9..." Please @remolaan, could you send me a working download link for the custom Android 9 system you made? -
Armbian 25.8.1 Noble XFCE (mainline Kernel: 6.16.6-edge-rockchip64) + PanVk - mesa 23.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.7 (https://ryanfortner.github.io/box64-debs/) + wine-10.15-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.15) + DXVK-stripped v2.7.1 ~60fps@720p Hades -
Hello @Ian Coelho, have you ever got any solution? I got the same issue
zero2w != zero2 moved
Hi and Thank @jock That's what I thought. I used ledconf-3 because that's the configuration you made specifically for my MX10 box. I ran a memtest, which went smoothly. The system is working, and I was able to compile rockchip mpp without any problems. The system is running Bookworm. Would it be better to update to Trixie or revert to a previous version? What do you think? I think the problem comes either from rk3318-box.dtb or from the overlays. Thanks again. 🤜🤛
@jock well thanks but I already figured that part out 😊 my problem right now is that i can't find a single distro that works with my box . almost every one (even multitool) goes to a black screen and freezes excatly after 60 seconds . the best thing i could find was a android rom that have the same problem but in excatly 30 minute after booting up ! i did this stupid thing that did not backed up my original rom before writing to internal emcp flash 🤦♂️ if i can find any version that doesn't have this problem , i know how to merge armbian rootfs with it ! thank you again !
Have you tried your python script with your Linux PC? If it happens again, you can tell that the problem is within the ESP32 program. I generally prefer having the most complex system (Armbian) poll the simplest device (ESP32), instead of the ESP32 interrupting the Armbian system. I found it more stable that way. Stay with wifi, and use the ESP32 serial port just for debugging. Program the ESP32 print an acknowledgement of data requests, and an alarm if it gets stuck in an unexpected state. I have also found ESP32 circuit or micro python very stable for serial port communications.
Vincenzoernst1 replied to Hqnicolas's topic in Rockchip CPU Boxes
@Hqnicolas would it be possible to have the driver @guenter pointed out in the base image? -
I think the core problem is that headers were compiled with Ubuntu compiler / userspace and you try to use it on Debian. I used this on Ubuntu, which is the reason why it worked. We are aware of this problem - headers should be distro specific. Which adds complexity on our side ...
Feel free to pr any missing overlay here: https://github.com/armbian/linux-rockchip
