  2. I troubleshooted my problem! So for some reason (I'm not sure if this is for all x88 pro 10's), the SD card needed to be under pressure on it to read Multitool. So, throughout the entire Multitool process, I needed to hold down the SD card with my thumb. I did hurt a bit, but it flashed to the EMMC
  3. Yesterday
  4. There was a devicetree related pull request sent for the audio issue on another board a month ago. It hasn't gotten any action since it was made. There apparently haven't been any devicetree-related patches in the entire Armbian build system - at least for this other board (Orange PI 5 Plus). So this would be the first. https://github.com/armbian/build/pull/8568
  5. You can install firefox. Not sure why you're not seeing it. If you're using Ubuntu Noble, firefox has issues. I think it normally installs from an Armbian repository, and last I installed it in Armbian Noble (just a couple days ago), it didn't work at all, so Armbian's firefox is, at present, non-functional. However you can install Ubuntu's, but their version is only available as a snap rather than a debian package. In my experience snap applications are slower to start up, plus they invade your home directories with a snap folder. Snap applications are also not necessarily open-source behind Cannonical's wall. Armbian desktop images also come with a Microsoft program: Visual Studio Code. And a Microsoft repository is added to the apt repositories specifically to handle updates for that program. You can, of course, uninstall it. The package name is just called code. Then you can go it: /etc/apt/sources.list.d/ and delete the microsoft file (using sudo), if it's still there. That will remove its repository. Then apt update. If there's no microsoft file there, then it's already been done. Not sure why it's taking 30 minutes to run apt update??? There is an Armbian repository that's usually slow, but it's I've never experienced it being that slow. If you really want an OS created by those who are more trustworthy, I would recommend Debian over Ubuntu. In Debian, firefox works without issue. Although the Armbian firefox hijacks your home page to keep returning to Armbian's site, despite your settings. There's a settings file somewhere that they modified to do that, you can delete their modification to stop that. I'm not sure which file it is though. I looked it up once, but never kept the info. But Ubuntu does seem to run better, and it has many more software options in its repositories, but those extras tend to be closed-source. But in Debian, there are a couple of software GUIs you can used to install snaps and flatpacks if you want to. Apparently snaps are maintained by Cannonical (Ubuntu) and tend to be closed, whereas flatpacks are openly-maintained and are apparently more efficient - though I don't have much experience with either. I prefer straight debian (.deb) packages when available.
  6. I retried that image now but with a different installation method, booting into OOWOW (?) via the Function+Reset button, control via serial debug console. I then wget the image from my local server and dd out to /dev/mmcblock0. Subsequent boot was indeed successful.
  7. Audio out of HDMI works for me out of the box. Kind of. I flashed a kernel 6.15 (that I had lying around) Cinnamon image, because all the recent Gnome images I have fail and just boot to initramfs. I then installed Gnome and enabled Wayland. I then used armbian-config to upgrade the kernel to 6.16 something. Sound test in Gnome settings work. I think this should just work with my kernel 6.15 too iirc. But also I seem to remember having problems when not using Gnome.
  8. The three holes could be access to a serial console if necessary. Ground Transmit Receive. If you want to try this, baudrate is most likely 115200 like all Allwinner SoCs.
  9. I think the easiest would be to get/build an image with mesa-vpu extension enabled. Unfortunately there is no automated way to do the stuff this extension does while building, in a live system. In general there are two ways to get hw acceleration: panthor or proprietary mali blobs. Former is from my feels better for general desktop usage and latter for hw encoding/decoding. Both cannot co-exist, no idea why. Latter needs vendor kernel branch. This would give you a Noble Gnome desktop image with Panthor driver enabled: ./compile.sh BOARD=youyeetoo-r1-v3 BRANCH=vendor BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED='browsers desktop_tools internet multimedia' DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base ENABLE_EXTENSIONS=mesa-vpu KERNEL_CONFIGURE=no RELEASE=noble Feel free to test: https://testing.armbian.de/Armbian-unofficial_25.11.0-trunk_Youyeetoo-r1-v3_noble_vendor_6.1.115_gnome_desktop.img.xz
  10. edge = 6.16.y vendor = 6.1.115 Which kernel do you actually use? Also isn't panthor the backported gpu driver for rk35xx?
  11. the current filogic kernel has no info [in github] for where it was forked from, and trying to apply incremental patches from kernel.org I found it contains pieces of 6.14 in an ostensibly 6.12 branch. @chainsx might you be able to divulge where you forked it from?
  12. PR Has been merged. I rebuilt on commit 1cf20837d27a3c09d93395f075cc305c81b4663f and things look good. Build instructions remain the same as my last post on this /_\ _ _ _ __ | |__(_)__ _ _ _ ___ _ _ _ _ ___ / _|/ _(_)__(_)__ _| | / _ \| '_| ' \| '_ \ / _` | ' \___| || | ' \/ _ \ _| _| / _| / _` | | /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| \_,_|_||_\___/_| |_| |_\__|_\__,_|_| v25.11 rolling for Odroid C1 running Armbian Linux 6.12.49-current-meson Packages: Debian stable (trixie) Support: DIY (custom image) IPv4: (LAN) 192.168.1.95, 10.8.0.1, 10.10.0.1 (WAN) ww.xx.yy.zz IPv6: 0000:1111:2222:3333:444:555:6666:7777 Performance: Load: 2% Uptime: 23:36 Memory usage: 8% of 986M CPU temp: 49°C Usage of /: 15% of 6.9G
  13. Has anyone here configured armbian with a Wayland desktop, and completely free of X11? How did you do it? I have compiled labwc and it works great with my orange pi zero 3, with bookworm or trixie... but I can't figure out how to configure a wayland greeter. I need to do this because my LCD driver can't work with X11 (panel-mipi-dbi-spi).
  14. Last week
  15. @ebin-dev could you perhaps update your post 1 and post your latest instructions and upload the files there? That would make it much easier to find the stable files.
  16. @pochopsp - you can buy two tv-boxes of the same type at once from the same seller and they might have different hardware internally still - that is the reason why it is not prossible to provide really good images for tv boxes: the hardware is simply too random and often also low quality
  17. @Luckyisnotcoolest try the x96q images here. https://github.com/NickAlilovic/build/releases/tag/20250306
  18. @emor acid could be your gpio settings for mmc0. Try the x98h image. If that doesn’t work you need to extract your android dts or use the one from the working Ubuntu.
  19. The kernel 6.17 release benefits from improvements in the graphics subsystem, hardware enablement, and more! See where Collabora's kernel team contributed to this release. View the full article
  20. leave a link for other users like @John Taylor to continue your work, also @fedes_gl could give a hand
  21. I know an expert in rk3528, his name is @fensoft we are depending on him finding a weekend to dedicate to the community https://github.com/ilyakurdyukov/rk3528-tvbox he will help us by taking this repository and including it in armbian with a wonderful pull request I would like to buy this board and join the fun that you have, but my country has literally started an embargo on all TV boxes
  22. Hi, I tested with the version 25.11.0-trunk.129 and the second network port worked with this. https://paste.armbian.com/hasewoloti
  23. This is internal development for our boards, unfortunately, there is no public repository for our kernel. The code is borrowed from reverse-engineered POCs h264 + * Based on https://github.com/jemk/cedrus + * Copyright (c) 2014-2015 Jens Kuske <jenskuske@gmail.com> jpeg + * Based on https://gitorious.org/recedro/jepoc + * Copyright (c) 2014 Manuel Braga <mul.braga@gmail.com>
  24. Fix: run armbian-install, then selected “Install/Update the bootloader on SD card (/dev/mmcblk0)”
  25. Describe what you did before to make it work. Show the DTS, the wiring you connected and the linux version that worked. If you used spidev before, I don't have experience in that. I only have experience with these drivers: panel-mipi-dbi-spi, ili9431 and adafrui-xy... The threads I showed you require you to stop using spidev, since the Linux kernel will communicate directly to the LCD, without a user program. Using both will just make them interfere with each other. If the LCD remains white and doesn't even flicker, and you made it work in an older kernel, then keep that wiring. If the /dev/fb0 exists, it means that linux has taken one SPI output port for display, but you need to make sure that: * and SPI parameters in the DTS are correct, * the gpio to handle the command/data, reset parameters are pointing to valid orange pi pins which are not used by anything else * the high/low polarity of those gpio * the wiring is correct, * the initialization bytes are correct
  26. Ok, I foud some time to make additional tests. Here is what I found. It fully boots with 'x96q-lpddr3' SD card image if you swap dtb to one of the two: h618-linganpi-3h h618-orngepi2w However in both cases internal Ethernet does not work. I can use USB to ETH converter. Do you see any way to make internal ETH working in this board? In original Android dmesg there is a message about gmac: [ 28.389711] sunxi-gmac gmac1 eth0: eth0: Type(6) PHY ID 00441400 at 0 IRQ poll (gmac1-0:00) Does it sound like a solution?
  27. quoting JPL: Did you see any announcement by the github's owner, about what we can expect from her/his source code? Looking at the content of the file, it seems like we need to download the code from: https://github.com/philipl/mpv#branch=v4l2request or https://github.com/philipl/mpv/tree/v4l2request And include this build-time configuration -Dv4l2request='enabled' I have posted instructions to build MPV on Sept 26 in this thread
  28. The easiest way to do this is through a chroot (or perhaps systemd-nspawn) but how practical this is will be dependent on your end goals. I do this all the time.
