tkaiser Posted November 4, 2016 Posted November 4, 2016 On 11/4/2016 at 8:14 AM, lanefu said: That's delightfully insane. A possible use case would be a wall or ceiling blocking Wi-Fi signals efficiently. Given a wall socket is available only on one side, drilling a hole, using a short Cat-7 cable (or real copper Cat-5/6) and two OPi Zero using one 5.2V PSU solves the problem: Wi-Fi repeater splitted into two devices, wlan0 acts as client here and as AP there and on both OPi Zero wlan0 and eth0 build br0. To increase confusion: The very same might work even better with a smaller hole to drill and more theoretical throughput. By using g_ether module (USB Ethernet gadget mode) and using a simple USB-to-Micro-USB cable for both powering and network of the second device. The necessary patch is included in Armbian since June and it's pretty easy to set this stuff up. In this case not eth0 would be used on both sides to interconnect but usb0 instead. And of course it could be even more insane since both methods could be combined. With a single PSU you could power one OPi Zero, connect/power another H3 device through USB (be it another OPi Zero or a NanoPi NEO for example) and also connect/power one more OPi Zero through PoE. And since OPi Zero has both Wi-Fi and Ethernet you can bridge air gaps wherever you want or where it's necessary. The possibility to use both Ethernet and Wi-Fi, el cheapo PoE (both injector or splitter role if distance is short enough!) and to power OPi Zero through Micro USB allows many (new) ways to interconnect (and power at the same time!) a bunch of such devices.
hojnikb Posted November 4, 2016 Posted November 4, 2016 https://www.aliexpress.com/store/product/New-Orange-Pi-PC-2-H5-64bit-Support-the-Lubuntu-linux-and-android-mini-PC-Beyond/1553371_32761481418.html PC2 already up for orders Any ideas when it's going to be supported by armbian ?
eli Posted November 4, 2016 Posted November 4, 2016 https://m.aliexpress.com/item/32761481418.html#autostay Orange pi pc 2 is now available 1
tkaiser Posted November 4, 2016 Posted November 4, 2016 On 11/4/2016 at 11:03 AM, hojnikb said: Any ideas when it's going to be supported by armbian ? When it's ready? See post #49 in this thread what's available: nothing to rely on but just a few optimistic assumptions. Nice details: SPI NOR flash is populated and for European customers board price + shipping remain below the EU VAT exempt threshold.
hojnikb Posted November 4, 2016 Posted November 4, 2016 On 11/4/2016 at 11:42 AM, tkaiser said: When it's ready? See post #49 in this thread what's available: nothing to rely on but just a few optimistic assumptions. Nice details: SPI NOR flash is populated and for European customers board price + shipping remain below the EU VAT exempt threshold. Makes sense. Obviously you guys have to get the board too and appropriate source code/documentation. Are there even any linux distros that run on H5 ? Also, there is no mention on the frequency of the arm cores or mali gpu. Any ideas on that ?
tkaiser Posted November 4, 2016 Posted November 4, 2016 On 11/4/2016 at 11:49 AM, hojnikb said: Are there even any linux distros that run on H5 ? Also, there is no mention on the frequency of the arm cores or mali gpu. Any ideas on that ? Again #49: http://forum.armbian.com/index.php/topic/1762-new-oranges-with-h5-and-h2/?p=19008 Everything based on assumptions by looking at BSP code snippets (in this case device tree). I would believe H5 is more or less a H3 with same CPU cores as A64. Codename/architecture variant is most probably sun50iw2 (DVB/TS tuner, Gbit Ethernet), it's the same regarding CPU cores as A64 (based on dvfs/cpufreq contents in DT files), it has a better GPU (Mali450, maybe Mali blobs from Hikey board can be used once community gets code ready) and according to rumours a better video engine. To my knowledge we have zero documentation, zero reference implementation (read as: at least an Android running on a H5 device) and just this smelly BSP drop here: https://github.com/BPI-SINOVOIP/BPI-M2U-bsp Even in case A64 and H5 are nearly identical as long as we're speaking about CPU cores only there is an important difference since A64 has PMIC support while H5 not. Stuff like dvfs (voltage regulation, powering specific parts) is done by AXP803 PMU on A64 devices while there's just an I2C interface to the voltage regulator on OPi PC 2 (maybe handled by an axpdummy driver, maybe not). Based on the availability of documentation, code known to work and hardware (zero, zero and zero) it's a bit hard to estimate the amount of time to get this thingie up and running
hojnikb Posted November 4, 2016 Posted November 4, 2016 So right now it's a piece of worthless pcb, until some decent images are provided... Typical Xunlong way; hardware now, software later (or never) Still gonna buy one; until i get it and get around to play with it, i'm sure something will be done
tkaiser Posted November 4, 2016 Posted November 4, 2016 On 11/4/2016 at 2:11 PM, hojnikb said: Typical Xunlong way; hardware now, software later (or never) Well, I'm into this SBC thing since two years and until recently I didn't encounter a single vendor provided OS image that wasn't horrible more or less. The only exception so far are the OS images from FriendlyARM. In other words: this is not specific to Xunlong but a broader problem. But anyway: we got good news in the meantime. An 'SDK' and documentation might soon be available (currently uploading which takes some time thanks to the GFW) and then community can start the work.
cfaulkingham Posted November 5, 2016 Posted November 5, 2016 Looks like it's here. Aliexpress has the Orange PI PC 2 available for $19.98 https://www.aliexpress.com/item/New-Orange-Pi-PC2-H5-64bit-Support-the-Lubuntu-linux-and-android-mini-PC-Beyond-Raspberry/32761481418.html?spm=2114.13010608.0.0.SMxuTv
Christos Posted November 5, 2016 Posted November 5, 2016 Think I'll wait for the Plus version, hopefully they'll give some eMMC soon. Flash addition is nice, but I2C is slow..
jernej Posted November 5, 2016 Posted November 5, 2016 On 11/5/2016 at 8:36 AM, Christos said: Think I'll wait for the Plus version, hopefully they'll give some eMMC soon. Flash addition is nice, but I2C is slow.. Flash is actually connected to SPI, which should be way faster than I2C. Also amount of it is enough only for U-Boot. I guess many of developers (me included) will pursue this way.
Christos Posted November 5, 2016 Posted November 5, 2016 On 11/5/2016 at 8:56 AM, jernej said: Flash is actually connected to SPI, which should be way faster than I2C. Also amount of it is enough only for U-Boot. I guess many of developers (me included) will pursue this way. Yep, seen schematic too (lol rare for orange to give schematics fast, still wait for the OPiPC+..), mistakenly read somewhere that it is I2C though yes it is SPI, faster obviously but still I prefer eMMC when/if they will get it out.
hojnikb Posted November 5, 2016 Posted November 5, 2016 Mine is already shipped, Xunlong works fast these days
Seasalt Posted November 5, 2016 Posted November 5, 2016 Are there any H5 benchmarks or comparisons out yet to the Orange Pi H3.
eli Posted November 5, 2016 Posted November 5, 2016 On 11/5/2016 at 1:40 PM, Seasalt said: Are there any H5 benchmarks or comparisons out yet to the Orange Pi H3. i don't know if there's any OS for this board yet. iv'e already ordered one and i promise to publish one when it'll arrive, hopefully some sort of OS will be available by then.
lanefu Posted November 6, 2016 Posted November 6, 2016 I got dorky and ordered one of each new one.... both Zero models and a PC2
Christos Posted November 6, 2016 Posted November 6, 2016 On 11/4/2016 at 3:50 PM, tkaiser said: But anyway: we got good news in the meantime. An 'SDK' and documentation might soon be available (currently uploading which takes some time thanks to the GFW) and then community can start the work. Is this something private/NDA or can it be dissiminated?
jernej Posted November 6, 2016 Posted November 6, 2016 SDK is not yet available. BTW, OPi Zero Android image is uploaded to orangepi.org download page, but it seems that it is actually PC Plus image. Anyway, I don't see a point having Android on Zero (no apparent video output, unless if you solder it). Additionaly, it doesn't include wifi driver nor wifi firmware blob.
Seasalt Posted November 11, 2016 Posted November 11, 2016 Its real. The 4 I ordered are already shipped and arrived in Hong Kong where a friend will pick them up. Seasalt
Seasalt Posted November 14, 2016 Posted November 14, 2016 Has any one managed to benchmark the h5 with a Mali 450. Can it really decode x265 10 bit HEVC 4000 X 2000 Video.
tkaiser Posted November 14, 2016 Posted November 14, 2016 I fear you've to grab the provided Android image and try out yourself. Linux development currently focuses on mainline u-boot/kernel -- see https://irclog.whitequark.org/linux-sunxi/2016-11-14#18168042; for example -- and display or even video stuff has very low priority. Also no dev cares about 'promises' made by Allwinner, we still have not even a H5 user manual.
hojnikb Posted November 14, 2016 Posted November 14, 2016 http://www.orangepi.org/orangepibbsen/forum.php?mod=viewthread&tid=2139&extra=page%3D1 anyone tried this image yet ?
tkaiser Posted November 14, 2016 Posted November 14, 2016 On 11/14/2016 at 2:10 PM, hojnikb said: http://www.orangepi.org/orangepibbsen/forum.php?mod=viewthread&tid=2139&extra=page%3D1 anyone tried this image yet ? Check Linux-sunxi IRC log
tkaiser Posted November 14, 2016 Posted November 14, 2016 This 'Debian Server' image from Xunlong is not that bad. It's based on longsleep's 'simpleimage' stuff for A64 and problems are more or less related to kernel. So comparable with Pine64 situation 9 months ago but most if not all fixes for A64 seem to fit here too. Known problems: - voltage regulation doesn't work at all - Gigabit Ethernet needs some TX/RX delay tweaks - a lot of kernel fixes required I then merged Xunlong's 'server' image with the roots from our Pine64 desktop image, got the usual desktop but fortunately video playback with mpv failed . http://sprunge.us/icXY
@lex Posted November 14, 2016 Posted November 14, 2016 On 11/14/2016 at 7:31 PM, tkaiser said: - Gigabit Ethernet needs some TX/RX delay tweaks Do you mean GbE issues?
tkaiser Posted November 14, 2016 Posted November 14, 2016 On 11/14/2016 at 8:00 PM, @lex said: Do you mean GbE issues? Yeah, seems TX/RX delay is not adopted to the board. At least symptoms look like, no time to further investigate but it should be pretty easy to start an automated test through all possible combinations. IRC log from today might be fun to read: https://irclog.whitequark.org/linux-sunxi/2016-11-14
balbes150 Posted November 15, 2016 Posted November 15, 2016 I ordered ORPi H5. When arrive, will see how it will work for my needs.
tkaiser Posted November 15, 2016 Posted November 15, 2016 On 11/15/2016 at 8:34 AM, balbes150 said: I ordered ORPi H5. When arrive, will see how it will work for my needs. Just as a reference: H2+ and H5 'SDKs' available on this mirror: http://filez.zoobab.com/allwinner/ Xunlong's 'Debian Server' image from yesterday is mirrored here: https://transfer.sh/f7Eet/orangepih5-pc2.img.xz(login: debian:debian -- sudo enabled) Regarding development efforts in general simply watch linux-sunxi IRC log (no need to join conversations, everything available as log -- see above) 1
tkaiser Posted November 15, 2016 Posted November 15, 2016 On 11/15/2016 at 9:24 AM, Christos said: Hmm.. -> https://github.com/OrangePiLibra Yes, this is one of the guys responsible for the new Xunlong OS images. Thanks for spotting it.
