tanod replied to maximumsettings's topic in Orange Pi 5
Hey @amazingfate, Thank you very much for the reply! I managed to build it but still a lot of errors in the log... #moonlight-qt/app/moonlight 00:00:00 - SDL Info (0): Compiled with SDL 2.30.0 00:00:00 - SDL Info (0): Running with SDL 2.30.0 00:00:00 - Qt Info: No translation available for "bg_BG" 00:00:00 - SDL Info (0): Detected Wayland 00:00:00 - Qt Warning: qrc:/gui/main.qml:13:1: QML ApplicationWindow: ToolTip must be attached to an Item 00:00:00 - Qt Info: Found "gamecontrollerdb.txt" at "/home/noone/.cache/Moonlight Game Streaming Project/Moonlight/gamecontrollerdb.txt" 00:00:00 - SDL Info (0): Loaded 335 new gamepad mappings Couldn't open plugin directory: No such file or directory No plugins found, falling back on no decorations 00:00:00 - SDL Warn (0): Failed to create test window with platform flags: Installed Vulkan doesn't implement the VK_KHR_surface extension 00:00:00 - SDL Info (0): V-sync disabled libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 00:00:00 - SDL Info (0): Skipping VAAPI fallback driver names on libva 2.20+ 00:00:00 - SDL Error (0): Failed to initialize VAAPI: -1 libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 00:00:00 - SDL Info (0): Skipping VAAPI fallback driver names on libva 2.20+ 00:00:00 - SDL Error (0): Failed to initialize VAAPI: -1 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): Trying DrmRenderer for codec hevc_rkmpp due to preferred pixel format: 0xb3 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Info (0): Trying SdlRenderer for codec hevc_rkmpp due to compatible pixel format: 0xe4 00:00:00 - SDL Warn (0): No renderer can handle output from decoder: hevc_rkmpp 00:00:00 - SDL Info (0): Trying SdlRenderer for codec hevc_cuvid due to preferred pixel format: 0x9f 00:00:00 - SDL Info (0): Trying DrmRenderer for codec hevc_cuvid due to compatible pixel format: 0x9f 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Info (0): Trying PlVkRenderer for codec hevc_cuvid due to compatible pixel format: 0x9f 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Warn (0): No renderer can handle output from decoder: hevc_cuvid 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): Trying DrmRenderer for codec hevc_rkmpp due to preferred pixel format: 0xb3 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Info (0): Trying SdlRenderer for codec hevc_rkmpp due to compatible pixel format: 0xe4 00:00:00 - SDL Warn (0): No renderer can handle output from decoder: hevc_rkmpp 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): Trying SdlRenderer for codec hevc_cuvid due to preferred pixel format: 0x9f 00:00:00 - SDL Info (0): Trying DrmRenderer for codec hevc_cuvid due to compatible pixel format: 0x9f 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Info (0): Trying PlVkRenderer for codec hevc_cuvid due to compatible pixel format: 0x9f 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Warn (0): No renderer can handle output from decoder: hevc_cuvid libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 00:00:00 - SDL Info (0): Skipping VAAPI fallback driver names on libva 2.20+ 00:00:00 - SDL Error (0): Failed to initialize VAAPI: -1 libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 00:00:00 - SDL Info (0): Skipping VAAPI fallback driver names on libva 2.20+ 00:00:00 - SDL Error (0): Failed to initialize VAAPI: -1 00:00:00 - SDL Warn (0): VDPAU is not supported on Wayland 00:00:00 - SDL Warn (0): VDPAU is not supported on Wayland 00:00:00 - SDL Error (0): Unable to find working decoder for format: 200 00:00:00 - SDL Error (0): Unable to load FFmpeg decoder 00:00:00 - SDL Info (0): V-sync disabled libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 00:00:00 - SDL Info (0): Skipping VAAPI fallback driver names on libva 2.20+ 00:00:00 - SDL Error (0): Failed to initialize VAAPI: -1 libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 00:00:00 - SDL Info (0): Skipping VAAPI fallback driver names on libva 2.20+ 00:00:00 - SDL Error (0): Failed to initialize VAAPI: -1 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): Trying SdlRenderer for codec av1_cuvid due to preferred pixel format: 0x9f 00:00:00 - SDL Info (0): Trying DrmRenderer for codec av1_cuvid due to compatible pixel format: 0x9f 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Info (0): Trying PlVkRenderer for codec av1_cuvid due to compatible pixel format: 0x9f 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Warn (0): No renderer can handle output from decoder: av1_cuvid 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): Trying DrmRenderer for codec av1_rkmpp due to preferred pixel format: 0xb3 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Info (0): Trying SdlRenderer for codec av1_rkmpp due to compatible pixel format: 0xe4 00:00:00 - SDL Warn (0): No renderer can handle output from decoder: av1_rkmpp 00:00:00 - SDL Info (0): Trying SdlRenderer for codec av1_cuvid due to preferred pixel format: 0x9f 00:00:00 - SDL Info (0): Trying DrmRenderer for codec av1_cuvid due to compatible pixel format: 0x9f 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Info (0): Trying PlVkRenderer for codec av1_cuvid due to compatible pixel format: 0x9f 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Warn (0): No renderer can handle output from decoder: av1_cuvid 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): Trying DrmRenderer for codec av1_rkmpp due to preferred pixel format: 0xb3 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): EGLRenderer: EGL doesn't support HDR rendering 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Info (0): Trying SdlRenderer for codec av1_rkmpp due to compatible pixel format: 0xe4 00:00:00 - SDL Warn (0): No renderer can handle output from decoder: av1_rkmpp libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 00:00:00 - SDL Info (0): Skipping VAAPI fallback driver names on libva 2.20+ 00:00:00 - SDL Error (0): Failed to initialize VAAPI: -1 libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 00:00:00 - SDL Info (0): Skipping VAAPI fallback driver names on libva 2.20+ 00:00:00 - SDL Error (0): Failed to initialize VAAPI: -1 00:00:00 - SDL Warn (0): VDPAU is not supported on Wayland 00:00:00 - SDL Warn (0): VDPAU is not supported on Wayland 00:00:00 - SDL Error (0): Unable to find working decoder for format: 2000 00:00:00 - SDL Error (0): Unable to load FFmpeg decoder 00:00:00 - SDL Info (0): V-sync disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): Unable to find working decoder for format: 200 00:00:00 - SDL Error (0): Unable to load FFmpeg decoder 00:00:00 - SDL Info (0): V-sync disabled 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): Unable to find working decoder for format: 2000 00:00:00 - SDL Error (0): Unable to load FFmpeg decoder 00:00:00 - SDL Info (0): V-sync disabled libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 00:00:00 - SDL Info (0): Skipping VAAPI fallback driver names on libva 2.20+ 00:00:00 - SDL Error (0): Failed to initialize VAAPI: -1 libva info: VA-API version 1.20.0 libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so libva info: va_openDriver() returns -1 00:00:00 - SDL Info (0): Skipping VAAPI fallback driver names on libva 2.20+ 00:00:00 - SDL Error (0): Failed to initialize VAAPI: -1 00:00:00 - SDL Warn (0): VDPAU is not supported on Wayland 00:00:00 - SDL Warn (0): VDPAU is not supported on Wayland 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Error (0): SDL_Vulkan_GetInstanceExtensions() #1 failed: The specified window isn't a Vulkan window 00:00:00 - SDL Info (0): Opened DRM render node: /dev/dri/renderD128 00:00:00 - SDL Info (0): GPU driver: rockchip 00:00:00 - SDL Info (0): Direct rendering via DRM is disabled 00:00:00 - SDL Info (0): DRM backend supports exporting EGLImage 00:00:00 - SDL Info (0): Color buffer is: R8G8B8A0 00:00:00 - SDL Info (0): EGL passed preflight checks. Using EGL for GL context creation. 00:00:00 - SDL Info (0): Using DRM renderer 00:00:00 - FFmpeg: [hevc_mp4toannexb @ 0xffff80cc7f80] The input looks like it is Annex B already 00:00:00 - FFmpeg: [hevc_rkmpp @ 0xffff80cc84f0] Picked up an existing RKMPP hardware device 00:00:00 - FFmpeg: [hevc_rkmpp @ 0xffff80cc84f0] Wrote 335 bytes to decoder 00:00:00 - FFmpeg: [hevc_rkmpp @ 0xffff80cc84f0] Wrote 335 bytes to decoder 00:00:00 - FFmpeg: [hevc_rkmpp @ 0xffff80cc84f0] Noticed an info change 00:00:00 - FFmpeg: [hevc_rkmpp @ 0xffff80cc84f0] Decoder options: deint=true afbc=0 fast_parse=true buf_mode=0 00:00:00 - FFmpeg: [hevc_rkmpp @ 0xffff80cc84f0] Configured with size: 1280x720 | pix_fmt: drm_prime | sw_pix_fmt: nv12 00:00:00 - FFmpeg: [hevc_rkmpp @ 0xffff80cc84f0] Wrote 335 bytes to decoder 00:00:00 - FFmpeg: [hevc_rkmpp @ 0xffff80cc84f0] Received a frame 00:00:00 - SDL Info (0): FFmpeg-based video decoder chosen 00:00:00 - Qt Info: Found "gamecontrollerdb.txt" at "/home/noone/.cache/Moonlight Game Streaming Project/Moonlight/gamecontrollerdb.txt" 00:00:00 - SDL Info (0): Loaded 335 new gamepad mappings 00:00:00 - Qt Debug: Current Moonlight version: "6.1.0" 00:00:01 - Qt Info: Gamepad mappings are up to date 00:00:01 - Qt Info: Latest supported GFE server: "99.99.99.99" Is it going to be able to render 4K over 1G network, with this setup? Regards, Tano -
sudo modprobe i2c-dev ?
Brace yourself, this is going to take a long time, most likely months to years and most likely you will never get this to run. That being said, to get yourself started, you probably ought to start compiling stuff and getting yourself familiar around the armbian build framework. Do you have another SBC that is supported by Armbian? If not, it's probably best to target one of the virtual system options. I wish the documentation for this stuff was better. As of now, it is scattered throughout.
Can you confirm that you can still run X11 with Linux 6.12? -
Reluctant Linux User replied to Reluctant Linux User's topic in Radxa Rock 5 ITX
Ok, the noble_vendor_gnome image actually works. Not out of the box, you have to select "headphones" and most important, the gnome self-test "front left, front right" doesn't work. That's what was fooling me to begin with. But if you play videos, that works just fine. So for anyone on down the line confused by all of this, you need to copy a known good video or soundfile over to see if it will play. Here's the armbianmonior -u for it in any case - https://paste.armbian.com/nutedakeco However, one problem solved, new problem shows up to take its place. The current_ kernel images I've tried no longer boot off the nvme now that I have a SATA drive connected! It just sits there and hangs. The vendor images work OK, although I am seeing the SATA drive mysteriously appear and disappear upon boot. I suppose I should start a new thread for that one? I see a big long thread about SATA drives already. -
@balbes150 which bios are you using, the exactly version, i updated to 9.0.0 but i had some issue. Thanks
I don't have a custom board. I have a ROCK PI 4 SE. These boards do not come with SPI flash IC soldered on the board, but have space if one chooses to solder SPI flash himself. Since I couldn't find flash IC that Raxda recommends: https://wiki.radxa.com/Rockpi4/hardware/spi_flash (W25Q64FV; GD25Q127CSIG;XT25F32B;XT25F128B) I found equivalent to W25Q64FV. The vendor Id of FL064LIF01 is different so I'm guessing that is why it is not recognized. I read that Piter75 had support for XTX flashes at first so other flash ICs can be added maybe? This is exactly what my goal is but since I'm new to this I though posting on forum and ask for some help would not hurt. Thanks
Werner replied to Sergey Dulimov's topic in Rockchip
There are unfortunately no detailed instructions how to add new boards or board families to the build framework yet. This is a very extensive topic. However there are a few existing pull requests that should give clues like https://github.com/armbian/build/pull/7902/files No, since it is community supported use Stating section for Rockchip devices in forums. I did a quick check on your work. - dts files which aren't upstreamed (yet) shall be added in full into the dt folder of the equivalent kernel patch directory (patch/kernel/archive/rockchip64-6.16/dt to say). You can use code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } kernel-dtb build command to extract such a full tree. - this also avoids my 2nd concern which is modifying the existing orangepi-5.dtsi and disabling nodes which where later re-added with another patch. - if possible try to bump to latest mainline u-boot, so either v2025.04 or wait a bit longer for v2025.07 which is currently RC. - Yesterday
I was having similar issues with this Armbian version, but on an Orange Pi Zero 3. I suggest trying to download the image again, as they received updates today, at least the Zero 3. In my case, I wasn't able to download any packages because every time the firmware tried to update, the kernel collapsed.
I updated my guide to include the newer "pipewire" audio system software. LINK HERE. I am curious to know if you got sound working on your tv box, and how you did it. Also, what tv box are you using these days? -
The previous post was mostly for slightly older releases of Armbian which includes Ubuntu 23 or Debian 10 and lower releases installed on a Tv Box. This short guide is for Ubuntu 24.04 and later releases installed on a Tv Box. This guide should also work for latest versions of Debian (but I didn't test it). Get a generic USB "sound card" audio adapter dongle from AliExpress, eBay, Amazon (etc). See the photo posted above (LINK). These gadgets are often between $2 and $5 USD but they all are usually similar, so I just got the lowest priced one at about $2.50 USD. Insert the USB "sound card" audio adapter dongle into your tv box. Create a new regular user in Linux, and login with the new user (not root). sudo adduser {user-name} Be sure your user is in the group 'audio' and 'sudo', and be sure you have logged in as the user (not root). sudo usermod -a -G audio,sudo {username} Now let's install and setup audio sound using Pipewire and WirePlumber (but not Pulse). First, install alsa base, and mixer software. sudo apt install -y alsa-base alsa-tools alsa-utils alsamixergui qasmixer Make a backup copy of these two text files /etc/modules and /etc/modprobe.d/alsa-base.conf and save the backup copies in your home directory. cp -v /etc/modules $HOME/modules.backup cp -v /etc/modprobe.d/alsa-base.conf $HOME/alsa-base.conf.backup Edit the text file /etc/modules and write “snd-usb-audio” without quotes at the end of the file, and then save and close the file. sudo nano /etc/modules Edit the text file /etc/modprobe.d/alsa-base.conf and change and add some text sudo nano /etc/modprobe.d/alsa-base.conf Put a hash # symbol in front of every “options snd-usb-audio index=-2” that you see in the file /etc/modprobe.d/alsa-base.conf - I found two instances. Add these two lines of text to the bottom of the file /etc/modprobe.d/alsa-base.conf, and then save and close the file. alias snd-card-0 snd-usb-audio options snd-usb-audio index=0 Install pipewire and wireplumber and support files. sudo apt install -y pipewire pipewire-pulse wireplumber pipewire-audio-client-libraries gstreamer1.0-pipewire Optional to install a graphical media player smplayer, vlc, totem, (etc). and optional install a graphical audio player rhythmbox, audacious, (etc). sudo apt install -y smplayer sudo apt install -y audacious In case that the pulse audio system is still installed, we will disable it for the local user. systemctl --user --now disable pulseaudio.service pulseaudio.socket Enable pipewire for the local user systemctl --user --now enable pipewire pipewire-pulse To be sure everything will work, let's reboot sudo reboot Login as the regular user, and run some informative commands to prove that the USB dongle and the pipewire audio system are working. Use alsa player to list audio devices. aplay -l Use alsa player to list PCM audio outputs (use capital "L"). aplay -L Use wireplumber control to show status of audio outputs/inputs via pipewire. wpctl status Use wireplumber control to show a volume level of default output wpctl get-volume @DEFAULT_AUDIO_SINK@ Change the volume using alsa mixer, after running it, press up/down arrow keys, and press "q", "e", "z", "c" and "s" keys. alsamixer Change the volume +/- by ten percent using wireplumber control. wpctl set-volume @DEFAULT_AUDIO_SINK@ 10%+ wpctl set-volume @DEFAULT_AUDIO_SINK@ 10%- * Important * connect a headphone, or amplifier to the 3.5mm output jack 🎧 of the USB adapter dongle and play some audio files. aplay /usr/share/sounds/alsa/Front_Center.wav aplay /usr/share/sounds/alsa/Noise.wav You can also login to the graphical desktop such as lxde or xfce4 and open a video/media player or an audio player software and play some audio files. I used Audacious for this example. Again, audio files are available in the directory /usr/share/sounds/alsa/ From here, you can use the wpctl command (LINK) or another control program for wireplumber. Maybe some of the Pulse audio tools would still work. Audacious works fine when playing locally stored audio files. The same should be true for using SMPlayer or VLC to play video files. Note that depending on the speed of your tv box, Youtube in Chrome / Chromium is sometimes laggy, has delays and resets. Other than that, it's all good. Enjoy ♪ ♫ ☺
Yes, I know about it and I did it right after the update was finished. Maybe it was an isolated case. I did armbin-install again and test 30 reboot again and each one correctly indicated 1Gb RAM 🙂
shrink-backup - a tool for backing up sbc:s
bedna replied to bedna's topic in Software, Applications, Userspace
Well that depends, have you tried adding more space to exclude the possibility that the img actually can fit all the data? If you are using snaps without excluding the containerized mounts on one of them and not the other, it seems like a very logical conclusion that the img actually runs out of space and the "not enough space" is accurate in this situation. Edit: I have never used snaps so I don't know, but I think snaps create containerized mounts every time you boot, and you probably don't want that data on your backup anyway since it will never be used. Others can surely put more light into this than my wild guess about this. Edit 2: This made me a bit curious about how snaps actually work, if they were to randomize the mountpoints and such, but after a tiny bit of searching I found this: https://www.howtogeek.com/660193/how-to-work-with-snap-packages-on-linux/#installing-snap-packages So just editing exclude.txt and adding /snap/* and then add -t option when running shrink-backup should solve this issue. As a matter of fact, I should probably add that as default in the exclude.txt file on the repo and in the script if not using the exclude file, because I don't think you ever want that data on the image... Feedback about this would be highly appreciated before I implement that change, does snap create the directory for each SquashFS within /snap if it does not exist or will it break if it is excluded like I suggest above? Edit 3: According to this each SquashFS is mounted directly to /snap so excluding /snap/* (keeping the actual /snap directory but excluding all content) should work right? Feedback please, I know there are some of you who know how this work, @eselarm maybe? -
Manually upgrading Armbian Focal -> Jammy on ODroid N2+
bthoven replied to dev-null's topic in Odroid N2/N2+
Thanks a lot. It worked with my Beelink Ultimate GT1 from focal to jammy. -
Thanks a lot, now the wifi is working. I have this strange clone in my hands, it is marked as Vontar H618, but the Vontar image on it cannot be written to eMMC. In the case of the Transpeed image, everything is working correctly. -
Unisoc UWE5621DS on RK3566 device? calling Orange Pi experts
Igor replied to dieselnutjob's topic in Off-topic
It works with Armbian too. Just two years ago it was not in good condition -
Package `base-files` 25.* not built for trixie
Igor replied to Zoom's topic in Software, Applications, Userspace
Solved. -
I wonder if for the device tree (DTB) we can combine the Orange Pi 5 Max DTB with the HDMI Input from Orange Pi 5 Plus will make the HDMI input work.
Hqnicolas replied to Nguyễn Tất Hùng's topic in Amlogic CPU Boxes
S928X-K present in expensive devices like: VS10 Z9X ZIDOO Z9X 8K Zidoo Z3000 PRO-8K ZIDOO Z30 PRO-8K I think you could ask for the factory to support armbian http://forum.zidoo.tv/index.php http://forum.zidoo.tv/index.php?threads/beta-version-v6-4-06-for-z9x-z10-pro-z1000-pro-uhd3000-neo-s-neo-x-release.93680/page-18 -
Check this thread -
Armbian 25.5.1 Noble Gnome can not open remote dosktop
Werner replied to 唐志's topic in Software, Applications, Userspace
https://forum.armbian.com/terms -
@ScoreABSM https://github.com/armbian/build/pull/8339
jondowd replied to jondowd's topic in Orange Pi 5
Thank you. After trying 4 different chargers, the problem persists. It looks like the official chargers from Orangepi do not have the plug layout for North America, I've ordered ones that others have found successful for SBCs including the Orange Pi 5 I have, but none have solved my problem. The good news is the machine will run properly when started from a powered-down state and seems very reliable. The bad news is I will sometime need to 'restart' the board, and if I'm away from it - there's no remedy. Hopefully you can recommend other things that will fix it, as it seems no power supply will solve the Oops error when returning from a 'restart' Here's a picture the power supply I tried today and the error I'm wanting to avoid. Thanks a lot Jon D> - Last week
[SOLVED] 100% /var/log usage & rsyslogd high CPU load
ioncube replied to ioncube's topic in Radxa Zero 3W/3E
Solution found at
