  2. Request for Official SECURE Firmware for H616 Device
  3. @José Manuel Márquez Luque try these images https://github.com/NickAlilovic/build/releases/tag/20250306
  4. At a glance, unless you see your board at https://armbian.com/download, chances are that no one else has gotten that board working. Might be better to post under "Other Families" for unsupported board stuff. @Werner may move later ... Might be crashing. Might be redirecting kernel to a different UART. May be worth checking earlycon and console settings in kernel args? You can try to pass break=premount or similar arguments to pause boot and allow you to poke around and see what's going on?
  5. HI, It looks like you have an RK3518 chip from your photo, and not the 3528? Or was that a typo? In any case I also bought a box from AliExpress. It looks similar to mine with the 3518 chip. If there is a way to extract the ROM Image from my box I can maybe upload it for you somewhere?
  6. I tested the new version (Armbian_26.2.0-trunk.591_Orangepi3-lts_forky_current_6.18.18_minimal) in terms of bloototh and it's OK... but there are errors that rule out this image. Namely, the system lacks 4 working processor cores 🙂 ... only one. Something is wrong at startup because the green LED is on and the red LED is constantly flashing/pulsing. Bringing up secondary CPUs ... [ 5.092655] CPU1: failed to come online [ 5.092666] CPU1: failed in unknown state : 0x0 [ 10.217311] CPU2: failed to come online [ 10.217324] CPU2: failed in unknown state : 0x0 [ 15.341948] CPU3: failed to come online [ 15.341961] CPU3: failed in unknown state : 0x0 [ 15.342047] smp: Brought up 1 node, 1 CPU [ 15.342057] SMP: Total of 1 processors activated. [ 15.342063] CPU: All CPU(s) started at EL2 [ 15.342112] CPU features: detected: 32-bit EL0 Support [ 15.342119] CPU features: detected: 32-bit EL1 Support [ 15.342129] CPU features: detected: CRC32 instructions [ 15.342146] CPU features: detected: PMUv3 [ 15.342193] alternatives: applying system-wide alternatives It's some kind of incompatibility: U-Boot / TF-A / kernel .... Similar errors are found in the version uploaded by: armbian imager (minimal / cli / debian - trixie) more information: https://paste.armbian.com/afokonucej command "poweroff" not working ! ? On version: Ubuntu / minimal (cli) there are the same errors regarding CPU...etc ..................................... dmesg | grep "CPU" [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: kernel page table isolation forced ON by KASLR [ 0.000000] CPU features: detected: Kernel page table isolation (KPTI) [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.006129] smp: Bringing up secondary CPUs ... [ 5.092344] CPU1: failed to come online [ 5.092356] CPU1: failed in unknown state : 0x0 [ 10.216761] CPU2: failed to come online [ 10.216771] CPU2: failed in unknown state : 0x0 [ 15.341165] CPU3: failed to come online [ 15.341176] CPU3: failed in unknown state : 0x0 [ 15.341242] smp: Brought up 1 node, 1 CPU [ 15.341258] CPU: All CPU(s) started at EL2 [ 15.341291] CPU features: detected: 32-bit EL0 Support [ 15.341297] CPU features: detected: 32-bit EL1 Support [ 15.341309] CPU features: detected: CRC32 instructions [ 16.273971] ledtrig-cpu: registered to indicate activity on CPUs [ 17.351303] sun50i_cpufreq_nvmem: Using CPU speed bin speed0 .........................
  7. You may want to check out this thread. There's someone else doing the same with an Orange Pi 5. Might be worth comparing notes with @KhanhDTP
  8. seems like openwrt already figured this and the fix is actually upstream: https://github.com/torvalds/linux/commit/c3fe7071e196e25789ecf90dbc9e8491a98884d7 (also see https://github.com/immortalwrt/immortalwrt/commit/7ef19bb9cd59f5018fc96b01a5465ed84038cfe8) This may tell that one or more Armbian patches make things worse , no clue though which one if any.
  9. Yesterday
  10. Hi @Werner, I bought an UART USB device and followed your video here https://www.youtube.com/watch?v=UpVMO7gbnYM to read boot logs. I'm not a huge expert but looks like there is a problem finding /boot when two nvme are connected. Please find attached the following logs: uart-bootcorrectnvme.log -> one nvme plugged (the one with os installed in slot 1) - works! uart-bootdualnvme.log -> two nvme plugged (the one with os installed in slot 1) - fails! uart-bootmicrosd.log -> two nvme plugged + microsd plugged - works! Tests have been executed with official 30W Radxa Power adapter ( same result with POE+ 25W hat) Please, let me know if there is anything else I can provide. Thanks uart-bootcorrectnvme.log uart-bootdualnvme.log uart-bootmicrosd.log
  11. @Werner I have tried your command but no success. Here is what a clean boot of Armbian shows. I also ran some commands with the outputs below.
  12. sven-ola
    Hello @1111Windows, you are booting an unknown u-boot from NVME that does not find any meaningful data stored on the NVME. You may need to re-insert the SD card or swap to a working SD card or so. I attach the (timestamp stripped for better diff) version from you (forum.txt) and the expected UART output on my RV2 (minicom.txt). The latter I have captured after re-downloading and SD-flashing the mentioned trixie-gnome img which has a root file system with UUID=8f6e5f9c-3108-4e4d-8fbd-10a8295d396e. HTH // Sven-Ola forum.txt minicom.txt
  13. https://docs.armbian.com/Process_Contribute/#adding-a-new-board
  14. Heres what I am seeing on my screen https://drive.google.com/file/d/1SSNnvOy-BjxAzklcAoApjS2zz1HnMn-v/view?usp=sharing Heres me messing with the headphon jack https://drive.google.com/file/d/1Z2Guva-FWYv2mu3VCPujXPoc7r_iqpB6/view?usp=sharing
  15. I ran into what appears to be the same issue (see my log). I have added the suggested qemu-user-static package, which forced removal of another qemu- family package I had previously installed to work around problems with binfmt. Not only did it compile correctly, it also ran so much faster, as you can see in the number of log lines for this build! Thank you for the assistance and getting me on the right track with the right package selection! Best Regards, Lobosito
  16. @tin harden A7A mainline is still a WIP.
  17. @Thur_Wander For debugging purposes, UART is highly recommended. Use balena Etcher to write the compiled image to your SD card.
  18. Last week
  19. Hi, I am here in 2026 with the Amrbian 26.2.1, I've tried the proposed fix from @c0rnelius but it's not working on my OS version. If anyone has any updated solution that'd be amazing. Thank you
  20. I will try downgrading u-boot next once I find the older package somewhere. Kernel does not seem to be the cause given that it has been working fine with both my own build 6.6.122 and 6.6.128 before and rolling back not helping. New device is something I had on my mind for a while. But given the RAM and SSD prices these days, I do not really want to overspend. Not to mention that the SBC landscape has not been that great lately when it comes to compact NAS offerings. HC4 is five years old at this point. Many even recommend N100 but this is a whole different size category.
  21. hello ,my box is mortal t1 2g8rom and motherboard show mortal t2 v2.0 it's broken and i wanna make linux boot what's the most version to be able for my box
  22. Good morning I have big problem I have tv box Transpeed-H616_ I update with orange pi But i can't back to old firmware
  23. Hi Armbian_25.5.1_Rpi4b_bookworm_current_6.12.28 broken after last upgrade. I run apt upgrade which installed kernel 6.18.10. It breaks ZFS. Provided ZFS version, 2.3.2, supports kernels up to 6.14. Don't forget a snapshot before "apt upgrade" 🙂 Regards, Chris
  24. what board did you replace it with?
  25. I have a T9 2017 rk3328 box running Ubuntu xcfe many hours for downloading. There are not problems but xcfe displays lunchs himself many times and i have to close 20 or more instances of this application when checking the progress. Box is not crashed by this funny clonning. is it possible to avoid this? p.d. la test trunk
  26. My ROCK3A has a jumper option to disable SPI clock, so whole SPI will be bypassed and only SD-card works then. I power with fixed 12V (USB-C pigtail). I do not know now what version the board/PCB is. AFAIR from Radxa docs other versions have no such jumper. Maybe you already tried/know all this. Maybe wipe the SPI via rkdevelop. W.r.t. Rockchip SBC's (various brands) I am a bit confused what boot-device prefence/priority is. From schematics I saw it depends on a resistor value, but many boards in the world and endless resistor values possible.
