53 minutes ago, RaptorSDS said:
the lastest old one is 5.77 with 3.10.108 and a desktop in the name , at 3.10.108 you have the dtb.img rename trick , at 4.19 and 5.xx Kernel you have toedit uENV.ini ; hope now it works
Hi
I download the 5.77 desktop one in the old folder (my minix is on kernel 3.10.33)
copy in root folder and rename a couple of dtb files to the dtb.img name
edit the uENV.ini just to be sure
but now the minix simply don't have any external signal, the tv lose the signal like the minix power off.
Do i need to try other dtb files and put in root folder (and rename them dtb.img) ?
Thank you
1 hour ago, balbes150 said:
These are not the correct sources. Martin is developing the S8xx. I use its source code.
https://github.com/xdarklight/linux/branches
Thanks a lot, will try! But the kernel release should be the same for everyone, no? I can imagine that for integration branches you'll get not-yet-merged changes, but when it's a released kernel the sources should be the same for everyone. But maybe there's something I'm missing.
@Nikeb do not edit uENV.ini at older roms please , neo x8-H plus should be meson8m2-n200-xx.dtb files be aware the first boot maybe around 5-10minutes , when no one of this work than
you could only extract android boot.img from your preinstalled Android and ask balbes150 to seperate and convert the dtb from android to armbian ; but i think extract boot.img is only possible with root android and maybe twrp as recovery image , also you can get a serial to usb adapter and solder/connect it to the onboard Serial port than you can also look at linux boot message
Ok thanks but the dtb files are in 2 folders:
dtb
dtb-3.10.108
Wich folder should i get the dtb?
for every single file in one of the 2 folders i will copy in the root folder of the SD renaming it to "dtb.img"
Is that correct?
Thank you again
@Nikeb both folderss are the same dtb files , you should use the dtb folder (without -30.10) , correct copy and rename single file do not edit uEnv.ini and wait at test around 5-10min , after finish test without postive result than only possible way is serial console and extract boot.img from android , or (with a small chance that it help )take a newer image 20.05 and SSH over Ethernet without hdmi
Thanks Raptor
I try every single dtb files but i find another way:
- Upgraded the Minix with the Lollipop version (not official but latest)
- Did again what i did
Right now i'm writing from the minix with the armbian on, and it's pretty amazing.
It's booting from my SD Card and it works very good.
I'm trying to install it on the ROM of the Minix (wich i guess is NAND) but i can't find the nand-sata-install script (command not found) or in the armbian-config (there is no such menù "Install")
Is something that i could do? use the armbian OS from the minix drive without SD Card?
I already update and upgrade the packages, i don't have wifi driver but i don't care honestly.
Thanks for your help
nice to hear
as far as i know there is no install to nand script
there are 3  different wifi chip AP6330 ;  BCM4335 and RTL8723BS  ;
please test in console
BCM-> "modprobe dhd" than  "ifconfig"
dhd is Broadcom Dongle Host Drive
RTL-> edit "etc/modprobe/blacklist.conf" add "blacklist dhd" at the end "restart" than "modprobe 8723bs" and "ifconfig"
AP -> i have no idea when there is a driver
when wlan0 show up than edit "etc/modules-load.d/modules.conf" insert  driver module name or insert "modprobe xxx" at "etc/rc.local"
maybe helps
20 minutes ago, RaptorSDS said:
nice to hear
maybe helps
Hi Raptor
Minix has a emmc storage of 16 GB wich i would like to use as the main OS Drive, is there a way to make the emmc storage the system drive with armbian?
In that way i can boot armbian without using the SD Card.
I tried the script of guides and tutorials but i can't find the command.
Many thanks for the tips about the wifi, i m planning to use it only with wired connection, but i ll give it a look.
Thanks
Assuming you are using one of balbes150's builds, then follow the information in this post:
Hi
I m using Armbian_5.77_Aml-s812_Ubuntu_bionic_default_3.10.108_desktop_20190326.img
wich i don't know but i guess it could be a fork.
Anyway i can't find any script (even in the /root folder) that can make me install the OS in the emmc . I always update and upgrade all the packages and check with root permissions.
I even use the find command , but even the armlogic-config don't have the Install section
Thanks
The build you are using would be a build from balbes150's fork.  As you can see from the build date, that build is over a year old and on a kernel version (3.10) that is almost 7 years old.  If you value security you really shouldn't be using such an old build.  balbes150's work is now focused on current mainline kernels (5.4 or higher).  Since the build you are using predates my involvement in these forums, I have no idea if installation to internal storage is possible with what you are using.
Hi SteeMan
My minix has that age, i tried to use the new packages but i have to use the img that works for my kernel (3.10)
Just looking for a method to make the SD system works on my emmc
Thanks
@balbes150 i did not get wifi work with dts/dtb files , when i use dts from github linux ( inclusive precompile with cpp) i always get "deferred probe " loop , with dtb(from image) to dts and than edit -> i got "SDIO MMC failed highspeed mode " .
it looks like many of the needed lines for wifi in meson8m2-m8s.dtb are there, like SDIO Slot 0  and Wifi32k Timer/PWM and ResetGPIO  but still nothing show up ( i can not find all information because dtb to dts are not 100% same as orginal dts ).
also some option have negativ effects to the box
i needed 5 restart from the old 3.10 kernel image because of sdio timeout and gpio32 loops now works again i think i stay at old image till someone get onboard wifi work again in newer 5.x kernel version .
maybe you can get me the orginal dts (maybe precompile) file for m8s that is inside your image ?
On 4/9/2020 at 7:29 PM, Nikeb said:
Hi SteeMan
Thanks
sorry to bother you guys again.
the 5.77 version works perfectly on the minix neo x8-h plus from the SD card, is there a way to cloning it to the native emmc of minix?
could i use clonezilla to put the entire system inside the emmc?
@balbes150 since the is not the nand-sata-install script is there a way to do it?
thanks
No
Only manual operations and if the UART console is available.
Hi, I am having trouble finding what version to install on a OTT Tv Box M8N, presumably with AMLogic S802. Can someone link a source ?
On 4/12/2020 at 9:39 PM, RaptorSDS said:
please can i get the orginal dts file that you use for meson8m2-m8s.dtb from your 20.05 (kernel 5.6)
29 minutes ago, balbes150 said:
sorry but inside also only the dts like torvalds linux for odroid , mxiii, neox8 ; the dts for meson8m2-m8s missing
Hi there,
Thanks for making this port work.
I have "minix x8-h plus" and was finally able to boot using image Armbian_5.77_Aml-s812_Ubuntu_bionic_default_3.10.108_20190326. Couldn't get wifi to work, but doesn't really matter as I have working wired eth.
(As an aside - I am not sure if there are more up to date images that work for this hardware - the images listed in the OP didn't boot, perhaps are built for more modern hardware?)
Anyway, I am very pleased with the 5.77 build with one problem - it won't start without a monitor attached to HDMI. I hoped to have this as a headless linux server. Is there any magic setting that can make it boot without HDMI cable connected?
Thanks!
..I had no problems that the box didn't start, but I had just a tiny desktop via vnc, so my solution for the un-attached monitor was/is a cheap 3,50€ hdmi-fake-monitor-plug..maybe this could solve your non-boot-issue cheap and easy too?!
The new version of images 20200427. Everyone who has the opportunity to test the wired network for s805\s812\s802. This is important for the developer of this direction, Martin. It needs feedback on how the wired network will work in the latest version of the core. To check it, you need to run a simple test and post the results here.
    start iperf3 on your computer with: "iperf3 -s"
    on the device: "iperf3 -c <computer IP>"
    after that on the device: "iperf3 -c -R <computer IP>"
iperf3 results for following S812 device:
OTT M8S clone with 'S812-20160116 V1.2' and 'M9&M8_8bit_V1.1 2015/09/02'
Device has IP101GR 100Mbit phy, 2G/8G
To avoid conflict with display framebuffer (random noise over HDMI output) and dtb loading over kernel address space (9.4MB kernel) I used the following load addresses in s805_autoscript:
kernel 0x21000000
uInitrd 0x22000000
envvars 0x21F00000
dtb    0x21E00000
EMMC seems disabled in dtb by default
Booting with meson8m2-m8s.dtb
Results with Armbian_20.05.0_Aml-S812_buster_current_5.6.0-20200331
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-10.01  sec   111 MBytes  92.6 Mbits/sec                  receiver
[ ID] Interval           Transfer     Bitrate         Retr
[  5]   0.00-10.00  sec   113 MBytes  95.1 Mbits/sec    0             sender
Results with Armbian_20.05.3_Aml-S812_buster_current_5.7.0-rc3-gbec-4f44648-dirty-20200427
I can't get this to boot. It hangs at the stage of mounting root filesystem:
Freeing unused kernel memory:2048K
Run /init as init process
process /usr/bin/sh started with executable stack
Any suggestions on how to debug please? I have checked the SD card burn is OK and fsck on the partitions.
emulti
These are test versions that are constantly changing, so don't expect them to be stable and work correctly.
I'm not expecting testing images to be stable/working, but I am trying to help you with the testing as you requested.
Probably the failure to mount ROOTFS is not connected to the ethernet changes, but 5.7.0-rc2 did produce a stack trace on ethernet probing as below.
Tested M8S with the following:
5.6.0:
[  5]   0.00-10.01  sec   111 MBytes  92.9 Mbits/sec                  receiver
[  5]   0.00-10.00  sec   113 MBytes  94.8 Mbits/sec    0             sender
5.7.0-rc2
Does not boot. Kernel oops related to ethernet interface with trace in dmesg:
------------[ cut here ]------------
[   32.504222] WARNING: CPU: 1 PID: 80 at drivers/base/dd.c:270 driver_deferred_probe_check_state+0x5c/0x68
[   32.513703] meson8b-dwmac c9410000.ethernet: deferred probe timeout, ignoring dependency
[   32.513705] Modules linked in:
[   32.524758] CPU: 1 PID: 80 Comm: kworker/1:2 Not tainted 5.7.0-rc2-aml-s812-g2faf66a18-dirty #20.05.3
[   32.533941] Hardware name: Amlogic Meson platform
[   32.538627] Workqueue: events deferred_probe_work_func
[   32.543752] [<c03119b8>] (unwind_backtrace) from [<c030bb6c>] (show_stack+0x10/0x14)
[   32.551458] [<c030bb6c>] (show_stack) from [<c0709b2c>] (dump_stack+0xc0/0xd4)
[   32.558653] [<c0709b2c>] (dump_stack) from [<c0345ae4>] (__warn+0xd0/0xf8)
[   32.565498] [<c0345ae4>] (__warn) from [<c0345ec8>] (warn_slowpath_fmt+0x94/0xb8)
[   32.572953] [<c0345ec8>] (warn_slowpath_fmt) from [<c09c1884>] (driver_deferred_probe_check_state+0x5c/0x68)
[   32.582751] [<c09c1884>] (driver_deferred_probe_check_state) from [<c09d8948>] (__genpd_dev_pm_attach+0x140/0x1a0)
[   32.593063] [<c09d8948>] (__genpd_dev_pm_attach) from [<c09cb54c>] (dev_pm_domain_attach+0x1c/0x24)
[   32.602078] [<c09cb54c>] (dev_pm_domain_attach) from [<c09c367c>] (platform_drv_probe+0x2c/0x98)
[   32.610833] [<c09c367c>] (platform_drv_probe) from [<c09c1690>] (really_probe+0x1e0/0x344)
[   32.619067] [<c09c1690>] (really_probe) from [<c09c1930>] (driver_probe_device+0x60/0x168)
[   32.627301] [<c09c1930>] (driver_probe_device) from [<c09bfb60>] (bus_for_each_drv+0x80/0xc4)
[   32.635796] [<c09bfb60>] (bus_for_each_drv) from [<c09c143c>] (__device_attach+0xd0/0x13c)
[   32.644031] [<c09c143c>] (__device_attach) from [<c09c0814>] (bus_probe_device+0x84/0x8c)
[   32.652179] [<c09c0814>] (bus_probe_device) from [<c09c0ca4>] (deferred_probe_work_func+0x64/0x90)
[   32.661110] [<c09c0ca4>] (deferred_probe_work_func) from [<c0361904>] (process_one_work+0x22c/0x568)
[   32.670211] [<c0361904>] (process_one_work) from [<c0361ee8>] (worker_thread+0x2a8/0x5d4)
[   32.678359] [<c0361ee8>] (worker_thread) from [<c0367eb4>] (kthread+0x150/0x154)
[   32.685727] [<c0367eb4>] (kthread) from [<c03001a8>] (ret_from_fork+0x14/0x2c)
[   32.692917] Exception stack(0xedf31fb0 to 0xedf31ff8)
[   32.697946] 1fa0:                                     00000000 00000000 00000000 00000000
[   32.706095] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   32.714242] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[   32.720842] ---[ end trace 20ce4bf72c18d31c ]---
[   32.725453] meson8b-dwmac: probe of c9410000.ethernet failed with error -110
[   32.732842] ------------[ cut here ]------------
[   32.737044] WARNING: CPU: 1 PID: 80 at drivers/base/dd.c:270 driver_deferred_probe_check_state+0x5c/0x68
[   32.746497] stmmaceth c9410000.ethernet: deferred probe timeout, ignoring dependency
[   32.746498] Modules linked in:
[   32.757238] CPU: 1 PID: 80 Comm: kworker/1:2 Tainted: G        W         5.7.0-rc2-aml-s812-g2faf66a18-dirty #20.05.3
[   32.767809] Hardware name: Amlogic Meson platform
[   32.772494] Workqueue: events deferred_probe_work_func
[   32.777613] [<c03119b8>] (unwind_backtrace) from [<c030bb6c>] (show_stack+0x10/0x14)
[   32.785324] [<c030bb6c>] (show_stack) from [<c0709b2c>] (dump_stack+0xc0/0xd4)
[   32.792519] [<c0709b2c>] (dump_stack) from [<c0345ae4>] (__warn+0xd0/0xf8)
[   32.799366] [<c0345ae4>] (__warn) from [<c0345ec8>] (warn_slowpath_fmt+0x94/0xb8)
[   32.806822] [<c0345ec8>] (warn_slowpath_fmt) from [<c09c1884>] (driver_deferred_probe_check_state+0x5c/0x68)
[   32.816617] [<c09c1884>] (driver_deferred_probe_check_state) from [<c09d8948>] (__genpd_dev_pm_attach+0x140/0x1a0)
[   32.826931] [<c09d8948>] (__genpd_dev_pm_attach) from [<c09cb54c>] (dev_pm_domain_attach+0x1c/0x24)
[   32.835946] [<c09cb54c>] (dev_pm_domain_attach) from [<c09c367c>] (platform_drv_probe+0x2c/0x98)
[   32.844701] [<c09c367c>] (platform_drv_probe) from [<c09c1690>] (really_probe+0x1e0/0x344)
[   32.852935] [<c09c1690>] (really_probe) from [<c09c1930>] (driver_probe_device+0x60/0x168)
[   32.861170] [<c09c1930>] (driver_probe_device) from [<c09bfb60>] (bus_for_each_drv+0x80/0xc4)
[   32.869665] [<c09bfb60>] (bus_for_each_drv) from [<c09c143c>] (__device_attach+0xd0/0x13c)
[   32.877900] [<c09c143c>] (__device_attach) from [<c09c0814>] (bus_probe_device+0x84/0x8c)
[   32.886048] [<c09c0814>] (bus_probe_device) from [<c09c0ca4>] (deferred_probe_work_func+0x64/0x90)
[   32.894978] [<c09c0ca4>] (deferred_probe_work_func) from [<c0361904>] (process_one_work+0x22c/0x568)
[   32.904079] [<c0361904>] (process_one_work) from [<c0361ee8>] (worker_thread+0x2a8/0x5d4)
[   32.912227] [<c0361ee8>] (worker_thread) from [<c0367eb4>] (kthread+0x150/0x154)
[   32.919595] [<c0367eb4>] (kthread) from [<c03001a8>] (ret_from_fork+0x14/0x2c)
[   32.926786] Exception stack(0xedf31fb0 to 0xedf31ff8)
[   32.931814] 1fa0:                                     00000000 00000000 00000000 00000000
[   32.939964] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   32.948111] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[   32.954707] ---[ end trace 20ce4bf72c18d31d ]---
[   32.959322] stmmaceth: probe of c9410000.ethernet failed with error -110
5.7.0-rc3
does not boot, as in above message, but no kernel oops related to ethernet interface.
I hope this information is helpful.
Emulti
From comparison analysis of the dmesg it seems that with 5.7.x-rc images the SDHC card is not detected with this m8S board.
Same with a kernel built manually from xdarklight's Git branch 'meson-mx-integration-5.8-20200411'.
With 5.6 images dmesg includes
meson-mx-sdhc c1108e00.mmc: got CD GPIO
and the SDHC partitions are detected.
On 5.7.x this line is absent and SDHC partitions are not detected. This would account for rootfs mounting failure.
I will investigate changes in dtb and report back.
emulti
