Hi. I've upgraded Buinic to Eoan and encountered an error with apt-get. Decided to have a fresh install of Disco from https://dl.armbian.com/orangepizero/ and got exact same error.
I did nothing with the installation except that I've configured WiFi with ntmui-connect command.
So I guess this is some issue with Ubuntu releases 19.xx
root@orangepizero:~# apt-get update && apt-get upgrade
Hit:1 http://ports.ubuntu.com disco InRelease
Hit:2 http://ports.ubuntu.com disco-security InRelease
Hit:3 http://ports.ubuntu.com disco-updates InRelease
Hit:5 http://ports.ubuntu.com disco-backports InRelease
Hit:4 https://apt.armbian.com disco InRelease
Traceback (most recent call last):
  File "/usr/lib/cnf-update-db", line 26, in <module>
    col.create(db)
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 93, in create
    self._fill_commands(con)
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 127, in _fill_commands
    self._parse_single_commands_file(con, fp)
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 165, in _parse_single_commands_file
    suite=tagf.section["suite"]
KeyError: 'suite'
Reading package lists... Done
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
No, I tried that - it didn't resolve the issue. I also considered a theory that an upgrade messed python 2.7 and 3.6 - didn't solve my problem as well.
on my OrangePi One creator.py is at
root@opi-one(192.168.6.114):/ # find / -name *creator*
/usr/share/command-not-found/CommandNotFound/db/creator.py
and cnf-update-db is as a symbolic link at the right place
root@opi-one(192.168.6.114):/usr/lib# ls -l cnf*
lrwxrwxrwx 1 root root 40 Nov 21  2018 cnf-update-db -> ../share/command-not-found/cnf-update-db
so whats the error after
sudo cp -r /usr/share/command-not-found/CommandNotFound /usr/lib/python3/dist-packages/
I will check in a moment. Currently trying other distributions. Found out that there is no wireless connectivity on Armbian_19.11.3_Orangepizero_buster_current_5.3.9 (nmtui-connect only displays "Wired connection 1").
root@orangepizero:~# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/ether 2a:d0:11:70:4e:02 brd ff:ff:ff:ff:ff:ff
3: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000
    link/ether 02:42:e8:02:49:d9 brd ff:ff:ff:ff:ff:ff
4: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 1000
    link/ether e2:2f:6f:d6:df:b2 brd ff:ff:ff:ff:ff:ff
root@orangepizero:~# ip link set dev wlan0 up
RTNETLINK answers: Invalid argument
your problem is just one thread aways (from the actual one's):
As I said in this other thread :
Quote
In my case, I'm using "old school" /etc/network/interface, running Stretch 5.4.2, and WiFi running properly as soon as I disabled NetworkManager service.
Re-installed Disco, wireless connectivity worked, but apt-get update produces error. Checking:
root@orangepizero:~# cd /usr/lib
root@orangepizero:/usr/lib# ls -l cnf*
-rwxr-xr-x 1 root root 684 Nov  9  2018 cnf-update-db
root@orangepizero:/usr/lib# find / -name *creator*
/usr/lib/python3/dist-packages/CommandNotFound/db/__pycache__/creator.cpython-37.pyc
root@orangepizero:/usr/lib# cp -r /usr/share/command-not-found/CommandNotFound /usr/lib/python3/dist-packages/
cp: cannot stat '/usr/share/command-not-found/CommandNotFound': No such file or directory
Tried
sudo cp -r  /usr/lib/python3/dist-packages/CommandNotFound /usr/share/command-not-found/
and also
sudo cp -r  /usr/lib/python3/dist-packages/CommandNotFound /var/lib/command-not-found/
Error is caused by /usr/lib/cnf-update-db in the line 165, which reads:
        # read header
and then causes error in line 127, which is
    def _fill_commands(self, con):
        for f in self.files:
            with open(f) as fp:
As far as I can understand, it works with this list of files:
root@orangepizero:~# ls -la /var/lib/apt/lists/*Commands-*
-rw-r--r-- 1 root root    699 May 29  2019 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-backports_main_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root     74 Nov 21  2018 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-backports_multiverse_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root     74 Nov 21  2018 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-backports_restricted_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root    156 Sep 14 07:17 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-backports_universe_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root   8023 Oct 23 22:22 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-security_main_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root     73 Nov 21  2018 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-security_multiverse_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root     73 Nov 21  2018 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-security_restricted_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root   7297 Oct 21 20:17 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-security_universe_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root  13128 Oct 24 14:17 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-updates_main_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root     72 Nov 21  2018 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-updates_multiverse_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root     72 Nov 21  2018 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-updates_restricted_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root   9799 Oct 24 14:17 /var/lib/apt/lists/ports.ubuntu.com_dists_disco-updates_universe_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root  48897 Apr 17  2019 /var/lib/apt/lists/ports.ubuntu.com_dists_disco_main_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root  13300 Apr 17  2019 /var/lib/apt/lists/ports.ubuntu.com_dists_disco_multiverse_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root    354 Feb 22  2019 /var/lib/apt/lists/ports.ubuntu.com_dists_disco_restricted_cnf_Commands-armhf.lz4
-rw-r--r-- 1 root root 475539 Apr 18  2019 /var/lib/apt/lists/ports.ubuntu.com_dists_disco_universe_cnf_Commands-armhf.lz4
Tried
Hmm - I did wrote the command with the path as oposite ( /usr/share in front , because it is there on my system):
To double-check, wiped the SD card and burned the image again. On fresh system:
Welcome to Armbian Disco with Linux 5.3.9-sunxi
System load:   0.00 0.11 0.10   Up time:       8 min
Memory usage:  15 % of 491MB    IP:
CPU temp:      66°C
Usage of /:    6% of 15G
root@orangepizero:~# ls -la /usr/lib/python3/dist-packages/CommandNotFound
total 40
drwxr-xr-x  4 root root  4096 Nov  1 09:35 .
drwxr-xr-x 14 root root  4096 Nov  1 09:34 ..
-rw-r--r--  1 root root 16319 May  4  2018 CommandNotFound.py
drwxr-xr-x  3 root root  4096 Nov  1 09:35 db
-rw-r--r--  1 root root    40 Mar 16  2018 __init__.py
drwxr-xr-x  2 root root  4096 Nov  1 09:35 __pycache__
-rw-r--r--  1 root root  1641 Mar 16  2018 util.py
root@orangepizero:~# ls -la /usr/share/command-not-found/
total 2624
drwxr-xr-x  2 root root    4096 Nov  1 09:27 .
drwxr-xr-x 93 root root    4096 Nov 19 08:13 ..
-rw-r--r--  1 root root 2678784 Nov  9  2018 commands.db
root@orangepizero:~# ls -la /var/lib/command-not-found/
total 32
drwxr-xr-x  2 root root  4096 Nov 19 08:15 .
drwxr-xr-x 27 root root  4096 Nov  1 09:30 ..
-rw-r--r--  1 root root 24576 Nov 19 08:15 commands.db.tmp
The /usr/lib/cnf-update-db throws error "out of the box": I never ran apt-get, I even haven't set up networking - it is "dead on arrival".
Quote
Non-LTS Ubuntu releases are not supported anyways. The ability to built those through the build system has been added by user contribution. They are to be considered experimental.
12 minutes ago, Werner said:
experimental
Exactly. Anything out from Bionic and Buster is not supported / on your own risk. We have no intention nor resources to fix after buggy Ubuntu development and/or non LTS releases. But if one like to use it, use it ...
Since last major upgrade, DISTRIBUTION status is getting a property and if you are running not one of them, you also get prompted:
https://github.com/armbian/build/blob/master/lib/main.sh#L273-L286
https://github.com/armbian/build/blob/master/packages/bsp/common/etc/profile.d/armbian-check-first-login.sh#L80-L82
Well, my intention was to use Debian Buster, but its wifi connectivity is broken, so I had to start shopping around.
Canonical / Ubuntu / Debian / * are not responsible for low level (hardware) functions, (Armbian) Linux kernel is. We provide different user space versions (Debian X, Ubuntu Y) for application level.purposes and testings. Wifi on this board is low/barely usable quality even when available.
This error rears its ugly head again in Focal 20.04LTS with the OPi0.
Googling for results for this error (it's exactly the same) gives exactly one google result - this thread.
So, for anyone else stumbling over this, here the solution:
sudo apt purge command-not-found
sudo apt --purge autoremove
sudo bash -c 'apt update && apt full-upgrade && apt autoremove && apt clean'
Unfortunately, a reinstall of the pkg 'command-not-found' brings back the same error.
This package is just for comfort. If you need suggestions for installing packages after entering nonexisting commands, just use another computer for reference. I advise to just leave it uninstalled for now.
