  On 1/11/2020 at 11:54 PM, chwe said:
so a small update...
Expand
Thanks chwe !!!
Not sure what was preinstalled but after flashing the "debian" image to sd, then emmc, it try to boot from sd, if no card, from emmc.
I never been able to mount the boot partitions but they do stuff using gdisk.
P.S. There is a recovery button, no idea what it does.
@martinayotte if I short eMMC clk to ground does it enter maskroom directly or does it just skip eMMC and tries SD card then?
Expand
To my knowledge, it should skip eMMC and try to find bootmagic from SDCard ...
(BTW, My OPi4 is still in the slovenia post, maybe I will receive it next week ...)
Someone sayd that the armbian op-rk3399 kernel 4.4, works on op4. Havent tested but i can tell that op-rk3399 kernel 5.4 doesnt work.
Expand
@Jack953 try beta images for OrangePi 4 instead ;). They are available in the download area: https://dl.armbian.com/orangepi4/archive/
I used buster for my preliminary support testing.
Keep in mind that the board support is in beta or even alpha state right now.
It works to some degree ... screen is black, but you can boot from SD card ... by inserting it in. (self made image - will try from the download l8r)
  Reveal hidden contents
More: http://ix.io/28r8
Expand
I did only test HDMI output in current (5.4.14) and it worked there. I must get myself a desktop monitor to test GUI more often ;p
I am glad it boots for you to the point where you can log in. At least now it is not only me who can boot it.
Expand
Yes, it works there :) I thought it will be the other way around. 5.4.y looks stable to me ... but I do use a heatsink and a good power source. http://ix.io/28ro
Happy for the progress! thank u all! Even if it doesnt work for me, not sure why... No video from hdmi and it doesnt connect to the lan... i tryed the buster 5.4 in the main folder and in the archive folder.
I tried Buster desktop/server and Bionic desktop/minimal but I have no HDMI output.
Actually my OPi4 only works only with the (slow) Orange Pi Ubuntu.
  On 1/27/2020 at 12:12 PM, Igor said:
Scroll down and pick version with kernel 5.4:
https://www.armbian.com/orange-pi-4/#kernels-archive-all
Version 4.4.y is without HDMI ATM, 5.4.y have HDMI ... it takes little longer to boot, be patient.
Expand
Thank you @Igor but it seems that don't want to boot. I see only a red light on the board and after 20 minutes I removed the power cable and the microSD card (32 GB) and on my PC the size of the partition remains ~4 GB (it has not been resized).
I think there somethink wrong with no NPU models but I can't see the error on my screen to understand.
Thank you for your great work.
Expand
OK. This was very first official test build and problems are more than expected.
Expand
Its possible but can't check since I only have this one.
  On 1/28/2020 at 12:58 AM, Jack953 said:
Here is the debug log !
Doesnt look encouraging :wacko:
Expand
Hmmm... IMHO it looks like your UART dongle cannot keep up with the data flow at 1.5Mbps.
What is the chip used in the dongle that you have?
Apart from that I cannot see much in the output and what is seen comes from the very early loader stage - probably from your earlier tries written to eMMC ;-)
Neither Armbian nor Xunlong uses DDR binary at version 1.22 - we use 1.24 and they have 1.15.
Buster kernel 5.4 works on my opi4 (non npu). Just that no hdmi output on my ultra wide screen monitor. Need to test out on a 16:9 monitor.
TTL com and lan login works ok.
Expand
Is that a v1.3 board ?
In my case, two days ago, it didn't reach the login prompt using Armbian_20.02.0-rc1_Orangepi4_buster_current_5.4.14_desktop.img ...
  On 1/28/2020 at 7:29 AM, piter75 said:
Hmmm... IMHO it looks like your UART dongle cannot keep up with the data flow at 1.5Mbps...
Expand
I dont think so, with working os i see pretty regular; Im using rpi; not my try (I wish I was able:) );
I installed OP image to ssd, maybe thats the problem ? but when Insert the sd with OP image, it boot from sd.
I could try to format the emmc with a command like:
dd if=/dev/zero of=/dev/mmcblk1 bs=1M count=100 > /dev/null 2>&1
(from scripts, I understand only the half of this command)
but will it boot from sd then ??? I wouldnt like to brick it :)
Expand
Similar issue here:
  • Orange PI 4, v1.3 board
  • model 4 (non NPU), no eMMC, booting straight from SD
  • tested with downloadable Armbian_20.02.0-rc1_Orangepi4_buster_current_5.4.14_desktop.img (2020-01-25)
  • tested with manual build using current code base in GitHub, with Buster + 5.4.y kernel, server, standard
Can't get my hands on an UART dongle right now, but can tell neither the green led is flashing (such as when using a working build using the Orange PI toolchain/code/scripts), nor does it get an IP (checked DHCP logs and sniffed network traffic)
Formated the emmc, the new log changed, its much better but still doesnt work (and yes there is some problem with the uart but its readable; did it cut something on the end? not sure...)
P.S. "securemode = 0" doesnt sounds good...
also: "Addr:0x8000 No find trust.img!"
Expand
I'm not too sure whether is v1.3, maybe covered up by the heat sink I put on. Based on the serial label on board, should by produced in 20191122
Attached is the com screenshot after boot.
Noticed that kernel takes quite some seconds to load.
Expand
IMHO it is perfectly normal.
I can see now that the boot starts with our image:
:DR Version 1.24
Boot1: 2019-03-14, version: 1.19
What is strange though is that it tries to boot from some medium with GPT partitions:
GPT part:  0, name:            uboot, start:00x2000 // probably 0x6000 but got garbled
GPT part:  1, name:            trust, start:0x8000, size:0x2000
GPT part:  2, name:             boot, start:0xc000, size:0x10000
GPT part:  3, name:           rootfs, start:0x5c000, size:0x4b27df
These are probably eMMC partitions.
Armbian's image does not have GPT partitions - you can observe it in Igor's boot log:
GPT 0x3190d20 signature is wrong
It tries to boot with those partitions but obviously cannot as they are already erased.
Does if boot now with Xunlong's image on SD?
If so and you want to give it another try, then also erase the end of eMMC device as you did with the beginning of it.
This should erase the secondary GPT on eMMC.
dd if=/dev/zero of=/dev/mmcblk1 bs=1M seek=14900
After that you can try booting again with Armian's image.
Ok ! I've finally found my issue with Non-Rev OPi4 : a junior mistake ! -_-
A power supply issue, I've decided to measure it after the freeze, it was too low !
I've try another PSU, and it reach the login prompt !
I'll happily move your posts here then:
https://forum.armbian.com/forum/31-sd-card-and-psu-issues/
:lol::ph34r:
sorry I couldn't resist.. :D I use the goat PSU called RPi USB-C PSU for most of my USB-C boards at the moment, until yet I didn't figure out a board which doesn't work as it should with it (my dirt cheap IKEA charger does also well but that one is used productive atm).
btw is the bq25700 from page 3 really populated on the board? It might have some interesting features to mess with.. http://www.ti.com/product/BQ25700A
(Input and Battery Current Monitor)
Expand
:P
It was a barrel PSU, but a 2A instead of 3A ...
Another point : WiFi didn't work at first, so using my usual recipe, it worked : "systemctl disable NetworkManager" and use "old school" /etc/network/interface ...
  On 1/29/2020 at 8:58 PM, martinayotte said:
I bet it is also another copy/paste error from orangepi-rk3399 schematic ...
Expand
it seems.. from the i2c map @piter75 shared I don't see a candidate fitting to bq25700... :( shame would've been a nice feature.. as much as I've love the powertree on page 3.. a not correct one is a pain to mess with..
