I got a little problem :(
I interrupted the first lines of the compile.sh and now I do get the error:
root@core2duo(192.168.6.19):/home/guido/build# ./compile.sh EXPERT=yes
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
I did found out that when entering the command "exit" this shell will close and the normal menu driven compile gui does start,
but maybe anyone could give me a hint to resolve this issue?
Many Thanks in advance :)
I've faced the same issue earlier today, but didn't figured out why yet ...
some pages on the net say something about /dev/pts, but it looks OK for me and is available
It seems to have somehting to do with changeing the user?:
root@core2duo(192.168.6.19):/home/guido# su guido
bash: cannot set terminal process group (1455): Inappropriate ioctl for device
guido@core2duo(192.168.6.19):~$
Its something about the "interactive" part of the bash.....but I couldnt find a solution by now :(
2 hours ago, Igor said:
@guidol
Is this still present? Do manual apt pull inside ... we have a broken pulling at this moment.
A apt pull inside?
I did a "apt update -y && apt upgrade -y" but it didnt help :(
Thats the point where I what I get after the "exit":
root@core2duo(192.168.6.19):/home/guido/build# exit
exit
 ...waiting for child to terminate.
[ o.k. ] Using config file [ /home/guido/build/userpatches/config-example.conf ]
[ o.k. ] Command line: setting EXPERT to [ yes ]
[ o.k. ] Preparing [ host ]
[ o.k. ] Build host OS release [ bionic ]
[ o.k. ] Syncing clock [ host ]
So it should be anything before these alert-lines.
BTW: Iam running on real hardware - no Docker/Vagrant/VMBox - so all if-statements shouldnt apply to my installation
12 minutes ago, guidol said:
A apt pull inside?
yes
git pull
Changes were affected building on real hardware as well. This:
https://github.com/armbian/build/pull/1580
has to be solved different way.
1 hour ago, Igor said:
git pull
but you did wrote before "apt pull" ;)
"git pull" doesnt seem to have a effect on my system because
root@core2duo(192.168.6.19):/home/guido/build# git pull
Already up to date.
I did set some breakpoints in the compile script and the problem seems to be in this if statement, because I get the echo "before messup" and then the error-message.
The command with the Problem is, because of the output EUID0:
su `stat --format=%U $SRC/.git` -c bash $TMPFILE
[EDIT] @Igor maybe the command neeeds a "="? I checked the git command for the option -c and this needs
<name>=<value>
but here if bash is the name $TMPFILE isnt the value - because there is no "="
How about this line - with this I didnt get a error:
su `stat --format=%U $SRC/.git` -c bash=$TMPFILE
script-part and output of the breakpoints:
echo "Sleep 5"
sleep 5
#do not update/checkout git with root privileges to messup files onwership.
#due to in docker/VM, we can't su to a normal user, so do not update/checkout git.
if [[ `systemd-detect-virt` == 'none' ]]; then
        if [[ $EUID == 0 ]]; then
                echo "EUID0" && su `stat --format=%U $SRC/.git` -c bash $TMPFILE
        else
                echo "EUID1" && bash $TMPFILE
        fi
fi
rm $TMPFILE
echo "After messup"
echo "Sleep 5"
sleep 5
Update Part
After Update
Sleep 5
before messup
Sleep 5
EUID0
exit
After messup
Sleep 5
 How can we correct ownership if messed up?
Is there a alternative command for real-hardware?
maybe in $TMPFILE, use return to replace exit?
because I can only test euid !=0.  no such error.
2 hours ago, ning said:
I have a fix: https://github.com/armbian/build/pull/1581
sorry for that.
Thanks for the fix! :)
I inserted it in my compile.sh manually ;)
Will the system update compile.sh when you pull request is commited?
Because of
error: Your local changes to the following files would be overwritten by merge:
        compile.sh
Please commit your changes or stash them before you merge.
Aborting
[ warn ] Can't update since you made changes to:
compile.sh
Press <Ctrl-C> or exit to abort compilation, <Enter> to ignore and continue, diff to display changes
diff
diff --git a/compile.sh b/compile.sh
index 048a7b5..7ce4396 100755
--- a/compile.sh
+++ b/compile.sh
@@ -76,7 +76,7 @@ echo update_src >> $TMPFILE
-               su `stat --format=%U $SRC/.git` -c bash $TMPFILE
+               su `stat --format=%U $SRC/.git` -c "bash $TMPFILE"
        else
                bash $TMPFILE
        fi
Or have we to replace compile.sh and a "checksum-file"?
9 minutes ago, martinayotte said:
It is already merged, issue is gone ...
Cool :)
OK, I reverted the changes to get the original state and then I did a "git pull" inside the build-directory:
Updating 2c0adc0..de58ac1
Fast-forward
 compile.sh | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
Is there any other git-command to overwrite changes while "git pull"?
Or is there a revert-command (stash the changes)?
I do only found ideas like
https://gist.github.com/vladimirtsyupko/10964772
but dont know how to aplly them to the armbian-git (master)...
