Single Armbian image for RK + AML + AW (aarch64 ARMv8)
I have X96 MAX. I download, burn and start Armbian_20.08_Arm-64_buster_current_5.7.15.img.xz from micro sd card. Internal storage is not found in kernel messages but when I try with Armbian_20.02.0-rc1.037_Aml-s9xxx_buster_current_5.5.0-rc6_desktop_20200205.img.xz I see all storage's (internal and external) and installation is ok.
I don't know way when I'm starting from Armbian_20.02.0-rc1.037_Aml-s9xxx_buster_current_5.5.0-rc6_desktop_20200205.img.xz showed memory is 3.2GB but when I start from Armbian_20.08_Arm-64_buster_current_5.7.15.img.xz showed memory is 3.6GB?
Little probleme with the last armbian buster 5.5.0.
After Qjackctl start:
/dev/snd/seq failed: No such file or directory.
Any solution ?
Sorry for my english im french.
On 8/20/2020 at 10:57 PM, sengsu said:
AFAIK, it has hisilicon hi3798mv100 which is a armv7
Regarding Linux on this box, i have found on chinese forum, someone managed to install Ubuntu 16.04 using serial console and hitool. But the sad news is, it uses ancient kernel 3.10
Hi @sengsu: Could you please give me the link about this successfull attempt? rightnow I had soldered the male header pin successfully. But just need a direction.
On 8/21/2020 at 4:21 PM, balbes150 said:
It is not a fact that you can use the UART console to activate multi-loading. The manufacturer could block the startup process from being interrupted in u-boot, in which case you will only be able to see the startup process itself.
@balbes150: It seems you are right. USB TTL does not work when the bootloader is locked by the firmware. Is there anyway to brick the bootloader forcefully?
For EC6108v9, I had soldered the male header pin, then connected the USB TTL (prolific 2303) to the pin:
GND - GND, TXD-RX, RXD-TX
Then I tried:
- ls /dev/ttyUSB*
   /dev/ttyUSB0
- sudo screen /dev/ttyUSB0 115200
Then I just got a Blank Screen.
I also tried using putty in serial connection, but I got a blank screen (black) using /dev/ttyUSB0 at 115200
Does this means that it is blocked by the firmware?
Edited by rna
Build on Windows 10 WSL2.
I was able to build the image from source code on Build-Armbian on Windows 10 (WSL2) Ubuntu 18.04.
Used NO_APT_CACHER=yes and cloned the folder in ~/. Had multiple build failures without these settings.
Thought I would share, just in case if someone is interested to use this environment to build images.
-R
hi, you can see here and use google translate if you dont understand chinese  :
http://www.hdpfans.com/thread-826810-1-1.html
if you already successfully download the file and other source code from pan baidu,  i hope you can reupload it to mega or other site, so people outside china mainland can try it too.
Actually I am not interested in the file. But I am interested in the process of how the uploader achieved it. It seems ubuntu 16 does not work well in this box based on the uploader description from Google Translate. There is no step by step as well on how to burn the image from Hitool. Which makes the process more complicated.
I am thinking that if somehow we can brick this box and force it to read the SD Card. That might trigger Armbian to boot. But I don't know how to brick it forcefully.
To be Honest, I really like how U-boot magically works in Allwinner by re-writing "u-boot.img" to the SD Card. How I wish to have such procedure for Amlogic
Edited by rna
Can someone help me get the midi to work on my h96 pro + s912?
Is there a specific distro to install (even dated) to operate the "midi"?
hi @balbes150, nanopc T4 freezes with the latest build 2020.08.21, Armbian_20.08_Arm-64_focal_current_5.7.16.img.xz . I can reproduce it by writing zeros to a USB2 HDD. The USB HDD works well on other systems.
tty@arm-64:/storage/upload$ dd if=/dev/zero of=./test_io bs=1M status=progress
2585788416 bytes (2.6 GB, 2.4 GiB) copied, 122 s, 21.2 MB/spacket_write_wait: Connection to 192.168.1.183 port 22: Broken pipe
The same applies to USB3 HDD.
tty# dd if=/dev/zero of=./test_io bs=1M status=progress
2681208832 bytes (2.7 GB, 2.5 GiB) copied, 53 s, 50.6 MB/spacket_write_wait: Connection to 192.168.1.183 port 22: Broken pipe
2637168640 bytes (2.6 GB, 2.5 GiB) copied, 53 s, 49.8 MB/spacket_write_wait: Connection to 192.168.1.183 port 22: Broken pipe
 I checked kern.log after reset, there's no abnormal logs.
One interesting thing is that it ALWAYS dies after writing ~2.5GB. The actual data written out is ~1.9G. My board has 4G memory. It dies earlier if I write to NTFS partition, ~1.2G.
Any help/comments on my question? In the meantime was able to successfully boot my X92 with Armbian_20.08_Arm-64_focal_current_5.7.16_desktop.img.xz. Sound playing over HDMI out of the box. Bluetooth not working (was working in the bionic build). Wifi working. Memory, CPU, diskspace reporting correctly. GPU not working. (Read about panfrost lima but no clue how to install). Liking my journey with Armbian. Thanks all the developers.
You seem to have answered your question yourself.
You are close... try this.
Version 20200825 kernel 5.7.16.
Fixed 3.5 analog audio for Nanopc t4.
add dir deb (kernel pakages)
Which image and dtb are you using ? I am unable to make it work . I have tried with almost all gxm dtb but it freezes on H96Pro logo .
50 minutes ago, cicéron said:
Gaurav, Vega s96 dtb.
Strange mine is stuck on the logo with this dtb as well. I do have H96 Pro + (S912) .  Not sure how to move past this screen
Thanks. You are awesome. Meanwhile in the focal build running on x92 3 + 32 saw that desktop was not showing up on my tv though boot scroll and shut down scroll was visible. Didn't face the same issue with computer monitor. Think there is an issue during display protocol negotiation during changeover to desktop. Changed the display frequency to 60hz which my tv supports in the display settings. Problem resolved.
On 8/14/2020 at 1:16 PM, balbes150 said:
The new version of images 20200814.
Please note that the algorithm for initial configuration of the system for startup has changed. Instead of a file "uEnv.txt", the file "/extlinux/extlinux.conf " is now used. The rules for editing a file remain the same.
All Amlogic models now need the "u-boot.ext" file.
Before launching on Amlogic, you must copy or rename one of the existing files "u-boot-*" to "u-boot.ext".
For s905 (not X) - used u-boot-s905
For s905x and s912 - used u-boot-s905x-s912
For s905x2 and s922 - used u-boot-s922
For g12a\g12b models, a single file is now used (files u-boot.sd and u-boot.usb now replaces one u-boot-s922 file).
"For g12a\g12b models, a single file is now used (files u-boot.sd and u-boot.usb now replaces one u-boot-s922 file)."
don't understand this, do we have to create one more file?
can you provide a folder listing of /, i'm having problems renaming the files
Bug?
HW: nanopc-t4
Image: Official 20.08 release (focal current)
Issue:
After boot, CPU usage  of core 0 keeps high. It almost remains at 100%.
    PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
    317 root     -51   0       0      0      0 R 100.0   0.0  24:02.87 irq/58-ff940000
I saw the following dump in dmesg.
[    5.673878] systemd[1]: Detected architecture arm64.
[   33.762463] vbus_typec: disabling
[   65.270398] rcu: INFO: rcu_preempt self-detected stall on CPU
[   65.270420] rcu:     0-....: (15006 ticks this GP) idle=16a/1/0x4000000000000002 softirq=380/382 fqs=6474
[   65.270429]  (t=15000 jiffies g=-123 q=4511)
[   65.270436] Task dump for CPU 0:
[   65.270443] irq/58-ff940000 R  running task        0   317      2 0x00000028
[   65.270457] Call trace:
[   65.270473]  dump_backtrace+0x0/0x1d8
[   65.270481]  show_stack+0x18/0x28
[   65.270493]  sched_show_task+0x160/0x190
[   65.270503]  dump_cpu_task+0x44/0x58
[   65.270513]  rcu_dump_cpu_stacks+0xb0/0xf0
[   65.270522]  rcu_sched_clock_irq+0x9b8/0xc38
[   65.270532]  update_process_times+0x30/0xc0
[   65.270545]  tick_sched_handle.isra.0+0x34/0x58
[   65.270555]  tick_sched_timer+0x58/0xb0
[   65.270564]  __hrtimer_run_queues+0x148/0x3c0
[   65.270574]  hrtimer_interrupt+0xf4/0x258
[   65.270585]  arch_timer_handler_phys+0x34/0x48
[   65.270596]  handle_percpu_devid_irq+0xa0/0x2b8
[   65.270605]  generic_handle_irq+0x30/0x48
[   65.270613]  __handle_domain_irq+0x94/0x108
[   65.270624]  gic_handle_irq+0x60/0x158
[   65.270633]  el1_irq+0xb8/0x180
[   65.270643]  preempt_count_sub+0x8/0xd8
[   65.270654]  regmap_unlock_spinlock+0x14/0x20
[   65.270662]  regmap_write+0x58/0x78
[   65.270687]  dw_hdmi_irq+0x14c/0x210 [dw_hdmi]
[   65.270697]  irq_thread_fn+0x2c/0xa0
[   65.270705]  irq_thread+0x150/0x250
[   65.270715]  kthread+0x114/0x148
[   65.270724]  ret_from_fork+0x10/0x34
[  147.119317] systemd[1]: Set hostname to <nanopct4>.
[  147.207216] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
Do not know what to do to solve this issue.
The exact name of the image.
Hello.
Tell me how to install Armbian so that it boots from eMMC on my TV-box x92 3/16?
With SD, Armbian loads and works well for me, I want it to work from eMMC on the set-top box, but I can't find a suitable instruction for my build version.
I have Armbian_20.02.0-rc1.038_Aml-s9xxx_eoan_current_5.5.0-rc6_desktop_20200205.img
I use meson-gxm-q201.dts, with which everything works great (except for the indicator on the front panel  and not sound).
Installing via armbian-config does not work, in the "system" section there is no item "install to eMMC, NAND, SATA & USB"
  Explain how can I put Armbian on eMMC?
Edited by iKPYT
I'm unable to make this work. I have what I believe is some random generic box (this one), with an Amlogic S905X. I'm sure I'm doing something wrong, or perhaps I'm missing a step or something. This is what I do:
1- Burn Armbian_20.08_Arm-64_focal_current_5.7.16_desktop.img.xz into a MicroSD with rufus.
2- In the BOOT partition, modify the 'extlinux.conf' and comment out everything except 'FDT /dtb/amlogic/meson-gxl-s905x-p212.dtb' and the APPEND that is there below (I honestly don't know how this thing works, I don't know if I have to change something or even if I should use it, sometimes I left it out with no difference).
3- Renamed the 'u-boot-s905x-912' into 'u-boot.ext'.
When I try to boot the SD card in the tv box nothing happens, I go directly to the Android system. I have another SD card with 'Alexelec' that boots fine. This box doesn't have a reset button, I tried flashing 'aml_autoscript' but it says 'error' after rebooting.
What I'm missing?
Regards!
Read the first message of the topic.
Read the first message of the topic, especially the one highlighted in red.
Has anybody here had success with running Single Armbian Image on RK3399 Orange Pi 4?
I tried using the latest image with revised procedure using extlinux. There are two dtb available in rockchip folder.
1. rk3399-orangepi-4.dtb. No HDMI with this image.
2. rk3399-orangepi.dtb. HDMI works only on 1024x728 resolution and no sound.
The startup screen and u-boot messages with both screen were hazy and jumbled.
If anybody here had got this working, let me know if these are the correct dtb files?
Thanks
-R
I assume a normal reset in the Android system wouldn't work, right? Because firmwares for these kind of boxes are usually non-existent, and I don't have any backup.
Hooray put it on eMMC, thanks to balbes150 for his work!
However, with the sound question, the image I use does not have a file gx_sound.sh there is only g12_sound.sh,
but is it suitable for GXM? or where to get gx_sound.sh?
Hello, I have a bunch of services already installed (also ssh host keys, etc). Is there the possibility to upgrade my S905 5.3 kernel to 5.7 without reflashing image? I started with Armbian_5.90_Aml-s905_Debian_buster_default_5.1.0_20190701 and was able to update to 5.3 branch
Hello
I ran Armbian from the SD card image:
Armbian_20.06.0_Arm-64_focal_current_5.7.6_desktop_20200630.img.xz
for Mecool m8s pro W (amlogics905x)
When installing to eMMC, I chose the install_aml_emmc.sh script and restarted the system after installing it. Unfortunately, from now on, the box does not work with the emmc or the SD card (only black screen on the HDMI output)
In previous experiments with this box and Armbian, I usually installed the system on the box with the install_aml.sh script and everything worked fine - I just have no idea why I chose a different script this time?!?!?
I tried to start the box with the reset pressed, but without a positive result.
Is there a chance to rescue the box?
