1 1
Przemysław Sztoch
Replace ntp with chrony
In my opinion ntp should be replaced by chrony.
Benefits of Chrony include:
1. Faster synchronization requiring only minutes instead of hours to minimize the time and frequency error, which is useful on desktops or systems not running 24 hours a day.
2. Better response to rapid changes in the clock frequency, which is useful for virtual machines that have unstable clocks or for power-saving technologies that don’t keep the clock frequency constant.
3. After the initial synchronization, it never steps the clock so as not to affect applications needing system time to be monotonic.
4. Better stability when dealing with temporary asymmetric delays, for example when the link is saturated by a large download.
5. Periodic polling of servers is not required, so systems with intermittent network connections can still quickly synchronize clocks.
I can prepare patch and pull request, but I need initial confirmation.
Share this post
Link to post
Share on other sites
I second this suggestion.  I've been using Chrony for years (I was the initial maintainer of the Debian Chrony package and also made upstream contributions).  It's much better suited for these sorts of boards.
Share this post
Link to post
Should be in the upstream repo's...
So use apt to purge ntp, and install chrony... chrony is a good solution.
Folks might also want to look at ntpsec packages...
sfx
Share this post
Link to post
On 8/22/2019 at 8:07 AM, Przemysław Sztoch said:
Can I replace ntp by chrony?
See above - yes, you can...
Be mindful of systemd-timesyncd - you might want to disable that one if one is running chrony, ntpd, or ntpsec.
Share this post
Link to post
7 hours ago, sfx2000 said:
systemd-timesyncd
Is disabled by default:
[Time]
#NTP=
#FallbackNTP=0.debian.pool.ntp.org 1.debian.pool.ntp.org 2.debian.pool.ntp.org 3.debian.pool.ntp.org
#RootDistanceMaxSec=5
#PollIntervalMinSec=32
#PollIntervalMaxSec=2048
Share this post
Link to post
systemd-timesyncd
[Time]
#NTP=
But chrony starts at boot, sync time and then dies. Is that normal?
Share this post
Link to post
There was something else in systemd that was stepping on ntpd (and likely chrony), ran into this actually on amd64 - look at journalctl....
Share this post
Link to post
Hmm here  on a NPi Neo2 with armbian stretch  5.2.5-sunxi64 #5.92 chronyd is running after reboot and isnt dying:
root@npi-neo2-22(192.168.6.22):~# ps -ef|grep chrony
_chrony    864     1  0 19:44 ?        00:00:00 /usr/sbin/chronyd
I did "apt purge ntp" /" apt autoremove" / "apt install chrony" and "reboot"
I changed my ntp-servers in /etc/chrony/chrony.conf:
# Welcome to the chrony configuration file. See chrony.conf(5) for more
# information about usuable directives.
# pool 2.debian.pool.ntp.org iburst
# german DCF77 servers in Braunschweig
server ptbtime3.ptb.de iburst
server ptbtime2.ptb.de iburst
server ptbtime1.ptb.de iburst
# This directive specify the location of the file containing ID/key pairs for
# NTP authentication.
keyfile /etc/chrony/chrony.keys
# This directive specify the file into which chronyd will store the rate
# information.
driftfile /var/lib/chrony/chrony.drift
# Uncomment the following line to turn logging on.
#log tracking measurements statistics
# Log files location.
logdir /var/log/chrony
# Stop bad estimates upsetting machine clock.
maxupdateskew 100.0
# This directive tells 'chronyd' to parse the 'adjtime' file to find out if the
# real-time clock keeps local time or UTC. It overrides the 'rtconutc' directive.
hwclockfile /etc/adjtime
# This directive enables kernel synchronisation (every 11 minutes) of the
# real-time clock. Note that it can’t be used along with the 'rtcfile' directive.
rtcsync
# Step the system clock instead of slewing it if the adjustment is larger than
# one second, but only in the first three clock updates.
makestep 1 3
chronyd should only quit with the -q (quit-option):
# chronyd -q 'pool pool.ntp.org iburst'
https://chrony.tuxfamily.org/faq.html
https://chrony.tuxfamily.org/doc/3.4/chrony.conf.html
Share this post
Link to post
Actually any reason we didn't just rely on systemd-timesyncd ?
I know it only implements SNTP, but should be more than enough for SBC use case.
I have nothing against chrony. I was just curious why we didn't consider systemd-timesyncd ;-)
Share this post
Link to post
I deployed Armbian to NanoPi-M1 couple of weeks ago and noticed that chrony fail to start for some reason, so clocks remain not syncronized. Replacing chrony with systemd-timesyncd solved this.
Share this post
Link to post
3 hours ago, RussianNeuroMancer said:
for some reason,
did you take a look a the logs?
Share this post
Link to post
Sure, tried to good this error too, but didn't found anything useful. Anyway, this error is either reproducible on every other supported board (in this case you can reproduce it easily) or specific to NanoPi-M1 (not supported anymore, so I guess there is no point to dig further?) There is also possibility that error is specific to H3-based or Allwinner-based SBCs, but I can't verify this as I don't have other Allwinner-based boards.
Share this post
Link to post
So, it didn't even start at boot?
What is if, you start Chrony from the command line, does it run stable then?
Share this post
Link to post
I checked this issue once again today - it start on boot on bionic image, but no longer works after upgrade to focal. Focal image doesn't even boot (no uboot on HDMI, solid green led; I didn't checked serial).
Log:
May 13 03:04:42 nanopim1 systemd[1]: Starting chrony, an NTP client/server...
May 13 03:04:42 nanopim1 chronyd[8395]: chronyd version 3.5 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +SECHASH +IPV6 -DEBUG)
May 13 03:04:42 nanopim1 chronyd[8395]: Frequency 20.659 +/- 0.346 ppm read from /var/lib/chrony/chrony.drift
May 13 03:04:43 nanopim1 systemd[1]: chrony.service: New main PID 8395 does not exist or is a zombie.
May 13 03:04:43 nanopim1 systemd[1]: chrony.service: Failed with result 'protocol'.
May 13 03:04:43 nanopim1 systemd[1]: Failed to start chrony, an NTP client/server.
However, manual launch via /usr/lib/systemd/scripts/chronyd-starter.sh (found it in /lib/systemd/system/chrony.service) indeed works fine - chrony start and synchronize time.
Share this post
Link to post
23 hours ago, Werner said:
Is there any further output available via journalctl -xe or something?
Two lines appear in journalctl -xe after every attempt to start chrony.service:
May 14 03:15:58 nanopim1 chronyd[1334]: chronyd version 3.5 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +SECHASH +IPV6 -DEBUG)
May 14 03:15:58 nanopim1 chronyd[1334]: Frequency 25.014 +/- 0.137 ppm read from /var/lib/chrony/chrony.drift
Nothing else besides that and service log chrony.service log I posted yesterday.
btw, I noticed that Ubuntu Server 19.10 and 20.04 (I tested generic aarch64 build of Ubuntu Server) ship systemd-timesynd by default, and it sync with ntp.ubuntu.com with default config.
Share this post
Link to post
It's good to have a backup but for maintaining reasons we better keep consistency over targets for basic services such as this. Its better to fix chrony than changing it only for Ubuntu 20.04 where it suppose to breaks. 19.10 is EOL so that's not relevant, but we should check this on Debian Sid / Bullseye.
Share this post
Link to post
@RussianNeuroMancer you could try to use the following commands
(YES - chronyc - which seems to be chrony-controller):
chronyc sources
and
chronyc tracking
see also
https://chrony.tuxfamily.org/doc/3.5/chronyc.html
chronyc sources
MS Name/IP address         Stratum Poll Reach LastRx Last sample
^- 213.251.52.185                2   6   377    24    -10ms[  -10ms] +/-   98ms
^+ ntp2.home4u.ch                1   6   377    23  -3301us[-3301us] +/-   46ms
^+ 195.21.59.161                 2   6   377    21  +6102us[+6102us] +/-   63ms
^* time.cloudflare.com           3   6   377    59  +5630us[+5961us] +/-   33ms
chronyc tracking
Reference ID    : A29FC801 (time.cloudflare.com)
Stratum         : 4
Ref time (UTC)  : Thu May 14 13:21:40 2020
System time     : 0.002209240 seconds fast of NTP time
Last offset     : +0.001954204 seconds
RMS offset      : 0.007558232 seconds
Frequency       : 38.654 ppm fast
Residual freq   : +2.103 ppm
Skew            : 21.641 ppm
Root delay      : 0.063654371 seconds
Root dispersion : 0.001272534 seconds
Update interval : 64.8 seconds
Leap status     : Normal
if that works chronyd(aemon) is running.
I did had the problem - here on my FOX G20 Retro system  that only v1.25 of chrony(c/d) was available to wheezy :(
And the v1.25 seem to hang because chronyc could not talk to the daemon chronyd
So I did download the source from https://github.com/mlichvar/chrony
and compiled it via
./configure / make / make install
(Didnt work in the first try, because I didnt got a system-time :(
BUT a ntpdate -4 -v ptbtime3.ptb.de did help and afterwards I could compile without an error)
Now I call my chronyd from crontab via:
@reboot /usr/local/sbin/chronyd
chronyd -v shows no real version:
chronyd (chrony) version DEVELOPMENT (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -NTS -SECHASH +IPV6 -DEBUG)
my NanoPI Neo2 shows under bulleye:
chronyd (chrony) version 3.5 (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +SECHASH +IPV6 -DEBUG)
[EDIT]
Now I have found the "official" git for chrony (the other is a mirror of the author) at
https://git.tuxfamily.org/chrony/chrony.git/
Now I compiled also the v3.5 on my FOX G20
https://git.tuxfamily.org/chrony/chrony.git/snapshot/chrony-3.5.tar.gz
and got the same version output as on my NanoPi Neo2 with ambian bullseye:
chronyd (chrony) version 3.5 (+CMDMON +NTP +REFCLOCK +RTC -PRIVDROP -SCFILTER -SIGND +ASYNCDNS -SECHASH +IPV6 -DEBUG)
Share this post
Link to post
1 1
