Upgrading to Bullseye (troubleshooting Armbian 21.08.1)
ebin-dev
Hi everyone! Thank you for all the updates on this. I have now fully upgraded my Helios64 with a ZFS pool from Armbian 21.08.2 Buster to Armbian 21.08.2 Bullseye (full Debian and Armbian repos). All good, no issues. As currently I'm just using the emmc to boot with system installed on sata1, the emmc speed impact is negligble in my case - but hopefully this will be sorted in the near future.
Link to comment
Share on other sites
Did anyone try 21.08.2? Is it worth upgrading already?
I made an upgrade buster -> bullseye yesterday on Pine64 . It just works .
Upgrade needed only if you need some updated software from Bullseye . As for me trigger was mpd (my Pine64 board used mostly as audio player / receiver ) .
Sent from my M2007J20CG using Tapatalk
Link to comment
Hello everyone,
I am currently trying to repair my Helios64.
I exposed my problem in this topic
A member ( @IcerJo ) said that this problem could be related to this topic. So I read the posts of this topic looking for a solution.
I removed the hard drives from my NAS (to avoid a false manipulation) and I opened it (to be able to force the boot from the microSD with the jumper cab P10). Then I followed the instructions of the @TDCroPower message (here
Unfortunately, it didn't work. My NAS refuses to boot from the eMMC (fail at step 10 of the @TDCroPower message). Note that I tried 2 times these instructions: first with the Armbian_21.08.2_Helios64_buster_current_5.10.63 image. Then with the Armbian_21.05.1_Helios64_buster_current_5.10.35 image. My current version is: Armbian 21.08.3 Buster with Linux 5.10.63-rockchip64 and my NAS can only boot from the MicroSD card. Moreover, I can only communicate with it through the usb−usb-c cable, via picocom. SSH doesn’t work (I have an error message " WARNING: remote host identification has changed! "...).
Concerning the boot from the eMMC, I understood that it was maybe necessary to refresh the bootloader on eMMC. I didn’t understand very well the procedure to follow to make such thing. I went to armbian-config > System > Install > 5 - Install/Update the bootloader on SD/eMMC, then I rebooted... but nothing. Here is what picocom returns when I try to boot from the eMMC
picocom v3.1
port is        : /dev/ttyUSB0
flowcontrol    : none
baudrate is    : 1500000
parity is      : none
databits are   : 8
stopbits are   : 1
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
hangup is      : no
nolock is      : no
send_cmd is    : sz -vv
receive_cmd is : rz -vv -E
imap is        :
omap is        :
emap is        : crcrlf,delbs,
logfile is     : none
initstring     : none
exit_after is  : not set
exit is        : no
Type [C-a] [C-h] to see available commands
Terminal ready
DDR Version 1.24 20191016
In
channel 0
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 928MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 928 MHz, current 856MHz
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 254
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67971
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xe5af4
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (Feb 03 2021 - 22:43:46 +0100)
SoC: Rockchip rk3399
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
MMC:   mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Revision: 1.2 - 4GB non ECC
Net:   eth0: ethernet@fe300000
scanning bus for devices...
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus dwc3: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus dwc3 for devices... cannot reset port 4!?
4 USB Device(s) found
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
3185 bytes read in 16 ms (194.3 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0
166 bytes read in 13 ms (11.7 KiB/s)
15701569 bytes read in 1507 ms (9.9 MiB/s)
28580352 bytes read in 2727 ms (10 MiB/s)
81924 bytes read in 42 ms (1.9 MiB/s)
Failed to load '/boot/dtb/rockchip/overlay/-fixup.scr'
Moving Image from 0x2080000 to 0x2200000, end=3de0000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    15701505 Bytes = 15 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f4ff6000, end f5eef601 ... OK
   Loading Device Tree to 00000000f4f79000, end 00000000f4ff5fff ... OK
Starting kernel ...
I'm a little bit lost. I don't understand much about it. Does anyone have a clue for me? Whether the NAS runs on eMMC or MicroSD doesn't really matter to me. I just want to be able to get a working NAS and recover the data from my hard drives (previously configured with OpenMediaVault).
Thank you very much, everyone.
Link to comment
14 hours ago, Cariboux said:
I removed the hard drives from my NAS (to avoid a false manipulation) and I opened it (to be able to force the boot from the microSD with the jumper cab P10). Then I followed the instructions of the @TDCroPower message (here :
If you boot from sdcard while your previous system was on eMMC the ssh identification is different. If you want to connect to the sd card rescue system:
ssh -o "UserKnownHostsFile /dev/null" -o StrictHostKeyChecking=no -o  "PasswordAuthentication yes" root@helios64
I mean if your system is on eMMC and you boot from a sd card rescue system you have to tell ssh to ignore the host (and force password auth because the sd card system will not have public kay auth set up).
about the failure at step 10 ... you should remove the sd card before boot (and your jumper mod) to boot from eMMC and all should be fine.
Mind the process you followed did not tell to set the jumper 10 because it tells to switch boot media via u-boot prompt a command "run bootcmd_mmc1" for sd and "run bootcmd_mmc0" for eMMC. Doing both jumper 10 and u-boot bootcmd_mmc1 is undefined. Simply do one or the other not both.
Cheers
Link to comment
Cheers
Hi @prahal, thank you for helping me !
So, I have remove the jumper cap and the MicroSD card, but the boot from eMMC doesn’t work.
This is what I have when I try to start from eMMC :
In
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
ChipType = 0x10, 323
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
StorageInit ok = 79411
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0xe5ba8
RunBL31 0x40000
INFO:    SPSR = 0x3c9
U-Boot 2020.10-armbian (Sep 08 2021 - 10:55:50 +0000)
Reset cause: RST
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
Scanning mmc 0:1...
166 bytes read in 12 ms (12.7 KiB/s)
15701569 bytes read in 1508 ms (9.9 MiB/s)
28580352 bytes read in 2726 ms (10 MiB/s)
   Image Name:   uInitrd
Starting kernel ...
... and the kernel never start. (The System activity LED of the Front Panel is blue still. It’s not blinking.)
When I boot from the MicroSD card (with the command « run bootcmd_mmc1 »), it’s working.
 When I boot from the MicroSD card, at the step 5 of the @TDCroPower’s message (https://forum.armbian.com/topic/18855-upgrading-to-bullseye-troubleshooting-armbian-21081/?do=findComment&comment=128305 ), I see this (I don’t know if it’s normal, especialy what is in red)
Welcome to Armbian 21.08.3 Buster with Linux 5.10.63-rockchip64
No end-user support: work in progress
System load:   7%               Up time:       0 min
Memory usage:  3% of 3.77G      IP:           192.168.2.155
CPU temp:      51°C               Usage of /:    5% of 29G
RX today:      16 KiB
root@helios64:~# mkdir -p /mnt/system
root@helios64:~# mount /dev/mmcblk2p1 /mnt/system
root@helios64:~# cd /mnt/system/
root@helios64:/mnt/system# ll
total 102792
lrwxrwxrwx   1 root root        7 Feb  4  2021 bin -> usr/bin
drwxr-xr-x   3 root root     4096 Oct 13 17:47 boot
drwxr-xr-x   2 root root     4096 Oct 13 17:46 dev
drwxr-xr-x 112 root root    12288 Sep 16 16:13 etc
drwxr-xr-x   2 root root     4096 Jan 12  2021 export
drwxr-xr-x   3 root root     4096 Feb 18  2021 home
lrwxrwxrwx   1 root root        7 Feb  4  2021 lib -> usr/lib
-rw-r--r--   1 root root   314356 Jul  8 19:32 linux-dtb-current-rockchip64_21.05.1_arm64.deb
-rw-r--r--   1 root root   316512 Sep  8 13:19 linux-dtb-current-rockchip64_21.08.2_arm64.deb
-rw-r--r--   1 root root 11533048 Jul  8 19:32 linux-headers-current-rockchip64_21.05.1_arm64.deb
-rw-r--r--   1 root root 11466188 Sep  8 13:19 linux-headers-current-rockchip64_21.08.2_arm64.deb
-rw-r--r--   1 root root 40272020 Jul  8 19:33 linux-image-current-rockchip64_21.05.1_arm64.deb
-rw-r--r--   1 root root 41246520 Sep  8 13:19 linux-image-current-rockchip64_21.08.2_arm64.deb
drwx------   2 root root    16384 Feb  4  2021 lost+found
drwxr-xr-x   2 root root     4096 Feb  4  2021 media
drwxr-xr-x   2 root root     4096 Feb  4  2021 mnt
drwxr-xr-x   2 root root     4096 Feb  4  2021 opt
drwxr-xr-x   2 root root     4096 Nov 22  2020 proc
drwx------   7 root root     4096 Mar 16  2021 root
drwxr-xr-x   2 root root     4096 Oct 13 16:32 run
lrwxrwxrwx   1 root root        8 Feb  4  2021 sbin -> usr/sbin
drwxrwxr-x   2 root root     4096 Feb  4  2021 selinux
drwxr-xr-x   7 root root     4096 Feb 28  2021 srv
drwxr-xr-x   2 root root     4096 Nov 22  2020 sys
lrwxrwxrwx   1 root root       42 Sep 16 16:13 thermal_zone0 -> /sys/devices/virtual/thermal/thermal_zone0
drwxrwxrwt   2 root root     4096 Oct 13 17:47 tmp
drwxr-xr-x  10 root root     4096 Feb  4  2021 usr
drwxr-xr-x  14 root root     4096 Feb 18  2021 var
( Maybe I have made a mistake because when I have do the step 6 of @TDCroPower’s message, I only « wget » 3 packages of this link : http://armbian.hosthatch.com/apt/pool/main/l/linux-5.10.63-rockchip64/ : linux-dtb-current-rockchip64_21.08.2_arm64.deblinux-headers-current-rockchip64_21.08.2_arm64.deb and linux-image-current-rockchip64_21.08.2_arm64.deb. I didn’t « wget » the 3 packages « 21.05.9 ».
(But, when i have try the downgrading with the Armbian_21.05.1_Helios64_buster_current_5.10.35 image on my MicroSD, i have « wget » all the three packages of http://armbian.hosthatch.com/apt/pool/main/l/linux-5.10.35-rockchip64/ . But it was not working neither....) )
Link to comment
  Hide contents
In
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: RST
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
Scanning mmc 0:1...
   Image Name:   uInitrd
Starting kernel ...
check that eMMC boot/armbianEnv.txt contains:
verbosity=1
bootlogo=false
overlay_prefix=rockchip
rootdev=UUID=a79a14c0-3cf4-4fb9-a6c6-838571351371
rootfstype=ext4
overlays=dwc3-0-host
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u,0x0bc2:0x231a:u
Note rootdev=UUID= will be different. You can check your by running
sudo blkid
from the sdcard os.
I believe yours is fine so you could also:
fsck /dev/mmcblk2p1
when booting from sdcard (booting kernel that has the emmc fix only ! your log shows 5.10.63 armbian 22.08.2 so your are fine. But double check before fscking).
Fscking will tell you if the filesystem is fine (readable/mountable by for one u-boot itself to start the kernel).
My mmcblk2p1 boot/armbianEnv.txt content was wrong as I ran fsck when my emmc was unstable (this was a bad idea). Thus u-boot was unable to start the system. Restoring armbianENv.txt fixed my boot.
  Hide contents
RX today:      16 KiB
total 102792
The red is fine it is color for deb file type.
just  a note. The steps were to download from :
root@helios64:/mnt/system# wget http://armbian.hosthatch.com/apt/pool/main/l/linux-5.10.43-rockchip64/linux-dtb-current-rockchip64_21.05.4_arm64.deb
root@helios64:/mnt/system# wget http://armbian.hosthatch.com/apt/pool/main/l/linux-5.10.43-rockchip64/linux-headers-current-rockchip64_21.05.4_arm64.deb
root@helios64:/mnt/system# wget http://armbian.hosthatch.com/apt/pool/main/l/linux-5.10.43-rockchip64/linux-image-current-rockchip64_21.05.4_arm64.deb
not 5.10.63 ... but 5.10.63 will be fine too per
 ie 21.08.2 has the emmc fix.
Link to comment
verbosity=1
bootlogo=false
rootfstype=ext4
I booted from the MicroSD (command « run bootcmd_mmc1 »). The command « sudo vim /boot/armbianEnv.txt » shows
verbosity=1
bootlogo=false
rootdev=UUID=a7a41236-bd7e-4b26-a31d-e30f47633de7
rootfstype=ext4
"/boot/armbianEnv.txt" 6L, 166C                               1,1           All
So, I added (with vim) the line « overlays=dwc3-0-host ».
When I enter « sudo blkid », I have this
root@helios64:~# sudo blkid
/dev/mmcblk2p1: UUID="e4e3bcd6-3f03-4362-bbe0-f1654138c5d8" TYPE="ext4" PARTUUID="aaedb48e-01"
/dev/mmcblk1p1: UUID="a7a41236-bd7e-4b26-a31d-e30f47633de7" TYPE="ext4" PARTUUID="436f9809-01"
/dev/zram0: UUID="5c89530a-5757-4e66-a8d6-987959cbd813" TYPE="swap"
/dev/mmcblk2: PTUUID="aaedb48e" PTTYPE="dos"
/dev/mmcblk1: PTUUID="436f9809" PTTYPE="dos"
/dev/zram1: LABEL="log2ram" UUID="8ad8e588-16b9-46e0-bc70-be4de52f85c5" TYPE="ext4"
I entered « fsck /dev/mmcblk2p1 » and it showed this
root@helios64:~# fsck /dev/mmcblk2p1
fsck from util-linux 2.33.1
e2fsck 1.44.5 (15-Dec-2018)
/dev/mmcblk2p1: recovering journal
/dev/mmcblk2p1 contains a file system with errors, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/mmcblk2p1: 101902/924288 files (0.1% non-contiguous), 771522/3774692 blocks
I turned off the NAS, removed the MicroSD, turned on.... and... it’s not working...
What did I miss ? Do I have to change the « rootdev=UUID » in boot/armbianEnv.txt ? Remplacing the actual UUID of the MicroSD by the UUID of the eMMC
(Note : now, if the MicroSD is in the NAS, this one boot automatically with no need of the command « run bootcmd_mmc1 »)
Link to comment
On emmc (/dev/mmcblk2p1) you just need to replace the root UUID in /etc/fstab and in /boot/armbianEnv.txt to match the UUID of your emmc (e4e3bcd6-3f03-4362-bbe0-f1654138c5d8). Then reboot without microsd in the slot...
Link to comment
I am deeply sorry to ask such a beginner's question, but : how can I do that ? I mean : I know how to edit (with « sudo vim ») /etc/fstab and /boot/armbianEnv.txt, but I don’t know how to « reach » theses files in the eMMC (/dev/mmcblk2p1)...
Link to comment
mount your eMMC to some random folder. mkdir ~/mount && mount /dev/mmcblk2p1 ~/mount && cd ~/mount
Link to comment
Beware ! Do not change your sdcard /boot/armbianEnv.txt. Only the one of the emmc ! thus /mnt/boot/armbianEnv.txt if you mount /dev/mmcblk2p1 to /mnt .
As I understood you checked the  /boot/armbianEnv.txt  of the Sdcard which is not right. If you boot from the sdcard then this one is correct, do not change it.
But check your emmc one is not corrupted. Thus /mnt/boot/armbianEnv.txt and compare with the one I gave.
As fsck showed your emmc partition was corrupted and fixed by fsck. Try to run
fsck /dev/mmcblk2p1
as second time and paste output just to be confident it is now ok.
Then when yoiu boot without sdcard try to force u-boot to boot from emmc.
run bootcmd_mmc0
from u-boot prompt.
Cheers. There are not many option for a failed boot. But check emmc not sdcard files.
From your lsblk output :
rootdev=UUID=e4e3bcd6-3f03-4362-bbe0-f1654138c5d8
Link to comment
You are right ! : I made the mistake of editing the /boot/armbianEnv.txt of the SDcard. (I didn’t touch the UUID but I added this line « overlays=dwc3-0-host ».)
So, I followed what @Werner wrote (« mkdir ~/mount && mount /dev/mmcblk2p1 ~/mount && cd ~/mount ») and this is what I see with « root@helios64:~/mount# sudo vim /boot/armbianEnv.txt »
verbosity=1
bootlogo=false
rootfstype=ext4
"/boot/armbianEnv.txt" 8L, 189C                               8,1           All
« root@helios64:~/mount# sudo vim /mnt/boot/armbianEnv.txt » gives this (!)
"/mnt/boot/armbianEnv.txt" [New DIRECTORY]                    0,0-1         All
(Yes, it’s empty !)
« root@helios64:~/mount# sudo vim /etc/fstab » gives this
UUID=e4e3bcd6-3f03-4362-bbe0-f1654138c5d8 / ext4 defaults,noatime,commit=600,err
ors=remount-ro 0 1
tmpfs /tmp tmpfs defaults,nosuid 0 0
"/etc/fstab" 2L, 136C                                         1,40          All
And « root@helios64:~/mount# fsck /dev/mmcblk2p1 », that (...)
/dev/mmcblk2p1 is mounted.
e2fsck: Cannot continue, aborting.
Link to comment
  Reveal hidden contents
(Yes, it’s empty !)
If you followed the example given by werner it should be mounted to /mount ...
Try this: sudo vim /mount/boot/armbianEnv.txt
Link to comment
If it is empty then you now know why u-boot fails to boot the kernl.
Mine was filled with garbage due to the FS corruption (due to the emmc bug)
Fill the emmc armbianEnv.txt with:
echo 'verbosity=1
bootlogo=false
rootfstype=ext4
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u,0x0bc2:0x231a:u' > /mount/boot/armbianEnv.txt
and reboot. You are done !
Link to comment
echo 'verbosity=1
bootlogo=false
rootfstype=ext4
I just tried it and it doesn't work (« "/mount/boot/armbianEnv.txt" E212: Can't open file for writing », with VIM).
Then, I was struck by a doubt... So, I checked if armbianEnv.txt exists (in my eMMC). I have mount my eMMC as @Werner said (here). Then, I tried this
root@helios64:~# cd ~/mount
root@helios64:~/mount# ls -a
.             linux-dtb-current-rockchip64_21.05.1_arm64.deb      root
..            linux-dtb-current-rockchip64_21.08.2_arm64.deb      run
.autorelabel  linux-headers-current-rockchip64_21.05.1_arm64.deb  sbin
bin           linux-headers-current-rockchip64_21.08.2_arm64.deb  selinux
boot          linux-image-current-rockchip64_21.05.1_arm64.deb    srv
dev           linux-image-current-rockchip64_21.08.2_arm64.deb    sys
.dpkg-old     lost+found                                          thermal_zone0
etc           media                                               tmp
export        mnt                                                 usr
home          opt                                                 var
lib           proc
root@helios64:~/mount# cd /mnt
root@helios64:/mnt# ls -a
.  ..  system
As you can see, it seems that there is nothing except « system » in /mnt. No armbianEnv.txt here.
But I have find armbianEnv.txt in /boot. Look :
etc           media                                               tmp
export        mnt                                                 usr
home          opt                                                 var
lib           proc
root@helios64:/# cd /boot
root@helios64:/boot# ls -a
.                               dtb
..                              dtb-5.10.63-rockchip64
armbianEnv.txt                  Image
armbianEnv.txt.out              initrd.img-5.10.63-rockchip64
armbian_first_run.txt.template  .next
boot.bmp                        System.map-5.10.63-rockchip64
boot.cmd                        uInitrd
boot.scr                        uInitrd-5.10.63-rockchip64
config-5.10.63-rockchip64       vmlinuz-5.10.63-rockchip64
So, I have edited this armbianEnv.txt here (with copy-paste of that ).
I have checked the UUID in /etc/fstab (here). « root@helios64:/etc# sudo vim fstab »
ors=remount-ro 0 1
"fstab" 2L, 136C                                              1,39          All
Then... I turned off the NAS..... removed the MicroSD.... restart.... and.....
... It doesn't work !!! Same problem as usual
Starting kernel ...
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67786
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
 will return SMC_UNK
INFO:    SPSR = 0x3c9
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
=> run bootcmd_mmc0
Scanning mmc 0:1...
   Image Name:   uInitrd
Starting kernel ...
(kernel never start.)
After that, I restarted with the MicroSD... as usual... and I see that (!)
Starting kernel ...
In
channel 0
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
StorageInit ok = 78781
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
 will return SMC_UNK
INFO:    SPSR = 0x3c9
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
=> run bootcmd_mmc1
mmc1 is current device
Scanning mmc 1:1...
3185 bytes read in 5 ms (622.1 KiB/s)
Boot script loaded from mmc 1
189 bytes read in 5 ms (36.1 KiB/s)
13868411 bytes read in 591 ms (22.4 MiB/s)
28580352 bytes read in 1212 ms (22.5 MiB/s)
81924 bytes read in 13 ms (6 MiB/s)
272 bytes read in 9 ms (29.3 KiB/s)
Applying kernel provided DT overlay rockchip-dwc3-0-host.dtbo
2698 bytes read in 10 ms (262.7 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
   Image Name:   uInitrd
   Data Size:    13868347 Bytes = 13.2 MiB
   Loading Ramdisk to f51b6000, end f5eefd3b ... OK
   Loading Device Tree to 00000000f5139000, end 00000000f51b5fff ... OK
Starting kernel ...
openmediavault 5.6.14-1 (Usul) helios64 ttyS2
Copyright (C) 2009-2021 by Volker Theile. All rights reserved.
To manage the system visit the openmediavault web control panel:
eth0: 192.168.2.155
eth0: fd00:ab:cd::2e9
eth0: fd00:ab:cd:0:6662:66ff:fed0:58a
eth0: fe80::6662:66ff:fed0:58a
By default the web control panel administrator account has the
username 'admin' and password 'openmediavault'.
It is recommended that you change the password for this account
within the web control panel or using the 'omv-firstaid' CLI
command.
For more information regarding this appliance, please visit the
web site: https://www.openmediavault.org
helios64 login: root
Password:
Last login: Tue Apr 13 20:43:55 CEST 2021 from 192.168.1.10 on pts/0
 _   _      _ _            __   _  _
| | | | ___| (_) ___  ___ / /_ | || |
| |_| |/ _ \ | |/ _ \/ __| '_ \| || |_
|  _  |  __/ | | (_) \__ \ (_) |__   _|
|_| |_|\___|_|_|\___/|___/\___/   |_|
Welcome to Armbian 21.08.1 Buster with Linux 5.10.63-rockchip64
No end-user support: built from trunk
System load:   5%               Up time:       4 min
Memory usage:  6% of 3.77G      IP:           192.168.2.155
CPU temp:      55°C               Usage of /:    22% of 15G
What I put in purple color is new for the situation. I guess I found my OMV installation, more or less !
Link to comment
Confirmation : I’m able to connect to my OpenMediaVault with web browser. It’s here ! Thank god you, guys !
So, what do I do next ? Update OMV (and Armbian, via the Update Management of OMV) ? Or fix the eMMC boot problem ?
Link to comment
You should settle the dust down. First check where you mount /dev/mmcblk2p1. Do you:
or
mount /dev/mmcblk2p1 /mount
Because the content of the emmc will show up in the above command right directory. It will not be in /mount  or /mnt if you did not made it so in the mount command.
Second give use the emmc boot/armbianEnv.txt because it could be  you set the sdcard armbianEnv.txt to boot with sdcard kernel and "rootdev" (ie boot partition) as emmc. Thus it works but you have to let the sdcard for the boot which is fragile.
It ought ot contains:
verbosity=1
bootlogo=false
rootfstype=ext4
only. "echo" and "> /mount/boot/armbianEnv.txt" where only there so you could paste the full command and have it write the armbianEnv.txt in /mount/boot for you. If you write them down in armbianEnv.txt it kills boot.
Then feel free to update. I currenty run OMV with buster and armbian up to date on my helios64.
Link to comment
On 9/16/2021 at 3:08 AM, prahal said:
bisected eMMC breakage:
06653ebc0ad2e0b7d799cd71a5c2933ed2fb7a66 is the first bad commit
commit 06653ebc0ad2e0b7d799cd71a5c2933ed2fb7a66
Author: Dmitry Baryshkov <dmitry.baryshkov@linaro.org>
Date:   Thu May 20 01:12:23 2021 +0300
    regulator: core: resolve supply for boot-on/always-on regulators
    commit 98e48cd9283dbac0e1445ee780889f10b3d1db6a upstream.
    For the boot-on/always-on regulators the set_machine_constrainst() is
    called before resolving rdev->supply. Thus the code would try to enable
    rdev before enabling supplying regulator. Enforce resolving supply
    regulator before enabling rdev.
    Fixes: aea6cb99703e ("regulator: resolve supply after creating regulator")
    Signed-off-by: Dmitry Baryshkov <dmitry.baryshkov@linaro.org>
    Link: https://lore.kernel.org/r/20210519221224.2868496-1-dmitry.baryshkov@linaro.org
    Signed-off-by: Mark Brown <broonie@kernel.org>
    Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
 drivers/regulator/core.c | 6 ++++++
 1 file changed, 6 insertions(+)
is https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/commit/drivers/regulator/core.c?id=98e48cd9283dbac0e1445ee780889f10b3d1db6a
from thread https://lore.kernel.org/all/20210519221224.2868496-1-dmitry.baryshkov@linaro.org/
diff --git a/drivers/regulator/core.c b/drivers/regulator/core.c
index 7b3de8b0b1ca..043b5f63b94a 100644
--- a/drivers/regulator/core.c
+++ b/drivers/regulator/core.c
@@ -1422,6 +1422,12 @@ static int set_machine_constraints(struct regulator_dev *rdev)
         * and we have control then make sure it is enabled.
        if (rdev->constraints->always_on || rdev->constraints->boot_on) {
+               /* If we want to enable this regulator, make sure that we know
+                * the supplying regulator.
+               if (rdev->supply_name && !rdev->supply)
+                       return -EPROBE_DEFER;
                if (rdev->supply) {
                        ret = regulator_enable(rdev->supply);
                        if (ret < 0) {
EDIT 1: this change to return EPROBE_DEFER if regulator has a supply name but no supply ready was intended to complete commit aea6cb99703e17019e025aa71643b4d3e0a24413 which  expects set_machine_constraints to return this eprobe_defer error to attempt to resolve the supply ( before attempting a second run of set_machine_constraints).
One still need to find out if aea6cb99703e17019e025aa71643b4d3e0a24413 fails to resolve the supply and thus does not make a second attempt to set_machine_constraints thus leaves the regulator disabled or else.
Author: Micha? Miros?aw <mirq-linux@rere.qmqm.pl>
Date:   Sat Sep 26 23:32:41 2020 +0200
    When creating a new regulator its supply cannot create the sysfs link
    because the device is not yet published. Remove early supply resolving
    since it will be done later anyway. This makes the following error
    disappear and the symlinks get created instead.
      DCDC_REG1: supplied by VSYS
      VSYS: could not add device link regulator.3 err -2
    Note: It doesn't fix the problem for bypassed regulators, though.
    Fixes: 45389c47526d ("regulator: core: Add early supply resolution for regulators")
    Signed-off-by: Micha? Miros?aw <mirq-linux@rere.qmqm.pl>
    Link: https://lore.kernel.org/r/ba09e0a8617ffeeb25cb4affffe6f3149319cef8.1601155770.git.mirq-linux@rere.qmqm.pl
index ff8e99ca0306..9f704a6c4802 100644
@@ -5280,15 +5280,20 @@ regulator_register(const struct regulator_desc *regulator_desc,
        else if (regulator_desc->supply_name)
                rdev->supply_name = regulator_desc->supply_name;
-        * Attempt to resolve the regulator supply, if specified,
-        * but don't return an error if we fail because we will try
-        * to resolve it again later as more regulators are added.
-       if (regulator_resolve_supply(rdev))
-               rdev_dbg(rdev, "unable to resolve supply\n");
        ret = set_machine_constraints(rdev, constraints);
+       if (ret == -EPROBE_DEFER) {
+               /* Regulator might be in bypass mode and so needs its supply
+                * to set the constraints */
+               /* FIXME: this currently triggers a chicken-and-egg problem
+                * when creating -SUPPLY symlink in sysfs to a regulator
+                * that is just being created */
+               ret = regulator_resolve_supply(rdev);
+               if (!ret)
+                       ret = set_machine_constraints(rdev, constraints);
+               else
+                       rdev_dbg(rdev, "unable to resolve supply early: %pe\n",
+                                ERR_PTR(ret));
        if (ret < 0)
                goto wash;
My logs for bad shows:
[    1.257297] reg-fixed-voltage vcc1v8-sys-s0: Failed to register regulator: -517
[    1.257446] reg-fixed-voltage vcc0v9-s3: Failed to register regulator: -517
[    1.257588] reg-fixed-voltage avdd-0v9-s0: Failed to register regulator: -517
[    1.257728] reg-fixed-voltage avdd-1v8-s0: Failed to register regulator: -517
[    1.258114] reg-fixed-voltage pcie-power: Failed to register regulator: -517
[    1.258312] reg-fixed-voltage vcc3v3-sys-s3: Failed to register regulator: -517
[    1.258451] reg-fixed-voltage vcc3v0-sd: Failed to register regulator: -517
[    1.258705] reg-fixed-voltage vcc5v0-usb: Failed to register regulator: -517
[    1.261721] reg-fixed-voltage usblan-power: Failed to register regulator: -517
[    2.158719] vdd_log: supplied by regulator-dummy
[    2.230749] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.230781] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.230792] rk808-regulator rk808-regulator: max buck steps per change: 4
[    2.240854] rk808 0-001b: failed to register 12 regulator
[    2.249848] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.253127] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    2.423549] reg-fixed-voltage vcc1v8-sys-s0: Failed to register regulator: -517
[    2.424263] reg-fixed-voltage vcc0v9-s3: Failed to register regulator: -517
[    2.424830] reg-fixed-voltage avdd-0v9-s0: Failed to register regulator: -517
[    2.425443] reg-fixed-voltage avdd-1v8-s0: Failed to register regulator: -517
[    2.556287] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.556318] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.556328] rk808-regulator rk808-regulator: max buck steps per change: 4
while for good:
[    2.172993] vdd_log: supplied by regulator-dummy
[    2.330040] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.330071] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.330081] rk808-regulator rk808-regulator: max buck steps per change: 4
[    2.347345] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.350525] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
as I read this post, I'm not certain whether this rk808 regulator issue is solved yet.
For info, I'm currently running:
kobol@helios64:~$ uname -a
Linux helios64 5.10.63-rockchip64 #21.08.2 SMP PREEMPT Wed Sep 8 10:57:23 UTC 2021 aarch64 GNU/Linux
and I have these logs (similar than @prahal for bad):
kobol@helios64:~$ journalctl -b | grep regulator
Oct 30 14:47:58 helios64 kernel: reg-fixed-voltage vcc1v8-sys-s0: Failed to register regulator: -517
Oct 30 14:47:58 helios64 kernel: reg-fixed-voltage vcc0v9-s3: Failed to register regulator: -517
Oct 30 14:47:58 helios64 kernel: reg-fixed-voltage avdd-0v9-s0: Failed to register regulator: -517
Oct 30 14:47:58 helios64 kernel: reg-fixed-voltage avdd-1v8-s0: Failed to register regulator: -517
Oct 30 14:47:58 helios64 kernel: reg-fixed-voltage pcie-power: Failed to register regulator: -517
Oct 30 14:47:58 helios64 kernel: reg-fixed-voltage vcc3v3-sys-s3: Failed to register regulator: -517
Oct 30 14:47:58 helios64 kernel: reg-fixed-voltage vcc3v0-sd: Failed to register regulator: -517
Oct 30 14:47:58 helios64 kernel: reg-fixed-voltage vcc5v0-usb: Failed to register regulator: -517
Oct 30 14:47:58 helios64 kernel: reg-fixed-voltage usblan-power: Failed to register regulator: -517
Oct 30 14:47:58 helios64 kernel: vdd_log: supplied by regulator-dummy
Oct 30 14:47:58 helios64 kernel: rk808-regulator rk808-regulator: there is no dvs0 gpio
Oct 30 14:47:58 helios64 kernel: rk808-regulator rk808-regulator: there is no dvs1 gpio
Oct 30 14:47:58 helios64 kernel: rk808-regulator rk808-regulator: max buck steps per change: 4
Oct 30 14:47:58 helios64 kernel: rk808 0-001b: failed to register 12 regulator
Oct 30 14:47:58 helios64 kernel: fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
Oct 30 14:47:58 helios64 kernel: fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
Oct 30 14:47:58 helios64 kernel: rockchip-saradc ff100000.saradc: failed to get regulator, -517
Oct 30 14:47:58 helios64 kernel: lm75 2-004c: supply vs not found, using dummy regulator
Oct 30 14:47:58 helios64 systemd[1]: Starting fan speed regulator...
Oct 30 14:47:59 helios64 systemd[1]: Started fan speed regulator.
Does there already exist a fix for such up-to-date kernel?
Regards,
Link to comment
Hello everyone,
Since the last time, I have good news and bad news.
I'll start with the good news : My NAS boots by itself, without the MicroSD card. (The problem was indeed on the side of the armbianEnv.txt file. The good one, I mean...)
Without your help ( @prahal , @ebin-dev , @Werner , @IcerJo), I would never have managed to get out of it. Thank you so much, all of you! (I have made a small donation to the Armbian forum as a material thank you to the community.)
Now, for the bad news (sorry guys... :unsure: ) My device is still not working properly. When I do " apt upgrade ", I get the following error message :
In
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x82
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
ChipType = 0x10, 322
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68847
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: RST
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
starting USB...
USB XHCI 1.10
Scanning mmc 0:1...
3185 bytes read in 17 ms (182.6 KiB/s)
203 bytes read in 13 ms (14.6 KiB/s)
16224611 bytes read in 1558 ms (9.9 MiB/s)
272 bytes read in 28 ms (8.8 KiB/s)
2698 bytes read in 32 ms (82 KiB/s)
   Image Name:   uInitrd
   Data Size:    16224547 Bytes = 15.5 MiB
   Loading Ramdisk to f4f76000, end f5eef123 ... OK
   Loading Device Tree to 00000000f4ef9000, end 00000000f4f75fff ... OK
Starting kernel ...
Armbian 21.08.3 Buster ttyS2
Password:
Last login: Tue Nov  2 17:42:50 CET 2021 on ttyS2
 _   _      _ _            __   _  _
System load:   9%               Up time:       3 min
Memory usage:  36% of 3.77G      IP:           192.168.2.155
[ General system configuration (beta): armbian-config ]
root@helios64:~# sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up openmediavault (5.6.18-2) ...
Creating configuration database ...
Migrating configuration database ...
Setting up Salt environment ...
[ERROR   ] An un-handled exception was caught by salt's global exception handler:
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x81 in position 0: invalid start byte
Traceback (most recent call last):
  File "/usr/bin/salt-call", line 11, in <module>
    load_entry_point('salt==3003', 'console_scripts', 'salt-call')()
  File "/usr/lib/python3/dist-packages/salt/scripts.py", line 449, in salt_call
    client.run()
  File "/usr/lib/python3/dist-packages/salt/cli/call.py", line 58, in run
    caller.run()
  File "/usr/lib/python3/dist-packages/salt/cli/caller.py", line 112, in run
    ret = self.call()
  File "/usr/lib/python3/dist-packages/salt/cli/caller.py", line 220, in call
    self.opts, data, func, args, kwargs
  File "/usr/lib/python3/dist-packages/salt/loader.py", line 1235, in __call__
    return self.loader.run(run_func, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/salt/loader.py", line 2268, in run
    return self._last_context.run(self._run_as, _func_or_method, *args, **kwargs)
  File "/usr/lib/python3/dist-packages/salt/loader.py", line 2283, in _run_as
    return _func_or_method(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/salt/executors/direct_call.py", line 12, in execute
    return func(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/salt/modules/state.py", line 360, in orchestrate
    pillarenv=pillarenv,
  File "/usr/lib/python3/dist-packages/salt/runners/state.py", line 125, in orchestrate
    orchestration_jid=orchestration_jid,
  File "/usr/lib/python3/dist-packages/salt/modules/state.py", line 1343, in sls
    initial_pillar=_get_initial_pillar(opts),
  File "/usr/lib/python3/dist-packages/salt/state.py", line 4634, in __init__
    self.client = salt.fileclient.get_file_client(self.opts)
  File "/usr/lib/python3/dist-packages/salt/fileclient.py", line 55, in get_file_client
    )(opts)
  File "/usr/lib/python3/dist-packages/salt/fileclient.py", line 1422, in __init__
    self.channel = salt.fileserver.FSChan(opts)
  File "/usr/lib/python3/dist-packages/salt/fileserver/__init__.py", line 871, in __init__
    self.fs.update()
  File "/usr/lib/python3/dist-packages/salt/fileserver/__init__.py", line 486, in update
    self.servers[fstr](**kwargs)
  File "/usr/lib/python3/dist-packages/salt/fileserver/roots.py", line 161, in update
    for line in fp_:
  File "/usr/lib/python3.7/codecs.py", line 322, in decode
    (result, consumed) = self._buffer_decode(data, self.errors, final)
    client.run()
    caller.run()
    ret = self.call()
    )(opts)
    self.fs.update()
    for line in fp_:
dpkg: error processing package openmediavault (--configure):
 installed openmediavault package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of openmediavault-diskstats:
 openmediavault-diskstats depends on openmediavault (>= 5.6); however:
  Package openmediavault is not configured yet.
dpkg: error processing package openmediavault-diskstats (--configure):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
 openmediavault
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@helios64:~#
On OpenMediaVault, when I make a change in the settings and go for the validation (" The configuration has been changed. You must apply the changes in order for them to take effect. "), the procedure fails and I get this error message :
ERROR
Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; omv-salt deploy run --no-color cronapt 2>&1' with exit code '1': Traceback (most recent call last): File "/sbin/omv-salt", line 151, in <module> sys.exit(main()) File "/sbin/omv-salt", line 147, in main cli() File "/usr/lib/python3/dist-packages/click/core.py", line 764, in __call__ return self.main(*args, **kwargs) File "/usr/lib/python3/dist-packages/click/core.py", line 717, in main rv = self.invoke(ctx) File "/usr/lib/python3/dist-packages/click/core.py", line 1137, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "/usr/lib/python3/dist-packages/click/core.py", line 1137, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "/usr/lib/python3/dist-packages/click/core.py", line 956, in invoke return ctx.invoke(self.callback, **ctx.params) File "/usr/lib/python3/dist-packages/click/core.py", line 555, in invoke return callback(*args, **kwargs) File "/sbin/omv-salt", line 134, in deploy_run result = caller.cmd("state.orchestrate", names) File "/usr/lib/python3/dist-packages/salt/client/__init__.py", line 2122, in cmd return self.sminion.functions[fun](*args, **kwargs) File "/usr/lib/python3/dist-packages/salt/loader.py", line 1235, in __call__ return self.loader.run(run_func, *args, **kwargs) File "/usr/lib/python3/dist-packages/salt/loader.py", line 2268, in run return self._last_context.run(self._run_as, _func_or_method, *args, **kwargs) File "/usr/lib/python3/dist-packages/salt/loader.py", line 2283, in _run_as return _func_or_method(*args, **kwargs) File "/usr/lib/python3/dist-packages/salt/modules/state.py", line 360, in orchestrate pillarenv=pillarenv, File "/usr/lib/python3/dist-packages/salt/runners/state.py", line 125, in orchestrate orchestration_jid=orchestration_jid, File "/usr/lib/python3/dist-packages/salt/loader.py", line 1235, in __call__ return self.loader.run(run_func, *args, **kwargs) File "/usr/lib/python3/dist-packages/salt/loader.py", line 2268, in run return self._last_context.run(self._run_as, _func_or_method, *args, **kwargs) File "/usr/lib/python3/dist-packages/salt/loader.py", line 2283, in _run_as return _func_or_method(*args, **kwargs) File "/usr/lib/python3/dist-packages/salt/modules/state.py", line 1343, in sls initial_pillar=_get_initial_pillar(opts), File "/usr/lib/python3/dist-packages/salt/state.py", line 4634, in __init__ self.client = salt.fileclient.get_file_client(self.opts) File "/usr/lib/python3/dist-packages/salt/fileclient.py", line 55, in get_file_client )(opts) File "/usr/lib/python3/dist-packages/salt/fileclient.py", line 1422, in __init__ self.channel = salt.fileserver.FSChan(opts) File "/usr/lib/python3/dist-packages/salt/fileserver/__init__.py", line 871, in __init__ self.fs.update() File "/usr/lib/python3/dist-packages/salt/fileserver/__init__.py", line 486, in update self.servers[fstr](**kwargs) File "/usr/lib/python3/dist-packages/salt/loader.py", line 1235, in __call__ return self.loader.run(run_func, *args, **kwargs) File "/usr/lib/python3/dist-packages/salt/loader.py", line 2268, in run return self._last_context.run(self._run_as, _func_or_method, *args, **kwargs) File "/usr/lib/python3/dist-packages/salt/loader.py", line 2283, in _run_as return _func_or_method(*args, **kwargs) File "/usr/lib/python3/dist-packages/salt/fileserver/roots.py", line 161, in update for line in fp_: File "/usr/lib/python3.7/codecs.py", line 322, in decode (result, consumed) = self._buffer_decode(data, self.errors, final) UnicodeDecodeError: 'utf-8' codec can't decode byte 0x81 in position 0: invalid start byte
-------------------------------------------------------- details --------------------------------------------------
Error #0:
OMV\ExecException: Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; omv-salt deploy run --no-color cronapt 2>&1' with exit code '1': Traceback (most recent call last):
    sys.exit(main())
    cli()
    )(opts)
    self.fs.update()
    for line in fp_:
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x81 in position 0: invalid start byte in /usr/share/php/openmediavault/system/process.inc:195
Stack trace:
#0 /usr/share/php/openmediavault/engine/module/serviceabstract.inc(62): OMV\System\Process->execute()
#1 /usr/share/openmediavault/engined/rpc/config.inc(167): OMV\Engine\Module\ServiceAbstract->deploy()
#2 [internal function]: Engined\Rpc\Config->applyChanges(Array, Array)
#3 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
#4 /usr/share/php/openmediavault/rpc/serviceabstract.inc(149): OMV\Rpc\ServiceAbstract->callMethod('applyChanges', Array, Array)
#5 /usr/share/php/openmediavault/rpc/serviceabstract.inc(588): OMV\Rpc\ServiceAbstract->OMV\Rpc\{closure}('/tmp/bgstatusRG...', '/tmp/bgoutputmK...')
#6 /usr/share/php/openmediavault/rpc/serviceabstract.inc(159): OMV\Rpc\ServiceAbstract->execBgProc(Object(Closure))
#7 /usr/share/openmediavault/engined/rpc/config.inc(189): OMV\Rpc\ServiceAbstract->callMethodBg('applyChanges', Array, Array)
#8 [internal function]: Engined\Rpc\Config->applyChangesBg(Array, Array)
#9 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
#10 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\Rpc\ServiceAbstract->callMethod('applyChangesBg', Array, Array)
#11 /usr/sbin/omv-engined(537): OMV\Rpc\Rpc::call('Config', 'applyChangesBg', Array, Array, 1)
#12 {main}
Does anyone have any idea what is going on this time?
Link to comment
On the actual topic.
Has anyone been able to upgrade an OMV 5 installation from Buster to Bullseye?
OMV 5 seems to use pam_tally2 and this is no longer supported in the current version of libpam-modules 1.4.0-9.
You are supposed to change this, but I read at OMV that the change was/will be implemented in OMV 6.
Is it possible to work around this without upgrading to OMV6 or do I have to get in with an OMV 5 -> OMV 6 upgrade first and then bullseye?
Unfortunately OMV 6 is only in release candidate 1 status.
962728318_Bildschirmfoto2022-04-02um23_47_09.thumb.png.c2fdce8d13c399a9eec65f0d7aff8f29.png
edit:
the attempt to edit the files used by OMV 5 with pam_tally2 with pam_faillock.so unfortunately did not work, because OMV 5 still searches for the pam_tally2 and thus a login in the WebInterface is not possible afterwards.
Link to comment
@TDCroPower OMV release are tied to a specific Debian release OMV 5 is buster only, OMV6 bullseye. OMV 6 should be pretty stable, a rc is close to release. As for the upgrade from google I get
https://forum.openmediavault.org/index.php?thread/40927-omv-5-omv-6-upgrade/&postID=288759#post288759 and https://www.openmediavault.org/?p=3010
votdev:
OMV5 systems with version 5.6.18 or later can be upgraded via the command line tool omv-release-upgrade. Please note that this migration path has not yet been tested with many systems.
I cannot tell for certain but I believe  omv-release-upgrade also upgrades Debian from buster to bullseye.
Link to comment
Thank you @prahalfor digging into this !! @aprayoga@piter75 Could the emmc issue be solved now with this input ?
@ebin-dev @piter75
I believe the upstream fix https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/drivers/regulator/core.c?id=8a866d527ac0441c0eb14a991fa11358b476b11d will do the job (in 6.1-rc1 so to be expected in Armbian edge if you want to try EMMC anew when it lands). This is likely the same issue as before the bad commit I pointed at the code only called set_machine_constraints once.  Still, requires testing (I saw that a lot of rk339 boards removed hs400 in Armbian, maybe that will fix them all).
regulator: core: Resolve supply name earlier to prevent double-init
Previously, an unresolved regulator supply reference upon calling
regulator_register on an always-on or boot-on regulator caused
set_machine_constraints to be called twice.
This in turn may initialize the regulator twice, leading to voltage
glitches that are timing-dependent. A simple, unrelated configuration
change may be enough to hide this problem, only to be surfaced by
chance.
One such example is the SD-Card voltage regulator in a NanoPI R4S that
would not initialize reliably unless the registration flow was just
complex enough to allow the regulator to properly reset between calls.
Fix this by re-arranging regulator_register, trying resolve the
regulator's supply early enough that set_machine_constraints does not
need to be called twice.
Signed-off-by: Christian Kohlschütter <christian@kohlschutter.com>
Link: https://lore.kernel.org/r/20220818124646.6005-1-christian@kohlschutter.com
Note that this fix reintroduce the less critical bug that was fixed by the bad commit I pinpointed namely sysfs entries issues; This was also fixed in 6.1-rc1 by commit https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/drivers/regulator/core.c?id=520fb178212d1dd545ed0ed231df09111b30ab7e "regulator: core: Fix regulator supply registration with sysfs"
Link to comment
@piter75@ebin-dev Feel free to confirm the rockchip emmc phy pulldown dts indeed fixes emmc write in hs400es mode (I believe on most rk3399 boards, not only helios64).
Likely on kernel up and above 6.1 (for the regulator fixes).
Thanks to @RussianNeuroMancer I found:
arm64: dts: rockchip: add enable-strobe-pulldown to emmc phy on nanopi4 https://github.com/torvalds/linux/commit/463be3cb357dab7d7e4d8dcc7c15c642e10c5bef
and:
phy: rockchip: set pulldown for strobe line in dts https://github.com/torvalds/linux/commit/8b5c2b45b8f0a11c9072da0f7baf9ee986d3151e
which might be related to this emmc issue (as noted in the mainline patch in the rockchip kernel this emmc pulldown setting is always enabled while in mainline it is disabled by default).
This patch was introduced in 5.11 which might explain why even with the regulator issue fixed (the one I found by regression testing) with kernel above 5.11 I still had hs400 failing on me.
With this emmc_phy pulldown setting in the dts I can now write to the emmc in hs400es mode !
means one have to add "rockchip,enable-strobe-pulldown;" in the emmc_phy node for most boards
 arch/arm64/boot/dts/rockchip/rk3399-kobol-helios64.dts | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm64/boot/dts/rockchip/rk3399-kobol-helios64.dts b/arch/arm64/boot/dts/rockchip/rk3399-kobol-helios64.dts
index 69d76dea35d0..3c1965660fbd 100644
--- a/arch/arm64/boot/dts/rockchip/rk3399-kobol-helios64.dts
+++ b/arch/arm64/boot/dts/rockchip/rk3399-kobol-helios64.dts
@@ -436,10 +436,11 @@ &cpu_b0 {
 &cpu_b1 {
        cpu-supply = <&vdd_cpu_b>;
 &emmc_phy {
+       rockchip,enable-strobe-pulldown;
        status = "okay";
 &gmac {
        assigned-clocks = <&cru SCLK_RMII_SRC>;
@@ -965,13 +966,12 @@ &saradc {
 &sdhci {
        assigned-clock-rates = <150000000>;
        bus-width = <8>;
        mmc-hs200-1_8v;
-       // hs400 is broken on Helios64 since 5.10.60
-       // mmc-hs400-1_8v;
-       // mmc-hs400-enhanced-strobe;
+       mmc-hs400-1_8v;
+       mmc-hs400-enhanced-strobe;
        supports-emmc;
        non-removable;
        disable-wp;
        status = "okay";
        vqmmc-supply = <&vcc1v8_sys_s0>;
There is also the regulator fix.
Back then I bisected the first bad commit 06653ebc0ad2e0b7d799cd71a5c2933ed2fb7a66 which seems to have been a backport of the master branch to commit https://github.com/torvalds/linux/commit/98e48cd9283dbac0e1445ee780889f10b3d1db6a "regulator: core: resolve supply for boot-on/always-on regulators" introduced in 5.13.
I am pretty confident the regulator issues were fixed at least in linux 6.1.
Note that the emmc phy pulldown code was not backported to 5.10.y (https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/log/drivers/phy/rockchip/phy-rockchip-emmc.c?h=linux-5.10.y)
So I believe it was first included in 5.11.
I no longer have the following CQE errors when writing to emmc in hs400es mode:
[   18.985162] mmc1: running CQE recovery
[   18.988056] ------------[ cut here ]------------
[   18.988500] mmc1: cqhci: spurious TCN for tag 12
[   18.989019] WARNING: CPU: 0 PID: 269 at drivers/mmc/host/cqhci-core.c:787 cqhci_irq+0x4b4/0x640
[   18.989838] Modules linked in: quota_v2 quota_tree r8152 snd_soc_hdmi_codec ftdi_sio usbserial snd_soc_rockchip_i2s leds_pwm snd_soc_rockchip_pcm snd_soc_core snd_pcm_dmaengine snd_pcm pwm_fan gpio_charger snd_timer panfrost gpu_sched snd hantro_vpu(C) soundcore rockchip_vdec(C) v4l2_h264 rockchip_rga rockchip_iep videobuf2_dma_contig videobuf2_vmalloc videobuf2_dma_sg v4l2_mem2mem sg videobuf2_memops videobuf2_v4l2 videobuf2_common fusb302 videodev tcpm typec mc gpio_beeper cpufreq_dt nfsd dm_mod auth_rpcgss nfs_acl lockd grace ledtrig_netdev sunrpc lm75 ip_tables x_tables autofs4 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear raid10 uas realtek md_mod dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys
[   18.995876] CPU: 0 PID: 269 Comm: kworker/0:1H Tainted: G         C        5.15.29-rockchip64 #trunk.0010
[   18.996740] Hardware name: Helios64 (DT)
[   18.997104] Workqueue: kblockd blk_mq_run_work_fn
[   18.997555] pstate: 800000c5 (Nzcv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[   18.998182] pc : cqhci_irq+0x4b4/0x640
[   18.998537] lr : cqhci_irq+0x4b4/0x640
[   18.998880] sp : ffff800008003d10
[   18.999179] x29: ffff800008003d10 x28: ffff0000012b8e80 x27: ffff000004c2d580
[   18.999819] x26: ffff00000652fc98 x25: ffff8000094d0888 x24: ffff800009c975e8
[   19.000462] x23: ffff8000094f49c8 x22: 0000000000000002 x21: ffff000004c2d000
[   19.001107] x20: 000000000000000c x19: ffff00000652fc80 x18: 0000000000000010
[   19.001754] x17: ffff8000ee03c000 x16: ffff800008004000 x15: 00000000000002f6
[   19.002400] x14: ffff800008003a20 x13: 00000000ffffffea x12: ffff800009abfbc8
[   19.003047] x11: 0000000000000003 x10: ffff800009aa7b88 x9 : ffff800009aa7be0
[   19.003694] x8 : 0000000000017fe8 x7 : c0000000ffffefff x6 : 0000000000000001
[   19.004338] x5 : ffff8000ee03c000 x4 : 0000000000000000 x3 : 0000000000010004
[   19.004980] x2 : 0000000000010003 x1 : f94ce7e57b395a00 x0 : 0000000000000000
[   19.005623] Call trace:
[   19.005852]  cqhci_irq+0x4b4/0x640
[   19.006169]  sdhci_arasan_cqhci_irq+0x5c/0x88
[   19.006564]  sdhci_irq+0xcc/0x10c0
[   19.006876]  __handle_irq_event_percpu+0x60/0x250
[   19.007302]  handle_irq_event_percpu+0x38/0x90
[   19.007705]  handle_irq_event+0x48/0xe8
[   19.008058]  handle_fasteoi_irq+0xb8/0x148
[   19.008430]  handle_domain_irq+0x90/0xd8
[   19.008788]  gic_handle_irq+0xb8/0x138
[   19.009131]  call_on_irq_stack+0x28/0x50
[   19.009492]  do_interrupt_handler+0x58/0x68
[   19.009874]  el1_interrupt+0x30/0x78
[   19.010202]  el1h_64_irq_handler+0x18/0x28
[   19.010575]  el1h_64_irq+0x74/0x78
[   19.010889]  preempt_count_sub+0x34/0xc0
[   19.011251]  _raw_spin_unlock_irqrestore+0x20/0x40
[   19.011686]  sdhci_cqe_enable+0x130/0x228
[   19.012060]  sdhci_arasan_cqe_enable+0x94/0xb8
[   19.012465]  cqhci_request+0xd0/0x650
[   19.012808]  mmc_cqe_start_req+0xb4/0x198
[   19.013177]  mmc_blk_mq_issue_rq+0x494/0x9a8
[   19.013567]  mmc_mq_queue_rq+0x114/0x2b0
[   19.013928]  blk_mq_dispatch_rq_list+0x120/0x7e8
[   19.014355]  __blk_mq_sched_dispatch_requests+0xc4/0x1e0
[   19.014835]  blk_mq_sched_dispatch_requests+0x3c/0x78
[   19.015291]  __blk_mq_run_hw_queue+0x64/0xa0
[   19.015678]  blk_mq_run_work_fn+0x20/0x30
[   19.016042]  process_one_work+0x20c/0x4c8
[   19.016407]  worker_thread+0x48/0x478
[   19.016739]  kthread+0x138/0x150
[   19.017033]  ret_from_fork+0x10/0x20
[   19.017358] ---[ end trace 70e1eee6af816777 ]---
[   19.020419] mmc1: running CQE recovery
[   19.025922] mmc1: running CQE recovery
[   19.028135] blk_update_request: I/O error, dev mmcblk1, sector 1605640 op 0x1:(WRITE) flags 0x800 phys_seg 57 prio class 0
[   19.029190] Buffer I/O error on dev mmcblk1p1, logical block 196609, lost sync page write
[   19.029989] EXT4-fs error (device mmcblk1p1): ext4_check_bdev_write_error:218: comm sed: Error while async write back metadata
[   19.030191] Aborting journal on device mmcblk1p1-8.
[   19.032803] EXT4-fs (mmcblk1p1): Remounting filesystem read-only
[   19.033426] EXT4-fs error (device mmcblk1p1) in __ext4_new_inode:1136: Journal has aborted
Feel free to submit this patch to Armbian github or even to the mainline helios64 dts on your side.
Link to comment
On 12/15/2023 at 9:44 AM, ebin-dev said:
I will test if linux 6.6 will write to emmc with hs400 speeds with those amendments to the device tree.
6.6 might be unstable, you could try the armbian repo 6.2 , that is linux-image-edge-rockchip64,  linux-headers-edge-rockchip64 and linux-dtb-edge-rockchip64 at version 23.11.1 (mind if you have both current and edge kernel there are issues when a current upgrade is push while you have a edge version previously installed, this is an armbian packaging issue though. BUt for the matter of testing it is fine).
Then ssh to the helios64 and edit the current dts with "armbian-config > System > Dtc"
emmc_phy settings are in the  "phy@f780" node (the default editor is nano, you can search with Ctrl+W).
Add "
" under this node
then under the mmc@fe330000 node add:
mmc-hs400-1_8v;
confirm and reboot.
It could be that the pulldown setting is enough even before linux 6.1 (there were other core regulator fixes, but the most important one was added in 6.1), so you could try with lower kernel version.
root@helios64:~# hdparm -tT /dev/mmcblk0
/dev/mmcblk0:
 Timing cached reads:   1888 MB in  2.00 seconds = 944.72 MB/sec
 Timing buffered disk reads: 552 MB in  3.00 seconds = 183.86 MB/sec
Note that EMMC on 6.6.7 /dev/mmcblk0 and SD /dev/mmcblk1
hdparm -tT /dev/mmcblk1
/dev/mmcblk1:
 Timing cached reads:   1858 MB in  2.00 seconds = 930.17 MB/sec
 Timing buffered disk reads: 128 MB in  3.10 seconds =  41.34 MB/sec
Edited by prahal
add stats
Link to comment
