Igor Posted March 22, 2016 Posted March 22, 2016 It might be time for some release line. Let's put together what was done in past few month, need to be done, was forgotten and it's worth mentioning. I sure missed stuff out ... so just add it. IMAGES / KERNEL: - all 3.10+ kernels are Docker ready - added Odroid C2 CLI and desktop, kernel upgraded to 3.14.65 - Udoo Neo wireless works - legacy kernel for Allwinner boards was upgraded to 3.4.111 - legacy kernel for iMx6 boards was upgraded to 3.14.65 - vanilla images comes with kernel 4.4.6 - Clearfog comes with 3.10.101 and 4.4.6 - added Armbianmonitor which knows .... - fixes for SPDIF / I2S audio driver in legacy kernel - added USB camera section - added fix for slow SD cards - changed first boot procedure and force user creation - all A10/A20/H3 comes with HW acccelerated video playback in desktop build - Bluetooth on Cubietruck works well, both kernels - verbose / no verbose boot works almost on all boards - added wifi radar to desktop - desktop jessie only - enabled I2S on sun8i BUILD SCRIPT: - Added Belink X2 as WIP target (H3 based media player) - Added Odroid C1 as WIP target - introducted CLI_TARGET per board - prepared FEL boot - prepared Xenial target - GCC 5 support for vanilla and allwinner legacy BUGS: - Udoo Neo reboots takes a while, 1min+ - C1 does not boot https://github.com/igorpecovnik/lib/issues NEED TO BE FIXED IN THIS RELEASE: - vanilla build for H3 with working EMAC / GMAC - nand installer for H3 eMMC DUE DATE: 30.4.2016 ------------ Copy paste / add and remove this text. Just add to the topic 2
tkaiser Posted March 23, 2016 Posted March 23, 2016 Just some random thoughts/notes: Added NanoPi M1 (still needs a fix/replacement for auto detection since this is 1:1 clone of Orange Pi PC with less RAM) In the same context we need a solution for exchaning .dtb files for mainline kernel (applies to Bananas and sun8i) We should add 1024:768 and 1280:1024 HDMI resolutions for H3 (defining new modes instead of overwriting already existing ones)
Avinash Ga Posted March 30, 2016 Posted March 30, 2016 Which kernel version does vanilla build for H3 will be based on? Is that 4.4.6?
Igor Posted March 30, 2016 Author Posted March 30, 2016 Which kernel version does vanilla build for H3 will be based on? Is that 4.4.6? 4.5, hopefully. We wait for Ethernet support to become stable. 1
Igor Posted March 31, 2016 Author Posted March 31, 2016 IMAGES / KERNEL - fixed kernel update on NAND based systems (A10 & A20) Currently only on A10 and A20, patches for other boards will follow later - after build check: - automated "make scripts" on headers install and fixed ARCH in profile.d -> next drivers compilation = make (no anything else) - initrd creation on kernel install (but not actually using it)
Toast Posted March 31, 2016 Posted March 31, 2016 - added Armbianmonitor which knows .... mind expanding on that ?
Igor Posted March 31, 2016 Author Posted March 31, 2016 Use armbianmonitor for the following tasks: armbianmonitor -b switches between verbose and normal boot armbianmonitor -c /path/to/test performs disk health/performance tests armbianmonitor -d tries to upload debug disk info to improve armbianmonitor armbianmonitor -m provides simple CLI monitoring armbianmonitor -r tries to install RPi-Monitor armbianmonitor -u tries to upload armhwinfo.log for support purposes This is currently possible. 2
NishaYume Posted April 1, 2016 Posted April 1, 2016 Hi all , i register to see advances in the h3 support. Im happy to see that my orange pi pc will be vanilla kernel support. Thanks for your work! PD: Sorry for me english. 1
Lemonlemon Posted April 3, 2016 Posted April 3, 2016 is it possible to include latest alsa version for 3.4.111? currently it is 1.0.25 which does not have some features required. thanks!
Igor Posted April 3, 2016 Author Posted April 3, 2016 For most system packages we use system defaults (Debian Wheezy-Jessie, Ubuntu Trusty-Xenial). Our build system is currently not friendly for such changes but we are working on it since we need to update some other packages too.
Lemonlemon Posted April 4, 2016 Posted April 4, 2016 Thanks for reply! I am happy with vanilla, which presumably would have the later also version, if i2s could be enabled.
Igor Posted April 11, 2016 Author Posted April 11, 2016 - Added Hummigboard 2 with working PCI and onboard wireless with legacy kernel 3.14.65. This applies for HB1 & Cubox too. 1
Igor Posted April 13, 2016 Author Posted April 13, 2016 - Added new (Allwinner updated) kernel source for H3 DEB: http://mirror.igorpecovnik.com/test/OPI_PC_linux-image-sun8i_4.83_armhf.zip - Added Banana M2+ server and desktop image based on thio new kernel.
disconnect Posted April 13, 2016 Posted April 13, 2016 other bug http://forum.armbian.com/index.php/topic/844-how-to-use-cubietruck-crypto-hardware-sunxi-ss/ however it seems it can't be fixed.
zador.blood.stained Posted April 14, 2016 Posted April 14, 2016 If this is now a bugs collection thread, then it should be noted that b53 patch for lamobo-r1 is not compatible with kernel 4.5.x and this doesn't apply on top of current patch. So I think lamobo-r1 mainline should be excluded from new Armbian release until someone fixes this patch manually (though kernel upgrade will break current images too).
Igor Posted April 14, 2016 Author Posted April 14, 2016 If this is now a bugs collection thread, then it should be noted that b53 patch for lamobo-r1 is not compatible with kernel 4.5.x and this doesn't apply on top of current patch. So I think lamobo-r1 mainline should be excluded from new Armbian release until someone fixes this patch manually (though kernel upgrade will break current images too). Let's say it's more release closing thread. Most of bugs are recorded @github, some of them just emerge withing debates. We people are never optimal I know, was checking yesterday for fixes. Perhaps it would be the best if we put out 4.4.7 within this release? I guess we actually don't have many choices since R1 will break within 4.5.x 1
zador.blood.stained Posted April 14, 2016 Posted April 14, 2016 I know, was checking yesterday for fixes. Perhaps it would be the best if we put out 4.4.7 within this release? I guess we actually don't have many choices since R1 will break within 4.5.x It can be fixed, just needs someone interested to spend some time on this There weren't that many changes to sunxi-next kernel (apart from kernel headers compilation "fix") since last release, so it doesn't matter - release 4.4.x, release 4.5.x or don't release anything yet for this branch.
jh3141 Posted April 16, 2016 Posted April 16, 2016 Speeking as an OPi+2 user who's struggling on with an SD card rather than the onboard MMC and a 1280x1024 monitor with a stretched 720P display, I'm definitely looking forward to this new release. Keep up the good work.
disconnect Posted April 20, 2016 Posted April 20, 2016 There is a patch for sunxi_ss data corruption: https://lkml.org/lkml/2016/3/23/302 Can be included in 5.1? 1
Igor Posted April 20, 2016 Author Posted April 20, 2016 - SS fix added, tnx Also made:- initrd @allwinner - eMMC installer for H3 (you need to build new u-boot for testing) 2
wildcat_paris Posted April 24, 2016 Posted April 24, 2016 (edited) I will be testing R1 b53 switch with latest Armbian updates for kernel 4.5.2 edit : the patch for R1 b53 switch is working Lamobo-R1 up and running! edit : Thanks Zador.blood.stain Edited April 24, 2016 by wildcat_paris tested 2
Igor Posted April 24, 2016 Author Posted April 24, 2016 - added already mentioned R1 patch for 4.5.x. Zador made a great job, again. - upgraded Guitar kernel - added / fixed C1. Thanks to Joe for C1 and Armbian mugs! My generic mugs has been replaced - various small bugfixes 3
zador.blood.stained Posted April 24, 2016 Posted April 24, 2016 - build script: support for Xenial as a build host is 95% ready. - build script: implemented automatic toolchain selection step 1: if kernel or u-boot needs specific GCC version, add this requirement in LINUXFAMILY case block in configuration.shvariables KERNEL_NEEDS_GCC and UBOOT_NEEDS_GCC, supported relationships are "<", ">" and "==", GCC version needs to be specified as major.minor. i.e. UBOOT_NEEDS_GCC="< 4.9" step 2: unpack toolchains (i.e. Linaro) in $SRC/toolchains/For running Linaro 4.8 on x64 build host you need to enable x86 support: dpkg --add-architecture i386 apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 libtinfo5:i386 zlib1g:i386 step 3: run compilation process and check results. Report discovered bugs here on forum on on GitHub. 2
Igor Posted April 26, 2016 Author Posted April 26, 2016 - Lemaker LCD for NEXT and DEV sunxi, disabled by default - Add support for IFB and net scheduling for sun7i-legacy - Udoo next upstream patch 4.4.8 Script: - come cleanup, configurations are subfoldered - extended_deboostrap becomes default Can I build 5.1 ? - it takes 16 hours for all images I know we would soon need 5.11 but anyway. Is there any problem which should be addressed in this week, except H3 auto detection?
zador.blood.stained Posted April 26, 2016 Posted April 26, 2016 Can I build 5.1 ? - it takes 16 hours for all images I know we would soon need 5.11 but anyway. Is there any problem which should be addressed in this week, except H3 auto detection? 16 hours with old debootstrap or with new? Lime2 problems are probably u-boot related, needs testing by someone sun8i-default headers scripts are still broken, I wasn't able to get any consistent results with them, needs more debugging new desktop stuff wasn't tested much but should work I suppose Looking at u-boot config files, different some H3 devices have different DRAM frequency at least in latest version, so IMO best H3 autodetection for me is no autodetection but separate images, but this is for next release (same for separating banana pi pro from other banana pi boards due to SATA and wireless stuff) eMMC installation should be reworked for using PARTUUIDs in the future headers packages should have postrm action to cleanup /usr/src/linux-headers-... directory (it isn't fully removed because of scripts compilation adding new files)
Igor Posted April 26, 2016 Author Posted April 26, 2016 I am now using the new deboostrap option for some time. A lot of time is now consumed on image compressing, which we can afford to have for automated solution. Maybe we can also say default no for compressing images as default for end user? OK, we got some more work to do. Lime2 problems are probably u-boot related, needs testing by someoneI am counting on user feedback here. sun8i-default headers scripts are still broken, I wasn't able to get any consistent results with them, needs more debuggingOK new desktop stuff wasn't tested much but should work I supposeIt looks like it works. Looking at u-boot config files, different H3 devices have different DRAM frequency at least in latest version, so IMO best H3 autodetection for me is no autodetection but separate images, but this is for next release (same for separating banana pi pro from other banana pi boards due to SATA and wireless stuff) I guess we don't have much choices. eMMC installation should be reworked for using PARTUUIDs in the futureand also recreating the file system type headers packages should have postrm action to cleanup /usr/src/linux-headers-... directory (it isn't fully removed because of scripts compilation)OK
bnda Posted April 28, 2016 Posted April 28, 2016 Is there a possibility to build a Ubuntu-Server 16.04 (Xenial) image for BPI-M1+ with ssh preinstalled, as well? Of course, will test and give you response and/or will "tinker"on it... :-) Thanks in general for excellent Armbian :-)
Igor Posted April 28, 2016 Author Posted April 28, 2016 We might build some Xenial images right after (or with) releasing 5.1.
zador.blood.stained Posted April 28, 2016 Posted April 28, 2016 Is there a possibility to build a Ubuntu-Server 16.04 (Xenial) image for BPI-M1+ with ssh preinstalled, as well? Of course, will test and give you response and/or will "tinker"on it... :-) You can build Xenial image with build tools or I can build an image and put in on Dropbox or Google Drive. Do you want legacy or vanilla kernel? BTW, SSH is always preinstalled. 1
bnda Posted April 29, 2016 Posted April 29, 2016 Thanks Igor, would be great.. hope you have time for an image server :-) and in general thanks for doing Armbian... .. and zador.blood.stained I appreciate it.. With my 10-year-old MacBook 2GB Ram (running linux) will be hard to build it..;-) I would prefer a vanilla-kernel.. well when it not stress you.. would be nice.. Cheers...
