  2. I've been an apt/Debian user long enough to have a reasonable idea how mirrors work, what I don't understand is why you have a mirror still listed that a few days ago had a copy of all packages and now it's an empty directory.
  4. PSP emulation with PPSSPP should work for a lot of games. It's a pity we never got a fully working Vulkan driver. God of War is probably too much. At least it was when I tested it many years ago.
  5. @Octavio Cuatrochio I just noticed your link in the first post. The board in the link is a FAKE Allwinner H313. If your board does not have a small AXP### chip then it's not an Allwinner H313.
  6. The last update installed a broken firmware package which prevents the system from rebooting and there is no heartbeat. This is the tail end of the upgrade: Preparing to unpack .../40-libnss-myhostname_255.4-1ubuntu8.14_arm64.deb ... Unpacking libnss-myhostname:arm64 (255.4-1ubuntu8.14) over (255.4-1ubuntu8.12) ... Errors were encountered while processing: /tmp/apt-dpkg-install-QRewUS/02-armbian-firmware_26.2.1_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1) Since the install is on the internal eMMc that pretty much prevents any recovery
  7. closed for off-topic
  8. LLM has most likely read the patch I merged into Armbian
  9. Is it possible to make a Bodhi Linux version that works on x98h
  10. We don't deal with OpenWRT. I suggest to ask at some place where OpenWRT is distributed/supported.
  11. Does this come from the patch I recently submitted to the maillist? I think it should work there too; the issue is present on all boards with the RK3588 chip.
  12. I need an OpenWrt system on X98H
  13. For lazy people like me clapper from flathub is a solution.
  14. @KV1 nice work! Looks like it made it to U-Boot before it died. Instead of building your own, have you tried to see if it boots using a release image built with a github runner here: https://github.com/bschnei/ebu-bootloader/releases/tag/2026.02.24. Even if you want to eventually build it yourself, you could just test to see if the image built at github works. If it does, and you know the source code is the same (it looks like you are building an -rc of U-Boot) then you can narrow it down to the compiler tools you are using. Just to confirm: this is for an EspressoBIN Ultra right? Not the V7/V5 or some other variant?
  15. At the begginging of the page https://docs.armbian.com/Mirrors/#introduction it is written how the system works. What we don't provide on that list is current status of which are live in in sync. However you can check this at any moment: curl http://apt.armbian.com/mirrors | jq
  16. Hi, Is it appropriate to raise this at https://github.com/armbian/build/issues, since the Headphone Jack audio is available on older version of the kernels and not available in the latest kernels? Thanks for your guidance.
  17. Thanks @bschnei. I tried for a while to figure out what to do, but couldn't really understand.. not sure if i should be trying to set it to thumb or arm mode at that point, even. I did fallback to earlier binutils, and the build went fine. However, trying to boot from the flash-image.bin with mox-imager results in incomplete load and reset back to mmc/spinor ... any ideas? -- /mox-imager/mox-imager -D /dev/ttyUSB0 -t -E /srv/development/espressobin-ultra/2026-03-bschnei/built-on-old-bb/flash-image-20260401-bb.bin TIM version 3.6.00, issue date 2026-04-01, non-trusted, 3 images, 0 keys, boot flash sign SPI NOR Reserved area packages: CRV2 (size 20) CIDP (size 32) Consumer TBRI, packages: GPP1 GPP2 DDR3 GPP1 (size 852) Ignore timeouts in instructions: 0 GPP2 (size 456) Ignore timeouts in instructions: 0 DDR3 (size 2024) Initialize DDR memory: 1 Term (size 8) Found TIMH, hash sha-256, encryption none, size 3780, load 0x20006000, flash 0x00000000 Found WTMI, hash sha-256, encryption none, size 24336, load 0x1fff0000, flash 0x00004000 Found OBMI, hash sha-256, encryption none, size 1140712, load 0x64100000, flash 0x00015000 Going to send images to the device Sending escape sequence, please power up the device Received sync reply Sending escape sequence with delay Detected BootROM command prompt Sending wtp sequence Received ack reply Sending clearbuf sequence Initialized UART download mode GetVersion response: version 3.4.01, date 2016-05-15, CPU ARMA Sending image type TIMH 100% sent in 00:00 TIM-1.0 mv_ddr-devel-g7bcb9dc DDR4 16b 1GB 1CS Sending image type WTMI 100% sent in 00:02 Sending image type OBMI 100% sent in 01:40 [Type Ctrl-\ + c to quit] WTMI-devel-18.12.1-a3e1c67 WTMI: system early-init SVC REV: 5, CPU VDD voltage: 1.213V Setting clocks: CPU 1200 MHz, DDR 750 MHz CZ.NIC's Armada 3720 Secure Firmware v2024.04.15-6-gd6d9646 (Apr 1 2026 16:32:36) Running on ESPRESSObin Ultra NOTICE: Booting Trusted Firmware NOTICE: BL1: v2.14.0(release):sandbox/v2.14-774-g8dae0862c NOTICE: BL1: Built : 16:32:41, Apr 1 2026 NOTICE: BL1: Booting BL2 NOTICE: BL2: v2.14.0(release):sandbox/v2.14-774-g8dae0862c NOTICE: BL2: Built : 16:32:51, Apr 1 2026 NOTICE: BL1: Booting BL31 NOTICE: BL31: v2.14.0(release):sandbox/v2.14-774-g8dae0862c NOTICE: BL31: Built : 16:32:56, Apr 1 2026 U-Boot 2026.04-rc5-00019-gc704af3c8b0f (Apr 01 2026 - 17:08:14 -0400) DRAM: 1 GiB "Synchronous Abort" handler, esr 0x96000044, far 0xd5380000aa1e03fd elr: 0000000000036a08 lr : 0000000000036a64 (reloc) elr: 000000003ff4aa08 lr : 000000003ff4aa64 x0 : 0000000000000098 x1 : d5380000aa1e03fd x2 : 0000000000000000 x3 : 000000003fb07b00 x4 : 0000000000000000 x5 : 0000000000000000 x6 : 0000000000000000 x7 : 000000003fb07b20 x8 : 000000003faff64c x9 : 000000003fb00034 x10: 0000000000000000 x11: 0000000000000600 x12: 000000003faff70c x13: 000000003faff9b0 x14: 000000003faff9b0 x15: 0000000000000000 x16: 0000000000000000 x17: 0000000000000000 x18: 000000003fb03e10 x19: 0000000000000000 x20: 000000003fb07780 x21: 000000003fb077a0 x22: 0000000000000000 x23: 0000000000000000 x24: 0000000000000000 x25: 0000000000000000 x26: 0000000000000000 x27: 0000000000000000 x28: 0000000000000000 x29: 000000003faff7a0 Code: f9405261 f9005274 f81e02a0 f9000681 (f9000034) Resetting CPU ... resetting ... TIM-1.0 WTMI-devel-18.12.1-1a13f2f WTMI: system early-init SVC REV: 5, CPU VDD voltage: 1.213V NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.5(release):e65dc63 (Marvell-devel-18.12.2) NOTICE: BL1: Built : 22:43:22, Mar 4 2026 NOTICE: BL1: Booting BL2 NOTICE: BL2: v1.5(release):e65dc63 (Marvell-devel-18.12.2) NOTICE: BL2: Built : 22:43:25, Mar 4 2026 NOTICE: BL1: Booting BL31 NOTICE: BL31: v1.5(release):e65dc63 (Marvell-devel-18.12.2) NOTICE: BL31: Built : 22 U-Boot 2020.10-6.0.0-g29a6ea5c-dirty (Mar 28 2026 - 21:49:54 -0400) Model: gti cellular cpe board DRAM: 1 GiB Comphy chip #0: Comphy-0: USB3_HOST0 Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps Target spinup took 0 ms. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d8000: 0 Loading Environment from SPIFlash... unrecognized JEDEC id bytes: 61, 12, 9b *** Warning - spi_flash_probe_bus_cs() failed, using default environment Net: Error: neta@30000 address not set. mdio_register: non unique device name 'neta@30000' No ethernet found. starting USB... Bus usb@58000: Register 2000104 NbrPorts 2 Starting the controller USB XHCI 1.00 Bus usb@5e000: USB EHCI 1.00 scanning bus usb@58000 for devices... 1 USB Device(s) found scanning bus usb@5e000 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 Marvell>>
  18. @alexc Thanks for all your hard work! I’ve put together an Armbian build using your kernel—you can check it out here: https://github.com/NickAlilovic/build/tree/Radxa-mainline-WIP
  19. So, I went through this recently on an NVidia device, and device tree overlays really aren't that hard. But there's a few things you'll need to get set up first, and not having an M5 to check, you'll probably have to do some reading / verification. I make no claim this will work out of the box for you. But I imagine this will save you a lot of reading. There's an example .dtbo at https://github.com/KF0ARE/i2c0-rtc.dtbo/blob/main/i2c0-rtc.dtbo you should look at, and you can decompile it with the following: dtc -O dts -o i2c0-rtc.dts i2c0-rtc.dtbo Which contains a fragment you'll be interested in, explicitly for the DS3231 ... /dts-v1/; / { compatible = "brcm,bcm2708"; ... snip ... fragment@3 { target = <0xffffffff>; __dormant__ { #address-cells = <0x01>; #size-cells = <0x00>; status = "okay"; ds3231@68 { compatible = "maxim,ds3231"; reg = <0x68>; status = "okay"; phandle = <0x04>; }; }; }; ... snip ... }; But you can't use this directly, because "compatible" doesn't include your M5, and "target" doesn't point anywhere useful in your DT. But it does call out the ds3231, and that it's at I2C address 0x68, so you can use that to find where the kernel thinks your RTC is. Take a look at where your I2C buses are (/dev/i2c-*) and just scan each of them like this to see if you can find it: tparys@pebble:~$ sudo i2cdetect -y -r 0 # NOTE: I2C bus #0 is /dev/i2c-0 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- 10: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- In the above, address 0x10 is unusable as there's something else bound at that register. But check your buses to see if you can find 0x68. If you see something other than "--" or "UU" there, that's probably it. If you can't find it, double check that it's connected, powered on, and that your I2C bus has been enabled (might need to enable via DTB). Once you find it, you should be able to register it by doing something similar to the below as root (driver and I2C bus may be different): echo ds3231 0x68 > /sys/bus/i2c/devices/i2c-0/new_device If that works, and creates a /dev/rtc0 device, test that it's working with "hwclock". Once it's working, it's time to make your .dtbo. You'll probably want to dump your main .dtb with the same dtc command above, and look for i2c-0 (or whatever other bus you found), as well as a .dtbo or two for your M5 to find text to enter for "compatible". And you'll end up with something like this, saved as "m5-ds3231.dts" (or whatever): /dts-v1/; /plugin/; / { compatible = "brcm,bcm2708"; // <---- Change this fragment@0 { target = "i2c-0"; // <---- Change this __overlay__ { #address-cells = <0x01>; #size-cells = <0x00>; status = "okay"; ds3231@68 { compatible = "maxim,ds3231"; reg = <0x68>; status = "okay"; phandle = <0x04>; }; }; }; }; And you'll compile it like this: dtc -@ -O dtb -o m5-ds3231.dtbo m5-ds3231.dts And check it against your M5's DTB like below. Note that "target" or "target-path" has some odd syntax requirements. Quotes with a leading slash is a full path to your I2C device. Quotes without a leading slash is an alias. And angle brackets with an ampersand is a label (not everything has an explicit label). Worst case scenariou, call out the whole path in "target-path" with a leading slash, and call it a day. I beat my head against a wall for a while here before I realized I could test this without rebooting ... fdtoverlay -i /path/to/your/used.dtb -o modified.dtb m5-ds3231.dtbo And then add it to your overlay directory (/boot/dtb/CHIPNAME/overlays), enable it armbianEnv.txt, and give it a go? There's also two kernel build configs that may be of interest as well: CONFIG_RTC_HCTOSYS_DEVICE="rtc0" CONFIG_RTC_SYSTOHC_DEVICE="rtc0" The first triggers the kernel to load time from a given RTC when it first shows up. The second will tell the system to update RTC when locked against NTP. FYI, it seems that you can change these only with a new kernel build.
  20. Yesterday
  21. I am glad that it's possible to use a different ffmpeg version than what the distribution expects. (it gives me hope of installing it in Trixie, instead of changing over to the newest Ubuntu) Did you install the locally compiled ffmpeg at OS level, or did you keep it in a folder within your /home/username/...?
  22. @andrey.lobov try to upgrade the kernel or pick a fresh image from the github repository. The tm16xx driver has been reenabled recently after having being disabled due to partial kernel upstream.
  23. @Mohammad Adel AW869A and AIC8800 are the same WiFI chips. You should have WiFi working.
  24. After I closed the lid of my chromebook Armbian decided to die even across reboots. https://drive.google.com/file/d/1gkEzVoY5QkNcWq3MOKYUSc8nkFYg91p-/view?usp=sharing Video of what I see https://drive.google.com/file/d/17yhnIjzkiYkkVohFrLf7MKDtYyb0xfOL/view?usp=sharing
  25. I finally successfully got Armbian installed on my Pinebook Pro's eMMC. That should be giving it its best possible performance. I thought you may all be interested in compiling a list of games that work at least reasonably well on it given its restrictions of being ARM64 architecture, 1.8GHz CPU & 4GBs RAM. So to start here is a list of the ones I currently have on mine. I may try more later but for now I'm limited by the stock 64GB eMMC that the PCP came with... 0AD - 3D RTS Cave Story - Pixel Art Metroidvania Dr Robotnik's Ring Racers - Kart Racer Dune Legacy - RTS Endless Sky - Space Sandbox Flare - Fantasy RPG Freeciv - Strategy Freecol - Strategy GZDoom - Doom Engine for Mods & Total Conversions Hedgewars - Worms "Homage" Neverball - Monkeyball "Homage" Neverputt - Miniputt Golf Game Open Fodder - FOSS Engine for "Cannon Fodder" OpenRA - FOSS RTS Engine for "Tiberian Dawn", "Red Alert" & "Dune 2000" Open TTD - Transit Management Sim OpenTyrian - FOSS Engine for Top-Down Shmup "Tyrian" Perfect Dark - PC Port of N64 Game with Keyboard/Mouse Support Pico-8 - Indie Pixel Art Gaming & Development Platform Pingus - Lemmings "Homage" ScummVM - FOSS Engine for Classic Point & Click Games Sonic Robo Blast 2 - 3D Platformer The Ur-Quan Masters - FOSS Port of Space Sandbox "Star Control II" Xonotic - Arena Shooter FPS There are other games I have not yet personally tried like OpenHV, SuperTuxKart, other emulators etc but if anyone can confirm they work reasonably well on the Pinebook Pro then please let the rest of us know. All ScummVM games I've tried from King's Quest I to Grim Fandango work perfectly. However GZDoom will struggle with especially demanding modern Doom mods like Trenchfoot, Auger Zenith, Inquisitor III, Godless Nite etc. but most like Aliens: Eradication, Ashes 2063/Afterglow, Brutal Doom, Castlevania: Simon's Destiny, Irontusk's Diablo 3D, Revenge of the Triad etc run just fine.
  26. Welcome to the latest Armbian Newsletter: your source for the latest developments, community highlights, and behind-the-scenes updates from the world of open-source ARM and RISC-V computing. The past two months have been particularly active for the embedded ecosystem. At EMBEDDED WORLD 2026, developers, hardware vendors, and open-source communities gathered to showcase the latest innovations shaping the future of embedded computing. In parallel, the Armbian project continues to evolve with new releases, expanded board support, and ongoing improvements to the build framework driven by the contributions of its global community and the growing demand for reliable Linux on ARM and RISC-V platforms. SPONSORED Join us in making open source better! Every donation helps Armbian improve security, performance, and reliability — so everyone can enjoy a solid foundation for their devices. Github HighlightsThis week in Armbian development saw a significant expansion of hardware support, including new board images and compatibility for devices such as the Ariaboard Photonicat 2, SpacemiT MUSE Book, NanoPC T6 Plus, and Mekotronics R58S2. Kernel patches were updated across multiple platforms, notably for Rockchip and Sunxi families, enhancing stabilityArmbian blogMichael RobinsonMy First embedded world and I Already Can’t Wait for the NextI’d been putting this off for years. Every March, I’d read someone else’s embedded world recap, tell myself “next year”, and go back to my terminal. This year I actually went and I’m still processing everything I saw. First things first: the team Before I talk about any stand orArmbian blogDaniele BriguglioArmbian Q1 2026: Technical Milestones and the Road to Embedded WorldThe first quarter of 2026 has been a period of significant technical consolidation for the Armbian project. Driven by the v26.02 (Goa) release cycle, the project has focused on three core pillars: aggressive framework refactoring, the stable rollout of the Linux 6.18 LTS kernel, and the maturation ofArmbian blogMichael RobinsonView the full article
  27. The first quarter of 2026 has been a period of significant technical consolidation for the Armbian project. Driven by the v26.02 (Goa) release cycle, the project has focused on three core pillars: aggressive framework refactoring, the stable rollout of the Linux 6.18 LTS kernel, and the maturation of the Armbian Imager utility. Core Framework RefactoringA primary objective this quarter was the reduction of technical debt within the armbian/build repository. The development team initiated a systematic cleanup to improve build reliability and maintenance. Toolchain Optimization: Through a series of pull requests, including #9218, #9252, and #9256, significant "dead code" was removed from the internal toolchain. This refactoring simplifies the logic required to support a diversifying array of ARM and RISC-V architectures.mmdebstrap Transition: The framework has officially transitioned to mmdebstrap as the exclusive engine for rootfs creation (#9512). By deprecating the legacy debootstrap method, the project ensures faster, more consistent, and reproducible builds across varied host environments.Bash Modernization: Internal build scripts have been transitioned from POSIX to Bash syntax to leverage modern shell features and enhance overall script reliability.Kernel and Hardware IntegrationQ1 marked the broad adoption of the Linux 6.18 LTS kernel series, providing improved driver support and hardware abstraction for tier-1 platforms. Linux 6.18 LTS Rollout: Stable support for the 6.18.y kernel was merged for major families, including meson64, rockchip64, and UEFI targets (#9069, #9086).Hardware Support Expansion:SpacemiT MusePi Pro: Full integration and kernel patching were completed (#9422).Orange Pi RV2: Initial support and nightly build availability were established for this RISC-V target.Radxa Rock 4D & ODROID M2: These boards were elevated to the stable support tier within the 26.02 release.Firmware Updates: U-Boot was bumped to v2026.01 for several platforms. Notably, boot delays on the Orange Pi 5 series were addressed via updated U-Boot candidates (#9450).Ecosystem Tools: Armbian ImagerThe Armbian Imager has transitioned from a utility to a cornerstone of the project’s user experience, with a focus on security and onboarding efficiency. Cross-Platform Security: Code signing was implemented for both macOS and Windows artifacts to reduce installation friction for non-Linux users (imager#87).Performance Improvements: The utility now features optimized image decompression and enhanced device disconnect detection (imager#28).Automated Reporting: A new AI Actions Report workflow (armbian.github.io#165) was implemented to automate development highlights, providing greater transparency into the commit history for the community.Strategic Industry AlignmentThe technical trajectory of Q1 was intentionally aligned with Armbian’s presence at Embedded World 2026 in Nuremberg. By showcasing the framework and Imager as guests of Seeed Studio, the project demonstrated its readiness for industrial-scale deployment. The shift toward mainline kernel and U-Boot support—specifically targeting the retirement of vendor-specific bootloaders—remains a priority for long-term security and professional-grade stability. Contributors & Credits The progress in Q1 2026 is the result of sustained contributions from the Armbian Dev team and the wider community. Detailed changelogs and commit histories are available at github.com/armbian/build. View the full article
