Hopefully I have posted appropriately, I am completely new to Armbian and orange PI so hopefully this fault is because of my lack of experience.
My problem I cannot get my orange pi to boot..  I have tried both supported Armbian Focal and Armbian Buster. They both appear to stop at the same place of boot (wondering if its actually a hardware fault?).  Hardware is a Orange Pi Zero H2 (H2 Printed on top of CPU yet CPU reports itself as H3 when booting)  the outputs captured via the serial port, the SD is a SANDisk A1 32GB card, the board is powered by a 2A USB wall supply and I also connected an ethernet cable directly to the router.  Below is the captured output from focal build (Armbian_20.11_Orangepizero_focal_current_5.8.16.img) , The first boot results in a kernel panic and the second one stalls at the t "Update UTMP about System Runlevel Changes"  I am note sure how to debug this as I have no opportunity to intervene etc, and not having an Orange PI that does boot, I have nothing to compare it too... Can anybody help? am I using the wrong build?- can anybody help? Have I bought a duff Orange? what am I doing wrong?
thanks all.
U-Boot SPL 2020.10-armbian (Nov 23 2020 - 18:53:11 +0100)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2020.10-armbian (Nov 23 2020 - 18:53:11 +0100) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Zero
DRAM:  512 MiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 1
Loading Environment from FAT... Unable to use mmc 0:1... In:    serial
Out:   serial
Err:   serial
Net:   phy interface0
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1b400: USB OHCI 1.0
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3967 bytes read in 4 ms (967.8 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
182 bytes read in 3 ms (58.6 KiB/s)
11503995 bytes read in 871 ms (12.6 MiB/s)
7793968 bytes read in 591 ms (12.6 MiB/s)
32515 bytes read in 11 ms (2.8 MiB/s)
504 bytes read in 7 ms (70.3 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
4185 bytes read in 7 ms (583 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 45000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    11503931 Bytes = 11 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
EHCI failed to shut down host controller.
   Loading Ramdisk to 49507000, end 49fff93b ... OK
   Loading Device Tree to 49496000, end 49506fff ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Loading, please wait...
Starting version 245.4-4ubuntu3.3
done.
Begin: Will now check root file system ... fsck from util-linux 2.34
[/usr/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: clean, 39833/69408 files, 243502/277504 blocks
done.
done.
Welcome to Armbian 20.11 Focal!
[  OK  ] Created slice system-modprobe.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[  OK  ] Set up automount Arbitrary…s File System Automount Point.
[  OK  ] Reached target Local Encrypted Volumes.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Reached target Slices.
[  OK  ] Reached target Swap.
[  OK  ] Reached target System Time Set.
[  OK  ] Listening on Syslog Socket.
[  OK  ] Listening on fsck to fsckd communication Socket.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Listening on udev Kernel Socket.
         Mounting POSIX Message Queue File System...
         Mounting Kernel Debug File System...
         Mounting Kernel Trace File System...
         Starting Restore / save the current clock...
         Starting Set the console keyboard layout...
         Starting Create list of st…odes for the current kernel...
[  OK  ] Started Nameserver information manager.
[  OK  ] Reached target Network (Pre).
         Starting Load Kernel Modules...
         Starting Remount Root and Kernel File Systems...
         Starting udev Coldplug all Devices...
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Trace File System.
[  OK  ] Finished Restore / save the current clock.
[  OK  ] Finished Create list of st… nodes for the current kernel.
[  OK  ] Finished Remount Root and Kernel File Systems.
[  OK  ] Finished Load Kernel Modules.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Load/Save Random Seed...
         Starting Apply Kernel Variables...
         Starting Create System Users...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Set the console keyboard layout.
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /tmp...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /tmp.
[  OK  ] Reached target Local File Systems.
         Starting Armbian ZRAM config...
         Starting Set console font and keymap...
         Starting Mark the need to relabel after reboot...
[  OK  ] Finished Set console font and keymap.
[  OK  ] Finished udev Coldplug all Devices.
[  OK  ] Finished Mark the need to relabel after reboot.
         Starting Helper to synchronize boot up for ifupdown...
[  OK  ] Finished Helper to synchronize boot up for ifupdown.
         Starting Raise network interfaces...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Found device /dev/ttyGS0.
[   10.982337] thermal thermal_zone0: binding zone cpu_thermal with cdev thermal                                                            -cpufreq-0 failed:-22
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Finished Raise network interfaces.
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Finished Armbian ZRAM config.
         Starting Armbian memory supported logging...
[  OK  ] Finished Armbian memory supported logging.
         Starting Journal Service...
[  OK  ] Started Journal Service.
         Starting Flush Journal to Persistent Storage...
[  OK  ] Finished Flush Journal to Persistent Storage.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Create Volatile Files and Directories.
[  OK  ] Started Entropy daemon using the HAVEGE algorithm.
         Starting Network Name Resolution...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Finished Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target System Initialization.
[  OK  ] Started resolvconf-pull-resolved.path.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Paths.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
         Starting Armbian hardware monitoring...
         Starting Armbian hardware optimization...
         Starting Armbian filesystem resize...
[  OK  ] Finished Armbian hardware monitoring.
[  OK  ] Finished Armbian hardware optimization.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Finished Armbian filesystem resize.
[  OK  ] Reached target Basic System.
[  OK  ] Started Armbian first run tasks.
[  OK  ] Started Regular background program processing daemon.
[  OK  ] Started D-Bus System Message Bus.
         Starting Network Manager...
[  OK  ] Started Save initial kernel messages after boot.
         Starting Remove Stale Onli…t4 Metadata Check Snapshots...
         Starting LSB: Load kernel …d to enable cpufreq scaling...
         Starting Dispatcher daemon for systemd-networkd...
         Starting resolvconf-pull-resolved.service...
         Starting System Logging Service...
         Starting Resets System Activity Data Collector...
         Starting Login Service...
         Starting WPA supplicant...
[  OK  ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
[  OK  ] Finished Resets System Activity Data Collector.
[  OK  ] Finished resolvconf-pull-resolved.service.
[  OK  ] Started WPA supplicant.
[  OK  ] Started System Logging Service.
[  OK  ] Started Login Service.
[  OK  ] Started LSB: Load kernel m…ded to enable cpufreq scaling.
         Starting LSB: set CPUFreq kernel parameters...
[  OK  ] Started LSB: set CPUFreq kernel parameters.
         Starting LSB: Set sysfs variables from /etc/sysfs.conf...
[  OK  ] Started LSB: Set sysfs variables from /etc/sysfs.conf.
[  OK  ] Started Network Manager.
[  OK  ] Reached target Network.
[  OK  ] Reached target Network is Online.
         Starting chrony, an NTP client/server...
         Starting LSB: Advanced IEEE 802.11 management daemon...
         Starting /etc/rc.local Compatibility...
         Starting OpenBSD Secure Shell server...
         Starting Permit User Sessions...
[  OK  ] Started Unattended Upgrades Shutdown.
[  OK  ] Started LSB: Advanced IEEE 802.11 management daemon.
[  OK  ] Started /etc/rc.local Compatibility.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Serial Getty on ttyGS0.
[  OK  ] Started Serial Getty on ttyS0.
         Starting Set console scheme...
         Starting Hostname Service...
[  OK  ] Started OpenBSD Secure Shell server.
[  OK  ] Started chrony, an NTP client/server.
[  OK  ] Finished Set console scheme.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Daily apt download activities.
[  OK  ] Started Daily apt upgrade and clean activities.
[  OK  ] Started Periodic ext4 Onli…ata Check for All Filesystems.
[  OK  ] Started Discard unused blocks once a week.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily man-db regeneration.
[  OK  ] Started Message of the Day.
[  OK  ] Reached target Timers.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Hostname Service.
[  OK  ] Started Dispatcher daemon for systemd-networkd.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Finished Update UTMP about System Runlevel Changes.
[   44.853428] 8<--- cut here ---
[   44.856532] Unable to handle kernel paging request at virtual address 347dec0                                                            1
[   44.863800] pgd = 4354a836
[   44.866505] [347dec01] *pgd=00000000
[   44.870144] Internal error: Oops: 5 [#1] SMP THUMB2
[   44.875019] Modules linked in: xradio_wlan mac80211 sun4i_gpadc_iio industria                                                            lio cfg80211 sun8i_thermal rfkill libarc4 sunxi_cedrus(C) sun8i_ce crypto_engine                                                             sun8i_di cpufreq_dt uio_pdrv_genirq uio zram sch_fq_codel usb_f_acm u_serial g_                                                            serial libcomposite ip_tables x_tables autofs4 pwrseq_simple sunxi phy_generic
[   44.902829] CPU: 1 PID: 1148 Comm: iozone Tainted: G         C        5.8.16-                                                            sunxi #20.08.14
[   44.911251] Hardware name: Allwinner sun8i Family
[   44.915964] PC is at kmem_cache_alloc+0x84/0x1e4
[   44.920576] LR is at 0xcc0
[   44.923279] pc : [<c0254a04>]    lr : [<00000cc0>]    psr: a0070033
[   44.929536] sp : d2ab3eb8  ip : 000131d1  fp : 347dec01
[   44.934753] r10: 00000142  r9 : c0f056c4  r8 : c0277a1b
[   44.939969] r7 : d70c5700  r6 : 00000cc0  r5 : d6804000  r4 : d70c5700
[   44.946487] r3 : 5dfdac01  r2 : eff2f8df  r1 : 1f0d7000  r0 : d2ab3eb8
[   44.953006] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA Thumb  Segment no                                                            ne
[   44.960304] Control: 50c5387d  Table: 5203806a  DAC: 00000051
[   44.966044] Process iozone (pid: 1148, stack limit = 0xbafee82d)
[   44.972043] Stack: (0xd2ab3eb8 to 0xd2ab4000)
[   44.976395] 3ea0:                                                       00000                                                            000 00000000
[   44.984563] 3ec0: d1710220 c026c4f9 c0bd4e68 00000000 006ca404 00000000 00000                                                            000 d2ab3f50
[   44.992731] 3ee0: c0f056c4 00000142 00596438 c0277a1b 00000000 00000000 00000                                                            000 00000000
[   45.000899] 3f00: d2ab3f50 ffffff9c 00000142 c0268083 d54f9f70 d2ab2000 00030                                                            000 ffff0000
[   45.009067] 3f20: 00000004 00000100 00000001 c0f04fc8 c0f04fcc d2ab3f60 d2ab3                                                            f78 00030000
[   45.017235] 3f40: 00000000 00000000 00000000 c026903f 00030000 00000000 00000                                                            000 00000000
[   45.025402] 3f60: 00000000 00000000 00030000 00000000 00000000 00000000 00000                                                            000 00000000
[   45.033571] 3f80: 00000006 c0f04fc8 d450ba80 00001000 b6fae5f0 00860a60 00000                                                            142 c0100284
[   45.041739] 3fa0: d2ab2000 c0100061 00001000 b6fae5f0 ffffff9c 006ca404 00030                                                            000 00000000
[   45.049907] 3fc0: 00001000 b6fae5f0 00860a60 00000142 be97f0b0 00597bf0 004dc                                                            9f8 00596438
[   45.058076] 3fe0: 00000142 be97ef70 b6f6fa5d b6f71416 20070030 ffffff9c 00000                                                            000 00000000
[   45.066263] [<c0254a04>] (kmem_cache_alloc) from [<c0277a1b>] (getname_flags+                                                            0x3b/0x130)
[   45.074354] [<c0277a1b>] (getname_flags) from [<c0268083>] (do_sys_openat2+0x                                                            13b/0x220)
[   45.082355] [<c0268083>] (do_sys_openat2) from [<c026903f>] (do_sys_open+0x6b                                                            /0x9c)
[   45.090008] [<c026903f>] (do_sys_open) from [<c0100061>] (ret_fast_syscall+0x                                                            1/0x62)
[   45.097738] Exception stack(0xd2ab3fa8 to 0xd2ab3ff0)
[   45.102785] 3fa0:                   00001000 b6fae5f0 ffffff9c 006ca404 00030                                                            000 00000000
[   45.110953] 3fc0: 00001000 b6fae5f0 00860a60 00000142 be97f0b0 00597bf0 004dc                                                            9f8 00596438
[   45.119119] 3fe0: 00000142 be97ef70 b6f6fa5d b6f71416
[   45.124169] Code: f8d4 20d0 eb05 0b03 (f855) a003
[   45.129017] ---[ end trace 3d01fddb7caaea25 ]---
[   45.129707] 8<--- cut here ---
[   45.136797] Unable to handle kernel paging request at virtual address 27df6c0                                                            1
[   45.136888] 8<--- cut here ---
[   45.144035] pgd = 77b9d853
[   45.144039] [27df6c01] *pgd=00000000
[   45.147104] Unable to handle kernel paging request at virtual address 84021ac                                                            6
[   45.147109] pgd = 88933591
[   45.149814] Internal error: Oops: 5 [#2] SMP THUMB2
[   45.153387] [84021ac6] *pgd=00000000
[   45.160580] Modules linked in: xradio_wlan mac80211 sun4i_gpadc_iio industria                                                            lio cfg80211 sun8i_thermal rfkill libarc4 sunxi_cedrus(C) sun8i_ce crypto_engine                                                             sun8i_di cpufreq_dt uio_pdrv_genirq uio zram sch_fq_codel usb_f_acm u_serial g_                                                            serial libcomposite ip_tables x_tables autofs4 pwrseq_simple sunxi phy_generic
[   45.199478] CPU: 0 PID: 1133 Comm: rs:main Q:Reg Tainted: G      D  C        5.8.16-sunxi #20.08.14
[   45.208506] Hardware name: Allwinner sun8i Family
[   45.213214] PC is at kmem_cache_alloc+0x84/0x1e4
[   45.217826] LR is at 0xcc0
[   45.220529] pc : [<c0254a04>]    lr : [<00000cc0>]    psr: a0010033
[   45.226785] sp : d2177ef8  ip : 000116fd  fp : 27df6c01
[   45.232000] r10: fffff000  r9 : c0f056c4  r8 : c0277a1b
[   45.237217] r7 : d70c5700  r6 : 00000cc0  r5 : c9e1c000  r4 : d70c5700
[   45.243735] r3 : 5dfdac01  r2 : eff2f8df  r1 : 1f0c3000  r0 : d2177ef8
[   45.250252] Flags: NzCv  IRQs on  FIQs on  Mode SVC_32  ISA Thumb  Segment no                                                            ne
[   45.257550] Control: 50c5387d  Table: 5200006a  DAC: 00000051
[   45.263287] Process rs:main Q:Reg (pid: 1133, stack limit = 0x237a0996)
[   45.269892] Stack: (0xd2177ef8 to 0xd2178000)
[   45.274243] 7ee0:                                                       00000                                                            000 c025457b
[   45.282411] 7f00: 04042000 00000cc0 ce6f2bf5 00000001 b6e088dc 00000001 00000                                                            000 00000000
[   45.290580] 7f20: c0f056c4 fffff000 00502f44 c0277a1b 00000001 ffffff9c d2177                                                            f74 b6e088dc
[   45.298748] 7f40: 00000000 d2176000 fffff000 c0278239 00000001 00000000 fffff                                                            f9c c0268697
[   45.306916] 7f60: 00000000 00000000 00000000 d28c7880 d206ef03 c026ba17 00009                                                            855 c0f04fc8
[   45.315084] 7f80: d2177fb0 b6e088dc b6e1dc00 00044d92 00000021 c0100284 d2176                                                            000 00000021
[   45.323252] 7fa0: 00502f44 c0100061 b6e088dc b6e1dc00 b6e088dc 00000000 00000                                                            000 7261762f
[   45.331421] 7fc0: b6e088dc b6e1dc00 00044d92 00000021 00073570 00ee3d18 b61fe                                                            6fc 00502f44
[   45.339589] 7fe0: 00000021 b61fe1fc b6db76df b6d3dbe6 60010030 b6e088dc 00000                                                            000 00000000
[   45.347768] [<c0254a04>] (kmem_cache_alloc) from [<c0277a1b>] (getname_flags+                                                            0x3b/0x130)
[   45.355853] [<c0277a1b>] (getname_flags) from [<c0278239>] (user_path_at_empt                                                            y+0x19/0x2c)
[   45.364026] [<c0278239>] (user_path_at_empty) from [<c0268697>] (do_faccessat                                                            +0x6f/0x1d8)
[   45.372188] [<c0268697>] (do_faccessat) from [<c0100061>] (ret_fast_syscall+0                                                            x1/0x62)
[   45.380005] Exception stack(0xd2177fa8 to 0xd2177ff0)
[   45.385052] 7fa0:                   b6e088dc b6e1dc00 b6e088dc 00000000 00000                                                            000 7261762f
[   45.393221] 7fc0: b6e088dc b6e1dc00 00044d92 00000021 00073570 00ee3d18 b61fe                                                            6fc 00502f44
[   45.401386] 7fe0: 00000021 b61fe1fc b6db76df b6d3dbe6
[   45.406434] Code: f8d4 20d0 eb05 0b03 (f855) a003
[   45.411222] Internal error: Oops: 5 [#3] SMP THUMB2
[   45.411284] ---[ end trace 3d01fddb7caaea26 ]---
[   45.416092] Modules linked in: xradio_wlan mac80211 sun4i_gpadc_iio industria                                                            lio cfg80211 sun8i_thermal rfkill libarc4 sunxi_cedrus(C) sun8i_ce crypto_engine                                                             sun8i_di cpufreq_dt uio_pdrv_genirq uio zram sch_fq_codel usb_f_acm u_serial g_                                                            serial libcomposite ip_tables x_tables autofs4 pwrseq_simple sunxi phy_generic
[   45.448465] CPU: 1 PID: 1148 Comm: iozone Tainted: G      D  C        5.8.16-                                                            sunxi #20.08.14
[   45.456888] Hardware name: Allwinner sun8i Family
[   45.461594] PC is at lock_page_memcg+0x1c/0x60
[   45.466034] LR is at page_remove_rmap+0x11/0x178
[   45.470644] pc : [<c0259124>]    lr : [<c023a7a9>]    psr: 40070133
[   45.476899] sp : d2ab3c18  ip : 00000000  fp : d2ab3d38
[   45.482115] r10: b6f89000  r9 : d2ab2000  r8 : 5775d59f
[   45.487332] r7 : 00000000  r6 : d7acc914  r5 : 00000000  r4 : 84021806
[   45.493848] r3 : 75ad3038  r2 : 00000000  r1 : 00000000  r0 : d7acc914
[   45.500365] Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA Thumb  Segment no                                                            ne
[   45.507662] Control: 50c5387d  Table: 5203806a  DAC: 00000051
[   45.513402] Process iozone (pid: 1148, stack limit = 0xbafee82d)
[   45.519400] Stack: (0xd2ab3c18 to 0xd2ab4000)
[   45.523752] 3c00:                                                       d7acc                                                            914 00000000
[   45.531920] 3c20: d2a0d628 c023a7a9 fffffffc d7acc914 b6f8a000 c023110d b6f9f                                                            000 d7a1e9d4
[   45.540088] 3c40: 00000000 d5fe2c00 c1031700 c0f08e04 d298ec00 d2a0d618 b6f86                                                            000 00000000
[   45.548257] 3c60: c100247c d203adc0 b6f9f000 b6f9efff c0e9663c c0212c4b c0f04                                                            fc8 d794c3f8
[   45.556424] 3c80: 00000006 dff6d008 d2ab3cbc c0212d8d c0fd71c0 00000006 dff6d                                                            008 c0212c4b
[   45.564592] 3ca0: c0a16aac 00000001 d794c3f8 d23c9e00 d794c3fc 00000000 00000                                                            001 d2ab3cbc
[   45.572760] 3cc0: d2ab3cbc c0f04fc8 00000000 fffffffc 00000000 00000000 00000                                                            000 c0f04fc8
[   45.580928] 3ce0: 00000000 d298ec00 ffffffff b6f86000 d2ab3d38 00000000 00000                                                            000 d54f9b00
[   45.589096] 3d00: ffffe000 c023157d 00000000 d54f9b00 ffffe000 d298e4e0 00000                                                            000 d5fe2c00
[   45.597264] 3d20: 00000000 ffffe000 d5fe2c40 c02368f1 1f0d7000 1f0d7000 d5fe2                                                            c00 00487000
[   45.605432] 3d40: ffffffff 00000009 00000005 cd09d000 cd0a2000 00000008 00000                                                            008 d79d2798
[   45.613600] 3d60: d79d2774 d79d2750 d79d272c d79d4dfc d79d4e20 d79d4e44 d79d4                                                            e68 c0f04fc8
[   45.621768] 3d80: d5fe2c00 d5fe2c00 ffffe000 c0118773 00000000 d54f9b00 d5fe2                                                            c00 c011fc71
[   45.629936] 3da0: 0000000b c10023e0 d2ab2000 c0f04fc8 bf000000 c0f0a894 ffffe                                                            000 c0109ce7
[   45.638104] 3dc0: d2ab2210 0000000b d5fe2c40 347dec01 d2ab3e68 00000005 d5fe2                                                            c00 d5fe2c00
[   45.646272] 3de0: d5fe2c40 00000000 00000234 c01108ed d54f9b00 c0110b27 00000                                                            000 c02ce581
[   45.654441] 3e00: d2ab2000 c04f7e4d d53bc988 00010000 00000000 c0151de5 d5631                                                            a80 00000005
[   45.662609] 3e20: c0f0b0d8 347dec01 d2ab3e68 c0f0b128 d2ab2000 00000142 347de                                                            c01 c0110c3d
[   45.670777] 3e40: 00001000 c0282a6f 00000010 c0a1e220 c0254a04 a0070033 fffff                                                            fff d2ab3e9c
[   45.678946] 3e60: c0277a1b c0100ad3 d2ab3eb8 1f0d7000 eff2f8df 5dfdac01 d70c5                                                            700 d6804000
[   45.687114] 3e80: 00000cc0 d70c5700 c0277a1b c0f056c4 00000142 347dec01 00013                                                            1d1 d2ab3eb8
[   45.695282] 3ea0: 00000cc0 c0254a04 a0070033 ffffffff 00000051 bf000000 00000                                                            000 00000000
[   45.703450] 3ec0: d1710220 c026c4f9 c0bd4e68 00000000 006ca404 00000000 00000                                                            000 d2ab3f50
[   45.711618] 3ee0: c0f056c4 00000142 00596438 c0277a1b 00000000 00000000 00000                                                            000 00000000
[   45.719786] 3f00: d2ab3f50 ffffff9c 00000142 c0268083 d54f9f70 d2ab2000 00030                                                            000 ffff0000
[   45.727954] 3f20: 00000004 00000100 00000001 c0f04fc8 c0f04fcc d2ab3f60 d2ab3                                                            f78 00030000
[   45.736122] 3f40: 00000000 00000000 00000000 c026903f 00030000 00000000 00000                                                            000 00000000
[   45.744289] 3f60: 00000000 00000000 00030000 00000000 00000000 00000000 00000                                                            000 00000000
[   45.752458] 3f80: 00000006 c0f04fc8 d450ba80 00001000 b6fae5f0 00860a60 00000                                                            142 c0100284
[   45.760626] 3fa0: d2ab2000 c0100061 00001000 b6fae5f0 ffffff9c 006ca404 00030                                                            000 00000000
[   45.768794] 3fc0: 00001000 b6fae5f0 00860a60 00000142 be97f0b0 00597bf0 004dc                                                            9f8 00596438
[   45.776962] 3fe0: 00000142 be97ef70 b6f6fa5d b6f71416 20070030 ffffff9c 00000                                                            000 00000000
[   45.785136] [<c0259124>] (lock_page_memcg) from [<c023a7a9>] (page_remove_rma                                                            p+0x11/0x178)
[   45.793395] [<c023a7a9>] (page_remove_rmap) from [<c023110d>] (unmap_page_ran                                                            ge+0x291/0x5f4)
[   45.801827] [<c023110d>] (unmap_page_range) from [<c023157d>] (unmap_vmas+0x2                                                            5/0x3c)
[   45.809564] [<c023157d>] (unmap_vmas) from [<c02368f1>] (exit_mmap+0x89/0x104                                                            )
[   45.816784] [<c02368f1>] (exit_mmap) from [<c0118773>] (mmput+0x43/0xd8)
[   45.823482] [<c0118773>] (mmput) from [<c011fc71>] (do_exit+0x2c5/0x870)
[   45.830179] [<c011fc71>] (do_exit) from [<c0109ce7>] (die+0x267/0x27c)
[   45.836704] [<c0109ce7>] (die) from [<c01108ed>] (__do_kernel_fault.part.0+0x                                                            69/0x74)
[   45.844527] [<c01108ed>] (__do_kernel_fault.part.0) from [<c0110b27>] (do_pag                                                            e_fault+0x22f/0x230)
[   45.853390] [<c0110b27>] (do_page_fault) from [<c0110c3d>] (do_DataAbort+0x35                                                            /0x9c)
[   45.861039] [<c0110c3d>] (do_DataAbort) from [<c0100ad3>] (__dabt_svc+0x53/0x                                                            80)
[   45.868422] Exception stack(0xd2ab3e68 to 0xd2ab3eb0)
[   45.873469] 3e60:                   d2ab3eb8 1f0d7000 eff2f8df 5dfdac01 d70c5                                                            700 d6804000
[   45.881638] 3e80: 00000cc0 d70c5700 c0277a1b c0f056c4 00000142 347dec01 00013                                                            1d1 d2ab3eb8
[   45.889803] 3ea0: 00000cc0 c0254a04 a0070033 ffffffff
[   45.894857] [<c0100ad3>] (__dabt_svc) from [<c0254a04>] (kmem_cache_alloc+0x8                                                            4/0x1e4)
[   45.902682] [<c0254a04>] (kmem_cache_alloc) from [<c0277a1b>] (getname_flags+                                                            0x3b/0x130)
[   45.910769] [<c0277a1b>] (getname_flags) from [<c0268083>] (do_sys_openat2+0x                                                            13b/0x220)
[   45.918768] [<c0268083>] (do_sys_openat2) from [<c026903f>] (do_sys_open+0x6b                                                            /0x9c)
[   45.926419] [<c026903f>] (do_sys_open) from [<c0100061>] (ret_fast_syscall+0x                                                            1/0x62)
[   45.934149] Exception stack(0xd2ab3fa8 to 0xd2ab3ff0)
[   45.939196] 3fa0:                   00001000 b6fae5f0 ffffff9c 006ca404 00030                                                            000 00000000
[   45.947364] 3fc0: 00001000 b6fae5f0 00860a60 00000142 be97f0b0 00597bf0 004dc                                                            9f8 00596438
[   45.955530] 3fe0: 00000142 be97ef70 b6f6fa5d b6f71416
[   45.960577] Code: f3af 8000 6a34 b194 (f8d4) 32c0
[   45.965463] ---[ end trace 3d01fddb7caaea27 ]---
[   45.970097] Fixing recursive fault but reboot is needed!
[   54.187662] 8<--- cut here ---
[   54.190724] Unable to handle kernel paging request at virtual address f7defeb                                                            b
[   54.197939] pgd = 79774b7a
[   54.200641] [f7defebb] *pgd=00000000
[   54.204218] Internal error: Oops: 5 [#4] SMP THUMB2
[   54.209088] Modules linked in: xradio_wlan mac80211 sun4i_gpadc_iio industria                                                            lio cfg80211 sun8i_thermal rfkill libarc4 sunxi_cedrus(C) sun8i_ce crypto_engine                                                             sun8i_di cpufreq_dt uio_pdrv_genirq uio zram sch_fq_codel usb_f_acm u_serial g_                                                            serial libcomposite ip_tables x_tables autofs4 pwrseq_simple sunxi phy_generic
[   54.236892] CPU: 1 PID: 1189 Comm: sleep Tainted: G      D  C        5.8.16-s                                                            unxi #20.08.14
[   54.245227] Hardware name: Allwinner sun8i Family
[   54.249931] PC is at page_remove_rmap+0x128/0x178
[   54.254629] LR is at page_remove_rmap+0x11/0x178
[   54.259238] pc : [<c023a8c0>]    lr : [<c023a7a9>]    psr: 400f0033
[   54.265494] sp : d2a59df0  ip : cd0af000  fp : d2a59f00
[   54.270710] r10: b6e5a000  r9 : d2a58000  r8 : 576d759f
[   54.275927] r7 : 00000000  r6 : d29c816c  r5 : 00000000  r4 : d7acb63c
[   54.282444] r3 : c0fd71c0  r2 : c7025800  r1 : 00000000  r0 : f7defe7f
[   54.288963] Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA Thumb  Segment no                                                            ne
[   54.296260] Control: 50c5387d  Table: 5296c06a  DAC: 00000051
[   54.301997] Process sleep (pid: 1189, stack limit = 0x9990dc95)
[   54.307907] Stack: (0xd2a59df0 to 0xd2a5a000)
[   54.312260] 9de0:                                     ffffffd6 d7acb63c b6e5b                                                            000 c023110d
[   54.320428] 9e00: b6f19000 d7a1e020 00000000 cdc2ce00 c1031700 c0f08e04 cdc28                                                            240 d29c80c0
[   54.328596] 9e20: b6e30000 00000000 c100247c d296edc0 b6f19000 b6f18fff d2a59                                                            e50 00000000
[   54.336764] 9e40: d71964a0 c015148d 00000000 d2a59e50 00000000 00000000 00000                                                            000 d2a59e5c
[   54.344932] 9e60: d2a59e5c c0f04fc8 00000000 cdc74c00 d7196464 00000001 d7196                                                            4a0 d2a59ea4
[   54.353100] 9e80: 00000003 c07fede1 00000000 c028e7f9 d7196400 ffffffd6 00000                                                            000 00000000
[   54.361268] 9ea0: 00000000 c0f04fc8 d1776c88 cdc28240 ffffffff b6e30000 d2a59                                                            f00 00000000
[   54.369436] 9ec0: 00000000 000000f8 b6f2a000 c023157d 00000000 c0564e7f fffff                                                            fff cdc28d20
[   54.377604] 9ee0: 00000000 cdc2ce00 00000000 ffffe000 cdc2ce40 c02368f1 fffff                                                            fff c010933b
[   54.385772] 9f00: cdc2ce00 004f3000 ffffffff c0f04f89 00000001 cd0ae000 cd0ae                                                            000 00000008
[   54.393940] 9f20: 00000008 d79e5248 d7a049b8 d79e5098 d7a31b20 d79e4ccc d7998                                                            190 d799b9d0
[   54.402108] 9f40: d7993438 c0f04fc8 cdc2ce00 cdc2ce00 ffffe000 c0118773 00000                                                            000 d2a91440
[   54.410277] 9f60: cdc2ce00 c011fc71 b6e7b64c c0f04fc8 c0f0b2d8 c0f04fc8 00000                                                            000 000000f8
[   54.418445] 9f80: b6f2a000 c0120277 97080500 b6f2b438 b6f2b438 00000000 00000                                                            0f8 c01202df
[   54.426613] 9fa0: 97080500 c0100061 b6f2b438 b6f2b438 00000000 00000000 00000                                                            000 97080500
[   54.434781] 9fc0: b6f2b438 b6f2b438 00000000 000000f8 00000002 00000000 b6f2d                                                            628 b6f2a000
[   54.442948] 9fe0: 000000f8 bec1dc9c b6eaad19 b6e4abe6 600f0030 00000000 00000                                                            000 00000000
[   54.451126] [<c023a8c0>] (page_remove_rmap) from [<c023110d>] (unmap_page_ran                                                            ge+0x291/0x5f4)
[   54.459557] [<c023110d>] (unmap_page_range) from [<c023157d>] (unmap_vmas+0x2                                                            5/0x3c)
[   54.467295] [<c023157d>] (unmap_vmas) from [<c02368f1>] (exit_mmap+0x89/0x104                                                            )
[   54.474514] [<c02368f1>] (exit_mmap) from [<c0118773>] (mmput+0x43/0xd8)
[   54.481212] [<c0118773>] (mmput) from [<c011fc71>] (do_exit+0x2c5/0x870)
[   54.487906] [<c011fc71>] (do_exit) from [<c0120277>] (do_group_exit+0x2f/0x84                                                            )
[   54.495122] [<c0120277>] (do_group_exit) from [<c01202df>] (sys_exit_group+0x                                                            13/0x14)
[   54.502945] [<c01202df>] (sys_exit_group) from [<c0100061>] (ret_fast_syscall                                                            +0x1/0x62)
[   54.510935] Exception stack(0xd2a59fa8 to 0xd2a59ff0)
[   54.515982] 9fa0:                   b6f2b438 b6f2b438 00000000 00000000 00000                                                            000 97080500
[   54.524150] 9fc0: b6f2b438 b6f2b438 00000000 000000f8 00000002 00000000 b6f2d                                                            628 b6f2a000
[   54.532315] 9fe0: 000000f8 bec1dc9c b6eaad19 b6e4abe6
[   54.537364] Code: eb02 0281 f8d2 05cc (6bc2) 210f
[   54.542149] ---[ end trace 3d01fddb7caaea28 ]---
[   54.546758] Fixing recursive fault but reboot is needed!
DRAM: 512 MiB
DRAM:  512 MiB
Out:   serial
Err:   serial
Net:   phy interface0
starting USB...
Scanning mmc 0:1...
231 bytes read in 2 ms (112.3 KiB/s)
11503995 bytes read in 876 ms (12.5 MiB/s)
7793968 bytes read in 594 ms (12.5 MiB/s)
32515 bytes read in 10 ms (3.1 MiB/s)
504 bytes read in 6 ms (82 KiB/s)
   Image Name:   uInitrd
Starting kernel ...
done.
/dev/mmcblk0p1: recovering journal
/dev/mmcblk0p1: clean, 39867/1820032 files, 354066/7712800 blocks
done.
done.
         Mounting /tmp...
[   10.793027] thermal thermal_zone0: binding zone cpu_thermal with cdev thermal                                                            -cpufreq-0 failed:-22
         Starting Network Manager Script Dispatcher Service...
[  OK  ] Started Network Manager Script Dispatcher Service.
Edited by TRS-80
put long output inside code block inside spoiler
I don't think you did anything wrong.  The following seems to me like something went wrong:
However you will need to wait for someone more knowledgeable to reply in further detail.
In the meantime, I am moving this to the correct forum.
Interesting. Last test with
20.11.0-trunk.29 (focal)
Linux 5.9.7-sunxi nightly
Was successful. Needs verification.
In the meantime, if you want to help us testing, feel free to try and give feedback on these:
https://werner.armbian.de/Nov25/Armbian_20.11.0-trunk_Orangepizero_buster_dev_5.10.0-rc5.img.xz
https://werner.armbian.de/Nov25/Armbian_20.11.0-trunk_Orangepizero_buster_current_5.9.11.img.xz
Never mind. They dont boot either but without error....
Oh well....confirmed
Something is definitely unstable. I managed to get to the login before it crashed....
orangepizero login: root (automatic login)
  ___  ____  _   _____
 / _ \|  _ \(_) |__  /___ _ __ ___
| | | | |_) | |   / // _ \ '__/ _ \
| |_| |  __/| |  / /|  __/ | | (_) |
 \___/|_|   |_| /____\___|_|  \___/
Welcome to Armbian 20.11 Focal with Linux 5.8.16-sunxi
System load:   37%              Up time:       0 min
Memory usage:  19% of 491M      IP:
CPU temp:      36°C             Usage of /:    7% of 15G
[ General system configuration (beta): armbian-config ]
Last login: Wed Nov 25 12:06:35 UTC 2020 on ttyGS0
New to Armbian? Documentation: https://docs.armbian.com Support: https://forum.armbian.com
New root password: *********
Repeat password: *********
Creating a new user account. Press <Ctrl-C> to abort
Please provide a username (eg. your forename): [   71.272263] 8<--- cut here ---
[   71.275359] Unable to handle kernel paging request at virtual address 48c99f70
[   71.282617] pgd = aba9305c
[   71.285332] [48c99f70] *pgd=00000000
[   71.288922] Internal error: Oops: 5 [#1] SMP THUMB2
[   71.293794] Modules linked in: xradio_wlan mac80211 cfg80211 sun4i_gpadc_iio industrialio sun8i_thermal rfkill libarc4 sun8i_ce crypto_engine sunxi_cedrus(C) sun8i_di uio_pdrv_genirq uio cpufreq_dt zram sch_fq_codel usb_f_acm u_serial g_serial libcomposite ip_tables x_tables autofs4 pwrseq_simple sunxi phy_generic
[   71.321609] CPU: 2 PID: 2042 Comm: systemd-cryptse Tainted: G         C        5.8.16-sunxi #20.08.14
[   71.330813] Hardware name: Allwinner sun8i Family
[   71.335523] PC is at do_page_fault+0x116/0x230
[   71.339962] LR is at do_page_fault+0x109/0x230
[   71.344399] pc : [<c0110a0e>]    lr : [<c0110a01>]    psr: 00040133
[   71.350655] sp : ccd99f40  ip : ffffe000  fp : 00000274
[   71.355871] r10: 00000000  r9 : d2a74c40  r8 : d2a74c00
[   71.361087] r7 : d2a65100  r6 : 00000005  r5 : a6f42399  r4 : 48c99f30
[   71.367605] r3 : 00030873  r2 : 00010000  r1 : 00000000  r0 : d2a74c40
[   71.374123] Flags: nzcv  IRQs on  FIQs on  Mode SVC_32  ISA Thumb  Segment none
[   71.381421] Control: 50c5387d  Table: 4ce5006a  DAC: 00000051
[   71.387159] Process systemd-cryptse (pid: 2042, stack limit = 0x0dee6926)
[   71.393937] Stack: (0xccd99f40 to 0xccd9a000)
[   71.398293] 9f40: 00000000 00000001 00000000 00000000 cce9cc00 00010000 00000000 b68c1000
[   71.406461] 9f60: 00000005 00000005 c0f0b0d8 a6f4a3d9 4cd99fb0 c0f0b128 00000022 b6f4c8f8
[   71.414629] 9f80: 00000000 c010043d 00000000 00000000 0000007d c0100284 b2f2a364 60040030
[   71.422797] 9fa0: ffffffff 50c5387d 50c5387d c0100ecf 00000000 00000001 00000000 00000000
[   71.430965] 9fc0: a6f4a240 00000001 b6f3e43c 00000001 00000005 00000022 b6f4c8f8 00000000
[   71.439133] 9fe0: 039b9287 bee27878 00000000 b2f2a364 60040030 ffffffff 00000000 00000000
[   71.447316] [<c0110a0e>] (do_page_fault) from [<c010043d>] (sys_call_table+0x1b9/0x6e0)
[   71.455306] Exception stack(0xccd99f88 to 0xccd99fd0)
[   71.460353] 9f80:                   00000000 00000000 0000007d c0100284 b2f2a364 60040030
[   71.468521] 9fa0: ffffffff 50c5387d 50c5387d c0100ecf 00000000 00000001 00000000 00000000
[   71.476686] 9fc0: a6f4a240 00000001 b6f3e43c 00000001
[   71.481736] Code: 0303 9a05 421a d023 (6c23) 0718
[   71.486538] ---[ end trace a3a6750bdf0712ad ]---
[   71.491500] 8<--- cut here ---
[   71.494553] Unable to handle kernel NULL pointer dereference at virtual address 00000205
[   71.502630] pgd = a45ca92c
[   71.505332] [00000205] *pgd=00000000
[   71.508905] Internal error: Oops: 5 [#2] SMP THUMB2
[   71.513773] Modules linked in: xradio_wlan mac80211 cfg80211 sun4i_gpadc_iio industrialio sun8i_thermal rfkill libarc4 sun8i_ce crypto_engine sunxi_cedrus(C) sun8i_di uio_pdrv_genirq uio cpufreq_dt zram sch_fq_codel usb_f_acm u_serial g_serial libcomposite ip_tables x_tables autofs4 pwrseq_simple sunxi phy_generic
[   71.541568] CPU: 2 PID: 1098 Comm: in:imklog Tainted: G      D  C        5.8.16-sunxi #20.08.14
[   71.550250] Hardware name: Allwinner sun8i Family
[   71.554951] PC is at regs_get_kernel_stack_nth+0x18/0x24
[   71.560255] LR is at 0xb6f96416
[   71.563391] pc : [<c010818c>]    lr : [<b6f96416>]    psr: 000100b3
[   71.569647] sp : d2cddff8  ip : 000000f0  fp : 01b5ad60
[   71.574863] r10: 01b5ad68  r9 : 01b5ad88  r8 : 00000000
[   71.580079] r7 : 000000f0  r6 : 01b5ad80  r5 : 00000000  r4 : 01b5ad60
[   71.586596] r3 : 00000000  r2 : 00000001  r1 : 00000081  r0 : 01b5ad88
[   71.593114] Flags: nzcv  IRQs off  FIQs on  Mode SVC_32  ISA Thumb  Segment user
[   71.600498] Control: 50c5387d  Table: 52ba806a  DAC: 00000055
[   71.606235] Process in:imklog (pid: 1098, stack limit = 0xff5bd55e)
[   71.612491] Stack: (0xd2cddff8 to 0xd2cde000)
[   71.616842] dfe0:                                                       00000000 00000000
[   71.625012] [<c010818c>] (regs_get_kernel_stack_nth) from [<b6f96416>] (0xb6f96416)
[   71.632660] Code: 53ff f023 031f b913 (f852) 0021
[   71.637444] ---[ end trace a3a6750bdf0712ae ]---
[   71.642805] 8<--- cut here ---
[   71.645887] Unable to handle kernel paging request at virtual address 96a8682c
[   71.653111] pgd = e8331cf8
[   71.655823] [96a8682c] *pgd=00000000
[   71.659405] Internal error: Oops: 5 [#3] SMP THUMB2
[   71.664274] Modules linked in: xradio_wlan mac80211 cfg80211 sun4i_gpadc_iio industrialio sun8i_thermal rfkill libarc4 sun8i_ce crypto_engine sunxi_cedrus(C) sun8i_di uio_pdrv_genirq uio cpufreq_dt zram sch_fq_codel usb_f_acm u_serial g_serial libcomposite ip_tables x_tables autofs4 pwrseq_simple sunxi phy_generic
[   71.692069] CPU: 2 PID: 2042 Comm: systemd-cryptse Tainted: G      D  C        5.8.16-sunxi #20.08.14
[   71.701270] Hardware name: Allwinner sun8i Family
[   71.705979] PC is at anon_vma_interval_tree_remove+0x116/0x1d0
[   71.711805] LR is at anon_vma_interval_tree_remove+0x193/0x1d0
[   71.717628] pc : [<c022be9e>]    lr : [<c022bf1b>]    psr: 20010133
[   71.723884] sp : ccd99d38  ip : 0000237c  fp : cce9cc00
[   71.729100] r10: c1031720  r9 : cce9cc3c  r8 : 00000000
[   71.734316] r7 : 96a86820  r6 : 00000000  r5 : d2a279e0  r4 : cce5e958
[   71.740834] r3 : ccf96010  r2 : 646d6573  r1 : 00000000  r0 : 00000000
[   71.747352] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA Thumb  Segment none
[   71.754650] Control: 50c5387d  Table: 52ba806a  DAC: 00000051
[   71.760387] Process systemd-cryptse (pid: 2042, stack limit = 0x0dee6926)
[   71.767163] Stack: (0xccd99d38 to 0xccd9a000)
[   71.771515] 9d20:                                                       cce9cc34 ccf96860
[   71.779683] 9d40: cce5e930 00000000 00000000 cce9cc3c c1031720 c023ae57 d6fe87b0 cce5e930
[   71.787851] 9d60: c0fdba98 c0bd0c7c d2a65100 cce9cc00 cce0f1e0 cce9cc00 b63c4000 ccd99dc0
[   71.796019] 9d80: 00002000 00000000 ffffe000 c0230215 b6200000 d2a65100 cd292cc0 00000000
[   71.804188] 9da0: d2a74c00 00000000 ffffe000 d2a74c40 d2a65100 c02368ff 1f0eb000 1f0eb000
[   71.812356] 9dc0: d2a74c00 00400000 ffffffff c100563d 00000001 cd155000 cd155000 00000008
[   71.820524] 9de0: 00000008 d7bf7dc8 d7bf7dec d7bf7e10 d7bf7e34 d79c7fd4 d79c5fe8 d7781710
[   71.828692] 9e00: d7781734 c0f04fc8 d2a74c00 d2a74c00 ffffe000 c0118773 00000000 d2a65100
[   71.836860] 9e20: d2a74c00 c011fc71 0000000b c10023e0 ccd98000 c0f04fc8 bf000000 c0f0a894
[   71.845028] 9e40: ffffe000 c0109ce7 ccd98210 0000000b d2a74c40 48c99f70 ccd99ef0 00000005
[   71.853196] 9e60: d2a74c00 d2a74c00 d2a74c40 00000000 00000234 c01108ed d2a65100 c0110b27
[   71.861364] 9e80: 00000000 00000000 00000001 d7036400 e0803000 00010000 00000000 00000000
[   71.869533] 9ea0: 00000000 00000005 c0f0b0d8 48c99f70 ccd99ef0 c0f0b128 ccd98000 00000000
[   71.877701] 9ec0: 00000274 c0110c3d a0040133 ffffffff ccd99f14 d2a74c00 c0110a0e 00040133
[   71.885869] 9ee0: ffffffff ccd99f24 d2a74c00 c0100ad3 d2a74c40 00000000 00010000 00030873
[   71.894038] 9f00: 48c99f30 a6f42399 00000005 d2a65100 d2a74c00 d2a74c40 00000000 00000274
[   71.902206] 9f20: ffffe000 ccd99f40 c0110a01 c0110a0e 00040133 ffffffff 00000051 bf000000
[   71.910374] 9f40: 00000000 00000001 00000000 00000000 cce9cc00 00010000 00000000 b68c1000
[   71.918542] 9f60: 00000005 00000005 c0f0b0d8 a6f4a3d9 4cd99fb0 c0f0b128 00000022 b6f4c8f8
[   71.926710] 9f80: 00000000 c010043d 00000000 00000000 0000007d c0100284 b2f2a364 60040030
[   71.934878] 9fa0: ffffffff 50c5387d 50c5387d c0100ecf 00000000 00000001 00000000 00000000
[   71.943046] 9fc0: a6f4a240 00000001 b6f3e43c 00000001 00000005 00000022 b6f4c8f8 00000000
[   71.951214] 9fe0: 039b9287 bee27878 00000000 b2f2a364 60040030 ffffffff 00000000 00000000
[   71.959392] [<c022be9e>] (anon_vma_interval_tree_remove) from [<c023ae57>] (unlink_anon_vmas+0x9b/0x170)
[   71.968864] [<c023ae57>] (unlink_anon_vmas) from [<c0230215>] (free_pgtables+0x31/0x70)
[   71.976863] [<c0230215>] (free_pgtables) from [<c02368ff>] (exit_mmap+0x97/0x104)
[   71.984343] [<c02368ff>] (exit_mmap) from [<c0118773>] (mmput+0x43/0xd8)
[   71.991040] [<c0118773>] (mmput) from [<c011fc71>] (do_exit+0x2c5/0x870)
[   71.997739] [<c011fc71>] (do_exit) from [<c0109ce7>] (die+0x267/0x27c)
[   72.004262] [<c0109ce7>] (die) from [<c01108ed>] (__do_kernel_fault.part.0+0x69/0x74)
[   72.012085] [<c01108ed>] (__do_kernel_fault.part.0) from [<c0110b27>] (do_page_fault+0x22f/0x230)
[   72.020947] [<c0110b27>] (do_page_fault) from [<c0110c3d>] (do_DataAbort+0x35/0x9c)
[   72.028596] [<c0110c3d>] (do_DataAbort) from [<c0100ad3>] (__dabt_svc+0x53/0x80)
[   72.035979] Exception stack(0xccd99ef0 to 0xccd99f38)
[   72.041025] 9ee0:                                     d2a74c40 00000000 00010000 00030873
[   72.049193] 9f00: 48c99f30 a6f42399 00000005 d2a65100 d2a74c00 d2a74c40 00000000 00000274
[   72.057360] 9f20: ffffe000 ccd99f40 c0110a01 c0110a0e 00040133 ffffffff
[   72.063969] [<c0100ad3>] (__dabt_svc) from [<c0110a0e>] (do_page_fault+0x116/0x230)
[   72.071618] [<c0110a0e>] (do_page_fault) from [<c010043d>] (sys_call_table+0x1b9/0x6e0)
[   72.079608] Exception stack(0xccd99f88 to 0xccd99fd0)
[   72.084655] 9f80:                   00000000 00000000 0000007d c0100284 b2f2a364 60040030
[   72.092823] 9fa0: ffffffff 50c5387d 50c5387d c0100ecf 00000000 00000001 00000000 00000000
[   72.100988] 9fc0: a6f4a240 00000001 b6f3e43c 00000001
[   72.106035] Code: 3a01 eb02 3211 b11f (68f9) 428a
[   72.110837] ---[ end trace a3a6750bdf0712af ]---
[   72.115455] Fixing recursive fault but reboot is needed!
[   72.266793] 8<--- cut here ---
[   72.269847] Unable to handle kernel paging request at virtual address 052efb18
[   72.277058] pgd = ef9fddd2
[   72.279760] [052efb18] *pgd=00000000
[   72.283333] Internal error: Oops: 5 [#4] SMP THUMB2
[   72.288201] Modules linked in: xradio_wlan mac80211 cfg80211 sun4i_gpadc_iio industrialio sun8i_thermal rfkill libarc4 sun8i_ce crypto_engine sunxi_cedrus(C) sun8i_di uio_pdrv_genirq uio cpufreq_dt zram sch_fq_codel usb_f_acm u_serial g_serial libcomposite ip_tables x_tables autofs4 pwrseq_simple sunxi phy_generic
[   72.315995] CPU: 2 PID: 1081 Comm: wpa_supplicant Tainted: G      D  C        5.8.16-sunxi #20.08.14
[   72.325110] Hardware name: Allwinner sun8i Family
[   72.329809] PC is at regs_get_kernel_stack_nth+0x18/0x24
[   72.335113] LR is at 0xb6b33be6
[   72.338249] pc : [<c010818c>]    lr : [<b6b33be6>]    psr: 000100b3
[   72.344504] sp : d6a5fff8  ip : 0000008e  fp : 005f1c00
[   72.349720] r10: 005f1c00  r9 : 005f1bc8  r8 : 01096550
[   72.354937] r7 : 0000008e  r6 : 00000000  r5 : b6fabf50  r4 : bef7ebcc
[   72.361453] r3 : 00000000  r2 : 010965d8  r1 : 01096550  r0 : 00000010
[   72.367971] Flags: nzcv  IRQs off  FIQs on  Mode SVC_32  ISA Thumb  Segment user
[   72.375355] Control: 50c5387d  Table: 52bcc06a  DAC: 00000055
[   72.381091] Process wpa_supplicant (pid: 1081, stack limit = 0xfbee14a5)
[   72.387780] Stack: (0xd6a5fff8 to 0xd6a60000)
[   72.392131] ffe0:                                                       00000000 00000000
[   72.400301] [<c010818c>] (regs_get_kernel_stack_nth) from [<b6b33be6>] (0xb6b33be6)
[   72.407950] Code: 53ff f023 031f b913 (f852) 0021
[   72.412734] ---[ end trace a3a6750bdf0712b0 ]---
https://werner.armbian.de/Nov01/Armbian_20.11.0-trunk_Orangepizero_buster_current_5.8.17.img.xz
This one boots at least. But you cannot ssh into it. For some reason the generated keys are invalid and need to be replaced via ssh-keygen -A
...and hangs up after a while...c'mon..:unsure:
https://werner.armbian.de/_extra/Armbian_20.11.0-trunk_Orangepizero_buster_legacy_5.4.78.img.xz
Let's try legacy. I dont think there were significant improvements incomparison to modern kernels anyway for this SoC.
Also does not boot.
I slowly start to believe by OPi zero is broken....
  • Werner changed the title to 20.11 - Orange Pi Zero not booting
Perhaps we only need to blacklist xradio? Once and for good.
I just tested Orangepi R1 ... and it works perfectly.
27 minutes ago, Igor said:
Oranepi Lite 2 doesn't boots properly.
But boots well if build from trunk (5.9.11 kernel) ... :)  Damn.
35 minutes ago, lanefu said:
All the 20.11 allwinner images are on kernel 5.8 right?
Right. Kernel was not upgraded. Right now I have tested Orange R1 (which had issues) with trunk and it works fine. http://ix.io/2Fxl
So we have two ways here - focus on 5.9.y and fix things, figure out why 5.8.y suddenly doesn't work ... perhaps u-boot?
Can we hack Opi3 network with 5.9.y to make it work. Anything else that is critical on sunxi? It seems it have effect on H3 and H6. Haven't got chance to test others yet.
19 minutes ago, Werner said:
Business as usual I guess. The major issues always pop up after release :lol:
We need a reason to make patch releases :)
I formatted my SD Card and even tried flashing all 4 favors of Armbian 20.11 (Bionic, Bullseye, Buster, Focal) with Etcher. After SSH into my Orange Pi Zero, I changed the password and got stuck at "Generating locales:". I left it running all night but still no progress.
Detected timezone: Asia/Saigon (+07, +0700)
Generating locales:
Edited by ngpnam261
All flavours have identical hardware interface - if one doesn't work, others will also fail.
Did you try the image from my previous post?
20 hours ago, Igor said:
This image does boot for me and I can use it after generating locales.
This does also work for the newer image
Armbian_21.02.0-trunk_Orangepizero_buster_current_5.8.16
and
Armbian_21.02.0-trunk_Orangepizero_buster_current_5.9.11
@Igor BTW: Is there a chance to change the following behavior?
(why is armbian - like many webpages on the world- thinking I want a TR locales only because Iam in turkey? )
-  I want to select a de_DE.UTF-8 or a en_US.UTF-8 :(
- I want a german keyboard
- and why we cant change the locale keyboard in armbian-config via a ssh-sesssion?
Detected timezone: Europe/Istanbul (+03, +0300)
At your location, more locales are possible:
1) ku_TR.UTF-8
2) tr_TR.UTF-8
Please enter your choice:2
Generating locales: tr_TR.UTF-8
Adding console keyboard layout: tr
Hi, So bear in mind I am new to OrangePi and its boot process, but using the build above the boot process hangs at the line "[ OK ] Found device /dev/ttyGS0 ". (full boot log below) I am using the same set up as I stated at the beginning of this thread. I have Ordered another SD card (same spec) and another orange PI just in case I have a fault somewhere else.  Is there a build that we know should absolutely work that I could use, to remove the possibility that it is the board or card etc?
Thanks for looking.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.11.27 12:07:53 =~=~=~=~=~=~=~=~=~=~=~=
DRAM: 512 MiB
DRAM:  512 MiB
Out:   serial
Err:   serial
Net:   phy interface0
starting USB...
Scanning mmc 0:1...
182 bytes read in 2 ms (88.9 KiB/s)
11504113 bytes read in 860 ms (12.8 MiB/s)
7793968 bytes read in 584 ms (12.7 MiB/s)
32515 bytes read in 9 ms (3.4 MiB/s)
4185 bytes read in 6 ms (680.7 KiB/s)
   Image Name:   uInitrd
   Data Size:    11504049 Bytes = 11 MiB
   Loading Ramdisk to 49507000, end 49fff9b1 ... OK
Starting kernel ...
done.
/dev/mmcblk0p1: clean, 39839/69408 files, 243848/277504 blocks
done.
done.
[  OK  ] Started Forward Password Ruests to Wall Directory Watch.
[  OK  ] Set up automount Arbitrarys File System Automount Point.
         Starting Create list of stodes for the current kernel...
[  OK  ] Finished Create list of st nodes for the current kernel.
         Mounting /tmp...
Edited by TRS-80
This is when serial console on mUSB goes up. This has to be investigated under ideal / required power conditions.
I proved that software works under expected conditions - with proper powering. Since you are saying you are unfamiliar with things - you have to study (!) this section first: https://forum.armbian.com/forum/31-sd-card-and-psu-issues/
I just checked and it works for me. armbian-config -> personal -> keyboard
via SSH?
when I try this I do get there "Loading keyboard submodule ..." and then it will fall back to the personal menu - but it works when Iam directly connected via TTL-serial :(
Hi All, thanks for help I am now up and running.
@Igor I got the build to work, and sure enough, the PSU feeder cable was causing brownouts on the board. Thanks for help.
