mainline amlogic hwvdec with patches still in review, can be directly used by mpv with `-hwdec=auto`
cpu usage drop to 10% from 50%
@ning
Glad to hear that .  Could you please tell me how to apply the codec to current mainline armbian OS ? I installed the latest armbian ( Armbian_20.02.0  with eoan desktop ) at my s905x tv box  and I would like to try it .  Thankyou !
I'd also like to try this on my s905x/w tv boxes, please share your steps @ning :thumbup:
I'll try the build root they used and see how far I get but this is above my pay grade.
I don't know buildroot. I just use these components from mainline: libdrm, libglvnd, xserver, mesa, libwayland. and mainline linux kernel with vdec patches.
my repo is currently disabled, due overload, and its only for buster, for os image, you can build from source or ask image owner.
aml vdec can be used directly by gstreamer, that means, we can play video from web via firefox or gnome-web.
Hi, i'm also interested on this topic. I'm recently trying to figure out how to use the meson_vdec module. When enabled, it report new v4l2 device (as it should), but when trying to use mpv with --hwdec=auto (or hwdec=yes) with a hvec video (v4l2-ctl report that the meson_vdec have a hevc (h.265) decoder) i got a lot of "[ffmpeg/video] hevc_v4l2m2m: output  POLLERR" and then a segmentation fault.
To be clear, i'm not expecting that it works out of the box, even when loading the module, a warning appear saying that it is in staging phase and not means for daily use. I have not applied any patch, but i'm using debian sid repository.
If someone make the meson_vdec working (that, if i'm not wrong, it is a v4l2 driver), there is a chance that it is possible to get also a VA API driver using libva-v4l2-request: https://github.com/bootlin/libva-v4l2-request.
From what i have understood correctly, this library provide a VA API interface to a v4l2 driver, making it also compatible with VA API. Probably it will not support all the features, but... it is basically a free driver implementation.
@UniformBuffer
Did you find any solution for this issue?
I installed debian Linux odroidc2 5.4.35-meson64 and like you when I use mpv with --hwdec=auto or yes I'm getting endless [ffmpeg/video] hevc_v4l2m2m: output  POLLERR.
I didn 't patch anything only got the latest mesa so I could use lima for hardware acelleration.
Now on video hardware decoding with meson vdec no luck
Thanks
Edited by dante6913
24 minutes ago, dante6913 said:
@UniformBuffer
Thanks
Unfortunatly no, i'm also trying to get this working. I have looked on the internet, but i have found no result about this error. Honestly i don't know what is the cause. Probably there is something wrong on low level code and i'm not enough skilled on this to figure out what's the problem :(. I think we have to wait for some kernel update that generally bring some fixes.
I have noticed that when i launch mpv with hardware decoding enable, dmesg gives me some errors. Maybe can be useful to figure out what's the problem:
[20730.099205] alloc_contig_range: 208 callbacks suppressed
[20730.099211] alloc_contig_range: [6c200, 6c300) PFNs busy
[20730.099351] alloc_contig_range: [6c300, 6c400) PFNs busy
[20730.100084] alloc_contig_range: [6c200, 6c300) PFNs busy
[20730.100221] alloc_contig_range: [6c300, 6c400) PFNs busy
[20730.100340] alloc_contig_range: [6ce00, 6cf00) PFNs busy
[20730.100467] alloc_contig_range: [6cf00, 6d000) PFNs busy
[20730.101182] alloc_contig_range: [6c200, 6c300) PFNs busy
[20730.101322] alloc_contig_range: [6c300, 6c400) PFNs busy
[20730.101442] alloc_contig_range: [6ce00, 6cf00) PFNs busy
[20730.101571] alloc_contig_range: [6cf00, 6d000) PFNs busy
[20730.222463] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.222477] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.285090] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.285103] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.345603] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.345615] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.406781] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.406793] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.467000] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.467012] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.531673] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.531683] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.593921] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.593934] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.657279] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.657291] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.731079] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.731090] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.793446] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.793457] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.859802] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.859814] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.926481] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.926493] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20730.988726] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20730.988738] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.051357] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.051369] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.113434] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.113446] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.177652] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.177664] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.240139] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.240152] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.302811] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.302823] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.365589] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.365600] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.428686] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.428698] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.490801] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.490813] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.552661] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.552674] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.615878] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.615947] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.683587] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.683601] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.748164] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.748177] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.812225] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.812238] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.874735] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.874747] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.936197] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.936209] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20731.999597] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20731.999609] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.063648] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.063660] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.126644] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.126656] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.190485] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.190495] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.253108] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.253120] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.321147] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.321159] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.388342] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.388355] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.450081] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.450092] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.512603] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.512616] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.576076] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.576089] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.637989] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.638001] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.701071] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.701082] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.766996] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.767008] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.830878] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.830889] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.892808] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.892821] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20732.954311] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20732.954323] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.024615] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.024627] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.122027] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.122075] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.224441] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.224453] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.298671] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.298682] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.363410] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.363423] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.427008] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.427020] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.491856] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.491869] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.559927] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.559939] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.622487] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.622499] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.686356] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.686367] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.754705] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.754716] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.819642] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.819653] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.884752] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.884764] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20733.947890] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20733.947901] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.010200] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.010213] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.072147] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.072159] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.135322] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.135334] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.204160] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.204172] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.267011] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.267023] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.337136] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.337148] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.400006] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.400018] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.469096] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.469108] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.532672] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.532683] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.594799] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.594811] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.658463] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.658475] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.724276] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.724288] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.788562] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.788574] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.852512] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.852525] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.916094] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.916106] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20734.980747] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20734.980759] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.049619] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.049631] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.102306] alloc_contig_range: 7462 callbacks suppressed
[20735.102312] alloc_contig_range: [73c00, 74c00) PFNs busy
[20735.102854] alloc_contig_range: [73d00, 74d00) PFNs busy
[20735.103391] alloc_contig_range: [73e00, 74e00) PFNs busy
[20735.103984] alloc_contig_range: [73f00, 74f00) PFNs busy
[20735.104540] alloc_contig_range: [74000, 75000) PFNs busy
[20735.105158] alloc_contig_range: [74100, 75100) PFNs busy
[20735.105769] alloc_contig_range: [74200, 75200) PFNs busy
[20735.110662] alloc_contig_range: [74300, 75300) PFNs busy
[20735.116422] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.116434] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.120026] alloc_contig_range: [6e300, 6f300) PFNs busy
[20735.120834] alloc_contig_range: [6e400, 6f400) PFNs busy
[20735.181022] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.181033] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.245401] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.245411] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.307502] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.307520] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.372087] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.372099] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.441144] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.441156] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.504057] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.504069] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.567664] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.567676] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.631339] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.631351] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.693208] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.693220] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.761147] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.761160] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.824463] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.824475] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.888390] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.888401] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20735.952735] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20735.952747] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.015925] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.015937] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.078087] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.078100] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.143191] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.143202] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.213571] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.213584] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.276796] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.276809] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.339004] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.339016] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.402567] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.402578] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.465756] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.465767] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.531150] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.531161] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.595235] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.595248] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.658294] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.658306] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.723338] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.723349] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.787910] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.787922] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.858352] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.858364] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.924339] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.924351] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20736.987709] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20736.987721] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.051079] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.051092] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.114260] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.114271] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.177929] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.177942] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.240844] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.240856] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.303774] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.303786] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.365349] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.365361] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.427327] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.427339] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.490727] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.490740] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.553846] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.553858] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.615000] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.615012] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.681313] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.681325] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.745771] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.745783] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.808954] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.808966] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.876137] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.876148] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20737.939754] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20737.939765] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20738.002930] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20738.002942] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20738.066087] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20738.066099] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20738.167496] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20738.167507] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20738.267945] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20738.267957] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
[20738.354070] meson-vdec c8820000.video-codec: Direct firmware load for meson/vdec/gxl_hevc.bin failed with error -2
[20738.354082] meson-vdec c8820000.video-codec: Unable to request firmware meson/vdec/gxl_hevc.bin
Maybe each time the terminal report "POLLERR", the dmesg gives "Unable to request firmware meson/vdec/gxl_hevc.bin"?
From what i know the "PFNs busy" errors are related to wrong cma allocations.
4 hours ago, xwfunny said:
Maybe you can download the missing file from here.
https://github.com/LibreELEC/meson-firmware/tree/master/meson
No, please just install armbian-firmware package. those firmwares are upstreamed to linux-firmware, which is built into armbian-firemware.
meson-vdev is stateful video decode, no related to libva-v4l2-request.
recent mpv requres add opengl-pbo to config file.
oh, ok sorry, i'm not expert, i was just thinking about. I would like a lot to get hardware decoding, so i'm trying all possible ways :P
Could you please give us a detailed tutorial on how to use HW decode?
I tried mpv with
vo=gpu
opengl-pbo
hwdec=auto
With Armbian_20.05.4_Arm-64_bullseye_current_5.7.0-rc5_desktop_20200514 but didn't have no luck video doesn't play. Can you please tell us, please, how to get hardware decoding?
On 1/25/2021 at 5:05 PM, lgranie said:
If you want those files you can install armbian-firmware-all package.
This is what I do here :
Thank you, I will try this when I was available.
