zador.blood.stained Posted October 11, 2017 Posted October 11, 2017 8 minutes ago, hojnikb said: Any chance frequency tables get bumped to 1.3Ghz, as it was before ? Mine only goes to 1.15G As soon as anyone tests (on multiple devices, using cpuburn and xhpl) and publishes a new DVFS table I may add it to kernel sources. Until that you could write a DT overlay or patch the DT manually. I just copy-pasted a DVFS table from somewhere and I don't want to waste time tweaking it without a good reason.
rusatch Posted October 12, 2017 Posted October 12, 2017 Hi! Fresh build with commit b084385fefa3e166dc4a007d5128e715cc9d2e2f stopping wlan interface. After manual actions like: cp /lib/firmware/brcm/brcmfmac43430-sdio.bin /lib/firmware/brcm/brcmfmac43430-sdio.bin.bak cp /lib/firmware/ap6212/fw_bcm43438a1.bin /lib/firmware/brcm/brcmfmac43430-sdio.bin rmmod brcmfmac modprobe brcmfmac wifi works again.
Menion Posted October 18, 2017 Posted October 18, 2017 Hi all What is the kernel branch used for "dev" branch in sun50i targets?
zador.blood.stained Posted October 18, 2017 Posted October 18, 2017 3 minutes ago, Menion said: What is the kernel branch used for "dev" branch in sun50i targets? Icenowy's linux-4.13.y For H5 targets using the "next" branch is recommended instead.
Menion Posted October 18, 2017 Posted October 18, 2017 dwmac-sun8i is not present in either the branch?
zador.blood.stained Posted October 18, 2017 Posted October 18, 2017 Just now, Menion said: dwmac-sun8i is not present in either the branch? It is present and should be working on several H5 boards: NanoPi Neo2, OrangePi PC2 and OrangePi Prime. Other H5 boards most likely are missing relevant DT entries for the driver.
Menion Posted October 18, 2017 Posted October 18, 2017 Also in next (that I understand it is mainline)? Because, AFAIK, this has been removed due to unstable DT bindings for all the board
zador.blood.stained Posted October 18, 2017 Posted October 18, 2017 Just now, Menion said: Also in next (that I understand it is mainline)? Yes Just now, Menion said: Because, AFAIK, this has been removed due to unstable DT bindings for all the board But we (and Icenowy in her branch) reverted that removal. "Unstable bindings" doesn't mean that something isn't working or is unstable, it just means that DT maintainers are not happy with the way DT represents the hardware. Today the 7th iteration of the attempt to resolve this was posted: https://groups.google.com/forum/#!topic/linux-sunxi/jxF_AIJP0VA 1
Menion Posted October 18, 2017 Posted October 18, 2017 Ahhhh ok, son on mainline we have armbian enable patch Thanks, yes I followed the thread, it was clear to me that the problem was more to let the maintainer agree on the DT bindings structure
rusatch Posted October 21, 2017 Posted October 21, 2017 Hi! On orange pi zero plus 2 h5 armbianmonitor show that cpu temperature is over 35C, but radiator is too hot, i cant touch it more 5 second. I think that real temperature is over 70C and calculation need to correct.
zador.blood.stained Posted October 21, 2017 Posted October 21, 2017 1 minute ago, rusatch said: On orange pi zero plus 2 h5 armbianmonitor show that cpu temperature is over 35C, but radiator is too hot, i cant touch it more 5 second. I think that real temperature is over 70C and calculation need to correct. Which kernel version and branch?
rusatch Posted October 21, 2017 Posted October 21, 2017 1 hour ago, zador.blood.stained said: Which kernel version and branch? cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepizeroplus2-h5 BOARD_NAME="Orange Pi Zero Plus 2" VERSION=5.33 LINUXFAMILY=sunxi64 BRANCH=next ARCH=arm64 IMAGE_TYPE=user-built BOARD_TYPE=conf INITRD_ARCH=arm64 KERNEL_IMAGE_TYPE=Image uname -r 4.13.8-sunxi64
znoxx Posted October 23, 2017 Posted October 23, 2017 Guys, thanks for update of image. Verium miner Before update:113 h/m After update:141 h/m (not sure of exact number, but hash rate is raise is about 25%) Throttle is working - temp keeps about 66-68 degrees. Output of armbianmonitor can be found here : http://znoxx.me/2017/10/20/na-frontie-orange-pi/ And yet another point. If one is using I2P on OpiPC2, probably, it will fail to run native big integer library, since it is not included in distribution. I've build one - you can grab one here: https://static-bins.herokuapp.com/files/aarch64/libjbigi/libjbigi-linux-armv8-a.so.gz Unpack the archive and copy .so file with name libjbigi.so to your I2P installation directory. After this restart I2P. Log should show, that Native Big Integer library is loaded from file. I've build it as static for OrangePi PC2 , but it also should work on other H5 boards. However, I didn't have a chance to test it on other machines, even ones different from one where it was build. So if someone interested, welcome to try it.
Jarik65535 Posted October 27, 2017 Posted October 27, 2017 Hello. On OPZ2-H5 with latest build of armbian (both next and dev branches) lsusb return error -99. Dmesg show no errors. Do i need somehow manually enable USB or use overlay?
rusatch Posted October 27, 2017 Posted October 27, 2017 1 hour ago, Jarik65535 said: Hello. On OPZ2-H5 with latest build of armbian (both next and dev branches) lsusb return error -99. Dmesg show no errors. Do i need somehow manually enable USB or use overlay? With overlay usb on OPZ2-H5 working fine.
hojnikb Posted October 30, 2017 Posted October 30, 2017 On 3/27/2017 at 8:20 PM, zador.blood.stained said: I wonder how many times the wheel can be reinvented... root@orangepiplus2e:~# fdtget /boot/dtb/sun8i-h3-orangepi-one.dtb /cpus/cpu@0 operating-points 1008000 1300000 816000 1100000 624000 1100000 480000 1100000 312000 1100000 240000 1100000 120000 1100000 root@orangepiplus2e:~# fdtput /boot/dtb/sun8i-h3-orangepi-one.dtb /cpus/cpu@0 operating-points 1008000 1300000 816000 1300000 624000 1100000 480000 1100000 312000 1100000 240000 1100000 120000 1100000 root@orangepiplus2e:~# fdtget /boot/dtb/sun8i-h3-orangepi-one.dtb /cpus/cpu@0 operating-points 1008000 1300000 816000 1300000 624000 1100000 480000 1100000 312000 1100000 240000 1100000 120000 1100000 root@orangepiplus2e:~# im trying to add 1.3GHz operating point to the newest PC2 image using these commands but im getting this error root@orangepipc2:/boot/dtb/allwinner# fdtget /boot/dtb/allwinner/sun50i-h5-orangepi-pc2.dtb /cpus/cpu@0 operating-points Error at 'operating-points': FDT_ERR_NOTFOUND
zador.blood.stained Posted October 30, 2017 Posted October 30, 2017 New DT uses a different format (operating-points-v2) that can't be easily edited with fdtget/fdtput, you need to use dtc to decompile, edit and recompile it.
hojnikb Posted October 30, 2017 Posted October 30, 2017 Yeah, i figured as much. Well, maybe old entries could be used from previous builds, these seem to work on most boards back then.
Menion Posted November 3, 2017 Posted November 3, 2017 Is it possible to change on the fly the MUSB from OTG<->HOST without having to do so in the dts?
zador.blood.stained Posted November 3, 2017 Posted November 3, 2017 1 hour ago, Menion said: Is it possible to change on the fly the MUSB from OTG<->HOST without having to do so in the dts? If it is in OTG mode (dr_mode = "otg") (and you loaded at least one gadget module) it will already switch from device to host mode on the fly by reading the OTG ID pin. Alternatively it may be possible to load overlays via configfs to change the dr_mode property, but it wasn't tested so I'm not sure that the driver will respect those changes.
Menion Posted November 3, 2017 Posted November 3, 2017 With original dtb, dr_mode='otg' I plugged an USB key but it doesn't get recognized. I changed the dr_mode='host', rebooted with the new dtb and then it worked fine. USB key is connected with a micro USB to USB A female cable, also named OTG cable, can this be the problem?
zador.blood.stained Posted November 3, 2017 Posted November 3, 2017 2 minutes ago, Menion said: With original dtb, dr_mode='otg' I plugged an USB key but it doesn't get recognized. Did you load any gadget modules (i.e. g_serial)?
Menion Posted November 3, 2017 Posted November 3, 2017 Mmmm I am afraid I don't know what this gadget module are. But I did nothing, so I guess no
Menion Posted November 3, 2017 Posted November 3, 2017 But the usb gadgets, aren't ment to be used for having the SBC acting like a serial, mass storage, etc...? My goal is just to use the OTG port in host mode
zador.blood.stained Posted November 3, 2017 Posted November 3, 2017 Switching between host and peripheral mode is done by the MUSB stack, and it won't be activated until you load a gadget module (even if you want to use OTG only in host mode). This applies at least to all Allwinner devices running the mainline kernel - A10, A20, A64, H3, H5, ...
Menion Posted November 3, 2017 Posted November 3, 2017 Ahhhhh ok Next time I will recompile the kernel I will enable one then
zador.blood.stained Posted November 3, 2017 Posted November 3, 2017 Just now, Menion said: Ahhhhh ok Next time I will recompile the kernel I will enable one then They are already enabled in our kernel config. Alternatively you could add a DT overlay to change dr_mode to "host" - then it should work without loading extra modules but without a possibility to switch to the peripheral mode on the fly.
Nowak Matthias Posted November 6, 2017 Posted November 6, 2017 (edited) Hello, I noticed that there isnt any support for the Orange Pi Zero Plus (H5) and would ask if there is a reason for it. They are more of an original Orange Pi Zero with an H5 from an hardware perspective and dont come with onboard flash. Have a good Day Matthias Edited November 6, 2017 by Nowak Matthias
_vn Posted November 9, 2017 Posted November 9, 2017 Any prevision to have a stable release for Orange Pi Prime? I'm actually waiting for a debian based armbian image instead of Ubuntu. Someone who tried this unstable version on a pi prime can share the faced issues?
Igor Posted November 9, 2017 Posted November 9, 2017 1 hour ago, _vn said: Someone who tried this unstable version on a pi prime can share the faced issues? Basic hardware features are operational - but all mainline kernels for H3/H5/A64 boards remain labeled testing (also after next major release) since things are not well tested, not fine-tuned (thermal protection) and there is nothing we can do to speed up. In the testing period we don't make all possible images, so you have to make your own (Debian Stretch) image or wait ...
