Single Armbian image for RK + AML + AW (armhf ARMv7)
On 7/2/2020 at 1:56 AM, Virverus said:
your bulseye rk3188 test image to my sd card this is the serial output:
Try replacing the parameters with the new ones for UART log
dd if=parametr-new.img of=/dev/SD_CARD seek=8192
https://yadi.sk/d/Jf8XW1DEybtKxA
Sorry @Virverus I see your AndroidTV stick and since I have a similar device I asked you if you did some tests with another device.
Anyway I tried my device with RK3066 and it didn't work. I know it was crazy, but I didn't lose much by trying.
Thanks.
uartparameternewrk3188.txt
Hi , no luck , result is the same , including the creation of two log files .
Something else , in my search for images ,answers and clues I stumbled on a small conversation you had in a Radxa forum .
They tried your image on a rockpro with the same result as I. You also mentioned you had difficulties accessing Radxa resources ,
So for sake of completeness : their first rk3188 models where simply called  "rock" and had the exact same hdmi chip as mine ,
the it66121fn and these images boot from sd om my stick , I downloaded yesterday thier latest Lubuntu image and it worked.
I'm connected to a fullhd hdmi monitor.
In 2014 they launched two more models "rock pro" and "rock lite" both of them use the rk618 for hdmi output , their images
do not work anymore on my stick , i tried their latest sd ubuntu_fullhd image , it only partly booted .
So they tested your image on a device with a different hdmi interface than mine .
May need to make changes to the kernel config . I hope to build a new version of the core next week (expand the list of USB modules for networks\audio, and so on). Yes, I have the image of Rock as well works with HDMI. By the way, I use u-boot from  old image.
The new version 20200716 5.7.8 with the kernel and u-boot-2020.07 for 3288. The kernel and u-boot sources shared with ARMv8 (aarch64) are used for the build.
Hello balbes150,
I've got a minix neo x7 (rk3188 with ubuintu 14.04 on sd card).
I am very interested by your work on armbian for rk 3188.
Tell me if I can help with something.
I tried your images (focal & bullseye) but no luck
Any way, thank you for working for our old hardware :D
can you show a photo of what components are used on this model ? Do you have a UART console ?
Sorry, no UART console but I can try to disassembly my minix neo x7 and send you a picture
Ok
New image 20200716-dev kernel 5.8-rc5 for rk3288
3 hours ago, moi_bis said:
minix neo x7 board
This model in the photo has a 66121 chip, so HDMI should work. What is in NAND ?
18 hours ago, moi_bis said:
I have android TV  "wasser 3.0.6 firmware "
to start the new kernel, I previously completely erased the internal NAND memory (I used the standard tools for USB from RK). But if you don't have the firmware to restore the system to its current state, I don't recommend erasing the internal memory.
I do not really want to erase the nand because erasing, flashing the firmware, flashing the update etc it may end with a brick. I already brick a "unbrickeable" device:  tronsmart cx-919:o. That's why I have the ubuntu 14.04 on sd card...
Now I am using my minix with Android TV on holidays with my kids for kids staff (cartoon, etc)
Erasing the nand is it mandatory before using new kernel?
I thought that the kernel was somewhere on the sd card when the device boots on the sd card, no?  There are devices without nand that boot only on sd card (some radxa rock boards I think)
That why I was interested by your work especially your sd card images for rk3188
PS Sorry for my dumm questions (I am quit a newbie:))
When you erase NAND, the regular u-boot in NAND is deleted. This makes the TV box always use fully all u-boot data only from the SD card. I don't know if you need to perform NAND (u-boot) Erasure to run a new kernel on your model or not. I know that for UT2 I had to do this, for full tests and checking new versions of u-boot (they only run if there is nothing in NAND).
add new image for rk3188 (20200719)
image "linaro", passwd and login   linaro\linaro
For all rk3188 owners, can you provide a link to any Linux image that you have start and running ? I want to see which version of u-boot and kernel is used there.
Hi , this version runs fine from sd :  https://drive.google.com/file/d/0B99O3A0dDe67UjVGRG14aGVoLVE/edit
The same results as previous , doesn't boot , I tried all versions from this repository.
I wiped nand memory with rkdevtool v2.71 om win10 boot still no boot ,
attached uart file for linux-rk3188-5.6.6-lubuntu uartlinux3188_5.6.6lubuntu.txt
By the way , it seems that ugoos ut1 firmware can run on my stick ( not tested by me )
for my "old" Raxda Rock with RK3188 is a debian 8 nand-image at
http://dl.radxa.com/rock/images/rabian/rock_rabian_rock_1c1e5f8_150506_58f2882_nand.img.xz
An overview of available images:
https://wiki.radxa.com/Rock/prebuilt_images
Specifications:
https://wiki.radxa.com/Rock/specifications
uname -a :
Linux radxa-rock 3.0.36+ #31 SMP PREEMPT Mon Oct 27 20:00:06 CST 2014 armv7l GNU/Linux
I correctly understood, this is the log when erased in NAND u-boot (i.e. this is the log of launching u-boot armbian  from the SD card)?
Need an image for the SD card. u-boot in NAND uses a different one, it is not suitable for starting from an SD card. It may be useful in the future, for installing Armbina in NAND.
Yes, I know about these images and use them in UT2 as "donors" for some tasks. :)
By the way, the latest images are compiled using part of the elements (kernel 3.0 and u-boot-old) that are build from their sources (this means i'm  can make changes to the build process).
@guidol  What exactly is your Rock model (they differ in the HDMI chip)?
they only I know for sdcard are
https://dl.radxa.com/rock/images/ubuntu/sd/radxa_rock_lubuntu_desktop_140626_sdcard.zip
https://dl.radxa.com/rock/images/ubuntu/sd/radxa_rock_ubuntu_14.04_server_140820_sdcard.zip
Maybe also interesting:
https://dl.radxa.com/rock/images/android/Boot_android_from_sdcard/radxa_rock_kitkat_sdcard_boot_update_0621.zip
And the directorys:
https://dl.radxa.com/rock/images/loader/
https://dl.radxa.com/rock/images/parameter/
https://dl.radxa.com/users/dev/3188/
Yes , I erased nand ( android was completely gone ,didn't boot anymore )and then I booted Armbian from sd and with this log as result
11 minutes ago, Virverus said:
booted from sd-card into desktop
Versions with the 3.0.36 core use the radxa rock core and DTB, and if you run a Lubuntu image, the armbian image should work (they use the same set of files and the core).
I will try it again.....
It is interesting to check out. Pull three components from the armbian image and replace the versions in the radxa image with them one by one.
Pulling out components
dd if=image_armbian of=u-boot.img skip=64 count=8128
dd if=image_armbian of=parametr.img skip=8192 count=2
dd if=image_armbian of=kernel.img skip=24576 count=32768
we change them one by one and check the launch (it is desirable to fix the UART log and attach it here)
dd if=u-boot.img of=SD_card_image_radxa  seek=64
dd if=parametr.img of=SD_card_image_radxa  seek=8192
dd if=kernel.img of=SD_card_image_radxa  seek=24576
I have an appointment an must leave now , probably tonight I can do this
does it make any difference wich Armbian image I use ?
