Skip to content
View in the app
Armbian Community Forums
Does debian buster need a login and password 4 initial boot?
Featured Replies
I started debian buster up and it started running through the black screen with non-graphics (doing this, doing that), then it got to ARMBIAN DEBIAN TTY1: login ... password.
Is there a default login and password for this?
If not, then there is something wrong with my download  though I checked to make sure it was debian for orangepiplus2e desktop, and it is. This iso worked in the past and i have it saved on my ext hdd.
UPDATE:
I checked the checksum that I created with the checksum document that downloaded with the .img, and they are the same.
I used "cp filename.img /dev/sdx" to copy the img to an microsd using a media card reader and it seemed to work fine.
But upon loading, the file gets stuck slightly after it says "FAILED: NO NETWORK..." " failed to start network manager wait online".
The "raw disk image" before copying to micro-sd is 2.3GB.
265be364d0a32e32251a90800a82837d578dbe48d19bf6968316422ca7f17214 *Armbian_5.93_Orangepiplus2e_Debian_buster_next_4.19.64_desktop.img
Thanks.
Edited by busterrr3x
solved
Latest images have root auto login where it asks for:
- changing root password
- asks if you want to make autodetected locales or provide selection if more then one exists
- asks for creating username (optional)
- password
- name (optional)
Something like this (not exactly this way):
86638322-5f8a6280-bfd7-11ea-83a3-272f131
Once you finish this, desktop will start - if you have a desktop images.
Default User/Password for a new flashed image on SDCard is
User: root
Initial Password: 1234
after that you have to enter a new root-password ;)
  • Author
User: root
Thank you Guidol - that's exactly right. Thanks Igor for your input.
- password
- name (optional)
Thanks I booted by Debian on Pine64 and it did Auto-login automatically However it does not ask for creation of password. But for root password and 1234 is not consider a default valid password. Is there a way to interrupt auto-login feature during boot so you can enter the command line prompt
Make sure to check https://docs.armbian.com/User-Guide_Getting-Started/ If you are using random Debian from internet, login could be different. If you are using official Armbian and you have such problems, your SD card could be failing https://forum.armbian.com/forum/31-sd-card-and-psu-issues/
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
