  2. driver for sv6051p working in kernel 7 @Qvy: https://github.com/eloirotava/6051 horray!
  3. now working with: Download: 8.06 Mbit/s Upload: 10.08 Mbit/s in kernel 7. https://github.com/eloirotava/6051 testes on s90w amlogic. also work with 6030p rockchip.
  4. Will try to find my UART to USB and see what I get. ljones
  5. @Igor Maybe we can add a lastchange.txt file with unix timestamp to the root and use it for a status page? Then periodically let it check and output status in a separate tab on https://actions.armbian.com/
  6. Hello, Can you connect the UART to the NanoPi and see where it gets stuck? I'll take a look at it over the weekend. Thank you.
  7. Yesterday
  8. Hello all! Not sure what is going on at all but I'm having a problem booting the "rolling release" of armbian (debian 14/forky) minimal cli. I'm using a nano pi R76S with 4gb of RAM and 64GB emmc. I can successfully burn a microsd for the previous version (also minimal cli vesion) which boots ok.However if I try to use the newer version nothing happens -- the red LED on the R76S stays permanently on and I get no display or any other life. I did try using different microsd cards but it did not make any difference. I also tried using the same microsd (I wrote the older version first to the microsd which boots) then wrote again on the same microsd. I'm using the download page for the images from here - https://armbian.com/boards/nanopi-r76s ljones
  9. As for promised photos, here they are. Note custom-trimmed bifurcation adapter.
  10. As for QRTR patch, WIP version is attached bellow. Be aware that this patch doesn't work yet. It builds, it writes to registries, but QCNFA765 ignores it. rk3588-ath11k-QRTR.patch
  11. As for QCNFA765, using more than one NIC in the same system still won't do. I have found correct MHI registries (0x28 and 0x48) which are used to store QRTR ID, but the driver omitts it completely during cold-boot of the NIC. So, for now, I moved over to use single QCNFA765 and Intel AX210 combo. Which brought another issue - annoying LAR. Bellow are patches I do use to be able to use both cards in HostAP Master mode with no restrictions on selected channels. I do use regdomain CZ. Should you need different regdom, use example found in those patches for CZ, and just copy over the changes made (removing NO-IR, DFS, and other flags). 404-regd_no_assoc_hints.patch atheros-dfs_fix.patch atheros-regdomainfix.patch regdb-fix.patch rk3588-iwlwifi-disable-lar.patch
  12. small update... last tries I've made: with an SD card loaded with armbian 26.2 (from Armbian archives) and DIP on SD, the boot is ok, boot is U-Boot 2025.10_armbian-2025.10-Se50b-P915a-H3623-V44f7-B2eb2-R448a. However, no option to load bootloader in SPI present in nand-sata-install, most probably because no SPI block listed in lsblk output. nan-sata-install complains that the command line is incomplete and request to try option 'help', but I could not figure how to get to the help, any common option passing I've tried did not worked. I tried to get to the initial install procedure from Kobol, modifying the spi_workaround from off to on in armbianEnv.txt on the SD, but this prevent the kernel to boot from SD. Any help would be appreciated...
  13. As you might see in my signature I decided to retain the Helios4 withdrawing the goodbye message above. @laibsch Actual problem: I didn't succeed in configuring Wake-on-LAN on 26.2.1. What I did was to replace "eth0" by "end1" in /lib/systemd/system/helios4-wol.service Triggering the suspend mode by pm-suspend Decompilation of armada-388-helios4.dtb didn't contain the device tree patch mentioned in https://wiki.kobol.io/helios4/files/wol/helios4-dts-add-wake-on-lan-support.patch Any clue what's missing? @Igor armbian-config does not find any .dtb files in /boot/dtb ("Device Tree Editor") /boot/dtb is a symlink to the directory dtb-6.6.124-current-mvebu.
  14. Now this issue seems to be fixed. I tried to build 6.18.25 kernel and it can complete boot wizard as expected.
  15. Thank you for the Input! Yes Proxmox and then different VM like HAos to gain access to HACS.
  16. Hi everyone! Can anyone tell me how to make the system boot without displaying any text characters? I'd like to just see the Radxa logo, then a black screen and the login screen (GDM). What settings do I need to configure to achieve this? I have the Armbian 2.6.4 Trixie CLI image installed with GNOME.
  17. the problem is solved
  18. Community images are tied to daily beta repo where it should always be a match kernel - headers. Just make sure you have a clean updated system then proceeding to header installation via armbian-config. And only if this doesn't work, report so we can look into.
  19. I see it like who is motivated to check and do the work w.r.t U-Boot. Especially while EDK2 UEFIv1.1 is available already a year and at least for my ROCK5B and NanoPi-R6C with both Armbian rockchip edge kernels as well as standard Debian arm64 kernels works OK. We call those things 'firmware' but the 'firm' selling this OP5 HW is not delivering this. Good thing is that it is all open source at least. For the ROCK5B I also used it in 'vendor' mode, so 6.1.115 works and so video encoders as well (for Jellyfin). For NanoPi-R6C (RK3588S, same as OP5) it is in the on-board eMMC, that is some disadvantage compared to SPI and more as SD-card. So not sure how OP5 will deal with it.
  20. At least that explains the result of the nvme scan command. Now it remains to find out why this is the case, but since improvements are still pending for PCIe support even in the mainline kernel, the question arises whether all of this has already been migrated into the firmware.
  21. It doesn't see NVMe device on PCI bus. => pci enum => pci BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 00.00.00 0x1d87 0x3588 Bridge device 0x04
  22. This week in Armbian development saw a broad range of updates spanning kernel enhancements, desktop improvements, and infrastructure refinements. Notable changes include new developer documentation for the desktop submodule, expanded GPU and multimedia support for vendor-kernel desktops, and several kernel version bumps for various platforms. The build system received fixes for filesystem resizing and improved dependency handling, while CI workflows were optimized with increased timeouts and better error handling. New hardware targets were added, including Radxa Dragon Q6A and Nio 12L, alongside updates to u-boot and kernel drivers for multiple devices. Additional improvements focused on patch maintenance, logo updates, and enhanced automation for VM provisioning. These collective efforts continue to strengthen Armbian’s reliability, performance, and hardware compatibility. ChangesAdd developer guide for the desktop submodule. by @igorpecovnik in armbian/documentation#912armbian-kernel: btf: fixes + enable KPROBES. by @rpardini in armbian/build#9715armbian-resize-filesystem: fix typo $rootdev → $diskdev in do_expand_partition. by @iav in armbian/build#9702artifact-uboot: add UBOOT_GIT_CACHE_TTL (fixes #7710). by @iav in armbian/build#9699ci/unit-tests: bump job timeouts by +30 minutes. by @igorpecovnik in armbian/configng#890ci/unit-tests: cancel in-flight runs on supersede. by @igorpecovnik in armbian/configng#891cli: kernel-dtb: pass -@ to normalized dtc invocation. by @rpardini in armbian/build#9720config.system: add Bianbu to the desktop install menu. by @igorpecovnik in armbian/configng#893desktops: enable panthor-gpu DT overlay on rk3588 vendor-kernel desktops. by @igorpecovnik in armbian/configng#886desktops: install libv4l-0 before rockchip-multimedia packages. by @igorpecovnik in armbian/configng#887desktops: move mesa/GPU runtime + diagnostics to common mid tier. by @igorpecovnik in armbian/configng#885desktops: prune unused wallpaper assets (-15 MB). by @igorpecovnik in armbian/configng#882desktops: strip libreoffice on jammy/riscv64 (no upstream build). by @igorpecovnik in armbian/configng#883env_init: reconcile BRANCH from installed kernel on every startup. by @igorpecovnik in armbian/configng#892external: enable code (VSCode) pull for jammy. by @igorpecovnik in armbian/os#457generate-armbian-images-json: detect preinstalled app past kernel rc/beta tag. by @igorpecovnik in armbian/armbian.github.io#294genio: edge: bump to collabora's 6.19.8. by @rpardini in armbian/build#9721helios64: u-boot: bump to v2026.04 + diagnostics + CMD_FILEENV; v2026.04: generic btrfs zstd fix. by @iav in armbian/build#9675hetzner: validate GitHub runner token before provisioning any VM. by @igorpecovnik in armbian/actions#19Improve Radxa logo. by @igorpecovnik in armbian/armbian.github.io#293kernel: add dependency of initramfs-tools for linux-image package. by @amazingfate in armbian/build#9727libbpf: fix const correctness in resolve_full_path for gcc15. by @EvilOlaf in armbian/linux-rockchip#474meson64-6.12: oldlts: update meson-axg mmc phase configuration patch. by @rpardini in armbian/build#9712mvebu: edge → 6.18 LTS family-wide + restore 4 patches lost in #6135. by @iav in armbian/build#9709Odin2: Now we can switch back to upstream sdhci-msm driver. by @kasimling in armbian/build#9703odroidhc4: u-boot: bump 2026.01 -> 2026.04 (final) & add LWIP. by @rpardini in armbian/build#9714owncloud: fix CI install test + docker_operation_progress pull/error-handling bugs it exposed. by @igorpecovnik in armbian/configng#888owncloud: fix CI install test + docker_operation_progress pull/error-handling bugs it exposed. by @igorpecovnik in armbian/configng#889patch maintenance: some rewriting against recent patch versions. by @EvilOlaf in armbian/build#9711pkg: prevent interactive dpkg prompts in automated builds. by @igorpecovnik in armbian/configng#884qrb2210: switch edge kernel to mainline linux v7.0. by @SuperKali in armbian/build#9710radxa-aic8800: Use gcc-14 for Noble release. by @HeyMeco in armbian/build#9707refactor(api): normalize application='ufs' to storage='ufs'. by @HeyMeco in armbian/website#9release-targets: add radxa-dragon-q6a and radxa-nio-12l with ufs extension. by @igorpecovnik in armbian/armbian.github.io#292Revert "Disable Sk-am64b as its not compiling on Resolute". by @jonaswood01 in armbian/armbian.github.io#289SpacemiT: Enable additional audio support in legacy and current. by @pyavitz in armbian/build#9717targets: set DESKTOP_TIER per desktop block, keyed on DESKTOP_APPGROUPS_SELECTED. by @igorpecovnik in armbian/armbian.github.io#288thinkpad-x13s: bump to steev's 7.0.y. by @rpardini in armbian/build#9716u-boot: 2026.04: drop #warnings in fdt_fixup_ethernet logging patch. by @rpardini in armbian/build#9713Update odroidxu4-current to 6.6.135. by @belegdol in armbian/build#9705Update Radxa logo. by @igorpecovnik in armbian/armbian.github.io#290workflows/hetzner: expose machine_count and server_type as dispatch inputs. by @igorpecovnik in armbian/armbian.github.io#291View the full article
  23. This week in Armbian development saw a broad range of updates spanning kernel enhancements, desktop improvements, and infrastructure refinements. Notable changes include new developer documentation for the desktop submodule, expanded GPU and multimedia support for vendor-kernel desktops, and several kernel version bumps for various platforms. The build system received fixes for filesystem resizing and improved dependency handling, while CI workflows were optimized with increased timeouts and better error handling. New hardware targets were added, including Radxa Dragon Q6A and Nio 12L, alongside updates to u-boot and kernel drivers for multiple devices. Additional improvements focused on patch maintenance, logo updates, and enhanced automation for VM provisioning. These collective efforts continue to strengthen Armbian’s reliability, performance, and hardware compatibility. ChangesAdd developer guide for the desktop submodule. by @igorpecovnik in armbian/documentation#912armbian-kernel: btf: fixes + enable KPROBES. by @rpardini in armbian/build#9715armbian-resize-filesystem: fix typo $rootdev → $diskdev in do_expand_partition. by @iav in armbian/build#9702artifact-uboot: add UBOOT_GIT_CACHE_TTL (fixes #7710). by @iav in armbian/build#9699ci/unit-tests: bump job timeouts by +30 minutes. by @igorpecovnik in armbian/configng#890ci/unit-tests: cancel in-flight runs on supersede. by @igorpecovnik in armbian/configng#891cli: kernel-dtb: pass -@ to normalized dtc invocation. by @rpardini in armbian/build#9720config.system: add Bianbu to the desktop install menu. by @igorpecovnik in armbian/configng#893desktops: enable panthor-gpu DT overlay on rk3588 vendor-kernel desktops. by @igorpecovnik in armbian/configng#886desktops: install libv4l-0 before rockchip-multimedia packages. by @igorpecovnik in armbian/configng#887desktops: move mesa/GPU runtime + diagnostics to common mid tier. by @igorpecovnik in armbian/configng#885desktops: prune unused wallpaper assets (-15 MB). by @igorpecovnik in armbian/configng#882desktops: strip libreoffice on jammy/riscv64 (no upstream build). by @igorpecovnik in armbian/configng#883env_init: reconcile BRANCH from installed kernel on every startup. by @igorpecovnik in armbian/configng#892external: enable code (VSCode) pull for jammy. by @igorpecovnik in armbian/os#457generate-armbian-images-json: detect preinstalled app past kernel rc/beta tag. by @igorpecovnik in armbian/armbian.github.io#294genio: edge: bump to collabora's 6.19.8. by @rpardini in armbian/build#9721helios64: u-boot: bump to v2026.04 + diagnostics + CMD_FILEENV; v2026.04: generic btrfs zstd fix. by @iav in armbian/build#9675hetzner: validate GitHub runner token before provisioning any VM. by @igorpecovnik in armbian/actions#19Improve Radxa logo. by @igorpecovnik in armbian/armbian.github.io#293kernel: add dependency of initramfs-tools for linux-image package. by @amazingfate in armbian/build#9727libbpf: fix const correctness in resolve_full_path for gcc15. by @EvilOlaf in armbian/linux-rockchip#474meson64-6.12: oldlts: update meson-axg mmc phase configuration patch. by @rpardini in armbian/build#9712mvebu: edge → 6.18 LTS family-wide + restore 4 patches lost in #6135. by @iav in armbian/build#9709Odin2: Now we can switch back to upstream sdhci-msm driver. by @kasimling in armbian/build#9703odroidhc4: u-boot: bump 2026.01 -> 2026.04 (final) & add LWIP. by @rpardini in armbian/build#9714owncloud: fix CI install test + docker_operation_progress pull/error-handling bugs it exposed. by @igorpecovnik in armbian/configng#888owncloud: fix CI install test + docker_operation_progress pull/error-handling bugs it exposed. by @igorpecovnik in armbian/configng#889patch maintenance: some rewriting against recent patch versions. by @EvilOlaf in armbian/build#9711pkg: prevent interactive dpkg prompts in automated builds. by @igorpecovnik in armbian/configng#884qrb2210: switch edge kernel to mainline linux v7.0. by @SuperKali in armbian/build#9710radxa-aic8800: Use gcc-14 for Noble release. by @HeyMeco in armbian/build#9707refactor(api): normalize application='ufs' to storage='ufs'. by @HeyMeco in armbian/website#9release-targets: add radxa-dragon-q6a and radxa-nio-12l with ufs extension. by @igorpecovnik in armbian/armbian.github.io#292Revert "Disable Sk-am64b as its not compiling on Resolute". by @jonaswood01 in armbian/armbian.github.io#289SpacemiT: Enable additional audio support in legacy and current. by @pyavitz in armbian/build#9717targets: set DESKTOP_TIER per desktop block, keyed on DESKTOP_APPGROUPS_SELECTED. by @igorpecovnik in armbian/armbian.github.io#288thinkpad-x13s: bump to steev's 7.0.y. by @rpardini in armbian/build#9716u-boot: 2026.04: drop #warnings in fdt_fixup_ethernet logging patch. by @rpardini in armbian/build#9713Update odroidxu4-current to 6.6.135. by @belegdol in armbian/build#9705Update Radxa logo. by @igorpecovnik in armbian/armbian.github.io#290workflows/hetzner: expose machine_count and server_type as dispatch inputs. by @igorpecovnik in armbian/armbian.github.io#291View the full article
  24. Last week
  25. Collabora's contributions to Git 2.54 and the upcoming 2.55 add powerful config-based hooks with better visibility, opt-in parallel hook execution, and safer submodule handling via path-collision fixes. View the full article
  26. u-boot-rockchip-spi.bin is a firmware. Out of pure curiosity, what is the result of 'pci enum' on the firmware console?
  27. There will be no fix if it is not clear what exactly needs to be fixed I would say. I guess you need to dig deeper yourself. You can build U-Boot independent of Armbian if you want, maybe less reading initially, still the testing/debugging is what matters.
  28. I could not get PCIE to work properly on BSP 6.6 on the A7S, but maybe it was my mistake. For SATA over M.2 to work (in case on m.2 SATA drives), the device need to support this electrically, which I'm not sure if A7x boards do. Sent from my SM-S931B using Tapatalk
