  2. Hi there, I followed the instructions in section 4.1 to install it onto the memory card, but when I plug it into the TV box, it won't boot from the card. Could you please provide instructions again?
  3. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. and/or lspci output it might also be a power issue or just that you specific nvme does not work with non-vndor kernel also kernel is already at 6.18.35 for current rockchip, maybe see if that fixes something w,r,t, yiour nvme
  4. As I have no board 2f to test it I made the image and dts blindly a bit... Image Fix to wifi card (I guess it should work)
  5. Today
  6. @KhanhDTP There's no pull request yet but they do have a preparation PR https://gitlab.freedesktop.org/mesa/mesa/-/merge_requests/41654 For DQ 11S, it's about 15 fps@1080p. The FPS varies depending on the gaming scenes. You can check out my video https://b23.tv/xvsMPqD
  7. Hello everyone, I am looking for the original firmware for my Q1 TV Box. Board information: Board: Q1-V4.0 CPU: Allwinner H313 RAM/Storage: 2GB + 16GB eMCP (Foresee) WiFi: SV6256P Sticker on PCB: Q1-H313-111-ATV-8800 XH20251014024 I have already tried searching on Needrom, but the available firmware is for Q1-V3.0 / A32 / A33 boards, and I am not sure it is compatible with my Q1-V4.0 board. Does anyone have the original firmware (.img) or know where I can download it? Thank you very much.
  8. With the most recent minimal Debian image, Armbian_26.2.1_Bananapim2s_trixie_current_6.18.15_minimal.img on my A311D, I hit a problem with Xorg. Instead of starting up into dwm via lightdm's autologin, all I got was the blank blinking cursor screen. Working through it with an LLM, the resolution worked out to be adding a stanza to Xorg.conf. Section "ServerFlags" Option "AutoAddGPU" "false" EndSection Is this the correct solution? Is this known or understood? I know nothing about any of this. I presume it's related to how the devices look to Xorg via the kernel, but I have no understanding beyond that level, if that's even correct.
  9. Yesterday
  10. @MMGen yeah, that's where mbr keeps its stuff. I guess my question is why skip copying the first 32KiB even if it's empty? In form of time saving, we are talking microseconds. Even if it were to be mbr that you convert into gpt, the conversion would remove the first 32KiB turning it into zeroes and put the gpt partition table on the last 34 x 512k blocks... Is there any other reason to skip it? Is it due to the encryption? Would this process not work if I don't skip the first 64x512 blocks?
  11. Well I don't know what is that firmware and I'm not going to touch it even with a 6 meters stick, sorry. Random software from the internet is not a wise idea, even more if it is a software you are going to install onto a computer laying in your private network. About the serial adapter, I don't know, you should post logs or something useful to give you sensible guidance; giving you blind instructions won't help. If you're a newbie, probably it is better to wait for someone telling you a way to get maskrom mode on your board. I just want to ask you if you tried to put the multitool on a sdcard and boot the board with it.
  12. I just installed Armbian_community_26.8.0-trunk.170_H96-tvbox-3566_resolute_edge_7.0.12_gnome_desktop on an original board HCY-RK3566-1X32-V13 2021-03-27 I wanted to confirm the WiFi chip visually but could not do so as pulling the shield off the HCY6335 was not possible, it's very likely actually soldered so don't try. With this image out of the box: What works: LAN Display What doesn't work: WiFi Bluetooth Unknown: SPDIF Hardware video decoding Afterwards, I installed brcmfmac4335-sdio.bin and brcmfmac4335-sdio.txt from https://github.com/LibreELEC/brcmfmac_sdio-firmware/tree/master to /lib/firmware/brcm/ as per https://green.bug-eyed.monster/armbian-on-the-h96-max-v56-android-tv-box/ but I don't think you need any symlinking. This made Bluetooth and WiFi work but the speed it gets is very poor (20mb/s) so I recommend using wired connection which did get ~500mb/s. I started looking to into hardware video acceleration and this seems to be a bit of a mess. AFAICT MPP (Media Process Platform) and RGA (2D Raster Graphic Acceleration) are needed for this to work. The two options I saw were ffmpeg-rockchip and jellyfin-ffmpeg but both mention needing Rockchip BSP/vendor kernel. Does anyone have any experience here as I was hoping to turn this into a media PC? Given component costs now an that I originally paid ~$42 for the 8GB model I do think this board + armbian runs quite smoothly.
  13. Hah. I switched to using the cheapest one I had and that worked. But thank you for the validation. This was indeed the correct strategem.
  14. So I've got two of these old android tv boxes, both running the S912 chipset, and both are pretty much dead at this point. Trying to figure out if it's worth the effort to revive them or if I should just toss them already. On both boxes: no display through hdmi at all, not even a logo or flicker. Tried the toothpick trick for recovery screen with power plugged in, no reaction. Keyboard and mouse don't get picked up when connected. And when I hook them up to my laptop with a usb to usb cable, the boot light does turn on so they're clearly getting power, but the box itself never shows up anywhere on the laptop, not even in device manager after installing the usb burning tool drivers (one does shows up, but says USB device not recognized). Also tried the SD card method, used the correct armbian image on it, still didn't worked. Basically all I get is that one led lighting up and that's it. No video output, no usb enumeration, nothing responds. Attaching some pics of the boards and ports in case it helps spot anything obvious. Before I give up on these completely, does anyone know if there's still a way to force them into burn mode, because i know for certain that it's not a hardware related issue. Software is stopping them going into burn mode. Hardware is completely fine and working. So i wanna force them to go into burn mode so i can use armbian image on them. If there really is no option, i'm tossing them out. But there has to be a way. Any help would work. Thanks in advance.
  15. Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
  16. Last week
  17. Oh man, every Armbian install to Pinbook Pro's eMMC I heard of always ended up failing. Which steps did you do to successfully install Armbian to your eMMC? Would really appreciate it!
  18. Join us on June 18 for our low-latency ML video analytics demo on the Ryzen AI Max 300 Series at the AMD Embedded Computing Summit! View the full article
  19. Linux kernel 7.1 brings improvements across filesystems, networking, scheduling, graphics, Rust, and hardware enablement, with Collabora contributing 65 patches from 16 engineers across Panthor, DRM, Rockchip, MediaTek, and driver fixes across the kernel. View the full article
  20. Hi, could someone please give me a backup of the MXQ PRO 4K (5G version) WiFi EA6521QF? I need it for my Android TV box. Thanks.
  21. https://forum.armbian.com/terms
  22. anyone able to build https://code.ffmpeg.org/Kwiboo/FFmpeg/src/branch/v4l2request-v3 on their opi5? i try to build on my opi5 with today current-kernel 6.18.35 and got error: ERROR: v4l2_request requested, but not all dependencies are satisfied: linux_media_h v4l2_timeval_to_ns v4l2_m2m_hold_capture_buf libdrm libudev try edge kernel 7.1 also got the same error. any idea?
  23. @johlnx i try img cant booting, i think X88PRO13 use ddr4 of ram. how to build for rk5328 with ddr3 of ram ? device : h96 max 8k ultra hd .dtb .dts file ⬇️ rk3528-evb2-ddr3-v10.dtb rk3528-evb2-ddr3-v10.dts
  24. just for reference: the velvet-os image mentioned above is using some old mainline u-boot with patches from warpme minimyth2 from that time - here is how it was built: https://github.com/hexdump0815/u-boot-misc/blob/230127-01/readme.h616 ... the default u-boot of this image is the tx6s one best wishes - hexdump
  25. This week's work centers on kernel and board enablement, CI infrastructure and caching, and user-facing tooling improvements across the imager and configuration utilities. On the kernel and board front, Rockchip edge moved to 7.1 and mainline was bumped to 7.1-rc7, while the Raspberry Pi 4B legacy target was re-enabled after a brief revert of the BCM2711 kernel bumps. New board support landed for BeagleBadge and TMDS64EVM (AM64x) on the TI platform, the Anbernic RG DS RK3568 handheld as CSC, and the Youyeetoo YY3588 received a mainline DTS rework with ES8388 audio routing. Several long-standing fixes were merged, including a meson64 GPIO can_sleep regression breaking 1-Wire, JMicron JMB582/JMB585 32-bit DMA forcing, and QRB2210 U-Boot load address corrections. A substantial CI and caching effort introduces a new git_cdn module providing a GitHub caching git+http proxy, an apt-cacher-ng configng module, and multi-arch Docker images for both. GitHub Actions runners now export per-runner apt, ghcr, ccache, and proxy environments from the NetBox registry, with added retry guards, SSH/rsync timeouts, and workspace ownership reconciliation between jobs. The rootfs builder now routes mmdebstrap through APT_PROXY_ADDR when configured. User-facing changes focus on the Armbian Imager and first-run experience. The imager gained marquee scrolling for long board names, a "Create new profile" shortcut, accurate progress-phase reporting, and surfaced flash write failures in place of blank error screens. The first-login flow now runs automatically on freshly-flashed boards, and armbian-firstrun uses atomic writes for armbianEnv.txt MAC randomization to prevent corruption. #Armbian #EmbeddedLinux #Rockchip #CICD #SBC ChangesAdd images for new board and missing images for existing boards. by @jonaswood01 in armbian/armbian.github.io#329Add module_aptcacherng: apt-cacher-ng caching proxy. by @igorpecovnik in armbian/configng#935add multi-arch git_cdn image build. by @igorpecovnik in armbian/docker-armbian-build#29Add new target boards for uefi arm64/x86 edge branch. by @igorpecovnik in armbian/armbian.github.io#327add usbip support to missing current 6.18.y configs. by @EvilOlaf in armbian/build#9971add usbip to more kernels. by @EvilOlaf in armbian/build#9973arm64: dts: rockchip: yy3588: bind ES8388 codec via es8328 driver. by @SuperKali in armbian/linux-rockchip#499armbian-firstrun: use atomic write for armbianEnv.txt MAC randomization. by @mingzhangqun in armbian/build#9937ata: ahci: force 32-bit DMA for JMicron JMB582/JMB585. by @HeyMeco in armbian/linux-rockchip#504Auto-run first-login on freshly-flashed boards. by @igorpecovnik in armbian/autotests#6ayn-thor: fix fused kernel args in LinuxLoader.cfg cmdline, add rw rootwait. by @eldandaman in armbian/build#9969bcm2711: bump kernels — legacy 6.18, current 7.0, edge 7.1. by @igorpecovnik in armbian/build#9964board: add Anbernic RG DS (RK3568 dual 4" 640x480 handheld) as CSC. by @crackerjacques in armbian/build#9934bootscript: rk35xx: simplify armbianEnv.txt corruption detection. by @mingzhangqun in armbian/build#9953bump mainline to 7.1-rc7. by @EvilOlaf in armbian/build#9950ci: build current apt-cacher-ng image (trixie/3.7.x). by @igorpecovnik in armbian/docker-armbian-build#28ci: cache GitHub runners from NetBox to github-runners.jq. by @igorpecovnik in armbian/armbian.github.io#328docs(git_cdn): add GCDN001 help header/footer markdown. by @igorpecovnik in armbian/configng#939docs: document gitproxy GITHUB_MIRROR and GITPROXY_ADDRESS. by @igorpecovnik in armbian/documentation#925feat(boards): scroll long board names with marquee. by @SuperKali in armbian/imager#146feat(flash): show only the progress phases that will actually run. by @SuperKali in armbian/imager#148feat(profiles): add "Create new profile" shortcut to the flash picker. by @SuperKali in armbian/imager#147Fix auto-firstlogin in CI: ssh-dut 1234 fallback + reconcile trigger. by @igorpecovnik in armbian/autotests#7fix(extensions/lvm): Fix support for non-ext filesystems. by @ojafuenf in armbian/build#9889fix(interactive): parse case alternatives in get_kernel_info_for_branch. by @iav in armbian/build#9798fix(mvebu-6.18): drop SysRq-via-BREAK patch, fixed upstream in 6.18.35. by @iav in armbian/build#9958fix(rockchip64-7.0): drop SysRq-via-BREAK patch, fixed upstream in 7.0.12. by @igorpecovnik in armbian/build#9956fix(rootfs/qemu-static): use direct armhf exec probe instead of broken arch-test gate. by @iav in armbian/build#9820fix(ui): keep marquee text aligned while scrolling. by @SuperKali in armbian/imager#149Fix: EasePi-A2 Boot & Ethernet on Vendor Kernel. by @ifroncy01 in armbian/build#9946gha/chunks: export per-runner apt/ghcr/ccache env from runner registry. by @igorpecovnik in armbian/os#471gha/chunks: export per-runner caches in images job. by @igorpecovnik in armbian/os#472gha: add retry and empty-result guard to NetBox server list step. by @igorpecovnik in armbian/os#469gha: add ssh/rsync timeouts to image upload so dead servers fail fast. by @igorpecovnik in armbian/os#473image/compress-checksum: cap compression threads (default 32). by @igorpecovnik in armbian/build#9949meson64: fix GPIO can_sleep regression that breaks w1-gpio (1-Wire). by @adeepn in armbian/build#9959module_aptcacherng: use current ghcr.io/armbian image. by @igorpecovnik in armbian/configng#937orangepi4pro: Add Orange Pi 4 Pro board photo. by @shkolnik in armbian/armbian.github.io#330qrb2210: fix U-Boot load addresses and root partition for 2GB variant. by @govindsi in armbian/build#9925README: document full image catalog (framework, automation, caching proxies). by @igorpecovnik in armbian/docker-armbian-build#31Revert "bcm2711: bump kernels — legacy 6.18, current 7.0, edge 7.1". by @EvilOlaf in armbian/build#9965rk35: add rk3568 DDR 1056MHz v1.23 and BL31 v1.45. by @crackerjacques in armbian/rkbin#45rockchip: bump edge kernel to 7.1. by @paolosabatino in armbian/build#9955rootfs: route mmdebstrap through APT_PROXY_ADDR when set. by @igorpecovnik in armbian/build#9961rpi4b: re-enable legacy target. by @EvilOlaf in armbian/build#9968rtl8192eu: fix -Wmissing-prototypes for 121 functions. by @iav in armbian/build#9963runner-clean: export per-runner proxy env and route git via git_cdn. by @igorpecovnik in armbian/actions#20runner-clean: export per-runner xz memory cap (IMAGE_XZ_MEMLIMIT). by @igorpecovnik in armbian/actions#22runner-clean: normalize git_proxy to one trailing slash. by @igorpecovnik in armbian/actions#21runner-clean: selectively chown root-owned workspace files before checkout. by @igorpecovnik in armbian/actions#23runner-cleanup: chown workspace after each job via JOB_COMPLETED hook. by @igorpecovnik in armbian/configng#944runner-cleanup: give job-completed hook a .sh extension. by @igorpecovnik in armbian/configng#945runner-cleanup: keep Armbian build images, stop wiping build cache hourly. by @igorpecovnik in armbian/configng#943runners: derive host from github_label custom field. by @igorpecovnik in armbian/armbian.github.io#331runners: make remove work via --api with named params and a range. by @igorpecovnik in armbian/configng#942software: add git_cdn module (GitHub caching git+http proxy). by @igorpecovnik in armbian/configng#938sunxi: patch maint. by @EvilOlaf in armbian/build#9957Surface flash write failures instead of a blank error screen. by @SuperKali in armbian/imager#150ti: configs: boards: Add initial BeagleBadge board support. by @jonaswood01 in armbian/build#9935ti: configs: boards: Add TMDS64EVM (AM64x SoC) board support. by @jonaswood01 in armbian/build#9962uwe5622: fix -Wmissing-prototypes warnings (155 -> 2). by @iav in armbian/build#9970Wifi: enable, connect every board, and record interfaces + IPs in NetBox. by @igorpecovnik in armbian/autotests#9youyeetoo-yy3588: rework DTS for mainline and switch audio to ES8388. by @SuperKali in armbian/build#9960View the full article
  26. This week's work centers on kernel and board enablement, CI infrastructure and caching, and user-facing tooling improvements across the imager and configuration utilities. On the kernel and board front, Rockchip edge moved to 7.1 and mainline was bumped to 7.1-rc7, while the Raspberry Pi 4B legacy target was re-enabled after a brief revert of the BCM2711 kernel bumps. New board support landed for BeagleBadge and TMDS64EVM (AM64x) on the TI platform, the Anbernic RG DS RK3568 handheld as CSC, and the Youyeetoo YY3588 received a mainline DTS rework with ES8388 audio routing. Several long-standing fixes were merged, including a meson64 GPIO can_sleep regression breaking 1-Wire, JMicron JMB582/JMB585 32-bit DMA forcing, and QRB2210 U-Boot load address corrections. A substantial CI and caching effort introduces a new git_cdn module providing a GitHub caching git+http proxy, an apt-cacher-ng configng module, and multi-arch Docker images for both. GitHub Actions runners now export per-runner apt, ghcr, ccache, and proxy environments from the NetBox registry, with added retry guards, SSH/rsync timeouts, and workspace ownership reconciliation between jobs. The rootfs builder now routes mmdebstrap through APT_PROXY_ADDR when configured. User-facing changes focus on the Armbian Imager and first-run experience. The imager gained marquee scrolling for long board names, a "Create new profile" shortcut, accurate progress-phase reporting, and surfaced flash write failures in place of blank error screens. The first-login flow now runs automatically on freshly-flashed boards, and armbian-firstrun uses atomic writes for armbianEnv.txt MAC randomization to prevent corruption. #Armbian #EmbeddedLinux #Rockchip #CICD #SBC ChangesAdd images for new board and missing images for existing boards. by @jonaswood01 in armbian/armbian.github.io#329Add module_aptcacherng: apt-cacher-ng caching proxy. by @igorpecovnik in armbian/configng#935add multi-arch git_cdn image build. by @igorpecovnik in armbian/docker-armbian-build#29Add new target boards for uefi arm64/x86 edge branch. by @igorpecovnik in armbian/armbian.github.io#327add usbip support to missing current 6.18.y configs. by @EvilOlaf in armbian/build#9971add usbip to more kernels. by @EvilOlaf in armbian/build#9973arm64: dts: rockchip: yy3588: bind ES8388 codec via es8328 driver. by @SuperKali in armbian/linux-rockchip#499armbian-firstrun: use atomic write for armbianEnv.txt MAC randomization. by @mingzhangqun in armbian/build#9937ata: ahci: force 32-bit DMA for JMicron JMB582/JMB585. by @HeyMeco in armbian/linux-rockchip#504Auto-run first-login on freshly-flashed boards. by @igorpecovnik in armbian/autotests#6ayn-thor: fix fused kernel args in LinuxLoader.cfg cmdline, add rw rootwait. by @eldandaman in armbian/build#9969bcm2711: bump kernels — legacy 6.18, current 7.0, edge 7.1. by @igorpecovnik in armbian/build#9964board: add Anbernic RG DS (RK3568 dual 4" 640x480 handheld) as CSC. by @crackerjacques in armbian/build#9934bootscript: rk35xx: simplify armbianEnv.txt corruption detection. by @mingzhangqun in armbian/build#9953bump mainline to 7.1-rc7. by @EvilOlaf in armbian/build#9950ci: build current apt-cacher-ng image (trixie/3.7.x). by @igorpecovnik in armbian/docker-armbian-build#28ci: cache GitHub runners from NetBox to github-runners.jq. by @igorpecovnik in armbian/armbian.github.io#328docs(git_cdn): add GCDN001 help header/footer markdown. by @igorpecovnik in armbian/configng#939docs: document gitproxy GITHUB_MIRROR and GITPROXY_ADDRESS. by @igorpecovnik in armbian/documentation#925feat(boards): scroll long board names with marquee. by @SuperKali in armbian/imager#146feat(flash): show only the progress phases that will actually run. by @SuperKali in armbian/imager#148feat(profiles): add "Create new profile" shortcut to the flash picker. by @SuperKali in armbian/imager#147Fix auto-firstlogin in CI: ssh-dut 1234 fallback + reconcile trigger. by @igorpecovnik in armbian/autotests#7fix(extensions/lvm): Fix support for non-ext filesystems. by @ojafuenf in armbian/build#9889fix(interactive): parse case alternatives in get_kernel_info_for_branch. by @iav in armbian/build#9798fix(mvebu-6.18): drop SysRq-via-BREAK patch, fixed upstream in 6.18.35. by @iav in armbian/build#9958fix(rockchip64-7.0): drop SysRq-via-BREAK patch, fixed upstream in 7.0.12. by @igorpecovnik in armbian/build#9956fix(rootfs/qemu-static): use direct armhf exec probe instead of broken arch-test gate. by @iav in armbian/build#9820fix(ui): keep marquee text aligned while scrolling. by @SuperKali in armbian/imager#149Fix: EasePi-A2 Boot & Ethernet on Vendor Kernel. by @ifroncy01 in armbian/build#9946gha/chunks: export per-runner apt/ghcr/ccache env from runner registry. by @igorpecovnik in armbian/os#471gha/chunks: export per-runner caches in images job. by @igorpecovnik in armbian/os#472gha: add retry and empty-result guard to NetBox server list step. by @igorpecovnik in armbian/os#469gha: add ssh/rsync timeouts to image upload so dead servers fail fast. by @igorpecovnik in armbian/os#473image/compress-checksum: cap compression threads (default 32). by @igorpecovnik in armbian/build#9949meson64: fix GPIO can_sleep regression that breaks w1-gpio (1-Wire). by @adeepn in armbian/build#9959module_aptcacherng: use current ghcr.io/armbian image. by @igorpecovnik in armbian/configng#937orangepi4pro: Add Orange Pi 4 Pro board photo. by @shkolnik in armbian/armbian.github.io#330qrb2210: fix U-Boot load addresses and root partition for 2GB variant. by @govindsi in armbian/build#9925README: document full image catalog (framework, automation, caching proxies). by @igorpecovnik in armbian/docker-armbian-build#31Revert "bcm2711: bump kernels — legacy 6.18, current 7.0, edge 7.1". by @EvilOlaf in armbian/build#9965rk35: add rk3568 DDR 1056MHz v1.23 and BL31 v1.45. by @crackerjacques in armbian/rkbin#45rockchip: bump edge kernel to 7.1. by @paolosabatino in armbian/build#9955rootfs: route mmdebstrap through APT_PROXY_ADDR when set. by @igorpecovnik in armbian/build#9961rpi4b: re-enable legacy target. by @EvilOlaf in armbian/build#9968rtl8192eu: fix -Wmissing-prototypes for 121 functions. by @iav in armbian/build#9963runner-clean: export per-runner proxy env and route git via git_cdn. by @igorpecovnik in armbian/actions#20runner-clean: export per-runner xz memory cap (IMAGE_XZ_MEMLIMIT). by @igorpecovnik in armbian/actions#22runner-clean: normalize git_proxy to one trailing slash. by @igorpecovnik in armbian/actions#21runner-clean: selectively chown root-owned workspace files before checkout. by @igorpecovnik in armbian/actions#23runner-cleanup: chown workspace after each job via JOB_COMPLETED hook. by @igorpecovnik in armbian/configng#944runner-cleanup: give job-completed hook a .sh extension. by @igorpecovnik in armbian/configng#945runner-cleanup: keep Armbian build images, stop wiping build cache hourly. by @igorpecovnik in armbian/configng#943runners: derive host from github_label custom field. by @igorpecovnik in armbian/armbian.github.io#331runners: make remove work via --api with named params and a range. by @igorpecovnik in armbian/configng#942software: add git_cdn module (GitHub caching git+http proxy). by @igorpecovnik in armbian/configng#938sunxi: patch maint. by @EvilOlaf in armbian/build#9957Surface flash write failures instead of a blank error screen. by @SuperKali in armbian/imager#150ti: configs: boards: Add initial BeagleBadge board support. by @jonaswood01 in armbian/build#9935ti: configs: boards: Add TMDS64EVM (AM64x SoC) board support. by @jonaswood01 in armbian/build#9962uwe5622: fix -Wmissing-prototypes warnings (155 -> 2). by @iav in armbian/build#9970Wifi: enable, connect every board, and record interfaces + IPs in NetBox. by @igorpecovnik in armbian/autotests#9youyeetoo-yy3588: rework DTS for mainline and switch audio to ES8388. by @SuperKali in armbian/build#9960View the full article
  27. I have sent a new pr. basically you do something like this: code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } ./compile.sh BOARD=orangepioneplus BRANCH=edge kernel-config This will spawn a kernel menuconfig where you can modify the kernel config. This menu also takes all necessary dependencies into account. Once everything is done the kernel config file in config/kernel is modified. If you use a tool like vscode this will automatically visualize. If you manually change the kernel config file and want to check if your settings are persistent to rewriting you can use the code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } rewrite-kernel-config command similar to the one above.
  28. You was right, i entered wrong name in /boot/armbianEnv.txt now it is: verbosity=7 bootlogo=false console=both extraargs=cma=256M overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588s-orangepi-5.dtb rootdev=UUID=... rootfstype=ext4 overlays=orangepi-5-ap6275p usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u But wifi still not working I also recorded successful launch of Joshua-Riek ubuntu Both with dtb files loading log Armbian Working FDT set to 12000000 398 bytes read in 56 ms (6.8 KiB/s) Applying kernel provided DT overlay rockchip-rk3588-orangepi-5-ap6275p.dtbo Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Ubuntu Joshua-Riek Retrieving file: /boot/initrd.img-6.1.0-1025-rockchip 16754764 bytes read in 1362 ms (11.7 MiB/s) Retrieving file: /boot/vmlinuz-6.1.0-1025-rockchip 53682688 bytes read in 4334 ms (11.8 MiB/s) append: root=UUID=... rootwait rw console=ttyS2,1500000 console=tty1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory Retrieving file: /lib/firmware/6.1.0-1025-rockchip/device-tree/rockchip/rk3588s-orangepi-5.dtb 260529 bytes read in 287 ms (885.7 KiB/s) Retrieving file: /lib/firmware/6.1.0-1025-rockchip/device-tree/rockchip/overlay/orangepi-5-ap6275p.dtbo 398 bytes read in 329 ms (1000 Bytes/s) Fdt Ramdisk skip relocation and key differense in the end: Armbian -> [ 117.425678] rk-pcie fe190000.pcie: PCIe Link Fail, LTSSM is 0x3, hw_retries=0 Joshuas Ubuntu -> [ 20.633531] rk-pcie fe190000.pcie: PCIe Link up, LTSSM is 0x30011 Ai tolds me it is PHY problems or wrons vcc3v3_pcie2x1l2 power consumption setup but is same for Joshua-Riek and Armbian (1800000 mA) Attaching full logs u-Ubuntu a-Armbian a_wifi_uart_debug u_wifi_uart_debug
  29. @alexc Hi, thanks for the response and for the patch! Just to clarify — we actually used your PCIe BSP fix (commit a9eaa51d) and the stock, unmodified hailo_pci 4.21.0 driver from the official Hailo GitHub (v4.21.0 tag). No changes were made to the Hailo driver side at all. Earlier in the process we had experimented with workarounds on the Hailo driver (INTx bypass + polling thread), but those were reverted completely before the final test. The report describes the end state: your kernel patch + stock driver. Result with your fix: hailo 0000:04:00.0: Enabled MSI interrupt No INTx fallback, no polling. Load average dropped from 18+ to ~12, Frigate CPU from ~485% to ~83% (real inference on 9 cameras). Regarding the GitHub PR / kernel patch — that would be great. The fix is clearly in the right place (PCIe driver), and a proper patch submission would help other Allwinner A733 users with PCIe devices.
