Either, you need to add it to the "extraargs=" (optionally "extraboardargs=") line in /boot/armbianEnv.txt, in case create those lines, if missing: extraargs=mem=16G Or, when adding it to /boot/boot.cmd directly, you need to generate /boot/boot.scr from it: mkimage -C none -A arm64 -T script -d /boot/boot.cmd /boot/boot.scr The initramfs does not need to be regenerated in any case.
I can say that a way has been found on a board to be able to run a minimal arch Linux distro. Unfortunately it is not easy and we are still in an initial testing phase. 1) Open the case and press the button located behind the audio jack during power on. At this point, use the USB male cable to load the modified image with Linux PC and Sunxi-fel utility to boot from USB. 2) Boot with a USB stick and USB keyboard hub and check that the Linux kernel starts. 3) Upload Linux image to eMMC. I am not at risk of carrying out point 2 and I will have to solder the cables for the serial port to understand where the problem is in my case. If there are any updates I'll let you know. If it is possible to create an image ready to be directly on emmc this could be within everyone's reach.
Did you get any luck with this? I tried adding the files to /boot/overlay-user/ and set the user_overlays in armbianEnv.txt but I didn't succeeded. I followed this guide: https://docs.armbian.com/User-Guide_Armbian_overlays/
Orange pi zero 3 RTS CTS not working in python script
vtech replied to vtech's topic in Allwinner sunxi
I also tried adding line "param_uart2_rtscts=1" to "/boot/armbianEnv.txt". This enabled GPIO Mode ALT2 for UART2_RTS and UART2_CTS. However, still no voltage changes on RTS or CTS pin when tried to send data over RX. Looking forward for help. Thanks in advance. P.S.: WiringPi (https://github.com/orangepi-xunlong/wiringOP.git) does not seem to be working for Orange Pi Zero 3 as it is showing H616 in output of gpio readall command Regards. -
Today I did update my 3 NanoPi Neo2 via apt update/upgrade, but only one is accessable via ssh after the update. (without SSH/SSL-conect also no conection via SFTP/WinSCP because if the timeout) The one which is accessable has after the update Welcome to Armbian 23.02.2 Bullseye with bleeding edge Linux 6.7.12-edge-sunxi64 ( Machine model: FriendlyARM NanoPi NEO 2) The two other do show prompts for user/password but doesnt login via ssh - and after some time they time out and I can reenter user/password After connecting via TTL-serial I can also enter user/password and then the Neo2 shows me: _ _ ____ _ _ _ ____ | \ | | _ \(_) | \ | | ___ ___ |___ \ | \| | |_) | | | \| |/ _ \/ _ \ __) | | |\ | __/| | | |\ | __/ (_) | / __/ |_| \_|_| |_| |_| \_|\___|\___/ |_____| Welcome to Armbian 23.8.1 Bullseye with bleeding edge Linux 6.7.12-edge-sunxi64 No end-user support: community creations System load: 266% Up time: 2 min Memory usage: 22% of 982M IP: 192.168.6.24 CPU temp: 73°C Usage of /: 54% of 15G storage/: 56% of 458G storage temp: 41°C RX today: 4.2 GiB [ General system configuration (beta): armbian-config ] Last login: Tue Dec 27 14:13:30 +03 2022 from 192.168.6.17 on pts/0 After prssing Ctrl-C: ^C Armbian 23.8.1 bullseye ttyS0 npi-neo2-24 login: For non-existing users I do get a timeout at the serial-TTL-Port: npi-neo2-24 login: maxandmoritz Password: Login timed out after Armbian 23.8.1 bullseye ttyS0 npi-neo2-24 login: but nothing more - and this time the login doenst time out. But the armbian seems to boot up correctly, because the SAMBA-server on the Neo2 is available/useable. So the only way to change something in the system will be to make modifikations to the SDCard - but which change have I to do? Maybe its something between the Neo2 Revisions 1&2 (not/no Black Revision). Does anyone got a glue/idea for me? Thanks in advance Guido
https://github.com/raspberrypi/libcamera https://github.com/raspberrypi/picamera2 Ubuntu Noble already has this available; sudo apt install python3-libcamera
Should be 7
There are some issues with Helios64 patches for 6.9.y https://github.com/armbian/build/pull/6691 Please check notes.
This is certainly not deliberately and will probably be fixed soon. Open a bug and / or report here.
@jock Hello sir, first of all, thank you for your great work. I'm trying to remove the currently installed armbian and install another version. I assume that i can do it with the multitool? But my problem is the device won't boot to multitool anymore, but it goes straight to armbian. is there a step i'm missing? Thanks in advance.
please post output of the following commands while the printer is plugged in the usb and is turned on. ls /dev/tty* and lsusb i never had problems with usb serial communication with armbian before. please check your klipper make menuconfig settings and that it is exactly what is intended for your printer mainboard. here is the guide for your printer.
Waydroid for rk3588 with armbian edge (Panthor, kernel 6.8)
ずっと一人 replied to Willzen's topic in Orange Pi 5 Plus
Is there any way to upgrade this Armbian and Waydroid to the latest? -
the manjaro is my main pc, it is x64 uefi, with a AMD gpu, i didnt think i can get a compatible dts this is what i got from orange pi zero 2 kernel 4.9 xrandr Screen 0: minimum 1280 x 720, current 1280 x 720, maximum 1280 x 720 default connected 1280x720+0+0 0mm x 0mm 1280x720 0.00* it is interesting, my monitor is 1920x1080 in the dmesg also show 1920x1080, but change to 1280x720, and it really show connect/disconnect, so maybe some pin is different from mainline, so maybe it communicated with monitor, but then it overwrite the settings dmesg.txt
Hi, thank for your answer ... root@orangepi5:~# armbian-add-overlay orangepi-5-sata.dts Compiling the overlay Copying the compiled overlay file to /boot/overlay-user/ Reboot is required to apply the changes after copy files and directory to m2 sata disk and reboot ... And there it stays... Please helpme, It's a new 500GB m2 sata 2242 drive that I bought for this opi5 I currently use the "rkspi_loader.img" from OPI5 Observation: This is the only version that runs smoothly on my opi5
https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first Don't expect wifi to work.
Thank you for your testing and update.
First attempt to add support for Radxa Rock 3C
north1 replied to Endian's topic in Advanced users - Development
Perfect. Thank you very much -
Description New codec and hub code for HDMI and analog sound on Allwinner H616 and H618 SOCs, including all the bits and pieces to implement the code (dts and configs). How Has This Been Tested? The patch was implemented on a recent fork of armbian build main. two images were built, Debian bookworm server from edge and Debian bookwork desktop xfce from current. Server testing: Analog audio was unmuted using alsamixer by unmuting Left out DACL and Right out DACR. Mpg123 was installed and used to play an mp3 file. Aplay speaker-test was also used to check left and right audio. Playing the mpg file and the speaker-test were also performed from an HDMI monitor connection. root@orangepizero3:~# aplay -l **** List of PLAYBACK Hardware Devices **** card 0: audiocodec [audiocodec], device 0: CDC PCM Codec-0 [CDC PCM Codec-0] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: HDMI [HDMI], device 0: ahub_plat-i2s-hifi i2s-hifi-0 [ahub_plat-i2s-hifi i2s-hifi-0] Subdevices: 1/1 Subdevice #0: subdevice #0 root@orangepizero3:~# aplay -L null Discard all samples (playback) or generate zero samples (capture) hw:CARD=audiocodec,DEV=0 audiocodec, CDC PCM Codec-0 Direct hardware device without any conversions plughw:CARD=audiocodec,DEV=0 audiocodec, CDC PCM Codec-0 Hardware device with all software conversions default:CARD=audiocodec audiocodec, CDC PCM Codec-0 Default Audio Device sysdefault:CARD=audiocodec audiocodec, CDC PCM Codec-0 Default Audio Device dmix:CARD=audiocodec,DEV=0 audiocodec, CDC PCM Codec-0 Direct sample mixing device hw:CARD=HDMI,DEV=0 HDMI, ahub_plat-i2s-hifi i2s-hifi-0 Direct hardware device without any conversions plughw:CARD=HDMI,DEV=0 HDMI, ahub_plat-i2s-hifi i2s-hifi-0 Hardware device with all software conversions default:CARD=HDMI HDMI, ahub_plat-i2s-hifi i2s-hifi-0 Default Audio Device sysdefault:CARD=HDMI HDMI, ahub_plat-i2s-hifi i2s-hifi-0 Default Audio Device dmix:CARD=HDMI,DEV=0 HDMI, ahub_plat-i2s-hifi i2s-hifi-0 Direct sample mixing device root@orangepizero3:~# ANALOG tests: sysadmin@orangepizero3:~$ mpg123 Scarborough\ Fair.mp3 High Performance MPEG 1.0/2.0/2.5 Audio Player for Layers 1, 2 and 3 version 1.31.2; written and copyright by Michael Hipp and others free software (LGPL) without any warranty but with best wishes Terminal control enabled, press 'h' for listing of keys and functions. Playing MPEG stream 1 of 1: Scarborough Fair.mp3 ... MPEG 1.0 L III cbr96 44100 j-s Title: Scarborough Fair/canticle Artist: Paul Simon Comment: Album: Art Garfunkel / The Graduate - Year: 1968 Genre: Soundtrack sysadmin@orangepizero3:~$ speaker-test -t wav -c 2 speaker-test 1.2.8 Playback device is default Stream parameters are 48000Hz, S16_LE, 2 channels WAV file(s) Rate set to 48000Hz (requested 48000Hz) Buffer size range from 32 to 131072 Period size range from 16 to 65536 Using max buffer size 131072 Periods = 4 was set period_size = 32768 was set buffer_size = 131072 0 - Front Left 1 - Front Right Time per period = 0.737457 0 - Front Left 1 - Front Right Time per period = 2.737752 0 - Front Left 1 - Front Right HDMI tests: sysadmin@orangepizero3:~$ mpg123 -a hw:1,0 Scarborough\ Fair.mp3 High Performance MPEG 1.0/2.0/2.5 Audio Player for Layers 1, 2 and 3 version 1.31.2; written and copyright by Michael Hipp and others free software (LGPL) without any warranty but with best wishes Terminal control enabled, press 'h' for listing of keys and functions. Playing MPEG stream 1 of 1: Scarborough Fair.mp3 ... MPEG 1.0 L III cbr96 44100 j-s Title: Scarborough Fair/canticle Artist: Paul Simon Comment: Album: Art Garfunkel / The Graduate - Year: 1968 Genre: Soundtrack [src/libout123/libout123.c:out123_play():700] error: Error in writing audio, wrote only 3824 of 4608 (Success?)! [0:14] Decoding of Scarborough Fair.mp3 finished. sysadmin@orangepizero3:~$ speaker-test -D hw:1,0 -t wav -c 2 speaker-test 1.2.8 Playback device is hw:1,0 Stream parameters are 48000Hz, S16_LE, 2 channels WAV file(s) Rate set to 48000Hz (requested 48000Hz) Buffer size range from 32 to 131072 Period size range from 16 to 65536 Using max buffer size 131072 Periods = 4 was set period_size = 32768 was set buffer_size = 131072 0 - Front Left 1 - Front Right Time per period = 0.729233 0 - Front Left 1 - Front Right Time per period = 2.737477 0 - Front Left 1 - Front Right ^CTransfer failed: Bad address sysadmin@orangepizero3:~$ Results: all tests worked as expected. Desktop testing: The server tests were performed from a terminal window on the desktop image. In addition a music video with audio was played on chromium youtube. An mp3 music file was played with the Celluloid app. The tests were done on both analog and HDMI, using pulseaudio to switch between outputs. All tests performed as expected. There was an anomaly observed when using the pulseaudio volume control on the analog output. When pulse audio volume control was selected, the analog audio started to play at high speed. This did not happen on HDMI output. The issue can be worked around by using pulseausio volume control configure tab to turn off HDMI when using the analog output. This patch, a repository with the patch and a few images were posted to the Allwinner sunxi community forum from where a number of members reported successful tests. https://forum.armbian.com/topic/37718-sound-on-h616h618-socs/ Checklist: [ x ] My changes generate no new warnings [ x] Any dependent changes have been merged and published in downstream modules View the full article
H2/H3: "old problem" Link (eth0) is Up/Down syndrom
Dav replied to guidol's topic in Allwinner sunxi
Update: I "fixed it" with https://mmonit.com/wiki/Monit/Installationmonit Basically, each 60 seconds it will check if my "eth0" ethernet interface is up. If not, it tries to wake it up. If for some reason, the port/board cannot wake up the ethernet interface... I have a secondary check (ping Google DNS IP 10 times in a row -> one per minute). If 10/10 failed, it reboots the board. Is not ideal, but now I have a "hands free" board. This is in a countryside, so before this "patch", I had to take my car to manually power-cycle the board hahaha Here you have, the config I used: ## Start Monit in the background (run as a daemon): # set daemon 60 # check services at 60 seconds intervals with start delay 120 # optional: delay the first check by 2-minutes (by # # default Monit check immediately after Monit start) # set log /var/log/monit.log set idfile /var/lib/monit/id set statefile /var/lib/monit/state set eventqueue basedir /var/lib/monit/events # set the base directory where events will be stored slots 100 # optionally limit the queue size ############################################################################### ## Services ############################################################################### ## check network eth0 with interface eth0 start program = "/sbin/ifconfig eth0 up" stop program = "/sbin/ifconfig eth0 down" if link down then restart check host 8.8.8.8 with address 8.8.8.8 if failed ping count 10 size 128 with timeout 10 seconds then exec "/usr/sbin/reboot" I hope this can be helpful to somebody. Regards -
Hi, is posible to add Canbus by a MCP2515 in a spi port ? thanks!
Is there still an image somewhere to try? I just got back from being away and link for the image above is a 404. I tried the official download. 24.5 No luck. After pressing the center button 3 times it tries to boot but cannot initialize ethernet or retrieve pxelinux.cfg. It fails with what looks like a prompt. But it does not do anything. I have a photo but it fails to attach.
I feel like I should mention I'm using an older version of Armbian because Colton's fix doesn't work on the last version. I'm using 24.2.1 Bookworm.
