Do you have any ideas why I'm unable to make it working ?
Can you post the full dmesg up to where the mmc errors start happening. Also the contents of /proc/interrupts
Hi dgp,
Here is the relevant fragment of the log :
Dec 28 16:52:06 localhost kernel: [    0.000000] Booting Linux on physical CPU 0x0
Dec 28 16:52:06 localhost kernel: [    0.000000] Linux version 4.9.0+ (root@giroles-xps8300) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #22 SMP Tue Dec 27 16:44:16 EST 2016
Dec 28 16:52:06 localhost kernel: [    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
Dec 28 16:52:06 localhost kernel: [    0.000000] CPU: div instructions available: patching division code
Dec 28 16:52:06 localhost kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Dec 28 16:52:06 localhost kernel: [    0.000000] OF: fdt:Machine model: Xunlong Orange Pi One
Dec 28 16:52:06 localhost kernel: [    0.000000] cma: Reserved 16 MiB at 0x4f000000
Dec 28 16:52:06 localhost kernel: [    0.000000] Memory policy: Data cache writealloc
Dec 28 16:52:06 localhost kernel: [    0.000000] On node 0 totalpages: 65536
Dec 28 16:52:06 localhost kernel: [    0.000000] free_area_init_node: node 0, pgdat c0b560c0, node_mem_map cedb0000
Dec 28 16:52:06 localhost kernel: [    0.000000]   Normal zone: 576 pages used for memmap
Dec 28 16:52:06 localhost kernel: [    0.000000]   Normal zone: 0 pages reserved
Dec 28 16:52:06 localhost kernel: [    0.000000]   Normal zone: 65536 pages, LIFO batch:15
Dec 28 16:52:06 localhost kernel: [    0.000000] psci: probing for conduit method from DT.
Dec 28 16:52:06 localhost kernel: [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
Dec 28 16:52:06 localhost kernel: [    0.000000] percpu: Embedded 14 pages/cpu @ced5e000 s26240 r8192 d22912 u57344
Dec 28 16:52:06 localhost kernel: [    0.000000] pcpu-alloc: s26240 r8192 d22912 u57344 alloc=14*4096
Dec 28 16:52:06 localhost kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Dec 28 16:52:06 localhost kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 64960
Dec 28 16:52:06 localhost kernel: [    0.000000] Kernel command line: root=UUID=0b55372c-e62d-4cec-bb00-80abf5b781c9 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 cgroup_enable=memory swapac
count=1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=7 ubootpart=e7918822-01   sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=
16
Dec 28 16:52:06 localhost kernel: [    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
Dec 28 16:52:06 localhost kernel: [    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 28 16:52:06 localhost kernel: [    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Dec 28 16:52:06 localhost kernel: [    0.000000] Memory: 226940K/262144K available (6144K kernel code, 347K rwdata, 2600K rodata, 1024K init, 310K bss, 18820K reserved, 16384K cma-reserved, 0K highmem)
Dec 28 16:52:06 localhost kernel: [    0.000000] Virtual kernel memory layout:
Dec 28 16:52:06 localhost kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Dec 28 16:52:06 localhost kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Dec 28 16:52:06 localhost kernel: [    0.000000]     vmalloc : 0xd0800000 - 0xff800000   ( 752 MB)
Dec 28 16:52:06 localhost kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
Dec 28 16:52:06 localhost kernel: [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
Dec 28 16:52:06 localhost kernel: [    0.000000]     modules : 0xbf800000 - 0xbfe00000   (   6 MB)
Dec 28 16:52:06 localhost kernel: [    0.000000]       .text : 0xc0008000 - 0xc0700000   (7136 kB)
Dec 28 16:52:06 localhost kernel: [    0.000000]       .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
Dec 28 16:52:06 localhost kernel: [    0.000000]       .data : 0xc0b00000 - 0xc0b56cc0   ( 348 kB)
Dec 28 16:52:06 localhost kernel: [    0.000000]        .bss : 0xc0b58000 - 0xc0ba59d0   ( 311 kB)
Dec 28 16:52:06 localhost kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Dec 28 16:52:06 localhost kernel: [    0.000000] Hierarchical RCU implementation.
Dec 28 16:52:06 localhost kernel: [    0.000000]     Build-time adjustment of leaf fanout to 32.
Dec 28 16:52:06 localhost kernel: [    0.000000] NR_IRQS:16 nr_irqs:16 16
Dec 28 16:52:06 localhost kernel: [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
Dec 28 16:52:06 localhost kernel: [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
Dec 28 16:52:06 localhost kernel: [    0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
Dec 28 16:52:06 localhost kernel: [    0.000033] Switching to timer-based delay loop, resolution 41ns
Dec 28 16:52:06 localhost kernel: [    0.000494] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
Dec 28 16:52:06 localhost kernel: [    0.001222] Console: colour dummy device 80x30
Dec 28 16:52:06 localhost kernel: [    0.002253] console [tty1] enabled
Dec 28 16:52:06 localhost kernel: [    0.002316] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
Dec 28 16:52:06 localhost kernel: [    0.002388] pid_max: default: 32768 minimum: 301
Dec 28 16:52:06 localhost kernel: [    0.002781] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Dec 28 16:52:06 localhost kernel: [    0.002829] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Dec 28 16:52:06 localhost kernel: [    0.004190] CPU: Testing write buffer coherency: ok
Dec 28 16:52:06 localhost kernel: [    0.004789] CPU0: update cpu_capacity 1024
Dec 28 16:52:06 localhost kernel: [    0.004837] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Dec 28 16:52:06 localhost kernel: [    0.004913] Setting up static identity map for 0x40100000 - 0x4010004c
Dec 28 16:52:06 localhost kernel: [    0.018717] CPU1: update cpu_capacity 1024
Dec 28 16:52:06 localhost kernel: [    0.018729] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Dec 28 16:52:06 localhost kernel: [    0.029994] CPU2: update cpu_capacity 1024
Dec 28 16:52:06 localhost kernel: [    0.030004] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
Dec 28 16:52:06 localhost kernel: [    0.041300] CPU3: update cpu_capacity 1024
Dec 28 16:52:06 localhost kernel: [    0.041309] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Dec 28 16:52:06 localhost kernel: [    0.041441] Brought up 4 CPUs
Dec 28 16:52:06 localhost kernel: [    0.041669] SMP: Total of 4 processors activated (192.00 BogoMIPS).
Dec 28 16:52:06 localhost kernel: [    0.041708] CPU: All CPU(s) started in HYP mode.
Dec 28 16:52:06 localhost kernel: [    0.041741] CPU: Virtualization extensions available.
Dec 28 16:52:06 localhost kernel: [    0.043396] devtmpfs: initialized
Dec 28 16:52:06 localhost kernel: [    0.061729] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
Dec 28 16:52:06 localhost kernel: [    0.062494] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Dec 28 16:52:06 localhost kernel: [    0.063704] xor: measuring software checksum speed
Dec 28 16:52:06 localhost kernel: [    0.161075]    arm4regs  :   653.200 MB/sec
Dec 28 16:52:06 localhost kernel: [    0.261194]    8regs     :   406.000 MB/sec
Dec 28 16:52:06 localhost kernel: [    0.361311]    32regs    :   374.800 MB/sec
Dec 28 16:52:06 localhost kernel: [    0.461428]    neon      :   610.800 MB/sec
Dec 28 16:52:06 localhost kernel: [    0.461467] xor: using function: arm4regs (653.200 MB/sec)
Dec 28 16:52:06 localhost kernel: [    0.461659] pinctrl core: initialized pinctrl subsystem
Dec 28 16:52:06 localhost kernel: [    0.463438] NET: Registered protocol family 16
Dec 28 16:52:06 localhost kernel: [    0.465707] DMA: preallocated 256 KiB pool for atomic coherent allocations
Dec 28 16:52:06 localhost kernel: [    0.489085] cpuidle: using governor ladder
Dec 28 16:52:06 localhost kernel: [    0.529108] cpuidle: using governor menu
Dec 28 16:52:06 localhost kernel: [    0.530464] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
Dec 28 16:52:06 localhost kernel: [    0.530528] hw-breakpoint: maximum watchpoint size is 8 bytes.
Dec 28 16:52:06 localhost kernel: [    0.732074] raid6: int32x1  gen()    78 MB/s
Dec 28 16:52:06 localhost kernel: [    0.902233] raid6: int32x1  xor()    78 MB/s
Dec 28 16:52:06 localhost kernel: [    1.072523] raid6: int32x2  gen()   115 MB/s
Dec 28 16:52:06 localhost kernel: [    1.242751] raid6: int32x2  xor()    91 MB/s
Dec 28 16:52:06 localhost kernel: [    1.412969] raid6: int32x4  gen()   125 MB/s
Dec 28 16:52:06 localhost kernel: [    1.582941] raid6: int32x4  xor()    91 MB/s
Dec 28 16:52:06 localhost kernel: [    1.753531] raid6: int32x8  gen()   114 MB/s
Dec 28 16:52:06 localhost kernel: [    1.923284] raid6: int32x8  xor()    83 MB/s
Dec 28 16:52:06 localhost kernel: [    2.093535] raid6: neonx1   gen()   223 MB/s
Dec 28 16:52:06 localhost kernel: [    2.263823] raid6: neonx1   xor()   170 MB/s
Dec 28 16:52:06 localhost kernel: [    2.434057] raid6: neonx2   gen()   304 MB/s
Dec 28 16:52:06 localhost kernel: [    2.604159] raid6: neonx2   xor()   222 MB/s
Dec 28 16:52:06 localhost kernel: [    2.774371] raid6: neonx4   gen()   371 MB/s
Dec 28 16:52:06 localhost kernel: [    2.944581] raid6: neonx4   xor()   252 MB/s
Dec 28 16:52:06 localhost kernel: [    3.114871] raid6: neonx8   gen()   339 MB/s
Dec 28 16:52:06 localhost kernel: [    3.284970] raid6: neonx8   xor()   235 MB/s
Dec 28 16:52:06 localhost kernel: [    3.285008] raid6: using algorithm neonx4 gen() 371 MB/s
Dec 28 16:52:06 localhost kernel: [    3.285044] raid6: .... xor() 252 MB/s, rmw enabled
Dec 28 16:52:06 localhost kernel: [    3.285079] raid6: using intx1 recovery algorithm
Dec 28 16:52:06 localhost kernel: [    3.285476] reg-fixed-voltage usb0-vbus: could not find pctldev for node /soc/pinctrl@01f02c00/usb0_vbus_pin@0, deferring probe
Dec 28 16:52:06 localhost kernel: [    3.286738] reg-fixed-voltage vdd_wifi: could not find pctldev for node /soc/pinctrl@01c20800/vcc_wifi_pin@0, deferring probe
Dec 28 16:52:06 localhost kernel: [    3.287001] gpio-regulator gpio-regulator: could not find pctldev for node /soc/pinctrl@01f02c00/regulator_pins@0, deferring probe
Dec 28 16:52:06 localhost kernel: [    3.287927] SCSI subsystem initialized
Dec 28 16:52:06 localhost kernel: [    3.288317] libata version 3.00 loaded.
Dec 28 16:52:06 localhost kernel: [    3.288771] usbcore: registered new interface driver usbfs
Dec 28 16:52:06 localhost kernel: [    3.288914] usbcore: registered new interface driver hub
Dec 28 16:52:06 localhost kernel: [    3.289083] usbcore: registered new device driver usb
Dec 28 16:52:06 localhost kernel: [    3.289456] media: Linux media interface: v0.10
Dec 28 16:52:06 localhost kernel: [    3.289570] Linux video capture interface: v2.00
Dec 28 16:52:06 localhost kernel: [    3.289737] pps_core: LinuxPPS API ver. 1 registered
Dec 28 16:52:06 localhost kernel: [    3.289777] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Dec 28 16:52:06 localhost kernel: [    3.289865] PTP clock support registered
Dec 28 16:52:06 localhost kernel: [    3.293071] clocksource: Switched to clocksource arch_sys_counter
Dec 28 16:52:06 localhost kernel: [    3.311024] NET: Registered protocol family 2
Dec 28 16:52:06 localhost kernel: [    3.312174] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
Dec 28 16:52:06 localhost kernel: [    3.312270] TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
Dec 28 16:52:06 localhost kernel: [    3.312369] TCP: Hash tables configured (established 2048 bind 2048)
Dec 28 16:52:06 localhost kernel: [    3.312488] UDP hash table entries: 256 (order: 1, 8192 bytes)
Dec 28 16:52:06 localhost kernel: [    3.312571] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Dec 28 16:52:06 localhost kernel: [    3.312930] NET: Registered protocol family 1
Dec 28 16:52:06 localhost kernel: [    3.313715] RPC: Registered named UNIX socket transport module.
Dec 28 16:52:06 localhost kernel: [    3.313769] RPC: Registered udp transport module.
Dec 28 16:52:06 localhost kernel: [    3.313805] RPC: Registered tcp transport module.
Dec 28 16:52:06 localhost kernel: [    3.313840] RPC: Registered tcp NFSv4.1 backchannel transport module.
Dec 28 16:52:06 localhost kernel: [    3.314430] Trying to unpack rootfs image as initramfs...
Dec 28 16:52:06 localhost kernel: [    3.891457] Freeing initrd memory: 4972K (c9a5b000 - c9f36000)
Dec 28 16:52:06 localhost kernel: [    3.894740] futex hash table entries: 1024 (order: 4, 65536 bytes)
Dec 28 16:52:06 localhost kernel: [    3.895412] Initialise system trusted keyrings
Dec 28 16:52:06 localhost kernel: [    3.896049] workingset: timestamp_bits=14 max_order=16 bucket_order=2
Dec 28 16:52:06 localhost kernel: [    3.912763] zbud: loaded
Dec 28 16:52:06 localhost kernel: [    3.919899] NFS: Registering the id_resolver key type
Dec 28 16:52:06 localhost kernel: [    3.920002] Key type id_resolver registered
Dec 28 16:52:06 localhost kernel: [    3.920038] Key type id_legacy registered
Dec 28 16:52:06 localhost kernel: [    3.920088] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Dec 28 16:52:06 localhost kernel: [    3.920129] Installing knfsd (copyright © 1996 okir@monad.swb.de).
Dec 28 16:52:06 localhost kernel: [    3.923283] JFS: nTxBlock = 1939, nTxLock = 15518
Dec 28 16:52:06 localhost kernel: [    3.927472] SGI XFS with ACLs, security attributes, realtime, no debug enabled
Dec 28 16:52:06 localhost kernel: [    3.941934] Key type asymmetric registered
Dec 28 16:52:06 localhost kernel: [    3.942490] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
Dec 28 16:52:06 localhost kernel: [    3.942744] io scheduler noop registered
Dec 28 16:52:06 localhost kernel: [    3.942786] io scheduler deadline registered
Dec 28 16:52:06 localhost kernel: [    3.943632] io scheduler cfq registered (default)
Dec 28 16:52:06 localhost kernel: [    3.945085] sun4i-usb-phy 1c19400.phy: could not find pctldev for node /soc/pinctrl@01c20800/usb0_id_detect_pin@0, deferring probe
Dec 28 16:52:06 localhost kernel: [    3.954158] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
Dec 28 16:52:06 localhost kernel: [    3.957685] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
Dec 28 16:52:06 localhost kernel: [    4.074410] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
Dec 28 16:52:06 localhost kernel: [    4.079622] console [ttyS0] disabled
Dec 28 16:52:06 localhost kernel: [    4.099902] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 40, base_baud = 1500000) is a U6_16550A
Dec 28 16:52:06 localhost kernel: [    4.931236] console [ttyS0] enabled
Dec 28 16:52:06 localhost kernel: [    4.941881] brd: module loaded
Dec 28 16:52:06 localhost kernel: [    4.956945] loop: module loaded
Dec 28 16:52:06 localhost kernel: [    4.962196] libphy: Fixed MDIO Bus: probed
Dec 28 16:52:06 localhost kernel: [    4.969012] usbcore: registered new interface driver catc
Dec 28 16:52:06 localhost kernel: [    4.974600] usbcore: registered new interface driver kaweth
Dec 28 16:52:06 localhost kernel: [    4.980203] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
Dec 28 16:52:06 localhost kernel: [    4.987747] usbcore: registered new interface driver pegasus
Dec 28 16:52:06 localhost kernel: [    4.993543] usbcore: registered new interface driver rtl8150
Dec 28 16:52:06 localhost kernel: [    4.999368] usbcore: registered new interface driver r8152
Dec 28 16:52:06 localhost kernel: [    5.005002] usbcore: registered new interface driver lan78xx
Dec 28 16:52:06 localhost kernel: [    5.010801] usbcore: registered new interface driver asix
Dec 28 16:52:06 localhost kernel: [    5.016341] usbcore: registered new interface driver ax88179_178a
Dec 28 16:52:06 localhost kernel: [    5.022546] usbcore: registered new interface driver cdc_ether
Dec 28 16:52:06 localhost kernel: [    5.028507] usbcore: registered new interface driver cdc_eem
Dec 28 16:52:06 localhost kernel: [    5.034307] usbcore: registered new interface driver dm9601
Dec 28 16:52:06 localhost kernel: [    5.039990] usbcore: registered new interface driver sr9700
Dec 28 16:52:06 localhost kernel: [    5.045742] usbcore: registered new interface driver CoreChips
Dec 28 16:52:06 localhost kernel: [    5.051720] usbcore: registered new interface driver smsc75xx
Dec 28 16:52:06 localhost kernel: [    5.057666] usbcore: registered new interface driver smsc95xx
Dec 28 16:52:06 localhost kernel: [    5.063546] usbcore: registered new interface driver gl620a
Dec 28 16:52:06 localhost kernel: [    5.069230] usbcore: registered new interface driver net1080
Dec 28 16:52:06 localhost kernel: [    5.075033] usbcore: registered new interface driver plusb
Dec 28 16:52:06 localhost kernel: [    5.080635] usbcore: registered new interface driver rndis_host
Dec 28 16:52:06 localhost kernel: [    5.086704] usbcore: registered new interface driver cdc_subset
Dec 28 16:52:06 localhost kernel: [    5.092739] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
Dec 28 16:52:06 localhost kernel: [    5.100339] usbcore: registered new interface driver cdc_ncm
Dec 28 16:52:06 localhost kernel: [    5.106139] usbcore: registered new interface driver huawei_cdc_ncm
Dec 28 16:52:06 localhost kernel: [    5.112503] usbcore: registered new interface driver cdc_mbim
Dec 28 16:52:06 localhost kernel: [    5.118312] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec 28 16:52:06 localhost kernel: [    5.124883] ehci-platform: EHCI generic platform driver
Dec 28 16:52:06 localhost kernel: [    5.130835] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Dec 28 16:52:06 localhost kernel: [    5.137098] ohci-platform: OHCI generic platform driver
Dec 28 16:52:06 localhost kernel: [    5.143056] usbcore: registered new interface driver cdc_wdm
Dec 28 16:52:06 localhost kernel: [    5.148872] usbcore: registered new interface driver usb-storage
Dec 28 16:52:06 localhost kernel: [    5.156318] sun6i-rtc 1f00000.rtc: rtc core: registered rtc-sun6i as rtc0
Dec 28 16:52:06 localhost kernel: [    5.163191] sun6i-rtc 1f00000.rtc: RTC enabled
Dec 28 16:52:06 localhost kernel: [    5.167983] i2c /dev entries driver
Dec 28 16:52:06 localhost kernel: [    5.173541] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
Dec 28 16:52:06 localhost kernel: [    5.184042] sunxi-mmc 1c0f000.mmc: Got CD GPIO
Dec 28 16:52:06 localhost kernel: [    5.243116] sunxi-mmc 1c0f000.mmc: base:0xd0967000 irq:24
Dec 28 16:52:06 localhost kernel: [    5.250651] ledtrig-cpu: registered to indicate activity on CPUs
Dec 28 16:52:06 localhost kernel: [    5.256896] hidraw: raw HID events driver © Jiri Kosina
Dec 28 16:52:06 localhost kernel: [    5.262591] usbcore: registered new interface driver usbhid
Dec 28 16:52:06 localhost kernel: [    5.268228] usbhid: USB HID core driver
Dec 28 16:52:06 localhost kernel: [    5.272542] Initializing XFRM netlink socket
Dec 28 16:52:06 localhost kernel: [    5.278327] NET: Registered protocol family 10
Dec 28 16:52:06 localhost kernel: [    5.284623] NET: Registered protocol family 17
Dec 28 16:52:06 localhost kernel: [    5.289139] NET: Registered protocol family 15
Dec 28 16:52:06 localhost kernel: [    5.293721] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Dec 28 16:52:06 localhost kernel: [    5.306819] 8021q: 802.1Q VLAN Support v1.8
Dec 28 16:52:06 localhost kernel: [    5.311129] Key type dns_resolver registered
Dec 28 16:52:06 localhost kernel: [    5.316139] Registering SWP/SWPB emulation handler
Dec 28 16:52:06 localhost kernel: [    5.320185] mmc0: host does not support reading read-only switch, assuming write-enable
Dec 28 16:52:06 localhost kernel: [    5.322206] mmc0: new high speed SDHC card at address b368
Dec 28 16:52:06 localhost kernel: [    5.323389] mmcblk0: mmc0:b368       7.46 GiB
Dec 28 16:52:06 localhost kernel: [    5.325312]  mmcblk0: p1
Dec 28 16:52:06 localhost kernel: [    5.342672] registered taskstats version 1
Dec 28 16:52:06 localhost kernel: [    5.346839] Loading compiled-in X.509 certificates
Dec 28 16:52:06 localhost kernel: [    5.351812] zswap: loaded using pool lzo/zbud
Dec 28 16:52:06 localhost kernel: [    5.359097] Btrfs loaded, crc32c=crc32c-generic
Dec 28 16:52:06 localhost kernel: [    5.392087] Key type encrypted registered
Dec 28 16:52:06 localhost kernel: [    5.408852] ehci-platform 1c1a000.usb: EHCI Host Controller
Dec 28 16:52:06 localhost kernel: [    5.414606] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
Dec 28 16:52:06 localhost kernel: [    5.422977] ehci-platform 1c1a000.usb: irq 27, io mem 0x01c1a000
Dec 28 16:52:06 localhost kernel: [    5.463085] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
Dec 28 16:52:06 localhost kernel: [    5.469638] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Dec 28 16:52:06 localhost kernel: [    5.476493] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 28 16:52:06 localhost kernel: [    5.483784] usb usb1: Product: EHCI Host Controller
Dec 28 16:52:06 localhost kernel: [    5.488692] usb usb1: Manufacturer: Linux 4.9.0+ ehci_hcd
Dec 28 16:52:06 localhost kernel: [    5.494137] usb usb1: SerialNumber: 1c1a000.usb
Dec 28 16:52:06 localhost kernel: [    5.500025] hub 1-0:1.0: USB hub found
Dec 28 16:52:06 localhost kernel: [    5.503918] hub 1-0:1.0: 1 port detected
Dec 28 16:52:06 localhost kernel: [    5.509191] ehci-platform 1c1b000.usb: EHCI Host Controller
Dec 28 16:52:06 localhost kernel: [    5.514867] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
Dec 28 16:52:06 localhost kernel: [    5.522968] ehci-platform 1c1b000.usb: irq 29, io mem 0x01c1b000
Dec 28 16:52:06 localhost kernel: [    5.553095] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
Dec 28 16:52:06 localhost kernel: [    5.559542] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
Dec 28 16:52:06 localhost kernel: [    5.566406] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 28 16:52:06 localhost kernel: [    5.573703] usb usb2: Product: EHCI Host Controller
Dec 28 16:52:06 localhost kernel: [    5.578610] usb usb2: Manufacturer: Linux 4.9.0+ ehci_hcd
Dec 28 16:52:06 localhost kernel: [    5.584061] usb usb2: SerialNumber: 1c1b000.usb
Dec 28 16:52:06 localhost kernel: [    5.589664] hub 2-0:1.0: USB hub found
Dec 28 16:52:06 localhost kernel: [    5.593534] hub 2-0:1.0: 1 port detected
Dec 28 16:52:06 localhost kernel: [    5.598649] ehci-platform 1c1c000.usb: EHCI Host Controller
Dec 28 16:52:06 localhost kernel: [    5.604317] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 3
Dec 28 16:52:06 localhost kernel: [    5.612352] ehci-platform 1c1c000.usb: irq 31, io mem 0x01c1c000
Dec 28 16:52:06 localhost kernel: [    5.643094] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
Dec 28 16:52:06 localhost kernel: [    5.649521] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
Dec 28 16:52:06 localhost kernel: [    5.656381] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 28 16:52:06 localhost kernel: [    5.663674] usb usb3: Product: EHCI Host Controller
Dec 28 16:52:06 localhost kernel: [    5.668582] usb usb3: Manufacturer: Linux 4.9.0+ ehci_hcd
Dec 28 16:52:06 localhost kernel: [    5.674024] usb usb3: SerialNumber: 1c1c000.usb
Dec 28 16:52:06 localhost kernel: [    5.679600] hub 3-0:1.0: USB hub found
Dec 28 16:52:06 localhost kernel: [    5.683468] hub 3-0:1.0: 1 port detected
Dec 28 16:52:06 localhost kernel: [    5.688561] ehci-platform 1c1d000.usb: EHCI Host Controller
Dec 28 16:52:06 localhost kernel: [    5.694231] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 4
Dec 28 16:52:06 localhost kernel: [    5.702255] ehci-platform 1c1d000.usb: irq 33, io mem 0x01c1d000
Dec 28 16:52:06 localhost kernel: [    5.733093] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
Dec 28 16:52:06 localhost kernel: [    5.739519] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
Dec 28 16:52:06 localhost kernel: [    5.746378] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 28 16:52:06 localhost kernel: [    5.753672] usb usb4: Product: EHCI Host Controller
Dec 28 16:52:06 localhost kernel: [    5.758579] usb usb4: Manufacturer: Linux 4.9.0+ ehci_hcd
Dec 28 16:52:06 localhost kernel: [    5.764028] usb usb4: SerialNumber: 1c1d000.usb
Dec 28 16:52:06 localhost kernel: [    5.769599] hub 4-0:1.0: USB hub found
Dec 28 16:52:06 localhost kernel: [    5.773464] hub 4-0:1.0: 1 port detected
Dec 28 16:52:06 localhost kernel: [    6.573226] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
Dec 28 16:52:06 localhost kernel: [    6.579914] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 5
Dec 28 16:52:06 localhost kernel: [    6.587965] ohci-platform 1c1a400.usb: irq 28, io mem 0x01c1a400
Dec 28 16:52:06 localhost kernel: [    6.667428] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
Dec 28 16:52:06 localhost kernel: [    6.674291] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 28 16:52:06 localhost kernel: [    6.681560] usb usb5: Product: Generic Platform OHCI controller
Dec 28 16:52:06 localhost kernel: [    6.687533] usb usb5: Manufacturer: Linux 4.9.0+ ohci_hcd
Dec 28 16:52:06 localhost kernel: [    6.692961] usb usb5: SerialNumber: 1c1a400.usb
Dec 28 16:52:06 localhost kernel: [    6.698645] hub 5-0:1.0: USB hub found
Dec 28 16:52:06 localhost kernel: [    6.702487] hub 5-0:1.0: 1 port detected
Dec 28 16:52:06 localhost kernel: [    6.707636] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
Dec 28 16:52:06 localhost kernel: [    6.714346] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
Dec 28 16:52:06 localhost kernel: [    6.722376] ohci-platform 1c1b400.usb: irq 30, io mem 0x01c1b400
Dec 28 16:52:06 localhost kernel: [    6.797397] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
Dec 28 16:52:06 localhost kernel: [    6.804258] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 28 16:52:06 localhost kernel: [    6.811526] usb usb6: Product: Generic Platform OHCI controller
Dec 28 16:52:06 localhost kernel: [    6.817503] usb usb6: Manufacturer: Linux 4.9.0+ ohci_hcd
Dec 28 16:52:06 localhost kernel: [    6.822931] usb usb6: SerialNumber: 1c1b400.usb
Dec 28 16:52:06 localhost kernel: [    6.828631] hub 6-0:1.0: USB hub found
Dec 28 16:52:06 localhost kernel: [    6.832468] hub 6-0:1.0: 1 port detected
Dec 28 16:52:06 localhost kernel: [    6.837629] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
Dec 28 16:52:06 localhost kernel: [    6.844351] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
Dec 28 16:52:06 localhost kernel: [    6.852356] ohci-platform 1c1c400.usb: irq 32, io mem 0x01c1c400
Dec 28 16:52:06 localhost kernel: [    6.927389] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
Dec 28 16:52:06 localhost kernel: [    6.934250] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 28 16:52:06 localhost kernel: [    6.941519] usb usb7: Product: Generic Platform OHCI controller
Dec 28 16:52:06 localhost kernel: [    6.947495] usb usb7: Manufacturer: Linux 4.9.0+ ohci_hcd
Dec 28 16:52:06 localhost kernel: [    6.952922] usb usb7: SerialNumber: 1c1c400.usb
Dec 28 16:52:06 localhost kernel: [    6.958596] hub 7-0:1.0: USB hub found
Dec 28 16:52:06 localhost kernel: [    6.962438] hub 7-0:1.0: 1 port detected
Dec 28 16:52:06 localhost kernel: [    6.967599] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
Dec 28 16:52:06 localhost kernel: [    6.974318] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
Dec 28 16:52:06 localhost kernel: [    6.982355] ohci-platform 1c1d400.usb: irq 34, io mem 0x01c1d400
Dec 28 16:52:06 localhost kernel: [    7.057389] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
Dec 28 16:52:06 localhost kernel: [    7.064252] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 28 16:52:06 localhost kernel: [    7.071520] usb usb8: Product: Generic Platform OHCI controller
Dec 28 16:52:06 localhost kernel: [    7.077495] usb usb8: Manufacturer: Linux 4.9.0+ ohci_hcd
Dec 28 16:52:06 localhost kernel: [    7.082922] usb usb8: SerialNumber: 1c1d400.usb
Dec 28 16:52:06 localhost kernel: [    7.088624] hub 8-0:1.0: USB hub found
Dec 28 16:52:06 localhost kernel: [    7.092462] hub 8-0:1.0: 1 port detected
Dec 28 16:52:06 localhost kernel: [    7.097761] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
Dec 28 16:52:06 localhost kernel: [    7.105686] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
Dec 28 16:52:06 localhost kernel: [    7.111471] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 9
Dec 28 16:52:06 localhost kernel: [    7.119794] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002
Dec 28 16:52:06 localhost kernel: [    7.126654] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 28 16:52:06 localhost kernel: [    7.133948] usb usb9: Product: MUSB HDRC host driver
Dec 28 16:52:06 localhost kernel: [    7.138942] usb usb9: Manufacturer: Linux 4.9.0+ musb-hcd
Dec 28 16:52:06 localhost kernel: [    7.144394] usb usb9: SerialNumber: musb-hdrc.1.auto
Dec 28 16:52:06 localhost kernel: [    7.150521] hub 9-0:1.0: USB hub found
Dec 28 16:52:06 localhost kernel: [    7.154392] hub 9-0:1.0: 1 port detected
Dec 28 16:52:06 localhost kernel: [    7.205115] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
Dec 28 16:52:06 localhost kernel: [    7.423095] sunxi-mmc 1c10000.mmc: base:0xd09da000 irq:25
Dec 28 16:52:06 localhost kernel: [    7.429004] of_cfs_init
Dec 28 16:52:06 localhost kernel: [    7.431633] of_cfs_init: OK
Dec 28 16:52:06 localhost kernel: [    7.434689] vcc3v0: disabling
Dec 28 16:52:06 localhost kernel: [    7.437691] vcc5v0: disabling
Dec 28 16:52:06 localhost kernel: [    7.444324] Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
Dec 28 16:52:06 localhost kernel: [    7.453740] mmc1: new high speed SDIO card at address 0001
Dec 28 16:52:06 localhost kernel: [    7.569063] random: systemd-udevd: uninitialized urandom read (16 bytes read)
Dec 28 16:52:06 localhost kernel: [    7.577295] random: systemd-udevd: uninitialized urandom read (16 bytes read)
Dec 28 16:52:06 localhost kernel: [    7.578135] random: udevadm: uninitialized urandom read (16 bytes read)
Dec 28 16:52:06 localhost kernel: [    7.581079] random: udevadm: uninitialized urandom read (16 bytes read)
Dec 28 16:52:06 localhost kernel: [    7.581834] random: udevadm: uninitialized urandom read (16 bytes read)
Dec 28 16:52:06 localhost kernel: [    7.582558] random: udevadm: uninitialized urandom read (16 bytes read)
Dec 28 16:52:06 localhost kernel: [    7.583383] random: udevadm: uninitialized urandom read (16 bytes read)
Dec 28 16:52:06 localhost kernel: [    7.584136] random: udevadm: uninitialized urandom read (16 bytes read)
Dec 28 16:52:06 localhost kernel: [    7.584823] random: udevadm: uninitialized urandom read (16 bytes read)
Dec 28 16:52:06 localhost kernel: [    7.585628] random: udevadm: uninitialized urandom read (16 bytes read)
Dec 28 16:52:06 localhost kernel: [    9.541329] random: fast init done
Dec 28 16:52:06 localhost kernel: [   10.331644] random: crng init done
Dec 28 16:52:06 localhost kernel: [   14.070124] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
Dec 28 16:52:06 localhost kernel: [   15.799539] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
Dec 28 16:52:06 localhost kernel: [   17.154789] Adding 131068k swap on /var/swap.  Priority:-1 extents:1 across:131068k SSFS
Dec 28 16:52:06 localhost kernel: [   18.289766] input: r_gpio_keys as /devices/platform/r_gpio_keys/input/input0
Dec 28 16:52:06 localhost kernel: [   18.464444] thermal thermal_zone0: failed to read out thermal zone (-16)
Dec 28 16:52:06 localhost kernel: [   18.714166] xradio_wlan: unknown parameter 'macaddr' ignored
Dec 28 16:52:06 localhost kernel: [   19.006819] xradio_wlan mmc1:0001:1: missed interrupt
Dec 28 16:52:06 localhost kernel: [   19.008025] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Dec 28 16:52:06 localhost dbus-daemon[530]: Unknown username "whoopsie" in message bus configuration file
Dec 28 16:52:06 localhost haveged[280]: haveged: ver: 1.9.1; arch: generic; vend: ; build: (gcc 5.2.1 CTV); collect: 128K
Dec 28 16:52:06 localhost haveged[280]: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 9/40; sz: 15750/67900
Dec 28 16:52:06 localhost haveged[280]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 8.0003
Dec 28 16:52:06 localhost haveged[280]: haveged: fills: 0, generated: 0
Dec 28 16:52:06 localhost systemd[1]: Starting Network Manager...
Dec 28 16:52:06 localhost systemd[1]: Starting LSB: Load kernel modules needed to enable cpufreq scaling...
Dec 28 16:52:06 localhost systemd[1]: Starting LSB: Armbian gathering hardware information...
Dec 28 16:52:06 localhost systemd[1]: Started Regular background program processing daemon.
Dec 28 16:52:06 localhost cron[570]: (CRON) INFO (pidfile fd = 3)
Dec 28 16:52:06 localhost kernel: [   19.731986] libphy: 1c30000.ethernet: probed
Dec 28 16:52:06 localhost systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Dec 28 16:52:07 localhost systemd[1]: Started Daily Cleanup of Temporary Directories.
Dec 28 16:52:07 localhost systemd[1]: Reached target Timers.
Dec 28 16:52:07 localhost cron[570]: (CRON) INFO (Running @reboot jobs)
Dec 28 16:52:07 localhost systemd[1]: Started System Logging Service.
Dec 28 16:52:07 localhost kernel: [   19.833640] Generic PHY 1c30000.ethernet:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1c30000.ethernet:01, irq=-1)
Dec 28 16:52:07 localhost kernel: [   19.833661] sun8i-emac 1c30000.ethernet: device MAC address slot 0 02:20:fd:44:4f:fe
Dec 28 16:52:07 localhost kernel: [   19.834353] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Dec 28 16:52:07 localhost systemd[1]: Started Permit User Sessions.
Dec 28 16:52:07 localhost avahi-daemon[574]: Found user 'avahi' (UID 110) and group 'avahi' (GID 115).
Dec 28 16:52:07 localhost avahi-daemon[574]: Successfully dropped root privileges.
Dec 28 16:52:07 localhost armhwinfo[563]: [#033[0;32m ok #033[0m] Setting noop I/O scheduler for mmcblk0
Dec 28 16:52:07 localhost avahi-daemon[574]: avahi-daemon 0.6.32-rc starting up.
Dec 28 16:52:07 localhost avahi-daemon[574]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Dec 28 16:52:07 localhost avahi-daemon[574]: Successfully called chroot().
Dec 28 16:52:07 localhost avahi-daemon[574]: Successfully dropped remaining capabilities.
Dec 28 16:52:07 localhost avahi-daemon[574]: No service file found in /etc/avahi/services.
Dec 28 16:52:07 localhost avahi-daemon[574]: Network interface enumeration completed.
Dec 28 16:52:07 localhost avahi-daemon[574]: Server startup complete. Host name is orangepizero.local. Local service cookie is 352237620.
Dec 28 16:52:07 localhost systemd[1]: Started Raise network interfaces.
Dec 28 16:52:07 localhost systemd[1]: Started LSB: Starts LIRC daemon..
Dec 28 16:52:07 localhost systemd[1]: Started LSB: Start/stop sysstat's sadc.
Dec 28 16:52:07 localhost loadcpufreq[553]:  * Loading cpufreq kernel modules...
Dec 28 16:52:07 localhost loadcpufreq[553]:    ...done.
Dec 28 16:52:07 localhost systemd[1]: Started LSB: Load kernel modules needed to enable cpufreq scaling.
Dec 28 16:52:07 localhost NetworkManager[544]: <info>  [1482961927.6589] NetworkManager (version 1.2.2) is starting...
Dec 28 16:52:07 localhost NetworkManager[544]: <info>  [1482961927.6603] Read config: /etc/NetworkManager/NetworkManager.conf (etc: default-wifi-powersave-on.conf)
Dec 28 16:52:07 localhost NetworkManager[544]: <info>  [1482961927.6944] manager[0x22f108]: monitoring kernel firmware directory '/lib/firmware'.
Dec 28 16:52:07 localhost NetworkManager[544]: <info>  [1482961927.6947] monitoring ifupdown state file '/run/network/ifstate'.
Dec 28 16:52:07 localhost NetworkManager[544]: <info>  [1482961927.7100] dns-mgr[0x222210]: set resolv-conf-mode: dnsmasq, plugin="dnsmasq"
Dec 28 16:52:07 localhost NetworkManager[544]: <info>  [1482961927.7102] dns-mgr[0x222210]: using resolv.conf manager 'resolvconf'
Dec 28 16:52:07 localhost NetworkManager[544]: <info>  [1482961927.7176] rfkill0: found WiFi radio killswitch (at /sys/devices/platform/soc/1c10000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/ieee80211/phy0/
rfkill0) (driver xradio_wlan)
Dec 28 16:52:07 localhost dbus[530]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Dec 28 16:52:07 localhost systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Dec 28 16:52:07 localhost systemd[1]: Started Network Manager.
Dec 28 16:52:08 localhost systemd[1]: Started Login Service.
Dec 28 16:52:08 localhost systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 28 16:52:08 localhost systemd[1]: Starting Network Manager Wait Online...
Dec 28 16:52:08 localhost systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec 28 16:52:08 localhost dbus[530]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dec 28 16:52:08 localhost systemd[1]: Starting LSB: set CPUFreq kernel parameters...
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1513] init!
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1541] guessed connection type (wlan0) = 802-11-wireless
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1547] update_connection_setting_from_if_block: name:wlan0, type:802-11-wireless, id:Ifupdown (wlan0), uuid: 5391eba4-6426-faca-338e-5828
034ff9d1
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1548] update wireless settings (wlan0).
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1554] setting wpa ssid = 15
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1557] update wireless security settings (wlan0).
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1562] setting wpa security key: psk=<omitted>
Dec 28 16:52:08 localhost NetworkManager[544]: <warn>  [1482961928.1570] nm-ifupdown-connection.c.52 - invalid connection read from /etc/network/interfaces: 802-11-wireless-security.key-mgmt: property is
 missing
Dec 28 16:52:08 localhost dbus[530]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1579] adding iface wlan0 to eni_ifaces
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1581] management mode: unmanaged
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1613] devices added (path: /sys/devices/platform/soc/1c10000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/net/wlan0, iface: wlan0)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1615] devices added (path: /sys/devices/platform/soc/1c30000.ethernet/net/eth0, iface: eth0)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1616] device added (path: /sys/devices/platform/soc/1c30000.ethernet/net/eth0, iface: eth0): no ifupdown configuration found.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1617] devices added (path: /sys/devices/virtual/net/lo, iface: lo)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1618] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1619] end _init.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1621] settings: loaded plugin ifupdown: © 2008 Canonical Ltd.  To report bugs please use the NetworkManager mailing list. (/usr/lib/ar
m-linux-gnueabihf/NetworkManager/libnm-settings-plugin-ifupdown.so)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1625] settings: loaded plugin keyfile: © 2007 - 2015 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
Dec 28 16:52:08 localhost systemd[1]: Started ifup for wlan0.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1684] SettingsPlugin-Ofono: init!
Dec 28 16:52:08 localhost NetworkManager[544]: <warn>  [1482961928.1689] SettingsPlugin-Ofono: file doesn't exist: /var/lib/ofono
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1690] SettingsPlugin-Ofono: end _init.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1692] settings: loaded plugin ofono: © 2013-2016 Canonical Ltd.  To report bugs please use the NetworkManager mailing list. (/usr/lib/
arm-linux-gnueabihf/NetworkManager/libnm-settings-plugin-ofono.so)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1693] (2372912) ... get_connections.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1694] (2372912) ... get_connections (managed=false): return empty list.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1711] SettingsPlugin-Ofono: (2411824) ... get_connections.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1713] SettingsPlugin-Ofono: (2411824) connections count: 0
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.1717] get unmanaged devices count: 1
Dec 28 16:52:08 localhost systemd[1]: Reached target Network.
Dec 28 16:52:08 localhost systemd[1]: Starting OpenBSD Secure Shell server...
Dec 28 16:52:08 localhost systemd[1]: Starting Set console scheme...
Dec 28 16:52:08 localhost systemd[1]: Started Set console scheme.
Dec 28 16:52:08 localhost systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 28 16:52:08 localhost wpa_supplicant[643]: Successfully initialized wpa_supplicant
Dec 28 16:52:08 localhost cpufrequtils[625]:  * CPUFreq Utilities: Setting schedutil CPUFreq governor...
Dec 28 16:52:08 localhost systemd[1]: Starting Hostname Service...
Dec 28 16:52:08 localhost cpufrequtils[625]:  * CPU0...
Dec 28 16:52:08 localhost kernel: [   21.175643] ieee80211 phy0: Interface ID:0 of type:2 added
Dec 28 16:52:08 localhost kernel: [   21.176444] ieee80211 phy0: configuring tx for vif 0
Dec 28 16:52:08 localhost kernel: [   21.176863] ieee80211 phy0: configuring tx for vif 0
Dec 28 16:52:08 localhost kernel: [   21.177147] ieee80211 phy0: configuring tx for vif 0
Dec 28 16:52:08 localhost kernel: [   21.177476] ieee80211 phy0: configuring tx for vif 0
Dec 28 16:52:08 localhost kernel: [   21.177928] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (1)IEEE80211_CONF_CHANGE_IDLE (1)
Dec 28 16:52:08 localhost kernel: [   21.178134] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Dec 28 16:52:08 localhost systemd[1]: Starting Load/Save RF Kill Switch Status...
Dec 28 16:52:08 localhost cpufrequtils[625]:  * CPU1...
Dec 28 16:52:08 localhost cpufrequtils[625]:  * CPU2...
Dec 28 16:52:08 localhost systemd-rfkill[651]: Failed to parse state file /var/lib/systemd/rfkill/platform-1c10000.mmc:wlan: Invalid argument
Dec 28 16:52:08 localhost systemd[1]: Started Load/Save RF Kill Switch Status.
Dec 28 16:52:08 localhost cpufrequtils[625]:  * CPU3...
Dec 28 16:52:08 localhost cpufrequtils[625]:    ...done.
Dec 28 16:52:08 localhost systemd[1]: Started LSB: set CPUFreq kernel parameters.
Dec 28 16:52:08 localhost dbus[530]: [system] Successfully activated service 'org.freedesktop.hostname1'
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5510] settings: hostname: using hostnamed
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5513] settings: hostname changed from (none) to "orangepizero"
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5539] Using DHCP client 'dhclient'
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5542] manager: WiFi enabled by radio killswitch; enabled by state file
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5547] manager: WWAN enabled by radio killswitch; enabled by state file
Dec 28 16:52:08 localhost nm-dispatcher: find-scripts: Cannot execute '/etc/NetworkManager/dispatcher.d/99disable-power-management': not executable by owner.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5550] manager: Networking is enabled by state file
Dec 28 16:52:08 localhost nm-dispatcher: req:1 'hostname': new request (1 scripts)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5556] Loaded device plugin: NMVxlanFactory (internal)
Dec 28 16:52:08 localhost nm-dispatcher: req:1 'hostname': start running ordered scripts...
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5561] Loaded device plugin: NMVlanFactory (internal)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5564] Loaded device plugin: NMVethFactory (internal)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5567] Loaded device plugin: NMTunFactory (internal)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5571] Loaded device plugin: NMMacvlanFactory (internal)
Dec 28 16:52:08 localhost systemd[1]: Started OpenBSD Secure Shell server.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5575] Loaded device plugin: NMIPTunnelFactory (internal)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5578] Loaded device plugin: NMInfinibandFactory (internal)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5582] Loaded device plugin: NMEthernetFactory (internal)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5586] Loaded device plugin: NMBridgeFactory (internal)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5591] Loaded device plugin: NMBondFactory (internal)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.5882] Loaded device plugin: NMAtmManager (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-adsl.so)
Dec 28 16:52:08 localhost systemd[1]: Started Hostname Service.
Dec 28 16:52:08 localhost systemd[1]: Starting LSB: Set sysfs variables from /etc/sysfs.conf...
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.6706] Loaded device plugin: NMWwanFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-wwan.so)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.7051] Loaded device plugin: NMBluezManager (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-bluetooth.so)
Dec 28 16:52:08 localhost sysfsutils[669]:  * Setting sysfs variables...
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.7274] Loaded device plugin: NMWifiFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-wifi.so)
Dec 28 16:52:08 localhost NetworkManager[544]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed
Dec 28 16:52:08 localhost sysfsutils[669]:    ...done.
Dec 28 16:52:08 localhost systemd[1]: Started LSB: Set sysfs variables from /etc/sysfs.conf.
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.7423] device (lo): link connected
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.7509] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/0)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.7706] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/1)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.7846] keyfile: add connection in-memory (0ff4c08f-fdb2-3dcd-be2c-e3a7dc835b7f,"Wired connection 1")
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.7972] settings: (eth0): created default wired connection 'Wired connection 1'
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.8119] device (eth0): state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.8223] (wlan0): using nl80211 for WiFi device control
Dec 28 16:52:08 localhost kernel: [   21.575478] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.8250] device (wlan0): driver supports Access Point (AP) mode
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.8359] manager: (wlan0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/2)
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.8487] manager: NetworkManager state is now CONNECTED_GLOBAL
Dec 28 16:52:08 localhost dhclient[679]: Internet Systems Consortium DHCP Client 4.3.3
Dec 28 16:52:08 localhost sh[628]: Internet Systems Consortium DHCP Client 4.3.3
Dec 28 16:52:08 localhost sh[628]: Copyright 2004-2015 Internet Systems Consortium.
Dec 28 16:52:08 localhost sh[628]: All rights reserved.
Dec 28 16:52:08 localhost sh[628]: For info, please visit https://www.isc.org/software/dhcp/
Dec 28 16:52:08 localhost systemd[1]: Starting Authenticate and Authorize Users to Run Privileged Tasks...
Dec 28 16:52:08 localhost dhclient[679]: Copyright 2004-2015 Internet Systems Consortium.
Dec 28 16:52:08 localhost dhclient[679]: All rights reserved.
Dec 28 16:52:08 localhost dhclient[679]: For info, please visit https://www.isc.org/software/dhcp/
Dec 28 16:52:08 localhost dbus[530]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkitd.service'
Dec 28 16:52:08 localhost dbus[530]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service'
Dec 28 16:52:08 localhost systemd[1]: Starting WPA supplicant...
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.9450] urfkill disappeared from the bus
Dec 28 16:52:08 localhost NetworkManager[544]: <info>  [1482961928.9626] ofono is now available
Dec 28 16:52:08 localhost NetworkManager[544]: <warn>  [1482961928.9739] failed to enumerate oFono devices: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by a
ny .service files
Dec 28 16:52:08 localhost dbus[530]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Dec 28 16:52:08 localhost dhclient[679]: Listening on LPF/wlan0/dc:44:6d:c0:ff:ee
Dec 28 16:52:08 localhost sh[628]: Listening on LPF/wlan0/dc:44:6d:c0:ff:ee
Dec 28 16:52:08 localhost sh[628]: Sending on   LPF/wlan0/dc:44:6d:c0:ff:ee
Dec 28 16:52:08 localhost sh[628]: Sending on   Socket/fallback
Dec 28 16:52:08 localhost sh[628]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3 (xid=0x2d2c680a)
Dec 28 16:52:08 localhost dhclient[679]: Sending on   LPF/wlan0/dc:44:6d:c0:ff:ee
Dec 28 16:52:08 localhost systemd[1]: Started WPA supplicant.
Dec 28 16:52:08 localhost dhclient[679]: Sending on   Socket/fallback
Dec 28 16:52:09 localhost dhclient[679]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3 (xid=0x2d2c680a)
Dec 28 16:52:09 localhost wpa_supplicant[685]: Successfully initialized wpa_supplicant
Dec 28 16:52:09 localhost NetworkManager[544]: <info>  [1482961929.0016] supplicant: wpa_supplicant running
Dec 28 16:52:09 localhost polkitd[682]: started daemon version 0.105 using authority implementation `local' version `0.105'
Dec 28 16:52:09 localhost dbus[530]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Dec 28 16:52:09 localhost systemd[1]: Started Authenticate and Authorize Users to Run Privileged Tasks.
Dec 28 16:52:09 localhost NetworkManager[544]: <info>  [1482961929.1756] device (eth0): link connected
Dec 28 16:52:09 localhost NetworkManager[544]: <info>  [1482961929.1799] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed') [20 30 40]
Dec 28 16:52:09 localhost kernel: [   21.933901] sun8i-emac 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Dec 28 16:52:09 localhost kernel: [   21.933955] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Dec 28 16:52:09 localhost NetworkManager[544]: <info>  [1482961929.1924] policy: auto-activating connection 'Wired connection 1'
Dec 28 16:52:09 localhost NetworkManager[544]: <info>  [1482961929.2116] device (eth0): Activation: starting connection 'Wired connection 1' (0ff4c08f-fdb2-3dcd-be2c-e3a7dc835b7f)
Dec 28 16:52:09 localhost armhwinfo[563]: [#033[0;32m ok #033[0m] Starting ARM hardware info:  (5.24.161226)
Dec 28 16:52:09 localhost NetworkManager[544]: <info>  [1482961929.2467] device (eth0): state change: disconnected -> prepare (reason 'none') [30 40 0]
Dec 28 16:52:09 localhost NetworkManager[544]: <info>  [1482961929.2547] device (eth0): state change: prepare -> config (reason 'none') [40 50 0]
Dec 28 16:52:09 localhost NetworkManager[544]: <info>  [1482961929.2601] device (eth0): state change: config -> ip-config (reason 'none') [50 70 0]
Dec 28 16:52:09 localhost NetworkManager[544]: <info>  [1482961929.2694] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Dec 28 16:52:09 localhost wpa_supplicant[657]: wlan0: SME: Trying to authenticate with 9c:d6:43:cd:bd:c6 (SSID='Giroles-Salon' freq=2462 MHz)
Dec 28 16:52:09 localhost kernel: [   22.415348] wlan0: authenticate with 9c:d6:43:cd:bd:c6
Dec 28 16:52:09 localhost kernel: [   22.415421] ieee80211 phy0: ignore IEEE80211_CONF_CHANGE_MONITOR (0)IEEE80211_CONF_CHANGE_IDLE (1)
Dec 28 16:52:09 localhost kernel: [   22.415434] ieee80211 phy0: Freq 2462 (wsm ch: 11).
Dec 28 16:52:09 localhost kernel: [   22.417892] wlan0: send auth to 9c:d6:43:cd:bd:c6 (try 1/3)
Dec 28 16:52:09 localhost kernel: [   22.482209] wlan0: authenticated
Dec 28 16:52:09 localhost wpa_supplicant[657]: wlan0: Trying to associate with 9c:d6:43:cd:bd:c6 (SSID='Giroles-Salon' freq=2462 MHz)
Dec 28 16:52:09 localhost kernel: [   22.482830] xradio_wlan mmc1:0001:1 wlan0: disabling HT as WMM/QoS is not supported by the AP
Dec 28 16:52:09 localhost kernel: [   22.482844] xradio_wlan mmc1:0001:1 wlan0: disabling VHT as WMM/QoS is not supported by the AP
Dec 28 16:52:09 localhost kernel: [   22.483223] wlan0: associate with 9c:d6:43:cd:bd:c6 (try 1/3)
Dec 28 16:52:09 localhost kernel: [   22.486220] wlan0: RX AssocResp from 9c:d6:43:cd:bd:c6 (capab=0x431 status=0 aid=18)
Dec 28 16:52:09 localhost kernel: [   22.486308] ieee80211 phy0: configuring tx for vif 0
Dec 28 16:52:09 localhost kernel: [   22.487233] ieee80211 phy0: configuring tx for vif 0
Dec 28 16:52:09 localhost kernel: [   22.488263] ieee80211 phy0: configuring tx for vif 0
Dec 28 16:52:09 localhost kernel: [   22.489138] ieee80211 phy0: configuring tx for vif 0
Dec 28 16:52:09 localhost kernel: [   22.494366] wlan0: associated
Dec 28 16:52:09 localhost kernel: [   22.494585] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Dec 28 16:52:09 localhost wpa_supplicant[657]: wlan0: Associated with 9c:d6:43:cd:bd:c6
Dec 28 16:52:09 localhost kernel: [   22.563200] xradio_wlan mmc1:0001:1: received frame has no key status
Dec 28 16:52:09 localhost kernel: [   22.563395] xradio_wlan mmc1:0001:1: received frame has no key status
Dec 28 16:52:09 localhost kernel: [   22.666481] xradio_wlan mmc1:0001:1: received frame has no key status
Dec 28 16:52:09 localhost kernel: [   22.666763] xradio_wlan mmc1:0001:1: received frame has no key status
Dec 28 16:52:09 localhost wpa_supplicant[657]: wlan0: WPA: Key negotiation completed with 9c:d6:43:cd:bd:c6 [PTK=CCMP GTK=TKIP]
Dec 28 16:52:09 localhost wpa_supplicant[657]: wlan0: CTRL-EVENT-CONNECTED - Connection to 9c:d6:43:cd:bd:c6 completed [id=0 id_str=]
Dec 28 16:52:09 localhost kernel: [   22.740482] ieee80211 phy0: vif 0: set_key cmd 0
Dec 28 16:52:09 localhost kernel: [   22.740505] ieee80211 phy0: CCMP_PAIRWISE keylen=16!
Dec 28 16:52:09 localhost kernel: [   22.741421] ieee80211 phy0: vif 0: set_key cmd 0
Dec 28 16:52:09 localhost kernel: [   22.741437] ieee80211 phy0: TKIP_GROUP keylen=32!
Dec 28 16:52:09 localhost NetworkManager[544]: <info>  [1482961929.9900] dhcp4 (eth0): dhclient started with pid 732
Dec 28 16:52:10 localhost dhclient[732]: DHCPREQUEST of 10.111.111.37 on eth0 to 255.255.255.255 port 67 (xid=0x23c0f8d1)
Dec 28 16:52:10 localhost dhclient[732]: DHCPACK of 10.111.111.37 from 10.111.111.1
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.1774]   address 10.111.111.37
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.1803]   plen 24 (255.255.255.0)
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.1807]   gateway 10.111.111.251
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.1808]   server identifier 10.111.111.1
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.1810]   lease time 86400
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.1813]   nameserver '205.151.67.6'
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.1814]   nameserver '205.151.67.2'
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.1816]   nameserver '10.111.111.251'
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.1817]   domain name 'cgocable.com'
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.1819] dhcp4 (eth0): state changed unknown -> bound
Dec 28 16:52:10 localhost avahi-daemon[574]: Joining mDNS multicast group on interface eth0.IPv4 with address 10.111.111.37.
Dec 28 16:52:10 localhost avahi-daemon[574]: New relevant interface eth0.IPv4 for mDNS.
Dec 28 16:52:10 localhost avahi-daemon[574]: Registering new address record for 10.111.111.37 on eth0.IPv4.
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.2130] device (eth0): state change: ip-config -> ip-check (reason 'none') [70 80 0]
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.2787] device (eth0): state change: ip-check -> secondaries (reason 'none') [80 90 0]
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.2846] device (eth0): state change: secondaries -> activated (reason 'none') [90 100 0]
Dec 28 16:52:10 localhost dhclient[732]: bound to 10.111.111.37 -- renewal in 32415 seconds.
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.9035] policy: set 'Wired connection 1' (eth0) as default for IPv4 routing and DNS
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.9129] dns-plugin[0x227b70]: starting dnsmasq...
Dec 28 16:52:10 localhost NetworkManager[544]: <info>  [1482961930.9396] dns-mgr: Writing DNS information to /sbin/resolvconf
Dec 28 16:52:10 localhost dnsmasq[746]: started, version 2.75 cache disabled
Dec 28 16:52:10 localhost dnsmasq[746]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Dec 28 16:52:10 localhost dnsmasq[746]: DBus support enabled: connected to system bus
Dec 28 16:52:10 localhost dnsmasq[746]: warning: no upstream servers configured
Dec 28 16:52:11 localhost systemd[1]: Started LSB: Armbian gathering hardware information.
Dec 28 16:52:11 localhost NetworkManager[544]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /run/resolvconf/resolv.conf
Dec 28 16:52:11 localhost NetworkManager[544]: <info>  [1482961931.1340] device (eth0): Activation: successful, device activated.
Dec 28 16:52:11 localhost nm-dispatcher: find-scripts: Cannot execute '/etc/NetworkManager/dispatcher.d/99disable-power-management': not executable by owner.
Dec 28 16:52:11 localhost nm-dispatcher: req:2 'up' [eth0]: new request (1 scripts)
Dec 28 16:52:11 localhost nm-dispatcher: req:2 'up' [eth0]: start running ordered scripts...
Dec 28 16:52:11 localhost NetworkManager[544]: <info>  [1482961931.1720] dnsmasq[0x227b70]: dnsmasq appeared as :1.9
Dec 28 16:52:11 localhost dnsmasq[746]: setting upstream servers from DBus
Dec 28 16:52:11 localhost dnsmasq[746]: using nameserver 205.151.67.6#53
Dec 28 16:52:11 localhost dnsmasq[746]: using nameserver 205.151.67.2#53
Dec 28 16:52:11 localhost dnsmasq[746]: using nameserver 10.111.111.251#53
Dec 28 16:52:11 localhost avahi-daemon[574]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::de44:6dff:fec0:ffee.
Dec 28 16:52:11 localhost avahi-daemon[574]: New relevant interface wlan0.IPv6 for mDNS.
Dec 28 16:52:11 localhost avahi-daemon[574]: Registering new address record for fe80::de44:6dff:fec0:ffee on wlan0.*.
Dec 28 16:52:11 localhost avahi-daemon[574]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9d08:68e:5df8:7740.
Dec 28 16:52:11 localhost avahi-daemon[574]: New relevant interface eth0.IPv6 for mDNS.
Dec 28 16:52:11 localhost avahi-daemon[574]: Registering new address record for fe80::9d08:68e:5df8:7740 on eth0.*.
Dec 28 16:52:11 localhost dhclient[679]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8 (xid=0x2d2c680a)
Dec 28 16:52:11 localhost sh[628]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8 (xid=0x2d2c680a)
Dec 28 16:52:14 localhost NetworkManager[544]: <info>  [1482961934.2667] manager: startup complete
Dec 28 16:52:14 localhost systemd[1]: Started Network Manager Wait Online.
Dec 28 16:52:14 localhost systemd[1]: Reached target Network is Online.
Dec 28 16:52:14 localhost systemd[1]: Starting LSB: disk temperature monitoring daemon...
Dec 28 16:52:14 localhost systemd[1]: Starting LSB: Start NTP daemon...
Dec 28 16:52:14 localhost systemd[1]: Starting LSB: Advanced IEEE 802.11 management daemon...
Dec 28 16:52:14 localhost systemd[1]: Starting /etc/rc.local Compatibility...
Dec 28 16:52:15 localhost systemd[1]: Started LSB: Advanced IEEE 802.11 management daemon.
Dec 28 16:52:15 localhost systemd[1]: Started LSB: disk temperature monitoring daemon.
Dec 28 16:52:17 localhost kernel: [   30.681890] ------------[ cut here ]------------
Dec 28 16:52:17 localhost kernel: [   30.681964] WARNING: CPU: 0 PID: 812 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x4b/0x58
Dec 28 16:52:17 localhost kernel: [   30.681979] sysfs: cannot create duplicate filename '/devices/platform/soc/1c2b000.i2c'
Dec 28 16:52:17 localhost kernel: [   30.681991] Modules linked in: ccm evdev xradio_wlan mac80211 cfg80211 rfkill sun8i_ths uio_pdrv_genirq cpufreq_dt uio gpio_keys thermal_sys
Dec 28 16:52:17 localhost kernel: [   30.682201] CPU: 0 PID: 812 Comm: rc.local Not tainted 4.9.0+ #22
Dec 28 16:52:17 localhost kernel: [   30.682216] Hardware name: Allwinner sun8i Family
Dec 28 16:52:17 localhost kernel: [   30.682289] [<c010ba4d>] (unwind_backtrace) from [<c0108d0b>] (show_stack+0xb/0xc)
Dec 28 16:52:17 localhost kernel: [   30.682334] [<c0108d0b>] (show_stack) from [<c0424079>] (dump_stack+0x71/0x80)
Dec 28 16:52:17 localhost kernel: [   30.682395] [<c0424079>] (dump_stack) from [<c0119bc1>] (__warn+0xad/0xc0)
Dec 28 16:52:17 localhost kernel: [   30.682493] [<c0119bc1>] (__warn) from [<c0119bf5>] (warn_slowpath_fmt+0x21/0x2c)
Dec 28 16:52:17 localhost kernel: [   30.682546] [<c0119bf5>] (warn_slowpath_fmt) from [<c021aaeb>] (sysfs_warn_dup+0x4b/0x58)
Dec 28 16:52:17 localhost kernel: [   30.682593] [<c021aaeb>] (sysfs_warn_dup) from [<c021ab7f>] (sysfs_create_dir_ns+0x5b/0x60)
Dec 28 16:52:17 localhost kernel: [   30.682639] [<c021ab7f>] (sysfs_create_dir_ns) from [<c0425bd7>] (kobject_add_internal+0x6f/0x1f8)
Dec 28 16:52:17 localhost kernel: [   30.682679] [<c0425bd7>] (kobject_add_internal) from [<c0425e83>] (kobject_add+0x2b/0x64)
Dec 28 16:52:17 localhost kernel: [   30.682755] [<c0425e83>] (kobject_add) from [<c04951cf>] (device_add+0x9b/0x3e4)
Dec 28 16:52:17 localhost kernel: [   30.682851] [<c04951cf>] (device_add) from [<c059afb7>] (of_platform_device_create_pdata+0x5b/0x7c)
Dec 28 16:52:17 localhost kernel: [   30.682904] [<c059afb7>] (of_platform_device_create_pdata) from [<c059b073>] (of_platform_notify+0x93/0xbc)
Dec 28 16:52:17 localhost kernel: [   30.682949] [<c059b073>] (of_platform_notify) from [<c012e727>] (notifier_call_chain+0x3f/0x54)
Dec 28 16:52:17 localhost kernel: [   30.682994] [<c012e727>] (notifier_call_chain) from [<c012e8dd>] (__blocking_notifier_call_chain+0x29/0x38)
Dec 28 16:52:17 localhost kernel: [   30.683036] [<c012e8dd>] (__blocking_notifier_call_chain) from [<c012e8fd>] (blocking_notifier_call_chain+0x11/0x14)
Dec 28 16:52:17 localhost kernel: [   30.683079] [<c012e8fd>] (blocking_notifier_call_chain) from [<c059b663>] (of_property_notify+0x2f/0x40)
Dec 28 16:52:17 localhost kernel: [   30.683125] [<c059b663>] (of_property_notify) from [<c059b69d>] (__of_changeset_entry_notify+0x29/0x80)
Dec 28 16:52:17 localhost kernel: [   30.683169] [<c059b69d>] (__of_changeset_entry_notify) from [<c059bbf3>] (__of_changeset_apply+0x37/0x7c)
Dec 28 16:52:17 localhost kernel: [   30.683219] [<c059bbf3>] (__of_changeset_apply) from [<c059e48f>] (of_overlay_create+0x1ab/0x234)
Dec 28 16:52:17 localhost kernel: [   30.683268] [<c059e48f>] (of_overlay_create) from [<c059e807>] (create_overlay+0x2f/0x84)
Dec 28 16:52:17 localhost kernel: [   30.683316] [<c059e807>] (create_overlay) from [<c059e88f>] (cfs_overlay_item_dtbo_write+0x33/0x54)
Dec 28 16:52:17 localhost kernel: [   30.683366] [<c059e88f>] (cfs_overlay_item_dtbo_write) from [<c021ba19>] (configfs_release_bin_file+0x39/0x5c)
Dec 28 16:52:17 localhost kernel: [   30.683417] [<c021ba19>] (configfs_release_bin_file) from [<c01cf6bb>] (__fput+0x5f/0x140)
Dec 28 16:52:17 localhost kernel: [   30.683474] [<c01cf6bb>] (__fput) from [<c012c83d>] (task_work_run+0x89/0xb4)
Dec 28 16:52:17 localhost kernel: [   30.683595] [<c012c83d>] (task_work_run) from [<c010887b>] (do_work_pending+0x63/0x64)
Dec 28 16:52:17 localhost kernel: [   30.683653] [<c010887b>] (do_work_pending) from [<c0105d81>] (slow_work_pending+0x9/0x18)
Dec 28 16:52:17 localhost kernel: [   30.683885] ---[ end trace f0479b3419a2aba7 ]---
Dec 28 16:52:17 localhost kernel: [   30.683908] ------------[ cut here ]------------
Dec 28 16:52:17 localhost kernel: [   30.683952] WARNING: CPU: 0 PID: 812 at lib/kobject.c:240 kobject_add_internal+0x1a5/0x1f8
Dec 28 16:52:17 localhost kernel: [   30.683972] kobject_add_internal failed for 1c2b000.i2c with -EEXIST, don't try to register things with the same name in the same directory.
Dec 28 16:52:17 localhost kernel: [   30.683981] Modules linked in: ccm evdev xradio_wlan mac80211 cfg80211 rfkill sun8i_ths uio_pdrv_genirq cpufreq_dt uio gpio_keys thermal_sys
Dec 28 16:52:17 localhost kernel: [   30.684144] CPU: 0 PID: 812 Comm: rc.local Tainted: G        W       4.9.0+ #22
Dec 28 16:52:17 localhost kernel: [   30.684156] Hardware name: Allwinner sun8i Family
Dec 28 16:52:17 localhost kernel: [   30.684209] [<c010ba4d>] (unwind_backtrace) from [<c0108d0b>] (show_stack+0xb/0xc)
Dec 28 16:52:17 localhost kernel: [   30.684246] [<c0108d0b>] (show_stack) from [<c0424079>] (dump_stack+0x71/0x80)
Dec 28 16:52:17 localhost kernel: [   30.684286] [<c0424079>] (dump_stack) from [<c0119bc1>] (__warn+0xad/0xc0)
Dec 28 16:52:17 localhost kernel: [   30.684326] [<c0119bc1>] (__warn) from [<c0119bf5>] (warn_slowpath_fmt+0x21/0x2c)
Dec 28 16:52:17 localhost kernel: [   30.684368] [<c0119bf5>] (warn_slowpath_fmt) from [<c0425d0d>] (kobject_add_internal+0x1a5/0x1f8)
Dec 28 16:52:17 localhost kernel: [   30.684433] [<c0425d0d>] (kobject_add_internal) from [<c0425e83>] (kobject_add+0x2b/0x64)
Dec 28 16:52:17 localhost kernel: [   30.684536] [<c0425e83>] (kobject_add) from [<c04951cf>] (device_add+0x9b/0x3e4)
Dec 28 16:52:17 localhost kernel: [   30.684594] [<c04951cf>] (device_add) from [<c059afb7>] (of_platform_device_create_pdata+0x5b/0x7c)
Dec 28 16:52:17 localhost kernel: [   30.684641] [<c059afb7>] (of_platform_device_create_pdata) from [<c059b073>] (of_platform_notify+0x93/0xbc)
Dec 28 16:52:17 localhost kernel: [   30.684684] [<c059b073>] (of_platform_notify) from [<c012e727>] (notifier_call_chain+0x3f/0x54)
Dec 28 16:52:17 localhost kernel: [   30.684729] [<c012e727>] (notifier_call_chain) from [<c012e8dd>] (__blocking_notifier_call_chain+0x29/0x38)
Dec 28 16:52:17 localhost kernel: [   30.684772] [<c012e8dd>] (__blocking_notifier_call_chain) from [<c012e8fd>] (blocking_notifier_call_chain+0x11/0x14)
Dec 28 16:52:17 localhost kernel: [   30.684815] [<c012e8fd>] (blocking_notifier_call_chain) from [<c059b663>] (of_property_notify+0x2f/0x40)
Dec 28 16:52:17 localhost kernel: [   30.684859] [<c059b663>] (of_property_notify) from [<c059b69d>] (__of_changeset_entry_notify+0x29/0x80)
Dec 28 16:52:17 localhost kernel: [   30.684977] [<c059b69d>] (__of_changeset_entry_notify) from [<c059bbf3>] (__of_changeset_apply+0x37/0x7c)
Dec 28 16:52:17 localhost kernel: [   30.685049] [<c059bbf3>] (__of_changeset_apply) from [<c059e48f>] (of_overlay_create+0x1ab/0x234)
Dec 28 16:52:17 localhost kernel: [   30.685130] [<c059e48f>] (of_overlay_create) from [<c059e807>] (create_overlay+0x2f/0x84)
Dec 28 16:52:17 localhost kernel: [   30.685212] [<c059e807>] (create_overlay) from [<c059e88f>] (cfs_overlay_item_dtbo_write+0x33/0x54)
Dec 28 16:52:17 localhost kernel: [   30.685378] [<c059e88f>] (cfs_overlay_item_dtbo_write) from [<c021ba19>] (configfs_release_bin_file+0x39/0x5c)
Dec 28 16:52:17 localhost kernel: [   30.685471] [<c021ba19>] (configfs_release_bin_file) from [<c01cf6bb>] (__fput+0x5f/0x140)
Dec 28 16:52:17 localhost kernel: [   30.685570] [<c01cf6bb>] (__fput) from [<c012c83d>] (task_work_run+0x89/0xb4)
Dec 28 16:52:17 localhost kernel: [   30.685700] [<c012c83d>] (task_work_run) from [<c010887b>] (do_work_pending+0x63/0x64)
Dec 28 16:52:17 localhost kernel: [   30.685781] [<c010887b>] (do_work_pending) from [<c0105d81>] (slow_work_pending+0x9/0x18)
Dec 28 16:52:17 localhost kernel: [   30.685834] ---[ end trace f0479b3419a2aba8 ]---
Dec 28 16:52:17 localhost kernel: [   30.685899] OF: of_platform_notify: failed to create for '/soc/i2c@01c2b400'
Dec 28 16:52:17 localhost kernel: [   30.693278] OF: changeset notifier error @/soc/i2c@01c2b400
Dec 28 16:52:18 localhost NetworkManager[544]: <info>  [1482961938.2684] WiFi hardware radio set enabled
Dec 28 16:52:18 localhost NetworkManager[544]: <info>  [1482961938.2690] WWAN hardware radio set enabled
Dec 28 16:52:18 localhost systemd[1]: Started /etc/rc.local Compatibility.
Dec 28 16:52:18 localhost ntp[808]:  * Starting NTP server ntpd
Dec 28 16:52:18 localhost systemd[1]: Started Getty on tty1.
Dec 28 16:52:18 localhost systemd[1]: Started Serial Getty on ttyS0.
Dec 28 16:52:18 localhost systemd[1]: Reached target Login Prompts.
Dec 28 16:52:19 localhost dhclient[679]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 19 (xid=0x2d2c680a)
Dec 28 16:52:19 localhost sh[628]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 19 (xid=0x2d2c680a)
Dec 28 16:52:19 localhost kernel: [   32.076564] spidev spi0.0: buggy DT: spidev listed directly in DT
Dec 28 16:52:19 localhost kernel: [   32.082990] ------------[ cut here ]------------
Dec 28 16:52:19 localhost kernel: [   32.083080] WARNING: CPU: 0 PID: 898 at drivers/spi/spidev.c:757 spidev_probe+0x146/0x15c [spidev]
Dec 28 16:52:19 localhost kernel: [   32.083195] Modules linked in: spidev(+) ccm evdev xradio_wlan mac80211 cfg80211 rfkill sun8i_ths uio_pdrv_genirq cpufreq_dt uio gpio_keys thermal_sys
Dec 28 16:52:19 localhost kernel: [   32.083354] CPU: 0 PID: 898 Comm: systemd-udevd Tainted: G        W       4.9.0+ #22
Dec 28 16:52:19 localhost kernel: [   32.083366] Hardware name: Allwinner sun8i Family
Dec 28 16:52:19 localhost kernel: [   32.083448] [<c010ba4d>] (unwind_backtrace) from [<c0108d0b>] (show_stack+0xb/0xc)
Dec 28 16:52:19 localhost kernel: [   32.083493] [<c0108d0b>] (show_stack) from [<c0424079>] (dump_stack+0x71/0x80)
Dec 28 16:52:19 localhost kernel: [   32.083539] [<c0424079>] (dump_stack) from [<c0119bc1>] (__warn+0xad/0xc0)
Dec 28 16:52:19 localhost kernel: [   32.083581] [<c0119bc1>] (__warn) from [<c0119c3f>] (warn_slowpath_null+0x13/0x18)
Dec 28 16:52:19 localhost kernel: [   32.083645] [<c0119c3f>] (warn_slowpath_null) from [<bf938233>] (spidev_probe+0x146/0x15c [spidev])
Dec 28 16:52:19 localhost kernel: [   32.083741] [<bf938233>] (spidev_probe [spidev]) from [<c04d7ca9>] (spi_drv_probe+0x51/0x70)
Dec 28 16:52:19 localhost kernel: [   32.083793] [<c04d7ca9>] (spi_drv_probe) from [<c0496e45>] (driver_probe_device+0x161/0x1d8)
Dec 28 16:52:19 localhost kernel: [   32.083832] [<c0496e45>] (driver_probe_device) from [<c0496f19>] (__driver_attach+0x5d/0x60)
Dec 28 16:52:19 localhost kernel: [   32.083877] [<c0496f19>] (__driver_attach) from [<c0495c01>] (bus_for_each_dev+0x2d/0x4c)
Dec 28 16:52:19 localhost kernel: [   32.083928] [<c0495c01>] (bus_for_each_dev) from [<c049678d>] (bus_add_driver+0x10d/0x16c)
Dec 28 16:52:19 localhost kernel: [   32.083972] [<c049678d>] (bus_add_driver) from [<c049742f>] (driver_register+0x33/0x84)
Dec 28 16:52:19 localhost kernel: [   32.084034] [<c049742f>] (driver_register) from [<bf93b073>] (spidev_init+0x72/0x97 [spidev])
Dec 28 16:52:19 localhost kernel: [   32.084102] [<bf93b073>] (spidev_init [spidev]) from [<c01016df>] (do_one_initcall+0x2f/0x110)
Dec 28 16:52:19 localhost kernel: [   32.084152] [<c01016df>] (do_one_initcall) from [<c018d2b5>] (do_init_module+0x45/0x14c)
Dec 28 16:52:19 localhost kernel: [   32.084197] [<c018d2b5>] (do_init_module) from [<c017154d>] (load_module+0x1421/0x16d4)
Dec 28 16:52:19 localhost kernel: [   32.084239] [<c017154d>] (load_module) from [<c017192d>] (SyS_finit_module+0x51/0x5c)
Dec 28 16:52:19 localhost kernel: [   32.084284] [<c017192d>] (SyS_finit_module) from [<c0105d21>] (ret_fast_syscall+0x1/0x4c)
Dec 28 16:52:19 localhost kernel: [   32.084302] ---[ end trace f0479b3419a2aba9 ]---
Dec 28 16:52:19 localhost kernel: [   32.086951] spidev spi1.0: buggy DT: spidev listed directly in DT
Dec 28 16:52:19 localhost dhclient[679]: DHCPREQUEST of 10.111.111.41 on wlan0 to 255.255.255.255 port 67 (xid=0xa682c2d)
Dec 28 16:52:19 localhost kernel: [   32.093388] ------------[ cut here ]------------
Dec 28 16:52:19 localhost kernel: [   32.093497] WARNING: CPU: 0 PID: 898 at drivers/spi/spidev.c:757 spidev_probe+0x146/0x15c [spidev]
Dec 28 16:52:19 localhost kernel: [   32.093522] Modules linked in: spidev(+) ccm evdev xradio_wlan mac80211 cfg80211 rfkill sun8i_ths uio_pdrv_genirq cpufreq_dt uio gpio_keys thermal_sys
Dec 28 16:52:19 localhost kernel: [   32.093741] CPU: 0 PID: 898 Comm: systemd-udevd Tainted: G        W       4.9.0+ #22
Dec 28 16:52:19 localhost kernel: [   32.093752] Hardware name: Allwinner sun8i Family
Dec 28 16:52:19 localhost kernel: [   32.093834] [<c010ba4d>] (unwind_backtrace) from [<c0108d0b>] (show_stack+0xb/0xc)
Dec 28 16:52:19 localhost kernel: [   32.093880] [<c0108d0b>] (show_stack) from [<c0424079>] (dump_stack+0x71/0x80)
Dec 28 16:52:19 localhost kernel: [   32.093938] [<c0424079>] (dump_stack) from [<c0119bc1>] (__warn+0xad/0xc0)
Dec 28 16:52:19 localhost kernel: [   32.094039] [<c0119bc1>] (__warn) from [<c0119c3f>] (warn_slowpath_null+0x13/0x18)
Dec 28 16:52:19 localhost kernel: [   32.094120] [<c0119c3f>] (warn_slowpath_null) from [<bf938233>] (spidev_probe+0x146/0x15c [spidev])
Dec 28 16:52:19 localhost kernel: [   32.094199] [<bf938233>] (spidev_probe [spidev]) from [<c04d7ca9>] (spi_drv_probe+0x51/0x70)
Dec 28 16:52:19 localhost kernel: [   32.094250] [<c04d7ca9>] (spi_drv_probe) from [<c0496e45>] (driver_probe_device+0x161/0x1d8)
Dec 28 16:52:19 localhost kernel: [   32.094307] [<c0496e45>] (driver_probe_device) from [<c0496f19>] (__driver_attach+0x5d/0x60)
Dec 28 16:52:19 localhost kernel: [   32.094412] [<c0496f19>] (__driver_attach) from [<c0495c01>] (bus_for_each_dev+0x2d/0x4c)
Dec 28 16:52:19 localhost kernel: [   32.094469] [<c0495c01>] (bus_for_each_dev) from [<c049678d>] (bus_add_driver+0x10d/0x16c)
Dec 28 16:52:19 localhost kernel: [   32.094512] [<c049678d>] (bus_add_driver) from [<c049742f>] (driver_register+0x33/0x84)
Dec 28 16:52:19 localhost kernel: [   32.094573] [<c049742f>] (driver_register) from [<bf93b073>] (spidev_init+0x72/0x97 [spidev])
Dec 28 16:52:19 localhost kernel: [   32.094680] [<bf93b073>] (spidev_init [spidev]) from [<c01016df>] (do_one_initcall+0x2f/0x110)
Dec 28 16:52:19 localhost kernel: [   32.094760] [<c01016df>] (do_one_initcall) from [<c018d2b5>] (do_init_module+0x45/0x14c)
Dec 28 16:52:19 localhost kernel: [   32.094809] [<c018d2b5>] (do_init_module) from [<c017154d>] (load_module+0x1421/0x16d4)
Dec 28 16:52:19 localhost kernel: [   32.094854] [<c017154d>] (load_module) from [<c017192d>] (SyS_finit_module+0x51/0x5c)
Dec 28 16:52:19 localhost kernel: [   32.094899] [<c017192d>] (SyS_finit_module) from [<c0105d21>] (ret_fast_syscall+0x1/0x4c)
Dec 28 16:52:19 localhost kernel: [   32.094918] ---[ end trace f0479b3419a2abaa ]---
Dec 28 16:52:19 localhost sh[628]: DHCPREQUEST of 10.111.111.41 on wlan0 to 255.255.255.255 port 67 (xid=0xa682c2d)
Dec 28 16:52:19 localhost sh[628]: DHCPOFFER of 10.111.111.41 from 10.111.111.1
Dec 28 16:52:19 localhost dhclient[679]: DHCPOFFER of 10.111.111.41 from 10.111.111.1
Dec 28 16:52:19 localhost dhclient[679]: DHCPACK of 10.111.111.41 from 10.111.111.1
Dec 28 16:52:19 localhost sh[628]: DHCPACK of 10.111.111.41 from 10.111.111.1
Dec 28 16:52:22 localhost root: /etc/dhcp/dhclient-enter-hooks.d/samba returned non-zero exit status 1
Dec 28 16:52:22 localhost avahi-daemon[574]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.111.111.41.
Dec 28 16:52:22 localhost avahi-daemon[574]: New relevant interface wlan0.IPv4 for mDNS.
Dec 28 16:52:22 localhost avahi-daemon[574]: Registering new address record for 10.111.111.41 on wlan0.IPv4.
Dec 28 16:52:22 localhost ntpd[901]: ntpd 4.2.8p4@1.3265-o Wed Oct  5 12:38:30 UTC 2016 (1): Starting
Dec 28 16:52:22 localhost ntpd[901]: Command line: /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 106:110
Dec 28 16:52:22 localhost systemd[1]: Started LSB: Start NTP daemon.
Dec 28 16:52:22 localhost ntp[808]:    ...done.
Dec 28 16:52:22 localhost systemd[1]: Reached target Multi-User System.
Dec 28 16:52:22 localhost ntpd[916]: proto: precision = 4.334 usec (-18)
Dec 28 16:52:22 localhost ntpd[916]: Listen and drop on 0 v6wildcard [::]:123
Dec 28 16:52:22 localhost ntpd[916]: Listen and drop on 1 v4wildcard 0.0.0.0:123
Dec 28 16:52:22 localhost ntpd[916]: Listen normally on 2 lo 127.0.0.1:123
Dec 28 16:52:22 localhost ntpd[916]: Listen normally on 3 eth0 10.111.111.37:123
Dec 28 16:52:22 localhost ntpd[916]: Listen normally on 4 wlan0 10.111.111.41:123
Dec 28 16:52:22 localhost systemd[1]: Reached target Graphical Interface.
Dec 28 16:52:22 localhost ntpd[916]: Listen normally on 5 lo [::1]:123
Dec 28 16:52:22 localhost ntpd[916]: Listen normally on 6 eth0 [fe80::9d08:68e:5df8:7740%2]:123
Dec 28 16:52:22 localhost ntpd[916]: Listen normally on 7 wlan0 [fe80::de44:6dff:fec0:ffee%3]:123
Dec 28 16:52:22 localhost ntpd[916]: Listening on routing socket on fd #24 for interface updates
Dec 28 16:52:22 localhost systemd[1]: Starting Update UTMP about System Runlevel Changes...
Dec 28 16:52:22 localhost sh[628]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /run/resolvconf/resolv.conf
Dec 28 16:52:23 localhost systemd[1]: Started Update UTMP about System Runlevel Changes.
Dec 28 16:52:23 localhost systemd[1]: Startup finished in 14.469s (kernel) + 21.370s (userspace) = 35.840s.
Dec 28 16:52:24 localhost ntpd[916]: Soliciting pool server 167.114.174.158
Dec 28 16:52:25 localhost dhclient[679]: bound to 10.111.111.41 -- renewal in 38876 seconds.
Dec 28 16:52:25 localhost sh[628]: bound to 10.111.111.41 -- renewal in 38876 seconds.
Dec 28 16:52:25 localhost ntpd[916]: Soliciting pool server 144.217.67.230
Dec 28 16:52:25 localhost kernel: [   38.233460] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.239810] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.246440] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.252476] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.258895] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.265467] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.271367] xradio_wlan mmc1:0001:1: Failed to read control register.
Dec 28 16:52:25 localhost kernel: [   38.313485] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.319649] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.326197] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.332114] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.338546] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.345065] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.350887] xradio_wlan mmc1:0001:1: Failed to read control register.
Dec 28 16:52:25 localhost systemd[1]: Reloading OpenBSD Secure Shell server.
Dec 28 16:52:25 localhost kernel: [   38.393518] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.399732] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.406308] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.412397] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.418753] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.425288] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.431246] xradio_wlan mmc1:0001:1: Failed to read control register.
Dec 28 16:52:25 localhost systemd[1]: Reloaded OpenBSD Secure Shell server.
Dec 28 16:52:25 localhost kernel: [   38.473537] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.479826] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.486441] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.492379] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.498697] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.505223] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.510999] xradio_wlan mmc1:0001:1: Failed to read control register.
Dec 28 16:52:25 localhost kernel: [   38.553541] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.559764] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.566265] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.572148] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.578587] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.585125] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.590950] xradio_wlan mmc1:0001:1: Failed to read control register.
Dec 28 16:52:25 localhost kernel: [   38.592216] ------------[ cut here ]------------
Dec 28 16:52:25 localhost kernel: [   38.592572] WARNING: CPU: 3 PID: 6 at drivers/net/wireless/allwinner/xr819/txrx.c:690 tx_policy_upload_work+0x28/0x2c [xradio_wlan]
Dec 28 16:52:25 localhost kernel: [   38.592668] Modules linked in: spidev ccm evdev xradio_wlan mac80211 cfg80211 rfkill sun8i_ths uio_pdrv_genirq cpufreq_dt uio gpio_keys thermal_sys
Dec 28 16:52:25 localhost kernel: [   38.592696] CPU: 3 PID: 6 Comm: kworker/u8:0 Tainted: G        W       4.9.0+ #22
Dec 28 16:52:25 localhost kernel: [   38.592704] Hardware name: Allwinner sun8i Family
Dec 28 16:52:25 localhost kernel: [   38.592936] Workqueue: xradio_wq tx_policy_upload_work [xradio_wlan]
Dec 28 16:52:25 localhost kernel: [   38.593015] [<c010ba4d>] (unwind_backtrace) from [<c0108d0b>] (show_stack+0xb/0xc)
Dec 28 16:52:25 localhost kernel: [   38.593059] [<c0108d0b>] (show_stack) from [<c0424079>] (dump_stack+0x71/0x80)
Dec 28 16:52:25 localhost kernel: [   38.593106] [<c0424079>] (dump_stack) from [<c0119bc1>] (__warn+0xad/0xc0)
Dec 28 16:52:25 localhost kernel: [   38.593145] [<c0119bc1>] (__warn) from [<c0119c3f>] (warn_slowpath_null+0x13/0x18)
Dec 28 16:52:25 localhost kernel: [   38.593365] [<c0119c3f>] (warn_slowpath_null) from [<bf900a0d>] (tx_policy_upload_work+0x28/0x2c [xradio_wlan])
Dec 28 16:52:25 localhost kernel: [   38.593615] [<bf900a0d>] (tx_policy_upload_work [xradio_wlan]) from [<c0129bb3>] (process_one_work+0xd7/0x248)
Dec 28 16:52:25 localhost kernel: [   38.593660] [<c0129bb3>] (process_one_work) from [<c0129e19>] (worker_thread+0xf5/0x398)
Dec 28 16:52:25 localhost kernel: [   38.593709] [<c0129e19>] (worker_thread) from [<c012d83f>] (kthread+0x9f/0xb4)
Dec 28 16:52:25 localhost kernel: [   38.593761] [<c012d83f>] (kthread) from [<c0105df1>] (ret_from_fork+0x11/0x20)
Dec 28 16:52:25 localhost kernel: [   38.593871] ---[ end trace f0479b3419a2abab ]---
Dec 28 16:52:25 localhost kernel: [   38.597842] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.604196] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.610623] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.616782] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.622916] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.629447] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.635332] xradio_wlan mmc1:0001:1: Failed to read control register.
Dec 28 16:52:25 localhost kernel: [   38.641895] xradio_wlan mmc1:0001:1: Invalid read len: -5
Dec 28 16:52:25 localhost kernel: [   38.683498] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.689690] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.696332] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.702242] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.708468] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.715003] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.720737] xradio_wlan mmc1:0001:1: Failed to read control register.
Dec 28 16:52:25 localhost kernel: [   38.727625] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost kernel: [   38.733898] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.740360] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:25 localhost kernel: [   38.746485] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:25 localhost ntpd[916]: Soliciting pool server 206.108.0.131
Dec 28 16:52:25 localhost ntpd[916]: Soliciting pool server 158.69.125.231
Dec 28 16:52:25 localhost kernel: [   38.752590] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:25 localhost kernel: [   38.759185] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:26 localhost kernel: [   38.765124] xradio_wlan mmc1:0001:1: Failed to read control register.
Dec 28 16:52:26 localhost kernel: [   38.771865] xradio_wlan mmc1:0001:1: Invalid read len: -5
Dec 28 16:52:26 localhost kernel: [   38.813532] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:26 localhost kernel: [   38.819833] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:26 localhost kernel: [   38.826371] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:26 localhost kernel: [   38.832284] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:26 localhost kernel: [   38.838639] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:26 localhost kernel: [   38.845110] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:26 localhost kernel: [   38.850885] xradio_wlan mmc1:0001:1: Failed to read control register.
Dec 28 16:52:26 localhost kernel: [   38.893489] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:26 localhost kernel: [   38.899841] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:26 localhost kernel: [   38.906381] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:26 localhost kernel: [   38.912342] sunxi-mmc 1c10000.mmc: smc 1 err, cmd 53, RD RTO !!
Dec 28 16:52:26 localhost kernel: [   38.918589] sunxi-mmc 1c10000.mmc: data error, sending stop command
Dec 28 16:52:26 localhost kernel: [   38.925088] sunxi-mmc 1c10000.mmc: send stop command failed
Dec 28 16:52:26 localhost kernel: [   38.930894] xradio_wlan mmc1:0001:1: Failed to read control register.
... and here is the /proc/interrupts
           CPU0       CPU1       CPU2       CPU3
 17:          0          0          0          0     GIC-0  29 Level     arch_timer
 18:     295189    2213696      52729      81304     GIC-0  30 Level     arch_timer
 21:          0          0          0          0     GIC-0  50 Level     sun4i_timer0
 22:          0          0          0          0     GIC-0  82 Level     1c02000.dma-controller
 24:    1026135          0          0          0     GIC-0  92 Level     sunxi-mmc
 25:       5100          0          0          0     GIC-0  93 Level     sunxi-mmc
 26:          0          0          0          0     GIC-0 103 Level     musb-hdrc.1.auto
 27:          0          0          0          0     GIC-0 104 Level     ehci_hcd:usb1
 28:          0          0          0          0     GIC-0 105 Level     ohci_hcd:usb5
 29:          0          0          0          0     GIC-0 106 Level     ehci_hcd:usb2
 30:          0          0          0          0     GIC-0 107 Level     ohci_hcd:usb6
 31:          0          0          0          0     GIC-0 108 Level     ehci_hcd:usb3
 32:          0          0          0          0     GIC-0 109 Level     ohci_hcd:usb7
 33:          0          0          0          0     GIC-0 110 Level     ehci_hcd:usb4
 34:          0          0          0          0     GIC-0 111 Level     ohci_hcd:usb8
 39:      36994          0          0          0     GIC-0  63 Level     1c25000.ths
 40:      25917          0          0          0     GIC-0  32 Level     serial
 41:      74593          0          0          0     GIC-0 114 Level     1c30000.ethernet
 42:          0          0          0          0     GIC-0  72 Level     1f00000.rtc
 87:        140          0          0          0  sunxi_pio_edge  42 Edge      xradio
 89:          1          0          0          0  sunxi_pio_edge  44 Edge      usb0-id-det
112:          1          0          0          0  sunxi_pio_edge   3 Edge      sw4
141:          0          0          0          0     GIC-0  38 Level     mv64xxx_i2c
142:          0          0          0          0     GIC-0  39 Level     mv64xxx_i2c
144:          0          0          0          0     GIC-0  97 Level     sun6i-spi
145:          0          0          0          0     GIC-0  98 Level     sun6i-spi
IPI0:          0          0          0          0  CPU wakeup interrupts
IPI1:          0          0          0          0  Timer broadcast interrupts
IPI2:       9863      41880      26849      45210  Rescheduling interrupts
IPI3:         51         49         50         13  Function call interrupts
IPI4:          0          0          0          0  CPU stop interrupts
IPI5:        310         35         50        260  IRQ work interrupts
IPI6:          0          0          0          0  completion interrupts
Err:          0
Hi dgp,
Here is the relevant fragment of the log :
Are you building the module externally to the kernel or have you integrated it back into the kernel source? If the later what are the kconfig options you have selected?
You can try to provide default options via separate Kconfig symbol like this (using "select"):
config XRADIO_SDIO
	bool
config XRADIO_USE_EXTENSIONS
	bool
config XRADIO_5GHZ_SUPPORT
	bool
config XRADIO_XR819
	bool "XRADIO XR819 support"
	depends on WLAN_VENDOR_XRADIO
	select XRADIO_SDIO
	select XRADIO_USE_EXTENSIONS
	select XRADIO_5GHZ_SUPPORT
	default y
@dgp, yes, I was trying to integrate xradio in armbian build process, it was the default configs.
But since zador is faster than me, I think my effort are now useless.
@zador, thanks for committing those changes, I will gave it a try when I get chance.
(especially that this morning, my PiZero didn't even boot at all, I hope it doesn't end up to be hardware issue)
Most of those options will probably be removed at some point. The non power of 2 block size option for example has to be enabled or the firmware crashes. I'm slowly taking the useless stuff that allwinner/xradio have bolted on so that it's closer to the cw1200 driver in the kernel that it's based on.
Ok, guys ! I found my hardware issue : I've been caught myself with an SDCard that becames crappy !
For the xradio issue, I don't know if it was also related, but I've created image with Zador stuff, although I had to tweak a bit the DT, and it is now working fine.
@Zador, the tweak needed is related to the fact that PL7 was already defined in PiOne, but due was slipped into pio instead of r_pio (same issue found few weeks ago for PiPC https://github.com/igorpecovnik/lib/commit/31c3133cf65af66197b0e78f92eae835615a90b1 )
I will commit this fix in few minutes along some removal in PiZero since we can reuse the PL7 from PiOne, simply by using same names.
EDIT : here is the first fix : https://github.com/igorpecovnik/lib/commit/5fff38add9873b50bc71d540573e4294bc97c10d, and here the redundancy cleanup : https://github.com/igorpecovnik/lib/commit/fdaadb42d7587371a7cb7f1184ade5915cd77924#diff-ef59beeea2dd85451fb9bf2905fb7ebf and https://github.com/igorpecovnik/lib/commit/369d3928e7154ac12c34f0e2bc4ce0e24636cb4e#diff-ef59beeea2dd85451fb9bf2905fb7ebf
Powering question:
Can we use the OTG USB port on OPi0 to draw 500mA from USB , and also use a second power source, e.g., via GPIO pins?
ErwinH,
I was afraid so ;(
So how much power does an OPi0 require roughly, without external devices, but with WiFi and TVout streaming?
And, with receiving a video stream from a USB camera over PoE, to display over TVout?
500mA should do, but you need a good power supply and more importantly a good micro usb cable since micro usb connector is a big reason for voltage drops causing instability.
I'm running the board without WiFi or display without any problems, but increasing the load might give you issues. To make sure it isn't because of the power supply or the cable you can try the GPIO pins, which give you less voltage drop.
ErwinH,
Thanks. Hopefully my OPi0 will arrive in the next few days, from my Dec 19 order.
Will it make sense to use the legacy Armbian image from Nov 14 as listed on linux-sunxi page? Is wifi now working?
Why do they say use legacy for multimedia, but mainline for headless?
Any caveats?
Any caveats?
Simple - drivers responsible for multimedia usually arrive last. For example, mainline doesn't have H3/H2+ drivers for HDMI video & audio, TV out and HW video decoding. Some initial patches exists for HDMI video & audio, but they won't be mainlined soon. I think Armbian includes patches at least for HDMI video.
Any caveats?
It's not true for H3. There it's "legacy for everything, mainline for developers" since some headless use cases require extensive Linux knowledge and ability to find necessary information.
jernej + zador,
OK, so I should stick to legacy Armbian which I am assuming is from Nov 14.
So confirming that OPi0 Wifi is working under legacy Armbian?
Anything else I need to worry about besides PSU preferably from pins not OTG, and a "fast" SD card?
Has the presence of 2MB SPI NOR flash on the 512MB version recently changed anything? I still can't avoid an SD card?
Presence of SPI NOR gives you possibility to do just that. You must build SPI enabled U-Boot and burn it on SPI chip. Then you can boot from USB, network, etc. But 2 MB is far too litle to boot full OS. AFAIK there is no tutorial how to put U-Boot on chip.
Good. So is Wifi OK on legacy?
It's operational on both kernels - at least self built versions / nightly updates. Just don't expect some great performances or advanced functionalities from this wireless chip.
Nope. And that's true for all the other cheap SBC. WiFi is more or less crap on all of them. It's also not that hard to understand the relationship between 'buy as cheap as possible' and (missing) functionality. What do people expect from devices as cheap as $7?
If you want ok-ish Wi-Fi then choose any of those Armbian devices with mPCIe slots (they're all from Solid-Run), add another $50 for a good WiFi card and you're done.
Or maybe he could buy a "patch" antenna with the correct connector for Opi0 and point it directly to the wireless router and gain range.
It's not about the antenna, it's about overall hardware capabilities and software/documentation support for this particular wireless chip. So far we can't get consistent feedback about wireless operability.
This is a bit of overkill unless you want to set up a router/AP combined with NAS. Any board running mainline kernel that can provide enough power to USB port combined with good USB wireless adaptee (i.e. ath9k) is enough, but people will still buy the cheapest hardware they can find and expect it to operate perfectly in any scenario.
Nope. Please stop spreading such wrong claims. With Armbian settings H2+ on this board remains in a good temperature range but as usual if you run constantly heavy loads some throttling will occur or you mount a heatsink. But there really is no need for one especially when you use this device as intended. Are your claims backed up by the output of 'sudo armbianmonitor -m'?
I have been running Armbian legacy with Wifi as AP with HostAPD and Ajenti Core Web Configuration installed. It is running pretty hot. I will try armbianmonitor on this tomorrow.
I also have a working OpenWRT build (Wifi not configured) and it is running cool.
Very interesting. How has the Wi-Fi performed for you? In terms of throughput/latency, etc...
@tkaiser - armbianmonitor - log
Activity:
1. Hotspot with HostAPD and connected to it.
2. Logging into Ajenti Core Dashboard
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
02:13:09: 1008MHz  0.27  10%   2%   5%   0%   2%   0%   59°C
02:13:14:  240MHz  0.25  10%   1%   5%   0%   2%   0%   59°C
02:13:19:  240MHz  0.29  10%   1%   5%   0%   2%   0%   59°C
02:13:24:  240MHz  0.26  10%   1%   4%   0%   1%   0%   60°C
02:13:30:  240MHz  0.24  10%   1%   4%   0%   1%   0%   60°C
02:13:35:  240MHz  0.22   9%   1%   4%   0%   1%   0%   59°C
02:13:40:  240MHz  0.20   9%   1%   4%   0%   1%   0%   61°C
02:13:45: 1008MHz  0.27   9%   1%   4%   0%   1%   0%   62°C
02:13:50:  240MHz  0.25   9%   1%   4%   0%   1%   0%   62°C
02:13:56:  240MHz  0.23   9%   1%   4%   0%   1%   0%   62°C
02:14:01:  240MHz  0.21   9%   1%   4%   0%   1%   0%   61°C
02:14:06:  240MHz  0.19   9%   1%   4%   0%   1%   0%   60°C
02:14:11: 1008MHz  0.18   9%   1%   4%   0%   1%   0%   62°C
02:14:16:  240MHz  0.24   9%   1%   4%   0%   1%   0%   61°C
02:14:22:  240MHz  0.22   9%   1%   4%   0%   1%   0%   62°C
OpiZero as Hostspot -
sftp: (standing nearby)
Upload - 5 to 6 Mbps
Download - 4 to 5 Mbps
I just got my Opizero enclosure and now it sits snugly in there with its teeny wifi antenna. That could be an issue.
Cheers @praveenbm5 . Quick clarification, do you mean megabits per second or megabytes per second (how file transfer is normally reported!)?
One other thing that would be of great interest is your actual link speed/signal strength. If you've an Android device just tapping on the active connection in Wi-Fi settings should reveal the answer :D If it reports a low signal strength and a low link speed then improving the antenna could help matters...
(Single chain 802.11n in 20MHz should be able to achieve 144Mbps max let's see how close we can get to that with a 30 cent chip!)
