0
c.man
orange pi zero boot from msata
ok.
After to use armbian-config I must to install armbian o.s. to msata with Balena Etcher o similar software .... but so I will delete all....
Or I must first install armbian o.s. to msata  and after to use armbian-config....?
Share this post
Link to post
Share on other sites
32 minutes ago, c.man said:
Have you any guide or tutorial ?
for SPI-boot check these 2 threads in the forum (you need to adapt the "old" files ;) :
OrangePi Zero SPI / mtd0:
But I dont know if the msata on the NAS-expansion is connected via USB, because I only got the NAS-Expansion at my Orange Pi R1, but no msata-drive :(
[EDIT]  seems to be connected via USB:
https://www.cnx-software.com/2017/01/19/orange-pi-zero-nas-expansion-board-with-sata-usb-and-av-port-sells-for-10-shipped/
Storage – 1x SATA port, 1x mSATA port both through a JMS578 USB 3.1 to SATA bridge with UAS support each, which should be better than some other USB to SATA solution despite only being connected to a USB 2.0 interface.
Share this post
Link to post
0
