balbes150 Posted March 2, 2021 Share Posted March 2, 2021 New version ArmbianTV of images for RK3288 and RK3188. rk3288 \ rk3188 https://users.armbian.com/balbes150/ https://mega.nz/#F!j9QSDQSQ!6WpasOlbZYIInfw6yo4phQ rk3188 https://disk.yandex.ru/d/7wqSh5Z5bv9q1g?w=1 rk3288 https://disk.yandex.ru/d/fRZwre9HDgAKHw?w=1 This link contains images with Libreelec for rk3288 and rk3188, testing these images can help with the development of media functions for rk3288 and rk3188. https://disk.yandex.ru/d/8vNYuuxynz1L0w?w=1 2 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted March 22, 2021 Author Share Posted March 22, 2021 New version of images for rk3188 \ rk3288. New kernel 5.10.25. 0 Quote Link to comment Share on other sites More sharing options...
cracker Posted April 8, 2021 Share Posted April 8, 2021 (edited) I have a radxa rock pro motherboard. Modify dtb to radxarock.dtb, and then start successfully.(Armbian_21.05.0-trunk_Rk3188_buster_current_5.10.27.img) But lan does not work. LAN8720A (https://dl.radxa.com/rock_pro/docs/hw/ds/LAN8720A.pdf). The LAN LED display is on (1s)-stop (2s)-on (1s)... cycle. dmesg: [ 977.001866] rockchip_emac 10204000.ethernet eth0: Link is Down [ 981.488483] rockchip_emac 10204000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 982.575118] speed 4294967295 not supported [ 982.575146] rockchip_emac 10204000.ethernet eth0: Link is Down [ 983.701809] rockchip_emac 10204000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 984.788436] speed 4294967295 not supported [ 984.788481] rockchip_emac 10204000.ethernet eth0: Link is Down [ 985.915143] rockchip_emac 10204000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 987.001816] speed 4294967295 not supported [ 987.001860] rockchip_emac 10204000.ethernet eth0: Link is Down [ 988.161805] rockchip_emac 10204000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 989.241782] speed 4294967295 not supported [ 989.241812] rockchip_emac 10204000.ethernet eth0: Link is Down [ 993.728511] rockchip_emac 10204000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 994.815115] speed 4294967295 not supported [ 994.815144] rockchip_emac 10204000.ethernet eth0: Link is Down [ 995.941806] rockchip_emac 10204000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 997.028434] speed 4294967295 not supported [ 997.028488] rockchip_emac 10204000.ethernet eth0: Link is Down [ 998.155135] rockchip_emac 10204000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off [ 999.241818] speed 4294967295 not supported [ 999.241862] rockchip_emac 10204000.ethernet eth0: Link is Down I think it is not equipped with the power on of the phy chip. https://linux-arm-kernel.infradead.narkive.com/VC3QzwPC/patch-4-4-arm-dts-enable-emac-node-on-the-rk3188-radxarock-boards please help me. Thank you! Edited April 8, 2021 by cracker 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted April 9, 2021 Author Share Posted April 9, 2021 23 часа назад, cracker сказал: I have a radxa rock pro motherboard. Modify dtb to radxarock.dtb, Try all dtbs, 0 Quote Link to comment Share on other sites More sharing options...
cracker Posted April 9, 2021 Share Posted April 9, 2021 1 hour ago, balbes150 said: Try all dtbs, Not work. 0 Quote Link to comment Share on other sites More sharing options...
cracker Posted April 10, 2021 Share Posted April 10, 2021 Can you add rtl8723au (wifi) rtl8152 drivers? Unable to drive by default. 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted April 12, 2021 Share Posted April 12, 2021 @cracker Have you checked and installed the armbian-firmware-full package? The default armbian-firmware only has driver firmware for the supported boards and since TV boxes are not supported the firmware you need may exist in the more comprehensive armbian-firmware-full package. 0 Quote Link to comment Share on other sites More sharing options...
cracker Posted April 13, 2021 Share Posted April 13, 2021 On 2021/4/12 at PM10点11分, SteeMan said: @cracker您是否已检查并安装了armbian-firmware-full软件包?默认的armbian-firmware仅具有支持的主板的驱动程序固件,并且由于不支持电视盒,因此您所需的固件可能包含在更全面的armbian-firmware-full软件包中。 No network,so cant install anything. 0 Quote Link to comment Share on other sites More sharing options...
cracker Posted April 29, 2021 Share Posted April 29, 2021 https://community.nxp.com/t5/i-MX-Processors/i-MX6UL-ENET1-with-LAN8720A-PHY-working-in-Uboot-but-not-in/m-p/502853 Kind of like the problem I encountered. https://patchwork.ozlabs.org/project/netdev/patch/20151127120919.66f2bfda@ipc1.ka-ro/ https://lists.openwall.net/netdev/2020/04/29/133 0 Quote Link to comment Share on other sites More sharing options...
guidol Posted May 5, 2021 Share Posted May 5, 2021 On 4/13/2021 at 11:12 PM, cracker said: No network,so cant install anything. a USB-ethernet adapter will help you to get a Network connection 0 Quote Link to comment Share on other sites More sharing options...
cracker Posted May 5, 2021 Share Posted May 5, 2021 3 hours ago, guidol said: USB以太网适配器将帮助您获得网络连接 The kernel's built-in driver does not support common usb network cards such as rtl8152. 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted May 6, 2021 Author Share Posted May 6, 2021 I don't have this equipment. Try contacting the @knaerzche to https://forum.libreelec.tv/board/43-rockchip/ 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted June 15, 2021 Author Share Posted June 15, 2021 ver 20210614 kernel 5.10.43 add image Hirsute 0 Quote Link to comment Share on other sites More sharing options...
vovan Posted July 12, 2021 Share Posted July 12, 2021 (edited) Hello, First of all thanks for the awesome work for supporting these Rockchip platforms! I've tried the Armbian_21.08.0-trunk_Rk3188_buster_current_5.10.45_xfce_desktop.img.xz for my CS968 TV box and been able to ssh to the box, but the connected HDMI TV was always blank during the whole boot process. However Xorg has been able to start, but the log file looks suspicious with multiple sections regarding resolution. I'd appreciate any thoughts regarding this situation. Below is the Xorg log file. Please let me know what kind of relevant boot log info may be needed. EDIT: forgot to mention that I've modified extlinux.conf with FDT set to /boot/dtb/rk3188-rbox-cs968.dtb. Spoiler [ 474.551] X.Org X Server 1.20.4 X Protocol Version 11, Revision 0 [ 474.551] Build Operating System: Linux 4.19.0-16-armmp-lpae armv7l Debian [ 474.552] Current Operating System: Linux rk3188 5.10.45-rk3188 #trunk SMP Mon Jun 21 07:44:21 UTC 2021 armv7l [ 474.552] Kernel command line: root=UUID=9aa9aa2f-5697-4797-95cd-3ffa5cb78c6b console=uart8250,mmio32,0x20064000 console=tty0 coherent_pool=2M video=HDMI-A-1:e rootflags=data=writeback rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 bootsplash.bootfile=bootsplash.armbian [ 474.552] Build Date: 19 April 2021 09:34:38AM [ 474.552] xorg-server 2:1.20.4-1+deb10u3 (https://www.debian.org/support) [ 474.552] Current version of pixman: 0.36.0 [ 474.552] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 474.553] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 474.554] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jul 11 15:16:49 2021 [ 474.562] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 474.563] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 474.585] (==) No Layout section. Using the first Screen section. [ 474.585] (==) No screen section available. Using defaults. [ 474.585] (**) |-->Screen "Default Screen Section" (0) [ 474.585] (**) | |-->Monitor "<default monitor>" [ 474.587] (==) No device specified for screen "Default Screen Section". Using the first device section listed. [ 474.587] (**) | |-->Device "Default Device" [ 474.587] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 474.587] (**) Option "AutoAddGPU" "off" [ 474.587] (**) Option "Debug" "dmabuf_capable" [ 474.587] (==) Automatically adding devices [ 474.587] (==) Automatically enabling devices [ 474.587] (**) Not automatically adding GPU devices [ 474.587] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 474.605] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 474.605] Entry deleted from font path. [ 474.605] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist. [ 474.605] Entry deleted from font path. [ 474.605] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist. [ 474.605] Entry deleted from font path. [ 474.605] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist. [ 474.605] Entry deleted from font path. [ 474.605] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist. [ 474.605] Entry deleted from font path. [ 474.606] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist. [ 474.606] Entry deleted from font path. [ 474.606] (==) FontPath set to: /usr/share/fonts/X11/misc, built-ins [ 474.606] (==) ModulePath set to "/usr/lib/xorg/modules" [ 474.606] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 474.606] (II) Loader magic: 0x60cf98 [ 474.606] (II) Module ABI versions: [ 474.606] X.Org ANSI C Emulation: 0.4 [ 474.606] X.Org Video Driver: 24.0 [ 474.606] X.Org XInput driver : 24.1 [ 474.606] X.Org Server Extension : 10.0 [ 474.611] (++) using VT number 7 [ 474.611] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 474.616] (II) xfree86: Adding drm device (/dev/dri/card1) [ 474.624] (II) xfree86: Adding drm device (/dev/dri/card0) [ 474.629] (**) OutputClass "Lima" setting /dev/dri/card0 as PrimaryGPU [ 474.629] (II) LoadModule: "glx" [ 474.635] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 474.747] (II) Module glx: vendor="X.Org Foundation" [ 474.747] compiled for 1.20.4, module version = 1.0.0 [ 474.747] ABI class: X.Org Server Extension, version 10.0 [ 474.747] (II) LoadModule: "modesetting" [ 474.748] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 474.755] (II) Module modesetting: vendor="X.Org Foundation" [ 474.755] compiled for 1.20.4, module version = 1.20.4 [ 474.755] Module class: X.Org Video Driver [ 474.755] ABI class: X.Org Video Driver, version 24.0 [ 474.755] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 474.828] (II) modeset(0): using drv /dev/dri/card0 [ 474.828] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 474.829] (II) modeset(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 474.829] (==) modeset(0): Depth 24, (==) framebuffer bpp 32 [ 474.829] (II) Applying OutputClass "Lima" options to /dev/dri/card0 [ 474.829] (**) modeset(0): Option "AccelMethod" "none" [ 474.829] (==) modeset(0): RGB weight 888 [ 474.829] (==) modeset(0): Default visual is TrueColor [ 474.829] (**) modeset(0): glamor disabled [ 474.830] (II) modeset(0): ShadowFB: preferred NO, enabled NO [ 474.831] (II) modeset(0): Output HDMI-1 has no monitor section [ 474.832] (II) Quirked EDID physical size to 0x0 cm [ 474.832] (II) modeset(0): EDID for output HDMI-1 [ 474.832] (II) modeset(0): Manufacturer: GSM Model: 1 Serial#: 16843009 [ 474.833] (II) modeset(0): Year: 2010 Week: 1 [ 474.833] (II) modeset(0): EDID Version: 1.3 [ 474.833] (II) modeset(0): Digital Display Input [ 474.833] (II) modeset(0): Indeterminate output size [ 474.833] (II) modeset(0): Gamma: 2.20 [ 474.833] (II) modeset(0): No DPMS capabilities specified [ 474.833] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 [ 474.833] (II) modeset(0): First detailed timing is preferred mode [ 474.833] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600 [ 474.833] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329 [ 474.833] (II) modeset(0): Supported established timings: [ 474.833] (II) modeset(0): 720x400@70Hz [ 474.833] (II) modeset(0): 640x480@60Hz [ 474.833] (II) modeset(0): 800x600@60Hz [ 474.833] (II) modeset(0): 1024x768@60Hz [ 474.834] (II) modeset(0): Manufacturer's mask: 0 [ 474.834] (II) modeset(0): Supported standard timings: [ 474.834] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337 [ 474.834] (II) modeset(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897 [ 474.835] (II) modeset(0): Supported detailed timing: [ 474.835] (II) modeset(0): clock: 148.5 MHz Image Size: 160 x 90 mm [ 474.835] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 474.835] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 474.835] (II) modeset(0): Supported detailed timing: [ 474.835] (II) modeset(0): clock: 74.2 MHz Image Size: 160 x 90 mm [ 474.835] (II) modeset(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0 [ 474.835] (II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0 [ 474.835] (II) modeset(0): Ranges: V min: 58 V max: 62 Hz, H min: 30 H max: 83 kHz, PixClock max 165 MHz [ 474.835] (II) modeset(0): Monitor name: LG TV [ 474.835] (II) modeset(0): Supported detailed timing: [ 474.835] (II) modeset(0): clock: 74.2 MHz Image Size: 160 x 90 mm [ 474.835] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 474.835] (II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0 [ 474.836] (II) modeset(0): Supported detailed timing: [ 474.836] (II) modeset(0): clock: 74.2 MHz Image Size: 160 x 90 mm [ 474.836] (II) modeset(0): h_active: 1280 h_sync: 1344 h_sync_end 1472 h_blank_end 1664 h_border: 0 [ 474.836] (II) modeset(0): v_active: 720 v_sync: 723 v_sync_end 728 v_blanking: 732 v_border: 0 [ 474.836] (II) modeset(0): Supported detailed timing: [ 474.836] (II) modeset(0): clock: 148.5 MHz Image Size: 160 x 90 mm [ 474.836] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 474.836] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 474.836] (II) modeset(0): Supported detailed timing: [ 474.836] (II) modeset(0): clock: 85.5 MHz Image Size: 160 x 90 mm [ 474.836] (II) modeset(0): h_active: 1360 h_sync: 1424 h_sync_end 1536 h_blank_end 1792 h_border: 0 [ 474.837] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 777 v_blanking: 795 v_border: 0 [ 474.837] (II) modeset(0): Number of EDID sections to follow: 1 [ 474.837] (II) modeset(0): EDID (in hex): [ 474.837] (II) modeset(0): 00ffffffffffff001e6d010001010101 [ 474.837] (II) modeset(0): 01140103801009780aee91a3544c9926 [ 474.837] (II) modeset(0): 0f5054a10800714f8180010101010101 [ 474.837] (II) modeset(0): 010101010101023a801871382d40582c [ 474.837] (II) modeset(0): 4500a05a0000001e011d007251d01e20 [ 474.837] (II) modeset(0): 6e285500a05a0000001e000000fd003a [ 474.837] (II) modeset(0): 3e1e5310000a202020202020000000fc [ 474.837] (II) modeset(0): 004c472054560a2020202020202001d7 [ 474.837] (II) modeset(0): 020326f14e101f841305140302122021 [ 474.837] (II) modeset(0): 2215012615075009570767030c003000 [ 474.837] (II) modeset(0): b82de3050301011d8018711c1620582c [ 474.837] (II) modeset(0): 2500a05a0000009e011d008051d00c20 [ 474.837] (II) modeset(0): 40803500a05a0000001e023a80187138 [ 474.837] (II) modeset(0): 2d40582c4500a05a0000001e662150b0 [ 474.838] (II) modeset(0): 51001b3040703600a05a0000001e0000 [ 474.838] (II) modeset(0): 00000000000000000000000000000019 [ 474.838] (--) modeset(0): HDMI max TMDS frequency 225000KHz [ 474.838] (II) modeset(0): Printing probed modes for output HDMI-1 [ 474.838] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 474.838] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 474.838] (II) modeset(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e) [ 474.838] (II) modeset(0): Modeline "1920x1080"x25.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e) [ 474.838] (II) modeset(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e) [ 474.838] (II) modeset(0): Modeline "1280x720"x61.0 74.25 1280 1344 1472 1664 720 723 728 732 +hsync +vsync (44.6 kHz e) [ 474.838] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 474.838] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 474.838] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 474.839] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 474.839] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 474.839] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 474.839] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e) [ 474.839] (II) modeset(0): Output HDMI-1 connected [ 474.839] (II) modeset(0): Using exact sizes for initial modes [ 474.839] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0 [ 474.839] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0) [ 474.839] (==) modeset(0): DPI set to (96, 96) [ 474.839] (II) Loading sub module "fb" [ 474.839] (II) LoadModule: "fb" [ 474.840] (II) Loading /usr/lib/xorg/modules/libfb.so [ 474.852] (II) Module fb: vendor="X.Org Foundation" [ 474.852] compiled for 1.20.4, module version = 1.0.0 [ 474.852] ABI class: X.Org ANSI C Emulation, version 0.4 [ 474.888] (==) modeset(0): Backing store enabled [ 474.888] (==) modeset(0): Silken mouse enabled [ 474.911] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc. [ 474.911] (==) modeset(0): DPMS enabled [ 474.912] (WW) modeset(0): Option "PrimaryGPU" is not used [ 474.912] (II) Initializing extension Generic Event Extension [ 474.912] (II) Initializing extension SHAPE [ 474.913] (II) Initializing extension MIT-SHM [ 474.914] (II) Initializing extension XInputExtension [ 474.915] (II) Initializing extension XTEST [ 474.916] (II) Initializing extension BIG-REQUESTS [ 474.916] (II) Initializing extension SYNC [ 474.917] (II) Initializing extension XKEYBOARD [ 474.918] (II) Initializing extension XC-MISC [ 474.919] (II) Initializing extension SECURITY [ 474.919] (II) Initializing extension XFIXES [ 474.920] (II) Initializing extension RENDER [ 474.921] (II) Initializing extension RANDR [ 474.922] (II) Initializing extension COMPOSITE [ 474.923] (II) Initializing extension DAMAGE [ 474.923] (II) Initializing extension MIT-SCREEN-SAVER [ 474.924] (II) Initializing extension DOUBLE-BUFFER [ 474.925] (II) Initializing extension RECORD [ 474.925] (II) Initializing extension DPMS [ 474.926] (II) Initializing extension Present [ 474.927] (II) Initializing extension DRI3 [ 474.927] (II) Initializing extension X-Resource [ 474.927] (II) Initializing extension XVideo [ 474.928] (II) Initializing extension XVideo-MotionCompensation [ 474.928] (II) Initializing extension SELinux [ 474.928] (II) SELinux: Disabled on system [ 474.928] (II) Initializing extension GLX [ 474.929] (II) AIGLX: Screen 0 is not DRI2 capable [ 476.877] (II) IGLX: Loaded and initialized swrast [ 476.877] (II) GLX: Initialized DRISWRAST GL provider for screen 0 [ 476.877] (II) Initializing extension XFree86-VidModeExtension [ 476.878] (II) Initializing extension XFree86-DGA [ 476.879] (II) Initializing extension XFree86-DRI [ 476.879] (II) Initializing extension DRI2 [ 476.880] (II) modeset(0): Damage tracking initialized [ 476.880] (II) modeset(0): Setting screen physical size to 508 x 285 [ 477.141] (II) config/udev: Adding input device USB Keyboard (/dev/input/event2) [ 477.141] (**) USB Keyboard: Applying InputClass "libinput keyboard catchall" [ 477.141] (II) LoadModule: "libinput" [ 477.143] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so [ 477.191] (II) Module libinput: vendor="X.Org Foundation" [ 477.191] compiled for 1.20.4, module version = 0.28.2 [ 477.191] Module class: X.Org XInput Driver [ 477.191] ABI class: X.Org XInput driver, version 24.1 [ 477.191] (II) Using input driver 'libinput' for ' USB Keyboard' [ 477.191] (**) USB Keyboard: always reports core events [ 477.191] (**) Option "Device" "/dev/input/event2" [ 477.192] (**) Option "_source" "server/udev" [ 477.222] (II) event2 - USB Keyboard: is tagged by udev as: Keyboard [ 477.222] (II) event2 - USB Keyboard: device is a keyboard [ 477.223] (II) event2 - USB Keyboard: device removed [ 477.243] (**) Option "config_info" "udev:/sys/devices/platform/101c0000.usb/usb2/2-1/2-1.4/2-1.4:1.0/0003:04D9:1702.0001/input/input2/event2" [ 477.243] (II) XINPUT: Adding extended input device " USB Keyboard" (type: KEYBOARD, id 6) [ 477.243] (**) Option "xkb_model" "pc105" [ 477.244] (**) Option "xkb_layout" "us" [ 477.251] (II) event2 - USB Keyboard: is tagged by udev as: Keyboard [ 477.251] (II) event2 - USB Keyboard: device is a keyboard [ 477.255] (II) config/udev: Adding input device USB Keyboard System Control (/dev/input/event3) [ 477.255] (**) USB Keyboard System Control: Applying InputClass "libinput keyboard catchall" [ 477.255] (II) Using input driver 'libinput' for ' USB Keyboard System Control' [ 477.255] (**) USB Keyboard System Control: always reports core events [ 477.255] (**) Option "Device" "/dev/input/event3" [ 477.256] (**) Option "_source" "server/udev" [ 477.262] (II) event3 - USB Keyboard System Control: is tagged by udev as: Keyboard [ 477.263] (II) event3 - USB Keyboard System Control: device is a keyboard [ 477.263] (II) event3 - USB Keyboard System Control: device removed [ 477.286] (**) Option "config_info" "udev:/sys/devices/platform/101c0000.usb/usb2/2-1/2-1.4/2-1.4:1.1/0003:04D9:1702.0002/input/input3/event3" [ 477.286] (II) XINPUT: Adding extended input device " USB Keyboard System Control" (type: KEYBOARD, id 7) [ 477.287] (**) Option "xkb_model" "pc105" [ 477.287] (**) Option "xkb_layout" "us" [ 477.294] (II) event3 - USB Keyboard System Control: is tagged by udev as: Keyboard [ 477.294] (II) event3 - USB Keyboard System Control: device is a keyboard [ 477.298] (II) config/udev: Adding input device USB Keyboard Consumer Control (/dev/input/event4) [ 477.298] (**) USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall" [ 477.298] (II) Using input driver 'libinput' for ' USB Keyboard Consumer Control' [ 477.298] (**) USB Keyboard Consumer Control: always reports core events [ 477.298] (**) Option "Device" "/dev/input/event4" [ 477.298] (**) Option "_source" "server/udev" [ 477.305] (II) event4 - USB Keyboard Consumer Control: is tagged by udev as: Keyboard [ 477.305] (II) event4 - USB Keyboard Consumer Control: device is a keyboard [ 477.306] (II) event4 - USB Keyboard Consumer Control: device removed [ 477.340] (**) Option "config_info" "udev:/sys/devices/platform/101c0000.usb/usb2/2-1/2-1.4/2-1.4:1.1/0003:04D9:1702.0002/input/input4/event4" [ 477.340] (II) XINPUT: Adding extended input device " USB Keyboard Consumer Control" (type: KEYBOARD, id 8) [ 477.340] (**) Option "xkb_model" "pc105" [ 477.340] (**) Option "xkb_layout" "us" [ 477.347] (II) event4 - USB Keyboard Consumer Control: is tagged by udev as: Keyboard [ 477.347] (II) event4 - USB Keyboard Consumer Control: device is a keyboard [ 477.351] (II) config/udev: Adding input device gpio_ir_recv (/dev/input/event1) [ 477.351] (**) gpio_ir_recv: Applying InputClass "libinput keyboard catchall" [ 477.351] (II) Using input driver 'libinput' for 'gpio_ir_recv' [ 477.351] (**) gpio_ir_recv: always reports core events [ 477.351] (**) Option "Device" "/dev/input/event1" [ 477.351] (**) Option "_source" "server/udev" [ 477.355] (II) event1 - gpio_ir_recv: is tagged by udev as: Keyboard Pointingstick [ 477.356] (II) event1 - gpio_ir_recv: device is a pointer [ 477.356] (II) event1 - gpio_ir_recv: device is a keyboard [ 477.357] (II) event1 - gpio_ir_recv: device removed [ 477.390] (II) libinput: gpio_ir_recv: needs a virtual subdevice [ 477.390] (**) Option "config_info" "udev:/sys/devices/platform/gpio-ir-receiver/rc/rc0/input1/event1" [ 477.390] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: MOUSE, id 9) [ 477.391] (**) Option "AccelerationScheme" "none" [ 477.391] (**) gpio_ir_recv: (accel) selected scheme none/0 [ 477.391] (**) gpio_ir_recv: (accel) acceleration factor: 2.000 [ 477.391] (**) gpio_ir_recv: (accel) acceleration threshold: 4 [ 477.395] (II) event1 - gpio_ir_recv: is tagged by udev as: Keyboard Pointingstick [ 477.396] (II) event1 - gpio_ir_recv: device is a pointer [ 477.396] (II) event1 - gpio_ir_recv: device is a keyboard [ 477.399] (II) config/udev: Adding input device gpio-keys (/dev/input/event0) [ 477.399] (**) gpio-keys: Applying InputClass "libinput keyboard catchall" [ 477.399] (II) Using input driver 'libinput' for 'gpio-keys' [ 477.399] (**) gpio-keys: always reports core events [ 477.399] (**) Option "Device" "/dev/input/event0" [ 477.399] (**) Option "_source" "server/udev" [ 477.402] (II) event0 - gpio-keys: is tagged by udev as: Keyboard [ 477.402] (II) event0 - gpio-keys: device is a keyboard [ 477.403] (II) event0 - gpio-keys: device removed [ 477.443] (**) Option "config_info" "udev:/sys/devices/platform/gpio-keys/input/input0/event0" [ 477.443] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 10) [ 477.443] (**) Option "xkb_model" "pc105" [ 477.443] (**) Option "xkb_layout" "us" [ 477.447] (II) event0 - gpio-keys: is tagged by udev as: Keyboard [ 477.447] (II) event0 - gpio-keys: device is a keyboard [ 477.478] (**) gpio_ir_recv: Applying InputClass "libinput keyboard catchall" [ 477.478] (II) Using input driver 'libinput' for 'gpio_ir_recv' [ 477.478] (**) gpio_ir_recv: always reports core events [ 477.478] (**) Option "Device" "/dev/input/event1" [ 477.478] (**) Option "_source" "_driver/libinput" [ 477.479] (II) libinput: gpio_ir_recv: is a virtual subdevice [ 477.479] (**) Option "config_info" "udev:/sys/devices/platform/gpio-ir-receiver/rc/rc0/input1/event1" [ 477.479] (II) XINPUT: Adding extended input device "gpio_ir_recv" (type: KEYBOARD, id 11) [ 477.479] (**) Option "xkb_model" "pc105" [ 477.479] (**) Option "xkb_layout" "us" [ 481.039] (II) Quirked EDID physical size to 0x0 cm [ 481.039] (II) modeset(0): EDID vendor "GSM", prod id 1 [ 481.040] (II) modeset(0): Using EDID range info for horizontal sync [ 481.040] (II) modeset(0): Using EDID range info for vertical refresh [ 481.040] (II) modeset(0): Printing DDC gathered Modelines: [ 481.040] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 481.040] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 481.040] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e) [ 481.041] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1344 1472 1664 720 723 728 732 +hsync +vsync (44.6 kHz e) [ 481.041] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e) [ 481.041] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 481.041] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 481.041] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e) [ 481.041] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 481.041] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 481.041] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e) [ 481.041] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e) [ 481.041] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e) [ 481.041] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e) [ 481.041] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 481.042] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 481.042] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e) [ 481.042] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 481.042] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e) [ 481.042] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e) [ 481.043] (--) modeset(0): HDMI max TMDS frequency 225000KHz [ 491.444] (II) Quirked EDID physical size to 0x0 cm [ 491.445] (II) modeset(0): EDID vendor "GSM", prod id 1 [ 491.445] (II) modeset(0): Using hsync ranges from config file [ 491.445] (II) modeset(0): Using vrefresh ranges from config file [ 491.445] (II) modeset(0): Printing DDC gathered Modelines: [ 491.445] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 491.445] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 491.445] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e) [ 491.445] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1344 1472 1664 720 723 728 732 +hsync +vsync (44.6 kHz e) [ 491.445] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e) [ 491.445] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 491.445] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 491.445] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e) [ 491.446] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 491.446] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 491.446] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e) [ 491.446] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e) [ 491.446] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e) [ 491.446] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e) [ 491.446] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 491.446] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 491.446] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e) [ 491.446] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 491.446] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e) [ 491.446] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e) [ 491.447] (--) modeset(0): HDMI max TMDS frequency 225000KHz [ 799.107] (II) Quirked EDID physical size to 0x0 cm [ 799.107] (II) modeset(0): EDID vendor "GSM", prod id 1 [ 799.107] (II) modeset(0): Using hsync ranges from config file [ 799.107] (II) modeset(0): Using vrefresh ranges from config file [ 799.108] (II) modeset(0): Printing DDC gathered Modelines: [ 799.108] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 799.108] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 799.108] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e) [ 799.108] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1344 1472 1664 720 723 728 732 +hsync +vsync (44.6 kHz e) [ 799.108] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e) [ 799.108] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 799.109] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 799.109] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e) [ 799.109] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 799.109] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 799.109] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e) [ 799.109] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e) [ 799.109] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e) [ 799.110] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e) [ 799.110] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 799.110] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 799.110] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e) [ 799.110] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 799.110] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e) [ 799.110] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e) [ 799.112] (--) modeset(0): HDMI max TMDS frequency 225000KHz [ 799.177] (II) Quirked EDID physical size to 0x0 cm [ 799.177] (II) modeset(0): EDID vendor "GSM", prod id 1 [ 799.177] (II) modeset(0): Using hsync ranges from config file [ 799.177] (II) modeset(0): Using vrefresh ranges from config file [ 799.177] (II) modeset(0): Printing DDC gathered Modelines: [ 799.178] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 799.178] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 799.178] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e) [ 799.178] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1344 1472 1664 720 723 728 732 +hsync +vsync (44.6 kHz e) [ 799.178] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e) [ 799.178] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 799.178] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 799.178] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e) [ 799.179] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 799.179] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 799.179] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e) [ 799.179] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e) [ 799.179] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e) [ 799.179] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e) [ 799.179] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 799.179] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 799.180] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e) [ 799.180] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 799.180] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e) [ 799.180] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e) [ 799.182] (--) modeset(0): HDMI max TMDS frequency 225000KHz [ 799.214] (II) Quirked EDID physical size to 0x0 cm [ 799.214] (II) modeset(0): EDID vendor "GSM", prod id 1 [ 799.214] (II) modeset(0): Using hsync ranges from config file [ 799.214] (II) modeset(0): Using vrefresh ranges from config file [ 799.214] (II) modeset(0): Printing DDC gathered Modelines: [ 799.214] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP) [ 799.214] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 799.215] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e) [ 799.215] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1344 1472 1664 720 723 728 732 +hsync +vsync (44.6 kHz e) [ 799.215] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e) [ 799.215] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 799.215] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 799.215] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e) [ 799.215] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 799.215] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 799.216] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e) [ 799.216] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e) [ 799.216] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e) [ 799.216] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e) [ 799.216] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 799.216] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 799.216] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e) [ 799.216] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 799.217] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e) [ 799.217] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e) [ 799.219] (--) modeset(0): HDMI max TMDS frequency 225000KHz Edited July 12, 2021 by TRS-80 put long output inside spoiler 1 Quote Link to comment Share on other sites More sharing options...
kymblc Posted August 31, 2021 Share Posted August 31, 2021 On 5/5/2021 at 8:54 PM, guidol said: a USB-ethernet adapter will help you to get a Network connection Hello, I have Minix Neo X7, and same problem with internet on it, so I used WiFi-dongle to install armbian-firmware-full. It didn't help me with ethernet, but also I lose my HDMI-output Maybe this problem also was caused by upgrading packages, but I newbie to ambian, so I don't know which algoritm to deal with those problems. If someone interested, output of armbianmonitor: http://ix.io/3xyR 0 Quote Link to comment Share on other sites More sharing options...
balbes150 Posted September 8, 2021 Author Share Posted September 8, 2021 ver 20210907 kernel 5.10.62 1 Quote Link to comment Share on other sites More sharing options...
vindio74 Posted October 18, 2021 Share Posted October 18, 2021 I have tried hirsute 5.10.63 booting from SD card in my Minix NEO X7. I am really grateful to you for giving new life to my TV Box. HDMI and sound works from start. I´m struggling to configure network connection, would something similar to rk3318-config be possible/useful? I will try to use a wifi-dongle as suggested before. Thanks again and I will be happy to contribute with any data if my user experience can be somehow useful. 1 Quote Link to comment Share on other sites More sharing options...
vindio74 Posted October 22, 2021 Share Posted October 22, 2021 On 10/18/2021 at 12:57 PM, vindio74 said: I have tried hirsute 5.10.63 booting from SD card in my Minix NEO X7. I am really grateful to you for giving new life to my TV Box. HDMI and sound works from start. I´m struggling to configure network connection, would something similar to rk3318-config be possible/useful? I will try to use a wifi-dongle as suggested before. Thanks again and I will be happy to contribute with any data if my user experience can be somehow useful. The wifi-dongle did the trick. I updated the system and is working nicely with ssh and vnc access. I'm not able to configure a Microsoft LifeCam usb webcam though, anyone with any hint about how to proceed? thanks in advance. 0 Quote Link to comment Share on other sites More sharing options...
vindio74 Posted November 21, 2021 Share Posted November 21, 2021 On 10/22/2021 at 8:45 PM, vindio74 said: The wifi-dongle did the trick. I updated the system and is working nicely with ssh and vnc access. I'm not able to configure a Microsoft LifeCam usb webcam though, anyone with any hint about how to proceed? thanks in advance. I have LifeCam and Tandberg precisionHD webcams working with webcamoid after compiling @balbes150 GitHub build. I only had to change CONFIG_USB_VIDEO_CLASS is not set to =y in file build/config/kernel/linux-rk3188-current.config I would never had expected this some months ago. I really hope you keep updating RK3188 armbian and be able to install it in EMMC in the future. In any case, my sincere gratitude. 0 Quote Link to comment Share on other sites More sharing options...
sadpanda Posted December 6, 2021 Share Posted December 6, 2021 Trying to revive some old boxes I've not played with in forever so pardon complete n00bness here; Hardware: Tronsmart MK908 (rk3188) flashed with finless 1.8 back in the day. I downloaded Armbian_21.05.0-trunk_Rk3188_focal_current_5.10.27_xfce_desktop.img.xz Flashed successfully with USBimager No boot. It seems possible from very old threads I may need to flash a stock rom or possibly use a loader/toolkit but I'm not seeing this info on current threads. Thanks in advance. 0 Quote Link to comment Share on other sites More sharing options...
Billyme Posted December 7, 2021 Share Posted December 7, 2021 (edited) Im interested to install it on an old cs968 rk3188. I flashed the file but no hdmi output can anyone help please? Edited December 7, 2021 by Billyme 0 Quote Link to comment Share on other sites More sharing options...
Billyme Posted December 11, 2021 Share Posted December 11, 2021 Any help? 0 Quote Link to comment Share on other sites More sharing options...
vindio74 Posted December 12, 2021 Share Posted December 12, 2021 On 11/21/2021 at 6:26 PM, vindio74 said: I have LifeCam and Tandberg precisionHD webcams working with webcamoid after compiling @balbes150 GitHub build. I only had to change CONFIG_USB_VIDEO_CLASS is not set to =y in file build/config/kernel/linux-rk3188-current.config I would never had expected this some months ago. I really hope you keep updating RK3188 armbian and be able to install it in EMMC in the future. In any case, my sincere gratitude. The GitHub script seems to not be working any longer, I have tried to build new images and I always get the error: LD .tmp_vmlinux.kallsyms1 [ error ] ERROR in function compile_kernel [ compilation.sh:489 ] [ error ] Kernel was not built [ @host ] [ o.k. ] Process terminated Regards 0 Quote Link to comment Share on other sites More sharing options...
vindio74 Posted December 18, 2021 Share Posted December 18, 2021 On 12/12/2021 at 4:20 AM, vindio74 said: The GitHub script seems to not be working any longer, I have tried to build new images and I always get the error: LD .tmp_vmlinux.kallsyms1 [ error ] ERROR in function compile_kernel [ compilation.sh:489 ] [ error ] Kernel was not built [ @host ] [ o.k. ] Process terminated Regards great Hi, I have tested the updated @balbes150 github script. Great to see rk3188 already included in the options for CSC compilations. Nevertheless the compilation is aborted with the following information: == u-boot make rbox-rk3188_defconfig == == u-boot make == .config:1725:warning: override: reassigning to symbol BOOTDELAY ===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ==================================================== == kernel == In file included from /home/xxxxx/build/cache/toolchain/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/plugin/include/gcc-plugin.h:28, from scripts/gcc-plugins/gcc-common.h:7, from scripts/gcc-plugins/arm_ssp_per_task_plugin.c:3: /home/xxxxx/build/cache/toolchain/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/plugin/include/system.h:687:10: fatal error: gmp.h: No existe el archivo o el directorio 687 | #include <gmp.h> | ^~~~~~~ compilation terminated. make[2]: *** [scripts/gcc-plugins/Makefile:47: scripts/gcc-plugins/arm_ssp_per_task_plugin.so] Error 1 make[1]: *** [scripts/Makefile.build:497: scripts/gcc-plugins] Error 2 make: *** [Makefile:1199: scripts] Error 2 0 Quote Link to comment Share on other sites More sharing options...
BOBAH Posted December 19, 2021 Share Posted December 19, 2021 Hi everyone, Good news regarding rk3188 and its integrated Ethernet! I found the source of the issue - it's invalid clocks of hclk_emac (and mac_src with sclk_macref). But it may be fixed on the existing image/environment - you just should update and recompile DTc. Steps: 1. open terminal under SU and launch the armbian-config 2. then go to System -> DTc, it will open nano editor 3. find section `clock-controller` and copy-n-paste the `assigned-clocks` and `assigned-clock-rates` keys (see below) clock-controller@20000000 { compatible = "rockchip,rk3188-cru"; reg = < 0x20000000 0x1000 >; rockchip,grf = < 0x09 >; #clock-cells = < 0x01 >; #reset-cells = < 0x01 >; assigned-clocks = < 0x02 0x03 0x02 0x04 0x02 0xcb 0x02 0x1d4 0x02 0x15e 0x02 0xcc 0x02 0x1d5 0x02 0x15f 0x02 0xc3 0x02 0xc4 >; assigned-clock-rates = < 0x2367b880 0x47868c00 0x11e1a300 0x8f0d180 0x47868c0 0x11e1a300 0x8f0d180 0x47868c0 0x11b3dc40 0x11b3dc40 >; phandle = < 0x02 >; }; 4. exit with saving of changes 5. armbian-config will ask to recompile, apply and reboot - do it 6. after restarting you will see the long awaited happy blinking of Ethernet LEDs Also you may add patch to your build as well. Spoiler I put the following 3-zzz-clock_rk3188-radxarock-dts.patch file to the patch/kernel/rk3188-current/ folder diff --git a/arch/arm/boot/dts/rk3188-radxarock.dts b/arch/arm/boot/dts/rk3188-radxarock.dts index b0fef82c0..fcabb2774 100644 --- a/arch/arm/boot/dts/rk3188-radxarock.dts +++ b/arch/arm/boot/dts/rk3188-radxarock.dts @@ -153,6 +153,19 @@ &cpu3 { cpu-supply = <&vdd_arm>; }; +&cru { + assigned-clocks = <&cru PLL_CPLL>, <&cru PLL_GPLL>, + <&cru ACLK_CPU>, <&cru HCLK_CPU>, + <&cru PCLK_CPU>, <&cru ACLK_PERI>, + <&cru HCLK_PERI>, <&cru PCLK_PERI>, + <&cru ACLK_LCDC0>, <&cru ACLK_LCDC1>; + assigned-clock-rates = <594000000>, <1200000000>, + <300000000>, <150000000>, + <75000000>, <300000000>, + <150000000>, <75000000>, + <297000000>, <297000000>; +}; + &gpu { status = "okay"; }; Do you think everything? No matter how it is - the good news does not end there. The RTL8723 module (WiFi+BT usb module) also works. But you should be able to build armbian image with enabled RTL8XXXU (and probably RTL8XXXU_UNTESTED) config-items PS: And please don't ask me how nor why - I'm newbie in armbian, linux and so, just 2 months experience a whole, just good experience in debugging and hardware knowledge. br, BOBAH 0 Quote Link to comment Share on other sites More sharing options...
Billyme Posted December 19, 2021 Share Posted December 19, 2021 Any news on the hdmi module? 0 Quote Link to comment Share on other sites More sharing options...
vindio74 Posted December 21, 2021 Share Posted December 21, 2021 On 12/18/2021 at 10:53 AM, vindio74 said: Hi, I have tested the updated @balbes150 github script. Great to see rk3188 already included in the options for CSC compilations. Nevertheless the compilation is aborted with the following information: == u-boot make rbox-rk3188_defconfig == == u-boot make == .config:1725:warning: override: reassigning to symbol BOOTDELAY ===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ==================================================== == kernel == In file included from /home/xxxxx/build/cache/toolchain/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/plugin/include/gcc-plugin.h:28, from scripts/gcc-plugins/gcc-common.h:7, from scripts/gcc-plugins/arm_ssp_per_task_plugin.c:3: /home/xxxxx/build/cache/toolchain/gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/8.3.0/plugin/include/system.h:687:10: fatal error: gmp.h: No existe el archivo o el directorio 687 | #include <gmp.h> | ^~~~~~~ compilation terminated. make[2]: *** [scripts/gcc-plugins/Makefile:47: scripts/gcc-plugins/arm_ssp_per_task_plugin.so] Error 1 make[1]: *** [scripts/Makefile.build:497: scripts/gcc-plugins] Error 2 make: *** [Makefile:1199: scripts] Error 2 Hi, after installing libgmp-dev and libdlib-dev, I have been able to compile: Armbian_21.11.0-trunk_Rk3188_bullseye_current_5.10.87_xfce_desktop.img Armbian_21.11.0-trunk_Rk3188_buster_current_5.10.87_xfce_desktop.img Compilation is aborted with hirsute or other desktop environment than Xfce. 0 Quote Link to comment Share on other sites More sharing options...
Billyme Posted December 21, 2021 Share Posted December 21, 2021 Is the latest version supports the integrated Ethernet for RK3188? 0 Quote Link to comment Share on other sites More sharing options...
vindio74 Posted December 21, 2021 Share Posted December 21, 2021 1 hour ago, Billyme said: Is the latest version supports the integrated Ethernet for RK3188? At least I haven't been able to set it up in my Minix X7 (RTL8152B). I will keep trying. 0 Quote Link to comment Share on other sites More sharing options...
Billyme Posted December 21, 2021 Share Posted December 21, 2021 I can help with the testing but im newbie so i will need guidance 0 Quote Link to comment Share on other sites More sharing options...
